- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Fast log output commands
- 22-Flow log commands
- 23-Information center commands
- 24-Packet capture commands
- 25-Flow monitor commands
- 26-NetAnalysis commands
- 27-KPI data collection commands
| 25-Flow monitor commands | 117.29 KB |
display flow-monitor
Use display flow-monitor to display information about flow monitor entries.
In standalone mode:
display flow-monitor [ invalid ] [ verbose ] [ { ip | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-address | interface interface-type interface-number | source source-address ] * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display flow-monitor [ invalid ] [ verbose ] [ { ip | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-address | interface interface-type interface-number | source source-address ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
invalid: Specifies illegitimate flow monitor entries. If you do not specify this keyword, this command displays information about legitimate flow monitor entries.
verbose: Displays detailed information about flow monitor entries. If you do not specify this keyword, this command displays brief information about flow monitor entries.
ip: Specifies IP flow monitor entries.
mpls: Specifies MPLS flow monitor entries.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 10. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 10. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 10. The value range for the label-value3 argument is 0 to 1048575.
destination destination-ip: Specifies a destination IP address in dotted-decimal notation.
source source-ip: Specifies a source IP address in dotted-decimal notation.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays information about flow monitor entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about flow monitor entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
State |
State of the flow monitor table: · Fixed—The table has been frozen. · Unfixed—The table has not been frozen. This field is not displayed for illegitimate flow monitor entries. |
Type |
Flow type: · IP—IP flow. · MPLS—MPLS flow without IP options. · IP&MPLS—MPLS flows with IP options. |
Source |
Source IP address of the flow. |
Destination |
Destination IP address of the flow. |
Protocol |
IP protocol number of the flow. |
Direction |
Flow direction: · Inbound. · Outbound. |
Interface that the flow passes through. |
VPN |
VPN to which the flow belongs. This field is empty if the flow does not belong to any VPN. |
Labels |
MPLS label list. The list supports a maximum of three labels. |
Packets |
Number of packets in the flow. |
Bytes |
Number of bytes in the flow. |
Entry created time |
Time when the flow monitor entry was created. |
First packet arrived |
Time when the first packet in the flow arrived. If no matching packet arrives, this field displays N/A. |
Last packet arrived |
Time when the last packet in the flow arrived. If no matching packet arrives, this field displays N/A. |
flow-monitor
Use flow-monitor to enable flow monitor.
Use undo flow-monitor to disable flow monitor.
flow-monitor { inbound | outbound }
undo flow-monitor { inbound | outbound }
Flow monitor is disabled.
inbound: Enables flow monitor for incoming traffic.
outbound: Enables flow monitor for incoming traffic.
The hardware NetStream feature is mutually exclusive with the flow monitor feature. Enabling the hardware NetStream feature after configuring the flow monitor feature will temporarily disable the flow monitor feature. Disabling the hardware NetStream feature will automatically enable the flow monitor feature.
# Enable flow monitor for incoming traffic.
[Sysname] flow-monitor inbound
ip netstream hardware enable (Network Management and Monitoring Command Reference)
flow-monitor add ip
Use flow-monitor add ip to add an IP flow monitor entry to the flow monitor table.
In standalone mode:
flow-monitor add ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
flow-monitor add ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
No IP flow monitor entries exist.
ip: Specifies the IP flow monitor entry.
source source-address: Specifies the source IP address in dotted-decimal notation.
destination dest-address: Specifies the destination IP address in dotted-decimal notation.
protocol protocol-number: Specifies the protocol number in the range of 0 to 255. Common protocols include ICMP (1), IGMP (2), TCP (6), and UDP (17).
interface interface-type interface-number: Specifies the interface that the flow passes through. The interface-type interface-number arguments specify an interface by its type and number.
inbound: Specifies the incoming traffic.
outbound: Specifies the outgoing traffic.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the flow belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the flow is on the public network, do not specify this option.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command adds the IP flow monitor entry to all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command adds the IP flow monitor entry to all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If you specify an existing illegitimate entry, the system adds the entry to the flow monitor table and deletes the entry from the illegitimate entry list.
# (In standalone mode.) Add an IP flow monitor entry to the specified slot.
[Sysname] flow-monitor add ip source 1.1.1.1 destination 2.2.2.2 protocol 6 interface ten-gigabitethernet 3/1/1 inbound slot 1
flow-monitor add mpls
Use flow-monitor add mpls to add an MPLS flow monitor entry to the flow monitor table.
In standalone mode:
flow-monitor add mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
flow-monitor add mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
No MPLS flow monitor entries exist.
mpls: Specifies the MPLS flow monitor entry.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command adds the MPLS flow monitor entry to all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command adds the MPLS flow monitor entry to all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Add an MPLS flow monitor entry to the specified slot.
[Sysname] flow-monitor add mpls 1 20 2 23 3 12 source 1.1.1.1 destination 2.2.2.2 protocol 6 interface ten-gigabitethernet 3/1/1 inbound slot 1
flow-monitor delete ip
Use flow-monitor delete ip to delete an IP flow monitor entry.
In standalone mode:
flow-monitor delete ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
flow-monitor delete ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
protocol protocol-number: Specifies the protocol number in the IPv4 header, in the range of 0 to 255. Common protocols include ICMP (1), IGMP (2), TCP (6), and UDP (17).
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command deletes the IP flow monitor entry from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes the IP flow monitor entry from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Delete an IP flow monitor entry from the specified slot.
[Sysname] flow-monitor delete ip source 1.1.1.1 destination 2.2.2.2 protocol 6 interface ten-gigabitethernet 3/1/1 inbound slot 1
flow-monitor delete mpls
Use flow-monitor delete mpls to delete an MPLS flow monitor entry.
In standalone mode:
flow-monitor delete mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
flow-monitor delete mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command deletes the MPLS flow monitor entry from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes the MPLS flow monitor entry from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Delete an MPLS flow monitor entry from the specified slot.
[Sysname] flow-monitor delete mpls 1 23 2 20 3 12 source 1.1.1.1 destination 2.2.2.2 protocol 6 interface ten-gigabitethernet 3/1/1 inbound slot 1
flow-monitor fixup
Use flow-monitor fixup to freeze the flow monitor table and set the table to fixed state.
Use undo flow-monitor fixup to set the flow monitor table to unfixed state and delete all illegitimate flow monitor entries.
In standalone mode:
flow-monitor fixup [ slot slot-number [ cpu cpu-number ] ]
undo flow-monitor fixup [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
flow-monitor fixup [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo flow-monitor fixup [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The flow monitor table is in unfixed state.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command freezes the flow monitor tables on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command freezes the flow monitor tables on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Freeze the flow monitor table in the specified slot.
[Sysname] flow-monitor fixup slot 1
reset flow-monitor entry
Use reset flow-monitor entry to delete flow monitor entries.
In standalone mode:
reset flow-monitor entry [ invalid ] [ ip | mpls ] [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ] [ source slot source-slot-number [ cpu source-cpu-number ] ]
In IRF mode:
reset flow-monitor entry [ invalid ] [ ip | mpls ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source chassis source-chassis-number slot source-slot-number [ cpu source-cpu-number ] ]
invalid: Specifies illegitimate flow monitor entries. If you do not specify this keyword, this command deletes fixed or unfixed flow monitor entries.
interface interface-type interface-number: Specifies the interface that the traffic passes through. The interface-type interface-number arguments specify an interface by its type and number.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command deletes flow monitor entries from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes flow monitor entries from all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
source: Specifies the source card from which the traffic is mirrored. Specify this keyword to delete the flow monitor entries generated based on the mirrored traffic when the source card is removed.
slot source-slot-number: Specifies a card by its slot number. This command deletes flow monitor entries that are generated based on the traffic passing through the card. (In standalone mode.)
chassis source-chassis-number slot source-slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This command deletes flow monitor entries that are generated based on the traffic passing through the card. (In IRF mode.)
cpu source-cpu-number: Specifies a CPU by its number. This command deletes flow monitor entries that are generated based on the traffic passing through the CPU. This option is available only if multiple CPUs are available on the specified slot.
The interface and source keywords are mutually exclusive. If you specify one of the two keywords, this command can delete flow monitor entries as follows:
· Unfixed entries from an unfrozen flow monitor table.
· Illegitimate and fixed entries from a frozen flow monitor table.
If you specify neither of the two keywords, this command can delete flow monitor entries as follows:
· Illegitimate entries from a frozen flow monitor table.
# (In standalone mode.) Delete all illegitimate flow monitor entries from the specified slot.
<Sysname> reset flow-monitor entry invalid slot 1
reset flow-monitor statistics
Use reset flow-monitor statistics to clear flow monitor statistics.
In standalone mode:
reset flow-monitor statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset flow-monitor statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command clears flow monitor statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears flow monitor statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Clear flow monitor statistics in the specified slot.
<Sysname> reset flow-monitor statistics slot 1
