04-IPoE命令
本章节下载: 04-IPoE命令 (459.87 KB)
1.1.1 display ip subscriber interface-leased
1.1.2 display ip subscriber interface-leased statistics
1.1.3 display ip subscriber offline statistics
1.1.4 display ip subscriber session
1.1.5 display ip subscriber session statistics
1.1.6 display ip subscriber subnet-leased
1.1.7 display ip subscriber subnet-leased statistics
1.1.9 ip subscriber access-out
1.1.10 ip subscriber dhcp domain
1.1.11 ip subscriber dhcp max-session
1.1.12 ip subscriber dhcp username
1.1.15 ip subscriber initiator dhcp enable
1.1.16 ip subscriber initiator unclassified-ip enable
1.1.17 ip subscriber interface-leased
1.1.18 ip subscriber nas-port-id format
1.1.19 ip subscriber nas-port-id nasinfo-insert
1.1.20 ip subscriber nas-port-type
1.1.22 ip subscriber service-identify
1.1.23 ip subscriber session static
1.1.24 ip subscriber subnet-leased
1.1.25 ip subscriber timer quiet
1.1.27 ip subscriber unclassified-ip domain
1.1.28 ip subscriber unclassified-ip max-session
1.1.29 ip subscriber unclassified-ip username
1.1.30 ip subscriber user-detect
1.1.32 reset ip subscriber offline statistics
1.1.33 reset ip subscriber session
1.2.1 display ipv6 subscriber interface-leased
1.2.2 display ipv6 subscriber interface-leased statistics
1.2.3 display ipv6 subscriber offline statistics
1.2.4 display ipv6 subscriber session
1.2.5 display ipv6 subscriber session statistics
1.2.6 display ipv6 subscriber subnet-leased
1.2.7 display ipv6 subscriber subnet-leased statistics
1.2.9 ipv6 subscriber access-out
1.2.10 ipv6 subscriber dhcp domain
1.2.11 ipv6 subscriber dhcp max-session
1.2.12 ipv6 subscriber dhcp username
1.2.15 ipv6 subscriber initiator dhcp enable
1.2.16 ipv6 subscriber initiator ndrs enable
1.2.17 ipv6 subscriber initiator unclassified-ip enable
1.2.18 ipv6 subscriber interface-leased
1.2.19 ipv6 subscriber nas-port-id format
1.2.20 ipv6 subscriber nas-port-id nasinfo-insert
1.2.21 ipv6 subscriber nas-port-type
1.2.22 ipv6 subscriber ndrs domain
1.2.23 ipv6 subscriber ndrs max-session
1.2.24 ipv6 subscriber ndrs username
1.2.25 ipv6 subscriber password
1.2.26 ipv6 subscriber service-identify
1.2.27 ipv6 subscriber session static
1.2.28 ipv6 subscriber subnet-leased
1.2.29 ipv6 subscriber timer quiet
1.2.31 ipv6 subscriber unclassified-ip domain
1.2.32 ipv6 subscriber unclassified-ip max-session
1.2.33 ipv6 subscriber unclassified-ip username
1.2.34 ipv6 subscriber user-detect
1.2.36 reset ipv6 subscriber offline statistics
1.2.37 reset ipv6 subscriber session
仅SPEX-1204单板支持配置本功能。
display ip subscriber interface-leased命令用来显示IPv4接口专线用户信息。
display ip subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv4接口专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4接口专线用户信息。
slot slot-number:显示指定单板的IPv4接口专线用户信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的IPv4接口专线用户信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4接口专线用户信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4接口专线用户信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的IPv4接口专线用户信息。
<Sysname> display ip subscriber interface-leased interface GigabitEthernet 3/1/1
Basic:
Access Interface : GE3/1/1
VPN instance : N/A
Username : a
User ID : 0x38080003
State : Online
Service node : Slot 3 Cpu 0
Domain : radius
Login time : Sep 15 18:54:30 2014
Online time (hh:mm:ss) : 00:16:37
AAA:
IP pool : ipoe
Session idle time : N/A
Session duration : N/A, remaining: N/A
Remaining traffic : N/A
Max multicast addresses : 4
Multicast address list : N/A
QoS:
User profile : h3c (active)
Session group profile : N/A
User group acl : N/A
Inbound CAR : CIR 100000bps PIR 200000bps (active)
Outbound CAR : CIR 300000bps PIR 400000bps (active)
Total traffic statistics:
Uplink packets/bytes : 0/0
DownLink packets/bytes : 0/0
ITA:
Level-1 Inbound CAR : CIR 1000bps PIR 10000bps (active)
Outbound CAR : CIR 1100bps PIR 4294967295bps (active)
uplink packets/bytes: 0/0
downLink packets/bytes: 0/0
Level-2 Inbound CAR : N/A
Outbound CAR : N/A
Level-3 Inbound CAR : CIR 1200bps PIR 12000bps (active)
Outbound CAR : CIR 1200bps PIR 12000bps (active)
Level-4 Inbound CAR : N/A
Outbound CAR : N/A
Level-5 Inbound CAR : CIR 1200bps PIR 12000bps (active)
Level-6 Inbound CAR : N/A
Outbound CAR : N/A
Level-7 Inbound CAR : N/A
Outbound CAR : N/A
Level-8 Inbound CAR : N/A
Outbound CAR : N/A
表1-1 display ip subscriber interface-leased命令显示信息描述表
Basic |
IPoE 会话的基本信息 |
用户所属的MPLS L3VPN,N/A表示用户属于公网 |
全局唯一的用户ID,只有用户在线后才会由系统分配,N/A表示暂未分配 |
· Invalid:无效状态 · Init:初始化 · Offline:正在下线 · Auth:认证中 · AuthFail:认证失败 · AuthPass :认证通过 · AssignedIP:用户已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
Login time |
用户登录时间 |
Online time (hh:mm:ss) |
用户本次上线的在线时长 |
AAA |
IPoE 会话的AAA授权信息 |
IP pool |
AAA授权的DHCP地址池名称,N/A表示AAA未授权该属性 |
Session idle time |
用户闲置切断时间,单位为秒,N/A表示不进行闲置切断 |
Session duration |
AAA授权的IPoE会话超时时间,单位为秒 · N/A:表示未下发会话时长 · Unlimited:表示会话时长无限 |
remaining |
AAA授权的IPoE会话剩余时长 只在Service node上可以查看到有效的剩余时长,非Service node上该字段显示为N/A |
Remaining traffic |
授权的剩余流量,单位为字节,N/A表示未对用户指定授权流量 |
Max multicast addresses |
AAA授权的用户能加入的组播组的最大数目 |
Multicast address list |
AAA授权的用户允许加入的组播组地址列表,N/A表示AAA未授权该属性 |
QoS |
IPoE 会话的QoS信息 |
AAA授权的User Profile名称。若未授权User Profile,则显示为N/A。授权状态包括如下: · active:AAA授权User Profile成功 · inactive:AAA授权User Profile失败或者设备上不存在该User Profile |
AAA授权的Session Group Profile名称。若未授权Session Group Profile,则显示为N/A。授权状态包括如下: · active:AAA授权Session Group Profile成功 · inactive:AAA授权Session Group Profile失败或者设备上不存在该Session Group Profile |
User group acl |
AAA授权的User group acl名称。若未授权User group acl,则显示为N/A。授权状态包括如下: · active:AAA授权User group acl成功 · inactive:AAA授权User group acl失败或者设备上不存在该User group acl · 授权结果未知 |
AAA授权的入方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。授权CAR的状态包括如下: · active:AAA授权入方向CAR成功 · inactive:AAA授权入方向CAR失败 · N/A:AAA未授权入方向CAR |
AAA授权的出方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps) 授权CAR的状态包括如下: · active:AAA授权出方向CAR成功 · inactive:AAA授权出方向CAR失败 · N/A:AAA未授权出方向CAR |
Total traffic statistics |
IPoE Session的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
IPoE Session的ITA信息 |
Level-n Inbound CAR |
AAA授权的计费等级为n的入方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。授权CAR的状态包括如下: active:AAA授权入方向CAR成功 inactive:AAA授权入方向CAR失败 N/A:AAA未授权入方向CAR n的取值范围为1~8 |
Outbound CAR |
AAA授权的计费等级为n的出方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps) 授权CAR的状态包括如下: · active:AAA授权出方向CAR成功 · inactive:AAA授权出方向CAR失败 · N/A:AAA未授权出方向CAR n的取值范围为1~8 |
计费等级为n的上行流量报文数/字节数,n的取值范围为1~8 |
计费等级为n的下行流量报文数/字节数,n的取值范围为1~8 |
display ip subscriber interface-leased statistics命令用来显示已经上线和正在上线的IPv4 IPoE接口专线用户统计信息。
display ip subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv4 IPoE接口专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE接口专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定单板上的IPv4 IPoE接口专线用户统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板中在位单板上的IPv4 IPoE接口专线用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv4 IPoE接口专线用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE接口专线用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的IPv4 IPoE接口专线用户统计信息。
<Sysname> display ip subscriber interface-leased statistics interface gigabitethernet 3/1/1
Total : 100
Init : 0
Authenticating : 20
Authenticate fail : 0
Authenticate pass : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-2 display ip subscriber interface-leased statistics命令显示信息描述表
成功分配到IP地址的用户数 |
display ip subscriber offline statistics命令用来显示IPv4 IPoE用户下线原因的统计信息。
display ip subscriber offline statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上IPoE用户下线原因的统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPoE用户下线原因的统计信息。
# 显示接口GigabitEthernet3/1/1上IPv4 IPoE用户下线原因的统计信息。
<Sysname> display ip subscriber offline statistics interface gigabitethernet 3/1/1
Total : 100
User request : 0
DHCP lease expire : 0
AAA lease expire : 0
Command cut : 80
AAA terminate : 0
Authorization fail : 0
Idle timeout : 10
Detect fail : 10
Not enough resource : 0
Interface down : 0
Interface shutdown : 0
VSRP event : 0
DHCP notify : 0
Other : 0
表1-3 display ip subscriber offline statistics命令显示信息描述表
DHCP租约到期正常下线的用户数 |
AAA租约到期正常下线的用户数 |
AAA强制下线的用户数 |
因接口状态为down下线的用户数 |
主动shutdown接口导致下线的用户数 |
VSRP(Virtual Service Redundancy Protocol,虚拟业务冗余协议) 状态变化引发的下线用户数(暂不支持) |
DHCP通知下线的用户数 |
· reset ip subscriber offline statistics
display ip subscriber session命令用来显示静态配置和动态触发的IPv4个人IPoE会话信息。
display ip subscriber session [ interface interface-type interface-number ] [ domain domain-name | ip ip-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv4个人IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4个人IPoE会话。
domain domain-name:显示使用指定ISP域认证的IPv4个人IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
ip ip-address:显示指定源IP地址的IPv4个人IPoE会话,ip-address为指定的IPv4地址。
vpn-instance vpn-instance-name:指定用户所属的VPN,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv4个人 IPoE会话位于公网中。
mac mac-address:显示指定源MAC地址的IPv4个人IPoE会话,形式为H-H-H。
static:显示静态配置的IPv4个人IPoE会话,不指定该参数时将显示静态配置的IPv4个人IPoE会话和动态触发创建的IPv4个人IPoE会话。
username name:显示指定用户名的IPv4个人IPoE会话,其中,name为1~255个字符的字符串,区分大小写。
slot slot-number:显示指定单板的IPv4个人IPoE会话,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的IPv4个人IPoE会话。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4个人IPoE会话,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4个人IPoE会话。(IRF模式)
verbose:显示IPv4个人IPoE会话的详细信息。如果不指定该参数,则只显示IPoE会话的简要信息。
# 显示用户IP为200.1.1.1,所属VPN为vpn1的IPv4 IPoE会话简要信息。
<Sysname> display ip subscriber session ip 200.1.1.1 vpn-instance vpn1
Type: D-Dhcp S-Static U-Unclassified-ip N-Ndrs
Interface IP address MAC address Type State
GE3/1/1 200.1.1.1 0010-9400-0002 U Online
# 显示所有静态配置和动态触发的IPv4 IPoE会话的详细信息。
<Sysname> display ip subscriber session verbose
Basic:
Username : 200.1.1.1
Domain : radius
VPN instance : vpn1
IP address : 200.1.1.1
MAC address : 0010-9400-0002
Service-VLAN/Customer-VLAN : -/-
Access interface : GE3/1/1
User ID : 0x38080002
VPI/VCI(for ATM) : 0/0
DHCP lease : N/A
DHCP remain lease : N/A
Login time : Sep 14 18:09:28 2014
Type : Unclassified-ip
State : Online
AAA:
IP pool : N/A
QoS:
User profile : profile1 (active)
Uplink packets/bytes : 594341/76075648
ITA:
Level-1 Inbound CAR : CIR 1000bps PIR 10000bps (inactive)
Outbound CAR : CIR 1100bps PIR 4294967295bps (inactive)
Outbound CAR : N/A
Level-3 Inbound CAR : CIR 1200bps PIR 12000bps (inactive)
Outbound CAR : CIR 1200bps PIR 12000bps (inactive)
Outbound CAR : N/A
Level-5 Inbound CAR : CIR 1200bps PIR 12000bps (inactive)
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
表1-4 display ip subscriber session命令显示信息描述表
Basic |
IPoE Session的基本信息 |
用户的IP地址 |
用户的MAC地址 |
服务提供商VLAN/用户VLAN(“-”表示没有VLAN信息) |
ATM的PVC信息 |
DHCP lease |
DHCP服务器分配给用户的IP地址租约时间,单位为秒 · N/A:表示无DHCP租约 · Unlimited:表示租约无限长 |
DHCP remain lease |
DHCP服务器分配给用户的IP地址租约剩余时长,只在service slot上可以看到有效的剩余时长,非service slot显示N/A |
Login time |
用户登录时间 |
用户本次上线的在线时长 |
IPoE会话的创建类型: · DHCP:DHCP报文触发创建 · Unclassified-ip:未知源IP报文触发创建 · Static:静态配置 |
· Invalid:无效状态 · Init:初始化 · Offline:正在下线中 · Auth:认证中 · AuthFail:认证失败 · AuthPass:认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
AAA |
IPoE Session的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
AAA授权的User Profile名称。若未授权User Profile,则显示为N/A。授权状态包括如下: · active:AAA授权User Profile成功 · inactive:AAA授权User Profile失败或者设备上不存在该User Profile · 授权结果未知 |
AAA授权的Session Group Profile名称。若未授权Session Group Profile,则显示为N/A。授权状态包括如下: · active:AAA授权Session Group Profile成功 · inactive:AAA授权Session Group Profile失败或者设备上不存在该Session Group Profile · 授权结果未知 |
User group acl |
IPoE 会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
AAA授权的计费等级为n的入方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。授权CAR的状态包括如下: · active:AAA授权入方向CAR成功 · inactive:AAA授权入方向CAR失败 · N/A:AAA未授权入方向CAR n的取值范围为1~8 |
Outbound CAR |
display ip subscriber session statistics命令用来显示已经上线和正在上线的IPv4 IPoE个人用户统计信息。
display ip subscriber session statistics [ session-type { dhcp | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
session-type:用户上线类型。不指定该参数,则表示显示所有类型的IPv4 IPoE个人用户统计信息。
dhcp:表示DHCP用户。
static:表示静态个人用户。
unclassified-ip:表示未知源IP用户。
interface interface-type interface-number:显示指定接口上的IPv4 IPoE个人用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上已经上线和正在上线的IPv4 IPoE个人用户统计信息。
slot slot-number:显示指定单板上的IPv4 IPoE个人用户统计信息, slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板中在位单板上的IPv4 IPoE用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv4 IPoE个人用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE个人用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的IPv4 IPoE个人用户统计信息。
<Sysname> display ip subscriber session statistics session-type dhcp interface gigabitethernet 3/1/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-5 display ip subscriber session statistics命令显示信息描述表
成功分配到IP地址的用户数 |
display ip subscriber subnet-leased命令用来显示IPv4子网专线用户信息。
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ ip ip-address mask-length ] [ slot slot-number ]
IRF模式
interface interface-type interface-number:显示指定接口上的IPv4子网专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4子网专线用户信息。
ip ip-address:显示指定IPv4网段内的IPv4子网专线用户信息。
mask-length:IP地址子网络掩码长度,取值范围为1~31。
slot slot-number:显示指定单板的IPv4子网专线用户信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上在位单板的IPv4子网专线用户信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4子网专线用户信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4子网专线用户信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的IPv4子网专线用户信息。
<Sysname> display ip subscriber subnet-leased interface GigabitEthernet 3/1/1
Basic:
VPN instance : N/A
Username : a
Network : 200.1.1.0/24
User ID : 0x38080004
State : Online
Domain : radius
Login time : Sep 15 19:06:38 2014
AAA:
IP pool : N/A
QoS:
User profile : cc (active)
ITA:
Level-1 Inbound CAR : N/A
Outbound CAR : N/A
Level-2 Inbound CAR : CIR 1000bps PIR 10000bps (active)
Outbound CAR : CIR 1100bps PIR 11000bps (active)
Level-4 Inbound CAR : CIR 1200bps PIR 12000bps (active)
Level-5 Inbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
表1-6 display ip subscriber subnet-leased命令显示信息描述表
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
Username |
用户认证时使用的用户名 |
User ID |
State |
用户的认证状态 · Init:初始化 · Offline:正在下线中 · Auth:认证中 · AuthFail:认证失败 · AuthPass :认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态 |
Service node |
为用户提供认证服务的节点信息 |
Domain |
认证使用的ISP域名 |
Login time |
用户登录时间 |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
User profile |
Session group profile |
User group acl |
Inbound CAR |
Outbound CAR |
IPoE会话的流量统计信息 |
Uplink packets/bytes |
上行流量报文数/字节数 |
Downlink packets/bytes |
下行流量报文数/字节数 |
ITA |
IPoE会话的ITA信息 |
Outbound CAR |
Level-n uplink packets/bytes |
downlink packets/bytes |
display ip subscriber subnet-leased statistics命令用来显示已经上线和正在上线的IPv4 IPoE子网专线用户统计信息。
display ip subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv4 IPoE子网专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE用户已经上线和正在上线的子网专线统计信息。
slot slot-number:显示指定单板上的IPv4 IPoE子网专线用户统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板中在位单板上的IPv4 IPoE子网专线用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv4 IPoE子网专线用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE子网专线用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的IPv4 IPoE子网专线用户统计信息。
<Sysname> display ip subscriber subnet-leased statistics interface gigabitethernet 3/1/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-7 display ip subscriber subnet-leased statistics命令显示信息描述表
成功分配到IP地址的用户数 |
ip subscriber 8021p命令用于配置IPv4未知源IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
undo ip subscriber 8021p命令用来恢复缺省情况。
ip subscriber 8021p 8021p-list domain domain-name
undo ip subscriber 8021p 8021p-list
未指定IPv4未知源IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
三层以太网子接口视图/三层聚合子接口视图
8021p-list:802.1p值列表,表示一个或多个802.1p值,表示方式为8021p-list = { 8021p-value [ to 8021p-value ] }&<1-8>,其中,8021p-value为指定8021p的编号,取值范围为0~7。&<1-8>表示前面的参数最多可以输入8次。
domain domain-name:表示与指定的8021p范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
本命令用来配置指定802.1p值范围内的未知源IP接入用户认证时使用的认证域,通过指定的认证域对进行认证、授权、计费。
# 在子接口GigabitEthernet3/1/1.100上配置内层VLAN TAG中802.1p值范围为2到5的IPv4未知源IP接入用户认证使用的认证域为1pdm。
[Sysname] interface gigabitethernet 3/1/1.100
[Sysname-GigabitEthernet3/1/1.100] ip subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet3/1/1.100] ip subscriber 8021p 2 to 5 domain 1pdm
· ip subscriber service-identify
ip subscriber access-out命令用来配置BRAS设备准出认证功能。
undo ip subscriber access-out用来恢复缺省情况。
接口上的准出认证功能处于关闭状态。
三层以太网接口视图/三层以太网子接口视图/三层聚合口视图/三层聚合子接口视图
BRAS设备准入准出认证组网中,准出认证设备的接口配置了该命令,将对用户进行准出认证,认证通过后,则允许用户接入,否则不允许用户接入。
# 在接口GigabitEthernet3/1/1上配置用户准出认证功能。
[Sysname-GigabitEthernet3/1/1] ip subscriber access-out
ip subscriber dhcp domain命令用来配置IPv4 DHCP个人接入用户使用的认证域。
undo ip subscriber dhcp domain命令用来恢复缺省情况。
ip subscriber dhcp domain domain-name
IPv4 DHCP个人接入用户的认证域为缺省认证域。
三层以太网接口视图/三层以太网子接口视图/三层聚合接口视图/三层聚合子接口视图
domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
本命令用来配置DHCP报文触发接入的IPv4 IPoE接入用户在认证时使用的域名,该域名必须与认证服务器上配置的域名保持一致。
配置ip subscriber dhcp domain命令后:
· 如果DHCP报文中未携带Option 60,或者Option 60内容不符合域名的格式要求,则IPoE用户使用本命令指定的认证域进行认证;
· 如果DHCP报文中携带Option60,Option60符合域名的格式要求,并且接口配置了ip subscriber trust option60命令,则使用Option60作为指定的认证域进行认证。
如果不配置ip subscriber dhcp domain命令,且DHCP报文中未携带Option 60,则使用缺省认证域认证。
当用户需要将Option60字段中的信息按字符串形式解析时,请确保Option60字段内容中不出现00和不可见字符,否则在生成域名时将产生异常。
# 配置接口GigabitEthernet3/1/1上的IPv4 DHCP个人接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp domain ipoe
· ip subscriber initiator dhcp enable
ip subscriber dhcp max-session命令用来配置接口上允许DHCPv4报文触发创建的IPv4 IPoE会话的最大数。
undo ip subscriber dhcp max-session命令用来恢复缺省情况。
ip subscriber dhcp max-session max-number
未限制接口上允许DHCPv4报文触发创建的IPv4 IPoE会话数目。
max-number:允许DHCPv4报文触发创建的IPv4 IPoE会话最大数,取值范围1~32768。
DHCPv4报文触发创建的IPv4 IPoE会话数目达到最大值后,后续DHCPv4报文不能触发创建IPv4 IPoE会话。
# 配置接口GigabitEthernet3/1/1上允许DHCPv4报文触发创建的IPv4 IPoE会话最大数为100。
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp max-session 100
· display ip subscriber session
ip subscriber dhcp username命令用来配置IPv4 DHCP个人接入用户的认证用户名。
undo ip subscriber dhcp username命令用来恢复缺省情况。
ip subscriber dhcp username include { circuit-id | client-id | nas-port-id | port [ separator ] | remote-id | second-vlan [ separator ] | slot [ separator ] | source-mac [ separator separator ] | subslot [ separator ] | sysname [ separator ] | vendor-class | vendor-specific | vlan [ separator ] } *
IPv4 DHCP个人接入用户使用报文源MAC地址作为认证用户名。
circuit-id:表示以DHCP报文中的Interface Identifier Option(Option82 sub-option1)字段中的信息为用户名。
client-id:表示以DHCP报文中的Client Identifier Option(Option61)字段中的信息作为用户名。
nas-port-id:表示以用户认证报文中的nas-port-id属性作为用户名。
port:表示以报文接入的端口号作为用户名。
remote-id:表示以DHCP报文中的Remote Identifier Option(Option82 sub2)字段中的信息作为用户名。
second-vlan:表示以认证报文中的内层VLAN作为用户名。
slot:表示以报文接入的槽位号作为用户名。
source-mac:表示以用户报文的源MAC地址作为用户名。
separator separator:MAC地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如xxxx-xxxx-xxxx;若不指定该参数,则用户名为xxxxxxxxxxxx形式。
sublot:表示以报文接入的子卡号作为用户名。
sysname:表示以报文接入设备的设备名作为用户名。
vendor-class:表示以DHCP报文中的Vendor Class Option(Option60)字段中的信息作为用户名。
vendor-specific:表示以DHCP报文中的Vendor Specific Option(Option82 sub9)字段中的信息作为用户名。
vlan:表示以认证报文中的外层VLAN作为用户名。
separator:当前字段的分隔符,字符形式。
该命令用来配置IPv4 DHCP用户在认证时使用的用户名,该用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ip subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。
例如:若配置ip subscriber dhcp username include vendor-class vendor-specific,则用户名为Option60字段内容和Option82 sub9字段内容的拼接,且两个字段之间无分隔符。
当用户需要将Option字段中的信息按字符串形式解析时,请确保Option字段内容中不出现00和不可见字符,否则在生成用户名时将产生异常。
建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
# 配置接口GigabitEthernet3/1/1上IPv4 DHCP个人接入用户使用Client Identifier Option字段中的信息作为用户名。
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp username include client-id
ip subscriber dscp命令用来配置IPv4未知源IP报文的DSCP值与认证域的映射关系。
undo ip subscriber dscp命令用来恢复缺省情况。
ip subscriber dscp dscp-value-list domain domain-name
undo ip subscriber dscp dscp-value-list
未指定IPv4未知源IP报文的DSCP值与认证域的映射关系。
dscp-value-list:DSCP值列表,表示一个或多个DSCP的值,表示方式为dscp-value-list = dscp-value [ to dscp-value ] }&<1-8>。其中,dscp-value为指定的DSCP的值,取值范围为0~63。&<1-8>表示前面的参数最多可以输入8次。
domain domain-name:表示与指定的DSCP范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
本命令用来配置指定DSCP范围内的IPv4未知源IP报文触发的用户认证时使用的认证域,通过指定的认证域进行认证、授权、计费。
# 在接口GigabitEthernet3/1/1上配置DSCP值范围为1到4的IPv4未知源IP接入用户认证使用的认证域为dscpdm。
[Sysname-GigabitEthernet3/1/1] ip subscriber service-identify dscp
[Sysname-GigabitEthernet3/1/1] ip subscriber dscp 1 to 4 domain dscpdm
ip subscriber enable命令用来在接口上使能IPv4 IPoE功能并指定用户的接入模式。
undo ip subscriber enable命令用来恢复缺省情况。
ip subscriber { l2-connected | routed } enable
undo ip subscriber { l2-connected | routed } enable
接口上的IPv4 IPoE功能处于关闭状态。
l2-connected:指定二层接入模式。
routed:指定三层接入模式。
只有在接口上使能了IPv4 IPoE功能后,其它的IPv4 IPoE相关配置才能生效。
不允许直接修改IPoE的接入模式,必须关闭IPoE功能之后,重新使能IPoE功能时指定新的接入模式。
# 在接口GigabitEthernet3/1/1上使能二层接入模式的IPv4 IPoE功能。
[Sysname-GigabitEthernet3/1/1] ip subscriber l2-connected enable
ip subscriber initiator dhcp enable命令用来在接口上使能DHCPv4报文触发生成IPv4 IPoE会话的功能。
undo ip subscriber initiator dhcp enable 命令用来关闭接口上DHCPv4报文触发生成IPv4 IPoE会话的功能。
DHCPv4报文不能触发生成IPv4 IPoE会话。
接口上使能该功能后,收到的首个DHCP Discover报文或直接申请地址的DHCP Request报文会触发生成IPv4 IPoE会话;关闭该功能后,该接口上收到的DHCPv4报文不能触发生成IPv4 IPoE会话,已有的由DHCPv4报文触发生成的IPv4 IPoE会话不会被删除。
接口上可同时配置DHCPv4报文和未知源IPv4报文触发生成IPv4 IPoE会话的功能。
# 在接口GigabitEthernet3/1/1上使能DHCPv4报文触发生成IPv4 IPoE会话的功能。
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator dhcp enable
· ip subscriber initiator unclassified-ip enable
ip subscriber initiator unclassified-ip enable命令用来在接口上使能未知源IPv4报文触发生成IPv4 IPoE会话的功能。
undo ip subscriber initiator unclassified-ip enable命令用来关闭接口上的未知源IPv4报文触发生成IPv4 IPoE会话的功能。
未知源IPv4报文不能触发生成IPv4 IPoE会话。
接口使能该功能后,收到的未知源IPv4报文会触发生成IPv4 IPoE会话;关闭该功能后,该接口上收到的未知源IPv4报文不能触发生成IPv4 IPoE会话,已有的由未知源IPv4报文触发生成的IPv4 IPoE会话不会被删除。
# 在接口GigabitEthernet3/1/1上使能未知源IPv4报文触发生成IPv4 IPoE会话的功能。
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator unclassified-ip enable
ip subscriber interface-leased命令用来配置IPv4 IPoE接口专线用户。
undo ip subscriber interface-leased命令用来删除已配置的IPv4 IPoE接口专线用户。
未配置IPv4 IPoE接口专线用户。
username name:指定用户认证时使用的用户名,其中name为1~255个字符的字符串,区分大小写。
password:指定用户认证时使用的密码。
ciphertext:表示以密文方式配置用户认证使用的密码。
plaintext:表示以明文方式配置用户认证使用的密码。
password:设置的明文密码或密文密码,区分大小写。密文密码为1~117个字符的字符串;明文密码为1~63个字符的字符串。
domain domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。如果未指定该参数,将使用缺省认证域来认证用户。关于缺省认证域的相关配置请参见“安全配置指导”中的 “AAA”。
一个IPv4 IPoE接口专线用户代表了该接口接入的所有IPv4用户,接口上接入的所有IPv4用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有IPv4用户流量均允许通过,且共享一个IPv4 IPoE会话,并基于接口进行授权和计费。
每个接口只能配置一个IPv4 IPoE接口专线用户。
同一接口下,IPoE个人接入用户、IPoE接口专线用户和IPoE子网专线用户的配置互斥,只能选择其中的一种配置。
# 在接口GigabitEthernet3/1/1上配置一个IPv4 IPoE接口专线用户:认证使用的用户名为intuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet3/1/1] ip subscriber interface-leased username intuser password plaintext pw123
· display ip subscriber interface-leased
ip subscriber nas-port-id format命令用于为IPv4 IPoE接入用户配置nas-port-id属性的封装格式,即IPv4 IPoE接入用户进行认证时,接入设备向RADIUS服务器发送的nas-port-id属性的封装格式。
undo ip subscriber nas-port-id命令用来恢复缺省情况。
ip subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
undo ip subscriber nas-port-id format
按version 1.0的格式填充RADIUS的nas-port-id属性。
version1.0:封装格式为version 1.0,表示发送给RADIUS服务器的nas-port-id属性以电信163大后台要求的格式填充。
version2.0:封装格式为version 2.0,表示发送给RADIUS服务器的nas-port-id属性以YDT 2275-2011宽带接入用户线路(端口)标识要求的格式填充。
(1) version 1.0封装格式:
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=0;
· 三层以太网子接口和三层聚合子接口(携带单层VLAN Tag接入)
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=vlan_id;
· 三层以太网子接口和三层聚合子接口(携带双层VLAN Tag接入)
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=inner-vlan;vlanid2=outer-vlan;
(2) version 2.0封装格式:
其中,{eth|trunk|atm}表示BRAS接入接口的类型,包括以太接口、trunk类型的以太网接口或ATM接口;NAS_slot表示BRAS接入接口的槽位号;NAS_subslot表示BRAS接入接口的子槽位号;NAS_port表示BRAS接入接口的端口号;svlan表示接入用户的SVLAN ID;cvlan表示接入用户的CVLAN ID;AccessNodeIdentifier表示接入节点的标识;ANI_rack表示接入节点机架号;ANI_frame表示接入节点机框号;ANI_slot表示接入节点槽位号;ANI_subslot表示接入节点子槽位号;ANI_port表示接入节点端口号。
# 在接口GigabitEthernet3/1/1上配置设备使用version 2.0格式封装RADIUS的nas-port-id属性。
[Sysname-GigabitEthernet3/1/1] ip subscriber nas-port-id format cn-telecom version2.0
l ip subscriber initiator dhcp enable
l ip subscriber nas-port-id nasinfo-insert
ip subscriber nas-port-id nasinfo-insert命令用于配置在提取出的DHCPv4报文的Option 82 Circuit-ID子选项内容中插入NAS信息,并使用插入NAS信息后的内容作为nas-port-id属性。
undo ip subscriber nas-port-id nasinfo-insert命令用来恢复缺省情况。
不使用Option 82 Circuit-ID子选项中的内容作为nas-port-id属性字符串。
在DHCP中继组网环境下,接入设备能捕获用户的DHCPv4报文,并从报文中提取出DHCP Option82 Circuit-ID子选项信息。在配置了本命令且信任DHCP Option 82的情况下,接入设备处理如下:
· 如果收到的DHCP报文带有DHCP Option82 Circuit-ID子选项,则从收到的DHCP报文中解析DHCP Option82 Circuit-ID子选项,并按YDT 2275-2011宽带接入用户线路(端口)标识要求在原有Circuit-ID子选项的内容里插入NAS信息(该信息标识了用户在本设备上的接入位置信息),然后将其作为RADIUS的nas-port-id属性内容。
· 如果收到的DHCP报文不带Option82 Circuit-ID子选项,则按version 2.0格式要求封装,保留该子选项中的原有的NAS信息字段(NAS_slot/NAS_subslot/NAS_port:svlan.cvlan),并将AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port部分修改为0/0/0/0/0/0。
本功能对原DHCP报文中Option82子选项不产生任何影响,且只在nas-port-id的封装格式为version 2.0时生效。
# 在接口GigabitEthernet3/1/1上配置设备使用DHCPv4客户端上报的Option82信息,并在其中插入NAS信息,然后将其封装为RADIUS的nas-port-id属性。
[Sysname-GigabitEthernet3/1/1] ip subscriber nas-port-id nasinfo-insert
· ip subscriber nas-port-id format
ip subscriber nas-port-type命令用来配置接口的IPv4 IPoE接入端口类型。
undo ip subscriber nas-port-type命令用来恢复缺省情况。
IPv4 IPoE接入端口类型为Ethernet类型。
802.11:符合Wireless-IEEE 802.11标准的接口类型,对应的编码值为19。
adsl-cap:ADSL-CAP(Asymmetric DSL,Carrierless Amplitude Phase Modulation)接口类型,对应的编码值为12。
adsl-dmt:ADSL-DMT(Asymmetric DSL,Discrete Multi-Tone)接口类型,对应的编码值为13。
async:Async接口类型,对应的编码值为0。
cable:Cable接口类型,对应的编码值为17。
ethernet:Ethernet接口类型,对应的编码值为15。
g.3-fax:G.3 Fax接口类型,对应的编码值为10。
hdlc:HDLC接口类型,对应的编码值为7。
idsl:IDSL(ISDN Digital Subscriber Line)接口类型,对应的编码值为14。
isdn-async-v110:ISDN Async V.110接口类型,对应的编码值为4。
isdn-async-v120:ISDN Async V.120接口类型,对应的编码值为3。
isdn-sync:ISDN Sync口类型,对应的编码值为2。
piafs:符合PIAFS(PHS(Personal Handyphone System)Internet Access Forum Standard)标准的接口类型,对应的编码值为6。
sdsl:SDSL(Symmetric DSL)接口类型,对应的编码值为11。
sync:Sync接口类型,对应的编码值为1。
virtual:Virtual接口类型,对应的编码值为5。
wireless-other:Wireless-other接口类型,对应的编码值为18。
x.25:X.25接口类型,对应的编码值为8。
x.75:X.75接口类型,对应的编码值为9。
xdsl:XDSL(Digital Subscriber Line of unknown type)接口类型,对应的编码值为16。
此处配置的端口接入类型值将作为向RADIUS服务器发送的RADIUS请求报文的NAS-Port-Type属性值,用于向RADIUS服务器正确传递用户的接入端口信息。
# 配置接口GigabitEthernet3/1/1的IPv4 IPoE接入端口类型为SDSL。
[Sysname-GigabitEthernet3/1/1] ip subscriber nas-port-type sdsl
ip subscriber password命令用来配置动态IPv4 IPoE个人接入用户的认证密码。
undo ip subscriber password命令用来恢复缺省情况。
ip subscriber password { ciphertext | plaintext } password
动态IPv4 IPoE个人接入用户的认证密码为字符串vlan。
ciphertext:表示以密文方式配置用户的认证密码。
plaintext:表示以明文方式配置用户的认证密码。
本命令用来配置动态IPv4 IPoE个人接入用户认证时使用的密码,动态IPv4 IPoE个人接入用户是指通过DHCP报文或未知源IPv4报文触发建立IPoE会话并进行认证的IPoE个人接入用户。
# 配置接口GigabitEthernet3/1/1上动态IPoE个人接入用户认证时使用的密码为明文123。
[Sysname-GigabitEthernet3/1/1] ip subscriber password plaintext 123
· ip subscriber unclassified-ip username
ip subscriber service-identify命令用来配置IPv4未知源IP接入用户的业务识别方式。
undo ip subscriber service-identify命令用来恢复缺省情况。
三层以太网接口视图/三层聚合口视图
ip subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
未指定IPv4未知源IP接入用户的业务识别方式。
8021p second-vlan:表示QinQ模式下基于内层VLAN Tag中的802.1p值识别业务。
8021p vlan:表示基于VLAN Tag中的802.1p值识别业务,QinQ模式下基于外层VLAN Tag中的802.1p值识别业务。
dscp:表示基于DSCP值识别业务。
second-vlan:QinQ模式下基于内层VLAN ID识别业务。
vlan:表示基于VLAN ID识别业务,QinQ模式下基于外层VLAN ID识别业务。
未知源IP用户认证时使用的认证域由报文中携带的业务信息来决定。不同的业务特征可以对应不同的认证域,每一个接口可以指定仅识别某种类型业务的报文。例如,接口上若指定了基于DSCP值识别业务,且通过ip subscriber dscp 1 domain aabcc命令指定了DSCP值1与认证域aabbcc的映射关系,则IP报文DSCP值为1的用户认证时将会使用认证域aabbcc。
· 本命令中的8021p second-vlan、8021p vlan、vlan和second-vlan参数仅子接口支持,非子接口不支持。
# 配置接口GigabitEthernet3/1/1上的IPv4未知源IP接入用户认证使用基于DSCP的业务识别方式。
ip subscriber session static命令用来配置静态IPv4 IPoE会话。
undo ip subscriber session static命令用来删除指定的静态IPv4 IPoE会话。
undo ip subscriber session static ip ip-address [ vlan vlan-id [ second-vlan vlan-id ] ]
ip ip-address:表示用户的IPv4地址。
vlan vlan-id:表示用户报文的外层VLAN。其中vlan-id表示VLAN ID,取值范围为1~4093。
second-vlan vlan-id:表示用户报文的内层VLAN。其中vlan-id表示VLAN ID,取值范围为1~4093。
mac mac-address:表示用户的MAC地址,形式为H-H-H。
domain domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。如果未指定该参数,将使用缺省认证域来认证用户。关于缺省认证域的相关配置请参见“安全配置指导”中的“AAA”。
管理员手工输入静态IPoE会话所需的信息(用户IP地址、MAC地址、用户报文的内/外层VLAN)后,接入设备根据这些信息生成对应的静态IPoE会话。接口上有与静态IPoE会话相匹配的IP报文通过时,将触发认证过程。
· 本命令的vlan和second-vlan参数仅子接口支持,非子接口不支持。
· 静态IPoE会话的匹配优先级高于动态IPoE会话。若已经存在静态IPoE会话,则与之匹配IP报文不会触发新的动态IPoE会话;若存在一个未知源IP报文触发建立的动态IPoE会话,则再配置一个能与该未知源IP报文匹配的静态IPoE会话,会覆盖已经存在的动态IPoE会话。
· 系统支持配置多个静态IPoE会话。
· 相同IP、外层VLAN、内层VLAN的静态IPoE会话只能存在一条,后配置的不能覆盖已配置的。若要修改相关参数,必须删除当前配置后重新配置。
· 同一接口下,静态IPoE会话、接口专线用户和子网专线用户的配置互斥,只能选择其中的一种配置。
# 在接口GigabitEthernet3/1/1上配置一条静态IPv4 IPoE会话:用户IP地址为1.1.1.1,认证使用的认证域为dm1。
[Sysname-GigabitEthernet3/1/1] ip subscriber session static ip 1.1.1.1 domain dm1
ip subscriber subnet-leased命令用来配置IPv4 IPoE子网专线用户。
undo ip subscriber subnet-leased命令用来删除指定的IPv4 IPoE子网专线用户。
undo ip subscriber subnet-leased ip ip-address { mask | mask-length }
未配置IPv4 IPoE子网专线用户。
mask:IP地址的网络掩码,为点分十进制形式。
mask-length:IP地址的网络掩码长度,取值范围为1~31。
一个IPv4 IPoE子网专线用户代表了该接口接入的所有该子网内IPv4用户,该子网内的所有IPv4用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有该子网内IPv4用户流量均允许通过,且共享一个IPv4 IPoE会话,并基于子网进行授权和计费。
每个子网只能配置一个IPv4 IPoE子网专线用户。
· 同一接口下,IPoE个人接入用户、IPoE接口专线用户和IPoE子网专线用户的配置互斥,只能选择其中的一种配置。
· VRRP组网环境下配置IPoE子网专线时,请不要将IPoE子网与VRRP备份组虚拟IP地址配置在同一网段,否则将导致VRRP备份组无法正常工作。VRRP相关的配置请参见“可靠性配置指导”中的“VRRP”。
# 在接口GigabitEthernet3/1/1上配置一个IPv4 IPoE子网专线用户:子网网段为1.1.1.1/24,认证使用的用户名为netuser,认证使用的明文密码为pw123。
[Sysname-GigabitEthernet3/1/1] ip subscriber subnet-leased ip 1.1.1.1 24 username netuser password plaintext pw123
· display ip subscriber subnet-leased
ip subscriber timer quiet命令用来配置IPv4 IPoE用户的静默时间。
undo ip subscriber timer quiet命令用来恢复缺省情况。
ip subscriber timer quiet time
IPv4 IPoE用户的静默时间功能处于关闭状态。
time:IPoE用户的静默时间,取值范围为10~3600,单位为秒。
# 在接口GigabitEthernet3/1/1上配置IPv4 IPoE用户的静默时间为100秒。
[Sysname-GigabitEthernet3/1/1] ip subscriber timer quiet 100
ip subscriber trust命令用于配置信任DHCPv4报文中指定Option。
undo ip subscriber trust命令用来恢复缺省情况。
ip subscriber trust { option60 | option82 }
undo ip subscriber trust { option60 | option82 }
不信任DHCPv4报文中的任何Option。
option60:表示信任DHCPv4报文中的Option60。
option82:表示信任DHCPv4报文中的Option82。
DHCP组网环境中,如果接入设备信任DHCPv4报文中的Option 60,则:
· 如果Option60内容有效,但没有@字符,以整个Option60的内容作为域名;
· 如果Option60内容中包含了域名分隔符@字符,且@字符后的字符串有效(无非法字符'\','/',':','*','?','\"','<','>','|'等),则以@字符之后的字符串作为域名;
如果不信任DHCPv4报文中的Option 60,则:
· 如果配置了ip subscriber dhcp domain domain-name,则以该命令配置的域名接入;
· 如果接口没有配置缺省DHCPv4接入的domain,则不设置AAA的domain属性,按系统缺省域接入。
DHCP中继组网环境中,接入设备可以提取用户的DHCP-DISCOVER报文中的Option 82信息。如果接入设备信任DHCPv4报文中的Option 82,则:
· 接入设备在采用version 2.0格式封装RADIUS nas-port-id属性时,会根据Option 82信息中的Circuit-ID子选项内容封装发往RADIUS服务器的nas-port-id属性;
· 接入设备会根据Option 82中的Circuit-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_CIRCUIT_ID属性;
· 接入设备会根据Option 82中的Remote-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_REMOTE_ID属性。
如果不信任DHCPv4报文中的Option 82,则接入设备在封装以上RADIUS属性时,不采用Option 82中的任何信息。
# 在接口GigabitEthernet3/1/1上配置设备信任DHCPv4报文中的Option 82。
[Sysname-GigabitEthernet3/1/1] ip subscriber trust option82
ip subscriber unclassified-ip domain命令用来配置IPv4未知源IP接入用户使用的认证域。
undo ip subscriber unclassified-ip domain命令用来恢复缺省情况。
ip subscriber unclassified-ip domain domain-name
IPv4未知源IP接入用户的认证域为缺省认证域。
domain-name:认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
该命令用来配置未知源IP报文触发接入的IPv4 IPoE接入用户在认证时使用的认证域,该域名必须与认证服务器上配置的域名保持一致。
如果指定接口上配置了ip subscriber service-identify,则优先使用ip subscriber service-identify指定的业务识别方式获取对应的认证域。只有在未匹配到ip subscriber service-identify命令指定的认证域时,才使用ip subscriber unclassified-ip domain命令指定的认证域。如果ip subscriber unclassified-ip domain命令也未配置,则使用缺省认证域。
# 配置接口GigabitEthernet3/1/1上的IPv4未知源IP接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip domain ipoe
ip subscriber unclassified-ip max-session命令用来配置接口上允许未知源IPv4报文触发创建的动态IPv4 IPoE会话的最大数。
undo ip subscriber unclassified-ip max-session命令用来恢复缺省情况。
ip subscriber unclassified-ip max-session max-number
未限制接口上允许未知源IPv4报文创建的动态IPv4 IPoE会话数目。
max-number:允许未知源IPv4报文触发创建的IPv4 IPoE会话最大数,取值范围为1~32768。
未知源IPv4报文触发创建的IPv4 IPoE会话数目达到最大值后,后续未知源IPv4报文不能触发创建IPv4 IPoE会话。
# 配置接口GigabitEthernet3/1/1上允许未知源IPv4报文触发创建的IPv4 IPoE会话最大数为100。
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip max-session 100
ip subscriber unclassified-ip username命令用来配置IPv4未知源IP接入用户的认证用户名。
undo ip subscriber unclassified-ip username命令用来恢复缺省情况。
IPv4未知源IP接入用户采用用户报文的源IPv4地址作为认证用户名。
nas-port-id:表示使用用户的nas-port-id属性作为用户名。
source-ip:表示使用用户报文的源IPv4地址作为用户名。
separator separator:IPv4地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如192-168-1-1;若不指定该参数,则用户名为x.x.x.x形式。
source-mac:表示使用用户报文的源MAC地址作为用户名。
separator separator-char:MAC地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如xxxx-xxxx-xxxx;若不指定该参数,则用户名为xxxxxxxxxxxx形式。
本命令用来配置未知源IP报文触发接入的IPv4 IPoE用户在认证时使用的用户名,该用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ip subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ip subscriber unclassified-ip username include source-ip source-mac,则用户名为源IPv4地址字段和源MAC地址字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet3/1/1上的未知源IPv4用户使用用户报文的源IPv4地址作为用户名。
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip username include source-ip
ip subscriber user-detect命令用来开启静态/动态IPv4 IPoE个人接入用户在线探测功能,并配置其探测方式。
undo ip subscriber user-detect命令用来关闭静态/动态IPv4 IPoE个人接入用户在线探测功能。
ip subscriber user-detect { arp | icmp } retry times interval interval
静态/动态IPv4 IPoE个人接入用户在线探测功能处于关闭状态。
arp:表示使用ARP请求报文作为探测报文。
icmp:表示使用ICMP请求报文作为探测报文。
retry times:探测失败后允许重复尝试的最大次数,取值范围为2~5。例如,times值为2表示连续三次失败就认为用户不在线。
interval interval:探测的时间间隔,取值范围为30~1200,单位为秒。
接口上的静态/动态IPoE个人接入用户上线后,设备会定时统计用户流量。若一个探测间隔(interval)内用户流量无变化,则该探测间隔结束后,设备将发送一次探测报文。如果设备在探测间隔内未收到用户的报文,则认为一次探测失败。
若设备首次探测失败,将继续做指定次数(times)的重复探测,若全部探测尝试都失败(即一直未收到该用户报文),则认为此用户不在线,停止发送探测报文并删除用户;若设备在探测中收到用户的报文,则认为用户在线,重置探测定时器并开始下一次探测。
对于与接口在同一网段内的静态/动态IPv4 IPoE个人接入用户,可使用ARP请求或ICMP请求报文对用户进行探测;对于与接口不在同一网段内的静态/动态IPv4 IPoE个人接入用户,应使用ICMP请求报文对用户进行探测。
接口上不可同时启用两种方式对静态/动态IPv4 IPoE个人接入用户进行探测。
# 开启接口GigabitEthernet3/1/1上使用ARP请求报文对静态/动态IPv4 IPoE个人接入用户进行在线探测,探测失败后允许重复尝试5次,探测的时间间隔为100秒。
[Sysname-GigabitEthernet3/1/1] ip subscriber user-detect arp retry 5 interval 100
ip subscriber vlan命令用于配置IPv4未知源IP报文的内/外层VLAN值与认证域的映射关系。
undo ip subscriber vlan命令用来恢复缺省情况。
ip subscriber vlan vlan-list domain domain-name
undo ip subscriber vlan vlan-list
未指定IPv4未知源IP报文的内/外层VLAN与认证域的映射关系。
vlan-list:VLAN列表,表示一个或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4093。&<1-10>表示前面的参数最多可以输入10次。
domain domain-name:表示与指定的VLAN范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
本命令用来配置指定VLAN范围内未知源IP接入用户进行认证时使用的认证域,通过指定的认证域进行认证、授权、计费。
# 在子接口GigabitEthernet3/1/1.100上配置内层VLAN ID范围为2到100的IPv4未知源IP接入用户认证使用的认证域为vlandm。
[Sysname-GigabitEthernet3/1/1.100] ip subscriber service-identify second-vlan
[Sysname-GigabitEthernet3/1/1.100] ip subscriber vlan 2 to 100 domain vlandm
reset ip subscriber offline statistics命令用来清除IPv4 IPoE用户下线统计信息。
reset ip subscriber offline statistics [ interface interface-type interface-number ]
interface interface-type interface-number:表示清除指定接口上的IPv4 IPoE用户下线统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的IPv4 IPoE用户下线统计信息。
# 清除接口GigabitEthernet3/1/1上的IPv4 IPoE用户下线统计信息。
<Sysname> reset ip subscriber offline statistics interface gigabitethernet 3/1/1
· display ip subscriber offline statistics
reset ip subscriber session命令用来清除动态触发创建的IPv4 IPoE会话,强制用户下线。
interface interface-type interface-number:表示清除指定接口动态触发创建的IPv4 IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口动态触发创建的IPv4 IPoE会话。
domain domain-name:表示清除使用指定ISP域认证的IPv4 IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
ip ip-address:表示清除指定IP地址的IPv4 IPoE会话,ip-address为指定的IPv4地址。
vpn-instance vpn-instance-name:表示清除指定VPN的IPv4 IPoE会话,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv4 IPoE会话位于公网中。
mac mac-address:表示清除指定源MAC地址的IPv4 IPoE会话,形式为H-H-H。
username name:表示清除指定用户名的IPv4 IPoE会话,name为1~255个字符的字符串,区分大小写。
本命令用来清除动态触发创建的IPv4 IPoE会话信息,并强制用户下线,如果不指定条件,则表示删除所有动态IPv4 IPoE会话。
接口专线用户和静态个人用户不能通过reset ip subscriber session命令强制下线,只能通过相应的undo命令删除配置。
# 清除接口GigabitEthernet3/1/1上动态触发创建的IPv4 IPoE会话,强制用户下线。
<Sysname> reset ip subscriber session interface gigabitethernet 3/1/1
display ipv6 subscriber interface-leased命令用来显示IPv6接口专线用户信息。
display ipv6 subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式
interface interface-type interface-number:显示指定接口上的IPv6接口专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6接口专线用户信息。
slot slot-number:显示指定单板的IPv6接口专线用户信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的IPv6接口专线用户信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6接口专线用户信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv6接口专线用户信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的IPv6接口专线用户信息。
<Sysname> display ipv6 subscriber interface-leased interface GigabitEthernet 3/1/1
Basic:
VPN instance : N/A
Username : a
User ID : 0x48080003
State : Online
Domain : radius
Login time : Sep 15 21:17:07 2014
IP pool : ipoe
QoS:
User profile : h3c6 (active)
ITA:
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
表1-8 display ipv6 subscriber interface-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
Username |
用户认证时使用的用户名 |
User ID |
State |
Service node |
为用户提供认证服务的节点信息 |
Domain |
认证使用的ISP域名 |
Login time |
用户登录时间 |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool name |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
User profile |
User group acl |
Inbound CAR |
Outbound CAR |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
IPoE会话的ITA信息 |
Outbound CAR |
display ipv6 subscriber interface-leased statistics 命令用来显示已经上线和正在上线的IPv6 IPoE接口专线用户统计信息。
display ipv6 subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv6 IPoE接口专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE接口专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定单板上的IPv6 IPoE接口专线用户统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板中在位单板上的IPv6 IPoE接口专线用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv6 IPoE接口专线用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE接口专线用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的IPv6 IPoE接口专线用户统计信息。
<Sysname> display ipv6 subscriber interface-leased statistics interface gigabitethernet 3/1/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-9 display ipv6 subscriber interface-leased statistics命令显示信息描述表
成功分配到IP地址的用户数 |
display ipv6 subscriber offline statistics 命令用来显示IPv6 IPoE用户下线原因的统计信息。
display ipv6 subscriber offline statistics [ interface interface-type interface-number ]
# 显示接口GigabitEthernet3/1/1上IPv6 IPoE用户下线原因的统计信息
<Sysname> displsy ipv6 subscriber offline statistics interface gigabitethernet3/1/1
User request : 0
Command cut : 80
AAA terminate : 0
Idle timeout : 10
Detect fail : 10
DHCP request timeout: 0
Interface down : 0
VSRP event : 0
DHCP notify : 0
Other : 0
表1-10 display ipv6 subscriber offline statistics命令显示信息描述表
DHCP租约到期正常下线的用户数 |
AAA租约到期正常下线的用户数 |
AAA强制下线的用户数 |
DHCP请求超时下线的用户数 |
因接口状态为down下线的用户数 |
DHCP通知下线的用户数 |
· reset ipv6 subscriber offline statistics
display ipv6 subscriber session命令用来显示静态配置和动态触发的IPv6个人IPoE会话信息。
display ipv6 subscriber session [ interface interface-type interface-number ] [ domain domain-name | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
IRF模式
interface interface-type interface-number:显示指定接口上的IPv6个人IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6个人IPoE会话。
domain domain-name:显示使用指定ISP域认证的IPv6个人IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括”/”、”\”、”|”、”““、”:”、”*”、”?”、”<“、”>“以及”@”等字符。
ipv6 ipv6-address:显示指定源IP地址的IPv6个人IPoE会话,ipv6-address为指定的IPv6地址。
vpn-instance vpn-instance-name:指定用户所属的VPN,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv6个人IPoE会话位于公网中。
mac mac-address:显示指定源MAC地址的IPv6个人IPoE会话,形式为H-H-H。
static:显示静态配置的IPv6个人IPoE会话,不指定该参数时将显示动态触发创建的IPv6个人IPoE会话。
username name:显示指定用户名的IPv6个人IPoE会话,其中,name为1~255个字符的字符串,区分大小写。
slot slot-number:显示指定单板的静态配置和动态触发的IPv6个人IPoE会话,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的IPv6个人IPoE会话。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的IPv6个人IPoE会话,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv6个人IPoE会话。(IRF模式)
verbose:显示IPv6个人IPoE会话的详细信息。如果不指定该参数,则只显示IPoE会话的简要信息。
# 显示用户IP为2000::1,所属VPN为vpn1的IPv6 IPoE会话简要信息。
<Sysname> display ipv6 subscriber session ipv6 2000::1 vpn-instance vpn1
GE3/1/1 2000::1 0010-9400-0002 U Online
# 显示所有静态配置和动态触发的IPv6个人IPoE会话的详细信息。
<Sysname> display ipv6 subscriber session verbose
Basic:
Username : 2000::1
Domain : radius
VPN instance : vpn1
IP address : 2000::1
VLAN : N/A
Secondary VLAN : N/A
User ID : 0x48080002
DHCP lease : N/A
Login time : Sep 15 19:20:13 2017
State : Online
AAA:
IP pool : N/A
QoS:
ITA:
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
图1-1 display ipv6 subscriber session命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Username |
用户认证时使用的用户名 |
Domain |
用户认证时使用的ISP域名 |
VPN instance |
IP Address |
用户的IP地址 |
MAC Address |
用户的MAC地址 |
Service-VLAN/Customer-VLAN |
Access interface |
用户接入的接口名称 |
User ID |
VPI/VCI(for ATM) |
ATM的PVC信息 |
DHCP lease |
DHCP remain lease |
DHCP服务器分配给用户的IP地址租约剩余时长 只在Service node上可以查看到有效的剩余时长,非Service node上该字段显示为N/A |
Login time |
用户登录时间 |
用户本次上线的在线时长 |
Service node |
为用户提供认证服务的节点信息 |
Type |
IPoE会话的创建类型 · DHCP:DHCP报文触发创建 · Unclassified-ip:未知源IP报文触发创建 · Static:静态配置 · NDRS:ND RS报文触发创建 |
State |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
User profile |
User group acl |
Inbound CAR |
Outbound CAR |
Total traffic statistics: |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
IPoE会话的ITA信息 |
Outbound CAR |
display ipv6 subscriber session statistics 命令用来显示已经上线和正在上线的IPv6 IPoE个人用户统计信息。
display ipv6 subscriber session statistics [ session-type { dhcp | ndrs | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
session-type:用户上线类型。不指定该参数,则表示显示所有类型的IPv6 IPoE个人用户统计信息。
dhcp:表示DHCP用户。
ndrs:表示RS报文触发认证的用户。
static:表示静态个人用户。
interface interface-type interface-number:显示指定接口上的IPv6 IPoE个人用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE个人用户已经上线和正在上线的统计信息。
slot slot-number:显示指定单板上的IPv6 IPoE个人用户统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的IPv6 IPoE个人用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv6 IPoE用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE个人用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的静态和动态IPv6 IPoE个人用户统计信息。
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-11 display ipv6 subscriber session statistics命令显示信息描述表
成功分配到IP地址的用户数 |
· reset ipv6 subscriber session
display ipv6 subscriber subnet-leased命令用来显示IPv6子网专线用户信息。
display ipv6 subscriber subnet-leased [ interface interface-type interface-number ] [ ipv6 ipv6-address prefix-length ] [ slot slot-number ]
IRF模式
interface interface-type interface-number:显示指定接口上的IPv6子网专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6子网专线用户信息。
ipv6 ipv6-address:显示指定IPv6网段内的IPv6子网专线用户信息。
prefix-length:IPv6子网前缀长度,取值范围为1~127。
slot slot-number:显示指定单板的IPv6子网专线用户信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上在位单板的IPv6子网专线用户信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6子网专线用户信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上在位单板的IPv6子网专线用户信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的IPv6子网专线用户信息。
<Sysname> display ipv6 subscriber subnet-leased interface GigabitEthernet 3/1/1
Basic:
VPN instance : N/A
Username : a
Network : 2000::/64
User ID : 0x48080004
State : Online
Domain : radius
Login time : Sep 15 21:23:07 2014
AAA:
IP pool : ipoe
QoS:
ITA:
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
Outbound CAR : N/A
表1-12 display ipv6 subscriber subnet-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
Username |
用户认证时使用的用户名 |
User ID |
State |
Service node |
为用户提供认证服务的节点信息 |
Domain |
认证使用的ISP域名 |
Login time |
用户登录时间 |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
User profile |
User group acl |
Inbound CAR |
Outbound CAR |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
IPoE会话的ITA信息 |
Outbound CAR |
· ipv6 subscriber enable
display ipv6 subscriber subnet-leased statistics命令用来显示已经上线和正在上线的IPv6 IPoE子网专线用户统计信息。
display ipv6 subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
IRF模式:
interface interface-type interface-number:显示指定接口上的IPv6 IPoE子网专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE子网专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定单板上的IPv6 IPoE子网专线用户统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板中在位单板上的IPv6 IPoE子网专线用户统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的IPv6 IPoE子网专线用户统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE子网专线用户统计信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上已经上线和正在上线的IPv6 IPoE子网专线用户统计信息。
<Sysname> display ipv6 subscriber subnet-leased statistics interface gigabitethernet 3/1/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-13 display ipv6 subscriber subnet-leased statistics命令显示信息描述表
成功分配到IP地址的用户数 |
ipv6 subscriber 8021p命令用于配置IPv6未知源IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
undo ipv6 subscriber 8021p命令用来恢复缺省情况。
ipv6 subscriber 8021p 8021p-list domain domain-name
undo ipv6 subscriber 8021p 8021p-list
未指定IPv6未知源IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
8021p-list: 802.1p值列表,表示一个或多个802.1p值,表示方式为8021p-list = { 8021p-value [ to 8021p-value ] }&<1-8>,其中,8021p-value为指定8021p的编号,取值范围为0~7。&<1-8>表示前面的参数最多可以输入8次。
本命令用来配置指定802.1p值范围内的IPv6未知源IP接入用户认证时使用的认证域,通过指定的认证域进行认证授权。
# 在子接口Gigabitethernet 3/1/1.100上配置内层VLAN TAG中802.1p值范围为2到5的IPv6未知源IP接入用户认证使用的认证域为1pdm。
[Sysname-GigabitEthernet3/1/1.100] ipv6 subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet3/1/1.100] ipv6 subscriber 8021p 2 to 5 domain 1pdm
· ipv6 subscriber service-identify
ipv6 subscriber access-out命令用来配置BRAS设备准出认证功能。
undo ipv6 subscriber access-out用来恢复缺省情况。
接口上的准出认证功能处于关闭状态。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber access-out
ipv6 subscriber dhcp domain命令用来配置IPv6 DHCP个人接入用户使用的认证域。
undo ipv6 subscriber dhcp domain命令用来恢复缺省情况。
ipv6 subscriber dhcp domain domain-name
IPv6 DHCP个人接入用户的认证域为缺省认证域。
本命令用来配置DHCPv6报文触发接入的IPv6 IPoE接入用户在认证时使用的域名,该域名必须与认证服务器上配置的域名保持一致。
配置ipv6 subscriber dhcp domain命令:
· 如果用户报文中未携带Option 16,或者Option 16内容不符合域名的格式要求,则IPoE接入用户使用本命令指定的缺省域名进行认证;
· 如果DHCPv6报文中携带Option16,Option16符合域名的格式要求,并且接口配置了ip subscriber trust option16命令,则使用Option16作为指定的认证域进行认证。
如果不配置ipv6 subscriber dhcp domain命令,且DHCPv6报文中未携带Option 16,则使用缺省认证域认证。
当用户需要将Option16字段中的信息按字符串形式解析时,请确保Option16字段内容中不出现00和不可见字符,否则在生成域名时将产生异常。
# 配置接口GigabitEthernet3/1/1上IPv6 DHCP个人接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber dhcp domain ipoe
· ipv6 subscriber initiator dhcp enable
· ipv6 subscriber dhcp username
ipv6 subscriber dhcp max-session命令用来配置接口上允许DHCPv6报文触发创建的IPv6 IPoE会话的最大数。
undo ipv6 subscriber dhcp max-session命令用来恢复缺省情况。
ipv6 subscriber dhcp max-session max-number
未限制接口上允许DHCPv6报文触发创建的IPv6 IPoE会话数目。
max-number :允许DHCPv6触发创建的IPv6 IPoE会话最大数,取值范围为1~32768。
DHCPv6报文触发创建的IPv6 IPoE会话数目达到最大值后,后续DHCPv6报文不能触发创建IPv6 IPoE会话,未知源IPv6报文等触发创建IPv6 IPoE会话不会受此最大值限制。
# 配置接口GigabitEthernet3/1/1上允许DHCPv6报文触发创建的IPv6 IPoE会话最大数为100。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber dhcp max-session 100
· display ipv6 subscriber session
ipv6 subscriber dhcp username命令用于配置IPv6 DHCP个人接入用户的认证用户名。
undo ipv6 subscriber dhcp username命令用来恢复缺省情况。
IPv6 DHCP个人接入用户使用报文源MAC地址作为认证用户名。
circuit-id:表示以IPv6 DHCP报文中的Interface Identifier Option(Option18)字段中的信息为用户名。
client-id:表示以IPv6 DHCP报文中的Client Identifier Option(Option1)字段中的信息作为用户名。
remote-id:表示以IPv6 DHCP报文中的Remote Identifier Option(Option37)字段中的信息作为用户名。
vendor-class:表示以IPv6 DHCP报文中的Vendor Class Option(Option16)字段中的信息作为用户名。
vendor-specific:表示以IPv6 DHCP报文中的Vendor Specific Option(Option17)字段中的信息作为用户名。
该命令用来配置IPv6 DHCP接入用户在认证时使用的用户名,该用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ipv6 subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ipv6 subscriber dhcp username include vendor-class vendor-specific,则用户名为Option16字段内容和Option17字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet3/1/1上IPv6 DHCP个人接入用户使用Client Identifier Option字段中的信息作为用户名。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber dhcp username include client-id
ipv6 subscriber dscp命令用来配置IPv6未知源IP报文的DSCP值与用户认证域的映射关系。
undo ipv6 subscriber dscp命令用来恢复缺省情况。
ipv6 subscriber dscp dscp-value-list domain domain-name
undo ipv6 subscriber dscp dscp-value-list
未指定IPv6未知源IP报文的DSCP值与认证域的映射关系。
dscp-value-list:DSCP值列表,表示一个或多个DSCP的值,表示方式为dscp-value-list ={ dscp-value [ to dscp-value ] }&<1-8>。其中,dscp-value为指定的DSCP的值,取值范围为0~63。&<1-8>表示前面的参数最多可以输入8次。
本命令用来配置指定DSCP范围内的IPv6未知源IP报文触发的用户认证时使用的认证域,通过指定的认证域进行认证授权。
# 在接口GigabitEthernet3/1/1上配置DSCP值范围为1到4的IPv6未知源IP接入用户认证使用的认证域为dscpdm。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber service-identify dscp
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber dscp 1 to 4 domain dscpdm
ipv6 subscriber enable命令用来在接口上使能IPv6 IPoE功能并指定用户的接入模式。
undo ipv6 subscriber enable命令用来恢复缺省情况。
ipv6 subscriber { l2-connected | routed } enable
undo ipv6 subscriber { l2-connected | routed } enable
接口上的IPv6 IPoE功能处于关闭状态。
l2-connected:指定二层接入模式,表示此接口上用户通过二层网络接入。
routed:指定三层接入模式,表示此接口上用户通过三层网络接入。
只有在接口上使能了IPv6 IPoE功能后,其它的IPv6 IPoE相关配置才能生效。
# 在接口GigabitEthernet3/1/1上使能二层接入模式的IPv6 IPoE功能。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber l2-connected enable
ipv6 subscriber initiator dhcp enable命令用来在接口上使能DHCPv6报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator dhcp enable命令用来关闭接口上DHCPv6报文触发生成IPv6 IPoE会话的功能。
DHCPv6报文不能触发生成IPv6 IPoE会话。
接口上使能该功能后,收到的首个DHCP Solicit报文或直接申请地址的DHCP Request报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的DHCPv6报文不能触发生成IPv6 IPoE会话,已有的由DHCPv6报文触发生成的IPv6 IPoE会话不会被删除。
接口上可同时配置DHCPv6报文、IPv6 ND RS和未知源IPv6报文触发生成IPv6 IPoE会话的功能。
# 在接口GigabitEthernet3/1/1上使能DHCPv6报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber initiator dhcp enable
· ipv6 subscriber initiator ndrs enable
· ipv6 subscriber initiator unclassified-ip enable
ipv6 subscriber initiator ndrs enable命令用来在接口上使能IPV6 ND RS报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator ndrs enable命令用来关闭接口上IPV6 ND RS报文触发生成IPv6 IPoE会话的功能。
RS报文不能触发生成IPv6 IPoE会话。
接口上使能该功能后,收到的首个IPV6 ND RS报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的IPv6 ND RS报文不能触发生成IPv6 IPoE会话,已有的由IPv6 ND RS报文触发生成的IPv6 IPoE会话不会被删除。
# 在接口GigabitEthernet3/1/1上使能IPv6 ND RS报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber initiator ndrs enable
ipv6 subscriber initiator unclassified-ip enable命令用来在接口上使能未知源IPv6报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator unclassified-ip enable命令用来关闭接口上的未知源IPv6报文触发生成IPv6 IPoE会话的功能。
未知源IPv6报文不能触发生成IPv6 IPoE会话。
接口使能该功能后,收到的未知源IPv6报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的未知源IPv6报文不能触发生成IPv6 IPoE会话,已有的由未知源IPv6报文触发生成的IPv6 IPoE会话不会被删除。
# 在接口GigabitEthernet3/1/1上使能未知源IPv6报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber initiator unclassified-ip enable
ipv6 subscriber interface-leased命令用来配置IPv6接口专线用户。
undo ipv6 subscriber interface-leased命令用来删除已配置的IPv6接口专线用户。
未配置IPv6接口专线用户。
domain domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符,如果未配置该参数,将使用缺省认证域来认证用户。关于缺省认证域的相关配置请参见“安全配置指导”中的 “AAA”。
一个IPv6 IPoE接口专线用户代表了该接口接入的所有IPv6用户,接口上接入的所有IPv6用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有IPv6用户流量均允许通过,且共享一个IPv6 IPoE会话,并基于接口进行授权和计费。
每个接口只能配置一个IPv6 IPoE接口专线用户。
# 在接口GigabitEthernet3/1/1上配置一个IPv6 IPoE接口专线用户:认证使用的用户名为intuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber interface-leased username intuser password plaintext pw123
· display ipv6 subscriber interface-leased
ipv6 subscriber nas-port-id format命令用于为IPv6 IPoE接入用户配置nas-port-id属性封装格式,即在IPv6 IPoE接入用户进行认证时,接入设备向RADIUS服务器发送的nas-port-id属性的封装格式。
undo ipv6 subscriber nas-port-id format命令用来恢复缺省情况。
ipv6 subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
按version 1.0的格式要求填充发往RADIUS服务器的nas-port-id属性内容。
version1.0:填充格式为version 1.0,表示发送给RADIUS服务器的nas-port-id属性以电信163大后台要求的格式填充。
version2.0:填充格式为version 2.0,表示发送给RADIUS服务器的nas-port-id属性以YDT 2275-2011宽带接入用户线路(端口)标识要求的格式填充。
# 在接口GigabitEthernet3/1/1上配置设备使用RADIUS的nas-port-id属性封装格式为version 2.0。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber nas-port-id format cn-telecom version2.0
· ipv6 subscriber nas-port-id nasinfo-insert
ipv6 subscriber nas-port-id nasinfo-insert命令用于配置在提取出的DHCPv6报文的Option 18 Circuit-ID子选项内容中插入NAS信息,并使用插入NAS信息后的内容作为nas-port-id属性。
undo ipv6 subscriber nas-port-id nasinfo-insert命令用来恢复缺省情况。
不使用Option18选项中的内容作为nas-port-id属性字符串。
在DHCP中继组网环境下,接入设备能捕获用户的DHCPv6报文,并从报文中提取出DHCPv6 Option18选项信息。在配置了本命令且信任DHCP Option 18的情况下,接入设备处理如下:
· 如果收到的DHCPv6报文带有DHCP Option18选项,则从收到的DHCPv6报文中解析DHCP Option18选项,并按YDT 2275-2011宽带接入用户线路(端口)标识要求在原有Option18内容里插入NAS信息(该信息标识了用户在本设备上的接入位置信息),然后将其作为RADIUS的nas-port-id属性内容。
· 如果收到的DHCPv6报文不带Option18选项,则按version 2.0格式要求封装,保留该子选项中的原有的NAS信息字段(NAS_slot/NAS_subslot/NAS_port:svlan.cvlan),并将AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port部分修改为0/0/0/0/0/0。
本功能对原DHCPv6报文中Option18选项不产生任何影响,且只在nas-port-id的封装格式为version 2.0时生效。
# 在接口GigabitEthernet3/1/1上配置设备使用DHCPv6客户端上报的Option18信息,并在其中插入NAS信息,然后将其封装为RADIUS的nas-port-id属性。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber trust option18
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber nas-port-id nasinfo-insert
· ipv6 subscriber nas-port-id format
ipv6 subscriber nas-port-type命令用来配置接口的IPv6 IPoE接入端口类型。
undo ipv6 subscriber nas-port-type命令用来恢复缺省情况。
IPv6 IPoE接入端口类型为Ethernet类型。
# 配置接口GigabitEthernet3/1/1的IPv6 IPOE接入端口类型为SDSL。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber nas-port-type sdsl
ipv6 subscriber ndrs domain命令用来配置IPv6 ND RS个人接入用户使用的认证域。
undo ipv6 subscriber ndrs domain命令用来恢复缺省情况。
ipv6 subscriber ndrs domain domain-name
IPv6 ND RS个人接入用户使用缺省认证域作为认证域。
本命令用来配置IPv6 ND RS报文触发接入的IPv6 IPoE接入用户在认证时使用的域名,该域名必须与认证服务器上配置的域名保持一致。
配置ipv6 subscriber ndrs domain命令后,对于IPv6 ND RS报文触发认证的IPoE接入用户使用本命令指定的域名进行认证,否则使用缺省认证域认证。
# 配置接口GigabitEthernet3/1/1上IPv6 ND RS接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber ndrs domain ipoe
ipv6 subscriber ndrs max-session命令用来配置接口上允许RS报文触发创建的IPv6 IPoE会话的最大数。
undo ipv6 subscriber ndrs max-session命令用来恢复缺省情况。
ipv6 subscriber ndrs max-session max-number
max-number:允许RS触发创建的IPv6 IPoE会话最大数,取值范围为1~32768。
RS报文触发创建的IPv6 IPoE会话数目达到最大值后,后续RS报文不能触发创建IPv6 IPoE会话,DHCPv6报文、未知源IPv6报文等触发创建IPv6 IPoE会话不会受此最大值限制。
# 配置接口GigabitEthernet3/1/1上允许RS报文触发创建的IPv6 IPoE会话最大数为100。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber ndrs max-session 100
ipv6 subscriber ndrs username命令用来配置IPv6 ND RS接入用户的认证用户名。
undo ipv6 subscriber ndrs username命令用来恢复缺省情况。
IPv6 ND RS接入用户采用用户报文的源MAC地址作为认证用户名。
本命令用来配置IPv6 RS报文触发接入的IPv6 IPoE接入用户在认证时使用的用户名,该用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ipv6 subscriber password命令配置。
# 配置接口GigabitEthernet3/1/1上的IPv6 ND RS接入用户使用用户报文的源MAC地址作为用户名。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber ndrs username include source-mac
ipv6 subscriber password命令用来配置动态IPv6 IPoE个人接入用户的认证密码。
undo ipv6 subscriber password命令用来恢复缺省情况。
ipv6 subscriber password { ciphertext | plaintext } password
动态IPv6 IPoE个人接入用户的认证密码为字符串vlan。
本命令用来配置动态IPv6 IPoE个人接入用户认证时使用的密码,动态IPv6 IPoE个人接入用户是指通过DHCPv6报文或未知源IPv6报文触发建立IPoE会话并进行认证的IPoE个人接入用户。
# 配置接口GigabitEthernet3/1/1上动态IPoE个人接入用户认证时使用的密码为明文的123。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber password plaintext 123
· ipv6 subscriber unclassified-ip username
ipv6 subscriber service-identify命令用来配置IPv6未知源IP接入用户的业务识别方式。
undo ipv6 subscriber service-identify命令用来恢复缺省情况。
三层以太网接口视图/三层聚合口视图
ipv6 subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
未指定IPv6未知源IP接入用户的业务识别方式。
dscp:表示基于DSCP值识别业务。
对于未知源IPv6用户认证时使用的认证域由报文中携带的业务信息来决定。不同的业务特征可以对应不同的认证域,每一个接口可以指定仅识别某种类型业务的报文。例如,接口上若指定了基于DSCP值识别业务,且通过ipv6 subscriber dscp 1 domain aabcc命令指定了DSCP值1与认证域aabbcc的映射关系,则IPv6报文DSCP值为1的用户认证时将会使用认证域aabbcc。
· 本命令中的8021p vlan、8021p second-vlan、vlan和second-vlan参数仅子接口支持,非子接口不支持。
# 配置接口GigabitEthernet3/1/1上的IPv6未知源IP接入用户认证使用基于DSCP的业务识别方式
· ipv6 subscriber 8021p
· ipv6 subscriber dscp
· ipv6 subscriber vlan
ipv6 subscriber session static命令用来配置静态IPv6 IPoE会话。
undo ipv6 subscriber session static命令用来删除指定的静态IPv6 IPoE会话。
undo ipv6 subscriber session static ipv6 ipv6-address [ vlan vlan-id [ second-vlan vlan-id ] ]
未配置静态IPv6 IPoE会话。
ipv6 ipv6-address:表示用户的IP地址。
· 系统支持配置多个静态IPoE会话。
# 在接口GigabitEthernet3/1/1上配置一条静态IPv6 IPoE会话:用户IPv6地址为2000::1,认证使用的认证域为dm1。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber session static ipv6 2000::1 domain dm1
ipv6 subscriber subnet-leased 命令用来配置IPv6 IPoE子网专线用户。
undo ipv6 subscriber subnet-leased 命令用来删除指定的IPv6 IPoE子网专线用户。
undo ipv6 subscriber subnet-leased ipv6 ipv6-address prefix-length
未配置IPv6 IPoE子网专线用户。
ipv6 ipv6-address:表示用户的IPv6地址。
一个IPv6 IPoE子网专线用户代表了该接口接入的所有该子网内IPv6用户,该子网内的所有IPv6用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有该子网内IPv6用户流量均允许通过,且共享一个IPv6 IPoE会话,并基于子网进行授权和计费。
每个子网只能配置一个IPv6 IPoE子网专线用户。
# 在接口GigabitEthernet3/1/1上配置一个IPv6 IPoE子网专线用户:用户IPv6地址和前缀为2001:10::100/64,认证使用的用户名为netuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber subnet-leased ipv6 2001:10::100 64 username netuser password plaintext pw123
· display ipv6 subscriber subnet-leased
ipv6 subscriber timer quiet命令用来配置IPv6 IPoE用户的静默时间。
undo ipv6 subscriber timer quiet命令用来恢复缺省情况。
ipv6 subscriber timer quiet time
IPv6 IPoE用户的静默时间功能处于关闭状态。
# 在接口GigabitEthernet3/1/1上配置IPv6 IPoE用户的静默时间为100秒。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber timer quiet 100
ipv6 subscriber trust命令用于配置信任DHCPv6报文中的指定Option。
undo ipv6 subscriber trust命令用来恢复缺省情况。
ipv6 subscriber trust { option16 | option18 | option37 }
undo ipv6 subscriber trust { option16 | option18 | option37 }
不信任DHCPv6报文中的任何Option。
option16:表示信任DHCPv6报文中的Option16。
option18:表示信任DHCPv6报文中的Option18。
option37:表示信任DHCPv6报文中的Option37。
DHCP组网环境中,如果接入设备信任DHCPv6报文中的Option 16,则:
· 如果Option16内容有效,但没有@字符,以整个Option16的内容作为域名;
· 如果Option16内容中包含了域名分隔符@字符,且@字符后的字符串有效(无非法字符'\','/',':','*','?','\"','<','>','|'等),则以@字符之后的字符串作为域名;
如果不信任DHCPv6报文中的Option 16,则:
· 如果配置了ipv6 subscriber dhcp domain domain-name,则以该命令配置的域名接入;
· 如果接口没有配置缺省DHCPv6接入的domain,则不设置AAA的domain属性,按系统缺省域接入。
DHCP中继组网环境中,接入设备可以提取用户DHCPv6报文中的指定Option信息。如果接入设备信任DHCPv6报文中的Option 18,则:
· 接入设备在采用version 2.0格式封装RADIUS nas-port-id属性时,会根据Option 18信息中的Circuit-ID子选项内容封装发往RADIUS服务器的nas-port-id属性;
· 接入设备会根据Option 18中的Circuit-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_CIRCUIT_ID属性。
如果接入设备信任DHCPv6报文中的Option 37,则接入设备会根据Option 37中的Remote-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_REMOTE_ID属性。
# 在接口GigabitEthernet3/1/1上配置设备信任DHCPv6报文中的Option18。
ipv6 subscriber unclassified-ip domain命令用来配置IPv6未知源IP接入用户使用的认证域。
undo ipv6 subscriber unclassified-ip domain命令用来恢复缺省情况。
ipv6 subscriber unclassified-ip domain domain-name
IPv6未知源IP接入用户的认证域为缺省认证域。
该命令用来配置未知源IPv6报文触发接入的IPv6 IPoE接入用户在认证时使用的缺省域名,该域名必须与认证服务器上配置的域名保持一致。
如果指定接口上配置了ipv6 subscriber service-identify,则优先使用ipv6 subscriber service-identify指定的业务识别方式获取对应的认证域。只有在未匹配到ipv6 subscriber service-identify命令指定的认证域时,才使用ipv6 subscriber unclassified-ip domain命令指定的认证域。如果 ipv6 subscriber unclassified-ip domain命令也未配置,则使用缺省认证域。
# 配置接口GigabitEthernet3/1/1上的IPv6未知源IP接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber unclassified-ip domain ipoe
ipv6 subscriber unclassified-ip max-session命令用来配置接口上允许未知源IPv6报文触发创建的动态IPv6 IPoE会话的最大数。
undo ipv6 subscriber unclassified-ip max-session命令用来恢复缺省情况。
ipv6 subscriber unclassified-ip max-session max-number
未限制接口上允许未知源IPv6报文创建的动态IPv6 IPoE会话数目。
max-number :允许未知源IPv6报文触发创建的IPv6 IPoE会话最大数,取值范围为1~32768。
未知源IPv6报文触发创建的IPv6 IPoE会话数目达到最大值后,后续未知源IPv6报文不能触发创建IPv6 IPoE会话。DHCPv6报文触发创建IPv6 IPoE会话不会受此最大值限制。
# 配置接口GigabitEthernet3/1/1上允许未知源IPv6报文触发创建的IPv6 IPoE会话最大数为100。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber unclassified-ip max-session 100
ipv6 subscriber unclassified-ip username命令用来配置IPv6未知源IP接入用户的认证用户名。
undo ipv6 subscriber unclassified-ip username命令用来恢复缺省情况。
IPv6未知源IP接入用户采用用户报文的源IPv6地址作为认证用户名。
source-ip:表示使用用户报文的源IPv6地址作为用户名。
separator separator:IPv6地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如1-2-3;若不指定该参数,则用户名形如1::2:3。
本命令用来配置未知源IPv6报文触发接入的IPv6 IPoE用户在认证时使用的用户名,该用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ipv6 subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ipv6 subscriber unclassified-ip username include source-ip source-mac,则用户名为源IPv6地址字段和源MAC地址字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet3/1/1上的未知源IPv6用户使用用户报文的源IPv6地址作为用户名。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber unclassified-ip username include source-ip
ipv6 subscriber user-detect命令用来开启静态/动态IPv6 IPoE个人接入用户在线探测功能,并配置其探测方式。
undo ipv6 subscriber user-detect命令用来关闭静态/动态IPv6 IPoE个人接入用户在线探测功能。
ipv6 subscriber user-detect { icmpv6 | nd } retry times interval interval
静态/动态IPoE个人接入用户在线探测功能处于关闭状态。
icmpv6:表示使用ICMPv6请求报文作为探测报文。
nd:表示使用ND NS报文作为探测报文。
接口上的静态/动态IPv6 IPoE个人接入用户上线后,设备会定时统计用户流量。若一个探测间隔(interval)内用户流量无变化,则该探测间隔结束后,设备将发送一次探测报文。如果设备在探测间隔内未收到用户的报文,则认为一次探测失败。
对于与接口在同一网段内的静态/动态IPv6 IPoE个人接入用户,可使用IPv6 ND NS或ICMPv6请求报文对用户进行探测;对于与接口不在同一网段内的静态/动态IPv6 IPoE个人接入用户,应使用ICMPv6请求报文对用户进行探测。
接口上不可同时启用两种方式对IPv6 IPoE个人接入用户进行探测。
# 配置接口GigabitEthernet3/1/1上使用IPv6 ND NS报文对静态/动态IPv6 IPoE个人接入用户进行在线检测,探测失败后允许重复尝试3次,探测的时间间隔为50秒。
[Sysname-GigabitEthernet3/1/1] ipv6 subscriber user-detect nd retry 3 interval 50
ipv6 subscriber vlan命令用于配置IPv6未知源IP报文的内/外层VLAN值与认证域的映射关系。
undo ipv6 subscriber vlan命令用来恢复缺省情况。
ipv6 subscriber vlan vlan-list domain domain-name
undo ipv6 subscriber vlan vlan-list
未指定IPv6未知源IP报文的内/外层VLAN与认证域的映射关系。
本命令用来配置指定VLAN范围内未知源IPv6接入用户进行认证时使用的认证域,通过指定的认证域进行认证授权。
# 在子接口GigabitEthernet 3/1/1.100上配置内层VLAN ID范围为2到100的IPv6未知源IP接入用户认证使用的认证域为vlandm。
[Sysname-GigabitEthernet3/1/1.100] ipv6 subscriber service-identify second-vlan
[Sysname-GigabitEthernet3/1/1.100] ipv6 subscriber vlan 2 to 100 domain vlandm
reset ipv6 subscriber offline statistics命令用来清除IPv6 IPoE用户下线统计信息。
reset ipv6 subscriber offline statistics [ interface interface-type interface-number ]
interface interface-type interface-number:表示清除指定接口上的IPv6 IPoE用户下线统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的IPv6 IPoE用户下线统计信息。
# 清除所有接口上的IPv6 IPoE用户的下线统计信息。
<Sysname> reset ipv6 subscriber offline statistics
· display ipv6 subscriber offline statistics
reset ipv6 subscriber session命令用来清除动态触发创建的IPv6 IPoE会话,强制用户下线。
interface interface-type interface-number:表示清除指定接口动态触发创建的IPv6 IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口动态触发创建的IPv6 IPoE会话。
domain domain-name:表示清除使用指定ISP域认证的IPv6 IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”等字符。
ipv6 ipv6-address:表示清除指定IP地址的IPv6 IPoE会话,ipv6-address为指定的IPv6地址。
vpn-instance vpn-instance-name:表示清除指定VPN的IPv6 IPoE会话,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv6 IPoE会话位于公网中。
mac mac-address:表示清除指定源MAC地址的IPv6 IPoE会话,形式为H-H-H。
username name:表示清除指定用户名的IPv6 IPoE会话,name为1~255个字符的字符串,区分大小写。
本命令用来清除动态触发创建的IPv6 IPoE会话信息,并强制用户下线,如果不指定条件,则表示删除所有动态IPv6 IPoE会话。
接口专线用户和静态个人用户不能通过reset ipv6 subscriber session命令强制下线,只能通过相应的undo命令删除配置。
# 清除接口GigabitEthernet3/1/1上动态触发创建的IPv6 IPoE会话,强制用户下线。
<Sysname> reset ipv6 subscriber session interface gigabitethernet 3/1/1
