06-Layer 3 - IP Routing Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10306-Layer 3 - IP Routing Command Reference
10-OSPFv3 Commands
10-OSPFv3 Commands 252.36 KB
The term router in the document refers to both routers and Layer 3 switches.
abr-summary (OSPFv3 area view)
abr-summary ipv6-address prefix-length [ not-advertise ]
undo abr-summary ipv6-address prefix-length
View
OSPFv3 area view
Default level
2: System level
ipv6-address: Destination IPv6 address of the summary route.
prefix-length: Prefix length of the destination IPv6 address, in the range 0 to 128. This argument specifies the number of consecutive 1s of the prefix, which defines the network ID.
not-advertise: Specifies not to advertise the summary IPv6 route.
Use the abr-summary command to configure an IPv6 summary route on an area border router.
Use the undo abr-summary command to remove an IPv6 summary route. Then the summarized routes are advertised.
By default, no route summarization is available on an ABR.
You can use this command only on an ABR to configure a summary route for the area. The ABR advertises only the summary route to other areas. Multiple contiguous networks may be available in an area, where you can summarize them with one route for advertisement.
# Summarize networks 2000:1:1:1::/64 and 2000:1:1:2::/64 in Area 1 with 2000:1:1::/48.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
area (OSPFv3 view)
area area-id
View
OSPFv3 view
Default level
2: System level
area-id: ID of an area, a decimal integer (in the range of 0 to 4294967295 and changed to IPv4 address format by the system) or an IPv4 address.
Use the area command to enter OSPFv3 area view.
The undo form of the command is not available. An area is removed automatically if no configuration is made and no interface is up in the area.
# Enter OSPFv3 Area 0 view.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
bandwidth-reference
bandwidth-reference value
undo bandwidth-reference
View
OSPFv3 view
Default level
2: System level
value: Bandwidth reference value for link cost calculation, in the range 1 to 2147483648 Mbps.
Use the bandwidth-reference command to specify a reference bandwidth value for link cost calculation.
Use the undo bandwidth-reference command to restore the default value.
The default value is 100 Mbps.
You can configure an OSPFv3 cost for an interface with one of the following methods:
·           Configure the cost value in interface view.
·           Configure a bandwidth reference value, and OSPFv3 computes the cost automatically based on the bandwidth reference value: Interface OSPFv3 cost = Bandwidth reference value/Interface bandwidth. If the calculated cost is greater than 65535, the value of 65535 is used.
If no cost value is configured for an interface, OSPFv3 computes the interface cost value automatically.
# Specify the reference bandwidth value as 1000 Mbps.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] bandwidth-reference 1000
default cost
default cost value
undo default cost
View
OSPFv3 view
Default level
2: System level
value: Specifies a default cost for redistributed routes, in the range of 1 to 16777214.
Use the default cost command to configure a default cost for redistributed routes.
Use the undo default cost command to restore the default.
By default, the default cost is 1.
You need to configure the default cost value for redistributed routes to advertise them throughout the whole AS.
If multiple OSPFv3 processes are available, use of this command takes effect for the current process only.
# Specify the default cost for redistributed routes as 10.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default cost 10
default-cost (OSPFv3 area view)
default-cost value
undo default-cost
View
OSPFv3 area view
Default level
2: System level
value: Specifies a cost for the default route advertised to the stub area, in the range of 0 to 65535. The default is 1.
Use the default-cost command to specify the cost of the default route to be advertised to the stub area.
Use the undo default-cost command to restore the default value.
Use of this command is only available on the ABR that is connected to a stub area.
You have two commands to configure a stub area: stub, defaulted-cost. You need to use the stub command on routers connected to a stub area to configure the area as stub.
If multiple OSPFv3 processes are running, use of this command takes effect only for the current process.
Related commands: stub.
# Configure Area1 as a stub area, and specify the cost of the default route advertised to the stub area as 60.
[Sysname] ospfv3
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
default-route-advertise
default-route-advertise [ always | cost value | route-policy route-policy-name | type type ] *
undo default-route-advertise
View
OSPFv3 view
Default level
2: System level
always: Generates a default route in an ASE LSA into the OSPF routing domain regardless of whether the default route exists in the  routing table. Without this keyword, the command can distribute a default route in a Type-5 LSA into the OSPF routing domain only when the default route exists in the routing table.
cost value: Specifies a cost for the default route, in the range 1 to 16777214. The default is 1.
route-policy route-policy-name: Specifies a routing policy, the name of which is a case-sensitive string of 1 to 63 characters.
type type: Specifies a type for the ASE LSA: 1 or 2. The default is 2.
Use the default-route-advertise command to generate a default route into the OSPF routing domain.
Use the undo default-route-advertise command to disable OSPF from redistributing a default route.
By default, no default route is redistributed.
Using the import-route command cannot redistribute a default route. To do so, you need to use the default-route-advertise command. If no default route exists in the router's routing table, use the default-route-advertise always command to generate a default route in a Type-5 LSA.
You can reference a routing policy to set the cost and type of the default route:
·           The router advertises the default route only when it passes the routing policy.
·           The default route passing the routing policy uses the cost set by the apply cost clause, and the type set by the apply cost-type clause in the routing policy.
·           The default route cost’s priority from high to low is: the cost set by the apply cost clause in the routing policy, the one set by the default-route-advertise command and the one set by the default cost command.
·           The default route type’s priority from high to low is: the type set by the apply cost-type clause in the routing policy, and the one set by the default-route-advertise command.
·           If the always keyword is included, the default route is advertised regardless of whether it passes the routing policy and uses the cost and type specified by the apply cost, apply cost-type clauses in the first node of the routing policy.
Related commands: import-route.
# Generate a default route into the OSPFv3 routing domain.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default-route-advertise always
display ospfv3
display ospfv3 [ process-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Specifies the ID of an OSPFv3 process, ranging from 1 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ospfv3 command to display the brief information of an OSPFv3 process. If no process ID is specified, OSPFv3 brief information about all processes will be displayed.
# Display brief information about all OSPFv3 processes.
<Sysname> display ospfv3
Routing Process "OSPFv3 (1)" with ID 1.1.1.1
 Graceful restart restarter enabled
 Graceful restart helper enabled
 Graceful restart helper srtict-lsa-checking enabled
 Graceful restart interval 150 secs
 SPF schedule delay 5 secs, Hold time between SPFs 10 secs
 Minimum LSA interval 5 secs, Minimum LSA arrival 1 secs
 Number of external LSA 0. These external LSAs’ checksum Sum 0x0000
 Number of AS-Scoped Unknown LSA 0
 Number of LSA originated 3
 Number of LSA received 0
 Number of areas in this router is 1
  Area 0.0.0.1
       Number of interfaces in this area is 1
       SPF algorithm executed 1 times
       Number of LSA 2. These LSAs’ checksum Sum 0x20C8
       Number of Unknown LSA 0
       IPsec policy name: policy001, SPI: 300
Table 1 Output description
OSPFv3 process is 1, and router ID is 1.1.1.1.
The current process supports GR.
The current process supports the GR Helper capability.
The current process supports GR Helper strict LSA checking.
GR restart interval.
SPF schedule delay
Delay interval of SPF calculation.
Hold time between SPF calculations.
Minimum interval for generating LSAs.
Minimum LSA arrival
Minimum LSA repeat arrival interval.
Number of ASE LSAs.
Sum of all the ASE LSAs’ checksum.
Number of LSAs with unknown flooding scope.
Number of LSAs originated.
Number of LSAs received.
Number of areas this router is attached to.
Area
Area ID.
Number of interfaces attached to this area.
SPF algorithm is executed 1 time.
Number of LSA
Number of LSAs.
Sum of all LSAs’ checksum.
Number of unknown LSAs.
IPsec policy name
IPsec policy used.
SPI
SPI defined in the IPsec policy.
display ospfv3 graceful-restart status
display ospfv3 [ process-id ] graceful-restart status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: ID of an OSPFv3 process, ranging from 1 to 65535.
Use the display ospfv3 graceful-restart status command to display GR status of the specified OSPFv3 process.
If no process ID is specified, GR status of all processes will be displayed.
# Display GR status of all OSPFv3 processes (GR Restarter).
<Sysname> display ospfv3 graceful-restart status
           OSPFv3 Router with ID (1.1.1.1) (Process 1)
             graceful restart  information
GR status        : GR in progress
GR remaining time: 100
# Display GR status of all OSPFv3 processes (GR Helper).
GR status: Helper
Neighbor ID    Interface  Instance ID  Remaining time
1.1.1.1        GE3/1/1     1            100
2.2.2.2        GE3/1/2     2            200
Table 2 Output description
The GR status of OSPFv3 process 1 with router ID 1.1.1.1 is displayed.
GR status
GR status:
·       GR in progress—Indicates GR is in process.
·       Calculating routes—Indicates route calculation is in process.
·       Flushing LSAs—Indicates the router is flushing stale LSA.
·       Normal—Indicates the router is not in GR or Helper status.
·       Helper—Indicates the Helper status.
GR remaining time
Remaining time before the GR timer expires.
Neighbor ID
Router ID of the neighbor router.
Outbound interface.
Instance ID
Instance ID.
display ospfv3 interface
display ospfv3 interface [ interface-type interface-number | statistic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
statistic: Displays the interface statistics.
Use the display ospfv3 interface command to display OSPFv3 interface information.
# Display OSPFv3 interface information.
<Sysname> display ospfv3 interface GigabitEthernet 2/1/1
GigabitEthernet2/1/1 is up, line protocol is up
  Interface ID 518
  IPv6 Prefixes
    FE80::1441:0:E213:1 (Link-Local Address)
    2000:1::1
  OSPFv3 Process (1), Area 0.0.0.1, Instance ID 0
    Router ID 2.2.2.2, Network Type POINTOPOINT, Cost: 1562
    Transmit Delay is 1 sec, State Point-To-Point, Priority 1
    No designated router on this link
    No backup designated router on this link
    Timer interval configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
       Hello due in 00:00:02
Neighbor Count is 1, Adjacent neighbor count is 1
    BFD: Enabled
Table 3 Output description
Interface ID
Interface ID.
IPv6 Prefixes
IPv6 Prefix.
OSPFv3 Process
OSPFv3 Process.
Area
Area ID.
Instance ID
Instance ID.
Router ID
Router ID
Network Type
Network type of the interface.
Cost
Cost value of the interface.
Transmit Delay
Transmission delay of the interface.
Interface state.
Priority
DR priority of the interface.
No designated router on this link.
No backup designated router on this link.
Time intervals in seconds configured on the interface:
·       Hello—Hello interval.
·       Dead—Dead interval.
·       Wait—After this timer expires, the interface quits from the waiting state.
·       Retransmit—LSA retransmission interval.
Hello packet will be sent in 2 seconds.
Neighbor Count
Number of Neighbors on the interface.
Number of Adjacencies on the interface.
IPsec policy name
IPsec policy used on the interface.
SPI
BFD
BFD status on the interface (enabled or disabled).
display ospfv3 lsdb
display ospfv3 [ process-id ] lsdb [ [ external | inter-prefix | inter-router | intra-prefix | link | network | router | grace ] [ link-state-id ] [ originate-router router-id ] | total ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Specifies ID of an OSPFv3 process, ranging from 1 to 65535.
external: Displays information about AS-external LSAs.
inter-prefix: Displays information about Inter-area-prefix LSAs.
inter-router: Displays information about Inter-area-router LSAs.
intra-prefix: Displays information about Intra-area-prefix LSAs.
link: Displays information about Link-LSAs.
network: Displays information about Network-LSAs.
router: Displays information about Router-LSAs.
grace: Displays information about Grace-LSAs
link-state-id: Link state ID, an IPv4 address.
originate-router router-id: ID of the advertising router .
total: Displays the LSA statistics in the LSDB.
Use the display ospfv3 lsdb command to display OSPFv3 LSDB information.
# Display OSPFv3 LSDB information.
<Sysname> display ospfv3 lsdb
           OSPFv3 Router with ID (2.2.2.2) (Process 1)
               Link-LSA (Interface GigabitEthernet3/1/1)
Link State ID   Origin Router    Age   Seq#       CkSum  Prefix
0.0.2.6         1.1.1.1          0055  0x80000001 0x4642      0
0.0.2.6         2.2.2.2          0053  0x80000001 0xf267      0
               Grace-LSA (Interface GigabitEthernet3/1/1)
0.0.2.6         1.1.1.1          100   0x8000004  0xba1f
               Router-LSA (Area 0.0.0.1)
Link State ID   Origin Router    Age   Sep#       CkSum    Link
0.0.0.0         1.1.1.1          0050  0x80000002 0x12d1      1
0.0.0.0         2.2.2.2          0048  0x80000002 0xa142      1
Table 4 Output description
Link-LSA
Type 8 LSA
Link State ID
Link State ID
Origin Router
Originating router
Age
Age of LSAs
Seq#
LSA sequence number
CkSum
LSA checksum
Prefix
Number of prefixes
Router-LSA
Router-LSA
Link
Number of links
Network-LSA
Network-LSA
Intra-Area-Prefix-LSA
Type 9 LSA
Grace-LSA
Type 11 LSA
Reference
Type of referenced LSA
# Display Link-local LSA information in the LSDB.
<Sysname> display ospfv3 lsdb link
                Link-LSA (Interface GigabitEthernet2/1/1)
  LS age: 11
  LS Type: Link-LSA
  Link State ID: 0.0.2.6
  Originating Router: 2.2.2.2
  LS Seq Number: 0x80000002
  Checksum: 0xEFFA
  Length: 56
  Priority: 1
  Options: 0x000013 (-|R|-|-|E|V6)
  Link-Local Address: FE80::1441:0:E213:1
  Number of Prefixes: 1
    Prefix: 2000:1::/64
    Prefix Options: 0 (-|-|-|-)
Table 5 Output description
LS age
Age of LSA
LS Type
Type of LSA
Originating Router
Originating router
LS Seq Number
LSA sequence number
Checksum
LSA checksum
Length
LSA length
Priority
Router priority
Options
Options
Link-Local Address
Link-local address
Number of Prefixes
Number of prefixes
Prefix
Address prefix
Prefix Options
Prefix options
# Display Grace-LSA information in the LSDB.
<Sysname> display ospfv3 lsdb grace
                Grace-LSA (Interface GigabitEthernet2/1/1)
  LS age                 : 15
  LS Type                : Grace-LSA
  Link State ID          : 0.0.2.6
  Originating Router     : 1.1.1.1
  LS Seq Number          : 0x80000014
  Checksum               : 0XBA1F
  Length                 : 44
  Graceful Restart Period:  120
  Restart Reason         :   3 - switch-over
Table 6 Output description
LS age
Age of LSA
LS Type
Type of LSA
Originating Router
Originating router
LS Seq Number
LSA sequence number
Checksum
LSA checksum
Length
LSA length
GR restart interval
Restart Reason
Cause of the GR restart
# Display LSA statistics in the LSDB.
<Sysname> display ospfv3 lsdb total
            OSPFv3 (Process 1) Database Total
  Type Of LSA                      Number
  Router-LSA              :        1
  Network-LSA             :        0
  Inter-Area-Prefix-LSA   :        0
  Inter-Area-Router-LSA   :        0
  AS-external-LSA         :        0
  Link-LSA                :        1
  Intra-Area-Prefix-LSA   :        0
  Grace-LSA               :        0
  Unknown-LSA             :        0
  Total Number Of LSAs    :        2
Table 7 Output description
Type Of LSA
Type of LSA
Number
Number of LSAs
Router-LSA
Type 1 LSA
Network-LSA
Type 2 LSA
Type 3 LSA
Type 4 LSA
AS-external-LSA
Type 5 LSA
Link-LSA
Type 8 LSA
Type 9 LSA
Grace-LSA
Type 11 LSA
Unknown-LSA
Unknown LSA
Total number of LSAs
display ospfv3 lsdb statistic
display ospfv3 lsdb statistic [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospfv3 lsdb statistic command to display LSA statistics in the OSPFv3 LSDB.
# Display OSPFv3 LSDB statistics.
<System> display ospfv3 lsdb statistic
                           LSA Statistics
Area ID         Router   Network  InterPre InterRou IntraPre Link Grace ASE
0.0.0.0         2        1        1        0        1
0.0.0.1         1        0        1        0        1
Total           3        1        2        0        2        3    0     0
Table 8 Output description
Area ID
Area ID
Router
Router-LSA number
Network
Network-LSA number
InterPre
Inter-Area-Prefix-LSA number
InterRou
Inter-Area-Router-LSA number
IntraPre
Intra-Area-Prefix-LSA number
Link
Link-LSA number
Grace
Grace-LSA number
ASE
AS-external-LSA number
Total
Total LSA number
display ospfv3 next-hop
display ospfv3 [ process-id ] next-hop [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospfv3 next-hop command to display OSPFv3 next hop information.
If no process is specified, next hop information of all OSPFv3 processes is displayed.
# Display OSPFv3 next hop information.
<Sysname> display ospfv3 next-hop
Neighbor-Id     Next-Hop                              Interface   RefCount
1.1.1.1         FE80::20F:E2FF:FE00:1                 GE1/1/1      1
Table 9 Output description
Neighbor-Id
Neighboring router ID
Next-hop
Next-hop address
Outbound interface
RefCount
Reference count
display ospfv3 peer
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
area: Specifies to display neighbor information of the specified area.
area-id: The ID of an area, a decimal integer that is translated into IPv4 address format by the system (in the range of 0 to 4294967295) or an IPv4 address.
verbose: Display detailed neighbor information.
peer-router-id: Router-ID of the specified neighbor.
Use the display ospfv3 peer command to display OSPFv3 neighbor information.
·           If no area-id is specified, the neighbor information of all areas is displayed.
·           If no process-id is specified, the information of all processes is displayed.
·           If no interface or neighbor Router-ID is specified, the neighbor information of all interfaces is displayed.
# Display the neighbor information of OSPFv3 process 1 on an interface.
<Sysname> display ospfv3 1 peer GigabitEthernet 2/1/1
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.1)
Neighbor ID     Pri   State            Dead Time   Interface  Instance ID
1.1.1.1         1     Full/ -          00:00:33    GE2/1/1        0
Table 10 Output description
Neighbor ID
Router ID of a neighbor
Pri
Priority of neighbor router
Neighbor state
Dead Time
Dead time remained
Interface connected to the neighbor
Instance ID
Instance ID
# Display detailed neighbor information of OSPFv3 process 100 of an interface.
<Sysname> display ospfv3 100 peer GigabitEthernet 2/1/1 verbose
OSPFv3 Process (100)
 Neighbor: 1.1.1.1, interface address: FE80::3D43:0:8C14:1
    In the area 0.0.0.1 via interface GigabitEthernet2/1/1
    DR is 0.0.0.0 BDR is 0.0.0.0
    Options is 0x000013 (-|R|-|-|E|V6)
    Dead timer due in 00:00:29
    Neighbor is up for 00:06:28
    Database Summary List 0
    Link State Request List 0
Link State Retransmission List 0
Graceful restart state: Normal
Table 11 Output description
Neighbor
Neighbor ID.
interface address
Interface address.
Interface GigabitEthernet 2/1/1 belongs to area 1.
Neither DR nor BDR is elected.
The option is 0x000013 (-|R|-|-|E|V6).
Dead timer due in 00:00:29.
Neighbor is up for 00:06:28.
Number of LSAs sent in DD packet.
Number of LSAs in the link state request list.
Number of LSAs in the link state retransmission list.
GR status:
·       Doing GR—Indicates that GR is in process.
·       Complete GR—Indicates the neighbor has completed GR.
·       Normal—Indicates normal status.
·       Helper—Indicates that the router is a GR Helper of the neighbor.
display ospfv3 peer statistic
display ospfv3 peer statistic [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospfv3 peer statistic command to display information about all OSPFv3 neighbors on the router—numbers of neighbors in different states.
# Display information about all OSPFv3 neighbors.
<Sysname> display ospfv3 peer statistic
                           Neighbor Statistics
Area ID         Down     Init     2-way    ExStar   Exchange Loading  Full
0.0.0.0         0        0        0        0        0        0        1
Total           0        0        0        0        0        0        1
Table 12 Output description
Area ID
Area ID.
Down
In this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Init
In this state, the router received a Hello packet from the neighbor but the packet contains no Router ID of the neighbor. Mutual communication is not setup.
2-Way
Indicates mutual communication between the router and its neighbor is available. DR/BDR election is finished under this state (or higher).
ExStart
In this state, the router decides on the initial DD sequence number and master/slave relationship of the two parties.
Exchange
In this state, the router exchanges DD packets with the neighbor.
Loading
In this state, the router sends LSRs to request the neighbor for needed LSAs.
Full
Indicates LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state.
display ospfv3 request-list
display ospfv3 [ process-id ] request-list [ { external | inter-prefix | inter-router | intra-prefix | link | network | router | grace } [ link-state-id ] [ originate-router ip-address ] | statistics ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: OSPFv3 process ID, in the range 1 to 65535.
external: Displays the AS-external LSA information of the OSPFv3 link state request list.
inter-prefix: Displays the Inter-area-prefix LSA information of the OSPFv3 link state request list.
inter-router: Displays the Inter-area-router LSA information of the OSPFv3 link state request list.
intra-prefix: Displays the Intra-area-prefix LSA information of the OSPFv3 link state request list.
link: Displays the Link LSA information of the OSPFv3 link state request list.
network: Displays the Network-LSA information of the OSPFv3 link state request list.
router: Displays the Router-LSA information of the OSPFv3 link state request list.
grace: Displays the Grace-LSA information of the OSPFv3 link state request list.
link-state-id: Link state ID, in the format of an IPv4 address.
originate-router ip-address: Specifies the router ID of an advertising router.
statistics: Displays the LSA statistics of the OSPFv3 link state request list.
Use the display ospfv3 request-list command to display OSPFv3 link state request list information.
If no process is specified, the link state request list information of all OSPFv3 processes is displayed.
# Display the information of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list
         OSPFv3 Router with ID (11.1.1.1) (Process 1)
             Interface GE1/1/2    Area-ID 0.0.0.0
                          Nbr-ID   12.1.1.1
LS-Type               LS-ID           AdvRouter       SeqNum       Age  CkSum
Router-LSA            0.0.0.0         12.1.1.1          0x80000014    774  0xe5b0
Table 13 Output description
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising router
SeqNum
LSA sequence number
Age
Age of LSA
CkSum
Checksum
# Display the statistics of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list statistics
Interface  Neighbor        LSA-Count
GE1/1/2    10.1.1.1        0
Table 14 Output description
Interface name
Neighbor
Neighbor router ID
LSA-Count
Number of LSAs in the request list
display ospfv3 retrans-list
display ospfv3 [ process-id ] retrans-list [ { external | inter-prefix | inter-router | intra-prefix | link | network | router | grace } [ link-state-id ] [ originate-router ip-address ] | statistics ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
external: Displays the AS-external LSA information of the OSPFv3 link state retransmission list.
inter-prefix: Displays the Inter-area-prefix LSA information of the OSPFv3 link state retransmission list.
inter-router: Displays the Inter-area-router LSA information of the OSPFv3 link state retransmission list.
intra-prefix: Displays the Intra-area-prefix LSA information of the OSPFv3 link state retransmission list.
link: Displays the Link LSA information of the OSPFv3 link state retransmission list.
network: Displays the Network-LSA information of the OSPFv3 link state retransmission list.
router: Displays the Router-LSA information of the OSPFv3 link state retransmission list.
grace: Displays the Grace-LSA information of the OSPFv3 link state retransmission list.
statistics: Displays the LSA statistics of the OSPFv3 link state retransmission list.
Use the display ospfv3 retrans-list command to display the OSPFv3 link state retransmission list.
If no process is specified, the link state retransmission list information of all OSPFv3 processes is displayed.
# Display the information of the OSPFv3 link state retransmission list.
<Sysname> display ospfv3 retrans-list
                          Nbr-ID   12.1.1.1
Link-LSA              0.15.0.24       12.1.1.1          0x80000003    519  0x7823
Table 15 Output description
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising Router
SeqNum
LSA sequence Number
Age
Age of LSA
CkSum
Checksum
# Display the statistics of OSPFv3 link state retransmission list.
<Sysname>display ospfv3 retrans-list statistics
GE1/1/2    12.1.1.1        2
Table 16 Output description
Interface name
Neighbor
Neighbor ID
LSA-Count
Number of LSAs in the retransmission request list
display ospfv3 routing
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length | ipv6-address/prefix-length | abr-routes | asbr-routes | all | statistics ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: IPv6 address prefix.
prefix-length: Prefix length, in the range 0 to 128.
abr-routes: Displays routes to ABR.
asbr-routes: Displays routes to ASBR.
all: Displays all routes.
statistics: Displays the OSPFv3 routing table statistics .
Use the display ospfv3 routing command to display OSPFv3 routing table information.
If no process is specified, routing table information of all OSPFv3 processes is displayed.
# Display OSPFv3 routing table information.
<Sysname> display ospfv3 routing
 E1 - Type 1 external route,    IA - Inter area route,    I  - Intra area route
 E2 - Type 2 external route,    *  - Seleted route
 *Destination: 2001::/64
  Type       : I                                        Cost     : 1
  NextHop    : directly-connected                       Interface: GE1/1/1
Table 17 Output description
Destination
Destination network segment
Route type
Cost
Route cost value
Next-hop
Next hop address
Outbound interface
# Display the statistics of OSPFv3 routing table.
<Sysname> display ospfv3 routing statistics
                           OSPFv3 Routing Statistics
 Intra-area-routes   :   1
 Inter-area-routes   :   0
 External-routes     :   0
Table 18 Output description
Intra-area-routes
Number of Intra-area-routes
Inter-area-routes
Number of inter-area routes
External-routes
Number of external routes
display ospfv3 statistic
display ospfv3 statistic [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospfv3 statistic command to display outbound/inbound OSPFv3 packet statistics on associated interface(s).
# Display outbound/inbound OSPFv3 packet statistics on associated interfaces.
<Sysname> display ospfv3 statistic
                       OSPFv3 Statistics
Interface GEernet1/1/1 Instance 0
 Type              Input       Output
 Hello             189         63
 DB Description    10          8
 Ls Req            2           1
 Ls Upd            16          6
 Ls Ack            10          6
 Discarded         0           0
Table 19 Output description
Interface name
Instance
Instance number
Type of packet
Input
Number of packets received by the interface
Output
Number of packets sent by the interface
Hello
Hello packet
DB Description
Database description packet
Ls Req
Link state request packet
Ls Upd
Link state update packet
Ls Ack
Link state acknowledgement packet
Discarded
Number of discarded packets
display ospfv3 topology
display ospfv3 [ process-id ] topology [ area area-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays the topology information of an OSPFv3 process; The process ID ranges from 1 to 65535.
area: Displays the topology information of the specified area.
area-id: ID of an area, a decimal integer (in the range of 0 to 4294967295) that is translated into IPv4 address format by the system or an IPv4 address.
Use the display ospfv3 topology command to display OSPFv3 topology information. If no process is specified, topology information of all OSPFv3 processes is displayed.
# Display OSPFv3 area 1 topology information.
<Sysname> display ospfv3 topology area 1
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.1) topology
Type  ID(If-Index)       Bits      Metric    Next-Hop        Interface
Rtr   1.1.1.1                      --
Rtr   2.2.2.2                      1         2.2.2.2         GE1/1/1
Rtr   3.3.3.3                      1         3.3.3.3         GE1/1/1
Rtr   4.4.4.4                      1         4.4.4.4         GE1/1/1
Net   4.4.4.4(983049)              1         0.0.0.0         GE1/1/1
Table 20 Output description
Type of node
ID(If-Index)
Router ID
Bits
Flag bit
Metric
Cost value
Next-Hop
Next hop
Outbound interface
display ospfv3 vlink
display ospfv3 [ process-id ] vlink [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospfv3 vlink command to display OSPFv3 virtual link information. If no process is specified, virtual link information of all OSPFv3 processes is displayed.
# Display OSPFv3 virtual link information.
<Sysname> display ospfv3 vlink
     Virtual Link VLINK1 to router 1.1.1.1 is up
       Transit area :0.0.0.1 via interface GigabitEthernet2/1/1, instance ID: 0
       Local address: 2000:1::1
       Remote address: 2001:1:1::1
       Transmit Delay is 1 sec, State: P-To-P,
       Timer intervals configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
         Adjacency state :Full
Table 21 Output description
The virtual link VLINK1 to router 1.1.1.1 is up.
Transit area 0.0.0.1 via interface GigabitEthernet2/1/1
Interface GigabitEthernet 2/1/1 in transit area 0.0.0.1.
instance ID
Instance ID.
Local address
Local IPv6 address.
Remote address
Remote IPv6 address.
Transmit Delay
Transmit delay of sending LSAs.
Interface state.
Timer intervals in seconds:
·       Hello—10.
·       Dead—40.
·       Wait—40.
·       Retransmit—5.
Send hello packets in 2 seconds.
Adjacency state
Adjacency state.
IPsec policy name
IPsec policy used on the virtual link.
SPI
enable ipsec-policy (OSPFv3 area view)
enable ipsec-policy policy-name
undo enable ipsec-policy
View
OSPFv3 area view
Default level
2: System level
policy-name: IPsec policy name, a string of 1 to 15 characters.
Use the enable ipsec-policy command to apply an IPsec policy in the OSPFv3 area.
Use the undo enable ipsec-policy command to remove the IPsec policy from the OSPFv3 area.
By default, no IPsec policy is applied in an area.
The IPsec policy to be applied must have been configured.
# Apply IPsec policy policy001 to OSPFv3 area 0.
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.0] enable ipsec-policy policy001
filter-policy export (OSPFv3 view)
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ bgp4+ | direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
undo filter-policy export [ bgp4+ | direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
View
OSPFv3 view
Default level
2: System level
acl6-number: Specifies the ACL6 number, ranging from 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list, a string of up to 19 characters.
bgp4+: Filters IPv6 BGP routes.
direct: Filters direct routes.
isisv6 process-id: Specifies to filter the routes of an IPv6 IS-IS process, which is in the range of 1 to 65535.
ospfv3 process-id: Specifies to filter the routes of an OSPFv3 process, which is in the range of 1 to 65535.
ripng process-id: Specifies to filter the routes of a RIPng process, which in the range of 1 to 65535.
static: Specifies to filter static routes.
Use the filter-policy export command to filter redistributed routes.
Use the undo filter-policy export command to remove the configuration.
By default, IPv6 OSPFv3 does not filter redistributed routes.
If no protocol is specified, all redistributed routes will be filtered.
·       If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command, the ACL should be configured with the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix command to deny/permit a route with the specified destination and prefix. The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route (the prefix must be valid; otherwise, the configuration is ineffective).
·       Using the filter-policy export command filters only routes redistributed by the import-route command. If the import-route command is not configured to redistribute routes from other protocols and other OSPFv3 processes, use of the filter-policy export command does not take effect.
# Filter all redistributed routes using IPv6 ACL 2001.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2002:1:: 64
[Sysname-acl6-basic-2001] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 2001 export
# Configure ACL6 3000 to permit only route 2001::1/128 to pass, and reference ACL6 3000 to filter redistributed routes.
[Sysname-acl6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl6-adv-3000] rule 100 deny ipv6
[Sysname-acl6-adv-3000] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 export
filter-policy import (OSPFv3 view)
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
undo filter-policy import
View
OSPFv3 view
Default level
2: System level
acl6-number: Specifies an ACL number, ranging from 2000 to 3999.
Use the filter-policy import command to configure OSPFv3 to filter routes computed from received LSAs.
Use the undo filter-policy import command to remove the configuration.
By default, OSPFv3 does not filter routes computed from received LSAs.
·       Using the filter-policy import command only filters routes computed by OSPFv3. The routes that fail to pass are not added to the routing table.
# Filter received routes using the IPv6 prefix list abc.
[Sysname] ip ipv6-prefix abc permit 2002:1:: 64
[Sysname] ospfv3 1
[Sysname-ospfv3-1] filter-policy ipv6-prefix abc import
# Configure ACL6 3000 to permit only route 2001::1/128 to pass, and reference ACL6 3000 to filter received routes.
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 import
graceful-restart enable
undo graceful-restart enable
View
OSPFv3 view
Default level
2: System level
None
Use the graceful-restart enable command to enable the GR capability for OSPFv3.
Use the undo graceful-restart enable command to disable the GR capability for OSPFv3.
By default, the GR capability for OSPFv3 is disabled.
You cannot enable the GR capability for an area of the current process already configured with the vlink-peer command.
# Enable the GR capability for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart enable
graceful-restart helper enable
undo graceful-restart helper enable
View
OSPFv3 view
Default level
2: System level
None
Use the graceful-restart helper enable command to enable the GR Helper capability for OSPFv3.
Use the undo graceful-restart helper enable command to disable the GR Helper capability for OSPFv3.
By default, the GR Helper capability for OSPFv3 is enabled.
# Enable the GR Helper capability for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper enable
graceful-restart helper strict-lsa-checking
undo graceful-restart helper strict-lsa-checking
View
OSPFv3 view
Default level
2: System level
None
Use the graceful-restart helper strict-lsa-checking command to enable strict LSA checking for the GR Helper. When an LSA change on the GR Helper is detected, the GR Helper router exits the GR Helper mode.
Use the undo graceful-restart helper strict-lsa-checking command to disable strict LSA checking for the GR Helper.
By default, strict LSA checking for the GR Helper is disabled.
# Enable strict LSA checking for the GR Helper in OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart interval interval-value
undo graceful-restart interval
View
OSPFv3 view
Default level
2: System level
interval-value: GR restart interval, in the range of 40 to 1800 seconds.
Use the graceful-restart interval command to configure the GR restart interval.
Use the undo graceful-restart interval command to restore the default.
By default, the GR restart interval is 120 seconds.
The value of the GR restart interval cannot be smaller than the maximum OSPFv3 neighbor dead time of all the OSPFv3 interfaces; otherwise, GR restart may fail.
Related commands: ospfv3 timer dead.
# Configure the GR restart interval for OSPFv3 process 1 as 100 seconds.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart interval 100
import-route (OSPFv3 view)
import-route protocol [ process-id | allow-ibgp ] [ cost value | route-policy route-policy-name | type type ] *
undo import-route protocol [ process-id ]
View
OSPFv3 view
Default level
2: System level
protocol: Redistributes routes from a specified routing protocol, which can be bgp4+, direct, isisv6, ospf v3, ripng, or static.
process-id: Process ID of the routing protocol, in the range 1 to 65536. It defaults to 1. This argument takes effect only when the protocol is isisv6, ospfv3, or ripng.
allow-ibgp: Allows redistributing IBGP routes. This keyword takes effect only the protocol is bgp4+.
cost value: Specifies a cost for redistributed routes, ranging from 1 to 16777214. The default is 1.
route-policy route-policy-name: Redistributes only the routes that match the specified routing policy. route-policy-name is a case-sensitive string of 1 to 19 characters.
type type: Specifies the type for redistributed routes, 1 or 2. It defaults to 2.
Using the import-route bgp4+ command redistributes only EBGP routes, and using the import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes.
Use the import-route command to redistribute routes.
Use the undo import-route command to disable routes redistribution.
IPv6 OSPFv3 does not redistribute routes from other protocols by default.
# Configure to redistribute routes from RIPng and specify the type as type 2 and cost as 50.
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# Configure OSPFv3 process 100 to redistribute the routes found by OSPFv3 process 160.
[Sysname] ospfv3 100
[Sysname-ospfv3-100] import-route ospfv3 160
log-peer-change
log-peer-change
undo log-peer-change
View
OSPFv3 view
Default level
2: System level
None
Use the log-peer-change command to enable the logging on neighbor state changes.
Use the undo log-peer-change command to disable the logging.
With this feature enabled, information about neighbor state changes of the current OSPFv3 process will display on the configuration terminal.
# Disable the logging on neighbor state changes of OSPFv3 process 100.
[Sysname-ospfv3-100] undo log-peer-change
maximum load-balancing (OSPFv3 view)
maximum load-balancing maximum
undo maximum load-balancing
View
OSPFv3 view
Default level
2: System level
maximum: Maximum number of equal-cost routes, in the range of 1 to 8. When it is set to 1, load balancing is not performed.
Use the maximum load-balancing command to configure the maximum number of equal-cost routes.
Use the undo maximum load-balancing command to restore the default.
By default, the maximum number of equal-cost routes is 8.
# Configure the maximum number of equal-cost routes as 6.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] maximum load-balancing 6
ospfv3
ospfv3 [ process-id ] [ vpn-instance vpn-instance-name ]
undo ospfv3 [ process-id ]
View
Default level
2: System level
process-id: OSPFv3 process ID, ranging from 1 to 65535. The process ID defaults to 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the OSPFv3 process belongs to the public network.
Use the ospfv3 command to enable an OSPFv3 process and enter OSPFv3 view.
Use the undo ospfv3 command to disable an OSPFv3 process.
The system runs no OSPFv3 process by default.
Related commands: router-id.
An OSPFv3 process can run properly only when router ID is configured in OSPFv3 view. Otherwise, you can find the process, but which cannot generate any LSA.
# Enable the OSPFv3 process with process ID as 120 and configure the Router ID as 1.1.1.1.
[Sysname] ospfv3 120
[Sysname-ospfv3-120] router-id 1.1.1.1
ospfv3 area
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
View
Interface view
Default level
2: System level
area-id: Area ID, a decimal integer (in the range of 0 to 4294967295) that is translated into IPv4 address format by the system or an IPv4 address.
instance-id: Instance ID of an interface, in the range 0 to 255. The default is 0.
Use the ospfv3 area command to enable an OSPFv3 process on the interface and specify the area for the interface.
Use the undo ospfv3 area command to disable an OSPFv3 process.
OSPFv3 is not enabled on an interface by default.
# Enable OSPFv3 process 1 on an interface that belongs to instance 1 and specify area 1 for the interface.
[Sysname] interface GigabitEthernet 2/1/1
[Sysname-GigabitEthernet2/1/1] ospfv3 1 area 1 instance 1
ospfv3 bfd enable
ospfv3 bfd enable [ instance instance-id ]
undo ospfv3 bfd enable [ instance instance-id ]
View
Interface view
Default level
2: System level
instance-id: Instance ID of the interface. It ranges from 0 to 255 and defaults to 0.
Use the ospfv3 bfd enable command to enable BFD for link failure detection on an OSPFv3 interface.
Use the undo ospfv3 bfd enable command to disable BFD on the OSPFv3 interface.
By default, the OSPFv3 interface is not enabled with BFD.
# Enable BFD on GigabitEthernet 3/1/1 in instance 1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ospfv3 bfd enable instance 1
ospfv3 cost
ospfv3 cost value [ instance instance-id ]
undo ospfv3 cost [ value ] [ instance instance-id ]
View
Interface view
Default level
2: System level
value: OSPFv3 cost, in the range 0 to 65535 for a loopback interface and 1 to 65535 for other interfaces.
instance-id: Instance ID of an interface, in the range of 0 to 255, which defaults to 0.
Use the ospfv3 cost command to configure the OSPFv3 cost of the interface in an instance.
Use the undo ospfv3 cost command to restore the default OSPFv3 cost of the interface in an instance.
By default, a router’s interface automatically calculates the OSPFv3 cost based on its bandwidth. For a VLAN interface, the cost value defaults to 1; for a loopback interface, the cost value defaults to 0.
# Specifies the OSPFv3 cost of the interface in instance 1 as 33.
[Sysname-GigabitEthernet2/1/1] ospfv3 cost 33 instance 1
ospfv3 dr-priority
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ priority ] [ instance instance-id ]
View
Interface view
Default level
2: System level
priority: DR priority, in the range 0 to 255.
instance-id: ID of the instance an interface belongs to, in the range 0 to 255, which defaults to 0.
Use the ospfv3 dr-priority command to set the DR priority for an interface in an instance.
Use the undo ospfv3 dr-priority command to restore the default value.
The DR priority on an interface defaults to 1.
An interface’s DR priority determines its privilege in DR/BDR selection, and the interface with the highest priority is preferred.
# Set the DR priority for an interface in instance 1 to 8.
[Sysname] interface GigabitEthernet 1/1/1
[Sysname-GigabitEthernet1/1/1] ospfv3 dr-priority 8 instance 1
ospfv3 ipsec-policy
ospfv3 ipsec-policy policy-name [ instance instance-id ]
undo ospfv3 ipsec-policy [ policy-name ] [ instance instance-id ]
View
Interface view
Default level
2: System level
instance-id: ID of the instance of the interface, in the range 0 to 255. It defaults to 0.
Use the ospfv3 ipsec-policy command to apply an IPsec policy on an OSPFv3 interface.
Use the undo ospfv3 ipsec-policy command to remove the IPsec policy from the OSPFv3 interface.
By default, no IPsec policy is applied on an OSPFv3 interface.
Note: The IPsec policy to be applied must have been configured.
# Apply IPsec policy policy001 to OSPFv3 interface GigabitEthernet 2/1/1.
[Sysname-GigabitEthernet2/1/1] ospfv3 ipsec-policy policy001 instance 1
ospfv3 mtu-ignore
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
View
Interface view
Default level
2: System level
instance-id: Instance ID, in the range 0 to 255, which defaults to 0.
Use the ospfv3 mtu-ignore command to configure an interface to ignore MTU check during DD packet exchange.
Use the undo ospfv3 mtu-ignore command to restore the default.
By default, an interface performs MTU check during DD packet exchange. A neighbor relationship can be established only if the interface’s MTU is the same as that of the peer.
# Configure an interface that belongs to instance 1 to ignore MTU check during DD packet exchange.
[Sysname-GigabitEthernet2/1/1] ospfv3 mtu-ignore instance 1
ospfv3 network-type
ospfv3 network-type { broadcast | nbma | p2mp [ non-broadcast ] | p2p } [ instance instance-id ]
undo ospfv3 network-type [ broadcast | nbma | p2mp [ non-broadcast ] | p2p ] [ instance instance-id ]
View
Interface view
Default level
2: System level
broadcast: Specifies the network type as Broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
p2p: Specifies the network type as P2P.
non-broadcast: Specifies the interface to send packets in unicast mode. By default, an OSPFv3 interface whose network type is P2MP sends packets in multicast mode.
instance-id: The instance ID of an interface, in the range of 0 to 255, which defaults to 0.
Use the ospfv3 network-type command to set the network type for an OSPFv3 interface.
Use the undo ospfv3 network-type command to restore the default.
By default, the network type of an interface depends on its link layer protocol. For example:
·           For PPP, the default network type is P2P.
·           For Ethernet, the default network type is broadcast.
# Configure the interface’s network type as NBMA.
[Sysname-GigabitEthernet3/1/1] ospfv3 network-type nbma
ospfv3 peer
ospfv3 peer ipv6-address [ dr-priority dr-priority ] [ instance instance-id ]
undo ospfv3 peer ipv6-address [ dr-priority dr-priority ] [ instance instance-id ]
View
Interface view
Default level
2: System level
ipv6-address: Neighbor link-local IP address.
dr-priority: Neighbor DR priority, in the range 0 to 255. The default is 1.
instance-id: Interface instance ID, in the range 0 to 255. The default is 0.
Use the ospfv3 peer command to specify a neighbor and the DR priority of the neighbor.
Use the undo ospfv3 peer command to remove the configuration.
A router uses the priority set with the ospfv3 peer command to determine whether to send a hello packet to the neighbor rather than use it for DR election.
# Specify the neighbor fe80::1111.
[Sysname-GigabitEthernet3/1/1] ospfv3 peer fe80::1111
ospfv3 timer dead
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ seconds ] [ instance instance-id ]
View
Interface view
Default level
2: System level
seconds: Dead time in seconds, ranging from 1 to 2147483647.
Use the ospfv3 timer dead command to configure the OSPFv3 neighbor dead time for an interface that belongs to a specified instance.
Use the undo ospfv3 timer dead command to restore the default.
By default, the OSPFv3 neighbor dead time is 40 seconds for P2P and Broadcast interfaces, and is not supported on P2MP and NBMA interfaces.
OSPFv3 neighbor dead time: if an interface receives no hello packet from a neighbor after dead time elapses, the interface will consider the neighbor dead.
The dead seconds value is at least four times the Hello seconds value and must be identical on interfaces attached to the same network segment.
Related commands: ospfv3 timer hello.
# Configure the OSPFv3 neighbor dead time as 80 seconds for the interface in instance 1.
[Sysname-GigabitEthernet2/1/1] ospfv3 timer dead 80 instance 1
ospfv3 timer hello
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ seconds ] [ instance instance-id ]
View
Interface view
Default level
2: System level
seconds: Interval between hello packets, ranging from 1 to 65535.
Use the ospfv3 timer hello command to configure the hello interval for an interface that belongs to an instance.
Use the undo ospfv3 timer hello command to restore the default .
By default, the hello interval is 10 seconds for P2P and Broadcast interfaces, and is not supported on the P2MP or NBMA interfaces.
# Configure the hello interval as 20 seconds for an interface in instance 1.
[Sysname-GigabitEthernet2/1/1] ospfv3 timer hello 20 instance 1
ospfv3 timer retransmit
ospfv3 timer retransmit interval [ instance instance-id ]
undo ospfv3 timer retransmit [ interval ] [ instance instance-id ]
View
Interface view
Default level
2: System level
interval: LSA retransmission interval in seconds, ranging from 1 to 65535.
Use the ospfv3 timer retransmit command to configure the LSA retransmission interval for an interface in an instance.
Use the undo ospfv3 timer retransmit command to restore the default.
The interval defaults to 5 seconds.
After sending a LSA to its neighbor, the router waits for an acknowledgement. If receiving no acknowledgement after the LSA retransmission interval elapses, it will retransmit the LSA.
The LSA retransmission interval should not be too small for avoidance of unnecessary retransmissions.
# Configure the LSA retransmission interval on an interface in instance 1 as 12 seconds.
[Sysname-GigabitEthernet1/1/1] ospfv3 timer retransmit 12 instance 1
ospfv3 timer poll
ospfv3 timer poll seconds [ instance instance-id ]
undo ospfv3 timer poll [ seconds ] [ instance instance-id ]
View
Interface view
Default level
2: System level
seconds: Poll interval in seconds, in the range 1 to 65535.
Use the ospfv3 timer poll command to set the poll interval on an NBMA interface.
Use the undo ospfv3 timer poll command to restore the default value.
By default, the poll interval is 120 seconds.
# Set the poll timer interval on the current interface to 130 seconds.
[Sysname-GigabitEthernet3/1/1] ospfv3 timer poll 130
ospfv3 trans-delay
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ seconds ] [ instance instance-id ]
View
Interface view
Default level
2: System level
seconds: Transmission delay in seconds, ranging from 1 to 3600.
instance-id: Instance ID of an interface, in the range of 0 to 255, with the default as 0.
Use the ospfv3 trans-delay command to configure the transmission delay for an interface with an instance ID.
Use the undo ospfv3 trans-delay command to restore the default.
The transmission delay defaults to 1s.
As LSAs are aged in the LSDB (incremented by 1 every second) but not aged on transmission, it is necessary to add a delay time to the age time before sending a LSA. This configuration is important for low-speed networks.
# Configure the transmission delay as 3 seconds for an interface in instance 1.
[Sysname-GigabitEthernet1/1/1] ospfv3 trans-delay 3 instance 1
preference
preference [ ase ] [ route-policy route-policy-name ] preference
undo preference [ ase ]
View
OSPFv3 view
Default level
2: System level
ase: Applies the preference to OSPFv3 external routes. If the keyword is not specified, the preference applies to OSPFv3 internal routes.
route-policy route-policy-name: References a routing policy to set preference for specific routes. The name is a case-sensitive string of 1 to 63 characters.
Preference: Preference of OSPFv3, in the range 1 to 255.
Use the preference command to specify a preference for OSPFv3 routes.
Use the undo preference command to restore the default.
By default, the preference for OSPFv3 internal routes is 10, and that for OSPFv3 external routes is 150.
The smaller the value is, the higher the preference is.
A router may run multiple routing protocols. Each protocol has a preference. When several routing protocols find multiple routes to the same destination, the route found by the protocol with the highest preference is selected.
# Set a preference of 150 for OSPFv3 routes.
[Sysname] OSPFv3
[Sysname-OSPFv3-1] preference 150
router-id
router-id router-id
undo router-id
View
OSPFv3 view
Default level
2: System level
router-id: 32-bit router ID, in IPv4 address format.
Use the router-id command to configure the OSPFv3 router ID.
Use the undo router-id command to remove a configured router ID.
Router ID is the unique identifier of a router running an OSPFv3 process in the AS. The OSPFv3 process cannot run without a Router ID.
Make sure that different processes have different Router IDs.
Related commands: ospfv3.
By configuring different router IDs for different processes, you can run multiple OSPFv3 processes on a router.
# Configure the Router ID as 10.1.1.3 for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
silent-interface(OSPFv3 view)
View
OSPFv3 view
Default level
2: System level
all: Specifies all interfaces.
Use the silent-interface command to disable the specified interface from receiving and sending OSPFv3 packets.
Use the undo silent-interface command to restore the default.
An interface is able to receive and send OSPFv3 packets by default.
Multiple processes can disable the same interface from receiving and sending OSPFv3 packets, but use of the silent-interface command takes effect only on interfaces enabled with the current process.
# Disable an interface from receiving and sending OSPFv3 packets in OSPFv3 processes 100 and 200.
[Sysname-ospfv3-100] router-id 10.110.1.9
[Sysname-ospfv3-100] silent-interface GigabitEthernet 1/1/1
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.18.0.7
[Sysname-ospfv3-200] silent-interface GigabitEthernet 1/1/1
spf timers
spf timers delay-interval hold-interval
undo spf timers
View
OSPFv3 view
Default level
2: System level
delay-interval: Interval in seconds between when OSPFv3 receives a topology change and when it starts SPF calculation. in the range 1 to 65535.
hold-interval: Hold interval in seconds between two consecutive SPF calculations, in the range 1 to 65535.
Use the spf timers command to configure the delay interval and hold interval for OSPFv3 SPF calculation.
Use the undo spf timers command to restore the default.
The delay interval and hold interval default to 5s and 10s.
An OSPFv3 router works out a shortest path tree with itself as root based on the LSDB, and decides on the next hop to a destination network according the tree. Adjusting the SPF calculation interval can restrain bandwidth and router resource from over consumption due to frequent network changes.
# Configure the delay interval and hold interval as 6 seconds for SPF calculation.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] spf timers 6 6
stub (OSPFv3 area view)
stub [ no-summary ]
undo stub
View
OSPFv3 area view
Default level
2: System level
no-summary: This argument is only applicable to the ABR of a stub area. With it configured, the ABR advertises only a default route in a Summary-LSA to the stub area (such an area is called a totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
By default, an area is not configured as a stub area.
When an area is configured as a stub area, all the routers attached to the area must be configured with the stub command.
Related commands: default-cost.
# Configure OSPFv3 area 1 as a stub area.
[Sysname] ospfv3 1
vlink-peer (OSPFv3 area view)
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | instance instance-id | ipsec-policy policy-name ] *
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead | ipsec-policy ] *
View
OSPFv3 area view
Default level
2: System level
router-id: Router ID for a virtual link neighbor.
hello seconds: Specifies the interval in seconds for sending Hello packets, ranging from 1 to 8192, with the default as 10. This value must be equal to the hello seconds configured on the virtual link peer.
retransmit seconds: Specifies the interval in seconds for retransmitting LSA packets, ranging from 1 to 3600, with the default as 5.
trans-delay seconds: Specifies the delay interval in seconds for sending LSA packets, ranging from 1 to 3600, with the default as 1.
dead seconds: Specifies the neighbor dead time in seconds, ranging from 1 to 32768, with the default as 40. This value must be equal to the dead seconds configured on the virtual link peer, and at least four times the value of hello seconds.
instance Instance-id: Instance ID of an virtual link, in the range of 0 to 255, with the default as 0.
ipsec-policy policy-name: Applies an IPsec policy, the name of which is a string of 1 to 15 characters.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
For a non-backbone area without a direct connection to the backbone area or for a backbone area that cannot maintain connectivity, you can use the vlink-peer command to create logical links. A virtual link can be considered as an interface with OSPFv3 enabled, because parameters such as hello, dead, retransmit and trans-delay are configured in the similar way.
Both ends of a virtual link are ABRs that are configured with the vlink-peer command.
Note that: If you have enabled the GR capability for the current process, you cannot execute the vlink-peer command for the process.
# Create a virtual link to 10.110.0.3.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 10.0.0.0
[Sysname-ospfv3-1-area-10.0.0.0] vlink-peer 10.110.0.3
