10-LLDP命令
本章节下载: 10-LLDP命令 (237.88 KB)
1.1.1 display lldp local-information
1.1.2 display lldp neighbor-information
1.1.7 lldp check-change-interval
1.1.8 lldp compliance admin-status cdp
1.1.14 lldp management-address-format string
1.1.17 lldp notification med-topology-change enable
1.1.18 lldp notification remote-change enable
1.1.19 lldp timer fast-interval
1.1.20 lldp timer notification-interval
1.1.21 lldp timer reinit-delay
display lldp local-information命令用来显示LLDP本地信息,这些信息将将根据端口TLV使能情况被组织成TLV发送给邻居设备。
global:显示全局LLDP本地信息。
interface interface-type interface-number:显示指定接口上的LLDP本地信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示所有LLDP本地信息,包括全局LLDP信息以及所有使能了LLDP功能且状态为up的接口上的LLDP信息。
<Sysname> display lldp local-information
Chassis ID : 80f6-2e82-1ed6
System name : Sysname
System description : H3C Comware Platform Software, Software Version 7.1.048,
Alpha 7131
H3C SR8804-X
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All
rights reserved.
System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
System capabilities enabled : Bridge, Router, Customer Bridge
MED information:
Device class : Connectivity device
MED inventory information of master board:
HardwareRev : VER.A
FirmwareRev : 004
SoftwareRev : 7.1.048 7137
SerialNum : Unknown
Manufacturer name : Unknown
Model name : H3C SR8804-X
Asset tracking identifier : Unknown
LLDP local-information of port 209[GigabitEthernet2/0/17]:
Port ID type : Interface name
Port ID : GigabitEthernet2/0/17
Port description : GigabitEthernet2/0/17 Interface
LLDP agent nearest-bridge management address:
Management address type : All802
Management address : 80f6-2e82-1ed8
Management address interface ID : Unknown
Management address OID : 0
LLDP agent nearest-nontpmr management address:
LLDP agent nearest-customer management address:
DCBX Control info:
Oper version : Ver 1.00
Sequence number : 1
Acknowledge number : 0
DCBX ETS info:
CoS Local Priority Percentage
0 2 0
1 0 0
2 1 0
3 3 0
4 4 0
5 5 0
6 6 0
7 7 0
DCBX PFC info:
P0-0 P1-0 P2-0 P3-0 P4-0 P5-0 P6-0 P7-0
Port VLAN ID(PVID) : 1
Port and protocol VLAN ID(PPVID) : 0
Port and protocol VLAN supported : No
Port and protocol VLAN enabled : No
VLAN name of VLAN 1 : VLAN 0001
Management VLAN ID : 0
Link aggregation enabled : No
Aggregation port ID : 0
Auto-negotiation enabled : Yes
OperMau : Speed(1000)/Duplex(Full)
Power port class : PSE
PSE power supported : No
PSE power enabled : No
PSE pairs control ability : No
Power pairs : Signal
Port power classification : Class 0
Maximum frame size : 9216
PoE PSE power source : Unknown
Port PSE priority : Unknown
Port available power value : 0.0(w)
LLDP local-information of port 211[GigabitEthernet2/0/19]:
Port ID : GigabitEthernet2/0/19
Port description : GigabitEthernet2/0/19 Interface
Management address : 80f6-2e82-1ed9
Maximum frame size : 1500
表1-1 display lldp local-information命令显示信息描述表
本设备的全局LLDP本地信息 |
Chassis ID值,为本设备的桥MAC地址 |
· Bridge:表示支持交换功能 · Router:表示支持路由功能 · WlanAccessPoint:表示支持无线接入点功能 · Router:表示支持路由功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
· Bridge:表示交换功能已使能 · Router:表示路由功能已使能 · WlanAccessPoint:表示无线接入点功能已使能 · Router:表示路由功能已使能 · Telephone:表示电话功能已使能 · DocsisCableDevice:表示电缆设备功能已使能 · StationOnly:表示只作站点功能已使能 · Customer Bridge:表示客户桥功能已使能 · Service Bridge:表示服务桥功能已使能 · TPMR:表示双端口MAC中继功能已使能 · Other:表示不在上述列表的其它功能已使能 |
MED设备相关信息 |
MED设备类型: · Connectivity device:表示网络设备 · Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备 · Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流 · Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用 |
主控板MED资产信息 |
端口1上LLDP本地信息 |
端口ID类型: · MAC address:表示MAC地址 · Interface name:表示接口名称 |
端口ID值,根据本设备的Port ID type取相应类型的值 |
LLDP缺省代理,即最近桥代理的管理地址 |
LLDP最近客户桥代理的管理地址 |
LLDP最近非TPMR桥代理的管理地址 |
显示DCBX控制TLV的信息,包括: · Oper version:DCBX版本号 · Sequence number:DCBX TLV内容改变的次数 · Acknowledge number:对端设备同步配置的次数 设备暂不支持DCBX相关字段,当前显示信息无效 |
CoS与本地优先级的映射关系及对应的带宽分配信息,包括: · CoS:CoS值 · Local Priority:本地优先级 · Percentage:对应的带宽分配 设备暂不支持DCBX相关字段,当前显示信息无效 |
P0- P1- P2- P3- P4- P5- P6- P7- |
本端的no-drop标记值对应的支持的优先级数。设备暂不支持DCBX相关字段,当前显示信息无效 |
VLAN 1的名称 |
Auto-negotiation supported |
端口是否支持自协商 |
Auto-negotiation enabled |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE(Power Sourcing Equipment,供电设备) · PD(Powered Device,受电设备) |
PSE power supported |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
PSE pairs control ability |
供电方式是否可控 |
Power pairs |
PoE端口的远程供电模式: · Signal:表示信号线供电模式 · Spare:表示空闲线供电模式 |
Port power classification |
PD的端口控制级别: · Class 0:表示级别0 · Class 1:表示级别1 · Class 2:表示级别2 · Class 3:表示级别3 · Class 4:表示级别4 |
Maximum frame size |
端口支持的最大帧长度 |
PSE所采用的电源类型: · Unknown:表示采用的电源类型未知 · Primary:表示采用主用电源作为电源 · Backup:表示采用备用电源作为电源 |
PSE上端口的供电优先级: · Unknown:表示优先级未知 · Critical:表示优先级为1级 · High:表示优先级为2级 · Low:表示优先级为3级 |
PSE上端口可提供的功率,或PD上端口所需的功率(单位为瓦特) |
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息,这些信息是由邻居设备组织成TLV并发送给本设备的。
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
agent:显示指定类型LLDP代理收到的由邻居设备发来的LLDP信息。如果未指定该参数,将显示所有类型LLDP代理收到的由邻居设备发来的LLDP信息。
nearest-bridge:表示最近桥代理。
nearest-customer:表示最近客户桥代理。
nearest-nontpmr:表示最近非TPMR桥代理。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口最近桥代理收到的由邻居设备发来的LLDP详细信息。
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 209[GigabitEthernet2/0/17]:
LLDP agent nearest-bridge:
LLDP neighbor index : 1
Update time : 0 days, 1 hours, 15 minutes, 1 seconds
Chassis type : MAC address
Chassis ID : 00e0-fc00-c518
Port ID : GigabitEthernet2/4/0/17
Time to live : 120
Port description : GigabitEthernet2/4/0/17 Interface
System name : H3C
System description : H3C Comware Software. H3C S12504 Product Version S12500-C
MW710-B732401. Copyright (c) 2004-1-13 Hangzhou H3C Tech.
Co., Ltd. All rights reserved.
Management address : 00e0-fc00-c518
CDP neighbor-information of port 1[GigabitEthernet1/0/1]:
CDP neighbor index : 4
Chassis ID : SEP00260B5C0548
Port ID : Port 1
Software version : SCCP41.8-4-1S
Platform version : Cisco IP Phone 7941
Duplex : Full
Time to live : 180
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP概要信息。
ChassisID/subtype : 00e0-fc00-c518/MAC address
PortID/subtype : GigabitEthernet2/4/0/17/Interface name
Capabilities : Bridge, Router, Customer Bridge
# 按列表显示类型LLDP代理所有邻居设备发来的LLDP信息。
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
# -- -- Nearest customer bridge neighbor
Default -- -- Nearest bridge neighbor
System Name Local Interface Chassis ID Port ID
H3C GE2/0/17 00e0-fc00-c518 GigabitEthernet2/4/0/17
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
端口1上收到的LLDP邻居信息 |
Chassis ID类型: · Chassis component:表示底架组件 · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Locally assigned:表示邻居自定义 |
Chassis ID值,根据邻居设备的Chassis type取相应类型的值 |
端口ID类型: · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network Address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Agent circuit ID:表示代理巡回标识 · Locally assigned:表示邻居自定义 |
端口ID值,根据邻居设备的Port ID type取相应类型的值 |
· Repeater:表示支持信号中继功能 · Bridge:表示支持交换功能 · WlanAccessPoint:表示支持无线接入点功能 · Router:表示支持路由功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
· Repeater:表示信号中继功能已使能 · Bridge:表示交换功能已使能 · WlanAccessPoint:表示无线接入点功能已使能 · Router:表示路由功能已使能 · Telephone:表示电话功能已使能 · DocsisCableDevice:表示电缆设备功能已使能 · StationOnly:表示只作站点功能已使能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示不在上述列表的其它功能已使能 |
Link aggregation supported |
端口是否支持链路聚合 |
Link aggregation enabled |
端口是否已使能链路聚合 |
Aggregation port ID |
聚合组中该成员端口的编号,未使能链路聚合功能时为0 |
端口是否支持自协商 |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
供电方式是否可控 |
Power pairs |
端口支持的最大帧长度 |
端口1的CDP邻居信息 |
CDP邻居索引 |
Chassis ID值及Chassis ID类型 |
Port ID值及PortID类型 |
· Repeater:表示使能信号中继功能 · Bridge:表示使能交换功能 · WlanAccessPoint:表示使能无线接入点功能 · Router:表示使能路由功能 · Telephone:表示使能电话功能 · DocsisCableDevice:表示使能电缆设备功能 · StationOnly:表示使能只作站点功能,与其他功能不能同时出现 · Other:表示使能不在上述列表的其他功能 · None:表示该邻居未发布该TLV |
接收LLDP信息的本端端口 |
· *符号:表示该邻居是最近非TPMR桥代理类型邻居 #符号:表示该邻居是最近客户桥代理类型邻居 |
display lldp statistics命令用来显示LLDP的统计信息。
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
agent:显示指定类型LLDP代理的统计信息。如果未指定该参数,将显示所有类型LLDP代理的统计信息。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted : 1
The number of LLDP neighbor information dropped : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted : 0
The number of LLDP frames received : 0
The number of LLDP frames discarded : 0
The number of LLDP error frames : 0
The number of LLDP TLVs discarded : 0
The number of LLDP TLVs unrecognized : 0
The number of CDP frames transmitted : 0
The number of CDP frames received : 0
The number of CDP frames discarded : 0
The number of CDP error frames : 0
LLDP agent nearest-nontpmr:
LLDP agent nearest-customer:
表1-3 display lldp statistics命令显示信息描述表
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
全局LLDP统计信息 |
端口1上的LLDP统计信息 |
发送的LLDP帧总数 |
收到的LLDP帧总数 |
丢弃的LLDP帧总数 |
收到的错误LLDP帧总数 |
老化的LLDP邻居信息总数 |
发送的CDP帧总数 |
收到的CDP帧总数 |
丢弃的CDP帧总数 |
收到的错误CDP帧总数 |
display lldp status命令用来显示LLDP的状态信息。
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有使能了LLDP功能的接口上的LLDP状态信息。
agent:显示指定类型LLDP代理的状态信息。如果未指定该参数,将显示所有类型LLDP代理的状态信息。
# 显示全局和所有接口上的LLDP状态信息。
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
Transmit interval : 30s
Fast transmit interval : 1s
Transmit max credit : 5
Hold multiplier : 4
Reinit delay : 2s
Trap interval : 5s
Fast start times : 3
LLDP status information of port 1 [GigabitEthernet1/0/1]:
Port status of LLDP : Enable
Admin status : Tx_Rx
Trap flag : No
MED trap flag : No
Polling interval : 0s
Number of LLDP neighbors : 5
Number of MED neighbors : 2
Number of CDP neighbors : 0
Number of sent optional TLV : 12
Trap flag : No
Trap flag : No
表1-4 display lldp status命令显示信息描述表
LLDP桥模式: · service-bridge:表示服务桥模式 · customer-bridge:表示客户桥模式 |
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
LLDP功能是否已全局使能 |
当前设备的LLDP邻居总数 |
当前设备的CDP邻居总数 |
LLDP报文的发送间隔 |
TTL乘数 |
LLDP报文发包限速令牌桶的最大值 |
Trap信息的发送间隔 |
快速发送LLDP报文的个数 |
端口1上的LLDP状态信息 |
LLDP功能是否已在端口上使能 |
端口LLDP工作模式: · Tx_Rx:表示既发送也接收LLDP报文 · Rx_Only:表示只接收不发送LLDP报文 · Tx_Only:表示只发送不接收LLDP报文 · Disable:表示既不发送也不接收LLDP报文 |
LLDP Trap功能是否已使能 |
LLDP-MED Trap功能是否已使能 |
轮询间隔,0表示轮询功能处于关闭状态 |
端口LLDP邻居数量 |
端口MED邻居设备的数量 |
端口CDP邻居设备的数量 |
端口在一个LLDP报文中发送的可选TLV总数 |
端口在所有LLDP报文中收到的不能识别的TLV总数 |
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
agent:显示指定类型LLDP代理的可选TLV信息。如果未指定该参数,将显示所有类型LLDP代理的可选TLV信息。
# 显示接口GigabitEthernet1/0/1上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 209[GigabitEthernet1/0/1]:
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES YES
System Name TLV YES YES
System Description TLV YES YES
System Capabilities TLV YES YES
Management Address TLV YES YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV YES YES
Port And Protocol VLAN ID TLV NO NO
VLAN Name TLV NO NO
DCBX TLV YES NO
EVB TLV NO NO
Link Aggregation TLV YES YES
Management VID TLV NO NO
IEEE 802.3 extend TLV:
MAC-Physic TLV YES YES
Power via MDI TLV YES YES
Maximum Frame Size TLV YES YES
LLDP-MED extend TLV:
Network Policy TLV YES YES
Location Identification TLV NO NO
Extended Power via MDI TLV YES YES
Inventory TLV YES YES
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV NO NO
System Name TLV NO NO
System Description TLV NO NO
System Capabilities TLV NO NO
Management Address TLV NO NO
Port VLAN ID TLV NO NO
VLAN Name TLV NO NO
DCBX TLV NO NO
EVB TLV YES YES
Link Aggregation TLV NO NO
MAC-Physic TLV NO NO
Power via MDI TLV NO NO
Maximum Frame Size TLV NO NO
Network Policy TLV NO NO
Extended Power via MDI TLV NO NO
Inventory TLV NO NO
NAME STATUS DEFAULT
Basic optional TLV:
VLAN Name TLV NO NO
DCBX TLV NO NO
EVB TLV NO NO
Inventory TLV NO NO
表1-5 display lldp tlv-config命令显示信息描述表
LLDP 缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
端口1上可发送的可选TLV类型 |
TLV类型 |
端口发布指定类型TLV的缺省情况 |
端口可发送的IEEE 802.1组织定义的TLV类型 |
VLAN名称TLV |
DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV。设备暂不支持本字段,当前显示信息无效 |
EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV 。设备暂不支持本字段,当前显示信息无效 |
Link Aggregation TLV |
链路聚合TLV |
端口可发送的IEEE 802.3组织定义的TLV类型 |
MED能力集TLV |
资产信息TLV,包括以下几种: · Hardware Revision TLV:终端设备硬件版本 · Firmware Revision TLV:终端设备固件版本 · Software Revision TLV:终端设备软件版本 · Serial Number TLV:终端设备序列号 · Manufacturer Name TLV:终端设备的制造厂商名称 · Model name TLV:终端设备的模块名称 · Asset id TLV:终端设备的资产标识符,以便目录管理和资产跟踪 |
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
在二层以太网接口视图/三层以太网接口视图下:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
在二层聚合接口视图/三层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
LLDP最近桥代理的工作模式为TxRx,既发送也接收LLDP报文。其他类型的LLDP代理的工作模式为Disable,即不发送也不接收LLDP报文。
二层以太网接口视图/二层聚合接口视图/三层以太网接口视图/三层聚合接口视图
agent:配置指定类型LLDP代理的工作模式。在以太网接口视图下,未指定时表示配置最近桥代理的工作模式。
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口GigabitEthernet1/0/1上最近客户桥代理LLDP的工作模式为Rx。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer admin-status rx
lldp check-change-interval命令用来使能轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
agent:配置指定类型LLDP代理的轮询功能。在以太网接口视图下,未指定时表示配置最近桥代理的轮询功能。
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口GigabitEthernet1/0/1的最近客户桥代理上使能轮询功能,并配置轮询间隔为30秒。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer check-change-interval 30
lldp compliance admin-status cdp命令用来配置LLDP兼容CDP功能的工作模式。
undo lldp compliance admin-status cdp命令用来恢复缺省情况。
lldp compliance admin-status cdp { disable | txrx }
LLDP兼容CDP功能的工作模式为Disable,既不发送也不接收CDP报文。
二层以太网接口视图/三层以太网接口视图
disable:表示工作模式为Disable,既不发送也不接收CDP报文。
txrx:表示工作模式为TxRx,既发送也接收CDP报文。
欲使LLDP兼容CDP的功能生效,必须先使能LLDP兼容CDP功能,同时将LLDP兼容CDP功能的工作模式配置为TxRx。
# 使能LLDP兼容CDP功能,并在接口GigabitEthernet1/0/1上配置LLDP兼容CDP功能的工作模式为TxRx。
[Sysname] lldp compliance cdp
[Sysname-GigabitEthernet1/0/1] lldp compliance admin-status cdp txrx
lldp compliance cdp命令用来使能LLDP兼容CDP功能。
undo lldp compliance cdp命令用来恢复缺省情况。
LLDP兼容CDP功能处于关闭状态。
由于CDP报文所携Time To Live TLV中TTL的最大值为255,而CDP报文的发送间隔由LLDP报文的发送间隔控制,因此为保证LLDP兼容CDP功能的正常运行,建议配置LLDP报文的发送间隔值不大于实际TTL的1/3。
# 使能LLDP兼容CDP功能。
lldp enable命令用来在接口上使能LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
接口上的LLDP功能处于使能状态。
只有当全局和接口上都使能了LLDP功能后,该功能才会生效。
# 在接口GigabitEthernet1/0/1上关闭LLDP功能。
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
快速发送LLDP报文的个数为4个。
count:表示快速发送LLDP报文的个数,取值范围为1~8,单位为个。
# 配置快速发送LLDP报文的个数为5个。
[Sysname] lldp fast-count 5
lldp global enable命令用来全局使能LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
LLDP的全局状态为关闭。
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
TTL乘数为4。
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔+1)),即取65535与(TTL乘数×LLDP报文的发送间隔+1)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
管理地址在TLV中的封装格式为数字格式。
agent:配置指定LLDP代理类型管理地址在TLV中的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的管理地址在TLV中的封装格式。
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
# 在接口GigabitEthernet1/0/1的最近客户桥代理上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer management-address-format string
lldp max-credit命令用来配置限制发送报文速率的令牌桶大小。
undo lldp max-credit命令用来恢复缺省情况。
credit-value:表示LLDP发包限速的令牌桶大小,取值范围1~100。
# 配置LLDP发包限速的令牌桶大小为10。
[Sysname] lldp max-credit 10
lldp mode命令用来配置当前设备的LLDP桥模式。
undo lldp mode命令用来恢复缺省情况。
设备的LLDP桥模式为客户桥模式。
service-bridge:表示服务桥模式。
LLDP的桥模式命令用于控制设备支持不同的LLDP代理。
· 工作于服务桥模式时,设备可支持最近桥代理和最近非TPMR桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
· 工作于客户桥模式时,设备可支持最近桥代理、最近非TPMR桥代理及最近客户桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
桥模式配置只在LLDP全局使能后才能生效,LLDP全局未使能时,只能作为客户桥对三种类型代理MAC的报文进行拦截。
# 配置LLDP桥模式为服务桥模式。
[Sysname] lldp mode service-bridge
lldp notification med-topology-change enable命令用来使能LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
# 在接口GigabitEthernet1/0/1上使能LLDP-MED Trap功能。
[Sysname-GigabitEthernet1/0/1] lldp notification med-topology-change enable
lldp notification remote-change enable命令用来使能LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP Trap功能处于关闭状态。
agent:使能指定类型LLDP代理的LLDP Trap功能。在以太网接口视图下,未指定时表示使能最近桥代理类型LLDP代理的LLDP Trap功能。
# 在接口GigabitEthernet1/0/1最近客户桥代理上使能LLDP Trap功能。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer notification remote-change enable
lldp timer fast-interval命令用来配置LLDP快速发送报文的时间间隔。
undo lldp timer fast-interval命令用来恢复缺省情况。
LLDP快速发送报文的时间间隔为1秒。
interval:表示LLDP快速发送报文的时间间隔,取值范围为1~3600,单位为秒。
# 配置LLDP快速发送报文的时间间隔为2秒。
[Sysname] lldp timer fast-interval 2
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为30秒。
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
interval:表示LLDP报文的发送间隔,取值范围为5~32768,单位为秒。
# 配置LLDP报文的发送间隔为20秒。
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
· 配置最近桥代理LLDP接口上允许发布的TLV类型
· 配置最近非TPMR代理LLDP接口上允许发布的TLV类型
· 配置最近客户桥代理LLDP接口上允许发布的TLV类型
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
· 最近桥代理允许发布除Port And Protocol VLAN ID TLV、VLAN Name TLV、DCBX TLV、EVB TLV、Management VLAN ID TLV和Location Identification TLV之外所有类型的TLV;
· 最近非TPMR桥代理只允许发布EVB TLV;
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Port VLAN ID TLV和Link Aggregation TLV。
· 最近桥代理允许发布除Network Policy TLV和Location Identification TLV之外所有类型的TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV;
· 最近非TPMR桥代理不发布任何TLV;
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV。
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Port VLAN ID TLV。
· 最近客户桥代理只允许发布基本TLV。
agent:配置指定类型LLDP代理允许发布的TLV类型。在以太网接口视图下,未指定时表示配置最近桥代理允许发布的TLV类型。
all:在二层以太网接口视图/二层聚合接口视图/三层以太网接口视图下指定basic-tlv、dot1-tlv或dot3-tlv,或者在三层聚合接口视图下指定basic-tlv或dot3-tlv时,本参数表示该类型下所有的可选TLV;而不论在上述任何视图下指定med-tlv时,本参数都表示该类型下除location-id以外所有的可选TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ip-address ]:表示Management Address TLV。其中,ip-address表示在LLDP报文中所要发布的管理地址,其缺省值在二层以太网接口视图/二层聚合接口视图下配置时若未指定ip-address,则发布的管理地址为该端口允许通过的、对应VLAN接口上配置有IP地址且处于up状态的最小VLAN的主IP地址(如果该端口允许通过的所有VLAN所对应的VLAN接口上都未配置IP地址或均处于down状态,则发布该接口的MAC地址),在三层以太网接口视图/三层聚合接口视图下配置时若未指定ip-address,则发布的管理地址为该接口的IP地址(如果该接口未配置IP地址,则发布该接口的MAC地址)。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
dcbx:表示Data Center Bridging Exchange Protocol TLV。设备目前不支持。
evb:表示EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV。设备目前不支持。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4093,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4093,缺省值为该端口所属VLAN中最小的VLAN ID。
management-vid [ mvlan-id ]:表示Management VLAN ID TLV。mvlan-id指定要发布管理VLAN的VLAN ID,取值范围为1~4093。如果未指定该参数,则表示发布0,表示当前LLDP agent未配置管理VLAN。
link-aggregation:表示Link Aggregation TLV。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Network device,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy:表示Network Policy TLV。
power-over-ethernet:表示Extended Power-via-MDI TLV。
· 在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
· 如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
· IEEE 802.1组织定义的TLV的Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV只能基于最近桥代理配置,但是其配置会被最近非TPMR桥代理和最近客户桥代理继承。
# 配置接口GigabitEthernet1/0/1上最近客户桥代理允许发布IEEE 802.1组织定义的Link Aggregation可选TLV。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
