06-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration GuidesH3C CR16000-M Routers Configuration Guides-R8630Pxx-6W10006-Layer 3—IP Routing Configuration Guide
05-IPv6 policy-based routing configuration
05-IPv6 policy-based routing configuration 184.23 KB
Configuring IPv6 PBR
About IPv6 PBR
IPv6 policy-based routing (PBR) uses user-defined policies to route IPv6 packets. A policy can specify parameters for packets that match specific criteria such as ACLs or that have specific lengths. The parameters include the next hop, output interface, SRv6 TE policy, default next hop, default output interface, and default SRv6 TE policy.
PBR and routing policies have the following differences:
·     PBR applies to data packets. PBR takes the specified actions for matching packets based on user demands. The packets will not be forwarded according to routing table lookup. If PBR-based packet forwarding fails, the packets can still be forwarded according to routing table lookup.
·     Routing policies apply to routing information. Routing policies typically implement route filtering and route attribute settings. You can use routing policies to change route attributes (including reachability), in order to change the forwarding paths of network traffic.
IPv6 packet forwarding process
When the device receives an IPv6 packet, the device searches the IPv6 PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the ‍next hops, output interfaces, or SRv6 TE policies specified on the node to forward the packet, or forward the packet in SRv6 BE mode.
b.     Searches the routing table for a route (except the default route) to forward the packet if one of the following conditions exists:
-     No next hops, output interfaces, or SRv6 TE policies are specified on the node, or packet forwarding in SRv6 BE mode is not set.
-     Forwarding failed based on the next hops, output interfaces, or SRv6 TE policies, or failed in SRv6 BE mode.
c.     Uses the default next hops, default output interfaces, or default SRv6 TE policies specified on the node to forward the packet or forward the packet in default SRv6 BE mode if one of the following conditions exists:
-     No matching route was found in the routing table.
-     The routing table-based forwarding failed.
d.     Uses the default route to forward the packet if one of the following conditions exists:
-     No default next hops, default output interfaces, or default SRv6 TE policies are specified on the node, or packet forwarding in default SRv6 BE mode is not set.
-     Forwarding failed based on the default next hops, default output interfaces, or default SRv6 TE policies, or failed in default SRv6 BE mode.
·     The device performs routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
IPv6 PBR types
IPv6 PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface only.
Policy nodes
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
An IPv6 policy compares packets with nodes in priority order.
·     If a packet matches the criteria on a node, it is processed by the action on the node.
·     If the packet does not match any criteria on the node, it goes to the next node for a match.
·     If the packet does not match the criteria on any node, the device performs a routing table lookup for the packet.
Relationship between if-match clauses
You can specify multiple if-match clauses for a node, but only one if-match clause of each type. A packet that matches all the if-match clauses of a node matches the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about the relationship between the apply clauses, see "Configuring actions for an IPv6 node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
In permit mode
In deny mode
Yes
·     If the node contains apply clauses, IPv6 PBR executes the apply clauses on the node.
¡     If IPv6 PBR-based forwarding succeeds, IPv6 PBR does not compare the packet with the next node.
¡     If IPv6 PBR-based forwarding fails, IPv6 PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No
IPv6 PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
IPv6 PBR and Track
IPv6 PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, default next hop, or default output interface.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and IPv6 PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: IPv6 PBR configuration
If a packet destined for the local device matches an IPv6 PBR policy, IPv6 PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure an IPv6 PBR policy, be careful to avoid this situation.
If traffic matches both a QoS policy configured globally or on an interface by using the MQC approach and an IPv6 PBR policy configured on an interface (for example, the same ACL rule), IPv6 PBR applies. Traffic will not match the QoS policy. For more information about QoS commands, see ACL and QoS Command Reference.
IPv6 PBR tasks at a glance
To configure IPv6 PBR, perform the following tasks:
1.     Configuring an IPv6 policy
a.     Creating an IPv6 node
b.     Setting match criteria for an IPv6 node
c.     Configuring actions for an IPv6 node
2.     Specifying a policy for IPv6 PBR
¡     Specifying an IPv6 policy for IPv6 local PBR
¡     Specifying an IPv6 policy for IPv6 interface PBR
3.     (Optional.) Enabling the IPv6 PBR logging feature
2.     Create an IPv6 policy or policy node and enter its view.
2.     Enter IPv6 policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, IPv6 PBR uses the action (permit or deny) and time range settings in the ACL.
¡     Set a local QoS ID match criterion.
if-match qos-local-id local-id-value [ qppb-manipulation ]
By default, no local QoS ID match criterion is set.
If you specify the qppb-manipulation keyword, the command applies only to QPPB. in which the device acts as a BGP receiver. The device determines that a received packet matches the policy node if the local QoS ID obtained from its matching route entry is identical to the specified local QoS ID criterion. For more information about QPPB, see ACL and QoS Configuration Guide.
About apply clauses
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply access-vpn vpn-instance
·     apply next-hop
·     apply output-interface
·     apply srv6-policy
·     apply srv6-be
·     apply default-next-hop
·     apply default-srv6-policy
·     apply default-srv6-be
IPv6 PBR supports the types of apply clauses shown in Table 1.
Table 1 Priorities and meanings of apply clauses
Clause
Meaning
Priority
apply precedence
Sets an IP precedence.
This clause is always executed.
apply loadshare { next-hop | default-next-hop }
Enables load sharing among multiple next hops or default next hops.
Multiple next hop or default next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Multiple next hops load share traffic in proportion to their weight. By default, all next hops have the same weight and traffic is evenly distributed among them.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops or default next hops are set in the policy.
Sets VPN instances.
If a packet matches a forwarding entry of a specified VPN instance, it is forwarded in the VPN instance.
apply next-hop, apply output-interface, apply srv6-policy, and apply srv6-be
Sets next hops, output interfaces, and SRv6 TE policies, and the SRv6 BE packet forwarding mode.
Only the apply clause with the highest priority is executed.
apply default-next-hop, apply default-srv6-policy, and apply default-srv6-be
Sets default next hops, default SRv6 TE policies, and the default SRv6 BE packet forwarding mode.
The clauses take effect only in the following cases:
·     No next hops, SRv6 TE polices, or default SRv6 BE mode are set, or the next hops and SRv6 TE polices are invalid or the packet fails to be forwarded in default SRv6 BE mode.
·     The IPv6 packet does not match any route in the routing table.
Restrictions and guidelines for action configuration
If you specify a next hop or default next hop, IPv6 PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if IPv6 PBR does not update the route immediately after its availability status changes.
Setting an IP preference
3.     Set an IP precedence.
By default, no IP precedence is specified.
Configuring actions for a node
3.     Configure actions for a node.
¡     Set VPN instances.
apply access-vpn vpn-instance vpn-instance-name
By default, no VPN instances are specified.
¡     Set next hops for permitted IPv6 packets.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-16>
By default, no next hops are specified.
You can specify a maximum of 16 next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Enable load sharing among multiple next hops.
apply loadshare next-hop
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
By default, no output interfaces are specified.
This command must be used together with the apply next-hop command. If you only configure this command, the configuration does not take effect.
You can specify a maximum of one output interface for backup or load sharing in one command line or by executing this command multiple times.
¡     Set SRv6 TE policies.
apply srv6-policy { endpoint color [ { sid | vpnsid } sid [ compress-16 block block-length flavor { coc-next | next [ wlib ] } ] ] }&<1-2>
By default, no SRv6 TE policies are specified.
You can specify a maximum of two SRv6 TE policies in one command line or by executing this command multiple times. The first available SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡     Configure packet forwarding in SRv6 BE mode.
apply srv6-be remote-sid { remote-sid locator-prefix-len }&<1-2>
By default, packets are not forwarded in SRv6 BE mode.
¡     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ]  { ipv6-address [ direct ] [ track track-entry-number ] }&<1-16>
By default, no default next hops are specified.
You can specify a maximum of 16 default next hops for backup or load sharing in one command line or by executing this command multiple times.
¡     Enable load sharing among multiple default next hops.
apply loadshare default-next-hop
By default, the default next hops operate in primary/backup mode.
¡     Set default SRv6 TE policies.
apply default-srv6-policy { endpoint color [ { sid | vpnsid } sid [ compress-16 block block-length flavor { coc-next | next [ wlib ] } ] ] }&<1-16>
By default, no default SRv6 TE policies are specified.
You can specify a maximum of 16 default SRv6 TE policies in one command line or by executing this command multiple times. The first available default SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡     Configure packet forwarding in default SRv6 BE mode.
apply default-srv6-be remote-sid { remote-sid locator-prefix-len }&<1-2>
By default, packets are not forwarded in default SRv6 BE mode.
Perform this task to specify an IPv6 policy for IPv6 local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for IPv6 local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. When you use IPv6 local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify an IPv6 policy for IPv6 local PBR.
By default, IPv6 local PBR is not enabled.
Perform this task to apply an IPv6 policy to an interface to guide the forwarding of packets received on the interface only.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify an IPv6 policy for IPv6 interface PBR.
ipv6 policy-based-route policy-name [ share-mode ]
By default, no IPv6 policy is applied to the interface.
The IPv6 PBR logging feature helps the administrator locate and fix faults. The feature logs IPv6 PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
2.     Enable the IPv6 PBR logging feature.
ipv6 policy-based-route-log enable
By default, the IPv6 PBR logging feature is disabled.
Display and maintenance commands for IPv6 PBR
Display IPv6 PBR policy information.
Display IPv6 PBR configuration.
display ipv6 policy-based-route setup
Display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
Display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
Clear IPv6 PBR statistics.
IPv6 PBR configuration examples
Example: Configuring packet type-based IPv6 local PBR
As shown in Figure 1, Router B and Router C are connected through Router A. Router B and Router C do not have a route to reach each other.
Configure IPv6 PBR on Router A to forward all TCP packets to the next hop 1::2 (Router B).
Figure 1 Network diagram
Table 2 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet3/0/1
Interface2
Ten-GigabitEthernet3/0/2
1.     Configure Router A:
# Configure the IPv6 addresses of Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2.
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 address 1::1 64
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] ipv6 address 2::1 64
[RouterA-Ten-GigabitEthernet3/0/2] quit
# Configure ACL 3001 to match TCP packets.
[RouterA] acl ipv6 advanced 3001
[RouterA-acl-ipv6-adv-3001] rule permit tcp
[RouterA-acl-ipv6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[RouterA] ipv6 policy-based-route aaa permit node 5
[RouterA-pbr6-aaa-5] if-match acl 3001
[RouterA-pbr6-aaa-5] apply next-hop 1::2
[RouterA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Router A.
[RouterA] ipv6 local policy-based-route aaa
2.     On Router B, configure the IPv6 address of Ten-GigabitEthernet 3/0/1.
<RouterB> system-view
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 address 1::2 64
3.     On Router C, configure the IPv6 address of Ten-GigabitEthernet 3/0/2.
<RouterC> system-view
[RouterC] interface ten-gigabitethernet 3/0/2
[RouterC-Ten-GigabitEthernet3/0/2] ipv6 address 2::2 64
1.     Perform telnet operations to verify that IPv6 local PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1::2 (Router B), as follows:
# Verify that you can telnet to Router B from Router A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Router A. (Details not shown.)
2.     Verify that Router A forwards packets other than TCP packets through Ten-GigabitEthernet 3/0/2. For example, verify that you can ping Router C from Router A. (Details not shown.)
Example: Configuring packet type-based IPv6 interface PBR
As shown in Figure 2, Router B and Router C do not have a route to reach each other.
Configure IPv6 PBR on Router A to forward all TCP packets received on Ten-GigabitEthernet 3/0/1 to the next hop 1::2 (Router B).
Figure 2 Network diagram
Table 3 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
Ten-GigabitEthernet3/0/3
1.     Configure IPv6 addresses and unicast routing protocol settings to make sure Router B and Router C each have a route to reach Host A. (Details not shown.)
2.     Configure Router A:
# Configure IPv6 interface PBR by applying policy aaa to Ten-GigabitEthernet 3/0/1.
[RouterA-Ten-GigabitEthernet3/0/1] undo ipv6 nd ra halt
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 policy-based-route aaa
1.     Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
2.     Perform telnet operations to verify that IPv6 interface PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1::2 (Router B), as follows:
# Verify that you can telnet to Router B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Host A. (Details not shown.)
3.     Verify that Router A forwards packets other than TCP packets through Ten-GigabitEthernet 3/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
