- 06-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-BGP configuration
- 03-DCN configuration
- 04-EIGRP configuration
- 05-IPv6 policy-based routing configuration
- 06-IPv6 static routing configuration
- 07-IS-IS configuration
- 08-OSPF configuration
- 09-OSPFv3 configuration
- 10-Policy-based routing configuration
- 11-RIP configuration
- 12-RIPng configuration
- 13-Routing policy configuration
- 14-Static routing configuration
| 09-OSPFv3 configuration | 1.35 MB |
Comparison of OSPFv3 with OSPFv2
Enabling a lightweight OSPFv3 process
Configuring OSPFv3 area parameters
Configuring an OSPFv3 virtual link
Configuring OSPFv3 network types
Restrictions and guidelines for OSPFv3 network type configuration
Setting the broadcast network type for an OSPFv3 interface
Setting the NBMA network type for an OSPFv3 interface
Setting the P2MP network type for an OSPFv3 interface
Setting the P2P network type for an OSPFv3 interface
Configuring OSPFv3 route control
Configuring OSPFv3 inter-area route summarization
Configuring redistributed route summarization
Configuring OSPFv3 received route filtering
Configuring Inter-Area-Prefix LSA filtering
Filtering outbound LSAs on an OSPFv3 interface
Filtering the LSAs to be advertised to an OSPFv3 neighbor
Setting an OSPFv3 cost for an interface
Changing the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold
Enabling OSPFv3 to adjust the interface cost according to the link quality
Enabling OSPFv3 to advertise the maximum link cost to neighbors
Setting the maximum number of OSPFv3 ECMP routes
Setting a preference for OSPFv3
Configuring OSPFv3 route redistribution
Adjusting the route tag settings to prevent routing loops
Configuring default route redistribution
Advertising OSPFv3 link state information to BGP
Configuring the OSPFv3 link tag feature
Configuring OSPFv3 to advertise network performance parameters
About OSPFv3 network performance parameters
Advertising link delay information
Advertising link bandwidth information
Configuring OSPFv3 flexible algorithm
About OSPFv3 flexible algorithm
OSPFv3 flexible algorithm tasks at a glance
Mapping an affinity attribute name to an affinity bit
Assigning affinity attributes to OSPFv3 links
Configuring a flexible algorithm
Configuring the metric type of a flexible algorithm
Configuring flexible algorithm FRR
Configuring flexible algorithm TI-LFA FRR
Set the priority of an FRR backup path selection policy for flexible algorithm
Applying a flexible algorithm to SRv6
Setting the LSA transmission delay
Setting the SPF calculation interval
Setting the LSA reception interval
Setting the LSA generation interval
Setting a DR priority for an interface
Configuring OSPFv3 packet parameters
Ignoring MTU check for DD packets
Setting the DSCP value for outgoing OSPFv3 packets
Disabling interfaces from receiving and sending OSPFv3 packets
Accelerating OSPFv3 convergence speed
Configuring prefix suppression
Configuring OSPFv3 advanced features
Configuring the virtual system feature
Enabling OSPFv3 to adjust the interface cost according to the BFD session state
Suppressing interface cost adjustment according to the BFD session state upon BFD session flapping
Configuring OSPFv3 FRR to use the LFA algorithm to calculate a backup next hop
Configuring OSPFv3 FRR to use a backup next hop in a routing policy
Setting the priority for FRR backup path selection policies
Configuring BFD control packet mode for OSPFv3 FRR
Configuring BFD echo packet mode for OSPFv3 FRR
Configuring OSPFv3 authentication
Applying an IPsec profile for authenticating OSPFv3 packets
Configuring OSPFv3 logging and SNMP notifications
Enabling logging for neighbor state changes
Setting the maximum number of OSPFv3 logs
Configuring OSPFv3 network management
Display and maintenance commands for OSPFv3
OSPFv3 configuration examples
Example: Configuring OSPFv3 stub area
Example: Configuring OSPFv3 NSSA area
Example: Configuring OSPFv3 DR election
Example: Configuring OSPFv3 route redistribution
Example: Configuring OSPFv3 route summarization
Example: Configuring OSPFv3 GR
Example: Configuring BFD for OSPFv3
Example: Configuring OSPFv3 FRR
Example: Configuring OSPFv3 IPsec profile
Configuring OSPFv3
About OSPFv3
This chapter describes how to configure Open Shortest Path First version 3 (OSPFv3) for an IPv6 network.
OSPFv3 and OSPFv2 have the following in common:
· 32-bit router ID and area ID.
· Hello, Database Description (DD), Link State Request (LSR), Link State Update (LSU), Link State Acknowledgment (LSAck).
· Mechanisms for finding neighbors and establishing adjacencies.
· Mechanisms for advertising and aging LSAs.
OSPFv3 and OSPFv2 have the following differences:
· OSPFv3 runs on a per-link basis. OSPFv2 runs on a per-IP-subnet basis.
· OSPFv3 supports running multiple processes on an interface, but OSPFv2 does not support.
· OSPFv3 identifies neighbors by router ID. OSPFv2 identifies neighbors by IP address.
For more information about OSPFv2, see "Configuring OSPF."
OSPFv3 packets
OSPFv3 uses the following packet types:
· Hello—Periodically sent to find and maintain neighbors, containing timer values, information about the DR, BDR, and known neighbors.
· DD—Describes the digest of each LSA in the LSDB, exchanged between two routers for data synchronization.
· LSR—Requests needed LSAs from the neighbor. After exchanging the DD packets, the two routers know which LSAs of the neighbor are missing from their LSDBs. They then send an LSR packet to each other, requesting the missing LSAs. The LSA packet contains the digest of the missing LSAs.
· LSU—Transmits the requested LSAs to the neighbor.
· LSAck—Acknowledges received LSU packets.
OSPFv3 LSA types
OSPFv3 sends routing information in LSAs. The following LSAs are commonly used:
· Router LSA—Type-1 LSA, originated by all routers. This LSA describes the collected states of the router's interfaces to an area, and is flooded throughout a single area only.
· Network LSA—Type-2 LSA, originated for broadcast and NBMA networks by the DR. This LSA contains the list of routers connected to the network, and is flooded throughout a single area only.
· Inter-Area-Prefix LSA—Type-3 LSA, originated by ABRs and flooded throughout the LSA's associated area. Each Inter-Area-Prefix LSA describes a route with IPv6 address prefix to a destination outside the area, yet still inside the AS.
· Inter-Area-Router LSA—Type-4 LSA, originated by ABRs and flooded throughout the LSA's associated area. Each Inter-Area-Router LSA describes a route to ASBR.
· AS External LSA—Type-5 LSA, originated by ASBRs, and flooded throughout the AS, except stub areas and Not-So-Stubby Areas (NSSAs). Each AS External LSA describes a route to another AS. A default route can be described by an AS External LSA.
· NSSA LSA—Type-7 LSA, originated by ASBRs in NSSAs and flooded throughout a single NSSA. NSSA LSAs describe routes to other ASs.
· Link LSA—Type-8 LSA. A router originates a separate Link LSA for each attached link. Link LSAs have link-local flooding scope. Each Link LSA describes the IPv6 address prefix of the link and Link-local address of the router.
· Intra-Area-Prefix LSA—Type-9 LSA. Each Intra-Area-Prefix LSA contains IPv6 prefix information on a router, stub area, or transit area information, and has area flooding scope. It was introduced because Router LSAs and Network LSAs contain no address information.
· Intra-Area-TE LSA—Type-10 LSA, generated by a router configured with an IPv6 router ID or a router in an OSPFv3 area enabled with MPLS TE. Intra-Area-TE LSAs generated by a router configured with an IPv6 router ID contain basic link state information, IPv6 Router ID, neighbor ID, local interface's IPv6 address, and remote interface's IPv6 address. Intra-Area-TE LSAs generated by a router in an OSPFv3 area enabled with MPLS TE contain TE attribute information.
· Grace LSA—Type-11 LSA, generated by a GR restarter at reboot and transmitted on the local link. The GR restarter describes the cause and interval of the reboot in the Grace LSA to notify its neighbors that it performs a GR operation.
Protocols and standards
· RFC 2328, OSPF Version 2
· RFC 3101, OSPF Not-So-Stubby Area (NSSA) Option
· RFC 4552, Authentication/Confidentiality for OSPFv3
· RFC 5187, OSPFv3 Graceful Restart
· RFC 5286, Basic Specification for IP Fast Reroute: Loop-Free Alternates
· RFC 5329, Traffic Engineering Extensions to OSPF Version 3
· RFC 5340, OSPF for IPv6
· RFC 5523, OSPFv3-Based Layer 1 VPN Auto-Discovery
· RFC 5643, Management Information Base for OSPFv3
· RFC 6506, Supporting Authentication Trailer for OSPFv3
· RFC 6565, OSPFv3 as a Provider Edge to Customer Edge (PE-CE) Routing Protocol
· RFC 6969, OSPFv3 Instance ID Registry Update
· RFC 7166, Supporting Authentication Trailer for OSPFv3
OSPFv3 tasks at a glance
To configure OSPFv3, perform the following tasks:
2. (Optional.) Enabling a lightweight OSPFv3 process
3. (Optional.) Configuring OSPFv3 area parameters
¡ Configuring an OSPFv3 virtual link
Perform this task on an ABR to create a virtual link when connectivity cannot be maintained between a non-backbone area and the backbone, or within the backbone.
4. (Optional.) Configuring OSPFv3 network types
¡ Setting the broadcast network type for an OSPFv3 interface
¡ Setting the NBMA network type for an OSPFv3 interface
¡ Setting the P2MP network type for an OSPFv3 interface
¡ Setting the P2P network type for an OSPFv3 interface
5. (Optional.) Configuring OSPFv3 route control
¡ Configuring OSPFv3 inter-area route summarization
¡ Configuring OSPFv3 received route filtering
¡ Configuring Inter-Area-Prefix LSA filtering
¡ Filtering outbound LSAs on an OSPFv3 interface
¡ Filtering the LSAs to be advertised to an OSPFv3 neighbor
¡ Setting an OSPFv3 cost for an interface
¡ Changing the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold
¡ Enabling OSPFv3 to adjust the interface cost according to the link quality
¡ Enabling OSPFv3 to advertise the maximum link cost to neighbors
¡ Setting the maximum number of OSPFv3 ECMP routes
¡ Setting a preference for OSPFv3
¡ Configuring OSPFv3 route redistribution
¡ Adjusting the route tag settings to prevent routing loops
¡ Configuring default route redistribution
¡ Advertising OSPFv3 link state information to BGP
¡ Configuring the OSPFv3 link tag feature
6. (Optional.) Configuring OSPFv3 to advertise network performance parameters
¡ Advertising link delay information
¡ Advertising link bandwidth information
7. (Optional.) Configuring OSPFv3 flexible algorithm
8. (Optional.) Setting OSPFv3 timers
¡ Setting OSPFv3 packet timers
¡ Setting the LSA transmission delay
¡ Setting the SPF calculation interval
¡ Setting the LSA reception interval
¡ Setting the LSA generation interval
¡ Setting the LSU transmit rate
9. (Optional.) Setting a DR priority for an interface
10. (Optional.) Configuring OSPFv3 packet parameters
¡ Ignoring MTU check for DD packets
¡ Setting the DSCP value for outgoing OSPFv3 packets
¡ Disabling interfaces from receiving and sending OSPFv3 packets
11. (Optional.) Accelerating OSPFv3 convergence speed
¡ Configuring prefix suppression
12. (Optional.) Configuring OSPFv3 advanced features
¡ Configuring OSPFv3 isolation
¡ Configuring the virtual system feature
13. (Optional.) Enhancing OSPFv3 availability
14. (Optional.) Enhancing OSPFv3 security
¡ Configuring OSPFv3 authentication
¡ Applying an IPsec profile for authenticating OSPFv3 packets
15. (Optional.) Configuring OSPFv3 logging and SNMP notifications
¡ Enabling logging for neighbor state changes
¡ Setting the maximum number of OSPFv3 logs
¡ Configuring OSPFv3 network management
Enabling OSPFv3
To enable an OSPFv3 process on a router:
1. Enable the OSPFv3 process globally.
2. Assign the OSPFv3 process a router ID.
3. Enable the OSPFv3 process on related interfaces.
An OSPFv3 process ID has only local significance. Process 1 on a router can exchange packets with process 2 on another router.
OSPFv3 requires you to manually specify a router ID for each router in an AS. Make sure all assigned router IDs in the AS are unique.
If a router runs multiple OSPFv3 processes, you must specify a unique router ID for each process.
1. Enter system view.
2. Enable an OSPFv3 process and enter its view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
By default, no OSPFv3 processes are enabled.
3. (Optional.) Configure a description for the OSPFv3 process.
By default, no description is configured for an OSPFv3 process.
To identify and manage different OSPFv3 processes, configure a unique description for each process.
4. Specify a router ID.
router-id router-id
By default, no router ID is configured.
5. Enter interface view.
6. Enable an OSPFv3 process on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
By default, no OSPFv3 processes are enabled on an interface.
Enabling multiple OSPFv3 processes on a device might cause memory insufficiency. To resolve this issue, perform this task to enable lightweight OSPFv3 processes.
Although lightweight processes use less memory resources than traditional processes, device performance might degrade when a large number of neighbors and routes exist. As a best practice, plan the number of lightweight OSPFv3 processes to be enabled on the basis of the device resource condition.
1. Enter non-default vSystem view.
2. Enable a lightweight OSPFv3 process and enter its view.
ospfv3 [ process-id ] [ lite | vpn-instance vpn-instance-name ] *
About OSPFv3 areas
OSPFv3 has the same stub area, NSSA area, and virtual link features as OSPFv2.
After you split an OSPFv3 AS into multiple areas, the LSA number is reduced and OSPFv3 applications are extended. To further reduce the size of routing tables and the number of LSAs, configure the non-backbone areas at an AS edge as stub areas.
A stub area cannot import external routes, but an NSSA area can import external routes into the OSPFv3 routing domain while retaining other stub area characteristics.
Non-backbone areas exchange routing information through the backbone area, so the backbone and non-backbone areas (including the backbone itself) must be fully meshed. If no connectivity can be achieved, configure virtual links.
Configuring a stub area
To configure a stub area, you must perform this task on all routers attached to the area.
2. Enter OSPFv3 view.
3. Enter OSPFv3 area view.
area area-id
4. (Optional.) Configure a description for the OSPFv3 area.
By default, no description is configured for an OSPFv3 area.
To identify and manage different OSPFv3 areas, configure a unique description for each area.
5. Configure the area as a stub area.
By default, no area is configured as a stub area.
The no-summary keyword is only available on the ABR of a stub area. If you specify the no-summary keyword, the ABR only advertises a default route in an Inter-Area-Prefix LSA into the stub area.
6. (Optional.) Set a cost for the default route advertised to the stub area.
default-cost cost-value
By default, the cost for the default route advertised to the stub area is 1.
Configuring an NSSA area
To configure an NSSA area, you must perform this task on all routers attached to the area.
area area-id
5. Configure the area as an NSSA area.
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] * | no-import-route | no-summary | [ translate-always | translate-never ] | suppress-fa | translator-stability-interval value ] *
By default, no area is configured as an NSSA area.
To configure a totally NSSA area, execute the nssa no-summary command on the ABR. The ABR of a totally NSSA area does not advertise inter-area routes into the area.
6. (Optional.) Set a cost for the default route advertised to the NSSA area.
By default, the cost for the default route advertised to the NSSA area is 1.
This command takes effect only on the ABR/ASBR of an NSSA or totally NSSA area.
You can configure a virtual link to maintain connectivity between a non-backbone area and the backbone, or in the backbone itself.
Both ends of a virtual link are ABRs that must be configured with the vlink-peer command.
area area-id
5. Configure a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | [ { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string | keychain keychain-name ] | retransmit seconds | trans-delay seconds ] *
Based on the link layer protocol, OSPFv3 classifies networks into different types, including broadcast, NBMA, P2MP, and P2P.
· An NBMA network must be fully connected. Any two routers in the network must be directly reachable to each other through a virtual circuit. If no such direct link is available, you must change the network type through a command.
· If direct connections are not available between some routers on an NBMA network, the type of interfaces associated must be configured as P2MP, or as P2P for interfaces with only one neighbor.
2. Enter interface view.
3. Set the network type to broadcast for the OSPFv3 interface.
ospfv3 network-type broadcast [ instance instance-id ]
By default, the network type of an interface depends on the media type of the interface.
When the link layer protocol is Ethernet or FDDI, the network type is broadcast by default.
For NBMA interfaces, you must specify the link-local IP addresses and DR priorities for their neighbors because these interfaces cannot find neighbors by broadcasting hello packets.
3. Set the network type to NBMA for the OSPFv3 interface.
ospfv3 network-type nbma [ instance instance-id ]
When the link layer protocol is ATM, the network type is NBMA by default.
4. (Optional.) Set the router priority for the interface
ospfv3 dr-priority priority
By default, an interface has a router priority of 1.
An interface's router priority determines its privilege in DR/BDR selection.
5. Specify an NBMA neighbor.
ospfv3 peer ipv6-address [ cost cost-value | dr-priority priority ] [ instance instance-id ]
By default, no link-local address is specified for the neighbor interface.
For P2MP interfaces (only when in unicast mode), you must specify the link-local IP addresses of their neighbors because these interfaces cannot find neighbors by broadcasting hello packets.
3. Set the network type to P2MP for the OSPFv3 interface.
ospfv3 network-type p2mp [ unicast ] [ instance instance-id ]
4. Specify a P2MP unicast neighbor.
3. Set the network type to P2P for the OSPFv3 interface.
ospfv3 network-type p2p [ instance instance-id ]
When the link layer protocol is PPP, LAPB, HDLC, or POS, the network type is P2P by default.
If contiguous network segments exist in an area, you can summarize them into one network segment on the ABR. The ABR will advertise only the summary route. Any LSA on the specified network segment will not be advertised, reducing the LSDB size in other areas.
area area-id
4. Configure route summarization on the ABR.
abr-summary ipv6-address prefix-length [ not-advertise ] [ cost cost-value ]
By default, route summarization is not configured on an ABR.
Perform this task to enable an ASBR to summarize external routes within the specified address range into a single route.
An ASBR can summarize routes in the following LSAs:
· Type-5 LSAs.
· Type-7 LSAs in an NSSA area.
· Type-5 LSAs translated from Type-7 LSAs in an NSSA area if the ASBR (also an ABR) is a translator. If the ASBR is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
3. Configure route summarization on an ASBR.
asbr-summary ipv6-address prefix-length [ cost cost-value | not-advertise | nssa-only | tag tag ] *
By default, route summarization is not configured on an ASBR.
This task allows you to filter routes calculated by using received LSAs.
3. Configure OSPFv3 to filter routes calculated by using received LSAs.
filter-policy { ipv6-acl-number [ gateway prefix-list-name ] | prefix-list prefix-list-name [ gateway prefix-list-name ] | gateway prefix-list-name | route-policy route-policy-name } import
By default, OSPFv3 accepts all routes calculated by using received LSAs.
This command can only filter routes computed by OSPFv3. Only routes not filtered out can be added into the local routing table.
The filter command takes effect only on ABRs.
area area-id
4. Configure OSPFv3 to filter Inter-Area-Prefix LSAs.
filter { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
By default, OSPFv3 accepts all Inter-Area-Prefix LSAs.
To control the size of routing information in an OSPFv3 domain, you can configure this feature on the desired OSPFv3 interface to filter outbound LSAs. This feature only filters the specified LSAs that are to be advertised from an interface. If a neighbor has received LSAs from the interface before you configure this feature, this feature will not take effect on those LSAs. They remain existing in the LSDB of the neighbor until they expire.
Perform the following operations with caution, because they will terminate re-establish all neighbor relationships of an interface:
· Cancel the configuration of this task after performing it.
3. Filter outbound LSAs on the interface.
ospfv3 database-filter { all | { external [ acl { ipv6-acl-number | ipv6-acl-name } ] | inter-prefix [ acl { ipv6-acl-number | ipv6-acl-name } ] | nssa [ acl { ipv6-acl-number | ipv6-acl-name } ] } * } [ instance instance-id ]
By default, the outbound LSAs are not filtered on the interface.
To control the size of routing information in an OSPFv3 domain, configure this feature on the desired OSPFv3 interface. This feature filters the specified LSAs before the interface advertises to the specified OSPFv3 neighbor.
This feature only filters the specified LSAs that are to be advertised from the interface to the specified OSPFv3 neighbor. If the neighbor has received LSAs from the interface before you configure this feature, this feature will not take effect on those LSAs. They remain existing in the LSDB of the neighbor until they expire.
Perform the following operations with caution, because they will terminate and re-establish all neighbor relationships of an interface:
· Perform this task.
This feature does not take effect on P2P-type or broadcast-type OSPFv3 interfaces.
3. Filtering the LSAs to be advertised to an OSPFv3 neighbor.
ospfv3 peer-database-filter ipv6-address { all | { external [ acl { ipv6-acl-number | ipv6-acl-name } ] | inter-prefix [ acl { ipv6-acl-number | ipv6-acl-name } ] | nssa [ acl { ipv6-acl-number | ipv6-acl-name } ] } * } [ instance instance-id ]
By default, OSPFv3 does not filter LSAs before advertising them to any neighbor.
You can set an OSPFv3 cost for an interface with one of the following methods:
· Set the cost value in interface view.
· Set a bandwidth reference value for the interface, and OSPFv3 computes the cost automatically based on the bandwidth reference value by using the following formula:
Interface OSPFv3 cost = Bandwidth reference value (100 Mbps) / Interface bandwidth (Mbps)
¡ If the calculated cost is greater than 65535, the value of 65535 is used.
¡ If the calculated cost is smaller than 1, the value of 1 is used.
· If no cost is set for an interface, OSPFv3 automatically computes the cost for the interface.
Setting a cost in interface view
3. Set an OSPFv3 cost for the interface.
ospfv3 cost cost-value [ instance instance-id ]
By default, the OSPFv3 cost is 1 for a VLAN interface, is 0 for a loopback interface. The OSPFv3 cost is automatically computed according to the interface bandwidth for other interfaces.
Setting a bandwidth reference value
3. Set a bandwidth reference value.
bandwidth-reference value
The default bandwidth reference value is 100 Mbps.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, perform this task to change the link cost of a Layer 3 aggregate interface as follows:
· When the bandwidth of the Layer 3 aggregate interface falls below the specified threshold, the aggregate interface uses the specified link cost. Make sure the link cost you specified is larger than the original link cost, so that OSPFv3 can select an optimal path for traffic forwarding.
· When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original link cost.
For more information about OSPFv3 link cost, see "Setting an OSPFv3 cost for an interface."
This feature applies to only Layer 3 aggregate interfaces and Layer 3 aggregate subinterfaces.
3. Change the link cost of the interface to the specified value when the bandwidth of the interface falls below the specified threshold.
ospfv3 cost-fallback cost-value threshold bandwidth-value [ instance instance-id ]
By default, an aggregate interface uses the original link cost.
If the device forwards OSPFv3 packets along low-quality links, slow packet transmission and packet loss might occur. To minimize the impact of low-quality links on the OSPFv3 network, you can enable OSPFv3 to adjust the interface cost according to the link quality.
The following items affect the quality level of links:
· Error codes—Error codes refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption. The link quality detection module adjusts the quality level of links based on the bit error ratio. For more information about bit errors, see error code detection configuration in High Availability Configuration Guide.
· Card health—The health of a card is downgraded when the card fails. The link quality detection module adjusts the quality level of links based on the card health. For more information about hardware failure detection, see device management configuration in Fundamentals Configuration Guide.
After you perform this task on an interface, OSPFv3 adjusts the interface cost as follows:
· When the link quality detection module detects that the link quality of the interface becomes poor, the module performs the following operations:
¡ Changes the link quality level from GOOD to LOW.
¡ Reports an error code event to the OSPFv3 module.
Upon receiving the error code event, OSPFv3 increases the cost value for the interface.
· When the link quality detection module detects that the link quality of the interface restores to GOOD, the module performs the following operations:
¡ Changes the link quality level from LOW to GOOD.
¡ Reports an error code clearing event to the OSPFv3 module.
Upon receiving the error code clearing event, OSPFv3 restores the cost value for the interface to the original value.
This interface cost adjustment mechanism enables OSPFv3 to select good-quality forwarding links, minimizing the impact of low-quality links on the OSPFv3 network.
This feature affects the route selection results on only one side, because it only adjusts the cost values for interfaces on the local device.
3. Enable OSPFv3 to adjust the interface cost according to the link quality.
ospfv3 link-quality adjust-cost { max | cost-offset } [ instance instance-id ]
By default, OSPFv3 adjusts the interface cost according to the link quality.
On an OSPFv3 network, when a link recovers from failures or the state of an interface changes, OSPFv3 will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To resolve this issue, enable OSPFv3 to advertise the maximum link cost to neighbors within the specified period of time, so the traffic forwarding path remains unchanged. After the specified period of time, OSPFv3 advertises the original link cost to neighbors and performs optimal route selection again.
3. Enable OSPFv3 to advertise the maximum link cost to neighbors within the specified period of time.
ospfv3 peer hold-max-cost duration timer [ instance instance-id ]
By default, OSPFv3 advertises the original link cost to neighbors during route convergence.
OSPFv3 might find multiple equal-cost routes to the same destination, which can be used to share the traffic load. This task allows you to set the maximum number of ECMP routes.
3. Set the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of ECMP routes is 64.
A router can run multiple routing protocols. The system assigns a priority for each protocol. When these routing protocols find the same route, the route found by the protocol with the highest priority is selected.
3. Set a preference for OSPFv3.
By default, the preference of OSPFv3 internal routes is 10, and the preference of OSPFv3 external routes is 150.
Because OSPFv3 is a link state routing protocol, it cannot directly filter LSAs to be advertised. OSPFv3 filters only redistributed routes. Only routes that are not filtered out can be advertised in LSAs.
3. Configure OSPFv3 to redistribute routes from other routing protocols.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static | unr } [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, route redistribution is disabled.
The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes, which might cause routing loops. Therefore, use the import-route bgp4+ allow-ibgp command with caution.
4. (Optional.) Configure OSPFv3 to filter redistributed routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id ] | static | unr ]
By default, OSPFv3 accepts all redistributed routes.
This command filters only routes redistributed by the import-route command. If no routes are redistributed by the import-route command, this command does not take effect.
5. Set a tag for redistributed routes.
default tag tag
By default, the tag of redistributed routes is 1.
Perform this task to resolve routing loop issues in the scenario meeting the following conditions:
· The CE is dual-homed (connecting to two PEs) and uses OSPFv3 to exchange private network routes with the PEs.
· One of the two PEs is an H3C device and the other PE is from another vendor.
When a PE redistributes BGP routes into OSPFV3 and advertises them to the CE in a Type 5 or 7 LSA, it adds an external-route tag to the LSA. On receipt of the Type 5 or 7 LSAs advertised by the CE, the other PE compares the external-route tag in the LSA against the local external-route tag. If they are the same, the PE ignores the LSA to avoid routing loops. Since different vendors use different external route tagging mechanisms, the PE might add the LSA into its LSDB and perform route calculation based on the LSA, thus causing loops.
To resolve the issue, perform this task on the H3C device. After you configure this task, OSPFV3 is disabled from inheriting the tag carried by the redistributed route. To ensure consistency with the external route tagging mechanisms of other vendors, OSPFV3 selects a tag for the redistributed route as follows:
1. Tag specified by using the apply tag command in a routing policy.
2. Tag specified by the tag option of the import-route command.
3. Tag specified by the route-tag command.
4. If the BGP AS number is less than or equal to 65535, the first two bytes of the external-route tag value are fixed at 0xD000, and the following two bytes are the local BGP AS number. If the BGP AS number is greater than 65535, the external-route tag value is 0. For example, if the local BGP AS number is 100, the default external-route tag value in decimal notation is 3489661028, which is 0xD0000000 (3489660928 in decimal notation) plus 100.
For more information about the CE dual-homed scenario and route tags, see MPLS L3VPN configuration in MPLS Configuration Guide.
3. Disable OSPFv3 from inheriting the tags of redistributed routes.
import-route no-inherit-tag
By default, OSPFv3 inherits the tags of redistributed routes.
The import-route command cannot redistribute a default external route. To redistribute a default route, perform this task.
3. Redistribute a default route.
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | tag tag | type type ] *
By default, no default route is redistributed.
4. Set a tag for redistributed routes.
default tag tag
After the device advertises OSPFv3 link state information to BGP, BGP can advertise the information for intended applications. For more information about BGP LS, see "Configuring BGP."
3. Advertise OSPFv3 link state information to BGP.
distribute bgp-ls [ instance-id instance-id ]
By default, the device does not advertise OSPFv3 link state information to BGP.
Advertising OSPFv3 link state information containing MPLS TE attributes to BGP
4. Configure an IPv6 Router ID for the device.
te-router-id ipv6-address
By default, no IPv6 Router ID is configured for a device.
After you execute this command, OSPFv3 generates Intra-Area-TE LSAs containing basic link state information, IPv6 Router ID, neighbor ID, local interface's IPv6 address, and remote interface's IPv6 address.
5. Enable OSPFv3 to generate Intra-Area-TE LSAs containing TE attribute information.
a. Return to system view.
b. Enable MPLS TE and enter MPLS TE view.
mpls te
By default, MPLS TE is disabled.
For more information about MPLS TE, see MPLS TE configuration in MPLS Configuration Guide.
c. Enter OSPFv3 view.
d. Enter OSPFv3 area view.
area area-id
e. Enable MPLS TE for the OSPFv3 area.
mpls te enable
By default, MPLS TE is disabled for an OSPFv3 area.
After you execute this command, OSPFv3 generates Intra-Area-TE LSAs containing basic link state information and TE attribute information.
The interface link tag feature can work together with the link tag inheritance feature to filter routes. For example, you can set an OSPFv3 link tag for Device A and enable OSPFv3 link tag inheritance on Device B to filter routes as follows:
1. Device A advertises the OSPFv3 link tag in E-router LSAs.
2. After receiving the LSAs advertised by Device A, Device B inherits the OSPFv3 link tag advertised by Device A.
If Device B receives multiple link tags from Device A, Device B selects and inherits only one tag.
3. Device B configures the link tag as the route tag for all routes that pass the link.
Then, the route tag can be used for route filtering.
This feature is usually used in Source Address Validation Architecture (SAVA) scenarios to ensure the consistency of IPv6 SAVA entries on multiple gateway devices as follows:
4. Set an OSPFv3 link tag for the customer-side interface on the gateway device that advertises IPv6 SAVA entries.
5. Enable OSPFv3 link tag inheritance on the gateway device that receives IPv6 SAVA entries. The device generates an IPv6 SAVA entry based on a route prefix if the following two tags are the same:
¡ The route tag configured by executing the ipv6 sava import remote-route-tag command.
¡ The OSPFv3 link tag that the route inherits.
For more information about SAVA and IPv6 SAVA entries, see SAVA configuration in Security Configuration Guide.
Setting an OSPFv3 link tag for an interface
3. Set an OSPFv3 link tag for the interface.
ospfv3 link-tag tag [ instance instance-id ]
By default, no OSPFv3 link tag is configured for the interface.
Enabling OSPFv3 link tag inheritance
3. Enable OSPFv3 link tag inheritance.
link-tag inherit enable
By default, OSPFv3 link tag inheritance is disabled.
A controller in a network performance-sensitive scenario uses parameters that can reflect the network performance as route calculation metrics.
Perform this task to enable OSPFv3 to advertise network performance parameters and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the network performance parameters.
Network performance parameters include the following:
· Delay—Unidirectional link delay performance metrics, including:
¡ Average link delay—Average unidirectional link delay.
¡ Min/Max link delay—Minimum/maximum unidirectional link delay.
¡ Average link delay variation—Average unidirectional link delay variation.
· Bandwidth—Unidirectional link bandwidth performance metrics, including:
¡ Remaining bandwidth—Remaining unidirectional link bandwidth.
¡ Available bandwidth—Available unidirectional link bandwidth.
¡ Utilized bandwidth—Unidirectional link bandwidth usage.
Perform this task to enable OSPFv3 to advertise link delay information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link delay information.
Perform either of the following tasks to obtain link delay information of an interface:
· Static configuration—Execute the ospfv3 link-delay command to manually configure link delay parameters on the interface.
· Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link delay information to the interface, and the interface will report the link delay information to OSPFv3 at periodic intervals. For more information about TWAMP Light, see NQA configuration in Network Management and Monitoring Configuration Guide.
In dynamic acquisition mode, an interface reports link delay information to OSPFv3 at rather short intervals, for example, 100 milliseconds. As a result, OSPFv3 needs to frequently process the link delay information and reports the information to the controller through BGP-LS, which consumes a lot of device and network resources. To resolve this issue, you can configure OSPFv3 to suppress link delay information advertisement.
Link delay advertisement suppression works as follows:
· An interface reports link delay information to OSPFv3 at negotiated intervals.
· OSPFv3 advertises link delay information through BGP-LS at intervals specified by the timer-value argument. OSPFv3 does not advertise link delay information within the suppression timer except for the following conditions:
¡ The variation ratio between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the delay variation ratio.
¡ The absolute value of the difference between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the absolute value of the delay variation.
For an interface, static link delay parameters take precedence over the parameters obtained through dynamic acquisition.
As a best practice, set the link delay advertisement suppression interval to be larger than or equivalent to the NQA delay measurement interval.
Configuring link delay parameters
3. Configure link delay parameters.
ospfv3 link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } * [ instance instance-id ]
By default, link delay parameters are not configured.
Enabling OSPFv3 to advertise link delay information
3. Enable OSPFv3 to advertise link delay information.
metric-delay advertisement enable
By default, OSPFv3 does not advertise link delay information.
Configuring the suppression settings for OSPFv3 to suppress link delay information advertisement
3. Configure the suppression settings for OSPFv3 to suppress link delay information advertisement.
metric-delay suppression timer timer-value percent-threshold percent-value absolute-threshold absolute-value
By default, the suppression interval is 120 seconds, the suppression threshold for the delay variation ratio is 10%, and the suppression threshold for the absolute value of the delay variation is 1000 microseconds.
If you set an argument to 0, the corresponding suppression mechanism does not take effect.
Perform this task to enable OSPFv3 to advertise link bandwidth information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link bandwidth information.
By default, an interface reports link bandwidth information to OSPFv3 at short intervals, for example, 100 milliseconds. As a result, OSPFv3 needs to frequently process the link bandwidth information and reports the information to the controller through BGP-LS, which consumes a lot of device and network resources. To resolve this issue, you can configure OSPFv3 to suppress advertisement of link bandwidth information.
Link bandwidth advertisement suppression works as follows:
· An interface reports link bandwidth information to OSPFv3 at negotiated intervals.
· OSPFv3 advertises link bandwidth information through BGP-LS at intervals specified by the timer-value argument. OSPFv3 does not advertise link bandwidth information within the suppression timer.
As a best practice, set the link bandwidth advertisement suppression interval to be larger than or equivalent to the Ethernet interface bandwidth measurement interval.
Enabling OSPFv3 to advertise link bandwidth information
3. Enable OSPFv3 to advertise link bandwidth information.
metric-bandwidth advertisement enable
By default, OSPFv3 does not advertise link bandwidth information.
Setting the suppression interval for OSPFv3 to suppress link bandwidth information advertisement
3. Sett the suppression interval for OSPFv3 to suppress link bandwidth information advertisement.
metric-bandwidth suppression timer timer-value
By default, the suppression interval is 120 seconds.
If you set the timer-value argument to 0, OSPFv3 does not suppress link bandwidth information advertisement.
OSPFv3 traditionally calculates optimal paths based on the IGP metric values of all links. This might not meet the traffic requirements. Flexible algorithm allows users to control path selection flexibly by customizing path calculation methods.
Flexible algorithm concepts
· FAD—Flexible algorithm definition, a composite of calculation type, metric type, and constraints.
· Calculation type—Algorithm used for path calculation. In the current software version, only the SPF algorithm is supported.
· Metric type—Metric type used for optimal path calculation. Only OSPFv3 link cost is supported.
· Constraint—Link filter criteria for topology generation. You can use a set of constraints to exclude links with specific affinities from or include them in the flexible algorithm topology.
· Flexible algorithm ID—Unique identifier of a flexible algorithm. The ID range is 128 to 255.
· Affinity attribute—A link attribute, also known as link color. You can use this attribute together with the link constraints to filter links for flexible algorithm path calculation.
· Extended administrative group—Flexible algorithm sub-TLV used to advertise the link constraints. OSPFv3 advertise a flexible algorithm sub-TLV in an LSA. There are three types of sub-TLVs, including Flexible Algorithm Exclude Admin Group Sub-TLV, Flexible Algorithm Include-Any Admin Group Sub-TLV, and Flexible Algorithm Include-All Admin Group Sub-TLV.
Flexible algorithm topology
The flexible algorithm topology is the scope of path calculation. It consists of links selected by the flexible algorithm based on the link constraints. The flexible algorithm excludes a node or a link from the topology in one of the following scenarios:
· The node is not configured with the c.
· The link meets one of the following requirements:
¡ An exclude-any constraint exists in the FAD and the link has an affinity attribute that is included in the constraint.
¡ An include-any constraint exists in the FAD and the link does not have any affinity attribute that is included in the constraint.
¡ An include-all constraint exists in the FAD and the link does not have all the affinity attributes that are included in the constraint.
¡ The link does not use the same metric type as the the metric type.
As shown in Figure 1, when no flexible algorithm is configured, all nodes calculate optimal paths by OSPFv3 link cost.
Figure 1 Topology without flexible algorithm 130
For comparison, you can configure flexible algorithm 130 for all nodes except Router F. The FAD of flexible algorithm 130 is as follows:
· Calculation type—SPF algorithm.
· Metric type—OSPFv3 link cost.
· Constraint—Exclude affinity attribute red.
In the new topology shown in Figure 2, all nodes calculate optimal paths based on the calculation type and metric type in the FAD.
Figure 2 Topology with flexible algorithm 130
To configure OSPFv3 flexible algorithm, perform the following tasks:
· Configuring the FAD of a flexible algorithm
a. Mapping an affinity attribute name to an affinity bit
b. Assigning affinity attributes to OSPFv3 links
c. Configuring a flexible algorithm
d. Configuring the metric type of a flexible algorithm
· (Optional.) Enhance the reliability of flexible algorithm
¡ Configuring flexible algorithm FRR
¡ Configuring flexible algorithm TI-LFA FRR
¡ Set the priority of an FRR backup path selection policy for flexible algorithm
· Applying a flexible algorithm to SRv6
Configure SRv6. For more information about SRv6, see SRv6 configuration in Segment Routing Configuration Guide.
OSPFv3 supports a maximum of 256 affinity bits. They are numbered from 0 to 255. You can perform this task to map different affinity attribute names to these bits. As shown in Figure 3, affinity attribute name blue is mapped to bit 1, and red to bit 5.
This feature enables you to configure affinity attributes for links or define the flexible algorithm topology by specifying only the affinity attribute names.
Figure 3 Mapping an affinity attribute to an affinity bit
3. Map an affinity attribute name to an affinity bit.
affinity-map affinity-name bit-position bit
By default, no affinity attribute name is mapped to an affinity bit.
If you perform this task on an OSPFv3 interface, the links between the interface and its neighbors will carry specific affinity attributes. In a flexible algorithm scenario, these links will be filtered for path calculation based on the link constraints in the FAD.
3. Assign affinity attributes to OSPFv3 links.
ospfv3 affinity flex-algo { affinity-name }&<1-32> [ instance instance-id ]
By default, an OSPFv3 link has no affinity attributes.
An OSPFv3 node cannot participate in the path calculation for a flexible algorithm unless you configure the flexible algorithm for the node. To use a flexible algorithm for path calculation, you must make sure a minimum of one node can advertises the FAD of that flexible algorithm in LSAs.
Each node that participates in the path calculation for a flexible algorithm can have a different FAD. To avoid routing loops in an FAD advertisement scope (OSPFv3 area), these nodes must use the same FAD. By convention, a node selects an FAD as follows:
· The FAD with the highest priority will be selected from the FADs advertised within the OSPFv3 routing domain. If the node does not advertise an FAD, it selects the FAD with the highest priority from the received FADs.
· The FAD with the greatest router ID will be selected from the FADs that have the highest priority.
3. Create a flexible algorithm and enter its view.
flex-algo flex-algo-id
4. Configure a priority for the flexible algorithm.
priority priority-value
By default, the priority of a flexible algorithm is 128.
5. Configure the link constraints for a flexible algorithm.
¡ Exclude links that have a minimum of one specified affinity attribute.
affinity exclude-any affinity-name&<1-32>
¡ Include links that have a minimum of one specified affinity attribute.
affinity include-any affinity-name&<1-32>
¡ Include links that have all specified affinity attribute.
affinity include-all affinity-name&<1-32>
By default, all nodes configured to participate in the path calculation for a flexible algorithm are not excluded from the topology.
6. Enable FAD advertisement on a node.
advertise-definition enable
By default, a node does not advertise the FAD.
About metric type configuration for flexible algorithm
By default, the flexible algorithm uses OSPFv3 link cost for optimal path calculation. In some scenarios, the paths calculated by the flexible algorithm might not be optimal. To resolve this issue, configure the flexible algorithm to use another metric type for optimal path calculation.
Flexible algorithm supports the following metric types:
· OSPFv3 link cost.
· Link delay. Flexible algorithm uses the minimum link delay for optimal path calculation.
· MPLS TE metric.
If you specify the metric type of the flexible algorithm as link delay or MPLS TE metric, you need to enable OSPFv3 to advertise application-specific link attribute information, so that the nodes can perform flexible algorithm path calculation. After enabling the function, OSPFv3 uses Application-Specific Link Attributes (ASLA) sub-TLVs to advertise link attributes associated with the flexible algorithm.
If the flexible algorithm uses link delay metric, make sure OSPFv3 link delay advertisement is enabled on all interfaces that participate in path calculation for that flexible algorithm.
If the flexible algorithm uses MPLS TE metric, make sure the following requirements are met:
· MPLS TE is enabled for each node that participates in path calculation for that flexible algorithm.
· MPLS and MPLS TE are enabled on each interface that participates in path calculation for that flexible algorithm.
· MPLS TE is enabled for the OSPFv3 area.
The default type values of ASLA Sub-TLVs and End.X SID Sub-TLVs are both 11. To ensure normal operation of Flex-Algo, you must use the segment-routing ipv6 sid-sub-tlv-type command to edit the type value for SRv6 SID-Sub TLVs. This ensures that all SRv6 nodes use the same type value for SRv6 SID-Sub TLVs.
Configuring the metric type as link delay
4. E nable OSPFv3 to advertise application-specific link attributes.
advertise application link-attributes te
By default, OSPFv3 does not advertise any application-specific link attributes.
5. Enter flexible algorithm view.
6. Configure the metric type as link delay.
metric-type delay
By default, the metric type is OSPFv3 link cost.
Configuring the metric type as MPLS TE metric
4. (Optional.) Suppress OSPFv3 from advertising link attributes in Intra-Area-TE LSAs.
suppress intra-te link-attributes
By default, OSPFv3 does not suppress advertisement of link attributes in Intra-Area-TE LSAs.
6. Configure the metric type as TE metric.
metric-type te-cost
The flexible algorithm FRR is similar to OSPFv3 LFA FRR, because it uses LFA to calculate a loop-free backup path with the lowest cost based on the topology.
For illustration, flexible algorithm 130 is configured for all nodes in Figure 4. The FAD of flexible algorithm 130 is as follows:
Figure 4 Topology without flexible algorithm 130
In Figure 5, after you enable FRR, flexible algorithm 130 uses LFA to calculate a primary path and a backup path from Router A to Router D.
Figure 5 Topology with flexible algorithm 130
3. Enter flexible algorithm view.
4. Enable flexible algorithm FRR.
fast-reroute enable
By default, flexible algorithm FRR is enabled.
If no backup paths exist in the network, execute the undo fast-reroute enable command to disable flexible algorithm FRR to save device resources.
About TI-LFA FRR
Topology-Independent Loop-free Alternate Fast Reroute (TI-LFA FRR) is an enhanced version of LFA FRR. TI-LFA FRR uses the same algorithms to calculate P space and Q space as Remote LFA FRR. This feature can protect a topology without PQ nodes.
For more information about P space, Q space and TI-LFA FRR path calculation, see SRv6 configuration in Segment Routing Configuration Guide.
TI-LFA FRR protection types
The following TI-LFA traffic protection types are available:
· Link protection—Protects traffic that traverses a specific link.
· Node protection—Protects traffic that traverses a specific node.
Node protection takes precedence over link protection.
TI-LFA FRR uses the common algorithm to calculate backup paths for a flexible algorithm. The only difference is that TI-LFA FRR calculates backup paths for a flexible algorithm according to the FAD and topology of that flexible algorithm.
As shown in Figure 6, Router B is the source node and Router A is the destination node.
The number on each link represents the link cost. A data flow traverses from Router B to Router A. To avoid traffic loss against Router B failure, TI-LFA FRR calculates the backup path: Router B > Router C > Router E > Router F > Router A.
Figure 6 TI-LFA FRR backup path calculation without a flexible algorithm
As shown in Figure 7, flexible algorithm 130 is configured for each node. The FAD of flexible algorithm 130 is as follows:
In this case, the backup path calculated by TI-LFA FRR is Router B > Router C > Router D > Router E > Router F > Router A.
Figure 7 TI-LFA FRR backup path calculation with a flexible algorithm
Enabling TI-LFA FRR
4. Enable TI-LFA FRR.
fast-reroute ti-lfa enable [ per-prefix ]
By default, TI-LFA FRR is enabled.
OSPFv3 flexible algorithm FRR selects a backup path based on the following policies:
· Node-protection policy—Selects the path that involves a specific node.
· Link-protection policy—Selects the path that involves a specific link.
Typically, the cost of a node-protection backup path is higher than that of a link-protection backup path. The link-protection backup path selection policy is known as the lowest-cost backup path selection policy. By default, the node-protection policy takes precedence over the lowest-cost policy. To adjust the priority value of either of the path selection policies as needed, perform this task.
If the node-protection policy has a higher priority but the backup path calculation fails, the flexible algorithm uses the lowest-cost policy for further calculation. If the backup path calculation still fails, the flexible algorithm does not perform further backup path calculation.
If the lowest-cost policy has a higher priority but the backup path calculation fails, the flexible algorithm does not perform further backup path calculation.
4. Set the priority value for an FRR backup path selection policy for a flexible algorithm.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference
By default, the priority values of the node-protection and lowest-cost backup path selection policies are 40 and 20, respectively.
With SRv6 enabled, OSPFv3 advertises SRv6 locator TLVs in LSAs. You can identify the algorithm associated to the locator by checking the algorithm field in an SRv6 locator TLV. By default, OSPFv3 uses the SPF algorithm to calculate the shortest path to an SRv6 locator, and the value for the algorithm field is 0.
If you associate an SRv6 locator to a flexible algorithm, OSPFv3 uses the flexible algorithm to calculate the shortest path to the locator. For example, you can associate the SRv6 locators in Figure 8 to flexible algorithm 130. The FAD of flexible algorithm 130 is as follows:
· Constraint—Exclude affinity attribute blue.
As shown in Figure 8, Router A uses the SPF algorithm to calculate the optimal path to locator 2001:0:8:6::/64 based on the topology of flexible algorithm 130.
Figure 8 Optimal path calculated by flexible algorithm 130
You must associate an SRv6 locator to a flexible algorithm that already exists, or OSPFv3 will not advertise the locator.
2. Enable SRv6 and enter SRv6 view.
By default, SRv6 is disabled.
For more information about this command, see SRv6 configuration in Segment Routing Configuration Guide.
3. Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4. Associate the locator to a flexible algorithm.
flex-algo algorithm algo-id
By default, a locator is not associated to any flexible algorithm.
3. Set the hello interval.
ospfv3 timer hello seconds [ instance instance-id ]
The default hello interval on P2P and broadcast interfaces is 10 seconds. The default hello interval on P2MP and NBMA interfaces is 30 seconds.
4. Set the dead interval.
ospfv3 timer dead seconds [ instance instance-id ]
The default dead interval on P2P and broadcast interfaces is 40 seconds. The default dead interval on P2MP and NBMA interfaces is 120 seconds.
The dead interval set on neighboring interfaces cannot be too short. If the interval is too short, a neighbor is easily down.
5. Set the poll interval.
ospfv3 timer poll seconds [ instance instance-id ]
By default, the poll interval is 120 seconds.
6. Set the LSA retransmission interval.
ospfv3 timer retransmit interval [ instance instance-id ]
The default LSA retransmission interval is 5 seconds.
The LSA retransmission interval cannot be too short. If the interval is too short, unnecessary retransmissions will occur.
Each LSA in the LSDB has an age that increases by 1 every second, but the age does not change during transmission. Therefore, it is necessary to add a transmission delay into the age time, especially for low-speed links.
3. Set the LSA transmission delay.
ospfv3 trans-delay seconds [ instance instance-id ]
By default, the LSA transmission delay is 1 second.
LSDB changes result in SPF calculations. When the topology changes frequently, a large amount of network and router resources are occupied by SPF calculation. You can adjust the SPF calculation interval to reduce the impact.
The default SPF calculation interval settings are as follows:
· The interval for the first SPF calculation is 50 milliseconds.
· The interval for the nth (n ≥ 2) SPF calculation is 50 + (200 x 2n-2) milliseconds, and cannot exceed 5 seconds.
The spf-schedule-interval command functions as follows:
· If the spf-schedule-interval maximum-interval command is executed:
¡ The values for the minimum-interval and incremental-interval arguments are both 0.
¡ The SPF calculation interval is fixed at maximum-interval.
· If the spf-schedule-interval maximum-interval minimum-interval command is executed:
¡ The value for the incremental-interval argument is 0.
¡ The interval for the first SPF calculation is minimum-interval.
¡ The interval for subsequent SPF calculations is maximum-interval.
- If the conservative keyword is not specified, OSPFv3 performs SPF calculation at the maximum interval for three consecutive times, and then performs SPF calculation at the minimum interval.
- If the conservative keyword is specified, OSPFv3 always performs SPF calculation at the maximum interval.
· If the spf-schedule-interval maximum-interval minimum-interval incremental-interval command is executed:
¡ The interval for the nth (n ≥ 2) SPF calculation is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
· If the spf-schedule-interval millisecond interval command is executed, OSPFv3 performs SPF calculation at intervals of interval milliseconds.
In scenarios that require a high route convergence speed, you can execute the spf-schedule-interval millisecond interval command to increase the SPF calculation frequency to accelerate route convergence.
3. Set the SPF calculation interval.
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
By default, the maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
An LSA is a duplicate of a previous LSA if they have the same LSA type, LSA ID, and router ID. OSPFv3 drops any duplicate LSAs within an LSA reception interval.
The default LSA reception interval settings are as follows:
· The reception interval for the first LSA is 500 milliseconds.
· The reception interval for the nth (n ≥ 2) LSA is 500 + (500 x 2n-2) milliseconds, and cannot exceed 1000 milliseconds.
· OSPFv3 drops duplicate LSAs received within an LSA reception interval.
You can use the lsa-arrival-interval command to adjust the LSA reception interval settings, and the configuration functions as follows:
· If the lsa-arrival-interval maximum-interval command is executed:
¡ The LSA reception interval is fixed at maximum-interval.
· If the lsa-arrival-interval maximum-interval minimum-interval command is executed:
¡ The reception interval for the first LSA is minimum-interval.
¡ The reception interval for subsequent LSAs is maximum-interval.
· If the lsa-arrival-interval maximum-interval minimum-interval incremental-interval command is executed:
¡ The reception interval for the nth (n ≥ 2) LSA is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
On a stable network that requires fast convergence, you can set the LSA reception interval to 0 for OSPFv3. In this way, OSPFv3 can learn the changes of the topology or routes immediately.
3. Set the LSA reception interval.
lsa-arrival-interval maximum-interval [ minimum-interval [ incremental-interval ] ]
By default, the maximum interval is 1000 milliseconds, the minimum interval is 500 milliseconds, and the incremental interval is 500 milliseconds.
If network changes become frequent, bandwidth resources and router resources might be overconsumed. To avoid this issue, use the lsa-generation-interval command to adjust the LSA generation interval settings for OSPFv3.
By default, the LSA generation interval is fixed at 5 seconds for OSPFv3.
The lsa-generation-interval command functions as follows:
· If the lsa-generation-interval maximum-interval command is executed:
¡ The LSA generation interval is fixed at maximum-interval.
· If the lsa-generation-interval maximum-interval minimum-interval command is executed:
¡ The interval for the first LSA generation is minimum-interval.
¡ The interval for subsequent LSA generations is maximum-interval.
· If the lsa-generation-interval maximum-interval minimum-interval incremental-interval command is executed:
¡ The interval for the nth (n ≥ 2) LSA generation is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
3. Set the LSA generation interval.
By default, the maximum interval is 5 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 0 milliseconds.
Sending large numbers of LSU packets affects router performance and consumes a large amount of network bandwidth. You can configure the router to send LSU packets at an interval and to limit the maximum number of LSU packets sent out of an OSPFv3 interface at each interval.
3. Set the LSU transmit rate.
By default, an OSPFv3 interface sends a maximum of three LSU packets every 20 milliseconds.
The router priority is used for DR election. Interfaces having the priority 0 cannot become a DR or BDR.
3. Set a router priority.
ospfv3 dr-priority priority [ instance instance-id ]
The default router priority is 1.
When LSAs are few in DD packets, it is unnecessary to check the MTU in DD packets to improve efficiency.
A neighbor relationship can be established only if the interface's MTU is the same as that of the peer.
3. Ignore MTU check for DD packets.
ospfv3 mtu-ignore [ instance instance-id ]
By default, OSPFv3 does not ignore MTU check for DD packets.
The DSCP value specifies the precedence of outgoing packets.
ospfv3 [ process-id | vpn-instance instance-name ] *
3. Set the DSCP value for outgoing OSPFv3 packets.
dscp dscp-value
By default, the DSCP value for outgoing OSPFv3 packets is 48.
After an OSPFv3 interface is set to silent, direct routes of the interface can still be advertised in Intra-Area-Prefix LSAs through other interfaces, but other OSPFv3 packets cannot be advertised. No neighboring relationship can be established on the interface. This feature can enhance the adaptability of OSPFv3 networking.
You can execute either the silent-interface or ospfv3 silent command or both commands for an interface to achieve the same effect. Choose an appropriate configuration method as needed.
Disabling interfaces from receiving and sending OSPFv3 packets in OSPFv3 view
3. Disable interfaces from receiving and sending OSPFv3 packets.
By default, the interfaces can receive and send OSPFv3 packets.
This command disables only the interfaces that run the current process. However, multiple OSPFv3 processes can disable the same interface from receiving and sending OSPFv3 packets.
Disabling an interface from receiving and sending OSPFv3 packets in interface view
3. Disable an interface from receiving and sending OSPFv3 packets.
ospfv3 silent
By default, an interface can receive and send OSPFv3 packets.
Configuring OSPFv3 ISPF
Incremental SPF (ISPF) allows the system to recalculate nodes affected by topology changes rather than the entire OSPFv3 shortest path tree. OSPFv3 ISPF saves CPU resources caused by SPF calculations and accelerates the convergence speed.
3. Enable OSPFv3 ISPF.
ispf enable
By default, OSPFv3 ISPF is enabled.
By default, an OSPFv3 interface advertises all of its prefixes in LSAs. To speed up OSPFv3 convergence, you can suppress interfaces from advertising all of their prefixes. This feature helps improve network security by preventing IP routing to the suppressed networks.
When prefix suppression is enabled:
· OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-8 LSAs.
· On broadcast and NBMA networks, the DR does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-2 LSAs.
· On P2P and P2MP networks, OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-1 LSAs.
Restrictions and guidelines for prefix suppression
As a best practice, configure prefix suppression on all OSPFv3 routers if you want to use prefix suppression.
Configuring prefix suppression for an OSPFv3 process
3. Enable prefix suppression for the OSPFv3 process.
prefix-suppression
By default, prefix suppression is disabled for an OSPFv3 process.
Enabling prefix suppression for an OSPFv3 process does not suppress the prefixes of loopback interfaces and passive interfaces.
Configuring prefix suppression for an interface
3. Enable prefix suppression for the interface.
ospfv3 prefix-suppression [ disable ] [ instance instance-id ]
By default, prefix suppression is disabled for an interface.
Configuring PIC
Prefix Independent Convergence (PIC) enables the device to converge without the dependence on the number of prefixes. The convergence time does not increase as the number of prefixes in the routing table increases.
Restrictions and guidelines for OSPFv3 PIC
When both OSPFv3 PIC and OSPFv3 FRR are configured, OSPFv3 FRR takes effect.
OSPFv3 PIC applies only to inter-area routes and external routes.
Enabling PIC
3. Enable PIC for OSPFv3.
By default, OSPFv3 PIC is disabled.
Configuring BFD OSPFv3 PIC (control packet mode)
3. Enable BFD control packet mode for OSPFv3 PIC.
ospfv3 primary-path-detect bfd ctrl [ instance instance-id ]
By default, BFD control packet mode is disabled for OSPFv3 PIC.
To speed up OSPFv3 convergence, enable BFD control packet mode for OSPFv3 PIC to detect the primary link failures. This mode requires BFD configuration on both OSPFv3 routers on the link.
Configuring BFD for OSPFv3 PIC (echo packet mode)
2. (Optional.) Configure the source IPv6 address of BFD echo packets.
By default, the source IPv6 address of BFD echo packets is not configured.
As a best practice to avoid network congestion caused by massive ICMPv6 redirect packets from the remote end, execute this command and specify a source IPv6 address that is not on the same network segment as any local interface's IP address.
For more information about this command, see High Availability Command Reference.
3. Enter interface view.
4. Enable BFD echo packet mode for OSPFv3 PIC.
ospfv3 primary-path-detect bfd echo [ instance instance-id ]
By default, BFD echo packet mode is disabled for OSPFv3 PIC.
To speed up OSPFv3 convergence, enable BFD single-hop echo packet mode for OSPFv3 PIC to detect the primary link failures. This mode requires BFD configuration on one OSPFv3 router on the link.
Configuring a stub router
A stub router is used for traffic control. It reports its status as a stub router to neighboring OSPFv3 routers. The neighboring routers can have a route to the stub router, but they do not use the stub router to forward data.
Use either of the following methods to configure a router as a stub router:
· Clear the R-bit of the Option field in Type-1 LSAs. When the R-bit is clear, the OSPFv3 router can participate in OSPFv3 topology distribution without forwarding traffic.
· Use the OSPFv3 max-metric router LSA feature. This feature enables OSPFv3 to advertise its locally generated Type-1 LSAs with a maximum cost of 65535. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
3. Configure the router as a stub router.
¡ Configure the router as a stub router and clear the R-bit of the Option field in Type-1 LSAs.
stub-router r-bit [ include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
¡ Configure the router as a stub router and advertise the locally generated Type-1 LSAs with the maximum cost of 65535.
stub-router max-metric [ external-lsa [ max-metric-value ] | summary-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
By default, the router is not configured as a stub router.
A stub router is not related to a stub area.
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate a device before upgrading it. OSPFv3 isolation works as follows:
1. After OSPFv3 isolation is enabled for a device, OSPFv3 increases the link cost in LSAs advertised by the device based on the following rules:
¡ The link cost in Type-1 LSAs (Router LSAs) is set to 65535.
¡ The link cost in Type-9 LSAs (Intra-area-prefix LSAs) that reference Type-1 LSAs is set to 65535.
¡ The link cost in the following LSAs is set to 16711680:
- Type-3 LSAs (Inter-area-prefix LSAs).
- Type-4 LSAs (Inter-area-router LSAs).
- Type-5 LSAs (AS external LSAs).
- Type-7 LSAs (NSSA LSAs).
2. Each neighbor of the device reselects an optimal route based on the LSAs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3. After the maintenance, disable OSPFv3 isolation on the device to restore its link cost and gracefully add it back to the network.
Both the isolate enable and stub-router max-metric external-lsa 16711680 summary-lsa 16711680 include-stub commands can isolate the device from the network.
When you execute both the isolate enable and stub-router max-metric commands, follow these restrictions and guidelines:
· When both the isolation feature and the stub router feature take effect, Type-3 LSAs, Type-4 LSAs, Type-5 LSAs, and Type-7 LSAs each use the higher one of the two LSA-specific link costs provided by those features.
· If the on-startup keyword is specified in the stub-router max-metric command, traffic forwarding path selection is affected only by the isolation feature when the stub router does not take effect.
1. Enter system view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
3. Configure OSPFv3 isolation.
¡ Enable OSPFv3 isolation to gracefully isolate the device from the network.
isolate enable
¡ Disable OSPFv3 isolation to gracefully add the device back to the network.
undo isolate enable
By default, OSPFv3 isolation is disabled.
Configuring OSPFv3 shutdown
For maintenance purposes, you can use this feature to shut down processes on the device with small impact on the network. If you shut down an OSPFv3 process, it will perform the following operations:
· Send 1-way hello packets to its neighbors.
On receipt of the packets, the neighbors disconnect from the process and use the backup path to forward traffic.
· Stop receiving and sending OSPFv3 packets.
· Clear its neighbor, LSDB, and OSPFv3 route information.
After maintenance, you can use the undo shutdown process command to restart the process for neighbor relationship re-establishment.
This feature shuts down an OSPFv3 process while retaining the process-associated settings to facilitate your maintenance.
3. Configure OSPFv3 shutdown.
a. Shut down an OSPFv3 process to isolate it from the network.
shutdown process
b. Restart the OSPFv3 process to add it back to the network.
By default, the OSPFv3 process is not shut down.
Configuring the virtual system feature
In an AS, each OSPFv3 node has a unique router ID and can manage multiple OSPFv3 interfaces. The IPv6 addresses of the interfaces managed by the same OSPFv3 node cannot reside on the same network segment.
3. Enable the virtual system feature for the OSPFv3 process.
virtual-system enable
By default, the virtual system feature is disabled.
4. Return to system view.
5. Enter interface view.
6. Enable the virtual system feature on the OSPFv3 interface.
ospfv3 virtual-system router-id router-id
Configuring OSPFv3 GR
About OSPFv3 GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
· GR restarter—Graceful restarting router. It must be Graceful Restart capable.
· GR helper—The neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
To prevent service interruption after a master/backup switchover, a GR restarter running OSPFv3 must perform the following tasks:
· Keep the GR restarter forwarding entries stable during reboot.
· Establish all adjacencies and obtain complete topology information after reboot.
After the active/standbyswitchover, the GR restarter sends a Grace LSA to tell its neighbors that it performs a GR. Upon receiving the Grace LSA, the neighbors with the GR helper capability enter the helper mode (and are called GR helpers). Then, the GR restarter retrieves its adjacencies and LSDB with the help of the GR helpers.
Configuring GR restarter
2. Enter OSPFv3 view.
3. Enable the GR capability.
graceful-restart enable [ global | planned-only ] *
By default, OSPFv3 GR restarter capability is disabled.
4. (Optional.) Set the GR interval.
By default, the GR interval is 120 seconds.
Configuring GR helper
3. Enable the GR helper capability.
By default, the GR helper capability is enabled.
4. Enable strict LSA checking.
graceful-restart helper strict-lsa-checking
By default, strict LSA checking is disabled.
Triggering OSPFv3 GR
OSPFv3 GR is triggered by an active/standby switchover or when this task is performed.
To trigger OSPFv3 GR, execute the reset ospfv3 [ process-id ] process graceful-restart command in user view.
Bidirectional forwarding detection (BFD) provides a mechanism to quickly detect the connectivity of links between OSPFv3 neighbors, improving the convergence speed of OSPFv3. For more information about BFD, see High Availability Configuration Guide.
After discovering neighbors by sending hello packets, OSPFv3 notifies BFD of the neighbor addresses, and BFD uses these addresses to establish sessions. Before a BFD session is established, it is in the down state. In this state, BFD control packets are sent at an interval of no less than 1 second to reduce BFD control packet traffic. After the BFD session is established, BFD control packets are sent at the negotiated interval, thereby implementing fast fault detection.
To configure BFD for OSPFv3, you need to configure OSPFv3 first.
3. Specify a router ID.
router-id router-id
4. Quit the OSPFv3 view.
6. Enable an OSPFv3 process on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
7. Enable BFD on the interface.
ospfv3 bfd enable [ instance instance-id ]
By default, BFD is disabled on the OSPFv3 interface.
Enabling OSPFv3 to adjust the interface cost according to the BFD session state
After you enable BFD for OSPFv3, the OSPFv3 neighbor relationship goes down when the BFD session is down and comes up when the BFD session is up. When the BFD session state changes frequently, OSPFv3 neighbor relationship flapping will occur and traffic forwarding might be affected.
To resolve this issue, enable OSPFv3 to adjust the interface cost according to the BFD session state.
After you execute this command on an interface, OSPFv3 adjusts the interface cost as follows:
· When the BFD session on the interface goes down, OSPFv3 increases the cost value for the interface.
· When the BFD session on the interface comes up, OSPFv3 restores the cost value for the interface.
2. Enter interface OSPFv3 view.
3. Enable OSPFv3 to adjust the interface cost according to the BFD session state.
ospfv3 bfd adjust-cost { cost-offset | max } [ instance instance-id ]
By default, OSPFv3 does not adjust the interface cost according to the BFD session state.
Suppressing interface cost adjustment according to the BFD session state upon BFD session flapping
After you enable OSPFv3 to adjust the interface cost according to the BFD session state, if BFD session flaps frequently, the following conditions might occur:
· The OSPFv3 interface cost changes frequently, resulting in repeated route calculations that greatly consume device resources.
· When the BFD session state changes from down to up, OSPFv3 immediately resumes the original interface cost. If the link becomes unavailable again in a short time, packet loss will occur on this link before route convergence.
You can configure this feature to address the previous issues. When the BFD session state changes, OSPFv3 performs the following operations instead of immediately adjusting the interface cost:
· When the BFD session state changes from up to down, OSPFv3 starts a BFD session state detection timer, and records one BFD session down event. If the number of BFD session down events crosses the threshold within the detection interval, OSPFv3 adjusts the interface cost based on configuration of the ospfv3 bfd adjust-cost command. (The threshold is specified with the threshold keyword. The detection interval is specified with the detect-interval argument.) If this condition is not met, OSPFv3 does not adjust the interface cost.
· After OSPFv3 adjusts the interface cost (based on the configuration of the ospfv3 bfd adjust-cost command), it starts a delay timer when the BFD session state changes from down to up. Before expiration of the delay timer (specified with the resume-interval argument), the following conditions will occur:
¡ If the BFD session remains up, OSPFv3 resumes the original interface cost when the delay timer expires.
¡ If the BFD session state changes from up to down, OSPFv3 deletes the delay timer and does not resume the original interface cost.
This command takes effect only after you configure the ospfv3 bfd adjust-cost command.
2. Enter interface view.
3. Suppress adjustment of the interface cost according to the BFD session state upon BFD session flapping.
ospfv3 bfd adjust-cost suppress-flapping { detect-interval detect-interval | resume-interval resume-interval | threshold threshold } *
By default, OSPFv3 does not suppress adjustment of the interface cost according to the BFD session state upon BFD session flapping.
Configuring OSPFv3 FRR
About OSPFv3 FRR
A primary link failure can cause packet loss and even a routing loop until OSPFv3 completes routing convergence based on the new network topology. OSPFv3 FRR enables fast rerouting to minimize the failover time.
Figure 9 Network diagram for OSPFv3 FRR
As shown in Figure 9, configure FRR on Router B. OSPFv3 FRR automatically calculates a backup next hop or specifies a backup next hop by using a routing policy. When the primary link fails, OSPFv3 directs packets to the backup next hop. At the same time, OSPFv3 calculates the shortest path based on the new network topology. It forwards packets over the path after network convergence.
You can configure OSPFv3 FRR to calculate a backup next hop by using the loop free alternate (LFA) algorithm, or specify a backup next hop by using a routing policy.
Configuring OSPFv3 FRR to use the LFA algorithm to calculate a backup next hop
Perform this task to configure OSPFv3 to select a backup next hop for each non-ECMP route, or for each route including ECMP routes, by using the LFA algorithm.
OSPFv3 ECMP FRR
In ECMP scenarios, you can configure OSPF to calculate a backup next hop separately for each ECMP route with the LFA algorithm. ECMP routes might not share the same backup next hop.
As shown in Figure 10, the source node Device A forwards traffic to the destination node Device D. Traffic is load balanced among Link 1, Link 2, and Link 3.
· With ECMP FRR disabled, OSPF does not calculate a backup next hop separately for Link 1, Link 2, and Link 3. When Link 1 fails, traffic previously forwarded through Link 1 is randomly switched to Link 2 or Link 3. This does not facilitate service traffic management.
· With ECMP FRR enabled, OSPF calculates a backup next hop separately for Link 1, Link 2, and Link 3. For example, if the backup next hop for Link 1 is Device C, when Link 1 fails, traffic previously forwarded through Link 1 is switched to backup next hop Device C. This facilitates service traffic management.
Figure 10 Network diagram for OSPFv3 ECMP FRR
OSPFv3 ECMP-shared FRR
In ECMP scenarios, you can configure OSPF to calculate a backup next hop for ECMP routes with the LFA algorithm. ECMP routes share the same backup next hop.
As shown in Figure 11, the source node Device A forwards traffic to the destination node Device D. Traffic is load balanced between Link 1 and Link 2. ECMP-shared FRR operates as follows:
· With ECMP-shared FRR disabled, OSPF does not calculate any backup next hop for Link 1 or Link 2. When Device B fails, Link 1 and Link 2 both fail, causing traffic disruption before routing convergence.
· With ECMP-shared FRR enabled, OSPF calculates a backup next hop for Link 1 and Link 2. If Device B fails, traffic is switched to the backup next hop Device C, preventing traffic disruption.
Figure 11 Network diagram for OSPFv3 ECMP-shared FRR
Do not use the fast-reroute lfa command together with the vlink-peer command.
3. (Optional.) Disable LFA on an interface.
ospfv3 fast-reroute lfa-backup exclude
By default, the interface on which LFA is enabled can be selected as a backup interface.
5. Enter OSPFv3 view.
6. Enable OSPFv3 FRR to use the LFA algorithm to calculate a backup next hop.
fast-reroute lfa [ abr-only | ecmp-frr | ecmp-shared ]
By default, OSPFv3 FRR is disabled.
If abr-only is specified, the route to the ABR is selected as the backup path.
Configuring OSPFv3 FRR to use a backup next hop in a routing policy
Before you perform this task, use the apply ipv6 fast-reroute backup-interface command to specify a backup next hop in the routing policy to be used. For more information about the apply ipv6 fast-reroute backup-interface command and routing policy configuration, see "Configuring routing policies."
By default, the interface is enabled with LFA and it can be selected as a backup interface.
6. Configure OSPFv3 FRR to use a backup next hop in a routing policy.
Setting the priority for FRR backup path selection policies
OSPFv3 FRR uses specific policies for backup path calculation. This command defines the priority for the backup path selection policy. The higher the value, the higher the priority of the associated backup path selection policy. Changing the backup path selection policy priority can affect the backup path calculation result for OSPFv3 FRR. The backup paths can provide node protection or link protection for traffic, or provide both node protection and link protection.
OSPFv3 FRR supports the following backup path selection policies that are used to generate different topologies for backup path calculation:
· Node protection—OSPFv3 FRR performs backup path calculation after excluding the primary next hop node.
· Lowest cost—OSPFv3 FRR performs backup path calculation after excluding the direct primary link.
If multiple backup path selection policies exist in an OSPFv3 process, the policy with the highest priority is used to calculate the backup path. If the policy fails to calculate the backup path, the policy with the highest priority in the remaining policies is used. OSPFv3 performs backup path calculation by using the node protection and lowest cost policies as follows:
· If the node protection policy has higher priority and fails to calculate the backup path, OSPF uses the lowest cost policy to calculate the backup path. If the lowest cost policy still fails to calculate the backup path, reliability cannot be ensured upon primary link failure.
· If the lowest cost policy has higher priority and fails to calculate the backup path, OSPF does not perform further backup path calculation with the node protection policy. Reliability cannot be ensured upon primary link failure.
Table 1 shows the backup path selection mechanism for OSPFv3 FRR based on priorities of backup path selection policies.
Priorities of link selection policies |
Backup path selection mechanism for OSPFv3 FRR |
Node protection > lowest cost |
OSPFv3 FRR performs calculations based on the node protection and lowest cost policies in descending order of priority. OSPFv3 FRR performs a maximum of two calculations. If OSPFv3 FRR calculates a backup path with a link selection policy, it does not perform further calculations. |
Lowest cost > node protection |
OSPFv3 FRR performs calculations based on the lowest cost policy. OSPFv3 FRR performs only one calculation. |
In a multi-active and multi-backup scenario, multiple load balancing paths exist between the source node and the destination node. You can enable OSPFv3 FRR to calculate a backup path separately for each load balancing path. By default, OSPFv3 FRR preferentially selects the path with the lowest cost as the backup path when it uses the node protection or lowest cost policy for backup path calculation. OSPFv3 FRR does not identify whether the selected backup path is a load balancing path, except in the following situations:
· OSPFv3 FRR uses the node protection policy to calculate backup paths. Only if the non-ECMP policy takes precedence over the node protection policy, OSPFv3 FRR prefers non-load-balancing paths during backup path selection. If no non-load-balancing path exists, OSPFv3 FRR selects a load balancing path as the backup path. If the lowest cost policy fails to calculate the backup path, OSPFv3 FRR uses the lowest cost policy for further calculation.
· OSPFv3 FRR uses the lowest cost policy to calculate backup paths. Only if the non-ECMP policy takes precedence over the lowest cost policy, OSPFv3 FRR prefers non-load-balancing paths during backup path selection. If no non-load-balancing path exists, OSPFv3 FRR selects a load balancing path as the backup path. If the lowest cost policy fails to calculate the backup path, OSPFv3 FRR does not use the node protection policy to calculate backup paths.
OSPFv3 FRR uses different backup path selection policies to select the backup path as follows:
· Node protection policy
As shown in Figure 12, Device A uses the node protection policy and selects path Device A->Device B->Device D as the backup path.
Figure 12 Node protection backup path selection
· Lowest cost policy
As shown in Figure 13, Device A uses the lowest cost policy and selects path Device A->Device E->Device D as the backup path.
Figure 13 Lowest cost backup path selection
3. Set the priority for a backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting | non-ecmp } preference preference
By default, the priority values of the node-protection, lowest-cost, and non-ECMP backup path selection policies are 40, 20, and 15, respectively.
Configuring BFD control packet mode for OSPFv3 FRR
By default, OSPFv3 FRR does not use BFD to detect primary link failures. To speed up OSPFv3 convergence, enable BFD control packet mode for OSPFv3 FRR to detect primary link failures. This mode requires BFD configuration on both OSPFv3 routers on the link.
3. Enable BFD control packet mode for OSPFv3 FRR.
By default, BFD control packet mode is disabled for OSPFv3 FRR.
Configuring BFD echo packet mode for OSPFv3 FRR
By default, OSPFv3 FRR does not use BFD to detect primary link failures. To speed up OSPFv3 convergence, enable BFD echo packet mode for OSPFv3 FRR to detect primary link failures. This mode requires BFD configuration on one OSPFv3 router on the link.
4. Enable BFD echo packet mode for OSPFv3 FRR.
By default, BFD echo packet mode is disabled for OSPFv3 FRR.
Enhancing OSPFv3 security
Configuring OSPFv3 authentication
OSPFv3 uses keychain authentication to prevent routing information from being leaked and routers from being attacked.
OSPFv3 adds the Authentication Trailer option into outgoing packets, and uses the authentication information in the option to authenticate incoming packets. Only packets that pass the authentication can be received. If a packet fails the authentication, the OSPFv3 neighbor relationship cannot be established.
The authentication mode specified for an OSPFv3 interface has a higher priority than the mode specified for the OSPFv3 area to which that OSPFv3 interface belongs.
Configuring OSPFv3 area authentication
3. Enter OSPFv3 area view.
area area-id
4. Specify an authentication mode for the area. Choose one option as needed:
¡ Configure the area to use HMAC-SHA-256/HMAC-SM3 authentication.
authentication-mode { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string
¡ Configure the area to use keychain authentication.
authentication-mode keychain keychain-name
For more information about keychains, see keychain configuration in Security Configuration Guide.
By default, no authentication is performed for the area.
All routers in an area must use the same authentication mode and the same key.
Configuring OSPFv3 interface authentication
3. Specify an authentication mode for the interface. Choose one option as needed:
¡ Configure the interface to use HMAC-SHA-256/HMAC-SM3 authentication.
ospfv3 authentication-mode { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string [ instance instance-id ]
¡ Configure the interface to use keychain authentication.
ospfv3 authentication-mode keychain keychain-name [ instance instance-id ]
By default, no authentication is performed for the interface.
All interfaces on a network must use the same authentication mode and the same key.
Applying an IPsec profile for authenticating OSPFv3 packets
To protect routing information and prevent attacks, OSPFv3 can authenticate protocol packets by using an IPsec profile. For more information about IPsec profiles, see Security Configuration Guide.
Outbound OSPFv3 packets carry the Security Parameter Index (SPI) defined in the relevant IPsec profile. A device compares the SPI carried in a received packet with the configured IPsec profile. If they match, the device accepts the packet. Otherwise, the device discards the packet and will not establish a neighbor relationship with the sending device.
Restrictions and guidelines for applying an IPsec profile
You can configure an IPsec profile for an area, an interface, a virtual link, or a sham link.
· To implement area-based IPsec protection, configure the same IPsec profile on the routers in the target area.
· To implement interface-based IPsec protection, configure the same IPsec profile on the interfaces between two neighboring routers.
· To implement virtual link-based IPsec protection, configure the same IPsec profile on the two routers connected over the virtual link.
· To implement sham link-based IPsec protection, configure the same IPsec profile on the two routers connected over the sham link. For more information about sham links, see MPLS Configuration Guide.
· If an interface and its area each have an IPsec profile configured, the interface uses its own IPsec profile.
· If a virtual link and area 0 each have an IPsec profile configured, the virtual link uses its own IPsec profile.
· If a sham link and its area have an IPsec profile configured, the sham link uses its own IPsec profile.
Applying an IPsec profile to an area
area area-id
4. Apply an IPsec profile to the area.
enable ipsec-profile profile-name
By default, no IPsec profile is applied.
Applying an IPsec profile to an interface
3. Apply an IPsec profile to the interface.
ospfv3 ipsec-profile profile-name [ instance instance-id ]
Applying an IPsec profile to a virtual link
area area-id
4. Apply an IPsec profile to a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit seconds | trans-delay seconds ] *
Applying an IPsec profile to a sham link
area area-id
4. Apply an IPsec profile to a sham link.
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit retrans-interval | trans-delay delay ] *
Configuring OSPFv3 logging and SNMP notifications
Enabling logging for neighbor state changes
With this feature enabled, the router delivers logs about neighbor state changes to its information center. The information center processes logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see Network Management and Monitoring Configuration Guide.
3. Enable logging for neighbor state changes.
log-peer-change
By default, this feature is enabled.
Setting the maximum number of OSPFv3 logs
OSPFv3 logs include route calculation logs, neighbor logs, and LSA aging logs.
3. Set the maximum number of OSPFv3 logs.
event-log { lsa-flush | peer | spf } size count
By default, the maximum number of LSA aging logs, neighbor logs, or route calculation logs is 10.
Configuring OSPFv3 network management
This task involves the following configurations:
· Bind an OSPFv3 process to MIB so that you can use network management software to manage the specified OSPFv3 process.
· Enable SNMP notifications for OSPFv3 to report important events.
· Set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
To report critical OSPFv3 events to an NMS, enable SNMP notifications for OSPFv3. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
The standard OSPFv3 MIB provides only single-instance MIB objects. To identify multiple OSPFv3 processes in the standard OSPFv3 MIB, you must assign a unique context name to each OSPFv3 process.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a community name as a context name for protocol identification.
2. Bind MIB to an OSPFv3 process.
ospfv3 mib-binding process-id
By default, MIB is bound to the process with the smallest process ID.
3. Enable SNMP notifications for OSPFv3.
snmp-agent trap enable ospfv3 [ grhelper-status-change | grrestarter-status-change | if-bad-pkt | if-cfg-error | if-state-change | intra-area-router-id-conflict | last-auth-key-expiry | neighbor-state-change | nssatranslator-status-change | virtgrhelper-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtneighbor-state-chang ] *
By default, SNMP notifications for OSPFv3 are enabled.
4. Enter OSPFv3 view.
5. Configure an SNMP context for the OSPFv3 process.
By default, no SNMP context is configured for the OSPFv3 process.
6. (Optional.) Set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
By default, OSPFv3 outputs a maximum of seven SNMP notifications within 10 seconds.
Display and maintenance commands for OSPFv3
Task |
Command |
Display information about the routes to OSPFv3 ABR and ASBR. |
display ospfv3 [ process-id ] abr-asbr |
Display summary route information on the OSPFv3 ABR. |
display ospfv3 [ process-id ] [ area area-id ] abr-summary [ ipv6-address prefix-length ] [ verbose ] |
Display information about the SPF tree calculated by a flexible algorithm for an OSPFv3 area. |
display ospfv3 [ process-id ] [ area area-id ] flex-algo flex-algo-id spf-tree [ verbose ] |
Display information about the FADs received or advertised by a node. |
display ospfv3 [ process-id ] [ area area-id ] global-flex-algo [ algorithm-id flex-algo-id ] |
Display summary route information on the OSPFv3 ASBR. |
display ospfv3 [ process-id ] asbr-summary [ ipv6-address prefix-length ] [ verbose ] |
Display OSPFv3 log information. |
display ospfv3 [ process-id ] event-log { lsa-flush | peer | spf } |
Display information about routes calculated by a flexible algorithm. |
display ospfv3 [ process-id ] flex-algo flex-algo-id routing [ ipv6-address prefix-length ] |
Display OSPFv3 process information. |
display ospfv3 [ process-id ] [ verbose ] |
Display OSPFv3 GR information. |
display ospfv3 [ process-id ] graceful-restart [ verbose ] |
Display OSPFv3 NSR information. |
display ospfv3 [ process-id ] non-stop-routing |
Display OSPFv3 interface information. |
display ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ] |
Display the configuration for a flexible algorithm on a node. |
display ospfv3 [ process-id ] local-flex-algo [ algorithm-id flex-algo-id ] |
Display OSPFv3 LSDB information. |
display ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | intra-te | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ] |
Display OSPFv3 next hop information. |
display ospfv3 [ process-id ] nexthop |
Display OSPFv3 neighbor information. |
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ] display ospfv3 [ process-id ] [ area area-id ] peer [ interface-type interface-number ] lsa-flush-received [ peer-router-id ] |
Display OSPFv3 request list information. |
display ospfv3 [ process-id ] [ area area-id ] request-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPFv3 retransmission list information. |
display ospfv3 [ process-id ] [ area area-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPFv3 routing information. |
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length ] |
Display OSPFv3 SPF tree information. |
display ospfv3 [ process-id ] [ area area-id ] spf-tree [ verbose ] |
Display OSPFv3 statistics. |
display ospfv3 [ process-id ] statistics [ error ] |
Display OSPFv3 virtual link information. |
display ospfv3 [ process-id ] vlink |
Display global OSPFv3 statistics. |
display ospfv3 global-statistics [ public | vpn-instance vpn-instance-name ] |
Restart an OSPFv3 process. |
reset ospfv3 [ process-id ] process [ graceful-restart ] |
Restart OSPFv3 route redistribution. |
reset ospfv3 [ process-id ] redistribution |
Clear OSPFv3 statistics. |
reset ospfv3 [ process-id ] statistics |
Clear OSPFv3 log information. |
reset ospfv3 [ process-id ] event-log [ lsa-flush | peer | spf ] |
OSPFv3 configuration examples
Example: Configuring OSPFv3 stub area
As shown in Figure 14:
· Enable OSPFv3 on all routers.
· Split the AS into three areas.
· Configure Router B and Router C as ABRs to forward routing information between areas.
· Configure Area 2 as a stub area to reduce LSAs in the area without affecting route reachability.
Table 2 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Ten-GigabitEthernet3/0/1 |
Interface2 |
Ten-GigabitEthernet3/0/2 |
1. Configure IPv6 addresses for interfaces.
# Assign IPv6 addresses to the related interfaces on Router A.
[Sysname] sysname RouterA
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::1 64
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 2001:1::2 64
[RouterA-Ten-GigabitEthernet3/0/2] quit
# Assign IPv6 addresses to the related interfaces on Router B.
[Sysname] sysname RouterB
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 2001::1 64
[RouterB-Ten-GigabitEthernet3/0/1] quit
[RouterB] interface ten-gigabitethernet 3/0/2
[RouterB-Ten-GigabitEthernet3/0/2] ipv6 address 2001:1::1 64
[RouterB-Ten-GigabitEthernet3/0/2] quit
# Assign IPv6 addresses to the related interfaces on Router C.
[Sysname] sysname RouterC
[RouterC] interface ten-gigabitethernet 3/0/1
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 2001::2 64
[RouterC-Ten-GigabitEthernet3/0/1] quit
[RouterC] interface ten-gigabitethernet 3/0/2
[RouterC-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::1 64
[RouterC-Ten-GigabitEthernet3/0/2] quit
# Assign IPv6 addresses to the related interfaces on Router D.
[Sysname] sysname RouterD
[RouterD] interface ten-gigabitethernet 3/0/2
[RouterD-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::2 64
[RouterD-Ten-GigabitEthernet3/0/2] quit
2. Configure basic OSPFv3:
# On Router A, enable OSPFv3 and specify the router ID as 1.1.1.1.
[RouterA] ospfv3 1
[RouterA-ospfv3-1] router-id 1.1.1.1
[RouterA-ospfv3-1] quit
[RouterA-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
[RouterA-Ten-GigabitEthernet3/0/2] ospfv3 1 area 1
# On Router B, enable OSPFv3 and specify the router ID as 2.2.2.2.
[RouterB] ospfv3 1
[RouterB-ospfv3-1] router-id 2.2.2.2
[RouterB-ospfv3-1] quit
[RouterB-Ten-GigabitEthernet3/0/1] ospfv3 1 area 0
[RouterB-Ten-GigabitEthernet3/0/2] ospfv3 1 area 1
# On Router C, enable OSPFv3 and specify the router ID as 3.3.3.3.
[RouterC] ospfv3 1
[RouterC-ospfv3-1] router-id 3.3.3.3
[RouterC-ospfv3-1] quit
[RouterC-Ten-GigabitEthernet3/0/1] ospfv3 1 area 0
[RouterC-Ten-GigabitEthernet3/0/2] ospfv3 1 area 2
# On Router D, enable OSPFv3 and specify the router ID as 4.4.4.4.
[RouterD] ospfv3 1
[RouterD-ospfv3-1] router-id 4.4.4.4
[RouterD-ospfv3-1] quit
[RouterD-Ten-GigabitEthernet3/0/2] ospfv3 1 area 2
# Display OSPFv3 neighbors on Router B.
[RouterB] display ospfv3 peer
OSPFv3 Process 1 with Router ID 2.2.2.2
Area: 0.0.0.0
Router ID Pri State Dead-Time InstID Interface
3.3.3.3 1 Full/BDR 00:00:40 0 XGE3/0/1
Area: 0.0.0.1
1.1.1.1 1 Full/DR 00:00:40 0 XGE3/0/2
# Display OSPFv3 neighbors on Router C.
[RouterC] display ospfv3 peer
OSPFv3 Process 1 with Router ID 3.3.3.3
Area: 0.0.0.0
2.2.2.2 1 Full/DR 00:00:40 0 XGE3/0/1
Area: 0.0.0.2
4.4.4.4 1 Full/BDR 00:00:40 0 XGE3/0/2
# Display OSPFv3 neighbors on Router D.
[RouterD] display ospfv3 routing
OSPFv3 Process 1 with Router ID 4.4.4.4
I - Intra area route, E1 - Type 1 external route, N1 - Type 1 NSSA route
IA - Inter area route, E2 - Type 2 external route, N2 - Type 2 NSSA route
* - Selected route
*Destination: 2001::/64
Type : IA Area : 0.0.0.2
AdvRouter : 3.3.3.3 Preference : 10
NibID : 0x23000004 Cost : 2
Interface : XGE3/0/2 BkInterface: N/A
Nexthop : FE80::48C0:26FF:FEDA:305
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
*Destination: 2001:1::/64
NibID : 0x23000004 Cost : 3
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
*Destination: 2001:2::/64
Type : I Area : 0.0.0.2
AdvRouter : 4.4.4.4 Preference : 10
NibID : 0x23000002 Cost : 1
Nexthop : ::
NexthopFlag: -
BkNexthop : N/A
Status : Direct
Delay Flag : N/A
*Destination: 2001:3::1/128
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
Total: 4
Intra area: 1 Inter area: 3 ASE: 0 NSSA: 0
3. Configure Area 2 as a stub area:
# Configure Router D.
[RouterD] ospfv3
[RouterD-ospfv3-1] area 2
[RouterD-ospfv3-1-area-0.0.0.2] stub
[RouterD-ospfv3-1-area-0.0.0.2] quit
# Configure Router C, and specify the cost of the default route sent to the stub area as 10.
[RouterC] ospfv3
[RouterC-ospfv3-1] area 2
[RouterC-ospfv3-1-area-0.0.0.2] stub
[RouterC-ospfv3-1-area-0.0.0.2] default-cost 10
# Display OSPFv3 routing table on Router D.
* - Selected route
*Destination: ::/0
NibID : 0x23000003 Cost : 11
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NibID : 0x23000003 Cost : 2
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NibID : 0x23000003 Cost : 3
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NibID : 0x23000001 Cost : 1
Nexthop : ::
NexthopFlag: -
BkNexthop : N/A
Status : Direct
Delay Flag : N/A
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
Total: 5
Intra area: 1 Inter area: 4 ASE: 0 NSSA: 0
The output shows that a default route is added and its cost is the cost of a direct route plus the configured cost.
4. Configure Area 2 as a totally stub area to further reduce the stub area routing table size:
# Configure Area 2 as a totally stub area on Router C.
[RouterC-ospfv3-1-area-0.0.0.2] stub no-summary
* - Selected route
*Destination: ::/0
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
Nexthop : ::
NexthopFlag: -
BkNexthop : N/A
Status : Direct
Delay Flag : N/A
Total: 2
Intra area: 1 Inter area: 1 ASE: 0 NSSA: 0
The output shows that route entries are reduced. All indirect routes are removed, except the default route.
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.1
interface Ten-GigabitEthernet3/0/1
ospfv3 1 area 0.0.0.1
ipv6 address 2001:3::1/64
interface Ten-GigabitEthernet3/0/2
ipv6 address 2001:1::2/64
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
area 0.0.0.1
ospfv3 1 area 0.0.0.0
ipv6 address 2001::1/64
ipv6 address 2001:1::1/64
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
area 0.0.0.2
stub no-summary
default-cost 10
ipv6 address 2001::2/64
ospfv3 1 area 0.0.0.2
ipv6 address 2001:2::1/64
return
Router D
sysname RouterD
ospfv3 1
router-id 4.4.4.4
area 0.0.0.2
stub
ipv6 address 2001:2::2/64
return
Example: Configuring OSPFv3 NSSA area
As shown in Figure 15:
· Configure OSPFv3 on all routers and split the AS into three areas.
· Configure Area 1 as an NSSA area and configure Router A as an ASBR to redistribute static routes into the AS.
Table 3 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
2. Configure basic OSPFv3 (see "Example: Configuring OSPFv3 stub area" or the configuration files).
3. Configure Area 1 as an NSSA area:
# Configure Router A.
[RouterA] ospfv3
[RouterA-ospfv3-1] area 1
[RouterA-ospfv3-1-area-0.0.0.1] nssa
[RouterA-ospfv3-1-area-0.0.0.1] quit
# Configure Router B.
[RouterB] ospfv3
[RouterB-ospfv3-1] area 1
[RouterB-ospfv3-1-area-0.0.0.1] nssa
[RouterB-ospfv3-1-area-0.0.0.1] quit
# Display OSPFv3 routing information on Router D.
<RouterD> display ospfv3 1 routing
* - Selected route
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NexthopFlag: -
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
Nexthop : ::
NexthopFlag: D
BkNexthop : N/A
Status : Direct
Delay Flag : N/A
*Destination: 2001:3::/64
NibID : 0x23000003 Cost : 4
Nexthop : ::
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
Total: 4
4. Configure route redistribution:
# Configure an IPv6 static route, and configure OSPFv3 to redistribute the static route on Router A.
[RouterA] ipv6 route-static 1234:: 64 null 0
[RouterA] ospfv3 1
[RouterA-ospfv3-1] import-route static
* - Selected route
NibID : 0x23000002 Cost : 2
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NibID : 0x23000002 Cost : 3
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
NibID : 0x23000004 Cost : 1
Nexthop : ::
NexthopFlag: -
BkNexthop : N/A
Status : Direct
Delay Flag : N/A
NibID : 0x23000002 Cost : 4
NexthopFlag: D
BkNexthop : N/A
Status : Rely
Delay Flag : N/A
*Destination: 1234::/64
Type : E2 Tag : 1
AdvRouter : 2.2.2.2 Preference : 150
NexthopFlag: D
BkNexthop : N/A
Status : Normal
Delay Flag : N/A
Total: 5
Intra area: 1 Inter area: 3 ASE: 1 NSSA: 0
The output shows an AS external route imported from the NSSA area exists on Router D.
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
import-route static
area 0.0.0.0
area 0.0.0.1
nssa
ipv6 route-static 1234:: 64 NULL0
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
area 0.0.0.1
nssa
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
area 0.0.0.2
return
Router D
sysname RouterD
ospfv3 1
router-id 4.4.4.4
area 0.0.0.1
area 0.0.0.2
return
Example: Configuring OSPFv3 DR election
As shown in Figure 16:
· Configure router priority 100 for Router A, the highest priority on the network, so it will become the DR.
· Configure router priority 2 for Router C, the second highest priority on the network, so it will become the BDR.
· Configure router priority 0 for Router B, so it cannot become a DR or BDR.
· Router D uses the default router priority 1.
Table 4 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2001::1 64
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 2001::2 64
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 2001::3 64
[RouterD] interface ten-gigabitethernet 3/0/1
[RouterD-Ten-GigabitEthernet3/0/1] ipv6 address 2001::4 64
[RouterD-Ten-GigabitEthernet3/0/1] quit
# On Router A, enable OSPFv3, and specify the router ID as 1.1.1.1.
[RouterA] ospfv3
[RouterA-Ten-GigabitEthernet3/0/1] ospfv3 1 area 0
# On Router B, enable OSPFv3, and specify the router ID as 2.2.2.2.
[RouterB] ospfv3
# On Router C, enable OSPFv3, and specify the router ID as 3.3.3.3.
[RouterC] ospfv3
# On Router D, enable OSPFv3, and specify the router ID as 4.4.4.4.
[RouterD] ospfv3
[RouterD-Ten-GigabitEthernet3/0/1] ospfv3 1 area 0
# Display neighbors on Router A. The routers have the same default router priority 1, so Router D (the router with the highest router ID) is elected as the DR, and Router C is the BDR.
[RouterA] display ospfv3 peer
OSPFv3 Process 1 with Router ID 1.1.1.1
Area: 0.0.0.0
2.2.2.2 1 2-Way/DROther 00:00:36 0 XGE3/0/1
3.3.3.3 1 Full/BDR 00:00:35 0 XGE3/0/1
4.4.4.4 1 Full/DR 00:00:33 0 XGE3/0/1
# Display neighbors on Router D. The neighbor states are all full.
[RouterD] display ospfv3 peer
Area: 0.0.0.0
1.1.1.1 1 Full/DROther 00:00:30 0 XGE3/0/1
2.2.2.2 1 Full/DROther 00:00:37 0 XGE3/0/1
3.3.3.3 1 Full/BDR 00:00:31 0 XGE3/0/1
3. Configure router priorities for interfaces:
# Set the router priority to 100 for the interface Ten-GigabitEthernet 3/0/1 of Router A.
[RouterA-Ten-GigabitEthernet3/0/1] ospfv3 dr-priority 100
# Set the router priority to 0 for the interface Ten-GigabitEthernet 3/0/1 of Router B.
[RouterB-Ten-GigabitEthernet3/0/1] ospfv3 dr-priority 0
# Set the router priority to 2 for the interface Ten-GigabitEthernet 3/0/1 of Router C.
[RouterC-Ten-GigabitEthernet3/0/1] ospfv3 dr-priority 2
# Display neighbors on Router A. The output shows that the router priorities have been changed, but the DR and BDR are not changed.
Area: 0.0.0.0
2.2.2.2 0 2-Way/DROther 00:00:36 0 XGE3/0/1
3.3.3.3 2 Full/BDR 00:00:35 0 XGE3/0/1
Area: 0.0.0.0
1.1.1.1 100 Full/DROther 00:00:30 0 XGE3/0/1
2.2.2.2 0 Full/DROther 00:00:37 0 XGE3/0/1
3.3.3.3 2 Full/BDR 00:00:31 0 XGE3/0/1
The output shows that the DR is still Router D.
4. Enable DR/BDR election:
# Perform the shutdown and undo shutdown commands on each interface to enable a new DR/BD election. (Details not shown.)
# Display neighbors on Router A. The output shows that Router C becomes the BDR.
Area: 0.0.0.0
2.2.2.2 0 Full/DROther 00:00:36 0 XGE3/0/1
4.4.4.4 1 Full/DROther 00:00:33 0 XGE3/0/1
Area: 0.0.0.0
1.1.1.1 100 Full/DR 00:00:30 0 XGE3/0/1
2.2.2.2 0 2-Way/DROther 00:00:37 0 XGE3/0/1
The output shows that Router A becomes the DR.
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
ipv6 address 2001::3/64
return
Router D
sysname RouterD
ospfv3 1
router-id 4.4.4.4
area 0.0.0.0
ipv6 address 2001::4/64
return
Example: Configuring OSPFv3 route redistribution
As shown in Figure 17:
· Router A, Router B, and Router C are in Area 2.
· OSPFv3 process 1 and OSPFv3 process 2 run on Router B. Router B communicates with Router A and Router C through OSPFv3 process 1 and OSPFv3 process 2.
· Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Router B, and set the metric for redistributed routes to 3. Router C can then learn the routes destined for 1::0/64 and 2::0/64, and Router A cannot learn the routes destined for 3::0/64 or 4::0/64.
Table 5 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2::1 64
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 1::1 64
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 3::1 64
[RouterB-Ten-GigabitEthernet3/0/2] ipv6 address 1::2 64
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 4::1 64
[RouterC-Ten-GigabitEthernet3/0/2] ipv6 address 3::2 64
# Enable OSPFv3 process 1 on Router A.
[RouterA] ospfv3 1
[RouterA-Ten-GigabitEthernet3/0/2] ospfv3 1 area 2
[RouterA-Ten-GigabitEthernet3/0/1] ospfv3 1 area 2
# Enable OSPFv3 process 1 and OSPFv3 process 2 on Router B.
[RouterB] ospfv3 1
[RouterB-Ten-GigabitEthernet3/0/2] ospfv3 1 area 2
[RouterB] ospfv3 2
[RouterB-ospfv3-2] router-id 3.3.3.3
[RouterB-ospfv3-2] quit
[RouterB-Ten-GigabitEthernet3/0/1] ospfv3 2 area 2
# Enable OSPFv3 process 2 on Router C.
[RouterC] ospfv3 2
[RouterC-ospfv3-2] router-id 4.4.4.4
[RouterC-ospfv3-2] quit
[RouterC-Ten-GigabitEthernet3/0/2] ospfv3 2 area 2
[RouterC-Ten-GigabitEthernet3/0/1] ospfv3 2 area 2
# Display the routing table on Router C.
[RouterC] display ipv6 routing-table
Destinations : 6 Routes : 6
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 3::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : XGE3/0/2 Cost : 0
Destination: 3::2/128 Protocol : Direct
Destination: 4::/64 Protocol : Direct
Interface : XGE3/0/1 Cost : 0
Destination: 4::1/128 Protocol : Direct
Destination: FE80::/10 Protocol : Direct
Interface : NULL0 Cost : 0
3. Configure OSPFv3 route redistribution:
# Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Router B, and set the metric for redistributed routes to 3.
[RouterB] ospfv3 2
[RouterB-ospfv3-2] import-route ospfv3 1 cost 3
[RouterB-ospfv3-2] import-route direct cost 3
Destinations : 8 Routes : 8
Destination: 1::/64 Protocol : O_ASE2
NextHop : FE80::200:CFF:FE01:1C03 Preference: 150
Interface : XGE3/0/2 Cost : 3
Destination: 2::/64 Protocol : O_ASE2
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.2
ipv6 address 2::1/64
ipv6 address 1::1/64
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.2
ospfv3 2
router-id 3.3.3.3
area 0.0.0.2
ipv6 address 3::1/64
ospfv3 2 area 0.0.0.2
ipv6 address 1::2/64
return
Router C
sysname RouterC
ospfv3 2
router-id 4.4.4.4
area 0.0.0.2
ipv6 address 4::1/64
ipv6 address 3::2/64
return
Example: Configuring OSPFv3 route summarization
As shown in Figure 18:
· OSPFv3 process 1 and OSPFv3 process 2 run on Router B. Router B communicates with Router A and Router C through OSPFv3 process 1 and OSPFv3 process 2, respectively.
· On Router A, configure IPv6 addresses 2:1:1::1/64, 2:1:2::1/64, and 2:1:3::1/64 for Ten-GigabitEthernet 3/0/1.
· On Router B, configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1. Router C can then learn the routes destined for 2::/64, 2:1:1::/64, 2:1:2::/64, and 2:1:3::/64.
· On Router B, configure route summarization to advertise only summary route 2::/16 to Router C.
Table 6 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2:1:1::1 64
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2:1:2::1 64
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2:1:3::1 64
2. Configure OSPFv3:
[RouterA] ospfv3 1
[RouterB] ospfv3 1
[RouterB] ospfv3 2
[RouterC] ospfv3 2
# Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Router B.
[RouterB] ospfv3 2
Destinations : 11 Routes : 11
Interface : XGE3/0/2 Cost : 1
Destination: 2:1:1::/64 Protocol : O_ASE2
Destination: 2:1:2::/64 Protocol : O_ASE2
Destination: 2:1:3::/64 Protocol : O_ASE2
NextHop : 3::2 Preference: 0
NextHop : 4::1 Preference: 0
4. Configure ASBR route summarization:
# On Router B, configure OSPFv3 process 2 to advertise a summary route 2::/16.
[RouterB] ospfv3 2
[RouterB-ospfv3-2] asbr-summary 2:: 16
Destination: 2::/16 Protocol : O_ASE2
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.2
ipv6 address 2:1:1::1/64
ipv6 address 2:1:2::1/64
ipv6 address 2:1:3::1/64
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.2
ospfv3 2
router-id 3.3.3.3
import-route direct
asbr-summary 2:: 16
area 0.0.0.2
return
Router C
sysname RouterC
ospfv3 2
router-id 4.4.4.4
area 0.0.0.2
return
Example: Configuring OSPFv3 GR
As shown in Figure 19:
· Router A, Router B, and Router C that reside in the same AS and the same OSPFv3 routing domain are GR capable.
· Router A acts as the GR restarter. Router B and Router C act as GR helpers, and synchronize their LSDBs with Router A through GR.
Table 7 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 2000::1 64
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 2000::2 64
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 2000::3 64
# On Router A, enable OSPFv3 process 1, enable GR, and set the router ID to 1.1.1.1.
[RouterA] ospfv3 1
[RouterA-ospfv3-1] graceful-restart enable
# On Router B, enable OSPFv3 and set the router ID to 2.2.2.2. (By default, GR helper is enabled on a router.)
[RouterB] ospfv3 1
[RouterB-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
# On Router C, enable OSPFv3 and set the router ID to 3.3.3.3. (By default, GR helper is enabled on a router.)
[RouterC] ospfv3 1
[RouterC-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
# Enable OSPFv3 GR event debugging and restart the OSPFv3 process by using GR on Router A.
<RouterA> debugging ospf event graceful-restart
<RouterA> terminal monitor
<RouterA> terminal logging level 7
<RouterA> reset ospfv3 1 process graceful-restart
Reset OSPFv3 process? [Y/N]:y
<RouterA>%Jun 19 11:14:03:206 2025 RouterA OSPFV3/3/OSPFv3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2(Ten-GigabitEthernet3/0/1) received KillNbr and its state changed from FULL to DOWN.
%Jun 19 11:14:03:206 2025 RouterA OSPFV3/3/OSPFv3_NBR_CHG: OSPFv3 1 Neighbor 3.3.3.3(Ten-GigabitEthernet3/0/1) received KillNbr and its state changed from FULL to DOWN.
*Jun 19 11:14:03:208 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: create GR waiting timer, timeout value is 40000(ms).
*Jun 19 11:14:03:208 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: create grace LSA send timer, timeout value is 1000(ms).
*Jun 19 11:14:07:213 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: delete grace LSA send timer.
*Jun 19 11:14:07:213 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: create GR period timer, timeout value is 120000(ms).
%Jun 19 11:14:10:287 2025 RouterA OSPFV3/3/OSPFv3_NBR_CHG: OSPFv3 1 Neighbor 3.3.3.3(Ten-GigabitEthernet3/0/1) received LoadingDone and its state changed from LOADING to FULL.
%Jun 19 11:14:11:087 2025 RouterA OSPFV3/3/OSPFv3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2(Ten-GigabitEthernet3/0/1) received LoadingDone and its state changed from LOADING to FULL.
*Jun 19 11:14:11:087 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: exit restarter mode for interface GigabitEthernet0/1, completed.
*Jun 19 11:14:11:087 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: delete GR waiting timer.
*Jun 19 11:14:11:087 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: delete GR period timer.
*Jun 19 11:14:11:087 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: process exit restarter mode, all neighbors have been done.
*Jun 19 11:14:11:087 2025 RouterA OSPFV3/7/OSPFV3DEBUG: OSPFv3 1: graceful restart finished.
The output shows that Router A has completed GR.
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.1
ipv6 address 2000::1/64
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.1
ipv6 address 2000::2/64
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.1
ipv6 address 2000::3/64
return
Example: Configuring BFD for OSPFv3
As shown in Figure 20:
· Configure OSPFv3 on Router A, Router B and Router C and configure BFD over the link Router A<—>L2 Switch<—>Router B.
· After the link Router A<—>L2 Switch<—>Router B fails, BFD can quickly detect the failure and notify OSPFv3 of the failure. Then Router A and Router B communicate through Router C.
Table 8 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Table 9 Interface and IP address assignment
Device |
IPv6 address |
Router A |
XGE3/0/1 |
2001::1/64 |
Router A |
XGE3/0/2 |
2001:2::1/64 |
Router B |
XGE3/0/1 |
2001::2/64 |
Router B |
XGE3/0/2 |
2001:3::2/64 |
Router C |
XGE3/0/1 |
2001:2::2/64 |
Router C |
XGE3/0/2 |
2001:3::1/64 |
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::1 64
[RouterB-Ten-GigabitEthernet3/0/2] ipv6 address 2001:3::2 64
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::2 64
[RouterC-Ten-GigabitEthernet3/0/2] ipv6 address 2001:3::1 64
# Enable OSPFv3 and set the router ID to 1.1.1.1 on Router A.
[RouterA] ospfv3 1
[RouterA-Ten-GigabitEthernet3/0/2] ospfv3 1 area 0
# Enable OSPFv3 and set the router ID to 2.2.2.2 on Router B.
[RouterB] ospfv3 1
[RouterB-Ten-GigabitEthernet3/0/2] ospfv3 1 area 0
# Enable OSPFv3 and set the router ID to 3.3.3.3 on Router C.
[RouterC] ospfv3 1
[RouterC-Ten-GigabitEthernet3/0/2] ospfv3 1 area 0
3. Configure BFD:
# Enable BFD and configure BFD parameters on Router A.
[RouterA] bfd session init-mode active
[RouterA-Ten-GigabitEthernet3/0/1] ospfv3 bfd enable
[RouterA-Ten-GigabitEthernet3/0/1] bfd min-transmit-interval 500
[RouterA-Ten-GigabitEthernet3/0/1] bfd min-receive-interval 500
[RouterA-Ten-GigabitEthernet3/0/1] bfd detect-multiplier 7
# Enable BFD and configure BFD parameters on Router B.
[RouterB] bfd session init-mode active
[RouterB-Ten-GigabitEthernet3/0/1] ospfv3 bfd enable
[RouterB-Ten-GigabitEthernet3/0/1] bfd min-transmit-interval 500
[RouterB-Ten-GigabitEthernet3/0/1] bfd min-receive-interval 500
[RouterB-Ten-GigabitEthernet3/0/1] bfd detect-multiplier 6
# Display the BFD information on Router A.
[RouterA] display bfd session
Total sessions: 1 Up sessions: 1 Init mode: Active
IPv6 session working in control packet mode:
Local discr: 1441 Remote discr: 1450
Source IP: FE80::20F:FF:FE00:1202 (link-local address of Ten-GigabitEthernet3/0/1 on Router A)
Destination IP: FE80::20F:FF:FE00:1200 (link-local address of Ten-GigabitEthernet3/0/1 on Router B)
Session state: Up Interface: XGE3/0/1
Hold time: 2319ms
# Display routes destined for 2001:4::0/64 on Router A.
[RouterA] display ipv6 routing-table 2001:4::0 64
Summary count : 1
Destination: 2001:4::/64 Protocol : O_INTRA
NextHop : FE80::20F:FF:FE00:1200 Preference: 10
Interface : XGE3/0/1 Cost : 1
The output shows that Router A communicates with Router B through Ten-GigabitEthernet 3/0/1. Then the link over Ten-GigabitEthernet 3/0/1 fails.
Summary count : 1
NextHop : FE80::BAAF:67FF:FE27:DCD0 Preference: 10
Interface : XGE3/0/2 Cost : 2
The output shows that Router A communicates with Router B through Ten-GigabitEthernet 3/0/2.
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
ospfv3 bfd enable
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
ospfv3 bfd enable
ipv6 address 2001:3::2/64
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
return
Example: Configuring OSPFv3 FRR
As shown in Figure 21, Router A, Router B, and Router C reside in the same OSPFv3 domain. Configure OSPFv3 FRR so that when Link A fails, traffic is immediately switched to Link B.
Table 10 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Table 11 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
XGE3/0/1 |
1::1/64 |
Router B |
XGE3/0/1 |
3::1/64 |
XGE3/0/2 |
2::1/64 |
XGE3/0/2 |
2::2/64 |
Loop0 |
10::1/128 |
Loop0 |
20::1/128 |
Router C |
XGE3/0/1 |
1::2/64 |
XGE3/0/2 |
3::2/64 |
1. Configure IPv6 addresses for interfaces on the routers.
[RouterA-LoopBack0] ipv6 address 10::1 128
[RouterA-LoopBack0] quit
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 1::1 64
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 2::1 64
[RouterB-LoopBack0] ipv6 address 20::1 128
[RouterB-LoopBack0] quit
[RouterB-Ten-GigabitEthernet3/0/2] ipv6 address 2::2 64
[RouterC-Ten-GigabitEthernet3/0/1] ipv6 address 1::2 64
2. Configure basic OSPF settings on all routers.
# On Router A, enable OSPFv3 and set the router ID to 1.1.1.1.
[RouterA] ospfv3 1
[RouterA-LoopBack0] ospfv3 1 area 0
[RouterB] ospfv3 1
[RouterB-LoopBack0] ospfv3 1 area 0
[RouterC] ospfv3 1
3. Configure OSPFv3 FRR:
You can enable OSPFv3 FRR to either calculate a backup next hop by using the LFA algorithm, or specify a backup next hop by using a routing policy.
¡ (Method 1.) Enable OSPFv3 FRR to calculate a backup next hop by using the LFA algorithm:
[RouterA] ospfv3 1
[RouterA-ospfv3-1] fast-reroute lfa
[RouterB] ospfv3 1
[RouterB-ospfv3-1] fast-reroute lfa
¡ (Method 2.) Enable OSPFv3 FRR to specify a backup next hop by using a routing policy:
[RouterA] ipv6 prefix-list abc index 10 permit 20::1 128
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/0/1 backup-nexthop fe80::6eab:8bff:fed4:205
[RouterA-route-policy-frr-10] quit
[RouterA] ospfv3 1
[RouterA-ospfv3-1] fast-reroute route-policy frr
[RouterB] ipv6 prefix-list abc index 10 permit 10::1 128
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/0/1 backup-nexthop fe80::6eab:8bff:fed4:206
[RouterB-route-policy-frr-10] quit
[RouterB] ospfv3 1
[RouterB-ospfv3-1] fast-reroute route-policy frr
# Display the route 20::1/128 on Router A to view the backup next hop information.
[RouterA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
Destination: 20::1/128
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h03m45s
FlushedAge: 15h28m49s
Cost: 6 Preference: 10
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0xa OrigAs: 0
NibID: 0x23000005 LastAs: 0
AttrID: 0xffffffffffffffff
BkAttrID: 0xffffffffffffffff Neighbor: ::
Flags: 0x10041 OrigNextHop: FE80::6EAB:90FF:FEF3:305
Label: NULL RealNextHop: FE80::6EAB:90FF:FEF3:305
BkLabel: NULL BkNextHop: FE80::6EAB:8BFF:FED4:205
SRLabel: NULL Interface: Ten-GigabitEthernet3/0/2
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/0/2
BkTunnel ID: Invalid BkIPInterface: Ten-GigabitEthernet3/0/1
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
UserID: 0xffffffff SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 Priority: Critical
MemberPort: N/A ExtFlags: 0x0
UCMIndex: 0x0 UserVLAN: 65535
UCMMTU: 0 BrasHash: 0
SessionID: 0 UserGroupID: 0
IsoGroupID: 0 BkIsoGroupID: 0
# Display the route 10::1/128 on Router B to view the backup next hop information.
[RouterB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
Destination: 10::1/128
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h03m10s
Cost: 1 Preference: 10
NibID: 0x23000006 LastAs: 0
Flags: 0x10041 OrigNextHop: FE80::6EAB:81FF:FE67:106
Label: NULL RealNextHop: FE80::6EAB:81FF:FE67:106
BkLabel: NULL BkNextHop: FE80::6EAB:8BFF:FED4:206
SID: N/A
BkSID: N/A
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
fast-reroute lfa
area 0.0.0.0
interface LoopBack0
ipv6 address 10::1/128
return
Router B
sysname RouterB
ospfv3 1
router-id 2.2.2.2
fast-reroute lfa
area 0.0.0.0
interface LoopBack0
ipv6 address 20::1/128
ipv6 address 2::2/64
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
return
Example: Configuring OSPFv3 IPsec profile
As shown in Figure 22, all routers run OSPFv3, and the AS is divided into two areas.
Configure IPsec profiles on the routers to authenticate and encrypt protocol packets.
Table 12 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
2. Configure OSPFv3 basic features:
[RouterA] ospfv3 1
[RouterB] ospfv3 1
[RouterC] ospfv3 1
3. Configure OSPFv3 IPsec profiles:
¡ On Router A:
# Create an IPsec transform set named trans.
[RouterA] ipsec transform-set trans
# Specify the encapsulation mode as transport.
[RouterA-ipsec-transform-set-trans] encapsulation-mode transport
# Specify the ESP encryption and authentication algorithms.
[RouterA-ipsec-transform-set-trans] protocol esp
[RouterA-ipsec-transform-set-trans] esp encryption-algorithm aes-cbc-128
[RouterA-ipsec-transform-set-trans] esp authentication-algorithm sha1
[RouterA-ipsec-transform-set-trans] quit
# Create a manual IPsec profile named profile001.
[RouterA] ipsec profile profile001 manual
# Use IPsec transform set trans.
[RouterA-ipsec-profile-manual-profile001] transform-set trans
# Configure the inbound and outbound SPIs for ESP.
[RouterA-ipsec-profile-manual-profile001] sa spi outbound esp 123456
[RouterA-ipsec-profile-manual-profile001] sa spi inbound esp 123456
# Configure the inbound and outbound SA keys for ESP.
[RouterA-ipsec-profile-manual-profile001] sa string-key outbound esp simple abcdefg
[RouterA-ipsec-profile-manual-profile001] sa string-key inbound esp simple abcdefg
[RouterA-ipsec-profile-manual-profile001] quit
¡ On Router B:
[RouterB] ipsec transform-set trans
[RouterB-ipsec-transform-set-trans] encapsulation-mode transport
[RouterB-ipsec-transform-set-trans] protocol esp
[RouterB-ipsec-transform-set-trans] esp encryption-algorithm aes-cbc-128
[RouterB-ipsec-transform-set-trans] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-trans] quit
[RouterB] ipsec profile profile001 manual
[RouterB-ipsec-profile-manual-profile001] transform-set trans
[RouterB-ipsec-profile-manual-profile001] sa spi outbound esp 123456
[RouterB-ipsec-profile-manual-profile001] sa spi inbound esp 123456
[RouterB-ipsec-profile-manual-profile001] sa string-key outbound esp simple abcdefg
[RouterB-ipsec-profile-manual-profile001] sa string-key inbound esp simple abcdefg
[RouterB-ipsec-profile-manual-profile001] quit
# Create a manual IPsec profile named profile002.
[RouterB] ipsec profile profile002 manual
[RouterB-ipsec-profile-manual-profile002] transform-set trans
[RouterB-ipsec-profile-manual-profile002] sa spi outbound esp 256
[RouterB-ipsec-profile-manual-profile002] sa spi inbound esp 256
[RouterB-ipsec-profile-manual-profile002] sa string-key outbound esp simple byebye
[RouterB-ipsec-profile-manual-profile002] sa string-key inbound esp simple byebye
[RouterB-ipsec-profile-manual-profile002] quit
¡ On Router C:
[RouterC] ipsec transform-set trans
[RouterC-ipsec-transform-set-trans] encapsulation-mode transport
[RouterC-ipsec-transform-set-trans] protocol esp
[RouterC-ipsec-transform-set-trans] esp encryption-algorithm aes-cbc-128
[RouterC-ipsec-transform-set-trans] esp authentication-algorithm sha1
[RouterC-ipsec-transform-set-trans] quit
[RouterC] ipsec profile profile002 manual
[RouterC-ipsec-profile-manual-profile002] transform-set trans
[RouterC-ipsec-profile-manual-profile002] sa spi outbound esp 256
[RouterC-ipsec-profile-manual-profile002] sa spi inbound esp 256
[RouterC-ipsec-profile-manual-profile002] sa string-key outbound esp simple byebye
[RouterC-ipsec-profile-manual-profile002] sa string-key inbound esp simple byebye
[RouterC-ipsec-profile-manual-profile002] quit
4. Apply the IPsec profiles to areas:
[RouterA] ospfv3 1
[RouterA-ospfv3-1-area-0.0.0.1] enable ipsec-profile profile001
[RouterB] ospfv3 1
[RouterB-ospfv3-1] area 0
[RouterB-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile002
[RouterB-ospfv3-1-area-0.0.0.0] quit
[RouterB-ospfv3-1-area-0.0.0.1] enable ipsec-profile profile001
# Configure Router C.
[RouterC] ospfv3 1
[RouterC-ospfv3-1] area 0
[RouterC-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile002
[RouterC-ospfv3-1-area-0.0.0.0] quit
# Verify that OSPFv3 packets between Routers A, B, and C are protected by IPsec. (Details not shown.)
Configuration files
Router A
sysname RouterA
ospfv3 1
router-id 1.1.1.1
area 0.0.0.1
transform-set trans
return
Router B
sysname RouterB
ospfv3 1
area 0.0.0.0
area 0.0.0.1
transform-set trans
transform-set trans
return
Router C
sysname RouterC
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
transform-set trans
return
