10-Portal命令
本章节下载: 10-Portal命令 (353.89 KB)
1.1.1 display portal interface
1.1.2 display portal packet statistics
1.1.6 display portal web-server
1.1.7 display web-redirect rule
1.1.11 portal { bas-ip | bas-ipv6 }
1.1.12 portal apply web-server
1.1.13 portal authorization strict-checking
1.1.17 portal fail-permit server
1.1.19 portal free-rule source
1.1.20 portal { ipv4-max-user | ipv6-max-user }
1.1.21 portal ipv6 layer3 source
1.1.22 portal ipv6 user-detect
1.1.25 portal nas-port-id format
1.1.27 portal pre-auth ip-pool
1.1.32 reset portal packet statistics
1.1.33 server-detect (portal server view)
本功能仅CSPEX-1204的单板支持。
display portal interface命令用来显示指定接口上的Portal配置信息和Portal运行状态信息。
display portal interface interface-type interface-number
# 显示接口GigabitEthernet3/1/1的Portal配置信息和Portal运行状态信息。
<Sysname> display portal interface gigabitethernet 3/1/1
Portal information of GigabitEthernet3/1/1
VSRP instance: --
VSRP state: N/A
Authorization Strict checking
ACL Enabled
User profile Disabled
IPv4:
Portal status: Enabled
Authentication type: Layer3
Portal Web server:wbs
Authentication domain: my-domain
Pre-auth domain: abc
Pre-auth IP pool: ab
BAS-IP: Not configured
User detection: Type: ICMP Interval: 300s Attempts: 5 Idle time: 180s
Action for server detection:
Server type Server name Action
Web server wbs fail-permit
Portal server pts fail-permit
Layer3 source network:
IP address Mask
1.1.1.1 255.255.0.0
IPv6:
Portal status: enabled
Authentication type: layer3
Portal Web server:wbsv6
Pre-auth IP pool: Not configured
BAS-IPv6:Not configured
User detection: Type: ICMPv6 Interval: 300s Attempts: 5 Idle time: 180s
Web server wbsv6 fail-permit
Portal server ptsv6 fail-permit
IP address Prefix length
11::5 64
表1-1 display portal interface命令显示信息描述表
接口上引用的VSRP实例名称(暂不支持) |
服务器下发给Portal用户的授权信息类型,包括ACL和User profile |
Portal授权信息的严格检查模式是否开启 |
IPv4 Portal的相关信息 |
IPv6 Portal的相关信息 |
接口上Portal认证的运行状态,包括以下取值: · Disabled:Portal认证未使能 · Enabled:Portal认证已使能 · Authorized:Portal认证服务器或者Portal Web服务器不可达,端口自动开放 |
· Direct:直接方式 · Redhcp:二次地址方式 · Layer3:可跨三层路由方式 |
接口上配置的Portal Web服务器的名称 |
接口上的Portal强制认证域 |
Pre-auth domain |
接口上的Portal认证前域,即Portal认证前用户使用的认证域,未指定则显示Not configured |
为认证前的Portal用户指定的IP地址池名称 |
发送给Portal认证服务器的Portal报文的BAS-IP属性 |
发送给Portal认证服务器的Portal报文的BAS-IPv6属性 |
接口上配置的用户在线状态探测配置,包括探测的方法(ARP、ICMP、ND、ICMPv6),探测周期和探测尝试次数,用户闲置的时间 |
· Server type:服务器类型,包括Portal server和Web server,分别表示Portal认证服务器和Portal Web服务器 · Server name:服务器名称 · Action:对应的接口根据服务器探测结果所采取的动作,为不需要认证(fail-permit) |
Portal源认证网段信息 |
Portal认证网段的IP地址 |
Portal认证网段的子网掩码 |
Portal IPv6认证网段的地址前缀长度 |
display portal packet statistics命令用来显示Portal认证服务器的报文统计信息,包括设备接收到Portal认证服务器发送的报文以及设备发送给该Portal认证服务器的报文的信息。
display portal packet statistics [ server server-name ]
server server-name:Portal认证服务器的名称,为1~32个字符的字符串,区分大小写。
若不指定参数server,则依次显示所有Portal认证服务器的报文统计信息。
# 显示名字为pts的Portal认证服务器的报文统计信息。
<Sysname> display portal packet statistics server pts
Portal server : pts
Invalid packets: 0
Pkt-Type Total Drops Errors
REQ_CHALLENGE 3 0 0
ACK_CHALLENGE 3 0 0
REQ_AUTH 3 0 0
ACK_AUTH 3 0 0
REQ_LOGOUT 1 0 0
ACK_LOGOUT 1 0 0
AFF_ACK_AUTH 3 0 0
NTF_LOGOUT 1 0 0
REQ_INFO 6 0 0
ACK_INFO 6 0 0
NTF_USERDISCOVER 0 0 0
NTF_USERIPCHANGE 0 0 0
AFF_NTF_USERIPCHAN 0 0 0
ACK_NTF_LOGOUT 1 0 0
NTF_USER_HEARTBEAT 2 0 0
ACK_NTF_USER_HEARTBEAT 0 0 0
NTF_CHALLENGE 0 0 0
NTF_USER_NOTIFY 0 0 0
AFF_NTF_USER_NOTIFY 0 0 0
表1-2 display portal server statistics命令显示信息描述表
Portal认证服务器名称 |
Portal认证服务器向接入设备发送的challenge请求报文 |
接入设备对Portal认证服务器challenge请求的响应报文 |
Portal认证服务器向接入设备发送的请求认证报文 |
接入设备对Portal认证服务器认证请求的响应报文 |
Portal认证服务器向接入设备发送的下线请求报文 |
接入设备对Portal认证服务器下线请求的响应报文 |
Portal认证服务器收到认证成功响应报文后向接入设备发送的确认报文 |
接入设备发送给Portal认证服务器,用户被强制下线的通知报文 |
Portal认证服务器向接入设备发送的发现新用户要求上线的通知报文 |
接入设备向Portal认证服务器发送的通知更改某个用户IP地址的通知报文 |
Portal认证服务器通知接入设备对用户表项的IP切换已成功报文 |
Portal认证服务器对强制下线通知的响应报文 |
接入设备收到的从Portal认证服务器发送的用户同步报文 |
接入设备向Portal认证服务器回应的用户同步响应报文 |
Portal认证服务器周期性向接入设备发送的服务器心跳报文 |
接入设备向Portal认证服务器发送的challenge请求报文 |
接入设备向Portal认证服务器发送的用户消息通知报文 |
Portal认证服务器向接入设备发送的对NTF_USER_NOTIFY的确认报文 |
· reset portal packet statistics
display portal rule命令用来显示指定接口上用于报文匹配的Portal过滤规则信息。
IRF模式:
all:显示所有Portal规则信息,包括动态Portal规则和静态Portal规则。
dynamic:显示动态Portal规则信息,即用户通过Portal认证后设备上产生的Portal规则,这类规则定义了允许指定源IP地址的报文通过接口。
static:显示静态Portal规则信息,即使能Portal后产生的Portal规则,这类规则定义了在Portal功能开启后对接口上收到的报文的过滤动作。
interface interface-type interface-number:显示指定接口的Portal规则信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板上的Portal规则信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的Portal规则信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有成员设备上的所有单板。(IRF模式)
# 显示接口GigabitEthernet3/1/1上所有Portal过滤规则的信息。
<Sysname> display portal rule all interface gigabitethernet 3/1/1
IPv4 portal rules on GigabitEthernet3/1/1:
Rule 1
Type : Static
Action : Permit
Protocol : Any
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : Any
MAC : 0000-0000-0000
Interface : GigabitEthernet3/1/1
VLAN : Any
Destination:
IP : 192.168.0.111
Mask : 255.255.255.255
Port : Any
Rule 2
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 2.2.2.2
MAC : 000d-88f8-0eab
VLAN : Any
Author ACL:
Number : 3001
Rule 3
Type : Static
Action : Redirect
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Protocol : TCP
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : 80
Rule 4:
Type : Static
Action : Deny
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
IPv6 portal rules on GigabitEthernet3/1/1:
Rule 1
Type : Static
Action : Permit
Protocol : Any
Status : Active
Source:
IP : ::
Prefix length : 0
Port : Any
VLAN : Any
Destination:
IP : 3000::1
Prefix length : 64
Port : Any
Rule 2
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 3000::1
MAC : 0015-e9a6-7cfe
VLAN : Any
Author ACL:
Number : 3001
Rule 3
Type : Static
Action : Redirect
Status : Active
Source:
IP : ::
Prefix length : 0
VLAN : Any
Protocol : TCP
Destination:
IP : ::
Prefix length : 0
Port : 80
Rule 4:
Type : Static
Action : Deny
Status : Active
Source:
IP : ::
Prefix length : 0
VLAN : Any
Destination:
IP : ::
Prefix length : 0
Author ACL:
Number : 3001
Rule 5:
Type : Static
Action : Match pre-auth ACL
Status : Active
Source:
Pre-auth ACL:
Number : 3002
表1-3 display portal rule命令显示信息描述表
Portal过滤规则编号。IPv4过滤规则和IPv6过滤规则分别编号 |
Portal过滤规则的类型,包括以下取值: · Static:静态类型 · Dynamic:动态类型 |
Portal过滤规则的匹配动作,包括以下取值: · Permit:允许报文通过 · Redirect:重定向报文 · Deny:拒绝报文通过 · Match pre-auth ACL:匹配认证前域中的授权ACL规则 |
Portal过滤规则的传输层协议,包括以下取值: · Any:不限制传输层协议类型 · TCP:TCP传输类型 · UDP:UDP传输类型 |
Portal过滤规则下发的状态,包括以下取值: · Active:表示规则已生效 · Unactuated:表示规则未生效 |
Portal过滤规则的源信息 |
源IP地址 |
源IPv4地址子网掩码 |
源IPv6地址前缀 |
源MAC地址 |
Portal过滤规则应用的二层或三层接口 |
源VLAN |
Portal规则的协议类型 |
Portal规则的目的信息 |
目的IP地址 |
目的IPv4地址子网掩码 |
目的IPv6地址前缀 |
Portal用户认证后的授权ACL,即AAA授权给用户的ACL,该字段仅在Type为Dynamic时显示 |
Pre-auth ACL |
Portal用户认证前的授权ACL,该字段仅在Action为Match pre-auth ACL时显示 |
授权ACL编号,N/A表示AAA未授权ACL |
display portal server命令用来显示Portal认证服务器信息。
display portal server [ server-name ]
若不指定参数server-name,则显示所有Portal认证服务器信息。
# 显示Portal认证服务器pts的信息。
<Sysname> display portal server pts
Portal server: pts
IP : 192.168.0.111
VPN instance : vpn1
Port : 50100
Server detection : Timeout 60s Action: log, trap
User synchronization : Timeout 200s
Status : Up
表1-4 display portal server命令显示信息描述表
Portal认证服务器名称 |
Portal认证服务器的IP地址 |
Portal认证服务器所属的MPLS L3VPN |
Portal认证服务器的监听端口 |
Portal认证服务器可达性探测功能的参数,包括超时时间(单位:秒),以及探测到服务器状态变化后触发的动作(暂仅支持log) |
Portal用户信息同步功能的参数,包括超时时间(单位:秒) |
Portal认证服务器当前状态,其取值如下: · N/A:服务器可达性探测功能未开启,可达状态未知 · Up:服务器可达性探测功能已开启,探测结果为该服务器当前可达 · Down:服务器可达性探测功能已开启,探测结果为该服务器当前不可达 |
· server-detect (portal server view)
display portal user命令用来显示Portal用户的信息。
pre-auth:显示Portal认证前用户信息。若不指定该参数,则显示Portal用户的信息。
all:显示所有Portal用户的信息。
interface interface-type interface-number:显示指定接口上的Portal用户信息。interface-type interface-number为接口类型和接口编号。
ip ipv4-address:显示指定IPv4地址的Portal用户信息。
ipv6 ipv6-address:显示指定IPv6地址的Portal用户信息。
Verbose:显示指定用户的详细信息。
# 显示所有Portal用户的信息。
<Sysname> display portal user all
Total portal users: 2
Username: abc
Portal server: pts
State: Online
VPN instance: --
MAC IP VLAN Interface
000d-88f8-0eab 2.2.2.2 -- GigabitEthernet3/1/1
Authorization information:
DHCP IP pool: N/A
User profile: abc(active)
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Username: def
Portal server: pts
State: Online
VPN instance: vpn1
000d-88f8-0eac 3.3.3.3 -- GigabitEthernet3/1/2
DHCP IP pool: N/A
User profile: N/A
ACL number: 3000 (active)
Inbound CAR: CIR 3072 bps PIR 3072 bps (active)
Outbound CAR: CIR 3072 bps PIR 3072 bps (active)
# 显示所有Portal认证前用户的信息。
<Sysname> display portal user pre-auth
Total portal pre-auth users: 2
000a-eb29-75f1 18.18.0.3 -- Route-Aggregation100
State: Online
VPN instance: N/A
User profile: quew (active)
000a-eb29-75f2 18.18.0.4 -- Route-Aggregation100
State: Online
VPN instance: N/A
# 显示IP地址为50.50.50.3的Portal用户的详细信息。
<Sysname>display portal user ip-address 50.50.50.3 verbose
Basic:
Current IP address: 50.50.50.3
Original IP address: 30.30.30.2
Username: user1@hrss
User ID: 0x28000002
Access interface: eth3/2/2
Service-VLAN/Customer-VLAN: -/-
MAC address: 0000-0000-0001
Domain: hrss
VPN instance: 123
Status: Online
Portal server: test
Portal authentication method: Direct
AAA:
Realtime accounting interval: 60s, retry times: 3
Idle-cut:180 sec, 10240 bytes
Session duration: 500 sec, remaining: 300 sec
Remaining traffic: 10240000 bytes
Login time: 2014-01-19 2:42:3 UTC
ITA policy name: test
IP pool: abc
ACL&QoS&Multicast:
Inbound CAR: CIR 64000bps PIR 640000bps (active)
Outbound CAR: CIR 64000bps PIR 640000bps (active)
ACL number: 3000(inactive)
User profile: portal (active)
Max multicast addresses: 4
Multicast address list: 1.2.3.1, 1.34.33.1, 3.123.123.3, 4.5.6.7
2.2.2.2, 3.3.3.3, 4.4.4.4
User group: N/A
Flow statistic:
Uplink packets/bytes: 7/546
Downlink packets/bytes: 0/0
ITA:
level-1 uplink packets/bytes: 4/32
downlink packets/bytes: 2/12
level-2 uplink packets/bytes: 0/0
downlink packets/bytes: 0/0
表1-5 display portal user命令显示信息描述表
总计的Portal用户数目 |
用户认证所使用的Portal认证服务器的名称 |
Portal用户的当前状态,包括以下取值: · Initialized:初始化完成后的待认证状态 · Authenticating:正在认证状态 · Authorizing:正在授权状态 · Online:在线状态 |
Portal用户所属的MPLS L3VPN。若用户属于公网,则显示为“--” |
Portal用户的授权ACL。若用户无授权ACL,则显示为“None” |
Portal用户的MAC地址 |
Portal用户的IP地址 |
Portal用户所在的VLAN |
Portal用户接入的接口 |
Portal用户的授权信息 |
Portal用户的授权地址池名字。若无授权地址池,则显示为N/A |
Portal用户的授权User Profile名称。若未授权User Profile,则显示为N/A。授权状态包括如下: · active:AAA授权User profile成功 · inactive:AAA授权User profile失败或者设备上不存在该User profile 需要注意的是,如果使能Portal功能的接口是全局接口(例如VLAN接口),显示的是主控板Portal用户的授权User Profile状态;如果使能Portal功能的接口是局部接口(例如以太网接口),显示的是该接口所在单板上Portal用户的授权User Profile状态 |
暂不支持 |
ACL number |
Portal用户的授权ACL。若无授权ACL,则显示为N/A。授权状态包括如下: · active:AAA授权ACL成功 · inactive:AAA授权ACL失败或者设备上不存在该ACL |
Inbound CAR |
授权的入方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。若未授权入方向CAR,则显示为N/A。授权状态包括如下: · active:授权的入方向CAR生效 · inactive:授权的入方向CAR不生效 |
Outbound CAR |
授权的出方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。若未授权出方向CAR,则显示为N/A。授权状态包括如下: · active:授权的出方向CAR生效 · inactive:授权的出方向CAR不生效 |
表1-6 display portal user verbose命令显示信息描述表
Current IP address |
用户当前的IP地址 |
Original IP address |
用户认证时的IP地址 |
Username |
用户认证上线的用户名 |
User ID |
用户ID |
Access interface |
用户接入的接口 |
Service-VLAN/Customer-VLAN |
用户接入的外层VLAN/内层VLAN |
MAC address |
用户MAC地址 |
Domain |
用户认证实际使用的域名 |
VPN instance |
用户接入的VPN实例名称 |
Status |
Portal用户的当前状态,包括以下取值: Authenticating:正在认证状态 Authorizing:正在授权状态 Waiting_SetRule:正在下发规则状态 Online:在线状态 Waiting_Traffic:正在等待用户流量状态 Stop Accounting:正在停止计费状态 Done:用户下线完成状态 |
Portal server |
Portal服务器名称 |
Portal authentication method |
用户接入的Portal使能方式,包括如下取值: Direct:直接方式 Re-Dhcp:二次地址方式 Layer3:三层方式 |
Realtime accounting interval |
实时计费时间间隔和重传次数,如果没有授权,显示为N/A |
Idle-cut |
授权的Idle-cut时间和流量,如果没有,显示为N/A |
Session duration |
授权的会话时间以及剩余的会话时间,如果没有,显示为N/A |
Remaining traffic |
授权的剩余流量,如果没有显示为N/A |
Login time |
用户接入的时间,即用户授权成功的时间,格式为设备时间,如:2023-1-19 2:42:30 UTC |
IP pool |
授权的DHCP地址池名称,如果没有,显示为N/A |
Inbound CAR |
Outbound CAR |
ACL number |
授权的ACL号,如果没有,显示为N/A,状态包括如下: · active:授权ACL生效 · inactive:授权ACL不生效 |
User profile |
Session group profile |
暂不支持 |
Max multicast addresses |
授权的可加入的最大受控组播个数 |
Multicast address list |
授权可加入的受控组播列表 |
User group |
Portal用户所属的用户组 |
Flow statistic |
Portal用户流量统计信息 |
Uplink packets/bytes |
上行流量包数/字节数 |
Downlink packets/bytes |
下行流量包数/字节数 |
level-n uplink packets/bytes |
ITA level-n的上行流量包数/字节数(n为1-8),如果未开启ITA特性,此处不显示 |
level-n downlink packets/bytes |
ITA level-n的下行流量包数/字节数(n为1-8),如果未开启ITA特性,此处不显示 |
display portal web-server命令用来显示Portal Web服务器信息。
display portal web-server [ server-name ]
server-name:Portal Web服务器的名称,为1~32个字符的字符串,区分大小写。
若不指定参数server-name,则显示所有Portal Web服务器信息。
# 显示Portal Web服务器wbs的信息。
<Sysname> display portal web-server wbs
Portal Web server: wbs
URL : http://www.test.com/portal
URL parameters : userurl=http://www.test.com/welcome
userip=source-address
VPN instance : Not configured
Server detection : Interval: 120s Attempts: 5 Action: log, trap
IPv4 status : Up
IPv6 status : N/A
表1-7 display portal web-server命令显示信息描述表
Portal Web服务器名称 |
Portal Web服务器的URL地址以及携带的参数 |
Portal Web服务器的URL携带的参数信息 |
Portal Web服务器所属的MPLS L3VPN实例名称 |
Portal Web服务器可达性探测功能的参数,包括探测间隔时间(单位:秒),探测尝试次数以及探测到服务器状态变化后的动作(暂仅支持log) |
IPv4/IPv6 status |
Portal web服务器当前状态,其取值如下: · N/A:服务器可达性探测功能未开启,可达状态未知 · Up:服务器可达性探测功能已开启,且探测结果为该服务器当前可达 · Down:服务器可达性探测功能已开启,且探测结果为该服务器当前不可达 |
· server-detect (portal web-server view)
display web-redirect rule命令用来显示指定接口上的Web重定向过滤规则信息。
display web-redirect rule interface interface-type interface-number [ slot slot-number ]
IRF设备:
interface interface-type interface-number:显示指定接口的Web重定向过滤规则信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板上指定接口的Web重定向过滤规则信息。slot slot-number表示单板所在槽位号。若不指定该参数,则显示主用主控板上的Web重定向过滤规则信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上指定接口的Web重定向过滤规则,chassis-number表示设备在IRF中的成员编号,slot slot-number表示单板所在槽位号。若不指定该参数,则显示全局主用主控板上的Web重定向过滤规则信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的所有Web重定向过滤规则。
<Sysname> display web-redirect rule interface gigabitethernet 3/1/1
IPv4 web-redirect rules on GigabitEthernet3/1/1:
Rule 1:
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 192.168.2.114
VLAN : Any
Rule 2:
Type : Static
Action : Redirect
Status : Active
Source:
VLAN : Any
Protocol : TCP
Destination:
Port : 80
IPv6 web-redirect rules on GigabitEthernet3/1/1:
Rule 1:
Type : Static
Action : Redirect
Status : Active
Source:
VLAN : Any
Protocol : TCP
Destination:
Port : 80
表1-8 display web-redirect rule命令显示信息描述表
Web重定向规则编号 |
Web重定向规则的类型,包括以下取值: · Static:静态类型。该类型的规则在Web重定向功能生效时生成 · Dynamic:动态类型。该类型的规则在用户访问重定向页面时生成 |
Web重定向规则的匹配动作,包括以下取值: · Permit:允许报文通过 · Redirect:重定向报文 |
Web重定向规则下发的状态,包括以下取值: · Active:表示规则已生效 · Deactive:表示规则未生效 |
Web重定向规则的源信息 |
源IP地址 |
源IPv4地址子网掩码 |
源IPv6地址前缀 |
源VLAN,如果未指定,显示为Any |
Web重定向规则的传输层协议类型,包括以下取值: · Any:不限制传输层协议类型 · TCP:TCP传输类型 |
Web重定向规则的目的信息 |
ip命令用来指定Portal认证服务器的IPv4地址。
undo ip命令用来删除指定的Portal认证服务器的IPv4地址。
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } key-string ]
没有指定Portal认证服务器的IPv4地址。
Portal认证服务器视图
ipv4-address:Portal认证服务器的IPv4地址。
vpn-instance vpn-instance-name:Portal认证服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示Portal认证服务器位于公网中。
key:与Portal认证服务器通信时使用的共享密钥。设备与Portal认证服务器交互的Portal报文中会携带一个在该共享密钥参与下生成的验证字,该验证字用于接受方校验收到的Portal报文的正确性。
cipher:表示以密文方式设置共享密钥。
simple:表示以明文方式设置共享密钥。
key-string:设置的明文密钥或密文密钥,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为33~117个字符的字符串。
· 一个Portal认证服务器对应一个IP地址,因此一个Portal认证服务器视图下只允许存在一个IP地址,后配置IP地址(无论IPv4或IPv6)会覆盖已配置的。
· 不同的Portal认证服务器不允许IP地址和VPN的配置都相同。
· 以明文或密文方式设置的共享密钥,均以密文的方式保存在配置文件中。
# 指定Portal认证服务器pts的IPv4地址为192.168.0.111、共享密钥为明文portal。
[Sysname] portal server pts
[Sysname-portal-server-pts] ip 192.168.0.111 key simple portal
ipv6命令用来指定Portal认证服务器的IPv6地址。
undo ipv6命令用来删除指定的Portal认证服务器的IPv6地址。
ipv6 ipv6-address [ vpn-instance vpn-instance-name] [ key { cipher | simple } key-string ]
没有指定Portal认证服务器的IPv6地址。
Portal认证服务器视图
ipv6-address:Portal认证服务器的IPv6地址。
key:与Portal认证服务器通信需要的共享密钥。设备与Portal认证服务器交互的Portal报文中会携带一个在该共享密钥参与下生成的验证字,该验证字用于接受方校验收到的Portal报文的正确性。
# 指定Portal认证服务器pts的IPv6地址为2000::1、共享密钥为明文portal。
[Sysname-portal-server-pts] ipv6 2000::1 key simple portal
port命令用来配置接入设备主动向Portal认证服务器发送Portal报文时使用的UDP端口号。
undo port命令用来恢复缺省情况。
接入设备主动发送Portal报文时使用的UDP端口号为50100。
Portal认证服务器视图
port-id:设备向Portal认证服务器主动发送Portal报文时使用的目的UDP端口号,取值范围为1~65534。
本命令配置的端口号要和Portal认证服务器上配置的监听Portal报文的端口号保持一致。
# 配置设备向Portal认证服务器pts主动发送Portal报文时使用的目的UDP端口号为50000。
[Sysname-portal-server-pts] port 50000
portal { bas-ip | bas-ipv6 }命令用来设置发送给Portal认证服务器的Portal报文中的BAS-IP或BAS-IPv6属性。
undo portal { bas-ip | bas-ipv6 }命令用来删除接口下指定的BAS-IP或BAS-IPv6属性。
portal { bas-ip ipv4-address | bas-ipv6 ipv6-address }
对于响应类报文IPv4 Portal报文中的BAS-IP属性为报文的源IP地址,IPv6 Portal报文中的BAS-IPv6属性为报文源IPv6地址。
对于通知类报文IPv4 Portal报文中的BAS-IP属性为出接口的IP地址,IPv6 Portal报文中的BAS-IPv6属性为出接口的IPv6地址。
三层以太网接口/三层以太网子接口/三层聚合接口/三层聚合子接口/VLAN接口视图
ipv4-address:接口发送Portal报文的BAS-IP属性值,应该为本机的地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6-address:接口发送Portal报文的BAS-IPv6属性值,应该为本机的地址,不能为多播地址、全0地址、本地链路地址。
· 设备上运行Portal协议2.0版本时,主动发送给Portal认证服务器的报文(例如强制用户下线报文)中必须携带BAS-IP属性。设备上运行Portal协议3.0版本时,主动发送给Portal认证服务器必须携带BAS-IP或者BAS-IPv6属性。
· 配置此命令后,设备主动发送的通知类Portal报文,其源IP地址为配置的BAS-IP,否则为Portal报文出接口IP地址。
· 接口上使能了二次地址分配认证方式的Portal认证时,如果Portal认证服务器上指定的设备IP不是Portal报文出接口IP地址,则必须通过本命令配置相应的BAS-IP或BAS-IPv6属性,使其值与Portal认证服务器上指定的设备IP一致,否则用户认证无法成功。
· 使用H3C iMC的Portal认证服务器的情况下,如果Portal服务器上指定的设备IP不是设备上Portal报文出接口的IP地址,则使能了Portal认证的接口上必须配置BAS-IP或者BAS-IPv6属性。
# 配置接口GigabitEthernet3/1/1发送Portal报文的BAS-IP属性值为2.2.2.2。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] portal bas-ip 2.2.2.2
· display portal interface
portal [ ipv6 ] apply web-server命令用来在接口上引用Portal Web服务器,设备会将Portal用户的HTTP请求报文重定向到该Web服务器。
undo portal [ ipv6 ] apply web-server命令用来取消接口上引用的Portal Web服务器。
portal [ ipv6 ] apply web-server server-name [ fail-permit ]
ipv6:表示IPv6 Portal Web服务器。若不指定该参数,则表示IPv4 Portal Web服务器。
server-name:被引用的Portal Web服务器的名字,为1~32个字符的字符串,区分大小写,且必须已经存在。
fail-permit:开启Portal Web服务器不可达时的Portal用户逃生功能,即设备探测到Portal Web服务器不可达时取消接口的控制功能,允许用户不经过Portal认证即可自由访问网络。
一个接口上可以同时使能IPv4 Portal认证和IPv6 Portal认证,因此也可以同时引用一个IPv4 Portal Web服务器和一个IPv6 Portal Web认证服务器。
如果接口上同时开启了Portal认证服务器逃生功能和Portal Web服务器逃生功能,则当任意一个服务器不可达时,即放开接口控制,当两个服务器均恢复可达性后,再重新启动Portal认证功能。
# 在接口GigabitEthernet3/1/1上引用名称为wbs的Portal Web服务器作为用户认证时使用的Web服务器。
[Sysname-GigabitEthernet3/1/1] portal apply web-server wbs
portal authorization strict-checking命令用来开启Portal授权信息的严格检查模式。
undo authorization strict-checking命令用来恢复缺省情况。
portal authorization { acl | user-profile } strict-checking
undo portal authorization { acl | user-profile } strict-checking
缺省为非严格检查授权信息模式,当服务器下发的授权ACL、User Profile在设备上不存在或者设备下发ACL、User Profile失败时,用户保持在线。
acl:表示开启对授权ACL的严格检查。
user-profile:表示开启对授权User Profile的严格检查。
接口上开启Portal授权信息的严格检查模式后,当服务器给用户下发的授权ACL、User Profile在设备上不存在或者设备下发ACL、User Profile失败时,设备将强制该用户下线。
可同时使能对授权ACL和授权User Profile的严格检查模式。若同时使能了对授权ACL和对授权User Profile的严格检查模式,则只要其中任意一个授权属性未通过严格授权检查,则用户就会下线。
# 在接口GigabitEthernet3/1/1上开启对授权ACL的严格检查模式。
[Sysname–GigabitEthernet3/1/1] portal authoriztion acl strict-checking
portal delete-user命令用来强制在线Portal用户下线。
ipv4-address:在线Portal用户的IPv4地址。
all:所有接口下的在线IPv4 Portal用户和IPv6 Portal用户。
interface interface-type interface-number:指定接口下的所有在线Portal用户,包括IPv4 Portal用户和IPv6 Portal用户。interface-type interface-number为接口类型和接口编号。
ipv6 ipv6-address:指定在线IPv6 Portal用户的地址。
# 强制IP地址为1.1.1.1的在线Portal用户下线。
[Sysname] portal delete-user 1.1.1.1
portal [ ipv6 ] domain命令用于指定Portal用户使用的认证域,使得所有从该接口上接入的Portal用户强制使用该认证域。
undo portal [ ipv6 ] domain命令用来删除指定的Portal用户使用的认证域。
portal [ ipv6 ] domain domain-name
未指定Portal用户使用的认证域。
ipv6:指定IPv6 Portal用户使用的认证域。若不指定本参数,则表示指定IPv4 Portal用户使用的认证域。
domain-name:ISP认证域名,为1~255个字符的字符串,不区分大小写。
· 接口上可以同时指定IPv4 Portal用户和IPv6 Portal用户的认证域。
· 如果不指定ipv6参数,则表示配置或者删除IPv4 Portal用户使用的认证域。
# 指定从接口GigabitEthernet3/1/1上接入的IPv4 Portal用户使用认证域为my-domain。
[Sysname–GigabitEthernet3/1/1] portal domain my-domain
portal [ ipv6 ] enable命令用来在接口上使能Portal认证,并指定认证方式。
undo portal [ ipv6 ] enable命令用来在指定接口上取消指定的Portal认证。
portal enable method { direct | layer3 | redhcp }
portal ipv6 enable method { direct | layer3 }
ipv6:表示IPv6 Portal认证。若不指定该参数,则表示IPv4 Portal认证。
method:认证方式。
· direct:直接认证方式。
· layer3:可跨三层认证方式。
· redhcp:二次地址分配认证方式。
· 使能IPv6 Portal功能之前,需要保证设备支持IPv6 ACL和IPv6转发功能。
· IPv6 Portal认证不支持二次地址分配方式。
· 为使接口上的Portal功能生效,使能Portal的接口不能加入聚合组。
· 允许在接口上同时使能IPv4 Portal认证和IPv6 Portal认证。
· Tunnel接口配置Portal功能不生效。
# 在接口GigabitEthernet3/1/1上使能IPv4 Portal认证,且指定为直接认证方式。
[Sysname-GigabitEthernet3/1/1] portal enable method direct
portal [ ipv6 ] fail-permit server命令用来开启Portal认证服务器不可达时的Portal用户逃生功能,即设备探测到Portal认证服务器不可达时取消接口的控制功能,允许用户不经过Portal认证即可自由访问网络。
undo portal [ ipv6] fail-permit server命令用来关闭指定的Portal认证服务器逃生功能。
portal [ ipv6 ] fail-permit server server-name
设备探测到Portal认证服务器不可达时,不允许Portal用户逃生。
ipv6:表示IPv6 Portal认证服务器。若不指定该参数,则表示IPv4 Portal认证服务器。
server-name:Portal认证服务器名称,为1~32个字符的字符串,区分大小写。
如果接口上同时开启了Portal认证服务器逃生功能和Portal Web服务器逃生功能,则当任意一个服务器不可达时,立即放开接口控制;当两个服务器均恢复可达后,再重新启动接口的Portal认证功能。重新启动接口的Portal认证功能之后,未通过认证的用户需要通过认证之后才能访问网络资源,已通过认证的用户可继续访问网络资源。
一个接口上,最多同时可以开启一个Portal认证服务器逃生功能和一个Portal Web服务器逃生功能,且新配置会覆盖原有的配置。
# 在接口GigabitEthernet3/1/1上启用Portal认证服务器pts1不可达时的Portal用户逃生功能。
[Sysname-GigabitEthernet3/1/1] portal fail-permit server pts1
portal free-rule命令用来配置基于IP地址的Portal免认证规则。
undo portal free-rule命令用来删除指定的或所有Portal免认证规则。
portal free-rule rule-number { destination ip { ip-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ip-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
undo portal free-rule { rule-number | all }
不存在基于IP地址的Portal免认证规则。
rule-number:免认证规则编号。
destination:指定目的信息。
source:指定源信息。
ip ip-address:免认证规则的IPv4地址。
{ mask-length | mask }:免认证规则的IP地址掩码。其中,mask-length为子网掩码长度,取值范围为0~32;mask为子网掩码,点分十进制格式。
ipv6 ipv6-address:免认证规则的IPv6地址。
prefix-length:免认证规则的IPv6地址前缀长度,取值范围为0~128。
ip any:任意IPv4地址。
ipv6 any:任意IPv6地址。
tcp tcp-port-number:免认证规则的TCP端口号,取值范围为0~65535。
udp udp-port-number:免认证规则的UDP端口号,取值范围为0~65535。
all:所有免认证规则。
interface interface-type interface-number:免认证规则生效的三层接口。
· 可以同时指定源和目的参数,或者仅指定其中一个参数,后者表示另外一个地址不受限制。
· 如果免认证规则中同时配置了源端口号和目的端口号,则要求源和目的端口号所属的传输层协议类型保持一致。
· 相同内容的免认证规则不能重复配置,否则提示免认证规则已存在或重复。
· 未指定三层接口的情况下,免认证规则对所有使能Portal的接口生效;指定三层接口的情况下,免认证规则只对指定的三层接口生效。
# 配置一条基于IPv4地址的Portal免认证规则:编号为1、源地址为10.10.10.1/24、目的地址为20.20.20.1、目的TCP端口号为23、生效接口为GigabitEthernet3/1/1。该规则表示在GigabitEthernet3/1/1接口上,10.10.10.1/24网段地址的用户不需要经过Portal认证即可以访问地址为20.20.20.1的主机在TCP端口23上提供的服务。
[Sysname] portal free-rule 1 destination ip 20.20.20.1 32 tcp 23 source ip 10.10.10.1 24 interface gigabitethernet 3/1/1
# 配置一条基于IPv6地址的Portal免认证规则:编号为2、源地址为2000::1/64、目的地址为2001::1、目的TCP端口号为23、生效接口为GigabitEthernet3/1/1。该规则表示在GigabitEthernet3/1/1接口上,2000::1/64网段地址的用户不需要经过Portal认证即可以访问目的地址为2001::1的主机在TCP端口23上提供的服务。
[Sysname] portal free-rule 2 destination ipv6 2001::1 128 tcp 23 source ip 2000::1 64 interface gigabitethernet 3/1/1
portal free-rule source命令用来配置基于源的Portal免认证规则,这里的源可以是源MAC地址、源接口或者源VLAN。
undo portal free-rule命令用来删除免认证规则。
没有配置基于源的Portal免认证规则。
interface interface-type interface-number:免认证规则的源接口。interface-type interface-number为接口类型和接口编号。
mac mac-address:免认证规则的源MAC地址,为H-H-H的形式。
vlan vlan-id:免认证规则的源VLAN编号。
all:所有免认证规则。
如果免认证规则中同时指定了源VLAN和二层源接口,则要求该接口属于对应的VLAN,否则该规则无效。
# 配置一条Portal免认证规则:编号为3、源MAC地址为1-1-1、源VLAN为VLAN 10。该规则表示MAC地址为1-1-1,属于VLAN 10的用户不需要经过Portal认证即可以访问网络资源。
[Sysname] portal free-rule 3 source mac 1-1-1 vlan 10
portal { ipv4-max-user | ipv6-max-user }命令用来配置每个接口下最大Portal用户数。
undo portal { ipv4-max-user | ipv6-max-user }命令用来恢复缺省情况。
portal { ipv4-max-user | ipv6-max-user } max-number
每个接口下最大Portal用户数不受限制。
max-number:每个接口下允许的最大IPv4或IPv6 Portal用户数,取值范围为1~4294967296。
如果接口上配置的Portal最大用户数小于当前接口上已经在线的Portal用户数,则该配置可以执行成功,且在线Portal用户不受影响,但系统将不允许新的Portal用户从该接口接入。
# 在接口GigabitEthernet3/1/1上配置最大IPv4 Portal用户数为100。
[Sysname-GigabitEthernet3/1/1] portal ipv4-max-user 100
portal ipv6 layer3 source命令用来配置IPv6 Portal源认证网段,即接口上只允许在源认证网段范围内的IPv6用户报文才能触发Portal认证,否则丢弃。
undo portal ipv6 layer3 source命令用来删除配置的IPv6 Portal源认证网段。
portal ipv6 layer3 source ipv6-network-address prefix-length
undo portal ipv6 layer3 source [ ipv6-network-address ]
没有配置IPv6 Portal源认证网段,表示对来自任意网段的IPv6用户都进行Portal认证。
ipv6-network-address:IPv6 Portal源认证网段地址。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
· 如果undo命令中不携带IP地址参数,则表示删除指定所有的IPv6 Portal源认证网段。
· 源认证网段仅对Portal的可跨三层认证方式(layer3)生效。
# 在接口GigabitEthernet3/1/1上配置一条IPv6 Portal源认证网段为1::1/16,仅允许来自1::1/16网段的用户触发Portal认证。
[Sysname–GigabitEthernet3/1/1] portal ipv6 layer3 source 1::1 16
portal ipv6 user-detect命令用来开启IPv6 Portal用户在线探测功能。
undo portal user-detect命令用来恢复缺省情况。
portal ipv6 user-detect type { nd | icmpv6 } [ retry retries ] [ interval interval ] [ idle time ]
接口上的IPv6 Portal用户在线探测功能处于关闭状态。
type:指定探测类型。
· nd:表示探测类型为ND。
· icmpv6:表示探测类型为ICMPv6。
retry retries:探测次数,取值范围为1~10,缺省3次。
interval interval:探测间隔,取值范围为1~1200,单位为秒,缺省3秒。
idle time:用户在线探测闲置时长,即闲置多长时间后发起探测,取值范围为60~3600,单位为秒,缺省180秒。
¡ 当探测类型为ICMPv6时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户定期(interval interval)发送探测报文。如果在指定探测次数(retry retries)之内,设备收到了该用户的响应报文,则认为用户在线,且停止发送探测报文,重复这个过程,否则,强制其下线。
¡ 当探测类型为ND时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户发送ND请求报文。设备定期(interval interval)检测用户ND表项是否被刷新过,如果在指定探测次数(retry retries)内用户ND表项被刷新过,则认为用户在线,且停止检测用户ND表项,重复这个过程,否则,强制其下线。
· 请根据配置的认证方式选择合适的探测方法,如果配置了直接方式或者二次地址分配方式,则可以使用ND或ICMPv6探测方式,如果配置了可跨三层认证方式,则可以使用ICMPv6探测方式,若配置了ND探测方式,则探测功能不生效。
· 如果用户接入设备上配置了阻止ICMPv6报文的防火墙策略,则接口上的ICMPv6探测方式可能会失败,从而导致接口上的Portal用户非正常下线。因此,若接口上需要使用ICMPv6探测方式,请保证用户接入设备不会过滤掉ICMPv6报文。
# 在接口GigabitEthernet3/1/1上开启IPv6 Portal用户在线探测功能:探测类型为ICMPv6,发送探测报文的次数为5次,发送间隔为10秒,闲置时间为300秒。
[Sysname–GigabitEthernet3/1/1] portal ipv6 user-detect type icmpv6 retry 5 interval 10 idle 300
portal layer3 source命令用来配置IPv4 Portal源认证网段,即接口上只允许在源认证网段范围内的IPv4用户报文才能触发Portal认证,否则丢弃。
undo portal layer3 source命令用来删除配置的IPv4 Portal源认证网段。
portal layer3 source ipv4-network-address { mask-length | mask }
undo portal layer3 source [ ipv4-network-address ]
没有配置IPv4 Portal源认证网段,表示对来自任意网段的IPv4用户都进行Portal认证。
ipv4-network-address:IPv4 Portal认证网段地址。
mask-length:子网掩码长度,取值范围为0~32。
mask:子网掩码,点分十进制格式。
· 如果undo命令中不携带IP地址参数,则表示删除指定所有的IPv4 Portal源认证网段。
# 在接口GigabitEthernet3/1/1上配置一条IPv4 Portal源认证网段为10.10.10.0/24,仅允许来自10.10.10.0/24网段的用户触发Portal认证。
[Sysname–GigabitEthernet3/1/1] portal layer3 source 10.10.10.0 24
portal max-user命令用来配置全局Portal最大用户数。
undo portal max-user命令用来恢复缺省情况。
全局Portal最大用户数不受限制。
max-number:系统中允许同时在线的最大Portal用户数。该参数的取值范围为1~4294967295。
· 如果配置的全局Portal最大用户数小于当前已经在线的Portal用户数,则该命令可以执行成功,且在线Portal用户不受影响,但系统将不允许新的Portal用户接入。
· 该命令指定的最大用户数是指IPv4 Portal和IPv6 Portal用户的总数。
· 建议所有使能Portal的接口上的最大IPv4 Portal用户数和最大IPv6 Portal用户数之和不超过全局最大Portal用户数配置为,否则会有部分Portal用户因为全局最大用户数已达到而无法上线。
# 配置全局Portal最大用户数为100。
[Sysname] portal max-user 100
· display portal user
· portal { ipv4-max-user | ipv6-max-user }
portal nas-port-id format命令用来配置NAS-Port-ID属性的格式。
undo portal nas-port-id format命令用来恢复缺省情况。
portal nas-port-id format { 1 | 2 | 3 | 4 }
NAS-Port-ID的消息格式为格式2。
1:表示格式1,具体为{atm|eth|trunk}NAS_slot/NAS_subslot/NAS_port:XPI.XCI AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port[:ANI_XPI.ANI_XCI]。
2:表示格式2,具体为SlotID/00/IfNO/VlanID。
3:表示格式3,具体为在格式2的内容后面添加Option82或者Option18。
4:表示格式4,具体为“slot=**;subslot=**;port=**;vlanid=**;vlanid2=**;”。
可通过本命令修改设备为Portal用户发送的RADIUS报文中填充的NAS-Port-ID属性的格式。
不同厂商的RADIUS服务器要求不同的格式,通常中国电信的RADIUS服务器要求采用格式1。
· {atm|eth|trunk}:BRAS端口类型,包括ATM接口、以太接口或trunk类型的以太网接口。
· NAS_slot:BRAS槽号,取值为0~31。
· NAS_subslot:BRAS子槽号,取值为0~31。
· NAS_Port:BRAS端口号,取值为0~63。
· XPI:如果接口类型为atm,则XPI对应VPI,取值为0~255;如果接口类型为eth或trunk,则XPI对应PVLAN,XPI取值为0~4095。
· XCI:如果接口类型为atm,则XCI对应VCI,取值为0~65535;如果接口类型为eth或trunk,XCI对应于CVLAN,XCI取值为0~4095。
· AccessNodeIdentifier:接入节点标识(例如DSLAM设备),为不超过50个字符的字符串,字符串中不能包括空格。
· ANI_rack:接入节点机架号(如支持紧耦合的DSLAM设备),取值为0~15。
· ANI_frame:接入节点机框号,取值为0~31。
· ANI_slot:接入节点槽号,取值为0~127。
· ANI_subslot:接入节点子槽号,取值为0~31。
· ANI_port:接入节点端口号,取值为0~255。
· ANI_XPI.ANI_XCI:可选项,主要用于携带CPE侧的业务信息,可用于标识未来的业务类型需求,如在多PVC应用场合下可标识具体的业务。其中,如果接口类型为atm,则ANI_XPI对应VPI,取值为0~255,ANI_XCII对应VCI,取值为0~65535;如果接口类型为eth或trunk,则ANI_XPI对应PVLAN,取值为0~4095,则ANI_XCI对应CVLAN,取值为0~4095。
· 字符串之间用一个空格隔开,要求字符串中间不能有空格。花括号中的内容是必选的,|表示并列的关系,多选一。[]表示可选项。对于某些设备没有机架、框、子槽的概念,相应位置应统一填0,对于无效的VLAN ID值都填4096。
· 如接口类型为ATM,则AccessNodeIdentifier、ANI_rack、ANI_frame、ANI_slot、ANI_subslot、ANI_port域可统一填0。
· 如运营商未使用SVLAN技术,则XPI=4096,XCI=VLAN,取值为0~4095。
· 如运营商未使用VLAN技术区分用户(用户PC直连BAS端口),则XPI=4096,XCI=4096。
· 对于接入节点设备(如DSLAM),按如上格式上报本接入节点的接入线路信息,对于与BRAS设备相关的接入线路信息可统一填0,如:
“0 0/0/0:4096.1234 guangzhou003/1/31/63/31/127”
其含义是DSLAM节点标识为guangzhou001、DSLAM的机架号为0(没有机架)、DSLAM的框号为31、DSLAM的槽号为63、DSLAM的子槽号为31、DSLAM的端口号为127、VLAN ID号为1234,BRAS接入线路信息为未知。
· 对于BRAS设备,在获取接入节点设备(如DSLAM)的接入线路信息后,根据BRAS的配置可透传接入线路信息,也可修改添加接入线路信息中与BRAS设备相关的线路信息,形成完整的接入线路信息,如:
“eth 31/31/7:4096.1234 guangzhou003/1/31/63/31/127”。
· 例1:NAS_PORT_ID =“atm 31/31/7:255.65535 0/0/0/0/0/0”
含义:BRAS设备的用户接口类型为ATM接口,BRAS槽号为31,BRAS子槽号为31,BRAS端口号为7,VPI为255,VCI为65535。
· 例2:NAS_PORT_ID =“eth 31/31/7:1234.2345 0/0/0/0/0/0”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31,BRAS端口号为7,PVLAN ID为1234,CVLAN ID为2345。
· 例3:NAS_PORT_ID =“eth 31/31/7:4096.2345 0/0/0/0/0/0”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31,BRAS端口号为7,VLAN ID为2345。
· 例4:NAS_PORT_ID =“eth 31/31/7:4096.2345 guangzhou001/1/31/63/31/127”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31, BRAS端口号为7,VLAN ID为2345,接入节点DSLAM的标识为guangzhou001,DSLAM的机架号为1,DSLAM的框号为31,DSLAM的槽号为63,DSLAM的子槽号为31,DSLAM的端口号为127。
· SlotID:用户接入的槽位号,为两个字符的字符串。
· IFNO:用户接入的接口编号,为3个字符的字符串。
· VlanID:用户接入的VLAN ID,为9个字符的字符串。
其格式为在格式2的NAS-Port-ID内容后面添加用户DHCP报文中指定Option的内容:
· 对于IPv4用户,此处添加的是DHCP Option82的内容。
· 对于IPv6用户,此处添加的是DHCP Option18的内容。
格式为“slot=**;subslot=**;port=**;vlanid=**;vlanid2=**;”,具体情况如下:
· 对于非VLAN接口,其格式为“slot=**;subslot=**;port=**;vlanid=0;”。
· 对于只终结了一层VLAN Tag的接口,其格式为“slot=**;subslot=**;port=**;vlanid=**;”。
# 配置NAS-Port-ID属性的格式为format 1。
[Sysname] portal nas-port-id format 1
portal [ ipv6 ] pre-auth domain命令用来在接口上配置Portal认证前用户使用的认证域。
undo portal [ ipv6 ] pre-auth domain命令用来删除接口上Portal认证前用户使用的认证域。
portal [ ipv6 ] pre-auth domain domain-name
接口上未配置Portal认证前用户使用的认证域。
context-admin
ipv6:指定IPv6用户使用的认证域。若不指定该参数,则表示指定IPv4用户使用的认证域。
domain-name:ISP认证域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符。
使能Portal的接口上配置了认证前使用的认证域(简称为认证前域)时,在此接口上获取到IP地址的用户将被Portal授予指定认证前域内配置的相关授权属性(目前包括ACL、User Profile和CAR),并根据授权信息获得相应的网络访问权限。若此用户后续触发了Portal认证,则认证成功之后会被AAA下发新的授权信息。用户下线之后,将被重新授予该认证前域中的授权属性。
认证前域的配置只对采用DHCP或DHCPv6分配IP地址的用户生效。
如果认证前域的域名发生变化,新的域名对所有认证前用户生效。
在三层以太网接口、三层以太网子接口、三层聚合接口或三层聚合子接口上配置Portal认证前用户使用的认证域时,如果当前认证前域中的ACL授权配置发生变化,该域中的新授权配置对已经存在和新生成的认证前用户均生效。
在VLAN接口上配置Portal认证前用户使用的认证域,如果当前认证前域中的ACL授权配置发生变化,该域中的新授权配置只对新生成的认证前用户生效。已存在的认证前用户继续使用旧配置。
如果当前认证前域中的User Profile和CAR授权配置发生变化,则新配置仅对新生成的认证前用户生效,已经存在的用户继续使用旧配置。
· 配置Portal认证前域时,请确保被引用的ISP域已创建。如果Portal认证前域引用的ISP域不存在或者引用过程中该ISP域被删除,创建该域后,请删除Portal认证前域(配置undo portal [ ipv6 ] pre-auth domain命令)后重新配置。
· 若认证前域中指定的授权ACL不存在,或者ACL中无任何规则,则表示不对用户的访问进行限制;若认证前域中指定的ACL中存在匹配源IP地址、匹配源MAC地址、匹配所有IP地址或匹配所有IPv6地址的规则,则该授权ACL下发后将会导致用户不能正常上线和下线。
# 在接口GigabitEthernet3/1/1上配置Portal认证前用户使用的认证域为abc。
[Sysname-GigabitEthernet3/1/1] portal pre-auth domain abc
portal [ ipv6 ] pre-auth ip-pool命令用来配置Portal认证前用户使用的地址池。
undo portal [ ipv6 ] pre-auth ip-pool命令用来恢复缺省情况。
portal [ ipv6 ] pre-auth ip-pool pool-name
接口上未配置Portal认证前用户使用的地址池。
ipv6:表示IPv6 Portal用户。若不指定该参数,则表示IPv4 Portal用户。
pool-name:表示IP地址池的名字,为1~63个字符的字符串,不区分大小写。
在Portal用户通过设备的子接口接入网络的组网环境中,当子接口上未配置IP地址,且用户需要通过DHCP获取地址时,就必须通过本命令指定一个地址池,并在用户进行Portal认证之前为其分配一个IP地址使其可以进行Portal认证。
· 仅当接口使用直接认证方式的情况下,接口上为认证前的Portal用户指定的IP地址池才能生效。
· 当使用接口上指定的IP地址池为认证前的Portal用户分配IP地址时,该指定的IP地址池必须存在且配置完整,否则无法为Portal用户分配IP地址,并导致用户无法进行Portal认证。
# 在接口GigabitEthernet3/1/1上为认证前的Portal用户指定IPv4地址池为abc。
[Sysname-GigabitEthernet3/1/1] portal pre-auth ip-pool abc
· dhcp server ip-pool(三层技术-IP业务/DHCP)
· ipv6 dhcp pool(三层技术-IP业务/DHCP)
portal roaming enable命令用来使能Portal用户漫游功能。
undo portal roaming enable命令用来关闭Portal用户漫游功能。
Portal用户漫游功能处于关闭状态,即Portal用户上线后不能在所在的VLAN内漫游。
· 该命令只对通过VLAN接口上线的Portal用户有效。
· 如果使能了Portal用户漫游功能,则Portal用户上线后可以在使能Portal的VLAN内漫游,即用户通过VLAN内的任何二层端口都可以访问网络资源;否则用户只能通过认证成功的二层端口访问网络资源。
· 设备上有用户在线或认证前域用户的情况下,不能配置此命令。
# 使能Portal用户漫游功能。
[Sysname] portal roaming enable
portal server命令用来创建Portal认证服务器,并进入Portal认证服务器视图。
undo portal server命令用来删除指定的Portal认证服务器。
undo portal server server-name
没有配置任何Portal认证服务器。
Portal认证服务器视图用于配置Portal认证服务器的相关参数,包括服务器的IP地址、端口号,服务器所在的VPN实例,设备和服务器间通信的预共享密钥,服务器探测功能等。
可以配置多个Portal认证服务器。
# 创建名称为pts的Portal认证服务器,并进入Portal认证服务器视图。
portal user-detect命令用来开启IPv4 Portal用户在线探测功能。
portal user-detect type { arp | icmp } [ retry retries] [ interval interval ] [ idle time ]
接口上的IPv4 Portal用户在线探测功能处于关闭状态。
type:指定探测类型。
· arp:表示探测类型为ARP。
· icmp:表示探测类型为ICMP。
¡ 当探测类型为ICMP时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户定期(interval interval)发送探测报文。如果在指定探测次数(retry retries)之内,设备收到了该用户的响应报文,则认为用户在线,且停止发送探测报文,重复这个过程,否则,强制其下线。
¡ 当探测类型为ARP时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户发送ARP请求报文。设备定期(interval interval)检测用户ARP表项是否被刷新过,如果在指定探测次数(retry retries)内用户ARP表项被刷新过,则认为用户在线,且停止检测用户ARP表项,重复这个过程,否则,强制其下线。
· 请根据配置的认证方式选择合适的探测方法,如果配置了直接方式或者二次地址分配方式,则可以使用ARP或ICMP探测方式,如果配置了可跨三层认证方式,则仅可以使用ICMP探测方式,若配置了ARP探测方式,则探测功能不生效。
· 如果用户接入设备上配置了阻止ICMP报文的防火墙策略,则接口上的ICMP探测方式可能会失败,从而导致接口上的Portal用户非正常下线。因此,若接口上需要使用ICMP探测方式,请保证用户接入设备不会过滤掉ICMP报文。
# 在接口GigabitEthernet3/1/1上开启Portal用户在线探测功能:探测类型为ICMP,发送探测报文的次数为5次,发送间隔为10秒,闲置时间为300秒。
[Sysname–GigabitEthernet3/1/1] portal user-detect type icmp retry 5 interval 10 idle 300
portal web-server命令用来创建Portal Web服务器,并进入Portal Web服务器视图。
undo portal web-server命令用来删除Portal Web服务器。
undo portal web-server server-name
没有配置任何Portal Web服务器。
Portal Web服务器是指Portal认证过程中向用户推送认证页面的Web服务器,也是设备强制重定向用户HTTP请求报文时所指的Web服务器。Portal Web服务器视图用于配置该Web服务器的URL地址及配置设备重定向该URL地址给用户时URL地址所携带的参数,同时该视图还用于配置Portal Web服务器探测等功能。
# 创建名称为wbs的Portal Web服务器,并进入Portal Web服务器视图。
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs]
· portal apply web-server
reset portal packet statistics命令用来清除Portal报文的统计信息。
reset portal packet statistics [ server server-name ]
若不指定参数server,则清除所有Portal认证服务器的报文统计信息。
# 清除名字为st上的Portal认证服务器的统计信息。
<Sysname> reset portal packet statistics server pts
· display portal packet statistics
server-detect命令用来开启Portal认证服务器的可达性探测功能。开启Portal认证服务器的可达性探测功能后,设备会定期检测Portal认证服务器发送的Portal报文来判断服务器的可达状态。
undo server-detect命令用来恢复缺省情况。
server-detect [ timeout timeout ] { log | trap } *
Portal认证服务器的可达性探测功能处于关闭状态。
Portal认证服务器视图
timeout timeout:探测超时时间,取值范围10~3600,单位为秒,缺省值为60。
{ log | trap } *:设备探测到Portal认证服务器可达状态变化时,触发执行的操作。包括以下两种,且可同时选择多种。
· log:Portal认证服务器可达或者不可达的状态改变时,发送日志信息。日志信息中记录了Portal认证服务器名以及该服务器状态改变前后的状态。
· trap:Portal认证服务器可达或者不可达的状态改变时,向网管服务器发送Trap信息。Trap信息中记录了Portal认证服务器名以及该服务器的当前状态。本参数配置后不生效。
只有在支持Portal服务器心跳功能(目前仅iMC的Portal认证服务器支持)的Portal认证服务器的配合下,本功能才有效。
若设备在指定的探测超时时间(timeout timeout)内收到Portal报文,且验证其正确,则认为此次探测成功且服务器可达,否则认为此次服务器不可达。
# 开启对Portal认证服务器pts的探测功能,探测超时时间为600秒,若服务器状态改变,则发送日志信息。
[Sysname-portal-server-pts] server-detect timeout 600 log
server-detect命令用来开启Portal Web服务器的可达性探测功能。
server-detect [ interval interval ] [ retry retries ] { log | trap } *
当前Portal Web服务器的可达性探测功能处于关闭状态。
Portal Web服务器视图
interval interval:进行探测尝试的时间间隔,取值范围为10~1200,单位为秒,缺省值为20。
retry retries:连续探测失败的最大次数,取值范围为1~10,缺省值为3。若连续探测失败数目达到此值,则认为服务器不可达。
{ log | trap } *:Portal Web服务器可达状态的变化时,可触发执行的操作。包括以下两种,且可同时选择多种。
· log:Portal Web服务器可达或者不可达的状态改变时,发送日志信息。日志信息中记录了Portal Web服务器名以及该服务器状态改变前后的状态。
· trap:Portal Web服务器可达或者不可达的状态改变时,向网管服务器发送Trap信息。Trap信息中记录了Portal Web服务器名以及该服务器的当前状态。本参数配置后不生效。
该探测方法可由设备独立完成,不需要Portal Web服务器端的任何配置来配合。
# 配置对Portal Web服务器wbs的探测功能,每次探测间隔时间为600秒,若连续二次探测均失败,则发送服务器不可达的日志信息。
[Sysname-portal-websvr-wbs] server-detect interval 600 retry 2 log
url命令用来指定Portal Web服务器的URL。
undo url命令用来删除指定的Portal Web服务器的URL。
没有指定Portal Web服务器的URL。
Portal Web服务器视图
url-string:Portal Web服务器的URL,为1~256个字符的字符串,区分大小写。
本命令指定的URL是可用标准HTTP或者HTTPS协议访问的URL,它以http://或者https://开头。如果该URL未以http://或者https://开头,则缺省认为是以http://开头。
# 配置Portal Web服务器wbs的URL为http://www.test.com/portal。
[Sysname-portal-websvr-wbs] url http://www.test.com/portal
url-parameter命令用来配置设备重定向给用户的Portal Web服务器的URL中携带的参数信息。
undo url-parameter命令用来删除配置的Portal Web服务器URL携带的参数信息。
url-parameter param-name { original-url | source-address | source-mac | value expression }
未配置设备重定向给用户的Portal Web服务器的URL中携带的参数信息。
Portal Web服务器视图
param-name:URL参数名,为1~32个字符的字符串,区分大小写。URL参数名对应的参数内容由param-name后的参数指定。
original-url:用户初始访问的Web页面的URL。
source-address:用户的IP地址。
source-mac:用户的MAC地址。
value expression:自定义字符串,为1~256个字符的字符串,区分大小写。
对于同一个参数名param-name后的参数设置,最后配置的生效。
该命令用于配置用户访问Portal Web服务器时,要求携带的一些参数,比较常用的是要求携带用户的IP地址、MAC地址、用户原始访问的URL信息。用户也可以手工指定,携带一些特定的字符信息。配置完成后,在设备给用户强制重定向URL时会携带这些参数,例如配置Portal Web服务器的URL为:http://www.test.com/portal,若同时配置如下两个参数信息:url-parameter userip source-address和url-parameter userurl value http://www.test.com/welcome,则设备给源IP为1.1.1.1的用户重定向时回应的URL格式即为:http://www.test.com/portal?userip=1.1.1.1&userurl= http://www.test.com/welcome。
param-name这个URL参数名必须与具体应用环境中的Portal服务器所支持的URL参数名保持一致,不同的Portal服务器支持URL参数名是不一样的,请根据具体情况配置URL参数名。
例如H3C公司的iMC服务器支持的URL参数名如下:
· userurl:表示original-url
· userip:表示source-address
· usermac:表示source-mac
在Portal服务器为H3C公司的iMC服务器的组网环境中,如果设备重定向给用户的Portal Web服务器的URL中需要携带用户的IP地址参数信息时,必须把param-name参数配置成userip,否则,iMC服务器不能识别用户的IP地址。
# 为设备重定向给用户的Portal Web服务器wbs的URL中配置两个参数userip和userurl,其值分别为用户IP地址和自定义字符串http://www.test.com/welcome。
[Sysname-portal-websvr-wbs] url-parameter userip source-address
[Sysname-portal-websvr-wbs] url-parameter userurl value http://www.test.com/welcome
user-sync命令用来配置开启Portal用户信息同步功能。配置此功能后,设备会响应并周期性地检测指定的Portal认证服务器发来的用户同步报文,以保持设备与该服务器上在线用户信息的一致性。
undo user-sync命令用来恢复缺省情况。
当前Portal认证服务器的Portal用户信息同步功能处于关闭状态。
Portal认证服务器视图
timeout timeout:检测用户同步报文的时间间隔,取值范围为60~18000,单位为秒,缺省值为1200。
· 只有在支持Portal用户心跳功能(目前仅iMC的Portal认证服务器支持)的Portal认证服务器的配合下,本功能才有效。为了实现该功能,还需要在Portal认证服务器上选择支持用户心跳功能,且服务器上配置的用户心跳间隔要小于等于设备上配置的检测超时时间。
· 在设备上删除Portal认证服务器时将会同时删除该服务器的用户信息同步功能配置。
· 对同一服务器多次执行用户信息同步功能的配置时,新的配置将覆盖原有的配置。
· 对于设备上多余的用户信息,即在检测用户同步报文的时间间隔timeout到达后被判定为Portal认证服务器上已不存在的用户信息,设备会在timeout后的某时刻将其删除掉。
· 如果服务器同步过来的用户信息在设备上不存在,则设备会将这些用户的IP地址封装在用户心跳回应报文中发送给服务器,由服务器删除多余的用户。
# 配置对Portal认证服务器pts的Portal用户信息同步功能,检测用户同步报文的时间间隔为600秒,如果设备中的某用户信息在600秒内未在该Portal认证服务器发送的同步报文中出现,设备将强制该用户下线。
[Sysname-portal-server-pts] user-sync timeout 600
vpn-instance命令用来配置Portal Web服务器所属的VPN。
undo vpn-instance命令用来取消配置的Portal Web服务器所属的VPN。
Portal Web服务器位于公网中。
Portal Web服务器视图
vpn-instance-name:Portal Web服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
一个Portal Web服务器只能属于一个VPN。
# 配置Portal Web服务器wbs所属的VPN为abc。
[Sysname-portal-websvr-wbs] vpn-instance abc
web-redirect url命令用来配置Web重定向功能。
undo web-redirect命令用来关闭Web重定向功能。
web-redirect [ ipv6 ] url url-string [ interval interval ]
Web重定功能处于关闭状态。
ipv6:表示IPv6 Web重定向功能。若不指定该参数,则表示IPv4 Web重定向功能。
url url-string:Web重定向的地址,即用户的Web访问请求被重定向的URL地址,为1~256个字符的字符串,必须是以http://或者https://开头的完整URL路径。
interval interval:对用户访问的Web页面进行重定向的周期,取值范围为60~86400,单位为秒,缺省为86400秒。
接口上配置了Web重定向功能后,当该接口上接入的用户初次通过Web页面访问外网时,设备会将用户的初始访问页面重定向到指定的URL页面,之后用户才可以正常访问外网,经过一定时长(interval)后,设备又可以对用户要访问的网页或者正在访问的网页重定向到指定的URL页面。
接口下同时开启Web重定向功能和Portal功能时,Web重定向功能失效。
需要注意的是,Web重定向功能仅对使用默认端口号80的HTTP/HTTPS协议报文生效。
# 在接口GigabitEthernet3/1/1上配置IPv4 Web重定向功能:Web重定向地址为http://192.0.0.1,Web重定向周期为3600秒。
[Sysname-GigabitEthernet3/1/1] web-redirect url http://192.0.0.1 interval 3600
