12-Network Management and Monitoring Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10312-Network Management and Monitoring Command Reference
03-NTP Commands
03-NTP Commands 154.95 KB
display ntp-service sessions
display ntp-service sessions [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays the detailed information of all NTP sessions. If you do not specify this keyword, only the brief information of the NTP sessions will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ntp-service sessions command to view the information of all NTP sessions.
# View the brief information of NTP service sessions.
<Sysname> display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]127.127.1.0     127.127.1.0        3     1   64   33    0.0    0.0    0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  1
Table 1 Output description
source
IP address of the clock source
reference
Reference clock ID of the clock source
1.      If the reference clock is the local clock, the value of this field is related to the value of the stra field:
¡ When the value of the stra field is 0 or 1, this field will be “LOCL”;
¡ When the stra field has another value, this filed will be the IP address of the local clock
2.      If the reference clock is the clock of another router on the network, the value of this field will be the IP address of that router.
stra
Stratum level of the clock source, which determines the clock precision. The value range is 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
reach
Reachability count of the clock source. 0 indicates that the clock source in unreachable
poll
Poll interval, namely the maximum interval between successive NTP messages.
now
The length of time in minutes from when the last NTP message was received or when the local clock was last updated to the current time
The time is in second by default. If the time length is greater than 2048 seconds, it is displayed in minute; if greater than 300 minutes, in hour; if greater than 96 hours, in day.
offset
The offset of the system clock relative to the reference clock, in milliseconds
delay
the roundtrip delay from the local router to the clock source, in milliseconds
disper
The maximum error of the system clock relative to the reference source.
[12345]
·       1—Clock source selected by the system, namely the current reference source, with a system clock stratum level of ≤ 15
·       2—Stratum level of this system source is ≤ 15
·       3—This clock source has passed the clock selection process
·       4—This clock source is a candidate clock source
·       5—This clock source was created by a configuration command
Total associations
Total number of associations
# View the detailed information of all NTP sessions.
<Sysname> display ntp-service sessions verbose
 clock source: 127.127.1.0
 clock stratum: 3
 clock status: configured, master, sane, valid
 reference clock ID: 127.127.1.0
 local mode: client, local poll: 6
 peer mode: server, peer poll: 6
 offset: 0.0000 ms,delay: 0.00 ms,  disper: 0.02 ms
 root delay: 0.00 ms, root disper: 10.00 ms
 reach: 1, sync dist: 0.010, sync state: 2
 precision: 2^18, version: 3, peer interface: InLoopBack0
 reftime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 orgtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 rcvtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.7149E881)
 xmttime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71464DC2)
 filter delay :  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter offset:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter disper:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 reference clock status: working abnormally
 timecode:
Table 2 Output description
clock source
clock stratum
clock status
Status of the clock source corresponding to this session, including
·       configured—The session was created by a configuration command.
·       dynamic—This session is established dynamically.
·       master—The clock source is the primary reference source of the current system.
·       selected—The clock source has survived the clock selection algorithm.
·       candidate—The clock source is the candidate reference source.
·       sane—The clock source has passed the sane authentication.
·       insane—The clock source has failed the sane authentication.
·       valid—The clock source is valid, which means the clock source meet the following requirements: it has passed the authentication and is being synchronized; its stratum level is valid; its root delay and root dispersion values are within their ranges.
·       invalid—The clock source is invalid.
·       unsynced—The clock source has not been synchronized or the value of the stratum level is invalid.
reference clock ID
1.      If the reference clock is the local clock, the value of this field is related to the stratum level of the clock source:
¡ When the stratum level of the clock source is 0 or 1, this field will be “LOCL”;
¡ When the stratum level of the clock source has another value, this field will be the IP address of the local clock.
local mode
Operation mode of the local router, including
·       unspec—The mode is unspecified.
·       active—Active mode.
·       passive—Passive mode.
·       client—Client mode.
·       server—Server mode.
·       bdcast—Broadcast server mode.
·       control—Control query mode.
·       private—Private message mode.
local poll
Poll interval of the local router, in seconds. The value displayed is a power of 2, for example, if the displayed value is 6, it indicates that the poll interval of the local router is 26, that is, 64 seconds.
peer mode
Operation mode of the peer router, including
peer poll
Poll interval of the peer router, in seconds. The value displayed is a power of 2, for example, if the displayed value is 6, it indicates that the poll interval of the local router is 26, that is, 64 seconds.
offset
delay
The roundtrip delay from the local router to the clock source, in milliseconds
disper
The maximum error of the system clock relative to the reference clock
root delay
The roundtrip delay from the local router to the primary reference source, in milliseconds
root disper
The maximum error of the system clock relative to the primary reference clock, in milliseconds
reach
Reachability count of the clock source. 0 indicates that the clock source is unreachable.
sync dist
The synchronization distance relative to the upper-level clock, in seconds, and calculated from dispersion and roundtrip delay values.
sync state
State of the state machine
The displayed value is an integral that ranges from 0 to 5.
precision
Precision of the system clock
version
NTP version
The displayed value is an integral that ranges from 1 to 3.
peer interface
Source interface
If the source interface is not specified, this field will be wildcard.
reftime
Reference timestamp in the NTP message
orgtime
Originate timestamp in the NTP message
rcvtime
Receive timestamp in the NTP message
xmttime
Transmit timestamp in the NTP message
filter delay
Delay information
filter offset
Offset information
filter disper
Dispersion information
Status of the reference clock, including
·       working normally
·       working abnormally
timecode
Time code
Total associations
When a router is working in the NTP broadcast/multicast server mode, the display ntp-service sessions command executed on the router does not display the NTP session information corresponding to the broadcast/multicast server, but the sessions will be counted in the total number of associations.
display ntp-service status
display ntp-service status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ntp-service status command to view the NTP service status information.
# View the NTP service status information.
<Sysname> display ntp-service status
Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^17
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Table 3 Output description
Clock status
Status of the system clock, including
·       Synchronized—The system clock has been synchronized.
·       Unsynchronized—The system clock has not been synchronized.
Clock stratum
Stratum level of the local clock
Reference clock ID
After the system clock is synchronized to a remote time server, this field indicates the address of the remote time server;
After the system clock is synchronized to a local reference source, this field indicates the identifier of the local clock source:
·       When the local clock has a stratum level of 1, the value of this field is “LOCL”;
·       When the local clock has another value, the value of this filed is the IP address of the local clock.
Nominal frequency
The nominal frequency of the local system hardware clock, in Hz
Actual frequency
The actual frequency of the local system hardware clock, in Hz
Clock precision
The precision of the system clock
Clock offset
The offset of the system clock relative to the reference source, in milliseconds
Root delay
Root dispersion
The maximum error of the system clock relative to the primary reference source, in milliseconds
Peer dispersion
The maximum error of the system clock relative to the reference source, in milliseconds
Reference time
Reference timestamp
display ntp-service trace
display ntp-service trace [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ntp-service trace command view the brief information of each NTP server along the NTP server chain from the local router back to the primary reference source.
The display ntp-service trace command is available only if the local router can ping all the routers on the NTP server chain; otherwise, this command will fail to display all the NTP servers on the NTP chain due to timeout.
# View the brief information of each NTP server from the local router back to the primary reference source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The information above shows an NTP server chain for the server 127.0.0.1: The server 127.0.0.1 is synchronized to the server 133.1.1.1, and the server 133.1.1.1 is synchronized to the local clock source.
Table 4 Output description
server
IP address of the NTP server
stratum
The stratum level of the corresponding system clock
offset
The clock offset relative to the upper-level clock, in seconds
synch distance
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock.
ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Default level
3: Manage level
peer: Specifies to permit full access. This level of right permits the peer routers to perform synchronization and control query to the local router and also permits the local router to synchronize its clock to that of a peer router. Control query refers to query of NTP status information, such as alarm information, authentication status, and clock source information.
query: Specifies to permit control query. This level of right permits the peer routers to perform control query to the NTP service on the local router but does not permit a peer router to synchronize its clock to that of the local router.
server: Specifies to permit server access and query. This level of right permits the peer routers to perform synchronization and control query to the local router but does not permit the local router to synchronize its clock to that of a peer router.
synchronization: Specifies to permit server access only. This level of right permits a peer router to synchronize its clock to that of the local router but does not permit the peer routers to perform control query.
acl-number: Specifies a basic ACL number, which ranges from 2000 to 2999.
Use the ntp-service access command to configure the access-control right for the peer routers to access the NTP services of the local router.
Use the undo ntp-service access command to remove the configured NTP service access-control right to the local router.
By default, the access-control right for the peer routers to access the NTP services of the local router is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When a router receives an NTP request, it performs an access-control right match and uses the first matched right. If no matched right is found, the router discards the NTP request.
The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication. The related command is ntp-service authentication enable.
Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
# Configure the peer routers on subnet 10.10.0.0/16 to have the full access right to the local router.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
undo ntp-service authentication enable
View
Default level
3: Manage level
None
Use the ntp-service authentication enable command to enable NTP authentication.
Use the undo ntp-service authentication enable command to disable NTP authentication.
By default, NTP authentication is disabled.
Related commands: ntp-service authentication-keyid and ntp-service reliable authentication-keyid.
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Default level
3: Manage level
keyid: Authentication key ID, which ranges from 1 to 4294967295.
authentication-mode md5 value: Specifies to use the MD5 algorithm for key authentication, where value represents authentication key and is a string of 1 to 32 characters.
Use the ntp-service authentication-keyid command to set the NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove the set NTP authentication key.
By default, no NTP authentication key is set.
In a network where there is a high security demand, the NTP authentication feature should be enabled for a system running NTP. This feature enhances the network security by means of the client-server key authentication, which prohibits a client from synchronizing with a router that has failed authentication.
After the NTP authentication key is configured, you need to configure the key as a trusted key by using the ntp-service reliable authentication-keyid command.
CAUTION
CAUTION:
·       Presently the system supports only the MD5 algorithm for key authentication.
·       You can set a maximum of 1,024 keys for each router.
·       If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
Related commands: ntp-service reliable authentication-keyid.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Default level
3: Manage level
None
Use the ntp-service broadcast-client command to configure the router to work in the NTP broadcast client mode and use the current interface to receive NTP broadcast packets.
Use the undo ntp-service broadcast-client command to remove the configuration.
By default, the router does not work in any NTP operation mode.
# Configure the router to work in the broadcast client mode and receive NTP broadcast messages on GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ntp-service broadcast-client
ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Default level
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid ranges from 1 to 4294967295. This parameter is not meaningful if authentication is not required.
version number: Specifies the NTP version, where number ranges from 1 to 3 and defaults to 3.
Use the ntp-service broadcast-server command to configure the router to work in the NTP broadcast server mode and use the current interface to send NTP broadcast packets.
Use the undo ntp-service broadcast-server command to remove the configuration.
# Configure the router to work in the broadcast server mode and send NTP broadcast messages on GigabitEthernet 3/1/1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-GigabitEthernet3/1/1] ntp-service broadcast-server authentication-keyid 4 version 3
ntp-service in-interface disable
undo ntp-service in-interface disable
View
Interface view
Default level
3: Manage level
None
Use the ntp-service in-interface disable command to disable an interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to restore the default.
By default, an interface is enabled to receive NTP messages.
# Disable interface GigabitEthernet 3/1/1 from receiving NTP messages.
[Sysname] interface GigabitEthernet3/1/1
[Sysname-GigabitEthernet3/1/1] ntp-service in-interface disable
ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Default level
3: Manage level
number: Maximum number of dynamic NTP sessions that allowed to be established, which ranges from 0 to 100.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions that allowed to be established locally.
Use the undo ntp-service max-dynamic-sessions command to restore the maximum number of dynamic NTP sessions to the system default.
By default, the number is 100.
A single router can have a maximum of 128 associations at the same time, including static associations and dynamic associations. A static association refers to an association that a user has manually created by using an NTP command, while a dynamic association is a temporary association created by the system during operation. A dynamic association will be removed if the system fails to receive messages from it over a specific long time. In the client/server mode, for example, when you carry out a command to synchronize the time to a server, the system will create a static association, and the server will just respond passively upon the receipt of a message, rather than creating an association (static or dynamic). In the symmetric mode, static associations will be created at the symmetric-active peer side, and dynamic associations will be created at the symmetric-passive peer side; in the broadcast or multicast mode, static associations will be created at the server side, and dynamic associations will be created at the client side.
# Set the maximum number of dynamic NTP sessions allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Default level
3: Manage level
ip-address: Multicast IP address, which defaults to 224.0.1.1.
Use the ntp-service multicast-client command to configure the router to work in the NTP multicast client mode and use the current interface to receive NTP multicast packets.
Use the undo ntp-service multicast-client command to remove the configuration.
# Configure the router to work in the multicast client mode and receive NTP multicast messages on GigabitEthernet 3/1/1, and set the multicast address to 224.0.1.1.
[Sysname-GigabitEthernet3/1/1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Default level
3: Manage level
ip-address: Multicast IP address, defaulting to 224.0.1.1.
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients, where keyid ranges from 1 to 4294967295. This parameter is not meaningful if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number ranges from 1 to 255 and defaults to 16.
Use the ntp-service multicast-server command to configure the router to work in the NTP multicast server mode and use the current interface to send NTP multicast packets.
Use the undo ntp-service multicast-server command to remove the configuration.
# Configure the router to work in the multicast server mode and send NTP multicast messages on GigabitEthernet 3/1/1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-GigabitEthernet3/1/1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
ntp-service refclock-master
undo ntp-service refclock-master [ ip-address ]
View
Default level
3: Manage level
ip-address: IP address of the local clock, which is 127.127.1.u, where u is the NTP process ID, which ranges from 0 to 3. If you do not specify ip-address, it defaults to 127.127.1.0.
stratum: Stratum level of the local clock, which ranges from 1 to 15 and defaults to 8.
Use the ntp-service refclock-master command to configure the local clock as a reference source for other routers.
Use the undo ntp-service refclock-master command to remove the local clock as a reference source.
The stratum level of a clock defines the clock precision. The value ranges from 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
# Specify the local clock as the reference source, with the stratum level of 3.
[Sysname] ntp-service refclock-master 3
undo ntp-service reliable authentication-keyid keyid
View
Default level
3: Manage level
keyid: Authentication key number, which ranges from 1 to 4294967295.
Use the ntp-service reliable authentication-keyid command to specify that the created authentication key is a trusted key. When NTP authentication enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use the ntp-service reliable authentication-keyid command to remove an authentication key as a trusted key.
No authentication key is configured to be trusted by default.
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Default level
3: Manage level
interface-type interface-number: Specifies an interface by its interface type and interface number.
Use the ntp-service source-interface command to specify the source interface for NTP messages.
Use the undo ntp-service source-interface command to restore the default.
By default, no source interface is specified for NTP messages, and the system uses the IP address of the interface determined by the matched route as the source IP address of NTP messages.
If you do not wish the IP address of a certain interface on the local router to become the destination address of response messages, you can use this command to specify the source interface for NTP messages, so that the source IP address in NTP messages is the primary IP address of this interface.
# Specify the source interface of NTP messages as GigabitEthernet 3/1/1.
[Sysname] ntp-service source-interface GigabitEthernet 3/1/1
ntp-service unicast-peer
ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | peer-name }
View
Default level
3: Manage level
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the symmetric-passive peer belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the symmetric-passive peer is on the public network, do not specify this option.
ip-address: IP address of the symmetric-passive peer. It must be a unicast address, rather than a broadcast address, a multicast address or the IP address of the local clock.
peer-name: Host name of the symmetric-passive peer, which is a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid ranges from 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local router sends to its peer, the source IP address is the primary IP address of this interface. interface-type interface-number represents the interface type and number.
Use the ntp-service unicast-peer command to designate a symmetric-passive peer for the router.
Use the undo ntp-service unicast-peer command to remove the symmetric-passive peer designated for the router.
No symmetric-passive peer is designated for the router by default.
·       To synchronize the PE to a PE or CE in a VPN, provide vpn-instance vpn-instance-name in your command.
·       If you include vpn-instance vpn-instance-name in the undo ntp-service unicast-peer command, the command will remove the symmetric-passive peer with the IP address of ip-address in the specified VPN; if you do not include vpn-instance vpn-instance-name in this command, the command will remove the symmetric-passive peer with the IP address of ip-address in the public network.
Designate the router with the IP address of 10.1.1.1 as the symmetric-passive peer of the local router, configure the local router to run NTP version 3, and specify the source interface of NTP messages as GigabitEthernet 3/1/1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface GigabitEthernet 3/1/1
ntp-service unicast-server
ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number  ] *
undo ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name }
View
Default level
3: Manage level
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the NTP server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the NTP server is on the public network, do not specify this option.
ip-address: IP address of the NTP server. It must be a unicast address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, which is a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid ranges from 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local router sends to the NTP server, the source IP address is the primary IP address of this interface. interface-type interface-number represents the interface type and number.
Use the ntp-service unicast-server command to designate an NTP server for the router.
Use the undo ntp-service unicast-server command to remove an NTP server designated for the router.
No NTP server is designated for the router by default.
# Designate the router with the IP address of as 10.1.1.1 an NTP server for the router.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
