12-IPv6 PIM命令
本章节下载: 12-IPv6 PIM命令 (282.51 KB)
1.1.1 anycast-rp (IPv6 PIM view)
1.1.2 bsm-fragment enable (IPv6 PIM view)
1.1.3 bsr-policy (IPv6 PIM view)
1.1.6 crp-policy (IPv6 PIM view)
1.1.7 display ipv6 pim bsr-info
1.1.8 display ipv6 pim claimed-route
1.1.10 display ipv6 pim interface
1.1.11 display ipv6 pim neighbor
1.1.12 display ipv6 pim routing-table
1.1.13 display ipv6 pim rp-info
1.1.14 display ipv6 pim statistics
1.1.15 hello-option dr-priority (IPv6 PIM view)
1.1.16 hello-option holdtime (IPv6 PIM view)
1.1.17 hello-option lan-delay (IPv6 PIM view)
1.1.18 hello-option neighbor-tracking (IPv6 PIM view)
1.1.19 hello-option override-interval (IPv6 PIM view)
1.1.20 holdtime join-prune (IPv6 PIM view)
1.1.25 ipv6 pim hello-option dr-priority
1.1.26 ipv6 pim hello-option holdtime
1.1.27 ipv6 pim hello-option lan-delay
1.1.28 ipv6 pim hello-option neighbor-tracking
1.1.29 ipv6 pim hello-option override-interval
1.1.30 ipv6 pim holdtime join-prune
1.1.31 ipv6 pim neighbor-policy
1.1.34 ipv6 pim state-refresh-capable
1.1.35 ipv6 pim timer graft-retry
1.1.37 ipv6 pim timer join-prune
1.1.38 ipv6 pim triggered-hello-delay
1.1.39 jp-pkt-size (IPv6 PIM view)
1.1.40 register-policy (IPv6 PIM view)
1.1.41 register-suppression-timeout (IPv6 PIM view)
1.1.42 register-whole-checksum (IPv6 PIM view)
1.1.43 snmp-agent trap enable pim6
1.1.44 source-lifetime (IPv6 PIM view)
1.1.45 source-policy (IPv6 PIM view)
1.1.46 spt-switch-threshold (IPv6 PIM view)
1.1.47 ssm-policy (IPv6 PIM view)
1.1.48 state-refresh-hoplimit (IPv6 PIM view)
1.1.49 state-refresh-interval (IPv6 PIM view)
1.1.50 state-refresh-rate-limit (IPv6 PIM view)
1.1.51 static-rp (IPv6 PIM view)
1.1.52 timer hello (IPv6 PIM view)
1.1.53 timer join-prune (IPv6 PIM view)
anycast-rp命令用来配置Anycast-RP。
undo anycast-rp命令用来删除Anycast-RP。
anycast-rp ipv6-anycast-rp-address ipv6-member-address
undo anycast-rp ipv6-anycast-rp-address ipv6-member-address
IPv6 PIM视图
ipv6-anycast-rp-address:指定Anycast-RP地址。必须是合法的IPv6全球单播地址。
ipv6-member-address:指定Anycast-RP成员地址。必须是合法的IPv6全球单播地址,不能与ipv6-anycast-rp-address相同。
本命令可重复配置,配置时如果指定了相同的Anycast-RP地址,则将Anycast-RP成员地址添加到该Anycast-RP地址所属的Anycast-RP集中。
# 在公网实例中配置如下Anycast-RP集:Anycast-RP地址为1:1::0,两个成员的地址分别为1:1::1和1:2::1(前者为本地接口LoopBack1的地址)。
[Sysname] ipv6 pim
[Sysname-pim6] anycast-rp 1:1::0 1:1::1
[Sysname-pim6] anycast-rp 1:1::0 1:2::1
· display ipv6 pim rp-info
bsm-fragment enable命令用来使能自举报文语义分片功能。
undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
IPv6 PIM视图
当IPv6 PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-fragment enable
bsr-policy命令用来配置合法的BSR地址范围,以防止BSR欺骗。
undo bsr-policy命令用来取消BSR地址范围的限制。
BSR的地址范围不受任何限制,即认为来自任意源的自举报文都是合法的。
IPv6 PIM视图
acl6-number:指定IPv6基本ACL的编号,取值范围为2000~2999。
ACL规则中的source参数用来指定合法BSR的源地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
# 在公网实例中配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001::2 64
[Sysname-acl6-basic-2000] quit
[Sysname] ipv6 pim
[Sysname-pim6] bsr-policy 2000
c-bsr命令用来配置C-BSR。
undo c-bsr命令用来删除C-BSR的相关配置。
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
undo c-bsr ipv6-address [ scope scope-id ]
IPv6 PIM视图
ipv6-address:指定C-BSR的IPv6地址。
scope scope-id:指定IPv6管理域的编号,取值范围为3~15。如果未指定本参数,表示配置服务于Global域的C-BSR。
hash-length hash-length:指定哈希掩码长度,取值范围为0~128,缺省值为126。
priority priority:指定C-BSR的优先级,取值范围为0~255,缺省值为64。数值越大,优先级越高。
· C-BSR的IPv6地址必须有对应的本地接口,且该接口上必须使能IPv6 PIM,否则配置不会生效。
· 如果对同一个域多次执行本命令,新配置将覆盖旧配置;而针对不同域的C-BSR则允许指定相同的IPv6地址。
# 在公网实例中将IPv6地址为1101::1的设备配置为Global域的C-BSR。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr 1101::1
c-rp命令用来配置C-RP。
undo c-rp命令用来删除C-RP的相关配置。
IPv6 PIM视图
ipv6-address:指定C-RP的IPv6地址。
advertisement-interval adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒,缺省值为60秒。
group-policy acl6-number:指定IPv6基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该C-RP将为所有IPv6组播组服务。
holdtime hold-time:指定C-RP的超时时间,取值范围为1~65535,单位为秒,缺省值为150秒。
priority priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
bidir:指定该C-RP服务于IPv6双向PIM。设备不支持该参数,所以本命令配置的C-RP仅服务于IPv6 PIM-SM。
· C-RP的IPv6地址必须有对应的本地接口,且该接口上必须使能IPv6 PIM,否则配置不会生效。
· ACL规则中的source参数用来指定C-RP所服务的IPv6组播组范围(若指定的不是IPv6组播组地址,则此规则不生效),而其它可选参数都将被忽略。该ACL规则用来定义该C-RP所服务的IPv6组播组范围,只有permit的IPv6组播组才会作为RP的服务组范围通告出去。
· 如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
· 如果对同一IPv6地址多次执行本命令,新配置将覆盖旧配置。
# 在公网实例中将IPv6地址为2001::1配置为组播组FF0E:0:1391::/96的C-RP,且C-RP的优先级为10。
[Sysname-acl6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
crp-policy命令用来配置合法的C-RP地址范围及其服务的IPv6组播组范围,以防止C-RP欺骗。
undo crp-policy命令用来取消C-RP地址范围及其服务的IPv6组播组范围的限制。
C-RP地址范围及其服务的IPv6组播组范围不受任何限制,即认为所有收到的C-RP报文都是合法的。
IPv6 PIM视图
acl6-number:指定IPv6高级ACL的编号,取值范围为3000~3999。
· ACL规则中的source参数用来指定合法C-RP的IPv6地址范围,destination参数用来指定该C-RP所服务的IPv6组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
· 本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只取其前缀部分进行匹配。例如,C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,如果其前缀部分“FF0E:0:1::”能匹配上本命令所引用的ACL规则,就认为整个IPv6组播组范围“FF0E:0:1::/96”都通过了过滤。
# 在公网实例中配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl6-adv-3000] quit
[Sysname] ipv6 pim
[Sysname-pim6] crp-policy 3000
display ipv6 pim bsr-info命令用来显示IPv6 PIM-SM域中的BSR信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name:显示指定VPN实例的BSR信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的BSR信息。
# 显示公网实例IPv6 PIM-SM域中的BSR信息。
<Sysname> display ipv6 pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 12:12::1
Priority: 64
Hash mask length: 126
Uptime: 00:21:56
Scope: 5
State: Accept Any
Scope-zone expiry timer: 00:21:12
Scope: 6
State: Elected
Bootstrap timer: 00:00:26
Elected BSR address: 17:11::1
Priority: 64
Uptime: 02:53:37
Candidate BSR address: 17:11::1
Priority: 64
Scope: 7
State: Candidate
Bootstrap timer: 00:01:56
Elected BSR address: 61:37::1
Priority: 64
Uptime: 02:53:32
Candidate BSR address: 17:12::1
Priority: 64
Scope: 8
State: Pending
Bootstrap timer: 00:00:07
Candidate BSR address: 17:13::1
Priority: 64
表1-1 display ipv6 pim bsr-info命令显示信息描述表
BSR定时器 |
当选BSR的地址 |
候选BSR的地址 |
BSR的优先级 |
BSR已存在的时间 |
display ipv6 pim claimed-route命令用来显示IPv6 PIM所使用的路由信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的路由信息。
ipv6-source-address:组播源的IPv6地址,显示到达指定组播源的路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有路由信息。
# 显示IPv6 PIM在公网实例中使用的所有路由信息。
<Sysname> display ipv6 pim claimed-route
RPF-route selecting rule: longest-match
Route/mask: 7:11::/64 (unicast (direct))
RPF interface: Vlan-interface2, RPF neighbor: 8::2
Total number of (S,G) or (*,G) dependent on this route entry: 4
(7:11::10, ff1e::1)
(7:11::10, ff1e::2)
(7:11::10, ff1e::3)
(*, ff1e::4)
Route/mask: 7:12::/64 (unicast)
RPF interface: Vlan-interface2, RPF neighbor: 8::3,
Total number of (S,G) or (*,G) dependent on this route entry: 2
(7:12::10, ff1e::1)
(7:12::10, ff1e::2)
表1-2 display ipv6 pim claimed-route命令显示信息描述表
RPF路由的选择规则 |
· igp:单播路由(内部网关协议) · egp:单播路由(外部网关协议) · unicast (direct):单播路由(直连) · unicast:其它单播路由(如单播静态路由等) · mbgp:IPv6 MBGP路由 |
RPF接口的名称 |
RPF邻居的IPv6地址 |
基于此RPF路由的(S,G)或(*,G)个数及列表 |
display ipv6 pim c-rp命令用来显示IPv6 PIM-SM域中的C-RP信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name:显示指定VPN实例的C-RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的C-RP信息。
local:显示本地配置且生效的C-RP信息。如果未指定本参数,将显示所有学习到的C-RP信息。
只有当选的BSR上才会有学习到的C-RP信息,其它设备上只能查看到本地配置生效的C-RP信息。
# 显示公网实例中学习到的C-RP信息。
<Sysname> display ipv6 pim c-rp
Scope: non-scoped
Group/MaskLen: FF00::/8
C-RP address Priority HoldTime Uptime Expires
8:12::2 (local) 192 150 00:27:48 00:01:43
Group/MaskLen: FF23::/92 Expires: 00:02:07
# 显示本地配置生效的C-RP信息。
<Sysname> display ipv6 pim c-rp local
Candidate RP: 8:12::2(Loop1)
Priority: 192
HoldTime: 150
Advertisement interval: 60
Next advertisement scheduled at: 00:00:46
表1-3 display ipv6 pim c-rp命令显示信息描述表
C-RP所服务的IPv6组播组。设备不支持IPv6双向PIM,所以C-RP仅服务于IPv6 PIM-SM |
C-RP的IPv6地址,local表示本地地址 |
C-RP的优先级 |
C-RP的超时时间 |
C-RP已存在的时间,w表示星期,d表示天,h表示小时 |
C-RP/组播组的超时剩余时间 |
本地C-RP的IPv6地址 |
本地C-RP发送通告报文时间间隔 |
本地C-RP发送下一个通告报文的剩余时间 |
display ipv6 pim interface命令用来显示接口上的IPv6 PIM信息。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM信息。
interface-type interface-number:显示指定接口上的IPv6 PIM信息。如果未指定本参数,将显示所有接口上的IPv6 PIM信息。
# 显示公网实例所有接口上的IPv6 PIM概要信息。
<Sysname> display ipv6 pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
GE1/0/1 1 30 1 FE80::200:5EFF:FE04:8700
表1-4 display ipv6 pim interface命令显示信息描述表
IPv6 PIM邻居的数量 |
发送Hello报文的时间间隔 |
竞选DR的优先级 |
DR的IPv6地址(链路本地地址) |
# 显示公网实例接口GigabitEthernet1/0/1上的IPv6 PIM详细信息。
<Sysname> display ipv6 pim interface gigabitethernet 1/0/1 verbose
Interface: GigabitEthernet1/0/1, FE80::200:5EFF:FE04:8700
PIM version: 2
PIM mode: Sparse
PIM DR: FE80::200:AFF:FE01:101
PIM DR Priority (configured): 1
PIM neighbor count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM BSR domain border: disabled
PIM BFD: disabled
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
表1-5 display ipv6 pim interface verbose命令显示信息描述表
接口名称与IPv6地址(链路本地地址) |
IPv6 PIM协议的版本号 |
IPv6 PIM协议的模式,是密集模式还是稀疏模式 |
DR的IPv6地址(链路本地地址) |
竞选DR优先级的配置值 |
IPv6 PIM邻居的总数 |
发送Hello报文的时间间隔 |
剪枝否决时间的协商值 |
剪枝否决时间的配置值 |
是否使能不接受无Generation ID的Hello报文 |
保持IPv6 PIM邻居的可达状态的时间 |
发送Hello报文的最大延迟时间 |
发送加入/剪枝报文的时间间隔 |
加入/剪枝状态的保持时间 |
该接口是否配置了BSR的服务边界 |
该接口是否使能了IPv6 PIM与BFD联动功能 |
该接口所在网段上没有使用DR优先级字段的路由器数量 |
该接口所在网段上未使用LAN-delay字段的路由器数量 |
display ipv6 pim neighbor命令用来显示IPv6 PIM邻居信息。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM邻居信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM邻居信息。
ipv6-neighbor-address:IPv6 PIM邻居的IPv6地址,显示指定IPv6 PIM邻居的信息。如果未指定本参数,将显示所有IPv6 PIM邻居的信息。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上的IPv6 PIM邻居信息。如果未指定本参数,将显示所有接口上的IPv6 PIM邻居信息。
# 显示公网实例所有IPv6 PIM邻居的概要信息。
<Sysname> display ipv6 pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
FE80::A01:101:1 GE1/0/1 02:50:49 00:01:31 1
FE80::A01:102:1 GE1/0/2 02:49:39 00:01:42 1
# 显示公网实例中IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display ipv6 pim neighbor fe80::a01:101:1 verbose
Neighbor: FE80::A01:101:1
Interface: GigabitEthernet1/0/3
Uptime: 00:00:10
Expiry time: 00:00:30
DR Priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Disabled
Secondary address(es):
1::1
表1-6 display ipv6 pim neighbor命令显示信息描述表
IPv6 PIM邻居的总数 |
IPv6 PIM邻居的IPv6主地址(链路本地地址) |
IPv6 PIM邻居所在接口的名称 |
IPv6 PIM邻居已存在的时间 |
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达 |
IPv6 PIM邻居的优先级 |
IPv6 PIM邻居的模式,B表示IPv6双向PIM模式,显示为空则表示非IPv6双向PIM模式。设备不支持IPv6双向PIM,所以该项一直显示为空。 |
IPv6 PIM邻居的Generation ID(状态随机数) |
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达 |
IPv6 PIM报文在共享网段中的传输延迟 |
剪枝否决的时间间隔 |
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段 |
IPv6双向PIM是否使能。设备不支持IPv6双向PIM,所以该项一直显示Disabled |
IPv6 PIM邻居的IPv6从地址(非链路本地地址) |
display ipv6 pim routing-table命令用来显示IPv6 PIM路由表的内容。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM路由项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6 PIM路由项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
flags flag-value:IPv6 PIM标志,显示包含指定标志的IPv6 PIM路由项。如果未指定本参数,将显示包含所有标志的IPv6 PIM路由项。flag-value的取值及含义如下:
· act:表示已经有实际数据到达的IPv6 PIM路由项;
· del:表示计划删除的IPv6 PIM路由项;
· exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
· ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
· loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
· niif:表示未确定入接口的IPv6 PIM路由项;
· nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
· rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
· spt:表示SPT上的IPv6 PIM路由项;
· swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
· wc:表示带WC通配符的IPv6 PIM路由项。
fsm:显示有限状态机的详细信息。
incoming-interface interface-type interface-number:显示指定入接口的IPv6 PIM路由项。如果未指定本参数,将显示所有入接口的PIM路由项。
mode mode-type:IPv6 PIM模式,显示指定模式下的IPv6 PIM路由项。如果未指定本参数,将显示所有模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
· bidir:表示IPv6双向PIM模式,设备不支持该参数;
· dm:表示IPv6 PIM-DM模式;
· sm:表示IPv6 PIM-SM模式;
· ssm:表示IPv6 PIM-SSM模式。
outgoing-interface { exclude | include | match } interface-type interface-number:显示指定出接口的IPv6 PIM路由项。其中,exclude表示不包含指定接口;include表示包含指定接口;match表示包含且仅包含指定接口。如果未指定本参数,将显示所有出接口的IPv6 PIM路由项。
# 显示公网实例IPv6 PIM路由表的内容。
<Sysname> display ipv6 pim routing-table
(2001::2, FFE3::101)
RP: FE80::A01:100:1
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: GigabitEthernet1/0/1
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: GigabitEthernet1/0/2
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 显示公网实例IPv6 PIM路由表的状态机信息。
<Sysname> display ipv6 pim routing-table fsm
Abbreviations for FSM states:
NI - no info, J - joined, NJ - not joined, P - pruned,
NP - not pruned, PP - prune pending, W - winner, L - loser,
F - forwarding, AP - ack pending, DR - designated router,
NDR - non-designated router, RCV - downstream receivers
RP: FE80::A01:100:1
UpTime: 02:54:43
Join/Prune FSM: [SPT: J] [RPT: NP]
DR state: [DR]
Join/Prune FSM: [NI]
Assert FSM: [NI]
FSM information for non-downstream interfaces: None
表1-7 display ipv6 pim routing-table命令显示信息描述表
IPv6 PIM路由表中(S,G)与(*,G)表项的总数 |
NI - no info, J - joined, NJ - not joined, P – pruned NP - not pruned, PP - prune pending, W - winner, L – loser |
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者 |
IPv6 PIM路由表中的(S,G)表项 |
RP的地址 |
IPv6 PIM的模式 |
IPv6 PIM路由表中(S,G)或(*,G)表项的标志: · ACT:表示已有实际数据到达 · DEL:表示计划要删除 · EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝 · EXT:表示包含了由其它IPv6组播路由协议提供的出接口 · LOC:表示与IPv6组播源处于同一网段 · NIIF:表示未确定入接口 · NONBR:表示IPv6 PIM邻居查找失败 · RPT:表示向RP方向发送过(S,G)RPT位剪枝 · SPT:表示在SPT上 · SWT:表示正在向SPT切换 · WC:表示带WC通配符 |
(S,G)或(*,G)表项已存在的时间 |
(S,G)或(*,G)表项的入接口 |
(S,G)或(*,G)表项的上游邻居 |
(S,G)或(*,G)表项的RPF邻居: · 对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL · 对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL |
DR的状态 |
加入/剪枝状态机 |
display ipv6 pim rp-info命令用来显示IPv6 PIM-SM域中的RP的信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的RP信息。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
# 显示公网实例中IPv6组播组FF0E::101所对应的RP信息。
<Sysname> display ipv6 pim rp-info ff0e::101
BSR RP address is: 7:12::1
Priority: 192
HoldTime: 180
Uptime: 03:01:10
Expires: 00:02:30
Static RP address is: 7:12::1
Preferred: No
Configured ACL: 2003
RP mapping for this group is: 7:12::1 (local host)
Anycast-RP 7:12::1 members:
Member address State
1:1::1 Active
1:1::2 Local
1:2::1 Remote
# 显示所有IPv6组播组对应的RP信息。
BSR RP information:
Scope: non-scoped
8:12::2 (local) 192 180 03:01:36 00:02:29
7:12::1 (local) 192 180 00:00:39 00:02:57
Static RP information:
RP address ACL Mode Preferred
3:3::1 2000 pim-sm No
3:3::2 2001 pim-sm Yes
3:3::3 2002 pim-sm No
3:3::4 pim-sm No
3:3::5 2002 pim-sm Yes
Anycast-RP information:
RP address Member address State
3:3::1 1:1::1 Active
3:3::1 1:1::2 Local
3:3::1 1:2::1 Remote
表1-8 display ipv6 pim rp-info命令显示信息描述表
RP的IPv6地址 |
BSR RP信息 |
RP所服务的IPv6组播组。设备不支持IPv6双向PIM,所以RP仅服务于IPv6 PIM-SM |
RP的优先级 |
RP的超时时间 |
RP已存在的时间 |
RP超时的剩余时间 |
静态RP信息 |
静态RP的IPv6地址 |
静态RP所服务的IPv6组播组列表 |
服务于当前组播组的RP的IPv6地址 |
Anycast-RP成员的IPv6地址 |
Anycast-RP成员地址的来源: · Active:表示本端激活接口的地址 · Local:表示本端未激活接口的地址 · Remote:表示远端的地址 |
display ipv6 pim statistics命令用来显示IPv6 PIM协议报文的统计信息。
# 显示IPv6 PIM协议报文的统计信息。
<Sysname> display ipv6 pim statistics
Received PIM packets: 3295
Sent PIM packets : 5975
Valid Invalid Succeeded Failed
Hello : 3128 0 4333 0
Reg : 14 0 0 0
Reg-stop : 0 0 0 0
JP : 151 0 561 0
BSM : 0 0 1081 0
Assert : 0 0 0 0
Graft : 0 0 0 0
Graft-ACK: 0 0 0 0
C-RP : 0 0 0 0
SRM : 0 0 0 0
DF : 0 0 0 0
表1-9 display ipv6 pim statistics命令显示信息描述表
收到的IPv6 PIM协议报文总数 |
发出的IPv6 PIM协议报文总数 |
收到的合法IPv6 PIM协议报文数量 |
收到的非法IPv6 PIM协议报文数量 |
发送成功的IPv6 PIM协议报文数量 |
发送失败的IPv6 PIM协议报文数量 |
Hello报文统计 |
加入/剪枝报文统计 |
C-RP报文统计 |
hello-option dr-priority命令用来全局配置竞选DR的优先级。
undo hello-option dr-priority命令用来恢复缺省情况。
竞选DR的优先级为1。
IPv6 PIM视图
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
本配置既可在IPv6 PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option dr-priority 3
· ipv6 pim hello-option dr-priority
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。
undo hello-option holdtime命令用来恢复缺省情况。
保持IPv6 PIM邻居可达状态的时间为105秒。
IPv6 PIM视图
time:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在公网实例中全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option holdtime 120
· ipv6 pim hello-option holdtime
hello-option lan-delay命令用来全局配置IPv6 PIM报文在共享网段中的传输延迟。
undo hello-option lan-delay命令用来恢复缺省情况。
IPv6 PIM报文在共享网段中的传输延迟为500毫秒。
IPv6 PIM视图
delay:指定IPv6 PIM报文在共享网段中的传输延迟,取值范围为1~32767,单位为毫秒。
# 在公网实例中全局配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option lan-delay 200
· hello-option override-interval (IPv6 PIM view)
· ipv6 pim hello-option lan-delay
· ipv6 pim hello-option override-interval
hello-option neighbor-tracking命令用来全局使能邻居跟踪功能,即禁止加入报文抑制能力。
undo hello-option neighbor-tracking命令用来恢复缺省情况。
IPv6 PIM视图
# 在公网实例中全局使能邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option neighbor-tracking
· ipv6 pim hello-option neighbor-tracking
hello-option override-interval命令用来全局配置剪枝否决时间。
undo hello-option override-interval命令用来恢复缺省情况。
剪枝否决时间为2500毫秒。
IPv6 PIM视图
interval:指定剪枝否决时间,取值范围为1~65535,单位为毫秒。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option override-interval 2000
· hello-option lan-delay (IPv6 PIM view)
holdtime join-prune命令用来全局配置加入/剪枝状态的保持时间。
undo holdtime join-prune命令用来恢复缺省情况。
加入/剪枝状态的保持时间为210秒。
IPv6 PIM视图
time:指定加入/剪枝状态的保持时间,取值范围为1~65535,单位为秒。
· 本配置既可在IPv6 PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
· IPv6 PIM接口向上游邻居发送加入/剪枝报文的时间间隔必须小于加入/剪枝状态的保持时间,以免上游邻居老化超时。
# 在公网实例中全局配置加入/剪枝状态的保持时间为280秒。
[Sysname] ipv6 pim
[Sysname-pim6] holdtime join-prune 280
· ipv6 pim holdtime join-prune
· timer join-prune (IPv6 PIM view)
ipv6 pim命令用来进入IPv6 PIM视图。
undo ipv6 pim命令用来清除IPv6 PIM视图下的所有配置。
undo ipv6 pim [ vpn-instance vpn-instance-name ]
# 先使能公网实例中的IPv6组播路由,再进入公网实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname] ipv6 pim
[Sysname-pim6]
# 先使能VPN实例mvpn中的IPv6组播路由,再进入该VPN实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn] quit
[Sysname] ipv6 pim vpn-instance mvpn
[Sysname-pim6-mvpn]
ipv6 pim bfd enable命令用来使能IPv6 PIM与BFD联动功能。
undo ipv6 pim bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
IPv6 PIM与BFD联动功能处于关闭状态。
只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,本命令才能生效。
# 使能公网实例中的IPv6组播路由,在接口GigabitEthernet1/0/1上使能IPv6 PIM-DM,并使能IPv6 PIM与BFD联动功能。
[Sysname-GigabitEthernet1/0/1] ipv6 pim dm
[Sysname-GigabitEthernet1/0/1] ipv6 pim bfd enable
ipv6 pim bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。
undo ipv6 pim bsr-boundary命令用来删除BSR的服务边界。
没有配置BSR的服务边界。
# 配置接口GigabitEthernet1/0/1为BSR的服务边界。
[Sysname-GigabitEthernet1/0/1] ipv6 pim bsr-boundary
· c-bsr (IPv6 PIM view)
· ipv6 multicast boundary(IP组播命令参考/IPv6组播路由与转发)
ipv6 pim dm命令用来使能IPv6 PIM-DM。
undo ipv6 pim dm命令用来关闭IPv6 PIM-DM。
IPv6 PIM-DM处于关闭状态。
只有在相应实例中先使能了IPv6组播路由,本命令才能生效。
# 使能公网实例中的IPv6组播路由,并在接口GigabitEthernet1/0/1上使能IPv6 PIM-DM。
· ipv6 multicast routing(IP组播命令参考/IPv6组播路由与转发)
ipv6 pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。
undo ipv6 pim hello-option dr-priority命令用来恢复缺省情况。
ipv6 pim hello-option dr-priority priority
竞选DR的优先级为1。
# 在接口GigabitEthernet1/0/1上配置竞选DR的优先级为3。
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option dr-priority 3
· hello-option dr-priority (IPv6 PIM view)
ipv6 pim hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。
undo ipv6 pim hello-option holdtime命令用来恢复缺省情况。
ipv6 pim hello-option holdtime time
time:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在接口GigabitEthernet1/0/1上配置保持PIM邻居可达状态的时间为120秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option holdtime 120
· hello-option holdtime (IPv6 PIM view)
ipv6 pim hello-option lan-delay命令用来在接口上配置IPv6 PIM报文在共享网段中的传输延迟。
undo ipv6 pim hello-option lan-delay命令用来恢复缺省情况。
ipv6 pim hello-option lan-delay delay
# 在接口GigabitEthernet1/0/1上配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option lan-delay 200
ipv6 pim hello-option neighbor-tracking命令用来在接口上使能邻居跟踪功能,即禁止加入报文抑制能力。
ipv6 pim hello-option neighbor-tracking disable命令用来在全局使能了邻居跟踪功能的情况下,关闭当前接口上的邻居跟踪功能。
undo ipv6 pim hello-option neighbor-tracking命令用来抵消上述两条命令的配置,即让接口与全局配置保持一致。
邻居跟踪功能处于关闭状态,即不禁止报文抑制能力处于开启状态。
# 在接口GigabitEthernet1/0/1上使能邻居跟踪功能。
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option neighbor-tracking
#在公网实例全局使能了邻居跟踪功能的情况下,关闭接口GigabitEthernet1/0/1上的邻居跟踪功能。
[Sysname]ipv6 pim
[Sysname-pim6]hello-option neighbor-tracking
[Sysname-pim6]quit
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option neighbor-tracking disable
· hello-option neighbor-tracking (IPv6 PIM view)
ipv6 pim hello-option override-interval命令用来在接口上配置剪枝否决时间。
undo ipv6 pim hello-option override-interval命令用来恢复缺省情况。
ipv6 pim hello-option override-interval interval
剪枝否决时间为2500毫秒。
# 在接口GigabitEthernet1/0/1上配置剪枝否决时间为2000毫秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option override-interval 2000
ipv6 pim holdtime join-prune命令用来在接口上配置加入/剪枝状态的保持时间。
undo ipv6 pim holdtime join-prune命令用来恢复缺省情况。
ipv6 pim holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
# 在接口GigabitEthernet1/0/1上配置加入/剪枝状态的保持时间为280秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim holdtime join-prune 280
· holdtime join-prune (IPv6 PIM view)
ipv6 pim neighbor-policy命令用来配置合法Hello报文的源地址范围,以防止Hello报文欺骗。
undo ipv6 pim neighbor-policy命令用来恢复缺省情况。
ipv6 pim neighbor-policy acl6-number
Hello报文的源地址范围不受任何限制,即认为所有收到的Hello报文都是合法的。
ACL规则中的source参数用来指定合法Hello报文的源地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
# 在接口GigabitEthernet1/0/1上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl6-basic-2000] rule permit source fe80:101::101 64
[Sysname-GigabitEthernet1/0/1] ipv6 pim neighbor-policy 2000
ipv6 pim require-genid命令用来配置拒绝无Generation ID的Hello报文。
undo ipv6 pim require-genid命令用来恢复缺省情况。
接受无Generation ID的Hello报文。
# 配置接口GigabitEthernet1/0/1拒绝无Generation ID的Hello报文。
[Sysname-GigabitEthernet1/0/1] ipv6 pim require-genid
ipv6 pim sm命令用来使能IPv6 PIM-SM。
undo ipv6 pim sm命令用来关闭IPv6 PIM-SM。
IPv6 PIM-SM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口GigabitEthernet1/0/1上使能IPv6 PIM-SM。
[Sysname-GigabitEthernet1/0/1] ipv6 pim sm
ipv6 pim state-refresh-capable命令用来使能状态刷新能力。
undo ipv6 pim state-refresh-capable命令用来关闭状态刷新能力。
# 在接口GigabitEthernet1/0/1上关闭状态刷新能力。
[Sysname-GigabitEthernet1/0/1] undo ipv6 pim state-refresh-capable
· state-refresh-hoplimit (IPv6 PIM view)
· state-refresh-interval (IPv6 PIM view)
· state-refresh-rate-limit (IPv6 PIM view)
ipv6 pim timer graft-retry命令用来配置嫁接报文的重传时间。
undo ipv6 pim timer graft-retry命令用来恢复缺省情况。
ipv6 pim timer graft-retry interval
嫁接报文的重传时间为3秒。
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
# 在接口GigabitEthernet1/0/1上配置嫁接报文的重传时间为80秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer graft-retry 80
ipv6 pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。
undo ipv6 pim timer hello命令用来恢复缺省情况。
发送Hello报文的时间间隔为30秒。
interval:指定发送Hello报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送Hello报文。
# 在接口GigabitEthernet1/0/1上配置发送Hello报文的时间间隔为40秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer hello 40
ipv6 pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。
undo ipv6 pim timer join-prune命令用来恢复缺省情况。
ipv6 pim timer join-prune interval
发送加入/剪枝报文的时间间隔为60秒。
interval:指定发送加入/剪枝报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送加入/剪枝报文。
· 本命令不会立即生效,新配置的发送间隔将在当前发送间隔完成后生效。
# 在接口GigabitEthernet1/0/1上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer join-prune 80
ipv6 pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。
undo ipv6 pim triggered-hello-delay命令用来恢复缺省情况。
ipv6 pim triggered-hello-delay delay
触发Hello报文的最大延迟时间为5秒。
delay:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
# 在接口GigabitEthernet1/0/1上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-GigabitEthernet1/0/1] ipv6 pim triggered-hello-delay 3
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。
undo jp-pkt-size命令用来恢复缺省情况。
加入/剪枝报文的最大长度为8100字节。
IPv6 PIM视图
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] ipv6 pim
[Sysname-pim6] jp-pkt-size 1500
register-policy命令用来配置注册报文的过滤规则。
undo register-policy命令用来删除注册报文的过滤规则。
register-policy acl6-number
IPv6 PIM视图
ACL规则中的source参数用来指定注册报文的源地址范围,destination参数用来指定IPv6组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。只有与该ACL规则中的permit语句匹配的注册报文才会被RP接受。
# 在公网实例中配置RP上对注册报文的过滤规则,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] ipv6 pim
[Sysname-pim6] register-policy 3000
register-suppression-timeout命令用来配置注册抑制时间。
undo register-suppression-timeout命令用来恢复缺省情况。
IPv6 PIM视图
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] register-suppression-timeout 70
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。
undo register-whole-checksum命令用来恢复缺省情况。
IPv6 PIM视图
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] ipv6 pim
[Sysname-pim6] register-whole-checksum
snmp-agent trap enable pim6命令用来开启IPv6 PIM的告警功能。
undo snmp-agent trap enable pim6命令用来关闭IPv6 PIM的告警功能。
IPv6 PIM的告警功能处于开启状态。
candidate-bsr-win-election:表示C-BSR成功当选BSR的告警信息。
elected-bsr-lost-election:表示原BSR在新的选举中失败的告警信息。
neighbor-loss:表示邻居丢失的告警信息。
如果未指定任何可选参数,表示开启或关闭IPv6 PIM的全部告警功能。
开启了IPv6 PIM的告警功能之后,IPv6 PIM会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭IPv6 PIM的全部告警功能。
[Sysname] undo snmp-agent trap enable pim6
source-lifetime命令用来配置IPv6组播源的生存时间。
undo source-lifetime命令用来恢复缺省情况。
IPv6组播源的生存时间为210秒。
IPv6 PIM视图
time:指定IPv6组播源的生存时间,取值范围为0~31536000,单位为秒。0表示无穷大,即IPv6组播源永不老化。
# 在公网实例中配置IPv6组播源的生存时间为200秒。
[Sysname] ipv6 pim
[Sysname-pim6] source-lifetime 200
source-policy命令用来配置IPv6组播数据过滤器。
undo source-policy命令用来删除IPv6组播数据过滤器。
没有配置IPv6组播数据过滤器。
IPv6 PIM视图
acl6-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。
· 对于IPv6基本ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。未通过该过滤规则的报文将被丢弃。
· 对于IPv6高级ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,destination参数用来指定组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。未通过该过滤规则的报文将被丢弃。
# 在公网实例中配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl6-basic-2000] rule permit source 3121::1 128
[Sysname-acl6-basic-2000] rule deny source 3121::2 128
[Sysname] ipv6 pim
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold命令用来配置发起SPT切换的条件。
undo spt-switch-threshold命令用来恢复缺省情况。
spt-switch-threshold { immediacy | infinity } [ group-policy acl6-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy acl6-number ]
设备收到第一个IPv6组播数据包后便立即向SPT切换。
IPv6 PIM视图
immediacy:表示立即发起SPT切换。
infinity:表示永不发起SPT切换。
group-policy acl6-number:表示组策略列表中的一项,与该组策略匹配的IPv6组播组将应用本配置。acl6-number表示IPv6基本ACL的编号,取值范围为2000~2999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则本配置将应用于所有IPv6组播组。
· ACL规则中的source参数用来指定IPv6组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
· 由于某些设备无法将IPv6组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上不建议配置永不发起SPT切换,以免导致IPv6组播报文转发失败。
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy命令用来配置IPv6 SSM组播组的范围。
undo ssm-policy命令用来恢复缺省情况。
IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
IPv6 PIM视图
· ACL规则中的source参数用来指定IPv6 SSM组播组范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
· 通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] ipv6 pim
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。
undo state-refresh-hoplimit命令用来恢复缺省情况。
state-refresh-hoplimit hoplimit-value
状态刷新报文的Hop Limit值为255。
IPv6 PIM视图
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
# 在公网实例中配置状态刷新报文的Hop Limit值为45。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-hoplimit 45
· ipv6 pim state-refresh-capable
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。
undo state-refresh-interval命令用来恢复缺省情况。
IPv6 PIM视图
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。
undo state-refresh-rate-limit命令用来恢复缺省情况。
IPv6 PIM视图
time:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-rate-limit 45
static-rp命令用来配置静态RP。
undo static-rp命令用来删除静态RP。
static-rp ipv6-rp-address [ acl6-number | bidir | preferred ] *
undo static-rp ipv6-rp-address
IPv6 PIM视图
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是合法的IPv6全球单播地址。
acl6-number:指定基本IPv6基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
bidir:指定该静态RP服务于IPv6双向PIM。设备不支持该参数,所以本命令配置的静态RP仅服务于IPv6 PIM-SM。
preferred:表示当网络中同时存在动态RP和静态RP时,优先选择静态RP,只有当静态RP失效时,动态RP才能生效。如果未指定本参数,则表示优先选择动态RP,只有当未配置动态RP或动态RP失效时,静态RP才能生效。
· 作为静态RP的接口不必使能IPv6 PIM。
· ACL规则中的source参数用来指定静态RP所服务的IPv6组播组范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
· 当某个静态RP引用的ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
· 重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,则新配置将覆盖旧配置;如果存在多个静态RP服务于同一组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
# 在公网实例中配置IPv6地址为2001::2的接口为静态RP,为IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source ff03::101 64
[Sysname-acl6-basic-2001] quit
[Sysname] ipv6 pim
[Sysname-pim6] static-rp 2001::2 2001 preferred
timer hello命令用来全局配置发送Hello报文的时间间隔。
undo timer hello命令用来恢复缺省情况。
timer hello interval
发送Hello报文的时间间隔为30秒。
IPv6 PIM视图
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer hello 40
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。
undo timer join-prune命令用来恢复缺省情况。
发送加入/剪枝报文的时间间隔为60秒。
IPv6 PIM视图
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer join-prune 80
