二层技术-以太网交换命令参考
07-命令索引
本章节下载: 07-命令索引  (745.56 KB)
07-命令索引
1  Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
active region-configuration
B
broadcast-suppression (Ethernet interface view)
C
check region-configuration
D
description
description
description
display brief interface
display interface
display interface loopback
display interface null
display interface vlan-interface
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-vlan
display mac-vlan interface
display port
display stp
display stp abnormal-port
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display vlan
duplex
E
F
flow-control
flow-interval
G
H
I
instance
interface
interface loopback
interface null
ip address
J
K
L
loopback
loopback-detection control enable
loopback-detection enable
loopback-detection interval-time
M
mac-address (Interface view)
mac-address (system view)
mac-address mac-learning disable
mac-address max-mac-count
mac-address timer
mac-vlan enable
mac-vlan mac-address
multicast-suppression (Ethernet interface view)
N
name
O
P
port
port access vlan
port hybrid pvid vlan
port hybrid vlan
port link-type
port trunk permit vlan
port trunk pvid vlan
Q
R
region-name
reset counters interface
reset stp
revision-level
S
shutdown
shutdown
shutdown
speed
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp priority
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
T
U
unicast-suppression (Ethernet interface view)
V
vlan
vlan-mapping modulo
W
X
Y
