06-Layer 3 - IP Routing Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10306-Layer 3 - IP Routing Command Reference
01-Basic IP Routing Commands
01-Basic IP Routing Commands 174.52 KB
display ip routing-table
display ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the information of the public network is displayed.
verbose: Displays detailed routing table information, including inactive routes. With this keyword absent, the command displays only brief information about active routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ip routing-table command to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and outbound interface. This command displays only the optimal routes in use.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 6        Routes : 6
192.168.1.0/24      Static 60   0            192.168.3.1     GE3/1/1
192.168.2.0/24      Static 60   0            192.168.3.1     GE3/1/1
192.168.3.0/24      Direct 0    0            192.168.3.2     GE3/1/1
192.168.3.2/32      Direct 0    0            127.0.0.1       InLoop0
Table 1 Output description
Destinations
Number of destination addresses
Routes
Number of routes
Destination/Mask
Destination address/mask length
Proto
Protocol that presents the route
Pre
Priority of the route
Cost
Cost of the route
NextHop
Address of the next hop on the route
Outbound interface for packets to be forwarded along the route
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
  Destination: 127.0.0.0/8
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
 IpPrecedence:                    QosLcID:
      NextHop: 127.0.0.1        Interface: InLoopBack0
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active NoAdv           Age: 02h59m10s
          Tag: 0
  Destination: 127.0.0.1/32
          Tag: 0
  Destination: 192.168.1.0/24
     Protocol: Static          Process ID: 0
   Preference: 60                    Cost: 0
      NextHop: 192.168.3.1      Interface: GigabitEthernet3/1/1
        State: Active Adv GotQ        Age: 00h02m31s
          Tag: 0
  Destination: 192.168.2.0/24
        State: Active Adv GotQ        Age: 00h02m32s
          Tag: 0
  Destination: 192.168.3.0/24
      NextHop: 192.168.3.2      Interface: GigabitEthernet3/1/1
        State: Active Adv             Age: 00h02m32s
          Tag: 0
  Destination: 192.168.3.2/32
        State: Active NoAdv           Age: 00h02m33s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 2 Output description
Destination
Destination address/mask length.
Protocol
Protocol that presents the route.
Process ID
Process ID.
Preference
Priority of the route.
Cost
Cost of the route.
IpPrecedence
IP precedence.
QosLcID
QoS-local ID.
NextHop
Address of the next hop on the route.
Outbound interface for packets to be forwarded along the route.
BkNextHop
Backup next hop.
BkInterface
Backup outbound interface.
RelyNextHop
The next hop address obtained through routing recursion.
Neighbor
Neighboring address determined by Routing Protocol.
Tunnel ID
Tunnel ID.
Label
Label.
Route status:
Active—This is an active unicast route.
Adv—This route can be advertised.
Delete—This route is deleted.
Gateway—This is an indirect route.
HolddownNumber of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For detailed information, see relevant routing protocols.
IntThe route was discovered by an Interior Gateway Protocol (IGP).
NoAdvThe route is not advertised when the router advertises routes based on policies.
NotInstallAmong routes to a destination, the route with the highest priority is installed into the core routing table and advertised. A NotInstall route cannot be installed into the core routing table but can be advertised.
RejectThe packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
StaticA static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
Unicast—Unicast routes.
Inactive—Inactive routes
Invalid—Invalid routes.
WaitQ—The route is the WaitQ during route recursion.
TunE—Tunnel.
GotQ—The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag.
display ip routing-table acl
display ip routing-table [ vpn-instance vpn-instance-name ] acl acl-number [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl-number: Basic ACL number, in the range of 2000 to 2999.
verbose: Displays detailed routing table information, including inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table acl command to display information about routes permitted by a specified basic ACL.
For more information about routing policy, see the chapter “Routing policy configuration.”
·       This command is usually used together with routing policy display commands.
·       If the specified ACL does not exist or it has no rules configured, the entire routing table is displayed.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access list : 2000
Summary Count : 6
Destination/Mask    Proto  Pre  Cost         NextHop       Interface
10.1.1.0/24         Direct 0    0            10.1.1.2      Vlan1
10.1.1.2/32         Direct 0    0            127.0.0.1     InLoop0
10.1.2.0/24         Direct 0    0            10.1.2.1      GE1/1/1
10.1.2.1/32         Direct 0    0            127.0.0.1     InLoop0
10.1.3.0/24         Direct 0    0            10.1.3.1      GE1/1/2
10.1.3.1/32         Direct 0    0            127.0.0.1     InLoop0
For detailed description of the output, see Table 1.
# Display detailed information about both active and inactive routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count: 6
  Destination: 10.1.1.0/24
      NextHop: 10.1.1.2         Interface: Vlan-interface1
        State: Active Adv             Age: 1d00h25m32s
          Tag: 0
  Destination: 10.1.1.2/32
        State: Active NoAdv           Age: 1d00h41m34s
          Tag: 0
  Destination: 10.1.2.0/24
      NextHop: 10.1.2.1         Interface: GigabitEthernet1/1/1
        State: Active Adv             Age: 1d00h05m42s
          Tag: 0
  Destination: 10.1.2.1/32
        State: Active NoAdv           Age: 1d00h05m42s
          Tag: 0
  Destination: 10.1.3.0/24
      NextHop: 10.1.3.1         Interface: GigabitEthernet1/1/2
        State: Active Adv             Age: 1d00h05m31s
          Tag: 0
  Destination: 10.1.3.1/32
      NextHop: 127.0.0.1        Interface: InLoopback0
        State: Active NoAdv           Age: 1d00h05m32s
          Tag: 0
For the description of the command output above, see Table 2.
display ip routing-table ip-address
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 { mask | mask-length } ip-address2 { mask | mask-length } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Destination IP address, in dotted decimal format.
mask | mask-length: IP address mask, in dotted decimal format or represented by an integer in the range 0 to 32.
longer-match: Displays the route with the longest mask.
verbose: Displays detailed routing table information, including both active and inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table ip-address command to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
·           display ip routing-table ip-address
¡  The system ANDs the input destination IP address with the subnet mask in each route entry.
¡  The system ANDs the destination IP address in each route entry with its own subnet mask.
¡  If the two operations yield the same result for an entry and this entry is active, it is displayed.
·           display ip routing-table ip-address mask
¡  The system ANDs the input destination IP address with the input subnet mask.
¡  The system ANDs the destination IP address in each route entry with the input subnet mask.
¡  If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
·           display ip routing-table ip-address longer-match
¡  If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
·           display ip routing-table ip-address mask longer-match
¡  If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use the display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } command to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
[Sysname] display ip routing-table 11.1.1.1
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
# Display route entries by specifying a destination IP address and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask.
[Sysname] display ip routing-table 11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 24 longer-match
Summary Count : 1
# Display route entries for destination addresses in the range 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1     InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1       GE1/1/1
3.3.3.1/32          Direct 0    0            127.0.0.1     InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1       GE1/1/2
4.4.4.1/32          Direct 0    0            127.0.0.1     InLoop0
display ip routing-table ip-prefix
display ip routing-table [ vpn-instance vpn-instance-name ] ip-prefix ip-prefix-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-prefix-name: IP prefix list name, a string of 1 to 19 characters.
Use the display ip routing-table ip-prefix command to display information about routes permitted by a specified prefix list.
This command is usually used together with routing policy display commands. If the specified prefix list is not configured, detailed information about all routes (with the verbose keyword) or brief information about all active routes (without the verbose keyword) is displayed.
# Configure a prefix list named test, permitting routes with a prefix of 2.2.2.0 and a mask length between 24 and 32.
[Sysname] ip ip-prefix test permit 2.2.2.0 24 less-equal 32
# Display brief information about active routes permitted by the prefix list test.
[Sysname] display ip routing-table ip-prefix test
Routes Matched by Prefix list : test
Summary Count : 2
2.2.2.1/32         Direct  0    0          127.0.0.1       InLoop0
# Display detailed information about both active and inactive routes permitted by IP prefix list test.
[Sysname] display ip routing-table ip-prefix test verbose
Routes Matched by Prefix list  test :
Summary Count : 2
Destination: 2.2.2.0/24
      NextHop: 2.2.2.1                  Interface: Vlan-interface2
        State: Active Adv                     Age: Od00h20m52s
          Tag: 0
Destination: 2.2.2.1/32
        State: Active NoAdv                   Age: Od00h20m52s
          Tag: 0
For detailed description of the output, see Table 2.
display ip routing-table protocol
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Routing protocol. It can be bgp, direct, isis, ospf, rip, or static.
inactive: Displays information about only inactive routes. With this argument absent, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. With this argument absent, the command displays brief routing table information.
Use the display ip routing-table protocol command to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing Table Status : <Active>
Summary Count : 6
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   GE1/1/1
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing Table Status : <Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing Table Status : <Active>
Summary Count : 0
Static Routing Table Status : <Inactive>
Summary Count : 2
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
3.0.0.0/8           Static  60   0          2.2.2.2      GE1/1/1
display ip routing-table statistics
display ip routing-table [ vpn-instance vpn-instance-name ] statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ip routing-table statistics command to display the route statistics of the routing table.
# Display route statistics in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
RIP        0           0           0           0             0
OSPF       0           0           0           0             0
IS-IS      0           0           0           0             0
BGP        0           0           0           0             0
Total      28          5           29          1             0
Table 3 Output description
Proto
Origin of the routes
route
Number of routes from the origin
active
Number of active routes from the origin
added
Number of routes added into the routing table since the router started up or the routing table was last cleared
deleted
Number of routes marked as deleted, which will be freed after a period
freed
Number of routes that got freed (got removed permanently)
Total
Total number
display ipv6 routing-table
display ipv6 routing-table [ vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ipv6 routing-table command to display brief IPv6 routing information, including destination IP address and prefix, protocol type, priority, metric, next hop and outbound interface.
The command displays only active routes (the brief information about the current optimal routes).
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table: Public
        Destinations : 1        Routes : 1
Destination : ::1/128                           Protocol  : Direct
NextHop     : ::1                               Preference: 0
Interface   : InLoop0                           Cost      : 0
Table 4 Output description
Destination
IPv6 address of the destination network/host
NextHop
Next hop address
Preference
Route priority
Outbound interface
Protocol
Routing protocol
Cost
Route cost
display ipv6 routing-table acl
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl acl6-number [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl6-number: Basic IPv6 ACL number, in the range 2000 to 2999.
verbose: Displays both active and inactive verbose routing information permitted by the ACL. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table acl command to display routing information permitted by the IPv6 ACL.
If the specified IPv6 ACL is not available, all routing information is displayed.
# Display brief routing information permitted by ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Routes Matched by Access list  2000  :
Summary Count : 2
NextHop     : ::1                               Preference : 0
Destination : 1:1::/64                          Protocol   : Static
NextHop     : ::                                Preference : 60
Interface   : NULL0                             Cost       : 0
For description of the output, see Table 4.
display ipv6 routing-table ipv6-address
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address prefix-length [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length, in the range 0 to 128.
longer-match: Displays the matched route having the longest prefix length.
verbose: Displays both active and inactive verbose routing information. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table ipv6-address command to display routing information about the specified destination IPv6 address.
·           display ipv6 routing-table ipv6-address prefix-length
¡  The system ANDs the input destination IPv6 address with the input prefix length.
¡  The system ANDs the destination IPv6 address in each route entry with the input prefix length.
¡  If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
·           display ipv6 routing-table ipv6-address prefix-length longer-match
¡  If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the one that is active with the longest prefix length is displayed.
# Display brief information about the route matching the specified destination IPv6 address.
<Sysname> display ipv6 routing-table 10::1 127
Summary Count: 3
Destination: 10::/64                                    Protocol  : Static
NextHop    : ::                                         Preference: 60
Destination: 10::/68                                    Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the matched route with the longest prefix length.
<Sysname> display ipv6 routing-table 10:: 127 longer-match
Summary Count : 1
display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address1/ipv6-address2: An IPv6 address range from IPv6 address1 to IPv6 address2.
prefix-length1/prefix-length2: Prefix length, in the range 0 to 128.
Use the display ipv6 routing-table ipv6-address1 ipv6-address2 command to display routes with destinations falling into the specified IPv6 address range.
# Display routes with destinations falling into the IPv6 address range.
<Sysname> display ipv6 routing-table 100:: 64 300:: 64
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
display ipv6 routing-table ipv6-prefix
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-prefix ipv6-prefix-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-prefix-name: Name of the IPv6 prefix list, in the range 1 to 19 characters.
Use the display ipv6 routing-table ipv6-prefix command to display routes permitted by the IPv6 prefix list.
# Display brief active routing information permitted by the IPv6 prefix list test2.
<Sysname> display ipv6 routing-table ipv6-prefix test2
Routes Matched by Prefix list  test2  :
Summary Count : 1
display ipv6 routing-table protocol
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Displays routes of a routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng and static.
inactive: Displays only inactive routes. Without the keyword, all active and inactive routes are displayed.
Use the display ipv6 routing-table protocol command to display IPv6 routes of a specified routing protocol.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary Count : 1
Summary Count : 1
Destination: ::1/128                                     Protocol  : Direct
Summary Count : 0
display ipv6 routing-table statistics
display ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ipv6 routing-table statistics command to display IPv6 routing statistics, including total route number, added route number, and deleted route number.
# Display IPv6 routing statistics.
<Sysname> display ipv6 routing-table statistics
Protocol   route      active     added      deleted     freed
DIRECT     1          1          1          0           0
STATIC     3          0          3          0           0
RIPng      0          0          0          0           0
OSPFv3     0          0          0          0           0
IS-ISv6    0          0          0          0           0
BGP4+      0          0          0          0           0
Total      4          1          4          0           0
Table 5 Output description
Protocol
Routing protocol
route
Route number of the protocol
active
added
Routes added after the last startup of the router
deleted
Deleted routes, which will be released after a specified time
freed
Released (totally removed from the routing table) route number
Total
Total number of routes
display ipv6 routing-table verbose
display ipv6 routing-table [ vpn-instance vpn-instance-name ] verbose [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ipv6 routing-table verbose command to display detailed information about all active and inactive IPv6 routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
 Destination  : ::1                                   PrefixLength : 128
 RelayNextHop : ::                                    Tag          : 0H
 Neighbor     : ::                                    ProcessID    : 0
 Interface    : InLoopBack0                           Protocol     : Direct
 State        : Active NoAdv                          Cost         : 0
 Tunnel ID    : 0x0                                   Label        : NULL
 Age          : 22161sec
Table 6 Output description
Destination
PrefixLength
Prefix length of the address
NextHop
Next hop
IpPrecedence
IP precedence
QosLcID
QoS-local ID
Preference
Route priority
RelayNextHop
Recursive next hop
Tag
Tag of the route
Neighbor
Neighbor address
ProcessID
Process ID
Outbound interface
Protocol
Routing protocol
State of the route, Active, Inactive, Adv (advertised), or NoAdv (not advertised)
Cost
Cost of the route
Tunnel ID
Tunnel ID
Label
Label
Age
Time that has elapsed since the route was generated
reset ip routing-table statistics protocol
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the routing statistics of the public network is cleared.
protocol: Clears statistics for the IPv4 routing protocol, which can be bgp, direct, isis, ospf, rip, or static.
all: Clears statistics for all IPv4 routing protocols.
Use the reset ip routing-table statistics protocol command to clear routing statistics for the routing table.
# Clear routing statistics in the routing table of VPN instance Sysname1.
<Sysname> reset ip routing-table statistics protocol vpn-instance Sysname1 all
reset ipv6 routing-table statistics
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
View
Default level
2: System level
protocol: Clears statistics for the routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
all: Clears statistics for all IPv6 routing protocols.
Use the reset ipv6 routing-table statistics command to clear the route statistics of the routing table.
# Clear statistics for all routing protocols.
<Sysname> reset ipv6 routing-table statistics protocol all
