12-WLAN Advanced Features Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1603Pxx)-6W10012-WLAN Advanced Features Configuration Guide
10-WDRC configuration
10-WDRC configuration 53.96 KB
Configuring WDRC
About WDRC
The WLAN Data Report Control (WDRC) module centrally manages wireless data reporting and can forward data to integrated platforms for further analysis and processing.
Restrictions: Hardware compatibility with WDRC
Hardware series
Model
Product code
Feature compatibility
WX3500X series
·     WX3510X
·     WX3520X
·     WX3540X
·     EWP-WX3510X
·     EWP-WX3520X
·     EWP-WX3540X
Yes
WX3500X-E series
WX3508X-E
EWP-WX3508X-E
Yes
Access controller modules
LSEM1WBC120G0
LSEM1WBC120G0
Yes
Hardware series
Model
Product code
WX3500X-G series
WX3520X-G
EWP-WX3520X-G
No
Hardware series
Model
Product code
WX3800X series
·     WX3820X
·     WX3840X
·     EWP-WX3820X
·     EWP-WX3840X
Yes
Configuring APs to report O&M data to the server
Typically, APs report collected statistics to the AC, and the AC reports the statistics to the server at specific intervals. The reported statistics cannot display the running status of the network in real time. To resolve this issue, perform this task to enable APs to directly report O&M data to the specified server at a set interval.
Set the report interval based on the actual network conditions. Setting a short interval causes significant pressure on the server, and setting a long interval cannot display the network conditions in real time.
2.     Specify the IP address of the server to which APs report O&M data.
wdrc report server { ip ipv4-address | ipv6 ipv6-address } [ port port-number ]
By default, the IP address of server to which APs report O&M data is not specified.
3.     Set the interval at which APs report O&M data to the server.
wdrc report interval interval
By default, APs report O&M data to the server at intervals of 60 seconds.
