05-三层技术-IP路由命令参考
02-静态路由命令
本章节下载 02-静态路由命令  (114.62 KB)
02-静态路由命令
1 静态路由
1.1  静态路由配置命令
1.1.1  delete static-routes all
delete static-routes all命令用来删除所有静态路由。
delete [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name:删除指定VPN的所有静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示删除公网的所有静态路由。
·              使用本命令删除静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
·              使用undo ip route-static命令可以删除一条静态路由,而使用delete static-routes all命令可以删除包括缺省路由在内的所有静态路由。
# 删除所有静态路由。
[Sysname] delete static-routes all
Delete all IPv4 static routes. Continue?[Y/N]y
·              ip route-static
1.1.2  ip route-static
ip route-static命令用来配置静态路由。
undo ip route-static命令用来删除已配置的静态路由。
ip route-static dest-address { mask | mask-length } { next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask | mask-length } { next-hop-address [ public ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static vpn-instance s-vpn-instance-name dest-address { mask | mask-length } [ next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
没有配置静态路由。
vpn-instance s-vpn-instance-name:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。每个VPN都有自己的路由表,配置的静态路由将被加入指定VPN的路由表。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
vpn-instance d-vpn-instance-name:指定目的VPNd-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,静态路由将根据配置的next-hop-address在目的VPN中查找出接口。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。
backup-interface interface-type interface-number:备份出接口。对于备份出接口为非P2P类型的接口时(如以太网接口、VLAN接口等),必须同时指定其对应的备份下一跳地址。interface-type interface-number为指定的接口类型和编号。
backup-nexthop backup-nexthop-address:备份下一跳地址。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
bfd-source ip-address:BFD源IP地址。建议配置为Loopback接口IP地址。
permanent:指定为永久静态路由。即使在出接口down时,配置的永久静态路由仍然保持active状态。
track track-entry-number:将静态路由与Track项相关联,track-entry-number为Track项的序号,取值范围为1~1024。关于Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
echo-packet:通过BFD echo报文方式实现BFD功能。
public:指定静态路由下一跳处于公网实例。
interface-type interface-number:指定静态路由的出接口类型和接口号。对于接口类型为非P2P接口(如以太网接口、VLAN接口等),必须指定下一跳地址。
preference preference-value:指定静态路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。关于路由策略的详细信息,请参见“三层技术-IP路由配置指导”中的“路由策略”。
可在路由策略中根据Tag值对路由进行灵活的控制,取值范围为1~4294967295,缺省值为0。
description description-text:配置的静态路由描述信息,取值范围为1~60个字符。除“?”外,可以包含空格等特殊字符。
如果目的IP地址和掩码都为0.0.0.0(或掩码为0),则配置的路由为缺省路由。当没有匹配的路由表项时,将使用缺省路由进行报文转发。
对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
配置静态路由时,可根据实际需要指定出接口或下一跳地址。需要注意的是:
·              对于Null0接口,配置了出接口就不需要配置下一跳地址。
·              对于广播类型接口(如以太网接口、VLAN接口),因为可能有多个下一跳,配置时必须同时指定出接口和下一跳IP地址。
配置静态路由时需要注意的是:
·              路由振荡时,使能BFD检测功能可能会加剧振荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性配置指导”中的“BFD”。
·              如果Track模块通过NQA探测私网静态路由中下一跳的可达性,静态路由下一跳的VPN实例号与NQA测试组配置的实例号必须相同,才能进行正常的探测。
·              在静态路由进行迭代时,Track项监测的应该是静态路由真正的下一跳,而不是配置的下一跳。否则,可能导致错误地将有效路由判断为无效路由。
·              参数permanent不能和bfdtrack一起进行配置。
举例】
# 配置静态路由,其目的地址为1.1.1.1/24,指定下一跳为2.2.2.2,Tag值为45,描述信息为“for internet”。
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
·              display ip routing-table protocol(三层技术-IP路由命令参考/IP路由基础)
1.1.3  ip route-static default-preference
ip route-static default-preference命令用来配置静态路由的缺省优先级。
undo ip route-static default-preference命令用来恢复缺省情况。
ip route-static default-preference default-preference-value
静态路由的缺省优先级为60。
default-preference-value:静态路由缺省优先级的值,取值范围为1~255。
·              如果在配置静态路由时没有指定优先级,就会使用缺省优先级。
·              重新配置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
# 配置静态路由的缺省优先级为120。
[Sysname] ip route-static default-preference 120
