- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Fast log output commands
- 22-Flow log commands
- 23-Information center commands
- 24-Packet capture commands
- 25-Flow monitor commands
- 26-NetAnalysis commands
- 27-KPI data collection commands
| 07-PTP commands | 492.99 KB |
display ptp foreign-masters-record
ptp alarm-threshold clock-source-class
ptp alarm-threshold { time-lock | time-unlock }
ptp alarm-threshold time-offset
ptp alarm-threshold time-offset-sum pk-pk
PTP commands
display ptp clock
Use display ptp clock to display PTP clock information.
display ptp clock
This command does not display any information if you have not specified a PTP profile (PTP standard) or a PTP mode (PTP clock node type).
# Display PTP clock information.
<Sysname> display ptp clock
PTP profile : IEEE 1588 Version 2
PTP mode : BC
Slave only : No
Sync uncertain : Disabled
Clock state : Disabled
Lock status : Locked
Clock ID : 62EA70-FFFE-AA0100
Clock type : Local
Clock domain : 1
Number of PTP ports : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay : 0 (ns)
Steps removed : 0
Local clock time : Fri Jul 17 14:17:41 2020
Clock source info:
Clock Pri1 Pri2 Accuracy Class TimeSrc Direction In-Status Offset(log variance)
Local 128 128 254 248 160 N/A Active 65535
ToD0 128 128 32 6 32 N/A Inactive 65535
ToD1 128 128 32 6 32 N/A Inactive 65535
PTP profile |
PTP standard: · IEEE 1588 version 2. · ITU-T G.8275.1. · ITU-T G.8275.2. |
PTP mode |
PTP clock node type: · BC. · E2ETC. · E2ETC-OC. · OC. · P2PTC. · P2PTC-OC. · T-BC. · T-TC. · T-TSC. · T-BC-P. · T-TSC-P. |
Slave only |
Whether the OC operates in Slave only mode: · Yes. · No. |
Sync uncertain |
Whether the device is enabled to notify the downstream nodes of its time synchronization state: · Disabled. · Enabled. |
Clock state |
PTP clock state: · Disabled—The PTP clock state feature is disabled. · Free-Run—The PTP clock has never been synchronized to a time source and is not in the process of synchronizing to a time source. · Acquiring—The PTP clock is in the process of synchronizing to a time source. · Locked—The PTP clock has been synchronized to a time source. · Holdover—The PTP clock is in holdover state. |
Lock status |
PTP time locking status. · Locked. · Unlocked. |
Clock ID |
Clock ID for the device, which uniquely identifies a PTP device. |
Clock type |
Clock type of the device: · Local—Local clock. · ToD0—ToD 0 clock. · ToD1—ToD 1 clock. |
ToD direction |
ToD input or output: · IN—The device receives clock signals from an external ToD clock. · N/A—The device neither receives nor transmits ToD clock signals. This field is not displayed for a local clock. |
ToD delay time |
Delay correction value in nanoseconds for the ToD clock. This field is not displayed when the device is a local clock. |
Offset from ToD |
Clock offset from the most recent synchronization with the ToD node, in nanoseconds. |
Clock domain |
PTP domain where the device resides. |
Priority1 |
Priority 1 value for the PTP clock. |
Priority2 |
Priority 2 value for the PTP clock. |
Local priority |
Local priority of the PTP clock. (This field is available only for the ITU-T G.8275.1 and ITU-T G.8275.2 PTP profiles.) |
Class |
Time class of the device. For a ToD clock source, when the value for In-Status is Inactive, this field displays the configured time level of the ToD clock source (default value is 187). When the value for In-Status is Active, this field displays the actual effective time level of the ToD clock source. |
Accuracy |
Time accuracy of the device. |
Offset (log variance) |
Offset of the grandmaster clock. |
Offset from master |
Offset from the master clock node (parent clock node), in nanoseconds. When the device is a transparent clock node (tc included in the ptp mode parameter), the value for this field is N/A, which indicates that information for this field is not obtained. |
Mean path delay |
Mean path delay, in nanoseconds. When the device is a transparent clock node (tc included in the ptp mode parameter), the value for this field is N/A, which indicates that information for this field is not obtained. |
Steps removed |
Hops from the grandmaster to the local clock node. N/A indicates that information for this field is not obtained. |
Clock source info |
Information about the clock source. |
Clock |
Clock source type: · Local—Local clock. · ToD0—ToD 0 clock. · ToD1—ToD 1 clock. |
Pri1 |
Priority 1 value of the clock source. |
Pri2 |
Priority 2 value of the clock source. |
LP |
Local priority of the clock source. (This field is available only for the ITU-T G.8275.1 PTP profile.) |
TimeSrc |
Time source of the clock source. |
Direction |
For a local clock source, this field displays N/A. For a ToD clock source, the values include: · In—The device receives ToD clock signals. · Out—The device transmits ToD clock signals. · N/A—The device does not receive or transmit ToD clock signals. |
In-Status |
Whether the clock source is active: · Active. · Inactive. |
display ptp corrections
Use display ptp corrections to display PTP corrections that have occurred on a subordinate port.
The PTP corrections are displayed only when the following conditions are met:
· You have specified a PTP profile and PTP clock node type for the device.
· The device has a subordinate port and has performed time or frequency synchronization through the port.
If the subordinate port is changed, the recorded information will be cleared.
PTP corrections that have occurred on a subordinate port displayed by this command have higher accuracy than those displayed by the display ptp tod corrections command.
# Display PTP corrections that have occurred on a subordinate port.
<Sysname> display ptp corrections
Slave port Correction time Corrections(s,ns) Rate ratio
XGE3/1/1 Mar 11 03:14:54 2012 0,74 0.999999973
XGE3/1/1 Mar 11 03:14:55 2012 -1,17 0.999999980
Slave port |
Name of the subordinate port. |
Correction time |
Time when the correction occurred. |
Corrections(s,ns) |
Time corrections in seconds or nanoseconds. N/A indicates that no correction occurred this time. |
Rate ratio |
Ratio of the subordinate port rate to the master port rate. N/A indicates that no correction occurred this time. |
Use display ptp foreign-masters-record to display information about foreign master nodes.
display ptp foreign-masters-record [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about foreign master nodes for all interfaces.
Foreign master node information is displayed only when the following conditions are met:
· The PTP profile is IEEE 1588 version 2 or ITU-T G.8275.1.
· You have specified a PTP clock node type for the device.
· The device has a PTP port in slave, passive, or uncalibrated state.
# Display information about foreign master nodes for all interfaces.
<Sysname> display ptp foreign-masters-record
P1=Priority1, P2=Priority2, LP=LocalPriority, C=Class, A=Accuracy,
OSLV=Offset-scaled-log-variance, SR=Steps-removed
GM=Grandmaster
Interface Clock ID P1 P2 LP C A OSLV SR GM
XGE3/1/1 000FE2-FFFE-FF0000 0 128 128 248 254 65535 0 Yes
XGE3/1/2 000FE2-FFFE-FF0001 0 128 128 248 254 65535 1 No
Name of a PTP interface. |
Clock ID |
Clock ID of the foreign master node. |
LP |
Local priority of the interface. It will be used as the local priority of the peer node in BMC selection. This field is available only for the ITU-T G.8275.1 PTP profile. |
C |
Time class. |
A |
Time accuracy. |
OSLV |
SR |
Hops from the grandmaster to the local clock node. |
GM |
Whether the node represents the grandmaster clock: · Yes. · No. |
display ptp interface
Use display ptp interface to display PTP running information for one or all PTP interfaces.
display ptp interface [ interface-type interface-number | brief ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP running information for all PTP interfaces.
brief: Displays brief PTP running information for all PTP interfaces. If you do not specify this keyword, this command displays detailed PTP running information for the specified PTP interface or all PTP interfaces.
This command displays detailed PTP information only for PTP-enabled interfaces. The brief PTP running information can be displayed only when PTP is operating on the interface.
# Display brief PTP running information for all PTP interfaces.
<Sysname> display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
XGE3/1/1 Slave E2E Two 0
XGE3/1/2 Passive E2E Two 0
# Display detailed PTP running information for Ten-GigabitEthernet 3/1/1.
<Sysname> display ptp interface ten-gigabitethernet 3/1/1
Interface : Ten-GigabitEthernet3/1/1
Clock ID : 9A673C-FFFE-870500
Port number : 2
PTP version : 2
PTP enable : Enabled
Transport of PTP : IEEE 802.3/Ethernet
Port state : Disabled
Force state : No
Clock step : Two
Asymmetry correction : 0
Delay mechanism : End to End
Announce Drop : Enabled
Unicast negotiate port role : Grant-port
Announce interval (log mean) : 1
Announce receipt time out : 3
Sync interval (log mean) : 0
Delay Response interval (log mean) : 0
Delay request interval (log mean) : N/A
Peer delay request interval (log mean) : 0
Name |
Name of the PTP interface. |
State |
States of the PTP interface: · Slave—Receives synchronization messages. · Uncalibrated—Temporary state before the interface enters Slave state. · Passive—Neither receives nor sends synchronization messages. A PTP interface is in passive state after it receives an announce messages. · Master—Sends synchronization messages. · Premaster—Temporary state before the interface enters Master state. · Listening—Neither receives nor sends synchronization messages. A PTP interface is in listening state after being initialized. · Faulty—PTP is running incorrectly. A PTP interface in faulty state does not process PTP messages. · Disabled—PTP is not running on the interface. A PTP interface in disabled state does not process PTP messages. · Initializing—The interface is initializing. A PTP interface in initializing state does not process PTP messages. · N/A—No PTP interface state is obtained. |
Delay mechanism |
Delay measurement mechanism: · End to End—Request-response mechanism. · Peer to Peer—Peer delay mechanism. |
Announce drop |
Whether dropping announce messages is enabled: · Enabled. · Disabled. |
Clock step |
Mode for carrying timestamps: · One—Single-step mode. · Two—Two-step mode. |
Asymmetry correction |
Asymmetric delay correction value (in nanoseconds). |
Clock ID |
Clock ID of the device where the interface resides. |
PTP version |
PTP version number. The version number is always 2. |
PTP enable |
Whether PTP is enabled or disabled: · Enabled. · Disabled. |
Transport of PTP |
PTP messages are transported by: · User Datagram Protocol (IPv4). · IEEE 802.3/Ethernet. |
Unicast destination address |
Destination IP address for unicast PTP messages transmitted over IPv4 UDP. This field is not displayed if the ptp unicast-destination command is not executed. |
Unicast negotiate port role |
This field is available only when the PTP profile is IEEE 1588 version 2 or ITU-T G.8275.2. Role of the port for unicast negotiation. This field displays Invalid when unicast negotiation is disabled on the port. · Request-port · Grant-port |
DSCP priority |
DSCP value for PTP messages transmitted over IPv4 UDP. This field is not displayed if the ptp dscp command is not executed. |
VLAN |
VLAN ID for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Dot1p priority |
802.1p precedence for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Force state |
Whether the force state is configured: · Yes. · No. |
Announce interval (log mean) |
Announce message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Announce receipt time out |
Number of announcement intervals before the receiving node stops receiving announce messages. If a member node does not receive any announce message from the master node within the specified value, it considers the master node invalid. |
Sync interval (log mean) |
Sync message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Delay request interval (log mean) |
Minimum delay request message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Delay response interval (log mean) |
Delay response message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Peer delay request interval (log mean) |
Peer delay request message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Local priority |
Priority of the peer node. This field is available only for the ITU-T G.8275.1 profile. |
NotSlave |
Whether or not the NotSlave feature is enabled. This field is available only for the ITU-T G.8275.1 profile. |
Mean path delay |
Mean path delay, in nanoseconds. |
display ptp parent
Use display ptp parent to display parent node (master node) information for the PTP device.
display ptp parent
The command does not display any information when any of the following conditions are met:
· No PTP profile is specified.
· No PTP clock node type is specified, or the PTP clock node type is TC or T-TC.
· The ptp active force-state command has been executed.
# Display parent node information for the PTP device.
<Sysname> display ptp parent
Parent clock:
Parent clock ID : 000FE2-FFFE-FF0005
Parent port number : 15
Observed parent offset (log variance) : N/A
Observed parent clock phase change rate : N/A
Grandmaster clock:
Grandmaster clock ID: 000FE2-FFFE-FF0000
Grandmaster clock quality:
Class : 248
Accuracy : 254
Priority1 : 128
Priority2 : 128
Table 5 Command output
Parent port number |
Outgoing interface number of the parent clock. |
Observed parent offset (log variance) |
Offset from the parent clock node. N/A indicates that information for this field is not obtained. |
Class |
Time class of the grandmaster clock. |
Accuracy |
Time accuracy of the grandmaster clock. |
Priority1 |
Priority 1 value of the grandmaster clock. |
Priority2 |
Priority 2 value of the grandmaster clock. |
display ptp path-trace
Use display ptp path-trace to display brief information about the PTP synchronization path from the GM to the device.
Operating mechansim
The command displays information about the PTP synchronization path from the GM to the device.
This command does not take effect if one of the following conditions exists:
· No PTP profile, PTP clock node type, or PTP domain is configured.
· The clock node type is E2ETC, E2ETC-OC, P2PTC, P2PTC-OC, or T-TC.
· The ptp active force-state command has been configured.
# Display brief information about the PTP synchronization path from the GM to the device.
<Sysname> display ptp path-trace
Sequence number Clock ID
2 000FE3-FFFE-F90000
3 000FE4-FFFE-F50000
4 000FE5-FFFE-F20000
5 000FE6-FFFE-F70000
Table 6 Command output
Sequence number |
Sequence number of the clock node. |
Clock ID |
ID of the clock node |
ptp domain
ptp mode
ptp profile
display ptp port-history
Use display ptp port-history to display historical role change information for PTP ports.
display ptp port-history [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays historical role change information for all interfaces.
# Display historical role change information for all PTP ports.
<Sysname> display ptp port-history
Interface: Ten-GigabitEthernet3/1/1
Role change: Disabled -> Listening
Time : Apr 15 08:56:50 2023
IfBMCInfo : 0 255 255 255 255 65535 65535 65535 65535 65535 6
Role change: Listening -> Master
Time : Apr 15 08:56:56 2023
Table 7 Command output
PTP port name. |
Role change |
Role change of the PTP port. |
Time |
Time at which the PTP port role was calculated. |
IfBMCInfo |
BMC information for the PTP port: · IEEE 1588 version 2—Includes the values of protocol type, priority 1, clock class, clock accuracy, priority 2, sending port number, receiving port number, source port number, hops, offset (log variance), and port number in sequence and separated by spaces. · ITU-T G.8275.1 and ITU-T G.8275.2—Includes the values of protocol type, local priority, clock class, clock accuracy, priority 2, sending port number, receiving port number, source port number, hops, offset (log variance), and port number in sequence and separated by spaces. |
display ptp statistics
Use display ptp statistics to display PTP statistics.
display ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP statistics for all interfaces.
The command does not display any PTP statistics if you have not specified a PTP profile or a PTP clock node type.
# Display PTP statistics on Ten-GigabitEthernet 3/1/1.
<Sysname> display ptp statistics interface ten-gigabitethernet 3/1/1
Received packets
Announce :0 Sync :0 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :0
PdelayReq:0 PdelayResp:0 PdelayRespFollowUp :0
Sent packets
Announce :476 Sync :2543 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :2542
PdelayReq:238 PdelayResp:0 PdelayRespFollowUp :0
Discarded packets
Table 8 Command output
Received packets |
Statistics about received PTP messages. |
Sent packets |
Statistics about sent PTP messages. |
Discarded packets |
Statistics about discarded PTP messages. |
display ptp time-property
Use display ptp time-property to display PTP clock properties.
This command does not display any information in any of the following circumstances:
· You have not specified a PTP standard or a clock node type.
· You have specified the clock node type as e2etc or p2ptc.
· You have executed the ptp active force-state command.
# Display PTP clock properties.
<Sysname> display ptp time-property
PTP clock time property:
Current UTC offset valid : True
Current UTC offset : 33
Leap59 : Yes
Leap61 : No
Time traceable : True
Frequency traceable : True
PTP timescale : True
Time source : 0xA0 (Internal oscillator)
Sync uncertain : False
Table 9 Command output
Current UTC offset valid |
Whether the Coordinated Universal Time (UTC) offset is valid: · True—Yes. · False—No. |
Current UTC offset |
Cumulative offset (in seconds) between the UTC of the grandmaster clock and the International Atomic Time (TAI). |
Leap59 |
Whether cumulative offset is minus 1: · Yes. · No. |
Leap61 |
Whether cumulative offset is plus 1: · Yes. · No. |
Time traceable |
Whether the PTP time is traceable: · True—Yes. · False—No. |
Frequency traceable |
Whether the PTP frequency is traceable: · True—Yes. · False—No. |
PTP timescale |
The possible timescales available for use by the grandmaster clock: · True—PTP timescale. · False—Non-PTP timescale. |
Time source |
Attributes of the grandmaster clock: · Atomic clock. · GPS. · Handset. · Internal oscillator. · NTP. · Other. · PTP. · Terrestrial radio. · Unknown. |
Sync uncertain |
Whether the upstream clock is not reliable: · True—The upstream clock is not reliable. · False—The upstream clock is reliable. |
Use display ptp tod corrections to display corrections that have occurred on ToD interfaces.
Each time the device synchronizes time with ToD, it logs a corresponding entry. Use this command to view corrections that have occurred on ToD interfaces.
PTP corrections that have occurred on a subordinate port displayed by the display ptp corrections command have higher accuracy than those displayed by this command.
# Display corrections that have occurred on ToD interfaces.
<Sysname> display ptp tod corrections
ToD type Corrected at Correction(s,ns) Direction
ToD0 Mar 11 03:14:54 2012 0,74 In
ToD0 Mar 11 03:14:55 2012 -1,17 In
Table 10 Command output
ToD type |
ToD interface name. |
Corrected at |
Correction (s,ns) |
Direction |
Direction of the ToD clock. The value is In. |
ptp { tod0 | tod1 }
ptp { tod0 | tod1 }
Use ptp { tod0 | tod1 } to configure ToD input or output.
Use undo ptp { tod0 | tod1 } to restore the default.
ptp tod0 input [ delay input-delay-time ]
undo ptp tod0 input
ptp tod1 output [ delay output-delay-time ]
undo ptp tod1 output
Whether to receive or transmit ToD 0 clock signals is not configured, and the correction delay is not configured.
The device transmits ToD 1 clock signals, and the correction delay is 0 nanoseconds.
tod0: Specifies the ToD 0 clock.
tod1: Specifies the ToD 1 clock.
input: Configures the device to receive ToD clock signals.
delay input-delay-time: Specifies the receiving delay correction value in nanoseconds. The value range for this argument is 0 to 20000. The default value is 0.
output: Configures the device to transmit ToD clock signals as a master.
delay output-delay-time: Specifies the transmitting delay correction value in nanoseconds. The value for this argument is 0 or in the range of 16 to 1600 when the ptp tod1 output delay command is executed. The default value is 0.
This command is available only after you specify a PTP profile and a PTP clock node type.
For the undo form of the command to take effect, first modify ToD input or output settings by executing this command.
# Configure the device to receive ToD clock signals from ToD 0 and set the receiving delay correction value to 1000 nanoseconds.
[Sysname] ptp profile 1588v2
[Sysname] ptp mode oc
[Sysname] ptp tod0 input delay 1000
ptp mode
ptp profile
Use ptp active force-state to activate the port role configuration.
Use undo ptp active force-state to restore the default.
The port role configuration is not activated.
Application scenarios
After you change the role of a PTP port, you must execute this command to activate the port role configuration.
The T-TSC, T-TSC-P, and T-BC-P clock nodes do not support this command.
# Activate the port role configuration.
[Sysname] ptp active force-state
ptp force-state
ptp mode
ptp profile
Use ptp alarm-threshold clock-source-class to set the class threshold for the clock source.
Use undo ptp alarm-threshold clock-source-class to restore the default.
ptp alarm-threshold clock-source-class class-value
The class threshold for the clock source is 6.
class-value: Specifies a class threshold, in the range of 0 to 255.
Operating mechanism
Each PTP clock source has a class value. For a ToD clock source, you can set its class value by using the ptp clock-source command. The higher the value, the lower the class. When the class value of the clock source crosses the class threshold, the system outputs a log for notification.
This command is available only after you specify a PTP profile and PTP clock node type.
Only the IEEE 1588 version 2, ITU-T G.8275.1, and ITU-T G.8275.2 PTP profiles support this command.
# Set the class threshold to 20 for the clock source.
[Sysname] ptp clock mode t-bc
[Sysname] ptp alarm-threshold clock-source-class 20
ptp clock mode
ptp clock-source
ptp profile
Use ptp alarm-threshold { time-lock threshold-value | time-unlock unlock-value } * to set the PTP time locking and unlocking thresholds.
Use undo ptp alarm-threshold { time-lock | time-unlock } * to restore the default.
ptp alarm-threshold { time-lock lock-value | time-unlock unlock-value } *
PTP time locking threshold and unlocking threshold are both 500 ns.
time-lock lock-value: Specifies the PTP time locking threshold in ns. The value is in the range of 20 to 3000.
time-unlock unlock-value: Specifies the PTP time unlocking threshold in ns. The value is in the range of 20 to 3000.
Operating mechanism
When the time offset of the PTP reference clock crosses the PTP time unlocking threshold, the PTP time is put into unlocked state. The system outputs a time-unlocked log entry for notification. When the time offset of the PTP reference clock drops to or below the PTP time locking threshold, the PTP time is put into locked state. The system outputs a time-locked log entry for notification.
You can execute the command multiple times. If different values are configured for a threshold, the most recent configuration takes effect.
Specify a PTP profile and PTP clock node type before you execute this command.
This command does not take effect on the clock source connected to a ToD interface. When the device uses such a clock source, it does not compare the time offset of the PTP clock source with the threshold set by this command.
The PTP time unlocking threshold must be greater than or equal to the locking threshold.
# Set the PTP time locking threshold to 100 ns.
[Sysname] ptp mode t-bc
[Sysname] ptp alarm-threshold time-lock 100
ptp mode
ptp profile
Use ptp alarm-threshold time-offset to set the time-offset threshold between the external reference clock and the PTP clock.
Use undo ptp alarm-threshold time-offset to restore the default.
ptp alarm-threshold time-offset time-offset-value
The time-offset threshold between the external reference clock and the PTP clock is 500 ns.
time-offset-value: Specifies the time-offset threshold between the external reference clock and the PTP clock, in the range of 200 to 1000, in ns.
Operating mechanism
If the device uses an external ToD reference clock, it calculates the time offset between the external reference clock and the PTP clock at a pre-defined interval (not configurable). When the offset exceeds the threshold, the device outputs a log for notification.
# Set the threshold to 800 ns for the time offset between the external reference clock and the PTP clock.
[Sysname] ptp alarm-threshold time-offset 800
ptp mode
ptp profile
Use ptp alarm-threshold time-offset-sum pk-pk to set the time-offset-sum peak-to-peak threshold.
Use undo ptp alarm-threshold time-offset-sum pk-pk to restore the default.
ptp alarm-threshold time-offset-sum pk-pk threshold-value
The time-offset-sum peak-to-peak threshold is 500 ns.
threshold-value: Sets the time-offset-sum peak-to-peak threshold in the range of 0 to 2000, in ns.
Operating mechanism
The PTP module calculates the time-offset-sum peak-to-peak value at specific intervals and compares the value with the threshold configured by this command. If the value is larger than the threshold, the system outputs a log for notification.
# Set the time-offset-sum peak-to-peak threshold to 1500 ns.
[Sysname] ptp alarm-threshold time-offset-sum pk-pk 1500
ptp mode
ptp profile
ptp announce-drop enable
Use ptp announce-drop enable to enable a PTP interface to drop announce messages.
Use undo ptp announce-drop enable to restore the default.
A PTP interface does not drop announce messages.
Operating mechanism
For two devices that synchronize time to each other, the master-member/subordinate relationship is determined by using the following methods:
· Manually specifying the master-slave interface at the CLI—If you use this method, connected PTP interfaces will not transmit announce messages, and you do not need to configure this command.
· Automatically determined based on the BMC algorithm—If you use this method, the connected PTP interfaces periodically send announce messages to negotiate their master-member/subordinate roles. After receiving an announce message, a PTP interface forwards it to the device's CPU for processing. An excess of announce messages might lead to CPU overload, potentially impacting processing of other types of service packets. In a stable network environment, once the master-member/subordinate relationship is determined, you can configure this command on the master interface. With this configuration, the master interface maintains its role and will discard received announce messages rather than sending them to the CPU.
You must configure a PTP profile and clock node types before you can use this command.
For a successful autonegotiation of the master-member/subordinate relationship, configure this command after master-member/subordinate relationship is negotiated successfully.
Do not configure this command on an interface with a member/subordinate role. If you do so, the member/subordinate interface will become a master interface, causing clock synchronization failure.
# Configure PTP interface Ten-GigabitEthernet3/1/1 to drop announce messages.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ptp announce-drop enable
· ptp mode
· ptp profile
ptp announce-interval
Use ptp announce-interval to set the interval for sending announce messages.
Use undo ptp announce-interval to restore the default.
ptp announce-interval interval
When the PTP profile is IEEE 1588 version 2, the interval argument value is 1 and the announce message sending interval is 2 (21) seconds.
When the PTP profile is ITU-T G.8275.1 and ITU-T G.8275.2, the interval argument value is –3 and the announce message sending interval is 1/8 (2-3) seconds.
FlexE physical interface view
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending announce messages. The value range for the interval argument is 4 to 6 for the IEEE 1588 version 2 PTP profile, –3 to 6 for the ITU-T G.8275.1 PTP profile, and –3 to 0 for the ITU-T G.8275.2 PTP profile.
Operating mechanism
The value of the interval at which the master node sends announce messages depends on whether unicast negotiation is enabled.
· When unicast negotiation is disabled, the master node uses the value configured in the ptp announce-interval command on its interface as the interval to send announce messages.
· When unicast negotiation is enabled, you must configure the interval on the request-port of the client. Then the client and server negotiates whether the server can send announce messages to the client at that interval from the grant-port. If the negotiation succeeds, the grant-port sends announce messages at the configured interval to the client. If the negotiation fails, the grant-port does not send announce messages to the client.
# Set the announce message sending interval to 4 (22) seconds on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp announce-interval 2
ptp mode
ptp profile
ptp announce-timeout
Use ptp announce-timeout to set the timeout multiplier for the announce message receiving interval.
Use undo ptp announce-timeout to restore the default.
ptp announce-timeout multiple-value
The timeout multiplier for the announce message receiving interval is 3.
multiple-value: Sets the timeout multiplier for the announce message receiving interval. The value range for this argument is 2 to 10.
Operating mechanism
A master node sends announce messages to the member nodes at the specified interval. If a member node does not receive any announce message from the master node after the timeout expires, it determines that the master node is invalid. The timeout = timeout multiplier × interval at which the master node sends announce messages.
Recommended configuration
To ensure a stable PTP network, set the timeout multiplier for receiving announce messages to a value in the range of 5 to 7.
# Set the timeout multiplier for the announce message sending interval to 5 on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp announce-timeout 5
ptp mode
ptp profile
ptp asymmetry-correction
Use ptp asymmetry-correction to set the asymmetric delay correction time.
Use undo ptp asymmetry-correction to restore the default.
ptp asymmetry-correction { minus | plus } value
The asymmetric delay correction time is 0 nanoseconds, which means that delay correction is not performed.
minus: Subtracts the specified asymmetric delay correction value.
plus: Adds the specified asymmetric delay correction value.
value: Specifies the asymmetric delay correction value in the range of 0 to 2000000 nanoseconds.
# Set the asymmetric delay correction time to 100 nanoseconds on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp asymmetry-correction plus 100
ptp mode
ptp profile
ptp clock-source
Use ptp clock-source to configure clock source parameters.
Use undo ptp clock-source to restore the default.
Local clock source:
ptp clock-source local { accuracy acc-value | class class-value | time-source ts-value }
undo ptp clock-source local { accuracy | class | time-source }
ToD clock source:
ptp clock-source { tod0 | tod1 } { accuracy acc-value | class class-value | grandmaster-clockid clock-id | offsetscaled-logvariance value | time-source ts-value }
undo ptp clock-source { tod0 | tod1 } { accuracy | class | grandmaster-clockid | offsetscaled-logvariance | time-source }
The clock ID of a GM clock is 000000-0000-000000.
· ITU-T G.8275.1 PTP profile
¡ T-TSC clock node type
- Local clock source—The accuracy value is 254, the time class value is 255, the offset (log variance) value is 65535, and the time source value is 160. The four values are not configurable.
- ToD clock source—The accuracy value is 254, the time class value is 255, the offset (log variance) value is 65535, and the time source value is 32.
¡ T-BC or T-TC clock node type
- Default PTP technical standard
Local clock source—The accuracy value is 254, the time class value is 248, the offset (log variance) value is 65535 and the time source value is 160. The offset (log variance) value is not configurable.
ToD clock source—The accuracy value is 32, the time class value is 6, the offset (log variance) value is 65535, and the time source value is 32.
- PTP OAM technical standard
Local clock source—The accuracy value is 254, the time class value is 165, the offset (log variance) value is 65535, and the time source value is 160. The offset (log variance) value is not configurable.
ToD clock source—The accuracy value is 254, the time class value is 165, the offset (log variance) value is 65535, and the time source value is 160.
- PTP Unicom technical standard
Local clock source—The accuracy value is 254, the time class value is 248, the offset (log variance) value is 65535, and the time source value is 160. The offset (log variance) value is not configurable.
ToD clock source—The accuracy value is 33, the time class value is 6, the offset (log variance) value is 20061, and the time source value is 32.
¡ The accuracy value is 254, the time class value is 248, the offset (log variance) value is 65535, and the time source value is 160. The offset (log variance) value is fixed and not configurable.
¡ ToD clock source—The accuracy value is 32, the time class value is 6, the offset (log variance) is 65535, and the time source value is 32.
· ITU-T G.8275.2
¡ T-TSC-P clock node type
¡ T-BC-P clock node type
- Local clock source—The accuracy value is 254, the time class value is 248, the offset (log variance) value is 65535, and the time source value is 160. The offset (log variance) value is fixed and not configurable.
- ToD clock source—The accuracy value is 32, the time class value is 6, the offset (log variance) value is 65535, and the time source value is 32.
NOTE: Only the ITU-T G.8275.1 PTP profile supports PTP technical standards. |
local: Specifies the local clock.
tod1: Specifies the ToD 1 clock. The device does not support this keyword.
accuracy acc-value: Specifies the accuracy of the ToD clock, in the range of 0 to 255. A smaller value indicates a higher accuracy. Table 11 shows the description for clock accuracy values.
Table 11 Clock accuracy value description
Clock accuracy value (in hexadecimal format) |
00 through 1F |
Reserved. |
20 |
Less than 25 nanoseconds (1 nanosecond = 10-9 second). |
21 |
Less than 100 nanoseconds. |
22 |
Less than 250 nanoseconds. |
23 |
Less than 1 microsecond (10-6 second). |
24 |
Less than 2.5 microseconds. |
25 |
Less than 10 microseconds. |
26 |
Less than 25 microseconds. |
27 |
Less than 100 microseconds. |
28 |
Less than 250 microseconds. |
29 |
Less than 1 millisecond (10-3 second). |
2A |
Less than 2.5 milliseconds. |
2B |
Less than 10 milliseconds. |
2C |
Less than 25 milliseconds. |
2D |
Less than 100 milliseconds. |
2E |
Less than 250 milliseconds. |
2F |
Less than 1 second. |
30 |
Less than 10 seconds. |
31 |
More than 10 seconds. |
32 through 7F |
Reserved. |
80 through FD |
For use by alternate PTP profiles. |
FE |
Unknown. |
FF |
Reserved. |
class class-value: Specifies the time class of the clock, in the range of 0 to 255. A smaller value indicates a higher time class. Table 12 shows the description for clock classes. The values not listed in the table are reserved by the protocol. As a best practice, do not use those values.
Table 12 Clock class description
Clock class (in decimal format) |
6 |
The clock node synchronizes its time to the master reference time source. PTP assigns a time table to the clock node. A clock node with time class 6 cannot become a member clock of any other clocks in the domain. |
7 |
The former time class is 6. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. PTP assigns a time table to the clock node. A clock node with time class 7 cannot become a member clock of any other clocks in the domain. |
13 |
The clock node synchronizes its time to a time source. ARB assigns a time table to the clock node. A clock node with time class 13 cannot become a member clock of any other clocks in the domain. |
14 |
The former time class is 13. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. ARB assigns a time table to the clock node. A clock node with time class 14 cannot become a member clock of any other clocks in the domain. |
52 |
The clock node with time class 7 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 52 cannot become a member clock of any other clocks in the domain. |
58 |
The clock node with time class 14 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 58 cannot become a member clock of any other clocks in the domain. |
187 |
The clock node with time class 7 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 187 can become a member clock of another clock in the domain. |
193 |
The clock node with time class 14 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 193 can become a member clock of another clock in the domain. |
248 |
Default time class value. |
255 |
Clock node operating in slave-only mode. |
grandmaster-clockid clock-id: Specifies the GM clock ID. The clock-id argument is in the XXXXXX-XXXX-XXXXXX format. X represents a hexadecimal number. A full 0 number is not supported. This option is not available for a local clock source. For a ToD clock source, you must specify this option.
offsetscaled-logvariance value: Specifies the offset (log variance). The value is in the range of 0 to 65535. This option is not available for a local clock source.
time-source ts-value: Specifies the clock attribute value in the range of 0 to 255. Table 13 shows the description for the clock attribute values (those not listed are reserved for the protocol).
Table 13 GM attribute value description
GM attribute values (in hexadecimal format) |
10 |
Atomic clock. |
20 |
GPS. |
30 |
Terrestrial radio. |
40 |
PTP. |
50 |
NTP. |
60 |
Handset. |
90 |
Other. |
A0 |
Internal oscillator. |
F0 to FE |
FF |
Reserved. |
The clock's time class is an attribute of the device. As a best practice, keep the default time class for a local clock source, and do not change it.
You can execute this command multiple times to configure different parameters. If you configure a parameter multiple times, the most recent configuration takes effect.
# Set the time accuracy for the ToD 0 clock to 44.
[Sysname] ptp clock-source tod0 accuracy 44
ptp mode
ptp profile
ptp technical-standard
PTP clock-state enable
Use ptp clock-state enable to enable the PTP clock state feature.
Use undo ptp clock-state enable to disable the PTP clock state feature.
Operating mechansim
The PTP clock state feature defines and clarifies the following PTP clock states:
· Locked—The PTP clock has been synchronized to a time source within the acceptable accuracy.
· Holdover—The PTP clock is no longer synchronized to a time source and is using information obtained when it was previously synchronized.
Specify a PTP profile and PTP clock node type before you execute this command. The PTP profile must be IEEE 1588 version 2 or ITU-T G.8275.1.
This command is mutually exclusive with the ptp technical-standard command.
# Enable the PTP clock state feature.
[Sysname] ptp mode bc
[Sysname] ptp clock-state enable
ptp mode
ptp profile
ptp clock-step
Use ptp clock-step to configure the mode for carrying timestamps.
Use undo ptp clock-step to restore the default.
ptp clock-step { one-step | two-step }
undo ptp clock-step
Two-step mode is used for carrying timestamps.
FlexE logical interface view
one-step: Specifies the single-step mode.
two-step: Specifies the two-step mode.
# Specify the two-step timestamp carrying mode on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp clock-step two-step
ptp mode
ptp profile
ptp delay-mechanism
Use ptp delay-mechanism to specify a PTP delay measurement mechanism.
Use undo ptp delay-mechanism to restore the default.
ptp delay-mechanism { e2e | p2p }
The request-response delay measurement mechanism applies.
e2e: Specifies the request-response mechanism.
p2p: Specifies the peer delay mechanism.
You can configure this command only after you have specified a PTP profile and PTP mode for the device.
When the PTP profile is IEEE 1588 version 2, the following restrictions apply:
· You can configure this command only on a BC or OC clock node.
· You cannot configure this command on an E2ETC, E2ETC+OC, P2PTC, or P2PTC+OC clock node. The E2ETC and E2ETC+OC clock nodes support both request-response and peer delay measurement mechanisms. A P2PTC clock node supports only the peer delay measurement mechanism.
The ITU-T G.8275.1 PTP profile supports only the request-response delay measurement mechanism and does not support this command.
The ITU-T G.8275.2 PTP profile supports only the request-response delay measurement mechanism and does not support this command.
# Specify the OC clock type. On Ten-GigabitEthernet 3/1/1, specify the request-response delay measurement mechanism (e2e).
[Sysname-Ten-GigabitEthernet3/1/1] ptp delay-mechanism e2e
ptp mode
ptp profile
ptp unicast-negotiate
ptp delay-resp-interval
Use ptp delay-resp-interval to set the interval at which the server sends Delay_resp messages to the client.
Use undo ptp delay-resp-interval to restore the default.
ptp delay-resp-interval interval
The default setting of this command varies by PTP profile.
· When the PTP profile is IEEE 1588 version 2, the value of the interval argument is 0 and the minimum interval for sending Delay_resp messages is 1 (20) second.
· When the PTP profile is ITU-T G.8275.2, the value of the interval argument is –4 and the minimum interval for sending Delay_resp messages is 1/16 (2-4) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending Delay_resp messages. The value range for this argument is –5 to 0.
Operating mechanism
This command, configured on a request-port, specifies the interval at which the grant-port sends Delay_resp messages to the request-port.
After receiving a Delay_req message from a request port, the grant-port responses by sending a Delay_resp message and starts a timer defined by this command. The grant-port will not send another Delay_resp message until it receives a Delay_req message after the timer expires.
Only the IEEE 1588 version 2 and ITU-T G.8275.2 PTP profiles support this command.
# Set the Delay_resp message sending interval to 2-3 seconds.
[Sysname-Ten-GigabitEthernet3/1/1] ptp unicast-destination 10.10.10.2
[Sysname-Ten-GigabitEthernet3/1/1] ptp unicast-negotiate request-port
[Sysname-Ten-GigabitEthernet3/1/1] ptp delay-resp-interval -3
ptp mode
ptp profile
ptp destination-mac
Use ptp destination-mac to configure the destination MAC address for PTP messages.
Use undo ptp destination-mac to restore the default.
ptp destination-mac mac-address
The destination MAC address for non-peer delay messages is 011B-1900-0000.
The destination MAC address for peer delay messages is 0180-C200-000E.
mac-address: Specifies the destination MAC address for PTP unicast messages as any unicast MAC address or specifies the destination MAC address for non-peer delay multicast messages as 0180-C200-000E or 011B-1900-0000.
IEEE 802.3/Ethernet-encapsulated PTP messages can be sent through multicast (default) or unicast. In multicast mode, the destination MAC address is 0180-C200-000E or 011B-1900-0000 for non-Pdelay messages and 0180-C200-000E for Pdelay messages. Non-Pdelay messages include delay_Req, delay_Resp, delay_Resp_Follow_Up, Announce, Sync, and FollowUp messages. Pdelay messages include Pdelay_Req, Pdelay_Resp, and Pdelay_Resp_Follow_Up messages.
If a clock node uses the unicast mode, you must configure any unicast MAC address on the uplink node of this clock node as the destination MAC address for PTP messages.
This command is not available for the ITU-T G.8275.2 PTP profile.
This command takes effect only if PTP messages are transported over IEEE 802.3/Ethernet packets.
# Set the destination MAC address for non-peer delay messages to 0180-C200-000E on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp destination-mac 0180-c200-000e
ptp mode
ptp profile
ptp domain
Use ptp domain to specify a PTP domain.
Use undo ptp domain to restore the default.
ptp domain domain-number
undo ptp domain
When the PTP profile is IEEE 1588 version 2, the device is in PTP domain 0.
When the PTP profile is ITU-T G.8275.1, the device is in PTP domain 24.
When the PTP profile is ITU-T G.8275.2, the device is in PTP domain 44.
domain-number: Specifies a PTP domain by its number in the range of 0 to 255. For the ITU-T G.8275.1 PTP profile, the value range for the argument is 24 to 43. For the ITU-T G.8275.2 PTP profile, the value range for the argument is 44 to 63.
Deleting a PTP domain also deletes all configuration for the PTP domain, except for PTP profile and clock node type configuration.
# Configure the PTP domain number to use for the device as 2.
[Sysname] ptp domain 2
ptp mode
ptp profile
ptp dscp
Use ptp dscp to set a DSCP value for PTP messages transmitted over IPv4 UDP.
Use undo ptp dscp to restore the default.
ptp dscp dscp
undo ptp dscp
The DSCP value is 56 for PTP messages transmitted over IPv4 UDP.
dscp: Sets a DSCP value in the range of 0 to 63 for PTP messages.
Specify a PTP profile and PTP clock node type before you execute this command. The ITU-T G.8275.1 profile does not support this command.
This command takes effect only if PTP messages are transmitted over IPv4 UDP.
# Set the DSCP value to 63 for PTP messages transmitted over IPv4 UDP on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp transport-protocol udp
[Sysname-Ten-GigabitEthernet3/1/1] ptp dscp 63
ptp mode
ptp profile
ptp enable
Use ptp enable to enable PTP.
Use undo ptp enable to disable PTP.
ptp enable
undo ptp enable
PTP is disabled.
As a best practice, enable PTP on an interface after you configure PTP parameters.
To enable PTP on a Layer 3 Ethernet interface that has been assigned to a VPN instance, you must specify this VPN instance in the ptp source ip-address vpn-instance vpn-instance-name command if PTP messages are to be transmitted in multicast mode over IPv4 UDP.
For an OC, T-TSC, or T-TSC-P clock node, you can enable PTP only on one port.
# Specify the OC clock node type and enable PTP on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp enable
# Specify the E2ETC clock node type, and enable PTP on Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2.
[Sysname] ptp mode e2etc
[Sysname-Ten-GigabitEthernet3/1/1] interface ten-gigabitethernet 3/1/2
[Sysname-Ten-GigabitEthernet3/1/2] ptp enable
ptp mode
ptp profile
ptp source
ptp force-state
Use ptp force-state to configure a role for a PTP port.
Use undo ptp force-state to restore the default.
ptp force-state { master | passive | slave }
The PTP port role is automatically calculated by the BMC algorithm.
master: Specifies the PTP port as a master port.
passive: Specifies the PTP port as a passive port.
slave: Specifies the PTP port as a subordinate port.
By default, the PTP port roles are automatically negotiated based on the BMC algorithm. If you use this command to change the role of one PTP port, all the other PTP ports in the PTP domain stop working. For these PTP ports to function, you must specify roles for each of them by using this command. As a best practice, enable automatic negotiation of PTP port roles based on the BMC algorithm.
You can configure only one subordinate port for a device.
After you change the role of a PTP port, you must execute the ptp active force-state command to activate the port role configuration.
Under the IEEE 1588 version 2 PTP profile, this command is mutually exclusive with the ptp unicast-negotiate command.
# Specify the OC clock node type and configure Ten-GigabitEthernet 3/1/1 as a subordinate port.
[Sysname-Ten-GigabitEthernet3/1/1] ptp force-state slave
ptp mode
ptp profile
ptp slave-only
ptp ignore sync-uncertain
Use ptp ignore sync-uncertain to enable the device to ignore the synchronizationUncertain flag.
Use undo ptp ignore sync-uncertain to restore the default.
The device does not ignore the synchronizationUncertain flag.
By default, the device reads the value of the synchronizationUncertain flag in the announce message it receives.
· A synchronizationUncertain bit value of 1 indicates that synchronization information from the upstream node is unlocked.
· A synchronizationUncertain bit value of 0 indicates that synchronization information from the upstream node is locked.
If synchronization information from the upstream node is unlocked, the device will not use that information for time synchronization. Only if the synchronization information from the upstream nodes locked, the device uses that information for time synchronization.
Typically, you are not required to configure this command. If the upstream clock is very reliable, you can configure this command to enable the device to ignore the synchronizationUncertain flag. After this command is configured, the device will synchronize the time directly with synchronization information from the upstream clock without reading the synchronizationUncertain bit value.
This command is available only after you specify a PTP profile and a PTP clock node type, and the PTP profile is IEEE 1588 version 2 or ITU-T G.8275.1.
# Enable the device to ignore the synchronizationUncertain flag.
[Sysname] ptp ignore sync-uncertain
ptp local-priority
Use ptp local-priority to configure a local priority for an interface.
Use undo ptp local-priority to restore the default.
ptp local-priority local-priority
The local priority of an interface is 128.
local-priority: Specifies a priority in the range of 1 to 255. The lower the value, the higher the priority.
Operating mechanism
An announce message does not carry the local priority of the clock node. Under the ITU-T G.8275.1 or ITU-T G.8275.2 PTP profile, each PTP-enabled interface on a clock node has a local priority. This priority will be used as the local priority of the peer node in BMC selection and is one of the factors that determine whether the peer node can be elected as the GM.
Only the ITU-T G.8275.1 and ITU-T G.8275.2 PTP profiles support this command.
# Set the local priority for Ten-GigabitEthernet3/1/1 to 10.
[Sysname] ptp profile g8275.1
[Sysname-Ten-GigabitEthernet3/1/1] ptp local-priority 10
ptp mode
ptp profile
ptp max-steps-removed
Use ptp max-steps-removed to specify the maximum number of removed steps (clock nodes) from the GM to the device.
Use undo ptp max-steps-removed to restore the default.
ptp max-steps-removed step-removed-value
The maximum number of removed steps is 255 from the GM to the device.
step-removed-value: Specifies the maximum number of removed steps from the GM to the device, in the range of 1 to 255.
Operating mechanism
If the number of removed steps from the GM to the device exceeds the maximum number, the device cannot synchronize time through PTP.
# Set the maximum number of removed steps from the GM to the device to 20.
[Sysname] ptp max-steps-removed 20
ptp mode
ptp profile
ptp min-delayreq-interval
Use ptp min-delayreq-interval to set the minimum interval for sending delay request messages.
Use undo ptp min-delayreq-interval to restore the default.
ptp min-delayreq-interval interval
When the PTP profile is IEEE 1588 version 2, the value of the interval argument is 0 and the minimum interval for sending delay request messages is 1 (20) second.
When the PTP profile is ITU-T G.8275.1 or ITU-T G.8275.2, the value of the interval argument is –4 and the minimum interval for sending delay request messages is 1/16 (2-4) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending delay request messages. The value range for this argument is –4 to 6. For the ITU-T G8275.2 PTP profile, the value range for this argument is –5 to 0.
Operating mechanism
When a member clock receives a Sync message, it responds by sending a Delay_Req message and starts a timer defined by this command. The member clock will not send another Delay_Req message until it receives a Sync message after the timer expires.
In PTP multicast transport mode, this command takes effect only when configured on the master clock. The master clock sends the value to a member clock through PTP messages to control the interval for the member clock to send Delay_Req messages. To view the value on a member clock, execute the display ptp interface command on the member clock.
In PTP unicast transport mode, this command takes effect when configured on member clocks. It does not take effect when configured on the master clock.
# Set the minimum interval to 4 (22) seconds for sending delay request messages on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp min-delayreq-interval 2
ptp mode
ptp profile
ptp syn-interval
ptp mode
Use ptp mode to specify a clock node type for the device.
Use undo ptp mode to restore the default.
IEEE 1588v2 PTP profile:
ptp mode { bc | e2etc | e2etc-oc | oc | p2ptc | p2ptc-oc }
undo ptp mode
ITU-T G.8275.1 PTP profile:
ptp mode { t-bc | t-tc | t-tsc }
undo ptp mode
ITU-T G.8275.2 PTP profile:
ptp mode { t-bc-p | t-tsc-p }
undo ptp mode
No clock node type is specified for the device.
bc: Specifies the boundary clock (BC) type.
e2etc: Specifies the end-to-end transparent clock (E2ETC) type.
e2etc-oc: Specifies the E2ETC+OC type.
oc: Specifies the ordinary clock (OC) type.
p2ptc: Specifies the peer-to-peer transparent clock (P2PTC) type.
p2ptc-oc: Specifies the P2PTC+OC type.
t-bc: Specifies the telecom boundary clock (T-BC) type.
t-tc: Specifies the telecom transparent clock (T-TC) type.
t-tsc: Specifies the telecom time slave clock (T-TSC) type.
t-bc-p: Specifies the partial-support telecom boundary clock (T-BC-P) type.
t-tsc-p: Specifies the partial-support telecom time slave clock (T-TSC-P) type.
CAUTION: If you change the clock node type for the device, all settings except for the PTP profile will be restored to the default. |
Specify a PTP profile before you execute this command.
· When the PTP profile is IEEE 1588 version 2, you cannot specify the T-TC, T-BC, or T-TSC clock node type.
· When the PTP profile is ITU-T G.8275.1, you can specify only the T-TC, T-BC, or T-TSC clock node type.
· When the PTP profile is ITU-T G.8275.2, you can specify only the T-BC-P or T-TSC-P clock node type.
You can specify only one clock node type for a device.
Changing or removing the clock node type will restore the default settings of the PTP profile.
# Specify the OC clock node type for the device.
ptp profile
ptp notslave disable
Use ptp notslave disable to disable the NotSlave feature.
Use undo ptp notslave disable to restore the default.
The NotSlave feature is enabled on a PTP interface.
Operating mechanism
The NotSlave feature, available only for the ITU-T G.8275.1 and ITU-T G.8275.2 PTP profiles, enables a PTP port to select the clock node where it resides as the master node. You can use this feature to control master/member role of the clock node. For automatic master/member clock node selection in a PTP domain under the ITU-T G.8275.1 PTP profile, you must disable NotSlave on all PTP ports.
Under the ITU-T G.8275.1 PTP profile, only the T-BC and T-TC clock node types support this command.
Under the ITU-T G.8275.2 PTP profile, only the T-BC-P clock node type supports this command.
By default, the ports on the T-BC-P and T-BC clock nodes are in master-only mode. To use a port on a T-BC-P or T-BC clock node as a subordinate port, first execute the ptp notslave disable command on the port.
# Disable the NotSlave feature on Ten-GigabitEthernet3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp notslave disable
ptp mode
ptp profile
ptp path-trace disable
Use ptp path-trace disable to disable PTP path tracing.
Use undo ptp path-trace disable to enable PTP path tracing.
PTP path tracing is enabled.
PTP path tracing traces the clock nodes that the clock signals traverse from the GM to the device.
The system can obtain complete path tracing information only when all clock nodes on the path are enabled with PTP path tracing. If a device on the path does not support PTP path tracing, disable this feature to prevent PTP intercommunication issues.
# Disable PTP path tracing.
[Sysname] ptp path-trace disable
ptp mode
ptp profile
ptp pdelay-req-interval
Use ptp pdelay-req-interval to set the interval for sending peer delay request messages.
Use undo ptp pdelay-req-interval to restore the default.
ptp pdelay-req-interval interval
The interval argument value is 0 and the interval for sending peer delay request messages is 1 (20) second.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending peer delay request messages. The value range for this argument is –4 to 6. For the IEEE 1588 version 2 PTP profile, the value range for this argument is 0 to 5.
The ITU-T G.8275.1 and ITU G.8275.2 PTP profiles do not support this command.
# Set the interval to 4 (22) seconds for sending peer delay request messages on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp pdelay-req-interval 2
ptp mode
ptp profile
ptp port-mode
Use ptp port-mode to configure the interface type as OC for a TC+OC (including E2ETC+OC and P2PTC+OC) clock node.
Use undo ptp port-mode to restore the default.
ptp port-mode oc
undo ptp port-mode
All interfaces on an E2ETC+OC or a P2PTC+OC clock node is TC type.
oc: Specifies the OC interface type.
Specify a PTP profile and PTP clock node type before you execute this command. Only E2ETC+OC and P2PTC+OC clock nodes support this command.
# Specify the P2PTC+OC clock node type for the device. Configure the interface type for Ten-GigabitEthernet 3/1/1 as OC.
[Sysname] ptp mode p2ptc-oc
[Sysname-Ten-GigabitEthernet3/1/1] ptp port-mode oc
ptp mode
ptp profile
ptp priority clock-source
Use ptp priority clock-source to configure the priority for a clock source.
Use undo ptp priority clock-source to restore the default.
ptp priority clock-source { local | tod0 | tod1 } { local-priority local-priority | priority1 priority1 | priority2 priority2 }
undo ptp priority clock-source { local | tod0 | tod1 } { local-priority | priority1 | priority2 }
When the PTP profile is IEEE 1588 version 2, the priority 1 and priority 2 values are both 128.
When the PTP profile is ITU-T G.8275.1, the priority 1 value is 128. The priority 2 value is 128 for both T-BC and T-TC clock nodes and 225 for a T-TSC clock node. The local priority value is 128.
When the PTP profile is ITU-T G.8275.2, the priority 1 value is 128. The priority 2 value is 128 for a T-BC-P clock node and 255 for a T-TSC-P clock node. The local priority value is 128.
local-priority local-priority: Specifies the local priority for the clock. The value is in the range of 0 to 255. A numerically smaller value has higher priority. This option is available only for the ITU-T G.8275.1 and ITU-T G.8275.2 PTP profiles.
priority1 priority1: Specifies priority 1 for the clock. The value is in the range of 0 to 255 for the IEEE 1588 version 2 PTP profile, and is 128 for the ITU-T G.8275.1 and ITU-T G.8275.2 PTP profiles. A numerically smaller value indicates higher priority.
priority2 priority2: Specifies priority 2 for the clock. The value is in the range of 0 to 255 for the IEEE 1588 version 2 PTP profile. For the ITU-T G.8275.1 PTP profile, the value is in the range of 0 to 255 for T-BC and T-TC clock nodes and 255 for a T-TSC clock node. For the ITU-T G.8275.2 PTP profile, the value is in the range of 0 to 255 for a T-BC-P clock node and 255 for a T-TSC clock node. A numerically smaller value indicates higher priority.
Operating mechanism
The local priority of a clock will not be carried in PTP announce messages.
# Set priority 1 to 10 for the local clock.
[Sysname] ptp priority clock-source local priority1 10
ptp mode
ptp profile
ptp profile
Use ptp profile to specify a PTP profile.
Use undo ptp profile to restore the default.
ptp profile { 1588v2 | g8275.1 | g8275.2 }
undo ptp profile
No PTP profile is specified for a device.
1588v2: Specifies the IEEE 1588 version 2 PTP profile.
g8275.1: Specifies the ITU-T G.8275.1 PTP profile.
g8275.2: Specifies the ITU-T G.8275.2 PTP profile.
You must first specify a PTP profile before configuring PTP commands.
Changing a PTP profile clears all settings under the PTP profile.
# Specify the IEEE 1588 version 2 PTP profile.
ptp refclock-master sync-utc
Use ptp refclock-master sync-utc to configure the device to synchronize the TAI time with the UTC time at 6-hour intervals to ensure consistency between the TAI and UTC time when it acts as the GM.
Use undo ptp refclock-master sync-utc to configure the device to synchronize the UTC time with the TAI time at 6-hour intervals to ensure consistency between the UTC and TAI time when it acts as the GM.
When the device acts as the GM, it synchronizes the TAI time with the UTC time at 6-hour intervals to ensure consistency between the TAI and UTC time.
When the device acts as the GM clock on the network and services that rely on PTP clock synchronization (such as iFIT measurement and deterministic network technology) exist on the network, a PTP time jump might affect the operation of these services. This command helps reduce PTP time jumps, and consequently minimize the impact of PTP time jumps on services.
Operating mechanism
The device has two local clock sources: one is UTC time (generated by the local crystal on the MPU), and the other is TAI time (also known as PTP time, generated by the clock daughtcard/PTP chip). After this command is configured, the device synchronizes the TAI time and UTC time as follows by default if the device acts as the GM clock on the network:
1. The device uses the UTC time as the reference clock source for the entire network.
2. After the network administrator enables PTP in interface view, the device synchronizes the clock daughtcard/PTP chip with the UTC time.
3. After synchronizing with the UTC time, the clock daughtcard/PTP chip uses its own frequency for timekeeping. The device synchronizes downstream devices with the TAI time.
4. The device automatically synchronizes the PTP-enabled clock daughtercard/PTP chip with the UTC time every 6 hours.
5. If the network administrator changes the UTC time (for example, execute the clock data-time, ptp utc offset, or ptp utc { leap59-date | leap61-date } command, the device will instantly and automatically synchronize the clock daughtercard and PTP chip with the UTC time.
Finally, devices on the network are synchronized with the UTC time of the device.
After the TAI time and UTC time are synchronized, they are counted separately based on their own frequencies. As a result, there might be extremely subtle deviations between the TAI time and UTC time. Synchronizing the TAI time with the UTC time every 6 hours might cause the TAI time to jump, leading to network-wide time jumps, and consequently affect services that rely on PTP clock synchronization.
To avoid this situation, you can undo this command. After undoing this command, the device will automatically synchronize the UTC time with the TAI time every 6 hours, preventing time jumps from affecting the entire network.
This command takes effect only after the clock protocol ptp command is configured.
# Enable the device to synchronize the UTC time with the TAI time every 6 hours when the device acts as a GM clock
[Sysname] clock protocol ptp
[Sysname] undo ptp refclock-master sync-utc
· clock data-time (device management commands in Fundamentals Command Reference)
· ptp utc
· ptp utc offset
ptp slave-only
Use ptp slave-only to configure the OC to operate only as a member clock.
Use undo ptp slave-only to restore the default.
ptp slave-only
undo ptp slave-only
An OC can operate either as a master clock or a member clock.
This command is applicable only to OCs and is available only after you specify a PTP profile and a PTP clock node type.
You can execute the ptp force-state command to specify a subordinate port as a master port or passive port even if the OC operates as a member clock.
# Specify the clock node type as OC for the device. Configure the OC to operate only as a member clock.
[Sysname] ptp slave-only
ptp force-state
ptp mode
ptp profile
ptp source
Use ptp source to configure the source IP address for multicast PTP messages transported over IPv4 UDP.
Use undo ptp source to remove the specified source IP address for multicast PTP messages transported over IPv4 UDP.
ptp source ip-address [ vpn-instance vpn-instance-name ]
undo ptp source ip-address [ vpn-instance vpn-instance-name ]
No source IP address is configured for multicast PTP messages transported over IPv4 UDP.
ip-address: Specifies the source IP address for multicast PTP messages transported over IPv4 UDP.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance used for communication between the local device and the peer device. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the peer device belongs to the public network, do not specify this option.
This command takes effect only when PTP messages are transmitted over IPv4 UDP in multicast mode.
If a PTP-enabled Layer 3 Ethernet interface has been assigned to a VPN instance, you must specify the VPN instance in the ptp source ip-address vpn-instance vpn-instance-name command.
# Specify 3.5.1.5 as the source address for multicast PTP messages transported over IPv4 UDP.
[Sysname] ptp source 3.5.1.5
ptp mode
ptp profile
ptp syn-interval
Use ptp syn-interval to set the interval for sending Sync messages.
Use undo ptp syn-interval to restore the default.
ptp syn-interval interval
When the PTP profile is IEEE 1588 version 2, the interval argument value is 0 and the interval for sending Sync messages is 1 (20) second.
When the PTP profile is ITU-T G.8275.1 or ITU G.8275.2, the interval argument value is –4 and the interval for sending Sync messages is 1/16 (2-4) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending Sync messages. The value range for the interval argument is -4 to 6 for the IEEE 1588 version 2 and ITU-T G.8275.1 PTP profiles, and –5 to 0 for the ITU-T G.8275.2 PTP profile
Operating mechanism
The value of the interval at which the master node sends Sync messages depends on whether unicast negotiation is enabled.
· When unicast negotiation is disabled, the master node uses the value configured in the ptp syn-interval command on its interface as the interval to send Sync messages.
· When unicast negotiation is enabled, you must configure the interval on the request-port of the client. Then the client and server negotiates whether the server can send Sync messages to the client at that interval from the grant-port. If the negotiation succeeds, the grant-port sends Sync messages at the configured interval to the client. If the negotiation fails, the grant-port does not send Sync messages to the client.
# Set the Sync message sending interval to 2 (21) seconds on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ptp syn-interval 1
ptp mode
ptp profile
ptp sync-uncertain enable
Use ptp sync-uncertain enable to enable the device to notify the downstream nodes of its time synchronization state.
Use undo ptp sync-uncertain enable to disable the device from notifying the downstream nodes of its time synchronization state.
The device does not notify the downstream nodes of its time synchronization state.
By default, the device transfers only the locked and unlocked status of the upstream node to the downstream nodes, and does not transfer its locked or unlocked status to the downstream nodes.
After this command is configured, the device notifies the downstream nodes of its locked and unlocked status through the synchronizationUncertain flag in the announce messages. The downstream nodes do not synchronize to the device when they receive information that the device time is unlocked and synchronize to the device when they receive information that the device time is locked.
This command is available only after you specify a PTP profile and a PTP clock node type. The PTP profile must be IEEE 1588 version 2 or ITU-T G.8275.1.
# Enable the device to notify the downstream nodes of its time synchronization state.
[Sysname] ptp sync-uncertain enable
ptp mode
ptp profile
Use ptp technical-standard to specify a PTP technical standard.
Use undo ptp technical-standard to restore the default.
ptp technical-standard { oam | cmcc | unicom }
The default PTP technical standard applies.
oam: Specifies the OAM standard.
cmcc: Specifies the CMCC standard.
unicom: Specifies the Unicom standard.
Operating mechanism
Only the ITU-T G.8275.1 PTP profile supports the OAM standard and Unicom standard. The default values for clock source-related parameters such as accuracy, time class, time source, and offset (log variance) differ between OAM and Unicom standards.
Only the IEEE 1588 version 2 PTP profile supports the CMCC standard. Configuring this standard affects the actual effective clock class of the ToD clock source.
If you configure the IEEE 1588 version 2 PTP profile and specify the CMCC standard, the device supports conversion between ToD status information and the IEEE 1588 version 2 clock class, as required by the CMCC standard:
· If you configure the clock class for the ToD clock source by using the ptp clock-source command, the actual effective clock class of the ToD clock source is the set value.
· If you do not configure the clock class for the ToD clock source (using the default value of 187), the clock card will automatically convert between the status information carried in the ToD clock signal and the IEEE 1588 version 2 clock class as shown in the following table:
Table 14 ToD status information and IEEE 1588 version 2 clock class
ToD status information |
IEEE 1588 version 2 clock class |
0x00 = Normal |
6 |
0x01 = Time sync device (atomic clock) holdover |
7 |
0x02 = Unavailable |
255 |
0x03 = Time sync device (high-stability oscillator) holdover |
52 |
0x04 = Transmission carrier equipment holdover |
187 |
0x05 = Local rubidium clock holdover |
8 |
ToD status information not included in Table 14 will be converted to IEEE 1588 version 2 clock class 255. IEEE 1588 version 2 clock classes not included in Table 14 will be converted to ToD status 0x02.
This command is available only after you specify a PTP profile and a PTP clock type.
This command is mutually exclusive with the ptp clock-state enable command.
# Specify the Unicom PTP technical standard.
[Sysname] ptp technical-standard unicom
Parameters of Clock Attribute will be restored to the default values. Continue? [Y/N]:y
ptp clock-source
ptp mode
ptp profile
ptp time-offset
Use ptp time-offset to configure the PTP offset threshold and the number of times PTP time synchronization is suppressed.
Use undo ptp time-offset to restore the default.
ptp time-offset { suppression-count suppression-count | suppression-threshold threshold-value } *
undo ptp time-offset { suppression-count | suppression-threshold } *
The PTP offset threshold is 3000 nanoseconds, and PTP time synchronization is suppressed twice.
suppression-count suppression-count: Specifies the number of times PTP time synchronization is suppressed. The value is in the range of 2 to 80.
suppression-threshold threshold-value: Specifies the PTP time offset threshold, in nanoseconds. The value is in the range of 20 to 1000000.
This command is designed to prevent clock source jumps. With this command configured, the device can handle clock jumps effectively to ensure that time synchronization resumes after the clock stabilizes, avoiding errors caused by sudden clock changes.
Operating mechanism
After master-member relationships are established between the clock nodes, the master and member clock nodes exchange PTP messages and record the message transmit and receive time. Based on the timestamps, each member clock calculates the path delay and then gets the time offset between them and the master clock and adjusts their time accordingly for time synchronization with the master clock.
With this command configured, the device determines that a clock jump has occurred and pauses PTP synchronization if the clock is stable but the offset of the current sample exceeds threshold-value. The device uses the following rules to determine whether to synchronize the clock in the future:
· Normal synchronization—If the offset of the next sample is equal to or smaller than threshold-value, PTP resumes time synchronization.
· Pausing synchronization—If subsequent offsets remain greater than threshold-value, PTP stops time synchronization until the suppression count reaches the preset value. The device then determines that the master clock is stable. When the device receives the next PTP signal, the device synchronizes the time regardless of whether the offset value exceeds threshold-value.
As shown in Figure 1, assume that the values for suppression-count and threshold-value are set to 5 and 3, respectively. When the offset is less than or equal to 3, synchronization occurs. When a sudden clock change causes the offset to exceed 3, synchronization of the clock signal is stopped until with a maximum of suppression-count clock signals being paused for synchronization. At time points P0 through P5, the device does not perform time synchronization, because the offset value is greater than 3. At time point P6, the device performs time synchronization not whether the offset value exceeds threshold-value.
Figure 1 PTP clock source jump prevention
You can configure this command only when the PTP profile, PTP clock node type, and PTP domain are all specified.
# Set the PTP offset threshold to 5000 nanoseconds in system view.
[Sysname] ptp time-offset suppression-threshold 5000
ptp mode
ptp profile
Use ptp transport-protocol to specify the IPv4 UDP transport protocol for PTP messages.
Use undo ptp transport-protocol to restore the default.
The IEEE 1588 version 2 and ITU-T G.8275.1 PTP profiles transport PTP messages over IEEE 802.3/Ethernet.
The ITU-T G.8275.2 PTP profile transports PTP messages over IPv4 UDP.
udp: Specifies the IPv4 UDP transport protocol.
This command is available only after you specify a PTP profile and a PTP clock type. The ITU-T G.8275.1, and ITU G.8275.2 PTP profiles do not support this command.
# Specify the IPv4 UDP transport protocol for PTP messages on Ten-GigabitEthernet 3/1/1.
ptp mode
ptp profile
Use ptp unicast-destination to configure the destination IP address for unicast PTP messages transported over IPv4 UDP.
Use undo ptp unicast-destination to restore the default.
ptp unicast-destination ip-address
undo ptp unicast-destination ip-address
No destination IP address is configured for unicast PTP messages transported over IPv4 UDP.
ip-address: Specifies the destination IP address for unicast PTP messages transported over IPv4 UDP.
Specify a PTP profile and PTP clock node type before you execute this command. The ITU-T G.8275.1 PTP profile does not support this command.
When the PTP profile is ITU-T G.8275.2, you must configure this command.
This command takes effect only for unicast PTP messages transported over IPv4 UDP.
# Configure 10.10.10.2 as the destination address for unicast PTP messages transported over IPv4 UDP.
ptp mode
ptp profile
Use ptp unicast-negotiate to enable unicast negotiation.
Use undo ptp unicast-negotiate to disable unicast negotiation.
ptp unicast-negotiate { grant-port | request-port }
Unicast negotiation is disabled.
grant-port: Specifies the port as a grant-port.
request-port: Specifies the port as a request-port.
Under the networking environment where IEEE 1588 version 2 or ITU-T G.8275.2 runs, you can establish a PTP synchronization tree by specifying the request-ports and master-ports with this command. By default, the synchronization tree is established through dynamic election.
Operating mechanism
After this command is configured, the request-port initiates a connection request to the specific grant-port to establish a PTP link. They negotiate PTP parameters and exchange PTP messages to synchronize the client time to the server. To ensure a successful unicast negotiation and PTP clock synchronization, plan the network in advance and specify the ports on the member (client) clock nodes as request-ports and the ports on the master (server) clock nodes as grant-ports.
For unicast negotiation to take effect, you must execute also the ptp unicast-destination command.
Under the ITU-T G.8275.2 PTP profile, the ports on a T-TSC-P clock node cannot be specified as grant-ports.
Under the IEEE 1588 version 2 PTP profile, follow these restriction and guidelines when configuring unicast negotiation:
· For unicast negotiation to take effect, you must configure also the ptp transport-protocol udp command.
· The E2ETC, P2PTC, and P2PTC-OC devices do not support unicast negotiation.
· The ptp unicast-negotiate command is mutually exclusive with the ptp slave-only, ptp force-state, and ptp delay-mechanism p2p commands.
# Enable unicast negotiation on Ten-GigabitEthernet 3/1/1 and specify the port as a request-port.
[Sysname] ptp profile 1588v2
ptp mode
ptp profile
ptp slave-only
ptp force-state
ptp delay-mechanism
ptp utc
Use ptp utc to add or subtract one second from the UTC scale on the specified date.
Use undo ptp utc to restore the default.
ptp utc { leap59-date | leap61-date } date
undo ptp utc { leap59-date | leap61-date }
No second is added to or subtracted from the UTC scale.
leap59-date: Subtracts one second from the UTC time scale at the last minute (23:59) on the specified date.
leap61-date: Adds one second to the UTC time scale at the last minute (23:59) on the specified date.
date: Sets the date to adjust UTC, in the format of YYYY/MM/DD. The value range for YYYY and MM is 2000 to 2035 and 1 to 12, respectively. The value range for DD depends on the specified month. For the configuration to take effect, do not specify a date earlier than the current date.
Operating mechanism
UTC is based on International Atomic Time (TAI), a high-precision atomic coordinate time scale, and adjusted by leap seconds for synchronization with astronomical time.
UTC is constantly compared with UT1 (astronomical time, reflecting the earth's rotation). The International Bureau of Weights and Measures (BIPM) will notify to add or subtract one second from the UTC time scale at the last minute on a specific date (typically June 30 or December 31) to ensure that the difference between UTC and UT1 is within one second.
You can use this command to add or subtract one second from the UTC time on the specific date as published by BIPM.
This command takes effect only when it is configured on the master clock node and the local clock of the master clock node is the GM.
# Assume that the current date is August 8, 2016. Specify the BC clock node type for the device. According to information published by BIPM, add one second to the UTC time at 23:59:60 on December 31, 2016.
[Sysname] ptp utc offset 36
[Sysname] ptp utc leap61-date 2016/12/31
ptp mode
ptp profile
ptp utc offset
ptp utc offset
Use ptp utc offset to set the cumulative offset of UTC relative to TAI.
Use undo ptp utc offset to restore the default.
ptp utc offset utc-offset
undo ptp utc offset
The cumulative offset of UTC relative to TAI is 0 seconds.
utc-offset: Sets the cumulative offset of UTC relative to TAI, in seconds. The value is in the range of 0 to 999.
Operating mechanism
A time difference exists between UTC and TAI. Internet devices typically use the UTC time. To provide more accurate time, PTP also uses TAI. If the device acts as a subordinate clock node, it uses the UTC time and TAI time of the clock reference. If the device acts as the clock reference, it will calculate the TAI time based on the UTC time, and synchronize the UTC and TAI time to the subordinate clocks. TAI provided by the device = Current UTC + cumulative offset.
BIPM periodically publishes the cumulative offset of UTC relative to TAI. Use the value published by BIPM to configure this command.
# According to information published by BIPM, the cumulative offset of UTC relative to TAI is 37 seconds. Set the cumulative offset of UTC relative to TAI to 37 seconds.
[Sysname] ptp mode oc
[Sysname] ptp utc offset 37
ptp mode
ptp profile
ptp utc
ptp vlan
Use ptp vlan to specify a VLAN tag for PTP messages.
Use undo ptp vlan to restore the default.
ptp vlan vlan-id [ dot1p dot1p-value ]
undo ptp vlan [ dot1p ]
PTP messages do not have a VLAN tag.
vlan vlan-id: Specifies a VLAN by its ID. The value is in the range of 1 to 4094.
dot1p dot1p-value: Specifies an 802.1p precedence for PTP messages. The value is in the range of 0 to 7. The default value is 7 (the highest). The device uses the default precedence value of 7 for PTP messages no matter which value is specified.
# Specify VLAN 2 and set the 802.1p precedence to 6 for PTP messages.
[Sysname-Ten-GigabitEthernet3/1/1] ptp vlan 2 dot1p 6
ptp mode
ptp profile
reset ptp statistics
Use reset ptp statistics to clear PTP statistics.
reset ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears PTP statistics on all interfaces.
# Clear PTP statistics on Ten-GigabitEthernet 3/1/1.
<Sysname> reset ptp statistics interface ten-gigabitethernet 3/1/1
display ptp statistics
snmp-agent trap enable ptp
Use snmp-agent trap enable ptp to enable SNMP notification for the PTP module.
Use undo snmp-agent trap enable ptp to disable SNMP notification for the PTP module.
SNMP notification is enabled for the PTP module.
To be informed of important events of the PTP module, enable SNMP notification for the PTP module.
The notifications generated for the PTP module will be sent to the SNMP module of the device. Configure SNMP notification parameters for the notifications to be output as needed.
# Enable SNMP notification for the PTP module.
[Sysname] snmp-agent trap enable ptp
display snmp-agent trap-list (SNMP commands in Network Management and Monitoring Command Reference)
