| 03-Appendix B Purchase guide | 87.36 KB |
This appendix describes the interface module compatibility with H3C MSR series routers. In the tables, "Yes" means "Supported" and "No" means "Not supported."
SIC purchase guide
IMPORTANT: · Layer 2 communication across slots is not supported between SIC Ethernet switching modules or between SIC Ethernet switching modules and HMIM Ethernet switching modules. · The PoE feature of a PoE interface module takes effect only when the PoE interface module is installed on a PoE device. When installed on a non-PoE device, the PoE interface module can only be used as a Layer 2 forwarding interface module. · The following routers do not support China Network Data Encryption (CNDE) modules when they are installed with a SIC-4G-CNDE or SIC-D4G-CNDE interface module: MSR2630E-X1, MSR2680-XS, MSR3610E-X1, MSR3610E-X1-DP, and MSR3620-G-X3. |
Table1-1 SIC compatibility with H3C MSR series routers
SIC model |
MSR2630E-X1/MSR2680-XS |
MSR3610E-X1/MSR3610E-X1-DP |
MSR3610-G-X3/MSR3610-G-X3-DC/MSR3610-G-X3-DP/MSR3610-G-X3-DP-DC |
MSR3620-G-X3 |
MSR5680-X3 (MSU-200) |
RT-SIC-4GSW-G |
No |
No |
Yes |
Yes |
No |
RT-SIC-4GSWF-G |
No |
No |
Yes |
Yes |
No |
RT-SIC-1XPF-G |
No |
No |
Yes (supported only in slots 1 and 2) |
No |
SIC-E1-F |
Yes |
Yes |
No |
No |
No |
SIC-2E1-F |
Yes |
Yes (a maximum of two supported) |
No |
No |
No |
RT-SIC-2E1-G |
Yes |
Yes (supported only in slots 1 and 3) |
Yes |
Yes |
No |
SIC-2SAE |
Yes |
Yes (a maximum of one supported) |
No |
SIC-4SAE |
No |
No |
SIC-8AS |
Yes |
Yes |
Yes |
Yes |
No |
SIC-16AS |
Yes |
Yes |
Yes |
Yes |
No |
SIC-4G-CNDE |
Yes |
Yes (supported only in slots 1, 2, and 3) |
Yes (supported only in slot 1) |
No |
RT-SIC-4G-CAT6 |
No |
No |
No |
SIC-D4G-CNDE |
Yes |
No |
SIC-CNDE-SJK |
Yes |
No |
SIC-4G-CNDE-SJK |
Yes |
No |
SIC-D4G-CNDE-SJK |
Yes |
No |
RT-SIC-5G |
Yes |
Yes |
RT-SIC-5G-CN |
Yes |
No |
RT-SIC-M2-SATA |
Yes |
No |
XMIM purchase guide
Table1-2 XMIM compatibility with MSR series routers
XMIM model |
MSR3620-G-X3 |
MSR5680-X3 (MSU-100) |
MSR5680-X3 (MSU-400-G) |
RT-XMIM-8GEE |
Yes |
No |
No |
Yes |
RT-XMIM-8GEE-R |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-8GEF |
Yes |
No |
No |
Yes |
RT-XMIM-8GEF-R |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-4XP |
Yes |
No |
No |
Yes |
RT-XMIM-2XPF |
Yes |
No |
No |
Yes |
RT-XMIM-1POS |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-2POS |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-1CPOS |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-2E1 |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-4E1 |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-8E1 |
Yes |
Yes |
Yes |
Yes |
RT-XMIM-CNDE-SJK |
Yes |
No |
No |
No |
SSD module purchase guide
Table1-3 SSD module compatibility with MSR series routers
SSD module model |
RT-SSD-960G |
No |
No |
Yes (supported only in slots 4 and 5) |
