12-LLDP命令
本章节下载: 12-LLDP命令 (203.03 KB)
1.1.1 display lldp local-information
1.1.2 display lldp neighbor-information
1.1.7 lldp agent nearest-nontpmr admin-status
1.1.8 lldp check-change-interval
1.1.9 lldp compliance admin-status cdp
1.1.12 lldp encapsulation snap
1.1.16 lldp management-address-format string
1.1.17 lldp notification med-topology-change enable
1.1.18 lldp notification remote-change enable
1.1.19 lldp timer notification-interval
1.1.20 lldp timer reinit-delay
display lldp local-information命令用来显示待发送的LLDP信息,这些信息将被组织成TLV发送给邻居设备。
global:显示待发送的全局LLDP信息。
interface interface-type interface-number:显示指定接口上待发送的LLDP信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示待发送的所有LLDP信息,包括全局LLDP信息以及所有使能了LLDP功能且状态为up的接口上的LLDP信息。
# 显示所有待发送的LLDP信息(假设DCBX的版本为1.00)。
<Sysname> display lldp local-information
Chassis ID : 0023-8912-3d06
System name : H3C
System description : H3C Comware Platform Software, Software Version 7.1.035,
Alpha 0035P05
H3C S7604-X
Copyright (c) 2004-2012 Hangzhou H3C Tech. Co., Ltd. All
rights reserved.
System capabilities supported : Bridge, Router
System capabilities enabled : Bridge, Router
MED information:
Device class : Connectivity device
MED inventory information of master board:
HardwareRev : VER.A
FirmwareRev : 101
SoftwareRev : S7600X-CMW-0035P04
SerialNum : Unknown
Manufacturer name : Unknown
Model name : H3C S7604-X
Asset tracking identifier : Unknown
LLDP local-information of port 1[Ten-GigabitEthernet1/0/1]:
Port ID type : Interface name
Port ID : Ten-GigabitEthernet1/0/1
Port description : Ten-GigabitEthernet1/0/1 Interface
Management address type : IPv4
Management address : 10.0.0.1
Management address interface ID : 3857
Management address OID : 0
Port VLAN ID(PVID) : 1
Port and protocol VLAN ID(PPVID) : 0
Port and protocol VLAN supported : No
Port and protocol VLAN enabled : No
VLAN name of VLAN 1 : VLAN 0001
DCBX Control subTLV info:
Oper version : Ver 1.00
Sequence number : 1
Acknowledge number : 0
DCBX ETS subTLV info:
CoS Local priority Percentage
0 2 7
1 15 0
2 1 4
3 3 11
4 4 14
5 5 18
6 6 21
7 7 25
DCBX PFC subTLV info:
P0-0 P1-0 P2-1 P3-1 P4-0 P5-0 P6-0 P7-0
DCBX APP subTLV info:
CoS map: 0x10
Auto-negotiation supported : No
Auto-negotiation enabled : No
OperMau : Speed(0)/Duplex(Unknown)
Power port class : PSE
PSE power supported : No
PSE power enabled : No
PSE pairs control ability : No
Power pairs : Signal
Port power classification : Class 0
Link aggregation enabled : No
Aggregation port ID : 0
Maximum frame size : 9216
# 显示所有待发送的LLDP信息(假设DCBX的版本为1.01)。
System name : H3C
Alpha 0035P05
H3C S7604-X
rights reserved.
MED information:
HardwareRev : VER.A
FirmwareRev : 101
SerialNum : Unknown
LLDP local-information of port 1[Ten-GigabitEthernet1/0/]:
DCBX control subTLV info:
Oper version : Ver 1.01
Sequence number : 1
0 2 7
1 15 0
2 1 4
3 3 11
4 4 14
5 5 18
6 6 21
7 7 25
Number of traffic classes supported: 8
ID type Protocol ID CoS map
APP protocol 0x8906 0x10
APP protocol 0x8914 0x20
TCP or UDP port 23 0xEA
表1-1 display lldp local-information命令显示信息描述表
Global LLDP local-information |
待发送的全局LLDP信息 |
Chassis ID |
Chassis ID值,为本设备的桥MAC地址 |
System name |
系统名称 |
System description |
系统描述 |
System capabilities supported |
系统所支持的功能: · Bridge:表示支持交换功能 · Router:表示支持路由功能 |
System capabilities enabled |
系统已使能的功能: · Bridge:表示交换功能已使能 · Router:表示路由功能已使能 |
MED information |
MED相关信息 |
Device class |
MED设备类型: · Connectivity device:表示网络设备 · Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备 · Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流 · Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用 |
MED inventory information of master board |
主控板MED资产信息 |
HardwareRev |
产品的硬件版本 |
FirmwareRev |
产品的固件版本 |
SoftwareRev |
产品的软件版本 |
SerialNum |
序列号 |
Manufacturer name |
制造厂商 |
Model name |
终端的模块名称 |
Asset tracking identifier |
资产跟踪ID |
LLDP local-information of port 1 |
端口1上待发送的LLDP信息 |
Port ID type |
端口ID类型: · MAC address:表示MAC地址 · Interface name:表示接口名称 |
Port ID |
端口ID值,根据本设备的Port ID type取相应类型的值 |
Port description |
端口描述 |
Management address type |
管理地址类型 |
Management address |
管理地址 |
Management address interface type |
管理地址所在接口的编码方式 |
Management address interface ID |
管理地址接口索引 |
Management address OID |
管理地址对象标识符 |
Port VLAN ID(PVID) |
端口缺省VLAN ID |
Port and protocol VLAN ID(PPVID) |
端口协议VLAN ID |
Port and protocol VLAN supported |
是否支持端口协议VLAN |
Port and protocol VLAN enabled |
是否已使能端口协议VLAN |
VLAN name of VLAN 12 |
VLAN 12的名称 |
DCBX control subTLV info |
显示DCBX控制TLV的信息 |
Oper version |
DCBX版本号 |
Sequence number |
DCBX TLV内容改变的次数 |
Acknowledge number |
对端设备同步配置的次数 |
DCBX ETS subTLV info |
CoS与本地优先级的映射关系及对应的带宽分配情况 |
CoS |
CoS值 |
Local priority |
本地优先级 |
Percentage |
对应的带宽分配 |
DCBX PFC subTLV info |
PFC功能开启情况 |
P0-0 P1-0 P2-1 P3-1 P4-0 P5-0 P6-0 P7-0 |
本端各802.1p优先级的PFC功能开启状态:1表示开启,0表示关闭 |
Number of traffic classes supported |
PFC支持的能力集,只在1.01版本中显示该项 |
DCBX APP subTLV info |
应用协议与CoS的映射关系,在1.0版本中只显示下面的CoS map信息 |
ID type |
应用协议号的类型,包括: · APP protocol · TCP or UDP port |
Protocol ID |
应用协议号 |
CoS map |
应用协议与CoS的映射关系 |
Auto-negotiation supported |
端口是否支持自协商 |
Auto-negotiation enabled |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE(Power Sourcing Equipment,供电设备) · PD(Powered Device,受电设备) |
PSE power supported |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
PSE pairs control ability |
供电方式是否可控 |
Power pairs |
PoE端口的远程供电模式: · Signal:表示信号线供电模式 · Spare:表示空闲线供电模式 |
Port power classification |
PD的端口控制级别: · Class 0:表示级别0 · Class 1:表示级别1 · Class 2:表示级别2 · Class 3:表示级别3 · Class 4:表示级别4 |
Link aggregation supported |
端口是否支持链路聚合 |
Link aggregation enabled |
端口是否已使能链路聚合 |
Aggregation port ID |
聚合组中该成员端口的编号,未使能链路聚合功能时为0 |
Maximum frame size |
端口支持的最大帧长度 |
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息,这些信息是由邻居设备组织成TLV并发送给本设备的。
display lldp neighbor-information [ interface interface-type interface-number [ verbose ] | list [ system-name system-name ] | verbose ]
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口收到的由邻居设备发来的LLDP详细信息(假设DCBX的版本为1.00)。
<Sysname> display lldp neighbor-information verbose
LLDP Neighbor index : 1
Update time : 0 days, 0 hours, 1 minutes, 1 seconds
LLDP mac type : Nearest Bridge
Chassis type : MAC address
Chassis ID : 000f-0055-0002
Time to live : 120
System name : Sysname
Management address : 192.168.1.55
Management address interface ID : 3858
Port VLAN ID(PVID) : 20
Sequence number : 1
0 2 7
1 15 0
2 1 4
3 3 11
4 4 14
5 5 18
6 6 21
7 7 25
CoS map: 0x10
Auto-negotiation enabled : Yes
OperMau : Speed(1000)/Duplex(Full)
Power port class : PD
PSE power supported : Yes
PSE power enabled : Yes
PSE pairs control ability : Yes
Link aggregation enabled : Yes
Aggregation port ID : 52
Maximum frame size : 1500
CDP neighbor-information of port 1[Ten-GigabitEthernet1/0/1]:
CDP neighbor index : 2
Chassis ID : Switch
Addresses : 2.0.0.2
Port ID : GigabitEthernet1/0/33
Software version : Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9
-M), Version 12.2(25)SED1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 22-Nov-05 23:37 by yenanh
Platform version : cisco WS-C3750G-48TS
Duplex : Full
Time to live : 180
# 显示所有接口收到的由邻居设备发来的LLDP详细信息(假设DCBX的版本为1.01)。
LLDP neighbor-information of port 1[Ten-GigabitEthernet1/0/1]:
Time to live : 120
Sequence number : 1
0 2 7
1 15 0
2 1 4
3 3 11
4 4 14
5 5 18
6 6 21
7 7 25
Chassis ID : Switch
Addresses : 2.0.0.2
Duplex : Full
Time to live : 180
# 显示所有接口收到的由邻居设备发来的LLDP概要信息。
LLDP neighbor-information of port 52[Ten-GigabitEthernet1/0/3]:
LLDP neighbor index : 3
ChassisID/subtype : 0011-2233-4400/MAC address
PortID/subtype : 000c-29f5-c71f/MAC address
Capabilities : Bridge, Router
LLDP neighbor index : 6
PortID/subtype : 000c-29f5-c715/MAC address
Capabilities : None
# 按列表显示所有邻居设备发来的LLDP信息。
Chassis ID : * -- Nearest non-tpmr bridge neighbor
# -- Nearest customer bridge neighbor
System name Local interface Chassis ID Port ID
System1 XGE1/0/1 000f-e25d-ee91 Ten-GigabitEthernet1/0/5
System2 XGE1/0/2 000f-e25d-ee92 Ten-GigabitEthernet1/0/6
System3 XGE1/0/3 000f-e25d-ee93 Ten-GigabitEthernet1/0/7
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP邻居的显示信息: |
LLDP neighbor-information of port 1 |
端口1上收到的LLDP邻居信息 |
LLDP Neighbor index |
邻居索引 |
Update time |
邻居信息最新更新时间 |
LLDP mac type |
邻居MAC地址类型: · Nearest brige:最近桥代理 · Nearest customer bridge:最近客户桥代理 · Nearest non-tpmr bridge:最近非TPMR桥代理 |
Chassis type |
Chassis ID类型: · Chassis component:表示底架组件 · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Locally assigned:表示邻居自定义 |
Chassis ID |
Chassis ID值,根据邻居设备的Chassis type取相应类型的值 |
Chassis ID : * -- Nearest non-tpmr bridge neighbor # -- Nearest customer bridge neighbor |
Chassis ID标记,*表示最近的non-tpmr桥邻居,#表示最近的customer桥邻居 |
Port ID type |
端口ID类型: · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network Address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Agent circuit ID:表示代理巡回标识 · Locally assigned:表示邻居自定义 |
Port ID |
端口ID值,根据邻居设备的Port ID type取相应类型的值 |
Time to live |
邻居信息在本地的存活时间 |
Port description |
端口描述 |
System name |
系统名称 |
系统描述 |
系统所支持的功能: · Repeater:表示支持信号中继功能 · Bridge:表示支持交换功能 · WlanAccessPoint:表示支持无线接入点功能 · Router:表示支持路由功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Other:表示支持不在上述列表的其它功能 |
系统已使能的功能: · Repeater:表示信号中继功能已使能 · Bridge:表示交换功能已使能 · WlanAccessPoint:表示无线接入点功能已使能 · Router:表示路由功能已使能 · Telephone:表示电话功能已使能 · DocsisCableDevice:表示电缆设备功能已使能 · StationOnly:表示只作站点功能已使能 · Other:表示不在上述列表的其它功能已使能 |
管理地址类型 |
管理地址 |
管理地址接口类型 |
管理地址接口索引 |
管理地址对象标识符 |
Port VLAN ID |
端口VLAN ID |
端口协议VLAN ID |
是否支持端口协议VLAN |
是否使能端口协议VLAN |
VLAN 12的名称 |
显示DCBX控制TLV的信息 |
Oper version |
DCBX版本号 |
Sequence number |
DCBX TLV内容改变的次数 |
对端设备同步配置的次数 |
CoS |
CoS值 |
Local priority |
本地优先级 |
Percentage |
对应的带宽分配 |
PFC功能开启情况 |
ID type |
Protocol ID |
应用协议号 |
CoS map |
应用协议与CoS的映射关系 |
端口是否支持自协商 |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE:表示供电设备 · PD:表示受电设备 |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
供电方式是否可控 |
Power pairs |
端口是否支持链路聚合 |
端口是否已使能链路聚合 |
端口支持的最大帧长度 |
Unknown basic TLV(仅在收到未知的基本TLV时支持此显示信息) |
未知的基本TLV |
TLV type(仅在收到未知的基本TLV时支持此显示信息) |
未知的基本TLV类型 |
TLV information(仅在收到未知的基本TLV时支持此显示信息) |
未知的基本TLV的具体信息 |
Unknown organizationally-defined TLV(仅在收到未知组织定义的TLV时支持此显示信息) |
未知组织定义TLV |
TLV OUI(仅在收到未知组织定义的TLV时支持此显示信息) |
未知组织定义TLV的对象唯一标识 |
TLV subtype(仅在收到未知组织定义的TLV时支持此显示信息) |
未知的组织定义TLV类型 |
Index(仅在收到未知组织定义的TLV时支持此显示信息) |
未知组织的索引 |
Local Interface |
接收LLDP信息的本端端口 |
CDP邻居的显示信息: |
CDP neighbor-information of port 1 |
端口1的CDP邻居信息 |
CDP neighbor index |
CDP邻居索引 |
Chassis ID/subtype |
Chassis ID值及Chassis ID类型 |
Address |
CDP邻居设备上与本设备相连端口的IPv4地址 |
Port ID/subtype |
Port ID值及PortID类型 |
Software version |
邻居软件版本 |
Platform version |
邻居平台版本 |
Duplex |
双工状态 |
display lldp statistics命令用来显示LLDP的统计信息。
display lldp statistics [ global | interface interface-type interface-number ]
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global Information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted : 1
The number of LLDP neighbor information dropped : 0
LLDP statistics information of port 1 [Ten-GigabitEthernet1/0/1]:
The number of LLDP frames transmitted : 0
The number of LLDP frames received : 0
The number of LLDP frames discarded : 0
The number of LLDP error frames : 0
The number of LLDP TLVs discarded : 0
The number of LLDP TLVs unrecognized : 0
The number of CDP frames transmitted : 0
The number of CDP frames received : 0
The number of CDP frames discarded : 0
The number of CDP error frames : 0
表1-3 display lldp statistics命令显示信息描述表
LLDP statistics global information |
全局LLDP统计信息 |
LLDP neighbor information last change time |
邻居信息的最后更新时间 |
The number of LLDP neighbor information inserted |
邻居信息的增加次数 |
The number of LLDP neighbor information deleted |
邻居信息的删除次数 |
The number of LLDP neighbor information dropped |
由于空间不足而导致丢弃邻居信息的次数 |
The number of LLDP neighbor information aged out |
邻居信息的老化数量 |
LLDP statistics Information of port 1 |
端口1上的LLDP统计信息 |
The number of LLDP frames transmitted |
发送的LLDP帧总数 |
The number of LLDP frames received |
收到的LLDP帧总数 |
The number of LLDP frames discarded |
丢弃的LLDP帧总数 |
The number of LLDP error frames |
收到的错误LLDP帧总数 |
The number of LLDP TLVs discarded |
丢弃的LLDP TLV总数 |
The number of LLDP TLVs unrecognized |
不可识别的LLDP TLV总数 |
老化的LLDP邻居信息总数 |
The number of CDP frames transmitted |
发送的CDP帧总数 |
The number of CDP frames received |
收到的CDP帧总数 |
The number of CDP frames discarded |
丢弃的CDP帧总数 |
The number of CDP error frames |
收到的错误CDP帧总数 |
display lldp status命令用来显示LLDP的状态信息。
display lldp status [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有使能了LLDP功能的接口上的LLDP状态信息。
# 显示全局和所有接口上的LLDP状态信息。
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
Transmit interval : 30s
Hold multiplier : 4
Reinit delay : 2s
Transmit delay : 2s
Trap interval : 5s
Fast start times : 3
LLDP status information of Port 1 [Ten-GigabitEthernet1/0/1]:
Port status of LLDP : Enable
Admin status : Tx_Rx
Trap flag : No
MED trap flag : No
Polling interval : 0s
Number of LLDP neighbors : 0
Number of MED neighbors : 0
Number of CDP neighbors : 0
Number of sent optional TLV : 12
表1-4 display lldp status命令显示信息描述表
Global status of LLDP |
LLDP功能是否已全局使能 |
The current number of LLDP neighbors |
当前设备的LLDP邻居总数 |
The current number of CDP neighbors |
当前设备的CDP邻居总数 |
LLDP neighbor information last changed time |
邻居信息的最后更新时间 |
Transmit interval |
LLDP报文的发送间隔 |
Hold multiplier |
TTL乘数 |
Reinit delay |
端口初始化延迟时间 |
Transmit delay |
LLDP报文的发送延迟 |
Trap interval |
Trap信息的发送间隔 |
Fast start times |
快速发送LLDP报文的个数 |
Port 1 |
端口1上的LLDP状态信息 |
Port status of LLDP |
LLDP功能是否已在端口上使能 |
Admin status |
端口LLDP工作模式: · Tx_Rx:表示既发送也接收LLDP报文 · Rx_Only:表示只接收不发送LLDP报文 · Tx_Only:表示只发送不接收LLDP报文 · Disable:表示既不发送也不接收LLDP报文 |
Trap Flag |
LLDP Trap功能是否已使能 |
MED trap flag |
LLDP-MED Trap功能是否已使能 |
Polling interval |
轮询间隔,0表示轮询功能处于关闭状态 |
Number of neighbors |
端口LLDP邻居数量 |
Number of MED neighbors |
端口MED邻居设备的数量 |
Number of CDP neighbors |
端口CDP邻居设备的数量 |
Number of sent optional TLV |
端口在一个LLDP报文中发送的可选TLV总数 |
Number of received unknown TLV |
端口在所有LLDP报文中收到的不能识别的TLV总数 |
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
display lldp tlv-config [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
# 显示接口Ten-GigabitEthernet1/0/1上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface ten-gigabitethernet 1/0/1
LLDP tlv-config of port 1[Ten-GigabitEthernet1/0/1]:
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES YES
System Name TLV YES YES
System Description TLV YES YES
System Capabilities TLV YES YES
Management Address TLV YES YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV YES YES
Port And Protocol VLAN ID TLV YES YES
VLAN Name TLV YES YES
DCBX TLV NO NO
IEEE 802.3 extend TLV:
MAC-Physic TLV YES YES
Power via MDI TLV YES YES
Link Aggregation TLV YES YES
Maximum Frame Size TLV YES YES
LLDP-MED extend TLV:
Network Policy TLV YES YES
Location Identification TLV NO NO
Extended Power via MDI TLV YES YES
Inventory TLV YES YES
表1-5 display lldp tlv-config命令显示信息描述表
LLDP tlv-config of port 1 |
端口1上可发送的可选TLV类型 |
NAME |
TLV类型 |
STATUS |
端口是否配置发布指定类型TLV |
DEFAULT |
端口发布指定类型TLV的缺省情况 |
Basic optional TLV |
端口可以发送的基本TLV类型 |
Port Description TLV |
端口描述TLV |
System Name TLV |
系统名称TLV |
System Description TLV |
系统描述TLV |
System Capabilities TLV |
系统能力集TLV |
Management Address TLV |
管理地址TLV |
IEEE 802.1 extended TLV |
端口可发送的IEEE 802.1组织定义的TLV类型 |
Port VLAN ID TLV |
端口VLAN ID TLV |
Port And Protocol VLAN ID TLV |
协议VLAN ID TLV |
VLAN Name TLV |
VLAN名称TLV |
DCBX TLV |
DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV。 |
IEEE 802.3 extended TLV |
端口可发送的IEEE 802.3组织定义的TLV类型 |
MAC-Physic TLV |
端口物理属性TLV |
Power via MDI TLV |
供电能力TLV |
Link Aggregation TLV |
链路聚合TLV |
Maximum Frame Size TLV |
最大帧长度TLV |
LLDP-MED extend TLV |
LLDP-MED TLV |
Capabilities TLV |
MED能力集TLV |
Network Policy TLV |
网络策略TLV |
Location Identification TLV |
位置标识TLV |
Extended Power via MDI TLV |
扩展供电能力TLV |
Inventory TLV |
资产信息TLV |
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
lldp admin-status { disable | rx | tx | txrx }
LLDP的工作模式为TxRx,既发送也接收LLDP报文。
二层以太网接口视图/三层以太网接口视图
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口Ten-GigabitEthernet1/0/1上LLDP的工作模式为Rx。
[Sysname-Ten-GigabitEthernet1/0/1] lldp admin-status rx
lldp agent nearest-nontpmr admin-status命令用来配置LLDP最近非TPMR桥代理的工作模式。
undo lldp agent nearest-nontpmr admin-status命令用来恢复缺省情况。
lldp agent nearest-nontpmr admin-status txrx
最近非TPMR桥代理工作模式为Disable,既不发送也不接收LLDP报文。
二层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上配置LLDP最近非TPMR桥代理的工作模式为TxRx。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-nontpmr admin-status txrx
lldp check-change-interval命令用来使能轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
lldp check-change-interval interval
轮询功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口Ten-GigabitEthernet1/0/1上使能轮询功能,并配置轮询间隔为30秒。
[Sysname-Ten-GigabitEthernet1/0/1] lldp check-change-interval 30
lldp compliance admin-status cdp命令用来配置LLDP兼容CDP功能的工作模式。
undo lldp compliance admin-status cdp命令用来恢复缺省情况。
lldp compliance admin-status cdp { disable | txrx }
LLDP兼容CDP功能的工作模式为Disable,既不发送也不接收CDP报文。
二层以太网接口视图/三层以太网接口视图
disable:表示工作模式为Disable,既不发送也不接收CDP报文。
txrx:表示工作模式为TxRx,既发送也接收CDP报文。
欲使LLDP兼容CDP的功能生效,必须先使能LLDP兼容CDP功能,同时将LLDP兼容CDP功能的工作模式配置为TxRx。
# 使能LLDP兼容CDP功能,并在接口Ten-GigabitEthernet1/0/1上配置LLDP兼容CDP功能的工作模式为TxRx。
[Sysname] lldp compliance cdp
[Sysname- Ten-GigabitEthernet1/0/1] lldp compliance admin-status cdp txrx
· lldp compliance cdp
lldp compliance cdp命令用来使能LLDP兼容CDP功能。
undo lldp compliance cdp命令用来恢复缺省情况。
lldp compliance cdp
LLDP兼容CDP功能处于关闭状态。
由于CDP报文所携Time To Live TLV中TTL的最大值为255,而CDP报文的发送间隔由LLDP报文的发送间隔控制,因此为保证LLDP兼容CDP功能的正常运行,建议配置LLDP报文的发送间隔值不大于实际TTL的1/3。
# 使能LLDP兼容CDP功能。
· lldp hold-multiplier
· lldp timer tx-interval
lldp enable命令用来在接口上使能LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
lldp enable
undo lldp enable
接口上的LLDP功能处于使能状态。
二层以太网接口视图/三层以太网接口视图
只有当全局和接口上都使能了LLDP功能后,该功能才会生效。
# 在接口Ten-GigabitEthernet1/0/1上关闭LLDP功能。
[Sysname-Ten-GigabitEthernet1/0/1] undo lldp enable
· lldp global enable
lldp encapsulation snap命令用来配置LLDP报文的封装格式为SNAP格式。
undo lldp encapsulation命令用来恢复缺省情况。
LLDP报文的封装格式为Ethernet II格式。
二层以太网接口视图/三层以太网接口视图
LLDP CDP报文的封装格式只能为SNAP格式,不能为Ethernet II格式。
# 配置接口Ten-GigabitEthernet1/0/1上发送的LLDP报文的封装格式为SNAP格式。
[Sysname-Ten-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
lldp fast-count count
快速发送LLDP报文的个数为3个。
count:表示快速发送LLDP报文的个数,取值范围为1~10,单位为个。
当LLDP报文的快速发送机制启动后,设备会将LLDP报文的发送周期缩短为1秒,并连续发送指定数量的LLDP报文后再恢复为正常的发送周期,该数量可通过本命令进行修改。
# 配置快速发送LLDP报文的个数为4个。
[Sysname] lldp fast-count 4
lldp global enable命令用来全局使能LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
lldp global enable
LLDP处于全局关闭状态。
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
· lldp enable
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
lldp hold-multiplier value
TTL乘数为4。
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔)),即取65535与(TTL乘数×LLDP报文的发送间隔)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
管理地址在TLV中的封装格式为数字格式。
二层以太网接口视图/三层以太网接口视图
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
# 在接口Ten-GigabitEthernet1/0/1上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-Ten-GigabitEthernet1/0/1] lldp management-address-format string
lldp notification med-topology-change enable命令用来使能LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上使能LLDP-MED Trap功能。
[Sysname-Ten-GigabitEthernet1/0/1] lldp notification med-topology-change enable
lldp notification remote-change enable命令用来使能LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
LLDP Trap功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上使能LLDP Trap功能。
[Sysname-Ten-GigabitEthernet1/0/1] lldp notification remote-change enable
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为5秒。
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
lldp timer reinit-delay delay
接口初始化的延迟时间为2秒。
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
lldp timer tx-delay命令用来配置LLDP报文的发送延迟。
undo lldp timer tx-delay命令用来恢复缺省情况。
lldp timer tx-delay delay
LLDP报文的发送延迟为2秒。
delay:表示LLDP报文的发送延迟,取值范围为1~8192,单位为秒。
· 建议将LLDP报文的发送延迟配置为不大于其发送间隔的四分之一。
· 如果所配置的LLDP报文的发送延迟大于其发送间隔,那么其实际发送间隔将以其发送延迟的取值为准。
# 配置LLDP报文的发送延迟为4秒。
[Sysname] lldp timer tx-delay 4
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
interval:表示LLDP报文的发送间隔,取值范围为5~32768,单位为秒。
· 建议将LLDP报文的发送间隔配置为不小于其发送延迟的四倍。
· 如果所配置的LLDP报文的发送间隔小于其发送延迟,那么其实际发送间隔将以其发送延迟的取值为准。
# 配置LLDP报文的发送间隔为20秒。
· lldp timer tx-delay
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
在二层以太网接口视图下:
lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | dcbx | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | dcbx | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | network-policy | power-over-ethernet } }
在三层以太网接口视图下:
lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | power-over-ethernet } }
二层以太网接口上允许发布除DCBX TLV、Location Identification TLV、VLAN Name TLV和Protocol VLAN ID TLV之外所有类型的TLV;三层以太网接口上允许发布除IEEE 802.1组织定义的TLV、Network Policy TLV和Location Identification TLV之外所有类型的TLV。
二层以太网接口视图/三层以太网接口视图
all:在二层以太网接口视图下指定basic-tlv、dot1-tlv或dot3-tlv,或者在三层以太网接口视图下指定basic-tlv或dot3-tlv时,本参数表示该类型下所有的可选TLV;而不论在二层还是三层以太网接口视图下指定med-tlv时,本参数都表示该类型下除location-id以外所有的可选TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ip-address ]:表示Management Address TLV。ip-address为所要发布的管理地址,其缺省值在二层以太网接口上为该端口允许通过的、对应VLAN接口上配置有IP地址且处于up状态的最小VLAN的主IP地址(如果该端口允许通过的所有VLAN所对应的VLAN接口上都未配置IP地址或均处于down状态,则不发布管理地址),在三层以太网接口上则为该接口的IP地址(如果该接口未配置IP地址,则不发布管理地址)。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
dcbx:表示Data Center Bridging Exchange Protocol TLV。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
link-aggregation:表示Link Aggregation TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Switch,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy:表示Network Policy TLV。
power-over-ethernet:表示Extended Power-via-MDI TLV。
· 在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
· 如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
# 配置接口Ten-GigabitEthernet1/0/1上允许发布IEEE 802.3组织定义的Link Aggregation可选TLV。
[Sysname-Ten-GigabitEthernet1/0/1] lldp tlv-enable dot3-tlv link-aggregation
