06-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration GuidesH3C CR16000-M Routers Configuration Guides-R8630Pxx-6W10006-Layer 3—IP Routing Configuration Guide
13-Routing policy configuration
13-Routing policy configuration 271.55 KB
Configuring routing policies
About routing policies
Routing policies control routing paths by filtering and modifying routing information.
Routing policies can filter advertised, received, and redistributed routes, and modify attributes for specific routes.
Implementation of a routing policy
To configure a routing policy:
1.     Define route filters—Configure filters based on route attributes.
2.     Apply route filters—Create a routing policy and apply filters to the routing policy.
Filters
Routing policies can use the following filters to match routes.
ACL
An access control list (ACL) can match the destination or next hop of routes.
For more information about ACLs, see ACL configuration in ACL and QoS Configuration Guide.
IP prefix list
An IP prefix list matches the destination address of routes.
An IP prefix list can contain multiple items that specify prefix ranges. Each destination IP address prefix of a route is compared with these items in ascending order of their index numbers. A prefix matches the IP prefix list if it matches one item in the list.
AS path list
An AS path list matches the AS_PATH attribute of BGP routes. The AS_PATH attribute identifies the ASs through which a route has passed.
For more information about the AS_PATH attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
Community list
A community list matches the COMMUNITY attribute of BGP routes. The COMMUNITY attribute identifies the community of BGP routes.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration and network maintenance.
For more information about community lists, see BGP configuration in Layer 3—IP Routing Configuration Guide.
Large community list
A large community list matches the large community attribute (12 bytes in aa:bb:cc format) of BGP routes. A large community attribute value is a 12-byte string in GlobalAdministration:LocalData1:LocalData2 format. The large community attribute has the following advantages:
·     It can denote two-ocet and four-ocet AS numbers entirely.
·     It contains two four-ocet local data attribute identifiers.
You can use the large community attribute together with the COMMUNITY attribute for flexible application of routing policies and control over route advertisement and reception.
For more information about the large community attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
Extended community list
An extended community list matches the extended community attribute of BGP routes.
To meet new demands, BGP defines the extended community attribute. The device supports the route target, link bandwidth, color, and Site of Origin (SoO) extended community attributes.
For information about route target, see MPLS L3VPN configuration in MPLS Configuration Guide.
For information about the color attribute, see SR-MPLS TE policy configuration in Segment Routing Configuration Guide.
For information about the link bandwidth or SoO attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
RD list
A route distinguisher (RD) list matches the RD of routes. After you add an RD as a prefix to an IPv4 address prefix, the address prefix becomes a unique VPN-IPv4 address prefix.
An RD list is identified by an RD list number and can contain multiple items that specify RD ranges. Each item is identified by an index number. The RD of a route is compared with these items in ascending order of their index numbers. An RD matches the RD list if it matches one item in the list.
For information about RD, see MPLS L3VPN configuration in MPLS Configuration Guide.
Routing policy
A routing policy can contain multiple nodes, which are in a logical OR relationship. A node with a smaller number is matched first. A route matches the routing policy if it matches one node (except the node configured with the continue clause) in the routing policy.
Each node has a match mode of permit or deny.
·     permit—Specifies the permit match mode for a routing policy node. If a route meets all the if-match clauses of the node, it is handled by the apply clauses of the node. The route is not compared with the next node unless the continue clause is configured. If a route does not meet all the if-match clauses of the node, it is compared with the next node. To pass a routing policy, a route must match a permit node of that routing policy.
·     deny—Specifies the deny match mode for a routing policy node. The apply and continue clauses of a deny node are never executed. If a route meets all the if-match clauses of the node, it is denied without being compared with the next node. If a route does not meet all the if-match clauses of the node, it is compared with the next node.
A node can contain a set of if-match, apply, and continue clauses.
·     if-match clauses—Specify the match criteria that match the attributes of routes. The if-match clauses of different types are in a logical AND relationship and the if-match clauses of the same type are in a logical OR relationship. A route must meet if-match clauses of all types to match the node.
·     apply clauses—Specify the actions to be taken on permitted routes, such as modifying a route attribute.
·     continue clause—Specifies the next node. A route that matches the current node (permit node) must match the specified next node in the same routing policy. The continue clause combines the if-match and apply clauses of the two nodes to improve flexibility of the routing policy. After you configure a continue clause, a route continues to match against the subsequent nodes if it does not match the specified next node. To prevent such a route from matching against other nodes, add a clause-less deny node following the specified next node.
Follow these guidelines when you configure if-match, apply, and continue clauses:
·     If you only want to filter routes, do not configure apply clauses.
·     If you do not configure any if-match clauses for a permit node, the node will permit all routes.
·     Configure a permit node containing no if-match or apply clauses following multiple deny nodes to allow unmatched routes to pass.
Restrictions and guidelines: Routing policy configuration
When you use a routing policy associated with prefix lists to filter EVPN routes, only the following EVPN routes cannot match prefix lists:
·     Type 2 routes (also called MAC/IP advertisement routes) carrying the IP field.
·     Type 5 routes (also called IP prefix advertisement routes).
Other types of EVPN routes can match prefix lists. The action taken by the routing policy on those routes depends on the match mode:
·     If the match mode is permit, those routes are permitted.
·     If the match mode is deny, those routes are denied.
To filter out certain types of EVPN routes, use the if-match route-type command. For example, to filter out EVPN aggregate routes advertised to neighbors without affecting Type 1 routes (also called Ethernet auto-discovery routes), add the if-match route-type bgp-evpn-ip-prefix configuration for the related routing policy node.
Routing policy tasks at a glance
To configure a routing policy, perform the following tasks:
1.     (Optional.) Configure filters:
¡     Configuring an IPv4 prefix list
¡     Configuring an IPv6 prefix list
¡     Configuring an AS path list
¡     Configuring a community list
¡     Configuring a large community list
¡     Configuring an extended community list
¡     Configuring an RD list
2.     Configuring a routing policy:
a.     Creating a routing policy
b.     Configuring if-match clauses
c.     Configuring apply clauses
d.     Configuring the continue clause
3.     (Optional.) Configuring the routing policy change delay timer
4.     (Optional.) Enabling interactive notifications about non-existent routing policy settings
An IPv4 prefix list is used to filter IPv4 addresses. It can contain multiple items, each of which specifies a range of IPv4 prefixes. The relation between the items is logical OR. A route can pass an IPv4 prefix list as long as it successfully matches an item. If the route cannot match any item, the IPv4 prefix list cannot be passed.
If the ip-address mask-length argument is specified as 0.0.0.0 0, only the default route will be matched. To match all routes, use 0.0.0.0 0 less-equal 32.
If all the items are set to deny mode, no routes can pass the IPv4 prefix list. To permit unmatched IPv4 routes, you must configure the permit 0.0.0.0 0 less-equal 32 item following multiple deny items.
2.     Configure an IPv4 prefix list.
An IPv6 prefix list is used to filter IPv6 addresses. An IPv6 prefix list can have multiple items, and each of them specifies a range of IPv6 prefixes. The relation between the items is logical OR. A route passing an item passes the IPv6 prefix list. A route passing no item cannot pass the IPv6 prefix list.
If the ipv6-address prefix-length argument is specified as :: 0, only the default route matches. To match all routes, configure :: 0 less-equal 128.
If all items are set to deny mode, no routes can pass the IPv6 prefix list. To permit unmatched IPv6 routes, you must configure the permit :: 0 less-equal 128 item following multiple deny items.
2.     Configure an IPv6 prefix list.
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address { inverse inverse-prefix-length | prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] }
The AS_PATH attribute identifies the ASs through which a BGP route has passed. Figure 1 shows the AS_PATH attribute format in the BGP routing table.
Figure 1 AS_PATH attribute
The AS_PATH attribute value is a character string containing digits, parentheses, brackets, braces, and spaces. It is a sequence of the following AS path segments:
·     AS_CONFED_SEQUENCE—Ordered set of member AS numbers in the local confederation that the UPDATE message has traversed.
·     AS_CONFED_SET—Unordered set of member AS numbers in the local confederation that the UPDATE message has traversed.
·     AS_SEQUENCE—Ordered set of ASs a route in the UPDATE message has traversed.
·     AS_SET—Unordered set of ASs a route in the UPDATE message has traversed.
The AS_PATH attribute of a BGP route might not contain all of the four AS path segments.
An AS path list consists of regular expressions used for filtering BGP routes by their AS_PATH attributes. A regular expression can contain the special characters described in Table 1.
Table 1 Special characters supported in a regular expression
Character
Example
Matches the beginning of a line.
Match a local route if its AS_PATH attribute is null:
ip as-path { as-path-number| as-path-name } { deny | permit } ^$
Matches the end of a line.
Match a route if it is originated from AS 100:
ip as-path { as-path-number | as-path-name } { deny | permit } 100$
Matches any single character.
Match a route if it has passed AS 100 but is not originated or received from AS 100:
ip as-path { as-path-number | as-path-name } { deny | permit } ._100_.
Matches the preceding character or string zero, one, or multiple times.
Match a route if it has an AS_PATH attribute:
ip as-path { as-path-number | as-path-name } { deny | permit } .*
Matches the preceding character or string one or multiple times.
Match a route if its AS_PATH attribute value contains 5:
ip as-path { as-path-number | as-path-name } { deny | permit } 5+
x|y
Matches the preceding or succeeding string.
Match a route if it is originated from AS 100 or AS 200:
ip as-path { as-path-number | as-path-name } { deny | permit } 100$|200$
Matches the string in the parentheses, usually used together with the plus sign (+) or asterisk sign (*).
Match a route if its AS_PATH attribute value contains 123:
ip as-path { as-path-number | as-path-name } { deny | permit } (123)+
[xyz]
Matches a single character in the brackets.
Match a route if it is received from AS 10 through AS 19:
ip as-path { as-path-number | as-path-name } { deny | permit } ^1[0-9]$
[^xyz]
Matches a single character that is not in the brackets.
Match a route if its originating AS number does not end with 2 or 4:
ip as-path { as-path-number | as-path-name } { deny | permit } [^24]$
{n}
Matches the preceding character n times. The number n must be a nonnegative integer.
Match a route if its AS_PATH attribute value contains two 5:
ip as-path { as-path-number | as-path-name } { deny | permit } 5{2}
{n,}
Matches the preceding character n times or more. The number n must be a nonnegative integer.
Match a route if its AS_PATH attribute value contains two or more consecutive 5:
ip as-path { as-path-number | as-path-name } { deny | permit } 5{2,}
{n,m}
Matches the preceding character n to m times or more. The numbers n and m must be nonnegative integers and n cannot be greater than m.
Match a route if its AS_PATH attribute value contains one or more consecutive 5:
ip as-path { as-path-number | as-path-name } { deny | permit } 5{1,2}
[a-z]
Matches a single character within the specified range for only once.
Match a route if its AS_PATH attribute value contains 0, 1, or 2:
ip as-path { as-path-number | as-path-name } { deny | permit }[0-2]
[^a-z]
Matches a single character that is not in the specified range.
Match a route if its AS_PATH attribute value contains digits other than 0, 1, or 2:
ip as-path { as-path-number | as-path-name } { deny | permit }^ [^0-2]$
_
Matches a punctuation. The expression can begin or end with _.
Match a route if it has passed AS101 100:
ip as-path { as-path-number | as-path-name } { deny | permit } 101_100_
\b
Matches a word that starts with the pattern following \b or ends with the pattern preceding \b.
ip as-path { as-path-number | as-path-name } { deny | permit } \b100$
\B
Matches a word that contains the pattern but does not start or end with the pattern.
Match a route if its AS_PATH attribute value starts with 1:
ip as-path { as-path-number | as-path-name } { deny | permit } ^1\B
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
N/A
\w
Same as [A-Za-z0-9_], matches a digit, letter, or underscore.
Match a route if its AS_PATH attribute value contains double digits:
ip as-path { as-path-number | as-path-name } \w{2}
\W
Same as [^A-Za-z0-9_], matches a character that is not a digit, letter, or underscore.
N/A
\index
Matches the specified string in the parentheses followed by \ twice. Each string in the parentheses is numbered from 1 in order. The index argument represents the sequence number of the string you want to match. If the parentheses contain n strings, you can specify the sequence number of the string in the range of 1 to n.
Match a route if its AS_PATH attribute value contains two consecutive 1:
ip as-path { as-path-number | as-path-name } (1)\1
The regular expressions shown in Table 1 are used for illustration only. Other regular expressions might be available to achieve the same effect.
You can configure multiple items for an AS path list that is identified by a number. The relationship between the items is logical OR. A route matches the AS path list if it matches one item in the list.
2.     Configure an AS path list.
ip as-path { as-path-number | as-path-name } { deny | permit } regular-expression
You can configure multiple items for a community list that is identified by a number. The relationship between the items is logical OR. A route matches the community list if it matches one item in the list.
An advanced community list matches the community attributes of BGP routes based on the regular expressions described in "Configuring an AS path list."
2.     Configure a community list.
¡     Configure a basic community list.
¡     Configure an advanced community list.
You can configure multiple items for a large community list. The relationship between the items is logical OR. A route matches the large community list if it matches one item in the list.
An advanced large community list matches the large community attributes of BGP routes based on the regular expressions described in "Configuring an AS path list."
2.     Configure a large community list.
¡     Configure a basic large community list.
ip large-community-list { basic-large-comm-list-num | basic basic-large-comm-list-name } { deny | permit } aa:bb:cc&<1-32>
¡     Configure an advanced large community list.
ip large-community-list { adv-large-comm-list-num | advanced adv-large-comm-list-name } { deny | permit } regular-expression
You can configure multiple items for an extended community list that is identified by a number. The relationship between the items is logical OR. A route matches the extended community list if it matches one item in the list.
An extended community list matches the RT or SoO attributes of BGP routes based on the regular expressions described in "Configuring an AS path list."
2.     Configure an extended community list.
¡     Configure an RT or SoO community list.
ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] { deny | permit } { bandwidth link-bandwidth-value | rt route-target | soo site-of-origin }&<1-32>
¡     Specify a regular expression to filter RT or SoO community attributes.
ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] { deny | permit } { rt | soo } advanced regular-expression
RD lists are used to filter VPN routing information. You can configure multiple items for an RD list that is identified by a number. The relationship between the items is logical OR. A route matches the RD list if it matches one item in the list.
2.     Configure an RD list.
A routing policy must have a minimum of one permit node. If all the nodes are in deny mode, no routes can pass the routing policy.
2.     Create a routing policy and a node, and enter routing policy node view.
3.     (Optional.) Prevent BGP routes from passing a routing policy that does not exist.
a.     Return to system view.
b.     Prevent BGP routes from passing a routing policy that does not exist.
route-policy non-exist-deny
By default, all routes can pass a routing policy that does not exist.
This command takes effect only on BGP routes. If you enable this feature and use a routing policy that does not exist for route filtering, non-BGP routes can still pass the routing policy.
4.     (Optional.) Enable consistency check between the IP version in routing information and the IP version of the prefix list specified by an if-match clause. Routing information with a different IP version does not match the clause.
route-policy prefix-protocol-check
By default, the routing policy does not check the IP protocol consistency between routes and the prefix list specified in an if-match clause:
¡     If the if-match clause uses an IPv6 address prefix list, all IPv4 routes can match the clause.
¡     If the if-match clause uses an IPv4 address prefix list, all IPv6 routes can match the clause.
You can either specify no if-match clauses or multiple if-match clauses for a routing policy node. If no if-match clause is specified for a permit node, all routes can pass the node. If no if-match clause is specified for a deny node, no routes can pass the node.
When you configure if-match clauses, follow these restrictions and guidelines:
·     The if-match clauses of a routing policy node have a logical AND relationship. A route must meet all if-match clauses before it can be executed by the apply clauses of the node. If an if-match command exceeds the maximum length, multiple if-match clauses of the same type are generated. These clauses have a logical OR relationship. A route only needs to meet one of them.
·     All IPv4 routes match a node if the if-match clauses of the node use only IPv6 ACLs. All IPv6 routes match a node if the if-match clauses of the node use only IPv4 ACLs.
·     If the ACL used by an if-match clause does not exist or the ACL is not configured with any rules, the clause is always matched. When the ACL of an if-match clause is configured with rules, a route cannot match the if-match clause in one of the following scenarios:
¡     The route cannot match any rule of the ACL.
¡     The route matches a deny-mode rule of the ACL.
·     If the prefix list, AS path list, community list, large community list, extended community list, or RD list used by an if-match clause does not exist, the clause is always matched. The clause is not mat‌ched if one of the following conditions exists:
¡     No rules of the specified prefix list, AS path list, community list, extended community list, or RD list are matched.
¡     The specified list is in deny mode.
·     The rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command can create a rule for an advanced ACL to match specific routes. The source sour-addr sour-wildcard option represents the destination network address and the destination dest-addr dest-wildcard option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
2.     Enter routing policy node view.
3.     Match routes whose destination, next hop, or source address matches an ACL or prefix list.
IPv4:
if-match ip { address | next-hop | route-source } { acl { ipv4-acl-number | name ipv4-acl-name } | prefix-list prefix-list-name }
IPv6:
if-match ipv6 { address | next-hop | route-source } { acl { ipv6-acl-number | name ipv6-acl-name } | prefix-list prefix-list-name }
By default, no ACL or prefix list match criterion is configured.
The ACL specified in an if-match clause must be a non-VPN ACL.
4.     Configure BGP route match criteria.
¡     Match BGP routes whose AS_PATH attribute matches a specified AS path list.
if-match as-path { as-path-number&<1-32> | as-path-name }
¡     Match BGP routes whose COMMUNITY attribute matches a specified community list.
if-match community { { basic-community-list-number [ whole-match ] | name comm-list-name [ whole-match | unorder-match ] } | adv-community-list-number [ unorder-match ] }&<1-32>
¡     Match BGP routes with a large community attribute in the specified large community list.
if-match large-community { { basic-large-comm-list-number | name large-comm-list-name } [ whole-match ] | adv-large-comm-list-number }&<1-32>
¡     Match BGP routes whose extended community attribute matches a specified extended community list.
if-match extcommunity ext-comm-list-name&<1-32>
¡     Match BGP routes having the specified local preference.
¡     Match BGP routes with the specified RPKI validation state.
By default, no BGP route match criteria are configured.
5.     Configure route match criteria.
¡     Match routes having the specified cost.
if-match cost cost-value
¡     Match routes having the specified output interface.
This command is not supported by BGP.
¡     Match routes having MPLS labels.
if-match mpls-label
By default, no MPLS label match criterion is set.
¡     Match routes having the specified route type.
if-match route-type { bgp-evpn-ad | bgp-evpn-imet | bgp-evpn-ip-prefix | bgp-evpn-mac-ip | ebgp | eigrp-external | eigrp-internal | external-type1 | external-type1or2 | external-type2 | ibgp | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
¡     Match IGP routes having the specified tag value.
if-match tag tag-value
¡     Match routes of the specified routing protocol.
if-match protocol { bgp | direct | eigrp | isis | ospf | ospfv3 | rip | ripng | static | unr } *
By default, no route match criteria are configured.
6.     Match routes whose RD matches the specified RD list.
By default, no RD match criterion is configured.
7.     Match routes by using a routing policy.
if-match route-policy route-policy-name
By default, no routing policy is specified to match routes.
3.     Configure BGP route attributes.
¡     Set the AS_PATH attribute for BGP routes.
apply { as-path as-number&<1-32> [ delete | replace ] | clear }
¡     Delete the specified COMMUNITY attribute for BGP routes.
By default, no COMMUNITY attribute is deleted for BGP routes.
¡     Set the specified COMMUNITY attribute for BGP routes.
¡     Set the large community attribute for BGP routes.
apply large-community { aa:bb:cc&<1-8> [ additive ] | additive | none }
¡     Remove the large community attribute from BGP routes.
apply large-comm-list { large-comm-list-number | large-comm-list-name } delete
¡     Set the extended community attribute for BGP routes.
apply extcommunity { bandwidth link-bandwidth-value | { rt route-target }&<1-32> } [ additive ]
¡     Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
¡     Set the SoO extended community attribute for BGP routes.
¡     Set a local preference for BGP routes.
¡     Set the ORIGIN attribute for BGP routes.
¡     Set a preferred value for BGP routes.
¡     Set the maximum number of BGP Add-Path optimal routes.
apply additional-paths best-number
¡     Set a traffic index for BGP routes.
¡     Set the AIGP attribute for BGP routes.
apply aigp { cost-value | igp-cost }
By default, no BGP route attributes are configured.
4.     Configure the route cost and cost type.
¡     Set a cost for routes.
By default, no cost is set for routes.
¡     Set a cost type for routes.
apply cost-type { external | internal | type-1 | type-2 }
By default, no cost type is set for routes.
5.     Set the next hop for routes.
¡     IPv4:
apply ip-address next-hop { ip-address [ public | vpn-instance vpn-instance-name ] | advertiser-address }
By default, no next hop is set for routes.
If you use the ip-address argument to set a next hop, the configuration does not take effect on redistributed routes.
¡     IPv6:
apply ipv6 next-hop { ipv6-address | advertiser-address }
If you use the ipv6-address argument to set a next hop, the configuration does not take effect on redistributed routes.
6.     Configure a gateway address for EVPN IP prefix advertisement routes.
IPv4:
apply gateway-ip { ip-address | origin-nexthop }
IPv6:
apply ipv6 gateway-ip { ipv6-address | origin-nexthop }
By default, no gateway address is configured for EVPN IP prefix advertisement routes.
7.     Configure route priorities.
¡     Set an IP precedence for matching routes.
By default, no IP precedence is set.
¡     Set a preference.
apply preference preference
By default, no preference is set.
¡     Set a prefix priority.
By default, the prefix priority is low.
8.     Redistribute routes to the specified IS-IS level.
By default, routes are not redistributed into the specified IS-IS level.
9.     Set MPLS labels.
apply mpls-label
By default, no MPLS label is set.
10.     Set a label index value or SID value.
¡     Set a label index value.
apply label-index index-value
By default, no label index value is set.
¡     Set an SID value.
apply label-value label-value
By default, no SID value is set.
11.     Set a local QoS ID for matching routes.
apply qos-local-id { local-id-value | clear }
By default, no local QoS ID is set.
12.     Set a tag value for IGP routes.
apply tag tag-value
By default, no tag value is set for IGP routes.
13.     Set a backup link for fast reroute (FRR).
IPv4:
IPv6:
By default, no backup link is set for FRR.
14.     Set a flexible algorithm ID for routes.
apply flex-algo flex-algo-id
By default, no flexible algorithm ID is configured for routes.
When you configure the continue clause to combine multiple nodes, follow these restrictions and guidelines:
·     If you configure an apply clause that sets different attribute values on all the nodes, the apply clause of the node configured most recently takes effect.
·     If you configure the following apply clauses on all the nodes, the apply clause of each node takes effect:
¡     apply as-path without the replace or clear keyword.
¡     apply cost with the + or keyword.
¡     apply community with the additive keyword.
¡     apply large-community with the additive keyword.
¡     apply extcommunity with the additive keyword.
·     The apply comm-list delete clause configured on the current node cannot delete the community attributes set by the apply community clauses of the preceding nodes.
·     The apply as-path delete or apply as-path clear clause configured on the current node deletes or clears the AS numbers added or replaced by the apply as-path clauses of the preceding nodes.
·     The apply large-comm-list delete clause configured on the current node cannot delete the large community attributes set by the apply large-community clauses of the preceding nodes.
3.     Specify the next node to be matched.
continue [ node-number ]
By default, no continue clause is configured.
The specified next node must have a larger number than the current node.
This feature makes a routing policy take effect after a delayed time interval, which prevents incomplete routing policy configuration from being issued to cause incorrect route advertisement. The system automatically starts the timer when a routing policy changes. The changes will not take effect on the policy until the change delay timer expires.
A routing policy changes when one of the following events occurs:
·     A routing policy is created.
·     A routing policy node, if-match clause, or apply clause is added, modified, or deleted for a routing policy.
·     You add, modify, or delete an IPv4 prefix list, IPv6 prefix list, AS path list, community list, extended community list, or MAC address list.
·     The ACL used by an if-match clause changes.
2.     Set the routing policy change delay timer.
route-policy-change delay-time { time-value | unlimited }
By default, routing policy changes immediately take effect, but the routing protocol waits five seconds before processing routes from the new routing policy.
When the delay timer expires, the routing protocol waits five seconds before processing routes from the new routing policy.
If a non-existent routing policy is used for route filtering or a non-existent ACL or prefix list is associated with an if-match clause, all routes can match the non-existent routing policy or if-match clause.
For example, if you associate a non-existent prefix list with an if-match clause, all routes might be permitted or denied by the related routing policy.
To avoid the above issue, use this feature to enable interactive notifications about non-existent routing policies, ACLs, and prefix lists. When you apply a non-existent routing policy, or associate a non-existent ACL or prefix list to an if-match clause, you must enter Y or N for configuration confirmation.
·     To issue the configuration, enter Y.
·     To cancel the configuration, enter N.
2.     Enable interactive notifications about non-existent routing policy settings.
route-policy nonexistent-config-confirm enable
By default, interactive notifications about non-existent routing policy settings are enabled.
Display and maintenance commands for routing policies
Display BGP AS path list information.
display ip as-path [ as-path-number | as-path-name ]
Display BGP community list information.
Display BGP large community list information.
display ip large-community-list [ basic-large-comm-list-number | adv-large-comm-list-number | name large-comm-list-name ]
Display BGP extended community list information.
display ip extcommunity-list [ ext-comm-list-number | ext-comm-list-name ]
Display IPv4 prefix list statistics.
Display RD list information.
Display IPv6 prefix list statistics.
Display routing policy information.
display route-policy [ name route-policy-name  [ node node-number ] ]
Clear BGP AS path list statistics.
reset ip as-path [ as-path-number | as-path-name ]
Clear IPv4 prefix list statistics.
Clear IPv6 prefix list statistics.
Routing policy configuration examples
Example: Configuring a routing policy for IPv4 route redistribution
As shown in Figure 2, Router B exchanges routing information with Router A by using OSPF and with Router C by using IS-IS.
On Router B, enable route redistribution from IS-IS to OSPF. Use a routing policy to set the cost of route 172.17.1.0/24 to 100 and the tag of route 172.17.2.0/24 to 20.
Figure 2 Network diagram
Table 2 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet3/0/1
Interface2
Ten-GigabitEthernet3/0/2
Interface3
Ten-GigabitEthernet3/0/3
Interface4
Ten-GigabitEthernet3/0/4
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Router C.
<RouterC> system-view
[RouterC] isis
[RouterC-isis-1] is-level level-2
[RouterC-isis-1] network-entity 10.0000.0000.0001.00
[RouterC-isis-1] quit
[RouterC] interface ten-gigabitethernet 3/0/1
[RouterC-Ten-GigabitEthernet3/0/1] isis enable
[RouterC-Ten-GigabitEthernet3/0/1] quit
[RouterC] interface ten-gigabitethernet 3/0/2
[RouterC-Ten-GigabitEthernet3/0/2] isis enable
[RouterC-Ten-GigabitEthernet3/0/2] quit
[RouterC] interface ten-gigabitethernet 3/0/3
[RouterC-Ten-GigabitEthernet3/0/3] isis enable
[RouterC-Ten-GigabitEthernet3/0/3] quit
[RouterC] interface ten-gigabitethernet 3/0/4
[RouterC-Ten-GigabitEthernet3/0/4] isis enable
[RouterC-Ten-GigabitEthernet3/0/4] quit
# Configure Router B.
<RouterB> system-view
[RouterB] isis
[RouterB-isis-1] is-level level-2
[RouterB-isis-1] network-entity 10.0000.0000.0002.00
[RouterB-isis-1] quit
[RouterB] interface ten-gigabitethernet 3/0/2
[RouterB-Ten-GigabitEthernet3/0/2] isis enable
[RouterB-Ten-GigabitEthernet3/0/2] quit
3.     Configure OSPF and route redistribution:
# Configure OSPF on Router A.
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[RouterA-ospf-1] quit
# On Router B, configure OSPF and enable route redistribution from IS-IS to OSPF.
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[RouterB-ospf-1] import-route isis 1
[RouterB-ospf-1] quit
# Display the OSPF routing table on Router A to view the redistributed routes.
[RouterA] display ospf routing
          OSPF Process 1 with Router ID 192.168.1.1
                   Routing Tables
 Routing for Network
 Destination        Cost     Type    NextHop        AdvRouter     Area
 192.168.1.0/24     1        Transit 192.168.1.1    192.168.1.1   0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag        NextHop        AdvRouter
 172.17.1.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 172.17.2.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 172.17.3.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 Total Nets: 4
 Intra Area: 1  Inter Area: 0  ASE: 3  NSSA: 0
4.     Configure filtering lists on Router B:
# Configure IPv4 basic ACL 2002 to permit route 172.17.2.0/24.
[RouterB] acl basic 2002
[RouterB-acl-ipv4-basic-2002] rule permit source 172.17.2.0 0.0.0.255
[RouterB-acl-ipv4-basic-2002] quit
# Configure IP prefix list prefix-a to permit route 172.17.1.0/24.
[RouterB] ip prefix-list prefix-a index 10 permit 172.17.1.0 24
5.     Configure a routing policy on Router B.
[RouterB] route-policy isis2ospf permit node 10
[RouterB-route-policy-isis2ospf-10] if-match ip address prefix-list prefix-a
[RouterB-route-policy-isis2ospf-10] apply cost 100
[RouterB-route-policy-isis2ospf-10] quit
[RouterB] route-policy isis2ospf permit node 20
[RouterB-route-policy-isis2ospf-20] if-match ip address acl 2002
[RouterB-route-policy-isis2ospf-20] apply tag 20
[RouterB-route-policy-isis2ospf-20] quit
[RouterB] route-policy isis2ospf permit node 30
[RouterB-route-policy-isis2ospf-30] quit
6.     Apply the routing policy to route redistribution on Router B:
# On Router B, enable route redistribution from IS-IS to OSPF and apply the routing policy.
[RouterB] ospf
[RouterB-ospf-1] import-route isis 1 route-policy isis2ospf
# Display OSPF routing table information on Router A.
                   Routing Tables
 Routing for Network
 Routing for ASEs
 172.17.1.0/24      100      Type2   1           192.168.1.2   192.168.2.2
 172.17.2.0/24      1        Type2   20          192.168.1.2   192.168.2.2
 Total Nets: 4
The output shows that the cost of route 172.17.1.0/24 is 100 and the tag of route 172.17.2.0/24 is 20.
Example: Configuring a routing policy for IPv6 route redistribution
As shown in Figure 3:
·     Run RIPng on Router A and Router B.
·     Configure three static routes on Router A.
·     On Router A, apply a routing policy to redistribute static routes 20::/32 and 40::/32 and deny route 30::/32.
Figure 3 Network diagram
Table 3 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
1.     Configure Router A:
# Configure IPv6 addresses for interfaces Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2.
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 10::1 32
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 11::1 32
[RouterA-Ten-GigabitEthernet3/0/2] quit
# Enable RIPng on Ten-GigabitEthernet 3/0/1.
[RouterA-Ten-GigabitEthernet3/0/1] ripng 1 enable
# Configure three static routes with next hop 11::2, and make sure the static routes are active.
[RouterA] ipv6 route-static 20:: 32 11::2
[RouterA] ipv6 route-static 30:: 32 11::2
[RouterA] ipv6 route-static 40:: 32 11::2
# Configure a routing policy.
[RouterA] ipv6 prefix-list a index 10 permit 30:: 32
[RouterA] route-policy static2ripng deny node 0
[RouterA-route-policy-static2ripng-0] if-match ipv6 address prefix-list a
[RouterA-route-policy-static2ripng-0] quit
[RouterA] route-policy static2ripng permit node 10
[RouterA-route-policy-static2ripng-10] quit
# Enable RIPng and apply routing policy static2ripng to filter redistributed static routes on Router A.
[RouterA] ripng
[RouterA-ripng-1] import-route static route-policy static2ripng
[RouterA-ripng-1] quit
2.     Configure Router B:
# Configure the IPv6 address of Ten-GigabitEthernet 3/0/1.
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 10::2 32
# Enable RIPng.
[RouterB] ripng
[RouterB-ripng-1] quit
# Enable RIPng on the interface.
[RouterB-Ten-GigabitEthernet3/0/1] ripng 1 enable
[RouterB-Ten-GigabitEthernet3/0/1] quit
# Display the RIPng routing table on Router B.
[RouterB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect, D – Direct
                O - Optimal, F - Flush to RIB
 Peer FE80::7D58:0:CA03:1 on Ten-GigabitEthernet3/0/1
 Destination 20::/32,
     via FE80::7D58:0:CA03:1, cost 1, tag 0, A, 8 secs
 Destination 40::/32,
     via FE80::7D58:0:CA03:1, cost 1, tag 0, A, 3 secs
 Local route
 Destination 10::/32,
     via ::, cost 0, tag 0, DOF
