H3C MSR Router Series Interface Module Guide(V9)-6W100
HomeSupportProduct LiteratureHardware Information & SpecificationsH3C MSR Router Series Interface Module Guide(V9)-6W100
01-Text
01-Text 5.41 MB
1 SIC interface modules· 1
Ethernet interface modules· 1
RT-SIC-4GSW-G·· 1
RT-SIC-4GSWF-G·· 2
RT-SIC-1XPF-G·· 3
E1 interface modules· 5
SIC-E1-F· 5
SIC-2E1-F· 6
RT-SIC-2E1-G·· 7
Serial interface modules· 9
SIC-8AS· 9
SIC-16AS· 10
SIC-2SAE/SIC-4SAE· 11
4G interface modules· 13
SIC-4G-CNDE· 13
RT-SIC-4G-CAT6· 15
SIC-D4G-CNDE· 17
5G interface modules· 20
RT-SIC-5G·· 20
RT-SIC-5G-CN· 23
Network data encryption modules· 26
SIC-CNDE-SJK· 26
SIC-4G-CNDE-SJK· 26
SIC-D4G-CNDE-SJK· 29
M.2 riser SIC modules· 31
RT-SIC-M2-SATA· 31
2 XMIM interface modules· 33
Ethernet interface modules· 33
RT-XMIM-8GEE/RT-XMIM-8GEE-R· 33
RT-XMIM-8GEF/RT-XMIM-8GEF-R· 35
RT-XMIM-4XP· 36
RT-XMIM-2XPF· 37
POS (SDH/SONET) interface modules· 38
RT-XMIM-1POS/RT-XMIM-2POS· 39
CPOS (SDH/SONET) interface modules· 40
RT-XMIM-1CPOS· 40
E1 interface modules· 41
RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1· 42
Network data encryption modules· 45
RT-XMIM-CNDE-SJK· 45
3 SSD modules· 46
RT-SSD-960G·· 46
4 Cables and the connection methods· 47
Ethernet interface· 47
Ethernet cable appearance and applicable models· 47
Connecting an Ethernet cable· 48
Fiber port 48
Appearances and applicable models of transceiver modules and optical fibers· 48
Connecting an optical fiber 48
E1 interface· 49
E1 cable appearance and applicable models· 49
Connecting a 1/2/8-port E1 75-ohm cable (D15/D68 <----> BNC) 50
Connecting a 4-port E1 75-ohm cable (D25 <----> D15) 51
Connecting a 1-port E1 120-ohm cable (D15 <----> RJ-45) 52
Connecting a 4-port E1 120-ohm cable (D25 <----> D15) 53
Synchronous/asynchronous serial ports· 53
Appearance and applicable models of synchronous/asynchronous serial port cables· 53
Connecting the cable· 55
Asynchronous serial ports· 56
Appearance and applicable models of asynchronous serial port cables· 56
Connecting a SIC-8AS/SIC-16AS interface module· 57
4G interface· 58
Appearance and applicable models of 4G antennas and extension cables· 58
Connection methods of 4G antennas and antenna extension cables· 60
5G interface· 61
Appearance and applicable models of stick antennas and antenna extension cables· 61
Connection methods of stick antennas and antenna extension cables· 65
GPS interface· 66
Appearance and applicable models of the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK interface module GPS antenna· 66
Connecting an antenna extension cable· 66
GNSS interface· 67
Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna· 67
Connecting a GNSS antenna· 67
5 Link mode of interfaces on Ethernet switching modules and interface modules  68
6 Frequency bands for 4G/5G interface modules· 69
7 Interface module net weights and power consumption· 70
CAUTION
CAUTION:
·     You can hot swap or perform an online removal and insertion (OIR) operation on an interface module. OIR requires you to execute the remove command or press the REMOVE button before you remove an interface module, and hot swapping does not.
·     Only the RT-SIC-4GSW-G, RT-SIC-4GSWF-G, and RT-SIC-2E1-G interface modules support hot swapping.
·     SIC interface modules with a remove button support OIR. To remove a SIC interface module with a remove button while the device is operating, first press the remove button or execute the remove command. For the specific operation instructions, see the description for the SIC interface module. The remove command and the remove button cannot be used simultaneously, as this might cause the SIC interface module to become unusable.
·     The SIC interface modules, except for the RT-SIC-4GSW-G, RT-SIC-2E1-G, and those with a remove button, do not support hot swapping or OIR.
MSR series routers use modular design and support a wide range of optional smart interface cards (SICs). The SIC series interface modules provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1, and Layer 2 switching interface.
·     RT-SIC-4GSW-G
·     RT-SIC-4GSWF-G
·     RT-SIC-1XPF-G
RT-SIC-4GSW-G
Introduction
The 4-port 1000 Mbps Ethernet SIC interface module RT-SIC-4GSW-G provides four 1000 Mbps RJ-45 ports and is used for communication between the router and LAN.
The interface module has the following features:
·     Effective transmission distance of 100 m (328.08 ft) over category-5 twisted pair cables (both crossover and straight-through).
·     Line rate of 1000 Mbps between any interfaces over category-5e twisted pair cables (both crossover and straight-through).
·     Autosensing operating speeds of 1000 Mbps, 100 Mbps, and 10 Mbps.
·     Both full duplex (typically used) and half-duplex operating modes
Interface specifications
Table1-1 describes the interface specifications of the RT-SIC-4GSW-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-1 Interface specifications
Item
Connector
RJ-45
Interface type
MDI/MDIX
Number of connectors
4
Cable
Standard (straight-through)/crossover Ethernet cable
Operating mode
10/100/1000 Mbps autosensing
Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Medium dependent interfaces crossover (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN switches.
Interface LEDs
Figure1-1 RT-SIC-4GSW-G panel
On the panel, each port corresponds to one green LED and one yellow LED.
Table1-2 LED description
LED
Status
LINK/ACT
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
The port is sending and receiving data at 1000 Mbps.
Steady yellow
A link is present on the port and the port is operating at 10/100 Mbps.
Flashing yellow
The port is sending and receiving data at 10/100 Mbps.
Off
No link is present.
Interface cables and the connection methods
For information about Ethernet interface cables and the connection methods, see "Ethernet interface."
RT-SIC-4GSWF-G
Introduction
The 4-port 100/1000 Mbps Ethernet Layer 3 SIC interface module RT-SIC-4GSWF-G provides four SFP fiber ports and is used for communication between the router and LAN. It supports:
·     Various types of FE and GE transceiver modules.
·     100/1000 Mbps interface rate.
·     Full duplex.
Table1-3 describes the interface specifications of the RT-SIC-4GSWF-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-3 Interface specifications
Item
Number of interfaces
4
Connector
SFP/LC
Interface standard
802.3, 802.3u, 802.3ab
Operating mode
100/1000 Mbps
Full duplex
Interface LEDs
Figure1-2 RT-SIC-4GSWF-G panel
The RT-SIC-4GSWF-G interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table1-4 LED description
LED
Status
LINK/ACT
Steady green
Flashing green
Steady yellow
A link is present on the port and the port is operating at 100 Mbps.
Flashing yellow
The port is sending and receiving data at 100 Mbps.
Off
No link is present.
Transceiver modules, optical fibers, and connection methods
For more information about transceiver modules, optical fibers, and connection methods, see "Fiber port."
RT-SIC-1XPF-G
CAUTION
CAUTION:
The RT-SIC-1XPF-G interface module is hot swappable. To remove an RT-SIC-1XPF-G interface module, first press and hold the remove button for a minimum of 3 seconds. You can remove the interface module only when the remove LED is turned off. If the remove LED is flashing green, wait for the remove LED to turn off and then remove the interface module.
Introduction
The 10 Gbps Ethernet interface module RT-SIC-1XPF-G provides one SFP+ fiber port, which is a Layer 3 service port. The interface module supports port type switching between standard Ethernet and FlexE. The FlexE mode allows flexible bandwidth assignment to meet different service requirements.
Table1-5 describes the interface specifications of the RT-SIC-1XPF-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-5 Interface specifications
Item
1
Connector
SFP+/LC
Interface standard
10GBASE-R
Operating mode
10 Gbps, full duplex
Panel and interface LEDs
Figure1-3 RT-SIC-1XPF-G panel
Table1-6 LED description
LED
Status
LINK/ACT
Steady green
A link is present on the port and the port is operating at 10 Gbps.
Flashing green
The port is sending and receiving data at 10 Gbps.
Off
No link is present.
REMOVE
Steady green
The module is operating correctly. You can press the remove button to remove the module.
Flashing green
·     The module is initializing. You cannot press the remove button or remove the module.
·     The module is being removed.
Off
You can remove the module if all the other LEDs on the module are also off.
CAUTION
CAUTION:
During online upgrade of the RT-SIC-1XPF-G interface module, do not remove it. In the upgrade process, the remove LED flashes green, turns off, flashes again, and then remains steady on.
·     SIC-E1-F
·     SIC-2E1-F
·     RT-SIC-2E1-G
SIC-E1-F
Introduction
The 1-port fractional E1 interface module (SIC-E1-F) supports:
·     Transmission/Receiving and handling of E1 data streams
·     Remote loopback and local loopback functions, facilitating fault test and location.
The timeslots on an interface in FE1 mode on the SIC-E1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 64 Kbps, where n ranges from 1 to 31.)
The SIC-E1-F does not support the PRI mode.
Table1-7 Interface specifications
Item
Connector type
D15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
75-ohm unbalanced coaxial cable (D15 to BNC)
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure1-4 SIC-E1-F panel
Table1-8 LED description
LED
LINK/ACT
·     On: A carrier signal is received.
·     Flashing: Data is being transmitted or received.
·     Off: No carrier signal is received.
LP/AL
·     On: The interface is in loopback mode.
·     Off: Neither loopback nor alarm is present.
·     Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty.
For more information about E1 interface cables and the connection methods, see "E1 interface."
SIC-2E1-F
Introduction
The 2-port fractional E1 interface module (SIC-2E1-F), where F indicates fractional, supports:
Table1-9 Interface specifications
Item
Connector type
D15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure1-5 SIC-2E1-F panel
Table1-10 LED description
LED
LINK/ACT (left)
·     On: A carrier signal is received on line RX1.
·     Flashing: Data is being transmitted on line TX1 or received on line RX1.
·     Off: No carrier signal is received on line RX1.
LP/AL (left)
·     On: The interface of lines TX1 and RX1 is in loopback mode.
·     Flashing: No cable is connected to the interface of lines TX1 and RX1, the cable is damaged or not connected correctly, or the peer device is faulty.
·     Off: Neither loopback nor alarm is present on the interface of lines TX1 and RX1.
LINK/ACT (right)
·     On: A carrier signal is received on line RX2.
·     Flashing: Data is being transmitted on line TX2 or received on line RX2.
·     Off: No carrier signal is received on line RX2.
LP/AL (right)
·     On: The interface of lines TX2 and RX2 is in loopback mode.
·     Flashing: No cable is connected to the interface of lines TX2 and RX2, the cable is damaged or not connected correctly, or the peer device is faulty.
·     Off: Neither loopback nor alarm is present on the interface of lines TX2 and RX2.
For more information about E1 interface cables and the connections methods, see "E1 interface."
RT-SIC-2E1-G
Introduction
The RT-SIC-2E1-G is a 2-port channelized CE1/PRI and fractional E1 (E1-F) interface module.
The module provides the following features:
·     Channelized CE1/PRI mode—The module allows arbitrary grouping of 31 channels and multiple bundles. It transmits/receives and handles E1 data streams, provides CE1 access, and supports ISDN PRI.
·     Unchannelized E1 mode—Interfaces on the module are 2.048 Mbps synchronous serial interfaces without timeslot division.
·     Fractional E1 (E1-F) mode—The time slots can only be bundled into one n x 64 kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
Table1-11 Interface specifications
Item
Connector type
RJ-45
2
Interface standard
G.703
Interface rate
2.048 Mbps
Cable type
·     E1 120-ohm balanced twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft)
·     E1 75-ohm unbalanced coaxial cable
·     75-ohm adapter cable
·     Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector)
Operating modes
·     Unchannelized E1 (G.703)
·     Channelized E1 (CE1/PRI)
Supported services
·     Backup
·     Terminal access service
·     ISDN PRI
The E1 cable after extension supports a maximum transmission distance of 100 m (328.08 ft).
Interface LEDs
Figure1-6 RT-SIC-2E1-G panel
Table1-12 LED description
LED
Status
LINK/ACT (green)
Steady green
A carrier signal has been received.
Flashing green
Data is being transmitted or/and received.
Off
No carrier signal has been received.
LP/AL (yellow)
Steady yellow
Flashing yellow
Off
No loopback or alarm is present.
Jumper caps
The RT-SIC-2E1-G interface module provides jumper caps, the installation status of which determines the interface impedance. By default, each pin pair is installed with a jumper cap and the impedance of an E1 interface is 75 ohms.
Figure1-7 Default installation status of jumper caps
To connect a 75-ohm cable to an E1 interface, install jumper caps on the pins corresponding to the interface. To connect a 120-ohm cable to an E1 interface, remove the jumper caps from the pins corresponding to the interface. Table1-13 displays the mapping relations between pins and E1 interfaces.
Table1-13 Mapping relations between pins and E1 interfaces
Pins
E1 interface
1 and 2
E1 interface 0
3 and 4
E1 interface 0
5 and 6
E1 interface 1
7 and 8
E1 interface 1
9 and 10
Reserved. Keep the jumper cap in its default installation status.
·     SIC-8AS
·     SIC-16AS
·     SIC-2SAE
·     SIC-4SAE
SIC-8AS
Introduction
The 8-port asynchronous serial interface module (SIC-8AS) mainly transmits and processes asynchronous data streams.
SIC-8AS has these features:
·     Each asynchronous serial port provides a rate up to 115.2 Kbps.
·     Supports the terminal access service and asynchronous dedicated line.
·     Serves as the small-/medium-sized ISP dial-up access server when an asynchronous serial port is used for dial-up.
Table1-14 Interface specifications
Item
Connector
DB60
1
Interface cable
Customized cable with 8-port RJ-45 connector
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 Kbps
Supported services
·     Modem dial-up
·     Backup
·     Asynchronous dedicated line
Interface LEDs
Figure1-8 SIC-8AS front panel
SIC-8AS+口
Table1-15 LED description
LED
LINK/ACT
·     Off: No link is present.
·     On: A link is present.
·     Flashing: Data is being received or/and transmitted.
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
SIC-16AS
Introduction
The 16-port asynchronous serial interface module (SIC-16AS) mainly transmits and processes asynchronous data streams.
SIC-16AS features the following:
·     Each asynchronous serial port provides a rate of up to 115.2 Kbps.
Table1-16 Interface specifications
Item
Connector
D28 (male)
1
Interface cable
Customized cable with 16-port RJ-45 connector (female)
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 Kbps
Supported services
·     Modem dial-up
·     Backup
Interface LEDs
Figure1-9 SIC-16AS panel
SIC-16AS
Table1-17 LED description
LED
LINK/ACT
SIC-2SAE/SIC-4SAE
Introduction
The SIC-2SAE/SIC-4SAE is a 1-port/2-port/4-port enhanced high-speed synchronous/asynchronous serial interface module.
Table1-18 Interface specifications
Item
Synchronous
Asynchronous
Connector
D28
·     2 (SIC-2SAE)
·     4 (SIC-4SAE)
Interface standard and operating mode
V.24
·     V.35
·     RS449
·     X.21
·     RS-530
RS-232
·     DTE
·     DCE
·     DTE
·     DCE
Minimum baud rate
(bps)
1200
1200
300
Maximum baud rate
(bps)
64 k
2.048 M
115.2
Cable
·     V.24 (RS-232) DTE cable
·     V.24 (RS-232) DCE cable
·     V.35 DTE cable
·     V.35 DCE cable
·     X.21 DTE cable
·     X.21 DCE cable
·     RS449 DTE cable
·     RS449 DCE cable
·     RS530 DTE cable
·     RS530 DCE cable
Supported service
·     DDN leased line
·     Dialup through modems
·     Backup
·     Asynchronous leased line
·     Terminal access
Interface LEDs
Figure1-10 SIC-2SAE panel
Figure1-11 SIC-4SAE panel
Table1-19 LED description for ports on the SIC-2SAE/SIC-4SAE
LED
LINK/ACT
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
·     SIC-4G-CNDE
·     RT-SIC-4G-CAT6
·     SIC-D4G-CNDE
SIC-4G-CNDE
Introduction
The SIC-4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-20 Interface specifications
Item
Connectors
3 SMA connectors
Supported antenna types
·     GPS
·     Omnidirectional antenna, support for FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/GPRS/GSM/EVDO/CDMA
Technologies and supported frequency bands
·     LTE-TDD band 38/39/40/41
·     LTE-FDD band 1/3/5/7/8
·     TD-SCDMA band 34/39
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
For information about the frequency bands supported by the interface module, see "Frequency bands for 4G/5G interface modules."
Interface LEDs
Figure1-12 SIC-4G-CNDE panel
Table1-21 LED description
LED
WWAN
·     Steady green indicates that a link is present.
·     Fast flashing green indicates that data is being transmitted or received.
·     Slowly flashing green indicates network searching.
·     Off indicates that no link is present.
RSSI
·     Steady green indicates strong signal (RSSI ≥ –69 dBm).
·     Fast flashing green indicates middle signal (–89 dBm ≤ RSSI <–69 dBm).
·     Slowly flashing green indicates low signal (–99 dBm ≤ RSSI < –89 dBm).
·     Steady yellow is reserved for future use.
·     Off indicates weak signal or no signal (RSSI < –99 dBm).
LTE
·     Steady green indicates the 4G-LTE service is valid.
·     Flashing green (8 Hz) indicates the high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is valid.
·     Steady yellow indicates the 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is valid.
·     Flashing yellow is reserved for future use.
·     Off indicates no LTE service.
GPS
·     Steady green indicates that the GPS service is valid.
·     Off indicates no GPS service.
CNDE
·     Steady green indicates that the module is operating correctly and is not sending or receiving data.
·     Flashing green indicates that the module is operating correctly and is sending or receiving data.
·     Steady yellow indicates that the module is faulty.
·     Off indicates that the module is not installed securely, or no power is present.
Antennas, interface cables, and the connection methods
For more information about SIC-4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing Micro SIM card
CAUTION
CAUTION:
Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
The SIC-4G-CNDE interface module supports Micro SIM cards.
The SIC-4G-CNDE has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
To install a Micro SIM card:
1.     Use a Phillips screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer.
3.     Insert SIM cards into the SIM card slots on the retainer.
4.     Reattach the retainer cover and use the two screws to secure the cover.
5.     Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the Micro SIM card is identified.
Figure1-13 Installing Micro SIM cards
RT-SIC-4G-CAT6
IMPORTANT
IMPORTANT:
The RT-SIC-4G-CAT6 module is hot swappable. However, to avoid unexpected reboot of the host, execute the remove command or press the remove button for over 3 seconds and wait for the remove LED to turn off before removing the module.
Introduction
The RT-SIC-4G-CAT6 module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     WCDMA
Table1-22 Interface specifications
Item
Connectors
3 SMA connectors
Standard and operating mode
·     GNSS: GPS/GLONASS/BDS/Galileo
·     Omnidirectional antenna: FDD-LTE, TDD-LTE, WCDMA
Supported services
·     LTE-TDD
·     LTE-FDD
·     WCDMA
Interface LEDs
Figure1-14 RT-SIC-4G-CAT6 panel
Table1-23 LED description
LED
Status
WWAN
Steady green
A WWAN link is present.
Fast flashing green
Data is being transmitted or received on the WWAN link.
Slow flashing green
Searching and connecting to a WWAN network.
Off
Not connected to a WWAN.
WCDMA
Steady green
Strong 3G signal strength (RSSI ≥ –70 dBm)
Fast flashing green
Medium 3G signal strength (–100 dBm ≤ RSSI < –70 dBm)
Slow flashing green
Low 3G signal strength (–125 dBm ≤ RSSI < –100 dBm)
Off
No 3G service (RSSI < –125 dBm)
LTE
Steady green
The module is operating in 4G mode and the 4G signal strength is strong (RSSI ≥ –70 dBm).
Fast flashing green
The module is operating in 4G mode and the 4G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm).
Slow flashing green
The module is operating in 4G mode and the 4G signal strength is low (–125 dBm ≤ RSSI < –100 dBm).
Off
No 4G service (RSSI < –125 dBm)
SIM
Steady green
The SIM card in SIM card slot 0 is working.
Steady yellow
The SIM card in SIM card slot 1 is working.
Off
No SIM cards are present in the two SIM card slots.
GNSS
Steady green
Valid GNSS service.
Off
No GNSS service.
REMOVE
Steady green
The module is operating correctly. You can remove it.
Fast flashing green
The module is initializing. You cannot remove it.
Off
Antennas, interface cables, and connection methods
For more information about RT-SIC-4G-CAT6 module antennas, interface cables, and the connection methods, see "4G interface" and "GNSS interface."
CAUTION
CAUTION:
The RT-SIC-4G-CAT6 module supports Micro SIM cards.
The RT-SIC-4G-CAT6 has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM0 slot is active and the SIM1 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
3.     Insert SIM cards into the SIM card slots on the retainer. Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
Figure1-15 Installing Micro SIM cards
SIC-D4G-CNDE
Introduction
The SIC-D4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-24 Interface specifications
Item
Connectors
5 SMA connectors
·     GPS
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-16 SIC-D4G-CNDE panel
Table1-25 LED description
LED
WWAN
RSSI
LTE
GPS
CNDE
For more information about SIC-D4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE interface module supports Micro SIM cards.
The SIC-D4G-CNDE has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure1-17 Installing Micro SIM cards
·     RT-SIC-5G
·     RT-SIC-5G-CN
RT-SIC-5G
CAUTION
CAUTION:
Before removing an RT-SIC-5G module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a SIC-5G module with its remove LED on.
Introduction
The RT-SIC-5G module provides 5G WLAN access and supports the following technologies:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
Table1-26 Interface specifications
Item
Connectors
4 SMA connectors
Standard and working mode
·     GNSS: GPS/GLONASS/BeiDou/Galileo
·     Omnidirectional antenna, support for WCDMA/FDD-LTE/TDD-LTE/5G NR
Supported service
·     5G/4G/3G networking
·     5G and LTE-A full coverage
·     NSA and SA modes
·     Integrating multi-constellation GNSS receiver for fast and precise positioning in different environments
Interface LEDs
Figure1-18 RT-SIC-5G panel
Table1-27 LED description
LED
Status
WWAN
Steady green
Fast flashing green
Slow flashing green
Off
5G
Steady green (SA mode)
Strong 5G signal strength (RSRP ≥ –85 dBm)
Fast flashing green (SA mode)
Medium 5G signal strength (–100 dBm ≤ RSRP < –85 dBm)
Slow flashing green (SA mode)
Low 5G signal strength (–115 dBm ≤ RSRP < –100 dBm)
Steady yellow (NSA mode)
Fast flashing yellow (NSA mode)
Slow flashing yellow (NSA mode)
Off
No 5G service
LTE
Steady green
Fast flashing green
Slow flashing green
Steady yellow
The module is operating in 3G mode and the 3G signal strength is strong (RSSI ≥ –70 dBm).
The module is operating in 3G mode and the 3G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm).
The module is operating in 3G mode and the 3G signal strength is low (–125 dBm ≤ RSSI < –100 dBm).
Off
No 3G and 4G services.
SIM
Steady green
Steady yellow
The SIM card in SIM card slot 2 is working.
Off
GNSS
Steady green
Valid GNSS service.
Off
No GNSS service.
REMOVE
Steady green
The module is operating correctly. You can hot-remove it.
Fast flashing green
The module is initializing. You cannot hot-remove it.
Off
For more information about RT-SIC-5G interface module antennas, interface cables, and the connection methods, see "5G interface."
Installing a 5G SIM card
CAUTION
CAUTION:
To avoid damage to the SIM card or the 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration.
The RT-SIC-5G interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the SIC-5G interface module. In Figure1-19, two SIM cards are installed.
To install a 5G SIM card:
1.     Use a screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer, as shown by callout 2 in Figure1-19.
3.     Orient the SIM card with the cut corner as shown in the illustration.
4.     Insert the SIM card into the SIM card slot along the guide rails.
5.     Slightly push SIM card edge to secure it into the slot.
6.     Reattach the retainer cover and use the two screws to secure the cover.
7.     Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the SIM card is identified.
Figure1-19 Installing 5G SIM cards
RT-SIC-5G-CN
CAUTION
CAUTION:
Before removing an RT-SIC-5G-CN module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a RT-SIC-5G-CN module with its remove LED on.
Introduction
The RT-SIC-5G-CN module provides 5G WLAN access and supports the following technologies:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
Table1-28 Interface specifications
Item
Connectors
4 SMA connectors
SMA
Supported service
·     NSA and SA modes
Interface LEDs
Figure1-20 RT-SIC-5G-CN panel
Table1-29 LED description
LED
Status
WWAN
Steady green
Fast flashing green
Slow flashing green
Off
5G
Off
No 5G service
LTE
Steady green
Fast flashing green
Slow flashing green
Steady yellow
Off
SIM
Steady green
Steady yellow
Off
REMOVE
Steady green
Fast flashing green
Off
For more information about RT-SIC-5G-CN interface module antennas, interface cables, and the connection methods, see "5G interface."
CAUTION
CAUTION:
To avoid damage to the SIM card and 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration.
The RT-SIC-5G-CN interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the RT-SIC-5G-CN interface module. In Figure1-21, two SIM cards are installed.
2.     Lift the cover up and away from the retainer, as shown by callout 2 in Figure1-21.
Figure1-21 Installing 5G SIM cards
·     SIC-CNDE-SJK
·     SIC-4G-CNDE-SJK
·     SIC-D4G-CNDE-SJK
SIC-CNDE-SJK
Introduction
The SIC-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers.
LEDs
Figure1-22 SIC-CNDE-SJK panel
Table1-30 LED description
LED
CNDE
·     Steady green: The module is operating correctly and is not sending or receiving data.
·     Flashing green: The module is operating correctly and is sending or receiving data.
·     Steady yellow: The module is faulty.
·     Off: The module is not installed securely, or no power is present.
SIC-4G-CNDE-SJK
Introduction
The SIC-4G-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-31 Interface specifications
Item
Connectors
3 × SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-23 SIC-4G-CNDE-SJK panel
Table1-32 LED description
LED
WWAN
·     Steady green: A link is present.
·     Fast flashing: Data is being transmitted or received.
·     Slowly flashing: The module is searching for wireless networks.
RSSI
·     Steady green: Strong signal strength (RSSI ≥ –69 dBm).
·     Fast flashing: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm).
·     Slowly flashing green: Low signal strength (–99 dBm ≤ RSSI < –89 dBm).
·     Off: Weak or no signal strength (RSSI < –99 dBm).
LTE
·     Steady green: The 4G-LTE service is running.
·     Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is running.
·     Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is running.
·     Off: No LTE service.
GPS
·     Steady green: The GPS service is running.
·     Off: No GPS service.
CNDE
For more information about SIC-4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing a Micro SIM card
CAUTION
CAUTION:
The SIC-4G-CNDE-SJK interface module supports Micro SIM cards.
The SIC-4G-CNDE-SJK has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
Figure1-24 Installing Micro SIM cards
SIC-D4G-CNDE-SJK
Introduction
The SIC-D4G-CNDE-SJK (D4G indicates that the module supports two SIM cards that can operate simultaneously; CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-D4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-33 Interface specifications
Item
Connectors
5 SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-25 SIC-D4G-CNDE-SJK panel
Table1-34 LED description
LED
WWAN
·     Fast flashing green: Data is being transmitted or received.
·     Slowly flashing green: The module is searching for wireless networks.
RSSI
·     Fast flashing green: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm).
LTE
·     Off: No LTE service is running.
GPS
·     Off: No GPS service is running.
CNDE
For more information about SIC-D4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE-SJK has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE-SJK interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure1-26 Installing Micro SIM cards
RT-SIC-M2-SATA
CAUTION
CAUTION:
·     The RT-SIC-M2-SATA module is hot swappable. To remove an RT-SIC-M2-SATA module, first press and hold the remove button for a minimum of three seconds. You can remove the module only when the remove LED is turned off. If the remove LED is flashing green, wait for the remove LED to turn off and then remove the module.
·     No M.2 SSD drive is provided with the RT-SIC-M2-SATA module. Purchase one as required.
·     To build a redundant array of independent disks (RAID), install two SSD drives of the same size in two RT-SIC-M2-SATA modules.
Introduction
The RT-SIC-M2-SATA module is an M.2 SSD riser SIC module that provides high data availability through RAID. RAID combines multiple physical drives into one logical drive to provide better storage performance and data backup than a single drive.
Module specifications
Table1-35 Module specifications
Item
Drive type
M.2 SATA SSD
Drive dimensions (D × W)
80 × 22 mm (3.15 × 0.87 in)
Number of drives
1
RAID level
RAID 1
Theoretical transmission rate
1.5/3/6 Gbps
Interface LEDs
Figure1-27 RT-SIC-M2-SATA panel
Table1-36 LED description
LED
Status
PWR
Steady green
The module has normal power input.
Off
The module does not have power input.
SSD
Steady green
A SSD drive is present.
Steady yellow
The SSD drive is damaged.
Off
No SSD drive is present.
ACT
The system is reading or writing data to the drive.
Off
The system is not reading or writing data to the drive.
REMOVE
·     The module is being initialized. Pressing the remove button or removing the module is not allowed.
·     A removal operation is being performed.
Steady green
The module is operating correctly. Pressing the remove button to remove the module is allowed.
Off
The module can be removed.
Installing an SSD drive on the module
CAUTION
CAUTION:
To use the RT-SIC-M2-SATA module, install an SSD drive in it.
To install an SSD drive on the module:
1.     Insert the SSD drive into the M.2 slot on the module at a 45° angle.
2.     Slightly press the SSD drive until it is level with the surface of the connector.
3.     Use a Phillips screwdriver to screw the SSD drive into place.
Figure1-28 Installing an SSD drive
CAUTION
CAUTION:
·     XMIM interface modules can be hot-swapped, with the exception of those with a remove button. To remove an XMIM SIC interface module with a remove button while the device is operating, first press and hold the remove button until the RUN LED is off.
·     Do not install, remove, or restart an XMIM interface module during an active/standby MSU switchover. To view the status of dual MSUs, execute the display system stable state command in any view.
·     To remove an XMIM while the device is operating, verify that the RUN LED on the module is steady green.
·     RT-XMIM-8GEE
·     RT-XMIM-8GEE-R
·     RT-XMIM-8GEF
·     RT-XMIM-8GEF-R
·     RT-XMIM-4XP
·     RT-XMIM-2XPF
The RT-XMIM-8GEE/RT-XMIM-8GEE-R is an 8-port GE copper port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEE/RT-XMIM-8GEE-R has the following features:
·     Provides a transmission distance of up to 100 m (328.08 ft) when used with category-5 twisted-pair cables.
·     The interfaces can operate at a data rate of 10 Mbps, 100 Mbps, or 1000 Mbps and support data rate auto-sensing.
·     Supports half-/full-duplex auto-negotiation.
The following table describes the interface specifications of the RT-XMIM-8GEE/RT-XMIM-8GEE-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-1 Interface specifications
Item
Connector type
RJ-45
8
Interface type
MDI/MDIX
Interface standard
802.3/802.3u/802.3ab
Cable
Straight-through and crossover Ethernet cable
Operating mode
Half/full-duplex auto-negotiation
Front panel and LEDs
The RT-XMIM-8GEE and RT-XMIM-8GEE-R front panels are as shown in the following figures.
Figure2-1 RT-XMIM-8GEE front panel
Figure2-2 RT-XMIM-8GEE-R front panel
The following table describes the LEDs on the RT-XMIM-8GEE/RT-XMIM-8GEE-R front panel.
Table2-2 LED description
LED
Status
LINK/ACT
Green LED: On
A link is present on the interface and the interface is operating in 1000 Mbps mode
Green LED: Flashing
The interface is transmitting or receiving data, and is operating in 1000 Mbps mode.
Yellow LED: On
A link is present on the interface and the interface is operating in 10 or 100 Mbps mode.
Yellow LED: Flashing
The interface is transmitting or receiving data, and is operating in 10 or 100 Mbps mode.
Off
No link is present on the port.
RUN
Steady green
The interface module is operating correctly.
The interface module is being identified.
Flashing green (1 Hz)
The device has successfully identified the interface module and has begun initializing the interface module.
Steady yellow
The interface module has failed to complete initialization.
Off
The interface module is faulty, has not been identified, or has been removed.
Interface cables and connection methods
For information about the Ethernet interface cables and connection methods, see "Ethernet interface."
The RT-XMIM-8GEF/RT-XMIM-8GEF-R is an 8-port GE fiber port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEF/RT-XMIM-8GEF-R has the following features:
·     Supports multiple types of transceiver modules, providing the flexibility for users to select the transceiver modules that meet their specific needs.
·     The interfaces can operate at a data rate of 100 Mbps or 1000 Mbps and support data rate auto-sensing.
The following table describes the interface specifications of the RT-XMIM-8GEF/RT-XMIM-8GEF-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-3 Interface specifications
Item
Interface quantity
8
Connector type
SFP/LC
Interface standard
Operating mode
100/1000 Mbps auto-sensing
The RT-XMIM-8GEF and RT-XMIM-8GEF-R front panels are as shown in the following figures.
Figure2-3 RT-XMIM-8GEF front panel
Figure2-4 RT-XMIM-8GEF-R front panel
The interface module provides a LED at the bottom of the front panel for each LED.
Table2-4 RT-XMIM-8GEF/RT-XMIM-8GEF-R LED description
LED
Status
LINK/ACT
Steady green
A link is present on the interface and the interface is operating in 1000 Mbps mode.
Flashing green
Steady yellow
A link is present on the interface and the interface is operating in 100 Mbps mode.
Flashing yellow
The interface is transmitting or receiving data, and is operating in 100 Mbps mode.
Off
No link is present on the interface.
RUN
Steady green
Steady yellow
Off
For more information about the transceiver modules, optical fibers, and connection methods, see "Fiber port."
RT-XMIM-4XP
The RT-XMIM-4XP is a 10GBASE-R Ethernet interface module that provides four SFP+ fiber ports. The interface module supports port type switching between standard Ethernet and FlexE. The FlexE mode allows flexible bandwidth assignment to meet different service requirements.
The following table describes the interface specifications of the RT-XMIM-4XP interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-5 Interface specifications
Item
Interface quantity
4
Connector type
SFP+/LC
Interface standard
10GBASE-R
Operating mode
1000 Mbps/10 Gbps auto-sensing, full duplex
The RT-XMIM-4XP front panel is as shown in the following figure.
Figure2-5 RT-XMIM-4XP front panel
Table2-6 RT-XMIM-4XP LED description
LED
Status
LINK/ACT
Steady green
A link is present on the interface and the interface is operating in 10 Gbps mode.
Flashing green
The interface is transmitting or receiving data, and is operating in 10 Gbps mode.
Steady yellow
Flashing yellow
Off
RUN
Steady green
Steady yellow
Off
RT-XMIM-2XPF
The RT-XMIM-2XPF is a 10GBASE-R Ethernet interface module that provides two SFP+ fiber ports. The interface module supports port type switching between standard Ethernet and FlexE. The FlexE mode allows flexible bandwidth assignment to meet different service requirements.
The following table describes the interface specifications of the RT-XMIM-2XPF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-7 Interface specifications
Item
Interface quantity
2
Connector type
SFP+/LC
Interface standard
10GBASE-R
Operating mode
The RT-XMIM-2XPF front panel is as shown in the following figure.
Figure2-6 RT-XMIM-2XPF front panel
Table2-8 RT-XMIM-2XPF LED description
LED
Status
LINK/ACT
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
RUN
Steady green
Steady yellow
Off
·     RT-XMIM-1POS
·     RT-XMIM-2POS
Introduction
The RT-XMIM-1POS/RT-XMIM-2POS is a 1/2-port packet over SDH/SONET (POS) XMIM interface module. The transmission rates of the modules are STM-1/OC-3 (155.52 Mbit/s) and STM-4/OC-12 (622.08 Mbit/s).
The RT-XMIM-1POS/RT-XMIM-2POS module supports PPP, frame relay, and HDLC at the data link layer and IP at the network layer. Interfaces on the RT-XMIM-1POS/RT-XMIM-2POS implements direct packet transmission over SONET/SDH.
Follow these restrictions and guidelines when using the RT-XMIM-1POS/RT-XMIM-2POS interface module:
·     You can use a command to set the POS interfaces on the interface module to operate in STM-1/OC-3 POS mode or STM-4/OC-12 POS mode. For more information about the command, see hardware resource management commands in System Management Command Reference for the router.
·     The setting of the POS interface-operating mode is applicable to the entire interface module, rather than being specific to an individual interface.
The following table describes the interface specifications of the RT-XMIM-1POS/RT-XMIM-2POS interface module.
Table2-9 RT-XMIM-1POS, RT-XMIM-2POS, and RT-XMIM-4POS interface specifications
Item
RT-XMIM-1POS
RT-XMIM-2POS
Interface standard
·     SONET OC-3/SDH STM-1
·     SONET OC-12/SDH STM-4
Interface quantity
1
2
Connector type
SFP/LC
Interface speed
155.52 Mbps,  622.08 Mbps
CAUTION
CAUTION:
When the RT-XMIM-2POS interface module is configured to operate in STM-4/OC-12 POS mode, only the interface marked 0 on the front panel is available, while the other interfaces are not available.
The T-XMIM-1POS and RT-XMIM-2POS front panels are as shown in the following figures.
Figure2-7 RT-XMIM-1POS front panel
Figure2-8 RT-XMIM-2POS front panel
The following table describes the LEDs on the front panel.
Table2-10 RT-XMIM-1POS/RT-XMIM-2POS LED description
LED
Status
ACT/ALM
Steady green
A link is present on the port.
Flashing green
The interface is receiving or sending data.
Steady yellow
A transceiver module has been installed in the interface, while an alarm is present on the interface.
Off
No transceiver module has been installed in the interface.
RUN
Steady green
The interface module is being identified, or the firmware is being updated.
Steady yellow
Off
RT-XMIM-1CPOS
Introduction
The RT-XMIM-1CPOS is a 1-port channelized SDH/SONET interface module. C stands for channelized, and POS for Packet over SDH/SONET. The RT-XMIM-1CPOS provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The following table describes the interface specifications of the RT-XMIM-1CPOS interface module.
Table2-11 RT-XMIM-1CPOS interface specifications
Item
Interface standard
Interface quantity
1
Connector type
SFP/LC
Interface speed
155.52 Mbps
The RT-XMIM-1CPOS front panel is as shown in the following figure.
Figure2-9 RT-XMIM-1CPOS front panel
Table2-12 RT-XMIM-1CPOS LED description
LED
Status
RUN
Steady green
The interface module is being identified or the firmware is being updated.
Steady yellow
Off
ACT/ALM
Steady green
Flashing green
Steady yellow
Off
·     RT-XMIM-2E1
·     RT-XMIM-4E1
·     RT-XMIM-8E1
When the RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface module changes to the fractional E1 (E1-F) mode, the interface module name displayed from the command output on the device will be changed to RT-XMIM-2E1-F/RT-XMIM-4E1-F/RT-XMIM-8E1-F accordingly.
Introduction
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 is a 2/4/8-port XMIM module that can operate in channelized E1 (CE1/PRI) mode or fractional E1 (E1-F) mode.
·     In channelized E1 (CE1/PRI) mode, the module can group the 31 channels in multiple ways to achieve different bundling configurations. Its primary function is to receive, transmit, and process E1 data streams while also providing CE1 access. In addition, it supports also ISDN PRI. These features enable multiple purposes to be achieved on a single module.
·     In non-channelized E1 mode, the module functions as a synchronous serial port with a data bandwidth of 2.048 Mbps and no timeslot division.
·     In fractional E1 (E1-F) mode, the module can only be bundled once (into a single channel with a speed of n × 64K, where n = 1 to 31), and does not support PRI mode.
The following table describes the interface specifications of the module.
Table2-13 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface specifications
Item
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
Connector type
RJ-45
RJ-45
RJ-45
2
4
8
Interface standard
G.703
Interface speed
2.048 Mbps
Cable
E1 120-ohm balanced twisted-pair cable (2m,15m, 30m)
75-ohm 8E1 repeater cable
Operating mode
Non-channelized E1(G.703)
Supported services
Backup
Endpoint access service
ISDN PRI
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 front panels are as shown in the following figures.
Figure2-10 RT-XMIM-2E1 module front panel
Figure2-11 RT-XMIM-4E1 module front panel
Figure2-12 RT-XMIM-8E1 module front panel
The module provides a green and a yellow LED for each interface.
Table2-14 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 LED description
LED
Status
LINK/ACT (green)
Steady green
Carrier signals are received.
Flashing green
The interface is sending or receiving data.
Off
No carrier signals are received.
LP/AL (yellow)
Steady yellow
The interface is in a loopback state.
Flashing yellow
The interface does not have a cable connected, the cable is faulty, or the peer device is faulty.
Off
RUN
Steady green
Steady yellow
Off
Jumper caps
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface module provides jumper caps, the installation status of which determines the interface impedance. By default, each pin pair is installed with a jumper cap and the impedance of an E1 interface is 75 ohms.
Figure2-13 Default installation status of jumper caps (RT-XMIM-8E1 as an example)
Every two interfaces on the interface module correspond to a jumper connector, and the pin settings are the same for the jumper connectors. You can set different impedance modes for the interfaces. For example, an RT-XMIM-8E1 interface module has four jumper connectors, with each jumper connector corresponding to two interfaces. The pins on a jumper connector are numbered PIN1 through PIN14. To set the impedance to 75 ohms for E1 interface 0, install jumper caps on pins 1 and 2, pins 3 and 4, and pins 5 and 6. To connect a 120-ohm cable to the E1 interface, remove the jumper caps from these pins. Table2-15 displays the mapping relations between pins on jumper connectors and E1 interfaces.
Table2-15 Mapping relations between pins on jumper connectors and E1 interfaces
Jumper connector
Pins
E1 interface
Supported interface modules
1
Pins 1 and 2, pins 3 and 4, pins 5 and 6
E1 interface 0
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
Pins 7 and 8, pins 9 and 10, pins 11 and 12
E1 interface 1
Pins 13 and 14
2
E1 interface 2
RT-XMIM-4E1
RT-XMIM-8E1
E1 interface 3
Pins 13 and 14
3
E1 interface 4
RT-XMIM-8E1
E1 interface 5
Pins 13 and 14
4
E1 interface 6
RT-XMIM-8E1
E1 interface 7
Pins 13 and 14
For more information about E1 interface cables and the connection methods, see "E1 interface.”
RT-XMIM-CNDE-SJK
Introduction
RT-XMIM-CNDE-SJK is an SCA SM encryption XMIM module. It supports SM1, SM3, and SM4 encryption algorithms, providing high-performance and high-reliability encryption features for routers.
Interface LEDs
Figure2-14 RT-XMIM-CNDE-SJK panel
Table2-16 RT-XMIM-CNDE-SJK LED description
LED
Status
RUN
Steady green
Flashing yellow (8 Hz)
The interface module resource is being released.
Steady green
Off
·     The interface module is faulty, has not been identified, or has been removed.
·     The interface module can be removed.
3 SSD modules
CAUTION
CAUTION:
The RT-SSD-960G SSD module can be hot-swapped. To remove an RT-SSD-960G SSD module on an operating device, first press and hold the remove button until the RUN LED is off.
RT-SSD-960G
Introduction
The RT-SSD-960G is a 960GB SSD module, which is mainly used for storage services.
Table3-1 Interface specifications
Item
Connector
SATA
Capacity
960 GB
Interface rate
3 Gbps
Interface LEDs
Figure3-1 RT-SSD-960G panel
Table3-2 LED description
LED
Status
RUN
Steady green
Flashing green (eight times per second)
The module is being identified.
Flashing yellow  (eight times per second)
The module resource is being released.
Steady yellow
The module has failed to complete initialization.
Off
·     The module has not been identified or has been removed.
·     The module can be removed.
Ethernet interface
Table4-1 Ethernet cable appearance and applicable models
Appearance
Applicable models
1 × RJ-45 < ---- > 1 × RJ-45
RT-SIC-4GSW-G
RT-XMIM-8GEE
RT-XMIM-8GEE-R
10/100 Mbps Ethernet uses category-5 twisted pair cables, and 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100BASE-T and 10BASE-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when working at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
For the pinouts of common twisted pair cables, see the following tables. (A and B represent the two ends of a cable respectively.)
Table4-2 Straight-through cable pinouts
Pinout No.
A
B
1
Orange/white
Orange/white
2
Orange
Orange
3
Green/white
Green/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Green
7
Brown/white
Brown/white
8
Brown
Brown
Table4-3 Crossover cable pinouts
Pinout No.
A
B
1
Orange/white
Green/white
2
Orange
Green
3
Green/white
Orange/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Orange
7
Brown/white
Brown/white
8
Brown
Brown
Strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables; otherwise, the communication quality may be affected.
1.     Connect one end of an Ethernet cable to an Ethernet interface on the module and the other end to the Ethernet interface on the peer device. Because the Ethernet interface of the module supports MDI/MDIX autosensing, you can use a straight-through cable or crossover cable to connect the interface.
2.     Check the status of the LED of the Ethernet interface after power-on. For the status of the LED, see the relevant part in this manual.
Fiber port
Optical interfaces must work with SFP or SFP+ transceiver modules and optical fibers with LC connectors. For more information about interface module and transceiver module compatibility, see H3C MSR Router Series Transceiver Module Compatibility Matrix.
CAUTION
CAUTION:
·     Never stare into an open optical Ethernet interface, because invisible rays may be emitted from the optical Ethernet interface.
·     Cover the dust cover if no optical fiber connector is connected to the optical Ethernet interface.
To connect an optical fiber:
1.     Insert the transceiver module to the interface on the interface module or service module.
2.     Identify the Rx and Tx ports on the transceiver module. Plug the LC connector at one end of one fiber cable into the Rx port of the router and the LC connector at the other end into the Tx port of the peer device. Plug the LC connector at one end of another fiber cable into the Tx port of the router and the LC connector at the other end to the Rx port of the peer device.
3.     View the LINK LED after connection.
¡     If the LED is on, the optical fiber link is present.
¡     If the LED is off, no link is present. This may be because the TX and Rx port of the optical fiber are not connected correctly. In this case, connect the optical fiber again.
E1 interface
To verify the impedance value of the E1 cable, view the label on the cable. The label location in Figure4-1 is for illustration only.
Figure4-1 E1 cable label
Table4-4 E1 cable appearance and applicable models
Cable
Appearance
Applicable models
1-port E1 75-ohm cable
图一 1端口E1 75欧姆电缆
1 × D15 < ---- > 2 × BNC
SIC-E1-F
1-port E1 120-ohm cable (2 m, 15 m, 30 m)-RJ-45
RT-SIC-2E1-G
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
2-port E1 75-ohm cable
图三  2端口E1 75欧姆电缆
1 × D15 < ---- > 4 × BNC
SIC-2E1-F
1-port E1 75-ohm cable-RJ-45
RT-SIC-2E1-G
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
图六  75欧姆中继电缆
1 × BNC < ---- > 1 × BNC
Use as needed
Coaxial connector
图七  同轴连接器
Use as needed
Impedance converter
图八 阻抗转换器
2 × BNC < ---- > 1 × RJ-45
Use as needed
CAUTION
CAUTION:
Make sure you insert the cable into the right interface so as to avoid damages to the interface module or the chassis.
·     If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows:
a.     Connect the D15/D68 connector of the E1 75-ohm cable to the D15/D68 interface of the interface module and fasten the bolts to fix the cable.
b.     The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure4-2 Connect an E1 75-ohm cable
·     If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure4-3 Connect an E1 75-ohm cable
·     If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure4-4 Connect an impedance converter
1.     Connect the D25 connector of the 4-port E1 75-ohm cable to the D25 interface of the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four D15 connectors. Connect them to the D15 interfaces on the remote device as needed.
Figure4-5 Connect an 4-port E1 75-ohm cable
1.     Connect the D15 connector of the E1 120-ohm cable to the D15 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides one or multiple RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure4-6 Connecting an E1 120-ohm cable
Table4-5 DB15 to BNC/RJ-45 pinouts
DB15
BNC (75-ohm coaxial cable)
RJ-45 (120-ohm twisted pair cable)
9
Tx Tip
Tx Tip
4
Tx Tip
2
Tx Ring
Tx Ring
5
Tx Ring
10
Tx Shield
N/A
6
Tx Shield
8
Rx Tip
Rx Tip
1
Rx Tip
15
Rx Ring
Rx Ring
2
Rx Ring
7
Rx Shield
N/A
3
Rx Shield
1.     Connect the D25 connector of the 4-port E1 120-ohm cable to the D25 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four D15 connectors. Connect them to the D15 interface on the remote device as needed.
Figure4-7 Connecting a 4-port E1 120-ohm cable
Table4-6 Appearance and applicable models of synchronous/asynchronous serial port cables
Cable
Appearance
Applicable models
V.24 DTE cable
1 × D25 (male) < ---- > 1 × D28
SIC-2SAE
SIC-4SAE
V.24 DCE cable
1 × D25 (female) < ---- > 1 × D28
V.35 DTE cable
1 × D28 < ---- > 1 × D34 (male)
V.35 DCE cable
1 × D28 < ---- > 1 × D34 (female)
X.21 DTE cable
1 × D15 (male) < ---- > 1 × D28
X.21 DCE cable
1 × D15 (female) < ---- > 1 × D28
RS-449 DTE cable
1 × D28 < ---- > 1 × D37 (male)
RS-449 DCE cable
1 × D28 < ---- > 1 × D37 (female)
RS-530 DTE cable
RS-530 DCE cable
1.     Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2.     Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3.     If the WAN uses DDN line, connect the cable to the port of CSU/DSU.
4.     Check the LINK LED on the SAE panel.
¡     If the LED is on, a link is present.
¡     If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Table4-7 Appearance and applicable models of asynchronous serial port cables
Cable
Appearance
Applicable models
8-port asynchronous serial port adapter cable
图九 8端口异步串口转接电缆
1 × D60 < ---- > 8 × RJ-45 (female)
SIC-8AS
4-port asynchronous serial port adapter cable
图十  4端口异步串口转接电缆
1 × D28 < ---- > 4 × RJ-45 (female)
SIC-16AS
To connect the SIC-8AS interface module, connect the D60 connector of the 8-port asynchronous serial port adapter cable to the SIC-8AS interface module.
To connect the SIC-16AS interface module, connect the D28 connector of the 4-port asynchronous serial port adapter cable to the SIC-16AS interface module, which allows up to four such cables.
Choose the cable connection type according to the remote device type:
·     If the remote device is a network device with a console port, connect the console port to the RJ-45 interface of the asynchronous serial port adapter cable by using a serial server cable. The sequence is shown in the following figure:
Figure4-8 Connecting a network device
·     If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the asynchronous serial port adapter cable. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a D25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure4-9 Connecting the dumb terminal device
·     If the interface of the remote device, usually a modem, is a D25/D9 interface, use the AUX cable to connect the asynchronous serial port adapter cable to the interface:
Figure4-10 Connecting a modem
4G interface
Table4-8 Appearance and applicable models of the 4G antennas and extension cables
Antenna and cable
Appearance
Applicable models
4G antenna
4G antenna
RT-SIC-4G-CAT6
cid:20251027_14953552_image005_2680897_294551_0.jpg@01D68CDF.2C973130
RT-SIC-4G-CAT6
Table4-9 Antenna specifications
Item
Specifications
RT-SIC-4G-CAT6
Frequency scope
791 to 960 MHz
1710 to 2690 MHz
617 to 960 MHz
1400 to 1612 MHz
1710 to 2170 MHz
2300 to 2700 MHz
3300 to 3800 MHz
4400 to 5000 MHz
5150 to 5850 MHz
Voltage standing wave ratio
≤ 3.5
≤ 4
Input impedance
50 ohms
50 ohms
Gain
791 to 960 MHz @ 3.1 dBi
1710 to 2690 MHz @ 7.2dBi
617 to 960 MHz/0.59 dBi
1400 to 1612 MHz/1.87 dBi
1710 to 2170 MHz/3.74 dBi
2300 to 2700 MHz/3.51 dBi
3300 to 3800 MHz/3.7 dBi
4400 to 5000 MHz/4.0 dBi
5150 to 5850 MHz/4.87 dBi
Polarization type
Vertical
Vertical
Maximum input power
1 W
1 W
SMA
SMA, male
Height
16.6 cm (6.54 in)
20.3 cm (7.99 in)
Weight
22 g (0.78 oz)
19.63 g (0.69 oz)
Color
Black
Black
Operating temperature
–10°C to +60°C (14°F to 140°F)
–20°C to +65°C (–4°F to +149°F)
Table4-10 4G antenna extension cable specifications for the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK module
Item
Specification
Frequency scope
698 to 960 MHz
1710 to 2700 MHz
≤ 2.0
Input impedance
50 ohms
Gain
2.0 dBi
Polarization type
Vertical
SMA
Height
16.4 ± 0.2 cm (6.46 ± 0.08 in)
Weight
134 ± 5 g (4.73 ± 0.18 oz)
Color
Black
Cable length
200 ± 2 cm (78.74 ± 0.79 in)
–40°C to +60°C (–40°F to +140°F)
Table4-11 4G antenna extension cable specifications for the RT-SIC-4G-CAT6 module
Item
Specification
Frequency range
DC to 6 GHz
≤ 5
Input impedance
50 ohms
Cable type
RG-174
Max input power
1 W
SMA
Cable length
3000 mm (118.11 in)
Weight
65.3 g (2.30 oz)
Color
Black
–40°C to +85°C (–40°F to +185°F)
Connection methods of 4G antennas and antenna extension cables
For how to install a 4G antenna and antenna extension cable for the SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, or SIC-D4G-CNDE-SJK module, see H3C MSR 4G SIC Modules SIM Card&Antenna&Antenna Extension Cable Installation Guides. (You can also obtain the document at official website https://www.h3c.com/en/Support/Resource_Center/EN/Home/Routers/00-Public/Install___Upgrade/Installation_Guides/H3C_MSR_4G_SIC_modules_SIM/.)
For how to install a 4G antenna and antenna extension cable for the RT-SIC-4G-CAT6 module, see H3C MSR 4G SIC-4G-CAT6 Module SIM Card&Antenna&Antenna Extension Cable Installation Guides. (You can also obtain the document at official website https://www.h3c.com/en/Support/Resource_Center/EN/Home/Routers/00-Public/Install___Upgrade/Installation_Guides/H3C_MSR_4G_SIC-4G-CAT6/.)
5G interface
Stick antenna varies by hardware version. Figures in this section are for illustration only.
Appearance and applicable models of stick antennas and antenna extension cables
Table4-12 Appearance and applicable models of the antennas and extension cables
Name
Appearance
Applicable models
Stick antenna A
cid:image004.jpg@01D68CDF.2C973130
RT-SIC-5G
Stick antenna B
RT-SIC-5G-CN
Stick antenna C
RT-SIC-5G-CN
3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base)
RT-SIC-5G
RT-SIC-5G-CN
1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base)
RT-SIC-5G
RT-SIC-5G-CN
10 cm (3.94 in) cable
RT-SIC-5G
RT-SIC-5G-CN
5 m (16.40 ft)/10 m (32.81 ft) antenna extension cable
RT-SIC-5G
RT-SIC-5G-CN
Antenna bracket
RT-SIC-5G
RT-SIC-5G-CN
Table4-13 Stick antenna A specifications
Item
Frequency range
698 to 960 MHz
1710 to 2170 MHz
2300 to 2700 MHz
3300 to 3800 MHz
4400 to 5000 MHz
5150 to 5850 MHz
≤ 4
Input impedance
50 ohms
Gain
617 MHz to 960 MHz, 0.59 dBi
1710 MHz to 2170 MHz, 3.74 dBi
2300 MHz to 2700 MHz, 3.51 dBi
3300 MHz to 3800 MHz, 3.7 dBi
4400 MHz to 5000 MHz, 4.0 dBi
5150 MHz to 5850 MHz, 4.87 dBi
Polarization type
Vertical
Maximum input power
1 W
SMA male
Height
203 mm (7.99 in)
Weight
19.63 g (0.69 oz)
Color
Black
–20 °C to +65 °C (–4°F to +149°F)
Table4-14 Stick antenna B specifications
Item
Frequency range
0.6 to 6 GHz
≤ 6
Input impedance
50 ohms
Gain (max.)
2.74 dBi @ 0.617 to 0.96 GHz
1.01 dBi @ 1.4 to 1.612 GHz
4.48 dBi @ 1.71 to 2.17 GHz
3.98 dBi @ 2.3 to 2.7 GHz
4.74 dBi @ 3.3 to 4.0 GHz
5.50 dBi @ 4.0 to 5.0 GHz
5.82 dBi @ 5.15 to 5.85 GHz
Polarization type
Vertical
Maximum input power
1 W
SMA male
Height
17.6 cm (6.93 in)
Weight
20 g (0.71 oz)
Color
Black
–20°C to +70°C (–4°F to +158°F)
Table4-15 Stick antenna C specifications
Item
Frequency range
0.6 to 5 GHz
2.8 MAX
Input impedance
50 ohms
Gain (max.)
0.24 dBi @ 0.617 to 0.96 GHz
2.32 dBi @ 1.4 to 1.612 GHz
1.89 dBi @ 1.71 to 2.17 GHz
3.00 dBi @ 2.3 to 2.7 GHz
4.18 dBi @ 3.3 to 4.0 GHz
4.18 dBi @ 4.0 to 5.0 GHz
Polarization type
Linear
Maximum input power
10 W
SMA male
Height
22.93 cm (9.03 in)
Weight
27.5 g (0.97 oz)
Color
Black
Table4-16 3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 5
Input impedance
50 ohms
Cable type
RG-174
Max input power
1 W
SMA
Cable length
3000 mm (118.11 in)
Weight
65.3 g (2.30 oz)
Color
Black
Table4-17 1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.7
Input impedance
50 ohms
Cable type
RG-174
SMA
Cable length
1 m (3.28 ft)
Weight
202 g (7.13 oz)
Color
Black
Table4-18 10 cm (3.94 in) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.2 @ (3 GHz)
≤ 1.4 @ (3 to 6 GHz)
Input impedance
50 ohms
Cable type
RG-174
SMA
Cable length
10 cm (3.94 in)
Color
Black
Table4-19 5 m (16.40 ft) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
< 1.2 @ (0.3 to 2.4 GHz)
< 1.4 @ (5 to 6 GHz)
Input impedance
50 ohms
Cable type
RG8
SMA
Cable length
5 m (16.40 ft)
Color
White
Table4-20 10 m (32.81 ft) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.2 @ (2.4 GHz)
≤ 1.5 @ (5 to 6 GHz)
Input impedance
50 ohms
Cable type
RG8
SMA
Cable length
10 m (32.81 ft)
Color
White
Connection methods of stick antennas and antenna extension cables
Different antenna configuration schemes and installation methods are used depending on the required antenna extension cable length and application scenario. For more information, see H3C MSR 5G SIC Modules SIM Card&Antenna&Antenna Extension Cable Installation Guides. (You can also obtain the document at official website https://www.h3c.com/en/Support/Resource_Center/EN/Home/Public/00-Public/Technical_Documents/Install___Upgrade/Installation_Guides/H3C_MSR_5G_SIC_SIM-5828/?CHID=1046959.)
GPS interface
Appearance and applicable models of the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK interface module GPS antenna
Table4-21 Appearance and applicable models of the 4G interface module GPS antenna
Antenna
Appearance
Applicable models
GPS antenna
SIC-4G-CNDE
SIC-D4G-CNDE
SIC-4G-CNDE-SJK
SIC-D4G-CNDE-SJK
Table4-22 Antenna specifications
Item
Specification
Frequency scope
1575.42 ± 3 MHz
≤ 1.92
Input impedance
50 ohms
Gain
1.5 dBic Typ
Echo return loss
10 dB Min
SMA
Extension cable length
5 m (16.40 ft)
Extension cable type
RG-174 Coaxial Cable
Color
Black
–30°C to +80°C (–22°F to +176°F)
Connecting an antenna extension cable
1.     Fasten the SMA connector onto the GPS antenna port on the module.
2.     Put the other end of the extension cable outdoor to achieve better signal coverage.
GNSS interface
Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Table4-23 Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Antenna
Appearance
Applicable models
GNSS antenna
RT-SIC-4G-CAT6
Table4-24 RT-SIC-4G-CAT6 module GNSS antenna specifications
Item
Specification
Frequency scope
·     1561±3 MHz
·     1575.42±3 MHz
·     1602±0.5 MHz
Operating mode
·     GPS
·     GLONASS
·     BDS
·     Galileo
Input impedance
50 ohms
Gain
–2.91 dBic Typ
SMA male
5 m (16.40 ft)
RG-174 coaxial cable
Color
Black
Connecting a GNSS antenna
1.     Fasten the SMA male connector of the antenna extension cable onto the GNSS antenna port on the module.
2.     Connect the other end of the extension cable to the antenna. Place the antenna outdoors for better signal receipt.
5 Link mode of interfaces on Ethernet switching modules and interface modules
An interface can operate in bridge or route link mode.
You can use the port link-mode command to change the link mode of an interface. Interfaces that operate in bridge mode are called Layer 2 interfaces. Interfaces that operate in route mode are called Layer 3 interfaces.
By default, the interfaces on all interface modules operate in route mode. The interfaces on some interface modules support link mode change from route to bridge on specific routers.
For example, the interfaces on an RT-SIC-4GSW-G interface module operate in route mode by default. When the interface module is installed on an MSR3610-G-X3, MSR3610-G-X3-DC, MSR3610-G-X3-DP, or MSR3610-G-X3-DP-DC router, the interfaces support link mode change  from route to bridge.
For information about the supported link modes of interfaces on interface modules, see Table5-1.
Table5-1 Supported link modes of interfaces on interface modules
Ethernet switching module/Ethernet interface module
Interfaces
RT-SIC-4GSW-G
GE0 to GE3
Route mode
If the module is installed on an MSR3610-G-X3, MSR3610-G-X3-DC, MSR3610-G-X3-DP, or MSR3610-G-X3-DP-DC router, the interfaces on it support link mode change from route to bridge.
RT-SIC-4GSWF-G
GE0 to GE3
Operates as Layer 3 interfaces.
If the module is installed on an MSR3610-G-X3, MSR3610-G-X3-DC, MSR3610-G-X3-DP, or MSR3610-G-X3-DP-DC router, the interfaces support link mode change and can operate as Layer 2 interfaces.
RT-SIC-1XPF-G
GE0
Route mode
RT-XMIM-8GEE
GE0 to GE7
If the module is installed on an MSR5680-X3 router (MSU-400-G), the interfaces support link mode change and can operate as Layer 2 interfaces.
RT-XMIM-8GEE-R
GE0 to GE7
RT-XMIM-8GEF
SFP0 to SFP7
RT-XMIM-8GEF-R
SFP0 to SFP7
RT-XMIM-4XP
SFP+0 to SFP+3
RT-XMIM-2XPF
SFP+0 and SFP+1
Operates only as Layer 3 interfaces.
6 Frequency bands for 4G/5G interface modules
IMPORTANT
IMPORTANT:
Support for each frequency band varies by mobile communication modem module model used by the interface module. The following tables are for your reference only.
Table6-1 Frequency bands for 4G/5G interface modules (1)
Interface module
CDMA
GSM
LTE-TDD
LTE-FDD
SIC-4G-CNDE
CDMA1x: BC0
B2/B3/B5/B8
B38/B39/B40/B41
B1/B3/B5/B7/B8
SIC-D4G-CNDE
CDMA1x: BC0
B2/B3/B5/B8
B38/B39/B40/B41
B1/B3/B5/B7/B8
RT-SIC-4G-CAT6
N/A
N/A
B38/B40/B41
B1/B3/B5/B7/B8/B20/B28/B32
RT-SIC-5G
N/A
N/A
B34/B38/B39/B40/B41/B42/B43/B48
B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71
RT-SIC-5G-CN
N/A
N/A
B34/B38/B39/B40/B41
B1/B3/B5/B8
Table6-2 Frequency bands for 4G/5G interface modules (2)
Interface module
TD-SCDMA
WCDMA
5G NR
LAA
SIC-4G-CNDE
B34/B39
B1/B8
N/A
N/A
SIC-D4G-CNDE
B34/B39
B1/B8
N/A
N/A
RT-SIC-4G-CAT6
N/A
B1/B3/B5/B8
N/A
N/A
RT-SIC-5G
N/A
B1/B2/B3/B4/B5/B8/B19
NSA: n38/n41/n71/n77/n78/n79
SA: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48/n66/n71/n77/n78/n79
B46
RT-SIC-5G-CN
N/A
B1/B5/B8
NSA: n41/n78/n79
SA: n1/n3/n5/n8/n28A/n41/n77/n78/n79
N/A
7 Interface module net weights and power consumption
Table7-1 Interface module net weights and power consumption
Interface module model
Net weight
Min power consumption
Max power consumption
RT-SIC-4GSW-G
0.10 kg (0.22 lb)
2.30 W
3.91 W
RT-SIC-4GSWF-G
0.23 kg (0.51 lb)
1.88 W
3.97 W
RT-SIC-1XPF-G
0.10 kg (0.22 lb)
10.42 W
10.43 W
SIC-E1-F
0.10 kg (0.22 lb)
N/A
0.40 W
SIC-2E1-F
0.10 kg (0.22 lb)
N/A
0.40 W
RT-SIC-2E1-G
0.15 kg (0.33 lb)
2.74 W
2.98 W
SIC-8AS
0.10 kg (0.22 lb)
N/A
3.40 W
SIC-16AS
0.10 kg (0.22 lb)
N/A
0.80 W
SIC-2SAE
N/A
N/A
3.40 W
SIC-4SAE
N/A
N/A
3.40 W
SIC-4G-CNDE
0.15 kg (0.33 lb)
N/A
4.20 W
SIC-D4G-CNDE
0.10 kg (0.22 lb)
3.41 W
6.60 W
SIC-CNDE-SJK
N/A
N/A
5.50 W
SIC-4G-CNDE-SJK
0.10 kg (0.22 lb)
N/A
6.60 W
SIC-D4G-CNDE-SJK
0.10 kg (0.22 lb)
N/A
4.20 W
RT-SIC-4G-CAT6
0.15 kg (0.33 lb)
2.79 W
4.80 W
RT-SIC-5G
0.25 kg (0.55 lb)
1.32 W
7.60 W
RT-SIC-5G-CN
0.25 kg (0.55 lb)
N/A
10.30 W
RT-SIC-M2-SATA
0.15 kg (0.33 lb)
2.80 W
4.80 W
RT-XMIM-8GEE
0.72 kg (1.59 lb)
7.70 W
12.00 W
RT-XMIM-8GEE-R
0.65 kg (1.43 lb)
5.12 W
8.80 W
RT-XMIM-8GEF
0.72 kg (1.59 lb)
10.10 W
14.00 W
RT-XMIM-8GEF-R
0.65 kg (1.43 lb)
10.00 W
13.00 W
RT-XMIM-4XP
0.75 kg (1.65 lb)
N/A
20.00 W
RT-XMIM-2XPF
0.76 kg (1.68 lb)
12.70 W
15.00 W
RT-XMIM-1POS
0.60 kg (1.32 lb)
8.70 W
9.70 W
RT-XMIM-2POS
0.60 kg (1.32 lb)
9.76 W
10.30 W
RT-XMIM-1CPOS
0.64 kg (1.41 lb)
8.80 W
11.00 W
RT-XMIM-2E1
0.60 kg (1.32 lb)
4.30 W
5.00 W
RT-XMIM-4E1
0.65 kg (1.43 lb)
4.60 W
5.40 W
RT-XMIM-8E1
0.65 kg (1.43 lb)
6.44 W
6.80 W
RT-XMIM-CNDE-SJK
0.65 kg (1.43 lb)
12.00 W
12.50 W
RT-SSD-960G
0.50 kg (1.10 lb)
9.00 W
11.00 W
