06-Layer 3 - IP Routing Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10306-Layer 3 - IP Routing Command Reference
07-Policy-Based Routing Commands
07-Policy-Based Routing Commands 103.69 KB
apply access-vpn vpn-instance
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
View
PBR policy node view
Default level
2: System level
vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters.
Use the apply access-vpn vpn-instance command to set one or multiple VPN instances.
Use the undo apply access-vpn vpn-instance command to remove one or multiple specified VPN instances.
·       The specified VPN instance(s) must exist.
·       You can set one VPN instance for a policy node.
# Set the VPN instance, vpn1, for forwarding packets.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1
apply ip-address default next-hop
apply ip-address default next-hop ip-address [ track track-entry-number ] [ ip-address [ track track-entry-number ] ]
undo apply ip-address default next-hop [ ip-address [ ip-address ] ]
View
Default level
2: System level
ip-address: IP address of the default next hop.
track track-entry-number: Specifies a track entry. The track-entry-number argument is in the range 1 to 1024.
Use the apply ip-address default next-hop command to set the default next hop(s).
Use the undo apply ip-address default next-hop command to remove the configuration.
Note the following:
·           At most two default next hops can be specified in one command line.
·           Using the undo apply ip-address default next-hop command with a next hop specified removes the default next hop. Using this command without any next hop specified removes all default next hops.
# Set the default next hop to 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply ip-address default next-hop 1.1.1.1 track 1
apply ip-address next-hop
apply ip-address next-hop ip-address [ direct ] [ track track-entry-number ] [ ip-address [ direct ] [ track track-entry-number ] ]
undo apply ip-address next-hop [ ip-address [ ip-address ] ]
View
Default level
2: System level
ip-address: IP address of the next hop.
direct: Specifies the current next hop as valid when it is a directly connected next hop.
Use the apply ip-address next-hop command to set the next hop(s) for packets.
Use the undo apply ip-address next-hop command to remove the configuration.
You can specify up to two next hops in one command line for load sharing.
Using the undo apply ip-address next-hop command with a next hop specified removes the next hop. Using this command without any next hop specified removes all next hops.
# Set the directly connected next hop to 1.1.1.1.
[Sysname-pbr-aa-11] apply ip-address next-hop 1.1.1.1 direct
apply ip-precedence
apply ip-precedence value
undo apply ip-precedence
View
Default level
2: System level
value: Sets the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and the corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
Use the apply ip-precedence command to set a precedence for packets.
Use the undo apply ip-precedence command to remove the configuration.
# Set the precedence to 5 (critical) for packets.
[Sysname-pbr-aa-11] apply ip-precedence critical
display ip policy-based-route
display ip policy-based-route [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ip policy-based-route command to display the PBR routing information.
# Display the PBR routing information.
<Sysname> display ip policy-based-route
Policy Name                interface
pr02                       local
pr02                       Virtual-Template0
pr01                       GigabitEthernet 3/1/1
Table 2 Output description
Policy Name
Policy name.
interface
PBR type.
This field displays local for a local PBR or a specific interface (such as Virtual-template 0) to which the policy has been applied to implement interface PBR.
display ip policy-based-route setup
display ip policy-based-route setup { policy-name | interface interface-type interface-number [ slot slot-number ] | local [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays the PBR routing information of the specified policy. A policy name is a string of 1 to 19 characters.
interface interface-type interface-number: Displays the PBR routing information on the specified interface.
local: Displays the local PBR information.
slot slot-number: Displays the PBR routing information on a card. slot-number represents the number of the slot that holds the card.
Use the display ip policy-based-route setup command to display the specified PBR routing information.
# Display the PBR routing information of policy pr01.
<Sysname> display ip policy-based-route setup pr01
 policy Name             interface
 pr01                    GigabitEthernet3/1/1
# Display the PBR routing information on GigabitEthernet 3/1/1.
<Sysname> display ip policy-based-route setup interface GigabitEthernet3/1/1
 Interface GigabitEthernet3/1/1 policy based routing configuration information:
 policy-based-route: pr01
   permit node 1:
     if-match acl 3101
     apply ip-address next-hop 1.1.2.2
# Display the local PBR routing information.
<Sysname> display ip policy-based-route setup local
 Local policy based routing configuration information:
   permit node 1:
     if-match acl 3101
Table 3 Output description
policy Name
Policy name.
interface
Interface where the policy is applied. Local means the policy is applied locally.
Local PBR information.
policy-based-route
Policy name.
permit node 1
The match mode is permit, and the policy has a node (node 1).
if-match acl 3101
Match packets against ACL 3101.
The next hop is 1.1.2.2.
display ip policy-based-route statistics
display ip policy-based-route statistics { interface interface-type interface-number | local } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the statistics of PBR on the specified interface.
local: Displays the statistics of local PBR.
Use the display ip policy-based-route statistics command to display PBR statistics.
# Display the statistics of PBR on GigabitEthernet 3/1/1.
<Sysname> display ip policy-based-route statistic interface GigabitEthernet 3/1/1
 Interface GigabitEthernet3/1/1 policy based routing statistics information:
 policy-based-route: aaa
   permit node 5:
     if-match acl 3101
   matched: 0
 Total matched: 0
Table 4 Output description
PBR statistics on GigabitEthernet 3/1/1.
The policy name is aaa.
permit node 5
The match mode of node 5 is permit.
matched: 0
Matching packets on node 5.
Total matched: 0
Total matching packets on all nodes.
display policy-based-route
display policy-based-route [ policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays information about the specified policy. A policy name is a string of 1 to 19 characters.
Use the display policy-based-route command to display PBR policy information.
If no policy name is specified, all PBR policy information is displayed. If a policy name is specified, information about the specified policy is displayed.
# Display the PBR policy information.
<Sysname> display policy-based-route
policy-based-route : aaa
    Node 5 permit :
       if-match acl 3101
Table 5 Output description
Node  5  permit :
The matching mode of node 5 is permit.
if-match acl 3101
if-match acl
if-match acl acl-number
undo if-match acl
View
Default level
2: System level
acl-number: ACL number, in the range of 2000 to 3999. The number of a basic ACL ranges from 2000 to 2999 and that of an advanced ACL ranges from 3000 to 3999.
Use the if-match acl command to define an ACL match criterion.
Use the undo if-match acl command to remove the ACL match criterion.
# Permit the packets matching ACL 2010.
[Sysname-pbr-aa-11] if-match acl 2010
ip local policy-based-route
ip local policy-based-route policy-name
undo ip local policy-based-route policy-name
View
Default level
2: System level
policy-name: Policy name, a string of 1 to 19 characters.
Use the ip local policy-based-route command to configure local PBR based on a specified policy.
Use the undo ip local policy-based-route command to remove the configuration.
No policy is referenced for local PBR by default.
Only one policy can be referenced for local PBR.
Local PBR is used to route packets generated locally. Unless otherwise required, H3C does not recommend configuring local PBR.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
ip policy-based-route policy-name
undo ip policy-based-route policy-name
View
Interface view
Default level
2: System level
Use the ip policy-based-route command to configure PBR on the interface.
Use the undo ip policy-based-route command to remove the configuration.
No policy is referenced for interface PBR by default.
Note the following:
·           Only one policy can be referenced by an interface for PBR.
·           The referenced policy applies to all packets arriving on the interface.
# Configure PBR based on policy aaa on GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ip policy-based-route aaa
policy-based-route
undo policy-based-route policy-name [ deny | node node-number | permit ]
View
Default level
2: System level
deny: Specifies the match mode of the policy node as deny.
permit: Specifies the match mode of the policy node as permit.
node node-number: Number of a policy node, in the range of 0 to 65535. A node with a smaller node-number has a higher match priority than a node with a greater one.
Use the policy-based-route command to create a policy, policy node, or both, and enter PBR policy node view.
Use the undo policy-based-route command to remove a created policy or policy node.
No policy or policy node is created by default.
The default match mode of a policy node is permit.
# Configure the match mode of node 10 of policy 1 as permit, and enter PBR policy node view.
reset policy-based-route statistics
reset policy-based-route statistics [ policy-name ]
View
Default level
1: Monitor level
Use the reset policy-based-route statistics command to clear PBR statistics.
If no policy name is specified, this command clears all the PBR statistics.
# Clear all PBR statistics.
<Sysname> reset policy-based-route statistics
