基础配置命令参考
10-命令索引
本章节下载: 10-命令索引  (958.03 KB)
10-命令索引
1  Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
acl (User interface view)
activation-key
archive configuration
archive configuration interval
archive configuration location
archive configuration max
ascii
authentication-mode
auto-execute command
B
backup startup-configuration
binary
boot-loader
bootrom
bye
C
cd
cd
cdup
clock datetime
clock summer-time one-off
clock summer-time repeating
clock timezone
close
command accounting
command authorization
command-alias enable
command-alias mapping
command-privilege
configuration replace file
configure-user count
copy
copyright-info enable
D
databits
debugging
delete
delete
dir
dir
disconnect
display archive configuration
display boot-loader
display clipboard
display clock
display command-alias
display configure-user
display cpu-usage
display cpu-usage history
display current-configuration
display device
display device manuinfo
display diagnostic-information
display environment
display ftp client configuration
display history-command
display hotkey
display ip http
display ip https
display job
display memory
display reboot-type
display saved-configuration
display schedule reboot
display startup
display system-failure
display tftp client configuration
display this
display user-interface
display users
display version
display web users
E
escape-key
execute
F
file prompt
fixdisk
format
free user-interface
free web-users
ftp
ftp client source
ftp ipv6
G
get
H
header
history-command max-size
hotkey
I
idle-timeout
ip http acl
ip http enable
ip http port
ip https acl
ip https certificate access-control-policy
ip https enable
ip https port
ip https ssl-server-policy
J
job
K
L
lcd
lock
ls
M
mkdir
mkdir
more
move
N
O
open
open ipv6
P
parity
passive
protocol inbound
put
pwd
pwd
Q
R
reboot
remotehelp
rename
reset recycle-bin
reset saved-configuration
reset unused porttag
restore startup-configuration
return
rmdir
rmdir
S
save
schedule reboot at
schedule reboot delay
screen-length
screen-length disable
send
set authentication password
shell
speed (User interface view)
startup saved-configuration
super
super authentication-mode
super password
sysname
system-failure
T
telnet
telnet ipv6
telnet server enable
temperature-limit
terminal type
tftp
tftp client source
tftp ipv6
tftp-server acl
time
U
undelete
user
user privilege level
user-interface
V
verbose
view
W
X
Y
