06-Layer 3 - IP Routing Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10306-Layer 3 - IP Routing Command Reference
05-IS-IS Commands
05-IS-IS Commands 321.9 KB
IS-IS configuration commands 1
area-authentication-mode· 1
auto-cost enable· 2
bandwidth-reference (IS-IS view) 2
circuit-cost 3
cost-style· 4
default-route-advertise (IS-IS view) 4
display isis brief 5
display isis debug-switches 7
display isis graceful-restart status 7
display isis interface· 9
display isis lsdb· 12
display isis mesh-group· 14
display isis name-table· 15
display isis peer 16
display isis route· 19
display isis spf-log· 22
display isis statistics 23
domain-authentication-mode· 25
fast-reroute· 26
filter-policy export (IS-IS view) 27
filter-policy import (IS-IS view) 29
flash-flood· 30
graceful-restart (IS-IS view) 30
graceful-restart interval (IS-IS view) 31
graceful-restart suppress-sa· 32
import-route (IS-IS view) 32
import-route isis level-2 into level-1· 34
import-route limit (IS-IS view) 34
isis 35
isis authentication-mode· 36
isis bfd enable· 37
isis circuit-level 38
isis circuit-type p2p· 38
isis cost 39
isis dis-name· 40
isis dis-priority· 41
isis enable· 41
isis mesh-group· 42
isis mib-binding· 43
isis peer-ip-ignore· 43
isis silent 44
isis small-hello· 45
isis timer csnp· 45
isis timer hello· 46
isis timer holding-multiplier 47
isis timer lsp· 48
isis timer retransmit 49
is-level 49
is-name· 50
is-name map· 51
is-snmp-traps enable· 51
log-peer-change (IS-IS view) 52
lsp-fragments-extend· 52
lsp-length originate· 53
lsp-length receive· 54
maximum load-balancing (IS-IS view) 54
network-entity· 55
preference (IS-IS view) 56
reset isis all 56
reset isis peer 57
set-overload· 58
summary (IS-IS view) 59
timer lsp-generation· 59
timer lsp-max-age· 61
timer lsp-refresh· 61
timer spf 62
virtual-system·· 63
area-authentication-mode { md5 | simple } password [ ip | osi ]
undo area-authentication-mode
View
IS-IS view
Default level
2: System level
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
password: Password. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or cipher text. A plaintext password can be a string of up to 16 characters, such as user918. A cipher password must be a ciphertext string of 24 characters, such as (TT8F]Y\5SQ=^Q`MAF4<1!!.
ip: Checks IP related fields in LSPs.
osi: Checks OSI related fields in LSPs.
Whether a password should use ip or osi is not affected by the actual network environment.
Use the area-authentication-mode command to specify the area authentication mode and a password.
Use the undo area-authentication-mode command to restore the default.
No area authentication is configured by default.
The password in the specified mode is inserted into all outgoing Level-1 packets (LSP, CSNP and PSNP) and is used for authenticating the incoming Level-1 packets.
With area authentication configured, IS-IS discards incoming routes from untrusted routers.
Routers in a common area must have the same authentication mode and password.
If neither ip nor osi is specified, OSI related fields are checked.
Related commands: reset isis all, domain-authentication-mode, isis authentication-mode
# Configure the area authentication password as ivg, and the authentication mode as simple.
[Sysname] isis 1
[Sysname-isis-1] area-authentication-mode simple ivg
auto-cost enable
auto-cost enable
undo auto-cost enable
View
IS-IS view
Default level
2: System level
None
Use the auto-cost enable command to enable automatic link cost calculation.
Use the undo auto-cost enable command to disable the function.
This function is disabled by default.
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the formula: Cost = (reference bandwidth value/link bandwidth) × 10. When the cost style is of other types: if the interface bandwidth does not exceed 10 Mbps, the interface cost equals 60; if the interface bandwidth does not exceed 100 Mbps, the interface cost equals 50; if the interface bandwidth does not exceed 155 Mbps, the interface cost equals 40; if the interface bandwidth does not exceed 622 Mbps, the interface cost equals 30; if the interface bandwidth does not exceed 2500 Mbps, the interface cost equals 20; if the interface bandwidth exceeds 2500 Mbps, the interface cost equals 10.
Related commands: bandwidth-reference and cost-style.
# Enable automatic link cost calculation.
[Sysname] isis 1
[Sysname-isis-1] auto-cost enable
bandwidth-reference value
undo bandwidth-reference
View
IS-IS view
Default level
2: System level
value: Bandwidth reference value in Mbps, ranging from 1 to 2147483648.
Use the bandwidth-reference command to set the bandwidth reference value for automatic link cost calculation.
Use the undo bandwidth-reference command to restore the default.
By default, the bandwidth reference value is 100 Mbps.
Related commands: auto-cost enable.
# Configure the bandwidth reference of IS-IS process 1 as 200 Mbps.
[Sysname] isis 1
[Sysname-isis-1] bandwidth-reference 200
circuit-cost
circuit-cost value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
value: Link cost value. The value range varies with cost styles.
·           For styles narrow, narrow-compatible and compatible, the cost value ranges from 0 to 63.
·           For styles wide and wide-compatible, the cost value ranges from 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
Use the circuit-cost command to set a global IS-IS link cost.
Use the undo circuit-cost command to restore the default.
By default, no global link cost is configured.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
Related commands: isis cost and cost-style.
# Set the global Level-1 link cost of IS-IS process 1 to 11.
[Sysname] isis 1
[Sysname-isis-1] circuit-cost 11 level-1
cost-style
undo cost-style
View
IS-IS view
Default level
2: System level
narrow: Receives and sends only narrow cost style packets (The narrow cost ranges from 0 to 63).
wide: Receives and sends only wide cost style packets (The wide cost ranges from 0 to 16777215).
compatible: Receives and sends both wide and narrow cost style packets.
narrow-compatible: Receives both narrow and wide cost style packets, but sends only narrow cost style packets.
wide-compatible: Receives both narrow and wide cost style packets, but sends only wide cost style packets.
relax-spf-limit: Allows receiving routes with a cost greater than 1023. If this keyword is not specified, any route with a cost bigger than 1023 will be discarded. This keyword is only available when compatible or narrow-compatible is included.
Use the cost-style command to set a cost style.
Use the undo cost-style command to restore the default.
Only narrow cost style packets can be received and sent by default.
Related commands: isis cost and circuit-cost.
# Configure the router to send only narrow cost style packets, but receive both narrow and wide cost style packets.
[Sysname] isis 1
[Sysname-isis-1] cost-style narrow-compatible
default-route-advertise [ route-policy route-policy-name | [ level-1 | level-1-2 | level-2 ] ] *
undo default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
Default level
2: System level
topology-name: Topology name, a case-sensitive character string of 1 to 31 characters.
route-policy-name: Specifies the name of a routing policy, a case-sensitive string of 1 to 63 characters.
level-1: Advertises a Level-1 default route.
level-1-2: Advertises both Level-1 and Level-2 default routes.
level-2: Advertises a Level-2 default route.
Use the default-route-advertise command to advertise a default route of 0.0.0.0/0.
Use the undo default-route-advertise command to disable default route advertisement.
Default route advertisement is disabled by default.
If no level is specified, a Level-2 default route is advertised.
The Level-1 default route is advertised to other routers in the same area, and the Level-2 default route is advertised to all the Level-2 and Level-1-2 routers.
Using the apply isis level-1 command in routing policy view will generate a default route in a Level-1 LSP. Using the apply isis level-2 command in routing policy view will generate a default route in a Level-2 LSP. Using the apply isis level-1-2 command in routing policy view will generate a default route in a Level-1 LSP and Level-2 LSP respectively.
# Advertise a Level-2 default route.
[Sysname] isis 1
[Sysname-isis-1] default-route-advertise
display isis brief
display isis brief [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS brief configuration information for the IS-IS process. The process ID is in the range 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS brief configuration information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS brief configuration information of the public network is displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display isis brief command to view IS-IS brief configuration information.
# Display IS-IS brief configuration information.
<Sysname> display isis brief
                  ISIS (1) Protocol Brief Information :
 network-entity:
     10.0000.0000.0001.00
 is-level :level-1-2
 cost-style:  narrow
 preference :  15
 Lsp-length receive :  1497
 Lsp-length originate :  level-1 1497
                         level-2 1497
maximum imported routes number     : 10000
 Timers:
     lsp-max-age:  1200
     lsp-refresh:  900
     Interval between SPFs:  10
Table 1 Output description
network-entity
Network entity name
is-level
IS-IS Routing level
cost-style
Cost style
preference
Preference
Lsp-length receive
Maximum LSP that can be received
Maximum LSP that can be generated
Maximum number of redistributed Level-1/Level-2 IPv4 routes
Timers
lsp-max-age
Maximum life period of LSP
lsp-refresh
Refresh interval of LSP
Interval between SPF calculations
display isis debug-switches { process-id | vpn-instance vpn-instance-name } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays the IS-IS debugging switch state for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS debugging switch state for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS debugging switch state for the public network is displayed.
Use the display isis debug-switches command to display IS-IS debugging switch state.
# Display the debugging switch state of IS-IS process 1.
<Sysname> display isis debug-switches 1
IS-IS - Debug settings.
        IS-IS SPF Triggering Events debugging is on
display isis graceful-restart status [ level-1 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays the IS-IS Level-1 Graceful Restart state.
level-2: Displays the IS-IS Level-2 Graceful Restart state.
process-id: IS-IS Process ID, in the range 1 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS Graceful Restart status for the public network is displayed.
Use the display isis graceful-restart status command to display IS-IS Graceful Restart status.
# Display IS-IS Graceful Restart status.
<Sysname> display isis graceful-restart status
IS-IS(1) Level-1 Restart Status
Restart Interval: 150
SA Bit Supported
  Total Number of Interfaces = 1
  Restart Status: RESTARTING
  Number of LSPs Awaited: 3
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
    Remaining Time: 59
IS-IS(1) Level-2 Restart Status
SA Bit Supported
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
    Remaining Time: 59
Table 2 Output description
Restart Interval
Graceful Restart interval.
SA Bit Supported
The SA bit is set.
The current IS-IS interface number.
Restart Status
Number of LSPs not obtained by the GR restarter from GR helpers during LSDB synchronization.
T3 Timer Status
Remaining time of T3 timer.
T2 Timer Status
Remaining time of T2 Timer.
display isis interface [ statistics | [ interface-type interface-number ] [ verbose ] ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
statistics: Displays IS-IS interface statistics information.
interface-type interface-number: Specifies an IS-IS interface whose statistics is to be displayed.
verbose: Displays detailed IS-IS interface information.
process-id: Displays the IS-IS interface information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS interface information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS interface information of the public network is displayed.
Use the display isis interface command to display IS-IS interface information.
# Display brief IS-IS interface information.
<Sysname> display isis interface
                       Interface information for ISIS(1)
Interface: GigabitEthernet 1/1/1
Id      IPV4.State        IPV6.State     MTU    Type    DIS
001         Up                Down       1497   L1/L2   No/No
# Display detailed IS-IS interface information.
<Sysname> display isis interface verbose
  Interface:  Vlan-interface999
  SNPA Address                : 000f-e237-c6e0
  IP Address                  : 192.168.1.48
  Secondary IP Address(es)    :
  IPV6 Link Local Address     :
  IPV6 Global Address(es)     :
  Csnp Timer Value            :  L1    10  L2    10
  Hello Timer Value           :  L1    10  L2    10
  Hello Multiplier Value      :  L1     3  L2     3
  Lsp Timer Value             :  L12   33
  Lsp Transmit-Throttle Count :  L12   5
  Cost                        :  L1    10  L2    10
  Priority                    :  L1    64  L2    64
  BFD                         :  Disabled
  MPLS TE Status              :  ON
  INTF L1 TE Status           :  OFF
  INTF L2 TE Status           :  ON
  TE Cost                     :  0
  TE Admin Group              :  0
  TE Max Bandwidth            :  0
  TE Max Res Bandwidth        :  0
Table 3 Output description
Interface type and number.
Id
Circuit ID.
IPV4.State
IPv4 state.
IPV6.State
IPv6 state.
MTU
Interface MTU.
Interface link adjacency type.
DIS
Whether the interface is elected as the DIS or not.
SNPA Address
Subnet access point address.
IP Address
Primary IP address.
Secondary IP addresses.
IPv6 link local address.
IPv6 global address.
Csnp Timer Value
Interval for sending CSNP packets.
Hello Timer Value
Interval for sending Hello packets.
Number of invalid Hello packets.
Lsp Timer Value
Minimum interval for sending LSP packets.
Number of LSP packets sent each time.
Cost
Cost of the interface.
Priority
DIS priority.
Retransmit Timer Value
LSP retransmission interval over the point-to-point link.
BFD
Whether BFD is enabled on the interface.
MPLS TE Status
Whether MPLS TE is enabled on the interface.
INTF L1 TE Status
Whether level-1 MPLS TE is enabled on the interface.
INTF L2 TE Status
Whether level-2 MPLS TE is enabled on the interface.
TE Cost
MPLS TE cost configured on the interface.
TE Admin Group
TE link administration group.
TE Max Bandwidth
TE link maximum bandwidth.
TE link maximum reserved bandwidth.
# Display IS-IS interface statistics information.
<sysname> display isis interface statistics
                  Interface Statistics information for ISIS(1)
  Type            IPv4 Up/Down           IPv6 Up/Down
  LAN                   0/1                   -/-
  P2P                   4/0                   -/-
Table 4 Output description
Network type of the interface:
·       LAN for broadcast network.
·       P2P for point-to-point network.
IPv4 UP
Number of IS-IS interfaces in up state.
IPv4 DOWN
Number of IS-IS interfaces in down state.
IPv6 UP
Number of IS-ISv6 interfaces in up state. If IPv6 is not enabled, this field displays a hyphen (-).
IPv6 DOWN
Number of IS-ISv6 interfaces in down state. If IPv6 is not enabled, this field displays a hyphen (-).
display isis lsdb
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ lsp-id lspid | lsp-name lspname ] | local | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
l1, level-1: Displays the level-1 LSDB.
l2, level-2: Displays the level-2 LSDB.
lspid: LSP ID, in the form of sysID. Pseudo ID-fragment num, where sysID represents the originating node or pseudo node.
lspname: LSP name, in the form of Symbolic name.[Pseudo ID]-fragment num.
local: Displays LSP information generated locally.
verbose: Displays LSDB detailed information.
process-id: Displays the LSDB of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the LSDB of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the LSDB of the public network is displayed.
Use the display isis lsdb command to display IS-IS link state database.
If no level is specified, both Level-1 and Level-2 link state databases are displayed.
# Display brief Level-1 LSDB information.
<Sysname> display isis lsdb level-1
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
1111.1111.1111.00-00  0x00000004   0xa76         563           68      0/0/0
1111.1111.1112.00-00* 0x00000006   0x498d        578           84      0/0/0
1111.1111.1112.01-00* 0x00000001   0x4c0e        556           55      0/0/0
# Display detailed Level-1 LSDB information.
<Sysname> display isis lsdb level-1 verbose
                        Database information for ISIS(1)
1111.1111.1111.00-00  0x00000005   0x877         1090          68      0/0/0
 SOURCE       1111.1111.1111.00
 NLPID        IPV4
 AREA ADDR    10
 INTF ADDR    3.1.1.2
 NBR  ID      1111.1111.1112.01  COST: 10
 IP-Internal  3.1.1.0        255.255.255.0    COST: 10
1111.1111.1112.00-00* 0x00000007   0x478e        1120          84      0/0/0
 SOURCE       1111.1111.1112.00
 NLPID        IPV4
 AREA ADDR    10
 INTF ADDR    3.1.1.1
 INTF ADDR    2.1.2.2
 IP-Internal  2.1.2.0        255.255.255.0    COST: 10
1111.1111.1112.01-00* 0x00000002   0x4a0f        1118          55      0/0/0
 SOURCE       1111.1111.1112.01
 NLPID        IPV4
 NBR  ID      1111.1111.1112.00  COST: 0
 NBR  ID      1111.1111.1111.00  COST: 0
Table 5 Output description
LSPID
Link state packet ID.
Seq Num
LSP sequence number.
Checksum
LSP checksum.
Holdtime
LSP lifetime which decreases as time elapses.
Length
LSP length.
ATT/P/OL
·       ATT—Attach bit.
·       P—Partition bit.
·       OL—Overload bit.
1 means the bit is set and 0 means the bit is not set.
SOURCE
System ID of the originating router.
NLPID
Network layer protocol the originating router runs.
AREA ADDR
Area address of the originating router.
INTF ADDR
IP address of the originating router’s IS-IS interface.
INTF ADDR V6
IPv6 address of the originating router’s IS-ISv6 interface.
NBR ID
Neighbor ID of the originating router.
IP-Internal
Internal IP address and mask of the originating router.
IP-External
External IP address and mask of the originating router.
IP-Extended
Extended IP address and mask of the originating router.
COST
Cost.
HOST NAME
Dynamic host name of the originating router.
ORG ID
Original system ID of the virtual system ID of the originating router.
Auth
Authentication information of the originating router.
IPV6
Internal IPv6 address and prefix of the originating router.
IPV6-Ext
External IPv6 address and prefix of the originating router.
display isis mesh-group [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS mesh-group configuration information for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS mesh-group configuration information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS mesh-group configuration information for the public network is displayed.
Use the display isis mesh-group command to display IS-IS mesh-group configuration information.
# Add the POS2/1/1 interface and POS2/1/2 interface to mesh-group 100.
[Sysname] interface POS 2/1/1
[Sysname-POS2/1/1] isis mesh-group 100
[Sysname-POS2/1/1] quit
[Sysname] interface POS 2/1/2
[Sysname-POS2/1/2] isis mesh-group 100
# Display the configuration information of IS-IS mesh-group.
[Sysname-POS2/1/2] display isis mesh-group
               Mesh Group information for ISIS(1)
 Interface          Status
 POS2/1/1         100
 POS2/1/2         100
Table 6 Output description
Interface name
Status
Mesh-group the interface belongs to
display isis name-table [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays the host name-to-system ID mapping table for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the host name-to-system ID mapping table for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the host name-to-system ID mapping table for the public network is displayed.
Use the display isis name-table command to display the host name-to-system ID mapping table.
# Configure a name for the local IS system.
[Sysname] isis 1
[Sysname-isis-1] is-name RUTA
# Configure a static mapping for the remote IS system (system ID 0000.0000.0041, host name RUTB).
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
# Display the IS-IS host name-to-system ID mapping table.
[Sysname-isis-1] display isis name-table
              Name table information for ISIS(1)
System ID            Hostname                            Type
6789.0000.0001       RUTA                                DYNAMIC
0000.0000.0041       RUTB                                STATIC
Table 7 Output description
System ID
System ID
Hostname
Hostname name
Mapping type (static or dynamic)
display isis peer
display isis peer [ statistics | verbose ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
statistics: Displays IS-IS neighbor statistics information.
verbose: Displays detailed IS-IS neighbor information. Without the keyword, the command displays brief IS-IS neighbor information.
process-id: Displays the IS-IS neighbor information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS neighbor information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS neighbor information of the public network is displayed.
Use the display isis peer command to display IS-IS neighbor information.
# Display brief IS-IS neighbor information.
<Sysname> display isis peer
                          Peer information for ISIS(1)
  System Id: 1111.1111.1111
  Interface: GigabitEthernet 1/1/1   Circuit Id: 1111.1111.1112.01
  State: Up     HoldTime: 23s        Type: L1(L1L2)     PRI: 64
  State: Up     HoldTime: 23s        Type: L2(L1L2)     PRI: 64
# Display detailed IS-IS neighbor information.
<Sysname> display isis peer verbose
  State: Up     HoldTime: 27s        Type: L1(L1L2)     PRI: 64
  Area Address(es):10
  Peer IP Address(es): 3.1.1.2
  Uptime: 00:38:15
  Adj Protocol:  IPV4
  State: Up     HoldTime: 28s        Type: L2(L1L2)     PRI: 64
  Area Address(es):10
  Uptime: 00:38:15
  Adj Protocol:  IPV4
Table 8 Output description
System Id
System ID of the neighbor.
Interface connecting to the neighbor.
Circuit Id
Circuit ID.
Circuit state.
HoldTime
Holdtime.
Within the holdtime if no hellos are received from the neighbor, the neighbor is considered down. If a hello is received, the holdtime is reset to the initial value.
Circuit type:
·       L1—Means the circuit type is Level-1 and the neighbor is a Level-1 router.
·       L2—Means the circuit type is Level-2 and the neighbor is a Level-2 router.
·       L1(L1L2)—Means the circuit type is Level-1 and the neighbor is a Level-1-2 router.
·       L2(L1L2)—Means the circuit type is Level-2 and the neighbor is a Level-1-2 router.
PRI
DIS priority of the neighbor.
Area Address(es)
The neighbor’s area address.
Peer IP Address(es)
IP address of the neighbor.
Uptime
Time that elapsed since the neighbor relationship was formed.
Adj Protocol
Adjacency protocol.
# Display IS-IS neighbor statistics information.
<Sysname> display isis peer statistics
                    Peer Statistics information for ISIS(1)
  Type              IPv4 Up/Init             IPv6 Up/Init
  LAN Level-1             0/0                      0/0
  LAN Level-2             0/0                      0/0
  P2P                     3/0                      0/0
Table 9 Output description
Neighbor type:
·       LAN Level-1Number of Level-1 neighbors whose network type is broadcast.
·       LAN Level-2Number of Level-2 neighbors whose network type is broadcast
·       P2PNumber of neighbors whose network type is P2P
IPv4 Up
Number of IPv4 neighbors in up state
IPv4 Init
Number of IPv4 neighbors in init state
IPv6 Up
Number of IPv6 neighbors in up state
IPv6 Init
Number of IPv6 neighbors in init state
display isis route
display isis route [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv4: Displays IS-IS IPv4 routing information (the default).
verbose: Displays detailed IS-IS IPv4 routing information.
process-id: Displays the IS-IS IPv4 routing information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS IPv4 routing information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS IPv4 routing information of the public network is displayed.
level-1: Displays Level-1 IS-IS routes.
level-2: Displays Level-2 IS-IS routes.
Use the display isis route command to display IS-IS IPv4 routing information.
If no level is specified, both Level-1 and Level-2 routing information will be displayed.
# Display IS-IS IPv4 routing information.
<Sysname> display isis route 1
                         Route information for ISIS(1)
                     ISIS(1) IPv4 Level-1 Forwarding Table
 IPV4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 1.1.0.0/16           20         NULL    GE1/1/1         1.2.1.1         R/L/-
 1.2.0.0/16           10         NULL    GE1/1/1         Direct          D/L/-
      Flags: D-Direct, R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
                     ISIS(1) IPv4 Level-2 Forwarding Table
 1.1.0.0/16           20        NULL
Table 10 Output description
Route information for IS-IS process 1.
IS-IS IPv4 routing information for Level-1.
IS-IS IPv4 routing information for Level-2.
IPv4 Destination
IPv4 destination address.
IntCost
Interior routing cost.
ExtCost
Exterior routing cost.
ExitInterface
Exit interface.
NextHop
Next hop.
Flags
Routing state flag:
·       D—Direct route.
·       R—The route has been added into the routing table.
·       L—The route has been advertised in an LSP.
·       U—A route’s penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
# Display detailed IS-IS IPv4 routing information.
<Sysname> display isis route verbose
 IPV4 Dest  : 1.1.0.0/16         Int. Cost : 20              Ext. Cost : NULL
 Admin Tag  : -                  Src Count : 2               Flag      : R/L/-
 NextHop    :                    Interface :                 ExitIndex :
    1.2.1.1                            GE1/1/1                   0x00000008
 IPV4 Dest  : 1.2.0.0/16         Int. Cost : 10              Ext. Cost : NULL
 Admin Tag  : -                  Src Count : 2               Flag      : D/L/-
    Direct                             GE1/1/1                   0x00000000
 Admin Tag  : -                  Src Count : 2               Flag      : -/-/-
 Admin Tag  : -                  Src Count : 3               Flag      : D/L/-
Table 11 Output description
IPV4 Dest
IPv4 destination.
Int. Cost
Internal route cost.
Ext. Cost
External route cost.
Admin Tag
Tag.
Src Count
Count of advertising sources.
Flag
Route state flag:
·       RIndicates the route have been installed into the routing table.
·       LThe route has been flooded in an LSP.
·       URoute leaking flag. If it is UP, routes from L2 to L1 cannot be advertised back to L2.
Next Hop
Next hop.
Outgoing interface.
ExitIndex
Index of the outgoing interface.
display isis spf-log [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS SPF log information for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS SPF log information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS SPF log information for the public network is displayed.
Use the display isis spf-log command to display IS-IS SPF log information.
# Display IS-IS SPF log information.
<Sysname> display isis spf-log
                        SPF Log information for ISIS(1)
   Level    Trig.Event                      No.Nodes  Duration   StartTime
   L2       IS_SPFTRIG_PERIODIC             2         0          13:3:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L2       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L1       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L2       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L1       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L2       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L1       IS_SPFTRIG_PERIODIC             2         0          13:55:43
-->L2       IS_SPFTRIG_PERIODIC             2         0          13:55:43
   L1       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L2       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L1       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:3:24
Table 12 Output description
SPF log information for IS-IS process 1
Level
SPF calculation level
Trig.Event
SPF triggered event
No.Nodes
Number of SPF calculation nodes
Duration
SPF calculation duration
StartTime
SPF calculation start time
display isis statistics [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays IS-IS Level-1 statistics.
level-1-2: Displays IS-IS Level-1-2 statistics.
level-2: Displays IS-IS Level-2 statistics.
process-id: Displays IS-IS statistics for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS statistics for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS statistics for the public network is displayed.
Use the display isis statistics command to display IS-IS statistics.
# Display IS-IS statistics.
<Sysname> display isis statistics
                               Level-1 Statistics
Learnt routes information:
         Total IPv4 Learnt Routes in IPv4 Routing Table: 1
         Total IPv6 Learnt Routes in IPv6 Routing Table: 0
Imported routes information:
         IPv4 Imported Routes:
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
         IPv6 Imported Routes:
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
Lsp information:
                  LSP Source ID:          No. of used LSPs
                  0000.0000.0003                  002
                               Level-2 Statistics
         Total IPv4 Learnt Routes in IPv4 Routing Table: 0
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
Lsp information:
                  0000.0000.0003                  002
Table 13 Output description
Statistics information for ISIS(processid)
Statistics for the IS-IS process
Level-1 Statistics
Level-1 Statistics
Level-2 Statistics
Level-2 Statistics
Number of learned IPv4 routes
Number of learned IPv6 routes
Lsp information
LSP information
·       LSP Source IDID of the source system
·       No. of used LSPsNumber of used LSPs
domain-authentication-mode { md5 | simple } password [ ip | osi ]
undo domain-authentication-mode
View
IS-IS view
Default level
2: System level
password: Specifies a password. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or cipher text. A plain text password can be a string of up to 16 characters, such as user918. A cipher password must be a string of 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the domain-authentication-mode command to specify the routing domain authentication mode and a password.
Use the undo domain-authentication-mode command to restore the default.
No routing domain authentication is configured by default
The configured password in the specified mode is inserted into all outgoing Level-2 packets (LSP, CSNP and PSNP) and is used for authenticating the incoming Level-2 packets.
All the backbone routers must have the same authentication mode and password.
If neither ip nor osi is specified, the OSI related fields in LSPs are checked.
Related commands: area-authentication-mode and isis authentication-mode.
# Specify the routing domain authentication mode as simple and password as 123456.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication-mode simple 123456
fast-reroute
fast-reroute { auto | route-policy route-policy-name }
undo fast-reroute
View
IS-IS view
Default level
2: System level
auto: Calculates a backup next hop automatically for all routes.
route-policy route-policy-name: References a routing policy to designate a next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters. You can specify the backup next hop in the routing policy.
Use the fast-reroute command to configure IS-IS fast reroute (FRR).
Use the undo fast-reroute command to restore the default.
By default, IS-IS FRR is disabled.
·       Do not use FRR and BFD at the same time. Otherwise, FRR may fail to take effect.
·       The automatic backup next hop calculation of FRR and that of TE are mutually exclusive.
Example
# Enable IS-IS FRR to automatically calculate a backup next hop for all routes.
[Sysname] isis 1
[Sysname-isis-1] fast-reroute auto
# Enable IS-IS FRR to designate a backup next hop by using a referenced routing policy named frr.
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface GiabitEthernet 3/1/1 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] isis 100
[Sysname-isis-100] fast-reroute route-policy frr
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter redistributed routes, ranging from 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter redistributed routes, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see the chapter “Routing policy configuration commands.”
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter redistributed routes, a case-sensitive string of 1 to 19 characters. For routing policy configuration information, see the chapter “Routing policy configuration commands.”
protocol: Filters routes redistributed from the routing protocol, which can be BGP, direct, IS-IS, OSPF, RIP or static.
process-id: Process ID, in the range of 1 to 65535. It is optional only when the protocol is IS-IS, OSPF or RIP.
Use the filter-policy export command to configure IS-IS to filter redistributed routes.
Use the undo filter-policy export command to disable IS-IS from filtering redistributed routes.
IS-IS does not filter redistributed routes by default.
If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command or in the routing policy, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
Related commands: filter-policy import.
# Reference ACL 2000 to filter redistributed routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter redistributed routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 export
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } import
undo filter-policy import
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter routes calculated from received LSPs, ranging from 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter routes calculated from received LSPs, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see the chapter “Routing policy configuration commands.”
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter routes calculated from received LSPs, a case-sensitive string of 1 to 63 characters. For routing policy configuration information, see the chapter “Routing policy configuration commands.”
Use the filter-policy import command to configure IS-IS to filter routes calculated from received LSPs.
Use the undo filter-policy import command to disable IS-IS from filtering routes calculated from received LSPs.
IS-IS does not filter routes calculated from received LSPs by default.
Related commands: filter-policy export.
# Reference ACL 2000 to filter routes calculated from received LSPs.
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter routes calculated from received LSPs.
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 import
flash-flood
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
flood-count flooding-count: Specifies the maximum number of LSPs to be flooded before the next SPF calculation, ranging from 1 to 15. The default is 5.
max-timer-interval flooding-interval: Specifies the delay (in milliseconds) of the flash flooding, ranging from 10 to 50000. The default is 10.
level-1: Enables flash flooding for level-1.
level-2: Enables flash flooding for level-2.
Use the flash-flood command to enable IS-IS LSP flash flooding.
Use the undo flash-flood command to disable IS-IS LSP flash flooding.
IS-IS LSP flash flooding is disabled by default.
If no level is specified, the command enables IS-IS LSP flash flooding for both Level-1 and Level-2.
# Enable fast flooding and specify the maximum LSPs to be sent as 10 and the delay time as 100 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
graceful-restart
undo graceful-restart
View
IS-IS view
Default level
2: System level
None
Use the graceful-restart command to enable IS-IS Graceful Restart capability.
Use the undo graceful-restart command to disable IS-IS Graceful Restart capability.
By default, IS-IS Graceful Restart capability is disabled.
# Enable the Graceful Restart capability for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
graceful-restart interval interval-value
undo graceful-restart interval
View
IS-IS view
Default level
2: System level
interval-value: Graceful Restart interval, in the range 30 to 1800 seconds.
Use the graceful-restart interval command to configure the Graceful Restart interval.
Use the undo graceful-restart interval command to restore the default Graceful Restart interval.
By default, the Graceful Restart interval is 300 seconds.
# Configure the Graceful Restart interval for IS-IS process 1 as 120 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart interval 120
undo graceful-restart suppress-sa
View
IS-IS view
Default level
2: System level
None
Use the graceful-restart suppress-sa command to suppress the SA (Suppress-Advertisement) bit during restart.
Use the undo graceful-restart suppress-sa command to set the SA bit.
By default, the SA bit is set during restart.
Suppressing the SA bit is mainly for avoiding black hole route. If a router starts or reboots without keeping the local forwarding table, sending packets to the router may result in a severe packet loss. To avoid this, you can set the SA bit of the hello packet sent by the GR Restarter to 1. Upon receiving such hello packets, the GR Helpers will not advertise the GR Restarter through LSP.
# Suppress the SA bit during Graceful Restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
View
IS-IS view
Default level
2: System level
protocol: Redistributes routes from a routing protocol, which can be BGP, direct, IS-IS, OSPF, RIP or static.
process-id: Process ID, in the range of 1 to 65535. It is available only when the protocol is IS-IS, OSPF or RIP.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. It is available when the protocol is BGP.
cost: Specifies a cost for redistributed routes.
The range of the cost depends on its style:
·           For the styles of narrow, narrow-compatible and compatible, the cost ranges from 0 to 63.
·           For the styles of wide, wide-compatible, the cost ranges from 0 to 16777215.
cost-type { external | internal }: Specifies the cost type. The internal type indicates internal routes, and the external type indicates external routes. If external is specified, the cost of a redistributed route to be advertised is added by 64 to make internal routes take priority over external routes. The type is external by default. The keywords are available only when the cost type is narrow, narrow-compatible or compatible.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, the routes are redistributed into the Level-2 routing table by default.
route-policy route-policy-name: Redistributes only routes satisfying the matching criteria of a routing policy, the name of which is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for redistributed routes from 1 to 4294967295.
Use the import-route command to redistribute routes from another routing protocol or another IS-IS process.
Use the undo import-route command to disable route redistribution from another routing protocol or another IS-IS process.
No route redistribution is configured by default.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
Related commands: import-route isis level-2 into level-1.
CAUTION
CAUTION:
·       Using the import-route bgp command redistributes only EBGP routes. Using the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes, but this may cause routing loops; be cautious with this command.
·       Only active routes can be redistributed. Use the display ip routing-table protocol command to display route state information.
# Redistribute static routes and set the cost to 15.
[Sysname] isis 1
[Sysname-isis-1] import-route static cost 15
import-route isis level-2 into level-1 [ filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } | tag tag ] *
undo import-route isis level-2 into level-1
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter routes from Level-2 to Level-1, ranging from 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter routes from Level-2 to Level-1, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see the chapter “Routing policy configuration commands.”
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter routes from Level-2 to Level-1, a case-sensitive string of 1 to 63 characters. For routing policy configuration information, see the chapter “Routing policy configuration commands.”
tag tag: Specifies a tag value from 1 to 4294967295 for redistributed routes.
Use the import-route isis level-2 into level-1 command to enable route leaking from Level-2 to Level-1.
Use the undo import-route isis level-2 into level-1 command to disable routing leaking.
No route leaking is configured by default.
You can specify a routing policy in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
If a filter policy is configured, only routes passing it can be advertised into the Level-1 area.
Related commands: import-route.
# Enable route leaking from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] import-route isis level-2 into level-1
import-route limit number
undo import-route limit
View
IS-IS view
Default level
2: System level
number: Maximum number of redistributed Level 1/Level 2 IPv4 routes, in the range of 1 to 1048576.
Use the import-route limit command to configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
Use the undo import-route limit command to restore the default.
# Configure IS-IS process 1 to redistribute up to 1000 Level 1/Level 2 IPv4 routes.
[Sysname] isis 1
[Sysname-isis-1] import-route limit 1000
isis
undo isis [ process-id ]
View
Default level
2: System level
process-id: Process ID, ranging from 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS process belongs to the public network.
Use the isis command to enable an IS-IS process and specify an associated VPN instance, enter IS-IS view, or both.
Use the undo isis command to disable an IS-IS process.
Related commands: isis enable, network-entity.
# Enable IS-IS routing process 1, with the system ID being 0000.0000.0002, and area ID being 01.0001.
[Sysname] isis 1
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
isis authentication-mode { md5 | simple } password [ level-1 | level-2 ] [ ip | osi ]
undo isis authentication-mode [ { md5 | simple } password ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
password: Specifies a password. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or ciphertext. A plain text password can be a string of up to 16 characters, such as user918. A cipher password must be a string of 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
level-1: Configures the password for Level-1.
level-2: Configures the password for Level-2.
ip: Checks IP related fields in LSPs and SNPs.
osi: Checks OSI related fields in LSPs and SNPs.
·       This command is not available in loopback interface view.
·       Whether a password should use ip or osi is not affected by the actual network environment.
Use the isis authentication-mode command to set the IS-IS authentication mode and password for an interface.
Use the undo isis authentication-mode command to restore the default.
No neighbor relationship authentication is configured by default.
The password in the specified mode is inserted into all outgoing hello packets and is used for authenticating the incoming hello packets. Only the authentication succeeds can the neighbor relationship be formed.
·       For two routers to become neighbors, the same authentication mode and password must be specified at both ends.
·       If you configure a password without specifying a level, the password applies to both Level-1 and Level-2.
·       If neither ip nor osi is specified, the OSI related fields in LSPs are checked.
·       The level-1 and level-2 keywords are supported on Layer 3 Ethernet interfaces and VLAN interfaces.
·       The level-1 and level-2 keywords are configurable on an interface that has had IS-IS enabled with the isis enable command.
Related commands: area-authentication-mode, domain authentication-mode.
# Configure the plain text password easykey for POS 2/1/1.
[Sysname-POS2/1/1] isis authentication-mode simple easykey
isis bfd enable
isis bfd enable
undo isis bfd enable
View
Interface view
Default level
2: System level
None
Use the isis bfd enable command to enable BFD on an IS-IS interface for link failure detection.
Use the undo isis bfd enable command to disable BFD on an IS-IS interface.
By default, an IS-IS interface is not enabled with BFD.
# Enable BFD for IS-IS on GigabitEthernet 4/1/1.
[Sysname] interface GigabitEthernet 4/1/1
[Sysname-GigabitEthernet4/1/1] isis enable
[Sysname-GigabitEthernet4/1/1] isis bfd enable
isis circuit-level
isis circuit-level [ level-1 | level-1-2 | level-2 ]
undo isis circuit-level
View
Interface view
Default level
2: System level
level-1: Sets the circuit level to Level-1.
level-1-2: Sets the circuit level to Level-1-2.
level-2: Sets the circuit level to Level-2.
Use the isis circuit-level command to set the circuit level for the interface.
Use the undo isis circuit-level command to restore the default.
An interface can establish either the Level-1 or Level-2 adjacency by default.
For a Level-1 (Level-2) router, the circuit level can only be Level-1 (Level-2). For a Level-1-2 router, you need to specify a circuit level for a specific interface to form only the specified level neighbor relationship.
Related commands: is-level.
# POS2/1/1 is connected to a non backbone router in the same area. Configure the circuit level of POS2/1/1 as Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-POS2/1/1] isis enable
[Sysname-POS2/1/1] isis circuit-level level-1
undo isis circuit-type
View
Interface view
Default level
2: System level
None
Use the isis circuit-type p2p command to configure the network type for an interface as P2P.
Use the undo isis circuit-type command to cancel the configuration.
By default, the network type of an interface depends on the physical media. (The network type of a VLAN interface is broadcast.)
Interfaces with different network types operate differently. For example, broadcast interfaces on a network need to elect a DIS and flood CSNP packets to synchronize the LSDBs, and P2P interfaces on a network need not elect a DIS and have a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, configure the network type of attached interfaces as P2P to avoid DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
·       You can perform this configuration only for a broadcast network with only two attached routers.
·       This command is not supported in loopback interface view.
# Configure the network type of the GigabitEthernet 1/1/1 interface as P2P.
[Sysname] interface GigabitEthernet 1/1/1
[Sysname-GigabitEthernet1/1/1] isis enable
[Sysname-GigabitEthernet1/1/1] isis circuit-type p2p
isis cost
isis [ ipv6-unicast ] cost value [ level-1 | level-2 ]
undo isis [ ipv6-unicast ] cost [ value ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
ipv6-unicast: Specifies an IPv6 unicast topology.
value: Specifies an IS-IS cost for the interface. The cost range differs with cost styles.
·           For cost styles narrow, narrow-compatible and compatible, the cost ranges from 1 to 63.
·           For cost styles wide and wide-compatible, the cost ranges from 1 to 16777215.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
Use the isis cost command to set the IS-IS cost of an interface.
Use the undo isis cost command to restore the default.
No cost is configured by default.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
H3C recommends to configure a proper IS-IS cost for each interface to guarantee correct route calculation.
Relate command: circuit-cost.
# Configure the Level-2 IS-IS cost as 5 for POS2/1/1.
[Sysname-POS2/1/1] isis cost 5 level-2
isis dis-name
isis dis-name symbolic-name
undo isis dis-name
View
Interface view
Default level
2: System level
symbolic-name: Specifies a DIS name, a string of 1 to 64 characters.
Use the isis dis-name command to configure a name for a DIS to represent the pseudo node on a broadcast network.
Use the undo isis dis-name command to remove the configuration.
No name is configured for the DIS by default.
This command takes effect only on a router that must have dynamic system ID to host name mapping enabled. This command is not supported on a Point-to-Point interface.
# Configure the DIS name as LOCALAREA.
[Sysname-GigabitEthernet1/1/1] isis dis-name LOCALAREA
isis dis-priority
isis dis-priority value [ level-1 | level-2 ]
undo isis dis-priority [ value ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
value: Specifies a DIS priority for the interface, ranging from 0 to 127.
level-1: Applies the DIS priority to Level-1.
level-2: Applies the DIS priority to Level-2.
Use the isis dis-priority command to specify a DIS priority at a specified level for an interface.
Use the undo isis dis-priority command to restore the default priority of 64 for Level-1 and Level-2.
If neither level-1 nor level-2 is specified in this command, the DIS priority applies to both Level-1 and Level-2.
On an IS-IS broadcast network, a router should be elected as the DIS at each routing level. You can specify a DIS priority at a level for an interface. The greater the interface’s priority is, the more likelihood it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest SNPA (Subnetwork Point of Attachment) address (SNPA addresses are MAC addresses on a broadcast network) becomes the DIS.
IS-IS has no backup DIS and the router with a priority of 0 can also participate in DIS election.
# Configure the DIS priority on Level-2 as 127 for GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] isis dis-priority 127 level-2
isis enable
isis enable [ process-id ]
undo isis enable
View
Interface view
Default level
2: System level
process-id: Specifies a IS-IS process ID, ranging from 1 to 65535. The default is 1.
Use the isis enable command to enable an IS-IS process on the interface.
Use the undo isis enable command to disable IS-IS.
No IS-IS routing process is enabled on an interface by default.
Related commands: isis, network-entity.
# Create IS-IS routing process 1, and enable it on the GigabitEthernet 3/1/1 interface.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] isis enable 1
isis mesh-group
isis mesh-group { mesh-group-number | mesh-blocked }
undo isis mesh-group
View
Interface view
Default level
2: System level
mesh-group-number: Mesh group number, ranging from 1 to 4294967295.
mesh-blocked: Blocks the interface, which sends LSPs only after receiving LSP requests.
Use the isis mesh-group command to add the interface into a specified mesh group or block the interface.
Use the undo isis mesh-group command to restore the default.
By default, an interface does not belong to any mesh group.
For an interface not in a mesh group, it follows the normal process to flood the received LSPs to other interfaces. For the NBMA network with high connectivity and multiple point-to-point links, this will cause repeated LSP flooding and bandwidth waste.
After an interface is added to a mesh group, it will only flood a received LSP or a generated LSP to interfaces not belonging to the same mesh group.
If you block an interface, the interface can send LSPs only after receiving LSP requests.
·       The mesh-group feature is only available for a point-to-point link interface.
# Add the frame relay subinterface POS3/1/1 to mesh-group 3.
[Sysname] interface POS 3/1/1
[Sysname-POS3/1/1] isis mesh-group 3
isis mib-binding
isis mib-binding process-id
undo isis mib-binding
View
Default level
2: System level
process-id: IS-IS process ID, in the range 1 to 65535.
Use the isis mib-binding command to bind MIBs with an IS-IS process.
Use the undo isis mib-binding command to restore the default.
By default, MIBs are bound with IS-IS process 1.
# Bind MIBs with IS-IS process 100.
[Sysname] isis mib-binding 100
isis peer-ip-ignore
isis peer-ip-ignore
undo isis peer-ip-ignore
View
Interface view
Default level
2: System level
None
Use the isis peer-ip-ignore command to configure the PPP interface not to check the peer’s IP address in received hello packets.
Use the undo isis peer-ip-ignore command to restore the default.
By default, the PPP interface checks the peer’s IP address upon receiving a hello packet.
An IS-IS PPP interface requires the sender of a hello packet must be on the same network segment as it. Otherwise, it discards the hello packet. You can use the isis peer-ip-ignore command to disable this restriction.
# Configure POS2/1/1 not to check the peer’s IP address in the received Hello packets.
[Sysname-POS2/1/1] isis peer-ip-ignore
isis silent
isis silent
undo isis silent
View
Interface view
Default level
2: System level
None
Use the isis silent command to disable the interface from sending and receiving IS-IS packets.
Use the undo isis silent command to restore the default.
By default, an interface is not disabled from sending and receiving IS-IS packets.
The feature is not supported on the loopback interface.
# Disable POS2/1/1 from sending and receiving IS-IS packets.
[Sysname-POS2/1/1] isis silent
isis small-hello
isis small-hello
undo isis small-hello
View
Interface view
Default level
2: System level
None
Use the isis small-hello command to configure the interface to send small hello packets without CLVs.
Use the undo isis small-hello command to restore the default.
An interface sends standard hello packets by default.
# Configure the POS2/1/1 interface to send small Hello packets.
[Sysname-POS2/1/1] isis small-hello
isis timer csnp
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ seconds ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
seconds: Specifies on the DIS of a broadcast network the interval in seconds for sending CSNP packets, ranging from 1 to 600.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
Use the isis timer csnp command to specify on the DIS of a broadcast network the interval for sending CSNP packets.
Use the undo isis timer csnp command to restore the default.
The default CSNP interval is 10 seconds.
·       If no level is specified, the CSNP interval applies to both Level-1 and Level-2.
·       This command only applies to the DIS of a broadcast network, which sends CSNP packets periodically for LSDB synchronization.
# Configure Level-2 CSNP packets to be sent every 15 seconds over POS2/1/1.
[Sysname-POS2/1/1] isis timer csnp 15 level-2
isis timer hello
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ seconds ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
seconds: Specifies the interval in seconds for sending hello packets, ranging from 3 to 255.
level-1: Specifies the interval for sending Level-1 hello packets.
level-2: Specifies the interval for sending Level-2 hello packets.
Use the isis timer hello command to specify the interval for sending hello packets.
Use the undo isis timer hello command to restore the default.
The default hello interval is 10 seconds.
·       Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify an interval for the two levels respectively. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify an interval for two levels respectively.
·       You can configure keywords level-1 and level-2 only on broadcast interfaces. Before doing that, you need to enable IS-IS on the interface.
·       As the shorter the interval is, the more system resources will be occupied, you should configure a proper interval as needed.
·       If no level is specified, the hello interval applies to both Level-1 and Level-2.
Related commands: isis timer holding-multiplier.
# Configure Level-2 hello packets to be sent every 20 seconds over POS2/1/1.
[Sysname-POS2/1/1] isis timer hello 20
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ value ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
value: Number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
Use the isis timer holding-multiplier command to specify the IS-IS hello multiplier.
Use the undo isis timer holding-multiplier command to restore the default.
The default IS-IS hello multiplier is 3.
With the IS-IS hello multiplier configured, a router can uses hello packets to notify its neighbor router of the adjacency hold time (hello multiplier times hello interval). If the neighbor router receives no hello packets from this router within the hold time, it declares the adjacency down. You can adjust the adjacency hold time by changing the hello multiplier or the hello interval on an interface.
·       Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify a hello multiplier for the two levels respectively. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify Level-1 or Level-2.
·       If no level is specified, the hello multiplier applies to the current level.
Related commands: isis timer hello.
# Configure the hello multiplier as 6 for interface POS2/1/1.
[Sysname-POS2/1/1] isis timer holding-multiplier 6
isis timer lsp
isis timer lsp time [ count count ]
undo isis timer lsp
View
Interface view
Default level
2: System level
time: Specifies the minimum interval in milliseconds for sending link-state packets, ranging from 1 to 1000.
count: Specifies the maximum number of link-state packets to be sent at one time, in the range of 1 to 1000. The default is 5.
Use the isis timer lsp command to configure the minimum interval for sending LSPs on the interface and specify the maximum LSPs that can be sent per time.
Use the undo isis timer lsp command to restore the default of 33ms.
Related commands: isis timer retransmit.
# Configure the interval as 500 milliseconds for sending LSPs on interface POS2/1/1.
[Sysname-POS2/1/1] isis timer lsp 500
isis timer retransmit seconds
undo isis timer retransmit
View
Interface view
Default level
2: System level
seconds: Specifies the interval in seconds for retransmitting LSP packets, ranging from 1 to 300.
Use the isis timer retransmit command to configure the interval for retransmitting LSP packets over a point-to-point link.
Use the undo isis timer retransmit command to restore the default.
By default, the retransmission interval is 5 seconds.
A P2P link requires a response to a sent LSP. If no response is received within the retransmission interval, the LSP is retransmitted.
You need not use this command over a broadcast link where CNSPs are broadcast periodically.
Related commands: isis timer lsp.
·       Configure a proper retransmission interval to avoid unnecessary retransmissions.
·       Perform this configuration only when the link layer protocol is PPP.
# Configure the LSP retransmission interval as 10 seconds for POS2/1/1.
[Sysname-POS2/1/1] isis timer retransmit 10
is-level
is-level { level-1 | level-1-2 | level-2 }
undo is-level
View
IS-IS view
Default level
2: System level
level-1: Configures the router to work on Level-1, which means it only calculates routes within the area, and maintains the L1 LSDB.
level-1-2: Configures the router to work on Level-1-2, which means it calculates routes and maintains the LSDBs for both L1 and L2.
level-2: Configures the router to work on Level-2, which means it calculates routes and maintains the LSDB for L2 only.
Use the is-level command to specify the IS level.
Use the undo is-level command to restore the default.
The default IS level is level-1-2.
Configure all the routers as either Level-1 or Level-2 if only one area is present, because the routers do not need to maintain two identical databases at the same time. If the only area is an IP network, configure all the routers as Level-2 for scalability.
Related commands: isis circuit-level.
# Configure the router to work in Level-1.
[Sysname] isis 1
[Sysname-isis-1] is-level level-1
is-name
is-name sys-name
undo is-name
View
IS-IS view
Default level
2: System level
symbolic-name: Specifies a host name for the local IS, a string of 1 to 64 characters.
Use the is-name command to specify a host name for the IS to enable dynamic system ID to hostname mapping.
Use the undo is-name command to disable dynamic system ID to hostname mapping.
Dynamic system ID to hostname mapping is not enabled by default.
# Configure a host name for the local IS.
[Sysname] isis 1
is-name map
is-name map sys-id map-sys-name
undo is-name map sys-id
View
IS-IS view
Default level
2: System level
sys-id: System ID or pseudonode ID of a remote IS.
map-sys-name: Specifies a host name for the remote IS, a string of 1 to 64 characters.
Use the is-name map command to configure a system ID to host name mapping for a remote IS.
Use the undo is-name map command to remove the mapping.
Each remote IS system ID corresponds to only one name.
# Map the host name RUTB to the system ID 0000.0000.0041 of the remote IS.
[Sysname] isis 1
is-snmp-traps enable
undo is-snmp-traps
View
IS-IS view
Default level
2: System level
None
Use the is-snmp-traps enable command to enable the SNMP Trap function of IS-IS.
Use the undo is-snmp-traps command to disable this function.
SNMP Trap is enabled by default.
# Enable SNMP Trap.
[Sysname] isis 1
[Sysname-isis-1] is-snmp-traps enable
log-peer-change (IS-IS view)
log-peer-change
undo log-peer-change
View
IS-IS view
Default level
2: System level
None
Use the log-peer-change command to enable the logging of IS-IS neighbor state changes.
Use the undo log-peer-change command to disable the logging.
The logging is enabled by default.
After the logging is enabled, information about IS-IS adjacency state changes is sent to the configuration terminal.
# Enable logging on the IS-IS adjacency state changes.
[Sysname] isis 1
[Sysname-isis-1] log-peer-change
lsp-fragments-extend
lsp-fragments-extend [ [ level-1 | level-1-2 | level-2 ] | [ mode-1 | mode-2 ] ] *
undo lsp-fragments-extend
View
IS-IS view
Default level
2: System level
level-1: Applies the fragment extension mode to Level-1 LSPs.
level-1-2: Applies the fragment extension mode to both Level-1 and Level-2 LSPs.
level-2: Applies the fragment extension mode to Level-2 LSPs.
mode-1: Fragment extension mode 1, used on a network where some routers do not support LSP fragment extension.
mode-2: Fragment extension mode 2, used on a network where all routers support LSP fragment extension.
Use the lsp-fragments–extend command to enable an LSP fragment extension mode for a level.
Use the undo lsp-fragments–extend command to disable LSP fragment extension for a level.
LSP fragment extension is disabled by default.
If no mode is specified, LSP fragment extension mode 1 is enabled.
If no level is specified, the LSP fragment extension mode is enabled for both Level-1 and Level-2.
# Enable LSP fragment extension mode 1 for Level-2.
[Sysname] isis 1
[Sysname-isis-1] lsp-fragments-extend mode-1 level-2
lsp-length originate
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
size: Specifies the maximum size in bytes of LSP packets, ranging from 512 to 16384.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
Use the lsp-length originate command to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use the undo lsp-length originate command to restore the default.
By default, the maximum size of generated Level-1 and Level-2 LSPs is 1497 bytes.
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
# Configure the maximum size of the generated Level-2 LSPs as 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length originate 1024 level-2
lsp-length receive
lsp-length receive size
undo lsp-length receive
View
IS-IS view
Default level
2: System level
size: Maximum size of received LSPs, in the range of 512 to 16384 bytes.
Use the lsp-length receive command to configure the maximum size of received LSPs.
Use the undo lsp-length receive command to restore the default.
By default, the maximum size of received LSPs is 1497 bytes.
# Configure the maximum size of received LSPs.
[Sysname] isis 1
[Sysname-isis-1] lsp-length receive 1024
maximum load-balancing (IS-IS view)
maximum load-balancing number
undo maximum load-balancing
View
IS-IS view
Default level
2: System level
number: Maximum number of equal-cost routes, in the range of 1 to 8.
Use the maximum load-balancing command to configure the maximum number of equal-cost routes.
Use the undo maximum load-balancing command to restore the default.
The maximum number is 8.
# Configure the maximum number of equal-cost routes as 2.
[Sysname] isis 100
[Sysname-isis-100] maximum load-balancing 2
# Restore the default maximum number of equal-cost routes.
[Sysname-isis-100] undo maximum load-balancing
network-entity
network-entity net
undo network-entity net
View
IS-IS view
Default level
2: System level
net: Network Entity Title (NET) in the format of X…X.XXXX....XXXX.00 in hexadecimal notation, with the first part X…X being the area address, the middle part XXXX....XXXX (a total of 12 “X”) being the router’s system ID, and the last part 00 being SEL.
Use the network-entity command to configure the Network Entity Title for an IS-IS routing process.
Use the undo network-entity command to delete a NET.
No NET is configured by default.
A NET is a special NSAP address with the SEL being 0. The length of the NET is in the range 8 bytes to 20 bytes.
A NET comprises three parts:
·           Area ID. Its length is in the range of 1 to 13 bytes.
·           System ID. A system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·           SEL. It has a value of 0 and a fixed 1-byte length.
For example, a NET is ab.cdef.1234.5678.9abc.00, where area ID is ab.cdef, system ID is 1234.5678.9abc, and SEL is 00.
Related commands: isis, isis enable.
# Specify the NET as 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis 1
preference (IS-IS view)
undo preference
View
IS-IS view
Default level
2: System level
preference: Specifies the preference for IS-IS protocol, ranging from 1 to 255.
route-policy route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters. The preference applies to routes passing the routing policy.
Use the preference command to configure the preference for IS-IS.
Use the undo preference command to restore the default.
By default, IS-IS preference is 15.
If a routing policy is specified in this command, the preference (if any) set by the routing policy applies to those matched routes. Other routes use the preference set by the preference command.
When a router runs multiple routing protocols at the same time, the system will configure a preference to each routing protocol. If several protocols find routes to the same destination, the route of the routing protocol with the highest preference is selected.
# Configure the preference of IS-IS protocol as 25.
[Sysname] isis 1
[Sysname-isis-1] preference 25
reset isis all
reset isis all [ process-id | vpn-instance vpn-instance-name ]
View
Default level
2: System level
process-id: Clears the data structure information of an IS-IS process numbered from 1 to 65535.
vpn-instance vpn-instance-name: Clears the data structure information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the data structure information of the public network is cleared.
Use the reset isis all command to clear all IS-IS data structure information.
No data structure information is cleared by default.
This command is used when the LSP needs to be updated immediately. For example, after performing the area-authentication-mode and domain-authentication-mode commands, you can use this command to clear old LSPs.
# Clear all IS-IS data structure information.
<Sysname> reset isis all
reset isis peer
reset isis peer system-id [ process-id | vpn-instance vpn-instance-name ]
View
Default level
2: System level
system-id: Specifies the system ID of an IS-IS neighbor.
process-id: Clears the data structure information of an IS-IS process with an ID from 1 to 65535.
Use the reset isis peer command to clear the data structure information of a specified IS-IS neighbor.
This command is used when you need to re-establish an IS-IS neighbor relationship.
# Clear the data structure information of the neighbor with the system ID 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
set-overload
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] [ allow { external | interlevel } * ]
undo set-overload
View
IS-IS view
Default level
2: System level
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set; if not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
·           system-id: Specifies the neighbor.
·           timeout1: The timeout1 interval is in the range 5 to 86400 seconds and defaults to 600 seconds.
·           nbr-timeout: The timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The interval is in the range 5 to 86400 seconds and defaults to 600 seconds.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learned from different IS-IS levels with the allow keyword specified.
Use the set-overload command to set the overload bit.
Use the undo set-overload command to clear the overload bit.
The overload bit is not set by default.
If the on-startup keyword is not specified, the command sets the overload bit immediately until the undo set-overload command is executed.
If the on-startup keyword is specified, IS-IS sets the overload bit upon system startup and keeps it set within the timeout2 interval.
# Set overload flag on the current router.
[Sysname] isis 1
[Sysname-isis-1] set-overload
summary (IS-IS view)
summary ip-address { mask | mask-length } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ip-address { mask | mask-length } [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Default level
2: System level
ip-address: Destination IP address of the summary route.
mask: Mask of the destination IP address, in dotted decimal format.
mask-length: Mask length, in the range of 0 to 32.
avoid-feedback: Avoids learning summary routes by route calculation.
generate_null0_route: Generate the Null 0 route to avoid routing loops.
level-1: Summarize only the routes redistributed to Level-1.
level-1-2: Summarizes the routes redistributed to both Level-1 and Level-2.
level-2: Summarizes only the routes redistributed to Level-2.
tag tag: Specifies a management tag, in the range of 1 to 4294967295.
Use the summary command to configure a summary route.
Use the undo summary command to remove a summary route.
No summarization is configured by default.
If no level is specified, only the level-2 routes will be summarized by default.
You can summarize multiple contiguous networks into a single network to reduce the size of the routing table, as well as that of LSP and LSDB generated by the router. It is allowed to summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of those summarized routes.
The router summarizes only routes in local LSPs.
# Configure a summary route of 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1] summary 202.0.0.0 255.0.0.0
timer lsp-generation
timer lsp-generation maximum-interval [ initial-interval [ second-wait-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
maximum-interval: Maximum wait interval in seconds for generating IS-IS LSPs, in the range 1 to 120.
initial-interval: Initial wait interval in milliseconds before generating the first IS-IS LSP, in the range 10 to 60000. The default is 0.
second-wait-interval: Wait interval in milliseconds before generating the second LSP, in the range 10 to 60000. The default is 0.
level-1: Applies the intervals to Level-1.
level-2: Applies the intervals to Level-2 .If no level is specified, the specified intervals apply to both Level-1 and Level-2.
Use the timer lsp-generation command to specify the wait interval before generating IS-IS LSPs.
Use the undo timer lsp-generation command to restore the default.
By default, the wait interval before LSP generation is 2 seconds.
·           If only the maximum interval is specified, IS-IS waits the maximum interval before generating an LSP.
·           If both the maximum and initial intervals are specified:
¡  IS-IS waits the initial interval before generating the first LSP.
¡  If the network topology is unstable—triggers occur at intervals shorter than the maximum interval, IS-IS waits the maximum interval before generating the first LSP until the network topology is stable.
·           If the maximum, initial, and second wait intervals are specified:
¡  If the network topology is unstable—triggers occur at intervals shorter than the maximum interval, IS-IS waits the second-wait-interval before generating the second LSP and penalty is applied on the wait interval before generating the next LSP. For each subsequent trigger, the wait interval before generating the LSP will be two times the previous wait interval until the maximum interval is reached.
¡  After the network topology is stable—triggers occur at intervals greater than the maximum interval, the wait interval before generating LSPs is restored to the initial interval.
# Set the maximum, initial, and second wait intervals to 10 seconds, 100 milliseconds and 200 milliseconds respectively.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-generation 10 100 200
timer lsp-max-age
timer lsp-max-age seconds
undo timer lsp-max-age
View
IS-IS view
Default level
2: System level
seconds: Specifies the LSP maximum aging time in seconds, ranging from 1 to 65535.
Use the timer lsp-max-age command to set the LSP maximum age in the LSDB.
Use the undo timer lsp-max-age command to restore the default.
The default LSP maximum age is 1200 seconds.
Related commands: timer lsp-refresh.
# Set the maximum LSP age to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh seconds
undo timer lsp-refresh
View
IS-IS view
Default level
2: System level
seconds: LSP refresh interval in seconds, ranging from 1 to 65534.
Use the timer lsp-refresh command to configure the LSP refresh interval.
Use the undo timer lsp-refresh to restore the default.
The default LSP refresh interval is 900 seconds.
Related commands: timer lsp-max-age.
To refresh LSPs before they are aged out, the interval configured by the timer lsp-refresh command must be smaller than that configured by the timer lsp-max-age command.
# Configure the LSP refresh interval as 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-refresh 1500
timer spf
timer spf maximum-interval [initial-interval [second-wait-interval ] ]
undo timer spf
View
IS-IS view
Default level
2: System level
maximum-interval: Maximum SPF calculation interval in seconds, ranging from 1 to 120.
initial-interval: Wait interval before the first SPF calculation, in milliseconds, ranging from 10 to 60000.
second-wait-interval: Wait interval before the second SPF calculation, in milliseconds, ranging from 10 to 60000.
Use the timer spf command to set the SPF calculation interval.
Use the undo timer spf command to restore the default.
The default IS-IS SPF calculation interval is 10 seconds.
·           If only the maximum interval is specified, IS-IS waits the maximum interval before performing the SPF calculation.
¡  IS-IS waits the initial interval before performing the first SPF calculation.
¡  When SPF calculation triggers occur at intervals shorter than the maximum interval, the topology is considered unstable and IS-IS waits the maximum interval before performing the SPF calculation until the topology is stable.
·           If maximum-interval, initial-interval, and second-wait-interval are specified:
¡  When SPF calculation triggers occur at intervals shorter than the maximum interval, the topology is considered unstable, IS-IS will wait the second-interval before performing the second SPF calculation and penalty is applied on the wait interval for the next SPF calculation. For each subsequent trigger, the wait interval before SPF calculation will be two times the previous wait interval until the maximum interval is reached.
¡  After the network topology becomes stable—triggers occur at intervals greater than the maximum interval, the wait interval before SPF calculation is restored to the initial interval.
# Configure the maximum SPF calculation interval as 10 seconds, the wait interval before the first SPF calculation as 100 milliseconds, and the wait interval before the second SPF calculation as 200 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] timer spf 10 100 200
virtual-system
virtual-system virtual-system-id
undo virtual-system virtual-system-id
View
IS-IS view
Default level
2: System level
virtual-system-id: Virtual system ID of the IS-IS process.
Use the virtual-system command to configure a virtual system ID for the IS-IS process. Use the undo virtual-system command to remove a virtual system ID.
Up to 50 virtual system IDs can be configured for the IS-IS process.
# Set a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] virtual-system 2222.2222.2222
