06-Layer 3 - IP Routing Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10306-Layer 3 - IP Routing Command Reference
13-IPv6 Policy-Based Routing Commands
13-IPv6 Policy-Based Routing Commands 82.96 KB
IPv6 policy-based routing configuration commands
apply ipv6-address next-hop
apply ipv6-address next-hop ipv6-address
undo apply ipv6-address next-hop [ ipv6-address ]
View
IPv6 PBR policy node view
Default level
2: System level
ipv6-address: IPv6 address of a next hop.
Use the apply ipv6-address next-hop command to set a next hop.
Use the undo apply ipv6-address next-hop command to remove the next hop.
The next hop must be adjacent to the router.
You can specify up to two next hops. Only one next hop is active at a time. When the active next hop becomes invalid, the other next hop takes effect.
Using the undo apply ipv6-address next-hop command with a next hop specified removes the next hop. Using this command without any next hop specified removes all next hops.
# Set a next hop of 1::1 for IPv6 packets.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply ipv6-address next-hop 1::1
apply ipv6-precedence
apply ipv6-precedence { type | value }
undo apply ipv6-precedence
View
Default level
2: System level
type: Sets a preference type.
value: Sets a preference value from 0 to 7 (inclusive). Each value corresponds to a keyword, as shown in Table 1.
Table 1 Preferences and the corresponding keywords
Preference value
Keyword
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
Use the apply ipv6-precedence command to set a preference or preference type for IPv6 packets.
Use the undo apply ipv6-precedence command to remove the clause.
# Set a preference of 5 (critical).
[Sysname-pbr6-aa-11] apply ipv6-precedence critical
display ipv6 config policy-based-route
display ipv6 config policy-based-route [ policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Policy name, a string of 1 to 19 characters.
slot slot-number: Displays the IPv6 PBR policy information of a specific board.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ipv6 config policy-based-route command to display the IPv6 PBR policy information.
If no policy name is specified, all the IPv6 PBR policy information is displayed. If a policy name is specified, information about the specified policy is displayed.
If no slot number is specified, all the IPv6 PBR policy information is displayed, as long as the policies are defined. If a slot number is specified, the IPv6 PBR policy information on the specified board is displayed, as long as the policies are applied to the system or an interface of the specified board.
# Display all IPv6 PBR policy information.
<Sysname> display ipv6 config policy-based-route
 IPv6 Policy based routing configuration information:
policy-based-route : abc
   Node  6  permit :
     if-match acl6 3001
       1::2
Table 2 Output description
IPv6 policy information.
policy-based-route: abc
Name of the referenced policy.
Node  6  permit :
The matching mode of Node 6 is permit.
if-match acl6 3001
Match IPv6 packets against ACL 3001.
apply ipv6-address next-hop 1::2
Next hop specified for matched packets is 1::2.
display ipv6 policy-based-route setup
display ipv6 policy-based-route setup { policy-name | interface interface-type interface-number [ slot slot-number ] | local [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the IPv6 PBR routing information on the specified interface.
local: Displays the IPv6 local PBR information.
slot slot-number: Displays the IPv6 PBR routing information on a card. slot-number represents the number of the slot that holds the card.
Use the display ipv6 policy-based-route setup command to display the specified IPv6 PBR routing information.
# Display the IPv6 PBR routing information of policy test.
<Sysname> display ipv6 policy-based-route setup test
 policy Name             interface
 test                    local
# Display the IPv6 PBR routing information on interface GigabitEthernet 3/1/1.
<Sysname> display ipv6 policy-based-route setup interface GigabitEthernet 3/1/1
 Interface GigabitEthernet 3/1/1 policy based routing configuration information:
 policy-based-route: test
   permit node 6:
     if-match acl6 2000
       1::1
# Display the IPv6 local PBR information.
<Sysname> display ipv6 policy-based-route setup local
 Local policy based routing configuration information:
   permit node 6:
     if-match acl6 2000
       1::1
Table 3 Output description
policy Name
Policy name.
interface
Interface where the policy is applied. Local means the policy is applied locally.
policy-based-route
permit node 6
The match mode of Node 6 is permit.
if-match acl6 2000
Match IPv6 packets against ACL 2000.
Permitted IPv6 packets are sent to the specified next hop.
display ipv6 policy-based-route statistics
display ipv6 policy-based-route statistics { interface interface-type interface-number | local } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays IPv6 PBR statistics on the specified interface.
local: Displays IPv6 local PBR statistics.
slot slot-number: Displays the IPv6 PBR statistics on a card. slot-number represents the number of the slot that holds the card.
Use the display ipv6 policy-based-route statistics command to display IPv6 PBR statistics.
# Display IPv6 local PBR statistics.
<Sysname> display ipv6 policy-based-route statistics local
 Local policy based routing statistics information:
   ipv6 policy-based-route: test
     permit node 10:
   matched: 50
 Total matched: 50
Table 4 Output description
Local policy based routing information
Local PBR information.
permit node
The matching mode of the node is permit.
if-match acl6 2000
Match IPv6 packets against IPv6 basic ACL 2000.
matched
Total number of matching packets on the node.
Total matched
Total number of matching packets on all nodes.
if-match acl6
if-match acl6 acl6-number
undo if-match acl6
View
Default level
2: System level
acl6-number: IPv6 ACL number, in the range 2000 to 3999. The number of a basic IPv6 ACL ranges from 2000 to 2999 and that of an advanced IPv6 ACL ranges from 3000 to 3999.
Use the if-match acl6 command to define an IPv6 ACL match criterion.
Use the undo if-match acl6 command to remove the IPv6 ACL match criterion.
# Permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl6 2000
ipv6 local policy-based-route
undo ipv6 local policy-based-route [ policy-name ]
View
Default level
2: System level
Use the ipv6 local policy-based-route command to configure IPv6 local PBR based on a policy.
Use the undo ipv6 local policy-based-route command to remove the configuration.
IPv6 local PBR is not configured by default.
Local PBR is used to route packets generated locally. Unless otherwise required, H3C does not recommend configuring local PBR.
# Configure IPv6 local PBR based on policy AAA.
[Sysname] ipv6 local policy-based-route AAA
ipv6 policy-based-route (interface view)
ipv6 policy-based-route policy-name
undo ipv6 policy-based-route
View
Interface view
Default level
2: System level
Use the ipv6 policy-based-route command to configure IPv6 PBR based on a policy on the interface.
Use the undo ipv6 policy-based-route command to remove the configuration.
IPv6 interface PBR is not configured by default.
# Configure IPv6 PBR based on policy AAA on GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ipv6 policy-based-route AAA
ipv6 policy-based-route (system view)
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
View
Default level
2: System level
deny: Specifies the match mode of the policy node as deny.
permit: Specifies the match mode of the policy node as permit.
node node-number: Number of the IPv6 policy node, in the range 0 to 65535. Packets will match against the node with a smaller node-number first.
Use the ipv6 policy-based-route command to create an IPv6 policy, a policy node, or both, and enter IPv6 PBR policy node view.
Use the undo ipv6 policy-based-route command to remove an IPv6 policy, a policy node, or both.
No IPv6 policy or policy node is created by default.
# Create Node 10 of IPv6 policy aaa with match mode being permit and enter IPv6 PBR policy node view.
[Sysname] ipv6 policy-based-route aaa permit node 10
reset ipv6 policy-based-route statistics
reset ipv6 policy-based-route statistics [ policy-name ]
View
Default level
1: Monitor level
Use the reset ipv6 policy-based-route statistics command to clear IPv6 PBR statistics.
If no policy name is specified, this command clears all IPv6 PBR statistics.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
