12-Network Management and Monitoring Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10312-Network Management and Monitoring Command Reference
12-Protocol Packet Statistics Commands
12-Protocol Packet Statistics Commands 56.36 KB
display to-cpu-packet statistics
display to-cpu-packet statistics { interface interface-type interface-number | [ protocol protocol-type ] slot slot-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays statistics for protocol packets passed to the CPU from the specified interface.
protocol protocol-type: Displays statistics for packets of the specified protocol that have been passed to the CPU. Supported protocols include: ARP, BGP, BGP4+, BPDU-tunnel, DHCP, DOT1X, GVRP, ICMP, IGMP, IP-lasthop, IP-to-localIF, ISIS, LACP, LDP, MLD, MPLS-lasthop, MSDP, ND, NTP, OSPF, OSPFv3, PIM, PIM-IPv6, RIP, RIPng, RSVP, STP, VRRP.
slot slot-number: Displays statistics for protocol packets passed to the CPU from the card in the specified slot.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display to-cpu-packet statistics command to view protocol packet statistics.
If you do not specify the protocol protocol-type option, the command displays statistics for protocol packets of all protocol types on the card in the specified slot.
# Display statistics for ARP packets passed from the card in slot 3 to the CPU.
<Sysname> display to-cpu-packet statistics protocol arp slot 3
Slot: 3
The total received packets of ARP: 0
Interface            Protocol type         Received packets
GE3/1/1               ARP                       0
GE3/1/2               ARP                       0
GE3/1/3               ARP                       0
GE3/1/4               ARP                       0
# Display statistics for protocol packets passed from GigabitEthernet 3/1/1 to the CPU.
<Sysname> display to-cpu-packet statistics interface gigabitethernet 3/1/1
Slot: 3
The total received packets of port GE3/1/1: 0
GE3/1/1               ARP                       0
GE3/1/1               BGP                       0
GE3/1/1               BGP4+                     0
GE3/1/1               BPDU-tunnel               0
GE3/1/1               DHCP                      0
GE3/1/1               802.1X                    0
GE3/1/1               GVRP                      0
GE3/1/1               ICMP                      0
GE3/1/1               IP-lasthop                0
GE3/1/1               IP-to-localIF             0
GE3/1/1               IGMP                      0
GE3/1/1               ISIS                      0
GE3/1/1               LACP                      0
GE3/1/1               LDP                       0
GE3/1/1               MSDP                      0
GE3/1/1               MPLS-lasthop              0
GE3/1/1               MLD                       0
GE3/1/1               NTP                       0
GE3/1/1               ND                        0
GE3/1/1               OSPF                      0
GE3/1/1               OSPFv3                    0
GE3/1/1               PIM                       0
GE3/1/1               PIM IPv6                  0
GE3/1/1               RIP                       0
GE3/1/1               RIPng                     0
GE3/1/1               RSVP                      0
GE3/1/1               STP                       0
GE3/1/1               VRRP                      0
reset to-cpu-packet statistics
reset to-cpu-packet statistics slot slot-number
View
Default level
1: Monitor level
slot slot-number: Clears statistics for protocol packets passed to the CPU from the card in the specified slot.
Use the reset to-cpu-packet statistics command to clear statistics for protocol packets passed to the CPU.
The command clears only the statistics for protocol packets passed from the specified card to the CPU.
# Clear the statistics for protocol packets passed to the CPU from the card in slot 2.
<Sysname> reset to-cpu-packet statistics slot 2
