- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Fast log output commands
- 22-Flow log commands
- 23-Information center commands
- 24-Packet capture commands
- 25-Flow monitor commands
- 26-NetAnalysis commands
- 27-KPI data collection commands
| 27-KPI data collection commands | 189.98 KB |
Available external indicators for KPI data collection
display system internal kpi register-status
display system internal kpi status
kpi collect indicator alarm-enable
kpi collect indicator collect-type
kpi collect indicator threshold
kpi file aging threshold remain-disk-size
kpi file aging threshold total-file-size
Table 1 lists some available external indicators for KPI data collection.
Table 1 Available external indicators for KPI data collection
Class |
Module |
Object |
Indicator |
Indicator description |
Net-performance |
IF-USAGE-EX |
Interface. The value is interface-type interface-number. |
Port_TXBW_Usage |
Output bandwidth usage of the interface, in the range of 0% to 100%. |
IF-USAGE-EX |
Port_RXBW_Usage |
Input bandwidth usage of the interface, in the range of 0% to 100%. |
Device-resource |
ARP-MSG-QUEUE |
Custom message queue. The value is message-queue. |
ARP_PKTQ_Health |
ARP packet queue health, which is the ratio of the number of messages in the queue to the total queue size. The value range is 0% to 100%. |
ARP-MSG-QUEUE |
ARP_EVTQ_Health |
ARP event queue health, which is the ratio of the number of messages in the queue to total queue size. The value range is 0% to 100%. |
ND-MSG-QUEUE |
ND_PKTQ_Health |
ND packet queue health, which is the ratio of the number of messages in the queue to the total queue size. The value range is 0% to 100%. |
ND-MSG-QUEUE |
ND_EVTQ_Health |
ND event queue health, which is the ratio of the number of messages in the queue to total queue size. The value range is 0% to 100%. |
MAC-USAGE |
Card. The value is chassis.x/slot.y. |
MAC_Addr_Useage |
MAC address usage of the card, in the range of 0% to 100%. |
AGG-USAGE |
Device. The value is device. |
AGG_ID_Useage |
Aggregate interface ID resource usage on the device, in the range of 0% to 100%. |
ACL_USE |
Chip. The value is chassis.x/slot.y/chip.z. |
ACL_USE_IPV4_RATIO |
IPv4 ACL entry resource usage, in the range of 0% to 100%. |
ACL_USE |
ACL_USE_IPV6_RATIO |
IPv6 ACL entry resource usage, in the range of 0% to 100%. |
CGN |
CGN_SESSION_USAGE |
CGN session resource usage, in the range of 0% to 100%. |
CGN |
CGN_FWD_RX_USAGE |
Input bandwidth usage of the CGN card, in the range of 0% to 100%. |
CGN |
CGN_FWD_TX_USAGE |
Output bandwidth usage of the CGN card, in the range of 0% to 100%. |
NAT_ADDRGRP_RES |
NAT address group usage. The value is group-name. |
NAT_ADDRGRP_CUR_RES_USAGE |
Resource usage of the address group, in the range of 0% to 100%. |
NAT_IPPOOL_RES |
Address pool. The value is pool-name. |
NAT_IPPOOL_CUR_RES_USAGE |
Address pool resource usage, in the range of 0% to 100%. |
NAT_QUEUE |
Queue. The value is Nat_cgn_send_queue. |
NAT_QUEUE_LEN |
Queue length. |
CGN_QUEUE |
Queue. The value is CGN_SEND_QUEUE. |
CGN_QUEUE_LEN |
Queue length. |
SOFTQUEINFO |
Custom message queue. The value is chassis.x/slot.y/RQ.u. |
SOFTQUE_PACKET |
Number of packets in the software queue. |
SOFTQUEINFO |
SOFTQUE_DROP |
Number of dropped packets in the software queue. |
Device-state |
BFD |
BFD_TOTAL_NUMBER |
Total number of BFD sessions. |
VRRP-V4 |
VRRP_FAIL_STATE_RATIO_V4 |
Ratio of abnormal VRRPv4 sessions to total VRRPv4 sessions. The value is a decimal in the range of 0 to 1. |
VRRP-V6 |
VRRP_FAIL_STATE_RATIO_V6 address family. |
Ratio of abnormal VRRPv6 sessions to total VRRPv6 sessions. The value is a decimal in the range of 0 to 1. |
VRRP-V4 address family. |
VRRP_STATE_CONVER_V4 address family. |
Number of master/backup switchovers in the VRRPv4 group. |
VRRP-V6 address family. |
VRRP_STATE_CONVER_V6 address family. |
Number of master/backup switchovers in the VRRPv6 group. |
STRUNK |
Subcard. The value is chassis.x/slot.y/subslot.z. |
STRUNK_FAIL_STATE_RATIO |
Ratio of abnormal S-Trunk sessions to total S-Trunk sessions. The value is a decimal in the range of 0 to 1. |
STRUNK |
STRUNK_GROUP_STATE_CONVER |
Number of S-Trunk group state changes. |
STRUNK |
STRUNK_MEMBER_STATE_CONVER |
Number of S-Trunk member state changes. |
ACL_STATE |
ACL_COPP_IPV4_USE_STATE |
State of IPv4 ACL entry operation in a COPP service cycle: · 0—Normal. · 1—Abnormal. |
ACL_STATE |
ACL_COPP_IPV6_USE_STATE |
State of IPv6 ACL entry operation in a COPP service cycle: · 0—Normal. · 1—Abnormal. |
ACL_STATE |
ACL_ATTACK_USE_STATE |
State of ACL entry operation in an anti-attack service cycle: · 0—Normal. · 1—Abnormal. |
ARP_ND |
ARP_USE_NUM |
Number of ARP entry deployments within a collection interval. |
FIB |
FIB_USE_NUM |
Number of FIB entry deployments within a collection interval. |
IBC_CHAN |
IBC_GE_STATE |
GE channel link state: · 0—Normal. · 1—Abnormal. |
IBC_CHAN |
IBC_FE_STATE |
FE channel link state: · 0—Normal. · 1—Abnormal. |
ARP_ND |
ND_USE_NUM |
Number of ND entry deployments within a collection interval. |
ARP_ND |
ARP_USE_STATE |
Whether ARP entry deployment to the driver is abnormal within a collection interval. |
ARP_ND |
ND_USE_STATE |
Whether ND entry deployment to the driver is abnormal within a collection interval. |
FIB |
FIB6_USE_NUM address family. |
Number of IPv6 FIB entry deployments within a collection interval. |
FIB |
FIB4_USE_STATE |
Whether IPv4 FIB entry deployment to the driver is abnormal within a collection interval. |
FIB |
FIB6_USE_STATE |
Whether IPv6 FIB entry deployment to the driver is abnormal within a collection interval. |
VSRP_INSTANCE |
VSRP instance. The value is instance-name. |
VSRP_INSTANCE_STATE |
VSRP instance state: · Master. · Backup. · Down. |
VSRP_PEER |
VSRP peer. The value is peer-name. |
VSRP_PEER_STATE |
VSRP peer state: · 0—Connected. · 1—Not connected. |
BFD |
BFD_NORMAL_NUMBER |
Number of normal BFD sessions. |
PROTORATE |
Protocol type: · 1588_FD. · 1588_FE. · 1588_FF. · 8021x_B. |
PROTO_RATE |
Rate of protocol packets sent to the operating system, in pps. |
display kpi data
Use display kpi data to display the KPI data for an object of a module within a time range on the storage media.
display kpi data module module-name object object-name from time1 date1 to time2 date2 [ file file-path ]
module module-name: Specifies a module by its name. For more information, see "Available external indicators for KPI data collection."
object object-name: Specifies an object by its name. An object is a physical or logical entity to which indicators belong, such as device, card, or subcard. The value for the object-name argument varies by object type. For external indicators, the object type and the value for the object-name argument vary by module and device model. For more information, see "Available external indicators for KPI data collection." Object name examples are as follows:
· device—Specifies a device. Indicators for this object describe the overall condition of the device.
· chassis.x/slot.y—Specifies a card. Indicators for this object describe the performance of the card. The value for the x argument is 0, and the y argument represents the slot number of the card. (In standalone mode.)
· chassis.x/slot.y—Specifies a card. Indicators for this object describe the performance of the card. The x argument represents the member ID of the IRF member device, and the y argument represents the slot number of the card. (In IRF mode.)
· chassis.x/slot.y/subslot.z—Specifies a subcard. Indicators for this object describe the performance of the subcard. The value for the x argument is 0, the y argument represents the slot number of the card, and the z argument represents the subcard ID. (In standalone mode.)
· chassis.x/slot.y/subslot.z—Specifies a subcard. Indicators for this object describe the performance of the subcard. The x argument represents the member ID of the IRF member device, the y argument represents the slot number of the card, and the y argument represents the subcard ID. (In IRF mode.)
· interface-type interface-number—Specifies an interface by its type and number. Indicators for this object describe the running status of the physical interface.
· chassis.x/slot.y/chip.z—Specifies a chip. The value for the x argument is 0, the y argument represents the member ID of the IRF member device, and the z argument represents the chip ID. (In standalone mode.)
· chassis.x/slot.y/chip.z—Specifies a chip. The x argument represents the member ID of the IRF member device or the virtual chassis number of the PEX, the y argument represents the slot number of the card, and the z argument represents the chip ID. (In IRF mode.)
· chassis.x/slot.y/chip.z—Specifies a chip. The value for the x argument is 0, the y argument represents the slot number of the card, and the z argument represents the chip ID. (In standalone mode.)
· chassis.x/slot.y/chip.z—Specifies a chip. The x argument represents the member ID of the IRF member device, the y argument represents the slot number of the card, and the z argument represents the chip ID. (In IRF mode.)
· up-x—Specifies a UP. The x argument represents the UP ID, in the range of 1024 to 2047.
from time1 date1: Specifies the start time and date for KPI data collection. The time1 argument specifies the time of the day in hh:mm:ss format. Its value is in the range of 00:00:00 to 23:59:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format. MM represents the month, in the range of 1 to 12. DD represents the day and its value range depends on the specified month. YYYY represents the year, in the range of 2000 to 2035.
to time2 date2: Specifies the end time and date for KPI data collection. The time2 argument has the same format and value range as the time1 argument. The date2 argument has the same format and value range as the date1 argument. The end time and date must be later than the start time and date.
file file-path: Specifies the KPI cache file path on the storage media. If you do not specify this option, the command displays the KPI data in all cache files.
# Display the KPI data for the Ten-GigabitEthernet 3/1/1 object of the IF-USAGE-EX module in the time range from 2025/5/13 14:00:00 to 2025/5/13 23:00:00.
<Sysname> display kpi data module IF-USAGE-EX object Ten-GigabitEthernet3/1/1 from 14
:00:00 2025/5/13 to 23:00:00 2025/5/13
Module : IF-USAGE-EX
Object : Ten-GigabitEthernet3/1/1
Slot : 8
Indicator Value Latest collect time
Port_RXBW_Usage 100 2025-05-13 15:38:41
Port_RXBW_Usage 100 2025-05-13 15:33:40
Module |
Module name. For more information, see "Available external indicators for KPI data collection." |
Slot |
Slot on which the object resides. |
Object |
Object for KPI data collection. |
Indicator |
Indicator for KPI data collection. For more information, see "Available external indicators for KPI data collection." |
Value |
Value for the indicator. |
Latest collect time |
Most recent time when the indicator value was collected. |
kpi collect module enable
display kpi module-info
Use display kpi module-info to display KPI data collection information for a module.
display kpi module-info [ module-name ] [ verbose ]
module-name: Specifies a module by its name. For more information, see "Available external indicators for KPI data collection." If you do not specify a module name, the command displays KPI data collection information for all available modules.
verbose: Displays detailed KPI data collection information about the module. If you do not specify this keyword, the command displays brief KPI data collection information about the module.
# Display brief KPI data collection information for the ARP_ND module.
<Sysname> display kpi module-info ARP_ND
Module : ARP_ND
Class : Device-state
KPI Collect : Enabled
Collect interval : 60 seconds
Collect times : 163
# Display detailed KPI data collection information for the ARP_ND module.
<Sysname> display kpi module-info ARP_ND verbose
Module : ARP_ND
Collect times : 1632
Slot : 18
Object : chassis.0/slot.18
ARP_USE_NUM 0 2025-05-15 18:12:54
ND_USE_NUM 0 2025-05-15 18:12:54
ARP_USE_STATE 0 2025-05-15 18:12:54
ND_USE_STATE 0 2025-05-15 18:12:5
Module |
Module name. For more information, see"Available external indicators for KPI data collection." |
Class |
KPI class to which the module belongs. For more information, see "Available external indicators for KPI data collection." |
KPI Collect |
State of KPI data collection: · Enabled. · Disabled. |
Collect interval |
KPI data collection interval, in seconds. |
Collect times |
Number of KPI data collections. |
Chassis |
Chassis number of the object. |
Slot |
Slot number of the object. |
Object |
Object name. |
Indicator |
Value |
Use display system internal kpi register-status to display the running status and registration information of KPI data collection for a module.
display system internal kpi register-status [ module module-name ]
module-name: Specifies the module name. If you do not specify a module, the command displays the running status and registration information of KPI data collection for all available modules. For more information, see "Available external indicators for KPI data collection."
Use this command to display external indicators for KPI data collection.
# Display the running status and registration information of KPI data collection for the IF-USAGE-EX module.
<Sysname> display system internal kpi register-status module IF-USAGE-EX
Support suppress : True
Indicator : Port_TXBW_Usage
Support alarm : True
Support eai : False
Collect type : Always
Low threshold : 0
Normal threshold : 30
Level 1 threshold : 50
Level 2 threshold : 70
Level 3 threshold : 90
Indicator : Port_RXBW_Usage
Support eai : False
Low threshold : 0
Module |
Module name. |
Support suppress |
Whether the module supports data collection suppression: · True—The module supports data collection suppression. When the CPU or memory usage exceeds the upper limit, data collection for the module suspends. · False—The module does not support data collection suppression. When the CPU or memory usage exceeds the upper limit, data collection for the module does not suspend. |
Indicator |
Indicator name. |
Support alarm |
Whether alarms are supported: · True. · False. |
Support eai |
Whether EAI monitoring and prediction are supported: · True. · False. |
Collect type |
Alarm and log report mode of the indicator: · Always. · Change. · Threshold. |
Low threshold |
Low threshold for the indicator. This field displays a hyphen (-) if the indicator does not have a threshold specified or the default custom threshold does not exist. |
Normal threshold |
Normal threshold for the indicator. This field displays a hyphen (-) if the indicator does not have a threshold specified or the default custom threshold does not exist. |
L1 threshold |
Level-1 threshold for the indicator. This field displays a hyphen (-) if the indicator does not have a threshold specified or the default custom threshold does not exist. |
L2 threshold |
Level-2 threshold for the indicator. This field displays a hyphen (-) if the indicator does not have a threshold specified or the default custom threshold does not exist. |
L3 threshold |
Level-3 threshold for the indicator. This field displays a hyphen (-) if the indicator does not have a threshold specified or the default custom threshold does not exist. |
Use display system internal kpi status to display the running status of KPI data collection for a module.
display system internal kpi status [ module module-name ]
module-name: Specifies the module name. If you do not specify a module, the command displays the running status of KPI data collection for all available modules. For more information, see "Available external indicators for KPI data collection."
# Display the running status of KPI data collection for the IF-USAGE-EX module.
<Sysname> display system internal kpi status
Slot : 3(Fd : 9)
Discard times : 0
Module collect state : Suppressing(CPU Alert)
Last collect duration : 1 ms
Max collect duration : 22 ms
Avg collect duration : 0 ms
Collect failures : 1326
Slot : 4(Fd : 22)
Discard times : 0
Last collect duration : 2 ms
Max collect duration : 25 ms
Collect failures : 1112
Slot : 5
Discard times : 0
Max collect duration : 23 ms
Collect failures : 892
Table 5 Command output
Module |
Module name. |
Discard times |
Number of collection failures caused by anomalies in the previous collection. |
Module collect state |
Module collection state: · Idle. · Collecting. · Suppressing. This state is followed by the reason in brackets: ¡ CPU alert: The CPU usage exceeds an alarm threshold. ¡ Memory alert: The memory usage exceeds an alarm threshold. ¡ CPU and Memory alert: Both CPU usage and memory usage exceed alarm thresholds. |
Last collect duration |
Duration of the previous collection, in milliseconds. |
Max collect duration |
Maximum collection duration, in milliseconds. |
Avg collect duration |
Average collection duration, in milliseconds. |
Collect failures |
Number of collection failures. |
Use kpi collect indicator alarm-enable to enable alarms for a KPI data collection indicator.
Use undo kpi collect indicator alarm-enable to restore the default.
kpi collect indicator indicator-name alarm-enable
undo kpi collect indicator indicator-name alarm-enable
The enabling status of alarms varies by module and device model. To obtain the enabling status of alarms, execute the display system internal kpi register-status command.
indicator-name: Specifies the indicator name. For more information, see "Available external indicators for KPI data collection."
After you enable alarms for a KPI data collection indicator, the device reports the collected data to NMS via SNMP and generates a log for it.
This feature is only supported by external indicators. For more information about alarms for indicators, execute the display system internal kpi register-status command.
# Enable alarms for the Port_TXBW_Usage indicator.
[Sysname] kpi collect indicator Port_TXBW_Usage alarm-enable
Use kpi collect module enable to enable KPI data collection for a module.
Use undo kpi collect module enable to disable KPI data collection for a module.
kpi collect module [ module-name ] enable
undo kpi collect module [ module-name ] enable
KPI data collection is enabled for all modules.
module-name: Specifies the module name. For more information, see "Available external indicators for KPI data collection." If you do not specify a module name, the command enables KPI data collection for all modules.
# Enable KPI data collection for the IF-USAGE-EX module.
[Sysname] kpi collect module IF-USAGE-EX enable
Use kpi collect indicator collect-type to specify a log and alarm report mode for an indicator.
Use undo kpi collect indicator collect-type to restore the default.
kpi collect indicator indicator-name collect-type { always | change | threshold }
undo kpi collect indicator indicator-name collect-type
The log and alarm report mode is customized for each module. To view the report mode for an indicator, execute the display system internal kpi register-status command.
always: Specifies the always mode.
change: Specifies the change mode.
threshold: Specifies the threshold mode.
Operating mechanism
After you enable alarms for a KPI data collection indicator, the device can send the collected data in SNMP traps to NMS and generate logs for it. Whether a trap and a log are generated and reported for an indicator varies by module and report mode.
· Always—Reports an alarm and a log every time an indicator value is collected.
· Change—Reports an alarm and a log only if the collected indicator value is different from that collected previously.
· Threshold—Reports an alarm and a log only if the collected indicator value exceeds an threshold.
# Set the log and alarm report mode to change for the Port_TXBW_Usage indicator.
[Sysname] kpi collect indicator Port_TXBW_UsageE collect-type change
kpi collect indicator alarm enable
Use kpi collect indicator threshold to configure alarm thresholds for an indicator.
Use undo kpi collect indicator threshold to restore the default.
kpi collect [ percentage ] indicator indicator-name threshold low low-threshold normal normal-threshold l1warning l1-threshold l2warning l2-threshold l3warning l3-threshold
undo kpi collect indicator indicator-name threshold
The alarm thresholds for an indicator are customized for each module. To view the alarm thresholds, execute the display system internal kpi register-status command.
percentage: Specifies the percentage format for alarm thresholds.
· Specify this keyword for an indicator if its value is a decimal in the range of 0 to 1. Then, the values for all alarms thresholds are in the range of 0 to 100.
· You cannot specify this keyword if the value for an indicator is an integer.
low low-threshold: Specifies the low alarm threshold, which indicates that the indicator value is too low. The value range varies by indicator. For more information, see "Available external indicators for KPI data collection."
normal normal-threshold: Specifies the reference value, which indicates that the indicator value is normal. The value range varies by indicator. For more information, see "Available external indicators for KPI data collection."
l1warning l1-threshold: Specifies the level-1 alarm threshold, which indicates that the indicator value is slightly high and requires attention. The value range varies by indicator. For more information, see "Available external indicators for KPI data collection." The level-1 alarm threshold cannot be lower than the reference value.
l2warning l2-threshold: Specifies the level-2 alarm threshold, which indicates that the indicator value is relatively high and a risk exists. The value range varies by indicator. For more information, see "Available external indicators for KPI data collection." The level-2 alarm threshold cannot be lower than the level-1 alarm threshold.
l3warning l3-threshold: Specifies the level-3 alarm threshold, which indicates that the indicator value is too high and a severe risk exists. The value range varies by indicator. For more information, see "Available external indicators for KPI data collection." The level-3 alarm threshold cannot be lower than the level-2 alarm threshold.
Operating mechanism
The device generates an alarm in the following conditions:
· The device generates a level-1 alarm if the indicator value collected by KPI exceeds the level-1 alarm threshold.
· The device generates a level-2 alarm if the indicator value collected by KPI exceeds the level-2 alarm threshold.
· The device generates a level-3 alarm if the indicator value collected by KPI exceeds the level-3 alarm threshold.
· The device generates a low value alarm if the indicator value collected by KPI drops below the low alarm threshold.
The device generates an alarm clearance notification in the following conditions:
· The device generates a level-3 alarm clearance notification if the indicator value collected by KPI drops below the level-3 alarm threshold.
· The device generates a level-2 alarm clearance notification if the indicator value collected by KPI drops below the level-2 alarm threshold.
· The device generates a level-1 alarm clearance notification if the indicator value collected by KPI drops below the level-1 alarm threshold.
· The device generates a low value alarm clearance notification if the indicator value collected by KPI exceeds the low alarm threshold but does not exceed the level-1 alarm threshold.
This feature is supported only by external indicators.
For more information about the alarm thresholds for indicators, execute the display system internal kpi register-status command.
# Set the low alarm threshold to 1, reference value to 30, level-1 threshold to 50, level-2 threshold to 70, and level-3 threshold to 90 for the Port_TXBW_Usage indicator.
[Sysname] kpi collect indicator-threshold Port_TXBW_Usage low 1 normal 30 l1warning 50 l2warning 70 l3warning 90
kpi copy-file to active-mpu
Use kpi copy-file to active-mpu to copy the KPI data on the standby MPU to the active MPU.
After an MPU active/standby switchover on the device, the new active MPU cannot automatically obtain the KPI data from the old active MPU (current standby MPU). To ensure service continuity, you must use this feature to copy the KPI data on the old active MPU to the new active MPU.
# Copy the KPI data on the standby MPU to the active MPU.
[Sysname] kpi copy-file to active-mpu
kpi file save-interval
Use kpi file save-interval to specify the interval for saving KPI files to the storage media.
Use undo kpi file save-interval to restore the default.
kpi file save-interval interval
KPI files are saved to the storage media at an interval of 1440 minutes.
interval: Specifies the interval for saving KPI files to the storage media, in the range of 60 to 65535 minutes.
# Set the interval for saving KPI files to the storage media to 60 minutes.
[Sysname] kpi file save-interval 60
Use kpi file aging threshold remain-disk-size to set the free storage media capacity threshold for triggering KPI file aging.
Use undo kpi file aging threshold remain-disk-size to restore the default.
kpi file aging threshold remain-disk-size size
The free storage media capacity threshold for triggering KPI file aging is 128 MB.
size: Specifies the free storage media capacity threshold in the range of 128 to 65535 MB.
When the free storage media capacity is less than the specified threshold, the device automatically deletes the earliest saved KPI files until the free capacity is greater than or equal to the specified threshold.
# Set the free storage media capacity threshold for triggering KPI file aging to 1000 MB.
[Sysname] kpi file aging threshold remain-disk-size 1000
Use kpi file aging threshold total-file-size to set the KPI file size threshold for triggering KPI file aging.
Use undo kpi file aging threshold total-file-size to restore the default.
kpi file aging threshold total-file-size size
The KPI file size threshold for triggering KPI file aging is 128 MB.
size: Specifies the KPI file size threshold in the range of 32 to 2048 MB.
When the total KPI file size on the storage media exceeds the specified threshold, the device automatically deletes the earliest saved KPI files until the total KPI file size is less than or equal to the specified threshold.
# Set the KPI file size threshold for triggering KPI file aging to 500 MB.
[Sysname] kpi file aging threshold total-file-size 500
kpi file directory
Use kpi file directory to specify the KPI file directory.
kpi file directory dir-name
KPI files are stored in the flash:/kpi directory.
dir-name: Specifies the directory name, a string of any length.
# Set the KPI file directory to flash:/.
[Sysname] kpi file directory flash:/
kpi module collect-interval
Use kpi module collect-interval to configure the KPI data collection interval for a module.
Use undo kpi module collect-interval to restore the default.
kpi module module-name collect-interval collect-interval
undo kpi module module-name collect-interval
The KPI data collection intervals for modules to which external indicators belong are customized.
collect-interval: Specifies the KPI data collection interval, in the range of 60 to 65535 seconds.
To view the KPI data collection intervals for different modules, execute the display kpi module-info command.
# Set the KPI data collection interval to 200 seconds for the IF-USAGE-EX module.
[Sysname] kpi module IF-USAGE-EX collect-interval 200
snmp-agent trap enable kpi
Use snmp-agent trap enable kpi to enable SNMP notifications for KPI.
Use undo snmp-agent trap enable kpi to disable SNMP notifications for KPI.
SNMP notifications are enabled for KPI.
Operating mechanism
With SNMP notifications enabled for KPI, the device sends related information to the SNMP module when an indicator value falls outside or within the alarm threshold range.
For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP notifications, see "Configuring SNMP."
# Enable SNMP notifications for KPI.
[Sysname] snmp-agent trap enable kpi
