12-WLAN Advanced Features Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1603Pxx)-6W10012-WLAN Advanced Features Configuration Guide
01-WLAN optimization configuration
01-WLAN optimization configuration 242.57 KB
Configuring WLAN optimization· 1
About WLAN optimization· 1
Restrictions and guidelines: WLAN optimization configuration· 1
Configuring rejection of weak-signal clients· 1
Configuring AP-triggered client reassociation· 2
Configuring hidden node protection· 2
Configuring multicast and broadcast buffering· 3
Configuring the EMR algorithm·· 4
Configuring channel reuse· 4
Enabling or disabling an AP to ignore weak signals· 5
Configuring roaming navigation· 6
Configuring packet receiving timing adjustment 6
Enabling or disabling an AP to decrease the sleep interval of clients· 7
Configuring channel sharing· 7
Setting the maximum number of probe response attempts· 8
Specifying a power supply mode for an AP to adjust the transmit power 8
Configuring the narrow bandwidth feature· 9
Configuring transmit power adjustment 9
Configuring per-packet transmit power control 10
Configuring 802.11n packet suppression· 11
Configuring fast forwarding of AP-to-client data frames· 11
Setting the maximum retransmissions and retries for an EAPOL-Key packet 12
Configuring broadcast and multicast packet control 12
Configuring broadcast and multicast packet rate limiting· 14
Enabling upstream ARP packet suppression‌· 15
Enabling the AP to reply ARP requests of clients on behalf of the gateway‌· 15
Configuring client fast keepalive‌· 16
Configuring software retransmission· 17
Enabling client inspection· 17
Configuring the packet DSCP precedence‌· 18
Specifying the flow scheduling mode for an AP group· 18
Enabling APs to permit uplink STP BPDUs· 19
Proper channel planning and power control policies during WLAN deployment are important for good performance. However, in live WLAN networks, channel overlapping, collisions, and interference can easily occur because the none-overlapping channels are limited but the number of WLAN devices always increases.
The WLAN optimization features can help you improve the quality and stability of a WLAN.
Use WLAN optimization commands under the guidance of H3C Support.
There is no fixed combination of features for optimizing a specific WLAN. Select and adjust the features based on the application effect and WLAN performance.
The overall performance of a WLAN is determined by the network architecture as well as channel and power planning. Therefore, the WLAN optimization features cannot significantly increase the performance of a WLAN. In practice, if the features can improve the WLAN performance by 3%, the optimization is considered successful.
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
To avoid client access failures, set an appropriate RSSI value when enabling this feature.
2.     Enter AP view or an AP group's AP model view.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter an AP group's AP model view:
wlan ap-group group-name
ap-model ap-model
3.     Enter radio view.
radio radio-id
4.     Configure rejection of weak-signal clients.
option client reject { disable | enable [ rssi rssi-value ] }
By default:
¡     In radio view, a radio uses the configuration in an AP group's radio view.
¡     In an AP group's radio view, rejection of weak-signal clients is disabled.
A client with a low signal strength can roam to another AP only when its signal strength is lower than the manufacturer-defined signal strength for triggering roaming. Therefore, the client cannot obtain good network experience and service quality.
This feature enables an AP to send unsolicited deauthentication frames to a client when the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
To avoid unexpected client logoff, set an appropriate RSSI value when enabling this feature.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure AP-triggered client reassociation.
option client reconnect { disable | enable [ rssi rssi-value ] [ interval interval ] }
By default:
¡     In an AP group's radio view, AP-triggered client reassociation is disabled.
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
This feature takes effect only on 802.11g, 802.11n, and 802.11ac clients.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure hidden node protection.
option client hide-node-protection { disable | enable }
By default:
¡     In an AP group's radio view, hidden node protection is disabled.
With this feature enabled, the AC stops sending broadcast and multicast packets and buffers them if an associated client is in sleep state. This mechanism affects the performance of real-time multicast applications.
With this feature disabled, the AC directly sends all broadcast and multicast packets regardless of whether an associated client is in sleep state.
As a best practice, set the power management parameter to the maximum value on wireless clients before you disable this feature.
Disabling this feature disables clients in sleep state from receiving some broadcast and multicast packets.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure multicast and broadcast buffering.
option broadcast-multicast-buffer { disable | enable [ limit limit ] }
By default:
¡     In an AP group's radio view, multicast and broadcast buffering is enabled.
Each 802.11 protocol supports a set of transmission rates. For example, 802.11g supports rates 1, 2, 5.5, 11, 6, 9, 12, 18, 24, 36, 48, and 54. A wireless device dynamically selects a set of transmission rates based on the channel quality and history data.
Perform this task to enable the ensure minimum rate (EMR) algorithm to ensure the connection reliability.
This feature might decrease the network throughput.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure the EMR algorithm.
option rate-algorithm emr { disable | enable }
By default:
¡     In an AP group's radio view, the EMR algorithm is disabled. A radio uses a rate that ensures the maximum throughput.
This feature enables an AP to ignore packets with a signal strength lower than the specified channel reuse level. This mechanism enables the AP to obtain more radio resources and improves the performance of APs working on the same channel.
Enabling this feature might add hidden nodes.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure channel reuse.
option channel-reuse-optimization { disable | enable level level }
By default:
¡     In an AP group's radio view, channel reuse is disabled.
An AP determines that the channel is still occupied even though the signals it detects are weak, and does not forward frames any more. Ignoring packets with a signal strength lower than the specified RSSI threshold can increase frame sending and receiving efficiency.
Ignoring weak signals might cause collisions and interference among devices on the same channel.
To avoid packet receiving failures, set an appropriate RSSI value when enabling this feature.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Enable or disable an AP to ignore weak signals.
option signal-ignore { disable | enable rssi rssi-value }
By default:
¡     In an AP group's radio view, a radio does not ignore weak signals.
802.11 protocols do not provide any client roaming control mechanisms and some clients cannot actively roam to APs with better signal strength.
Perform this task to decrease the transmit power for beacons or probe responses of an AP to enable clients to roam to APs with better signal strength.
If you set the transmit power for beacons or probe responses, the system uses the default transmit power to transmit other packets.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure roaming navigation.
option roam-navigation { disable | enable rssi rssi-value { beacon-power power-value | probe-response-power power-value } }
By default:
¡     In an AP group's radio view, roaming navigation is disabled.
This feature enables an AP to adjust the timing for receiving packet to achieve the optimal receiving effect.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure packet receiving timing adjustment.
option rx-opportunity-optimize { disable | enable }
By default:
¡     In an AP group's radio view, packet receiving timing adjustment is disabled.
A wireless client in sleep state listens for traffic indication map (TIM) information in beacon frames to determine whether the associated AP has buffered packets for it. This feature enables an AP to modify the TIM information in beacon frames to decrease the sleep interval of wireless clients to improve transmission efficiency.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Enable or disable an AP to decrease the sleep interval of clients.
option keep-active { disable | enable }
By default:
¡     In an AP group's radio view, a radio does not decrease the sleep interval of clients.
When this feature is enabled, an AP sends or does not send packets according to whether the detected signals are stronger or weaker than the specified power level. This mechanism avoids channel collision and interference.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure channel sharing.
option channel-share { disable | enable power-level power-level }
By default:
¡     In an AP group's radio view, channel sharing is enabled.
Perform this task to reduce the number of probe responses sent by a radio to save resources and improve network performance.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Set the maximum number of probe response attempts.
option probe-response-try { disable | enable number }
By default:
¡     In an AP group's radio view, the number of probe response attempts is not limited.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Specify a power supply mode for an AP to adjust the transmit power.
option power-supply { disable | enable { local | poe | poeplus } }
By default:
¡     In an AP group's radio view, the transmit power corresponding to the local power supply mode is used.
This feature is applicable to the communication based train control (CBTC) system that is not sensitive to bandwidth but sensitive to signal reliability.
Perform this task to limit the bandwidth in subways to meet the requirements of the CBTC system. When the bandwidth decreases from 20 MHz to 5 MHz, the signal strength is greatly improved. The low bandwidth also reduces the risks of signal interference.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure the narrow bandwidth feature.
option subway-band-width { disable | enable { 5 | 10 } }
By default:
¡     In an AP group's radio view, the narrow bandwidth feature is disabled.
This feature enables an AP to use the adjusted transmit power to transmit packets.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure transmit power adjustment.
option capacity-adjust { disable | enable [ all ] { increase | decrease } value }
By default:
¡     In an AP group's radio view, transmit power adjustment is disabled.
This feature enables an AP to dynamically perform transmit power control on a per packet basis. For example, the AP reduces the transmit power when it sends packets to a client with high RSSI. This feature can reduce power consumption, radiation, and interference and improve user experience.
This feature is not applicable to 5 GHz radios of 802.11ac APs.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure per-packet transmit power control.
option tpc { disable | enable [ minpower minpower | powerstep powerstep | rssistep rssistep | rssithreshold rssithreshold ] }
By default:
¡     In an AP group's radio view, per-packet transmit power control is disabled.
Perform this task to suppress 802.11n packets by defining the maximum number of aggregated MPDUs and the maximum A-MPDU length. The two thresholds take effect at the same time. If either threshold is reached, the AP stops aggregation and sends the A-MPDU.
This feature prevents 802.11n clients from affecting the performance of 802.11a and 802.11b/g clients.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure 802.11n packet suppression.
option dot11n-restraint { disable | enable packet-number packet-number packet-length packet-length } [ inbound | outbound ] [ tid tid-number ]
By default:
¡     In an AP group's radio view, 802.11n packet suppression is disabled.
This feature enables an AP to forward data frames to clients without extra processing (such as verification and counting) to improve processing efficiency.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure fast forwarding of AP-to-client data frames.
option client fast-forwarding { disable | enable level level-value }
By default:
¡     In an AP group's radio view, the default setting on the AP is used.
In Robust Security Network Association (RSNA) authentication, an AP and a client use EAPOL-Key packets in the four-way handshake to negotiate the keys. After that, the AP and the client periodically exchange EAPOL-Key packets to update the keys.
During key negotiation or update, the AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
The system starts to count the retries when the maximum number of retransmissions is reached.
For more information about RSN key negotiation or update, see WLAN user security configuration in WLAN Security Configuration Guide.
To ensure successful RSN key negotiation or update, you can increase the maximum number of retransmissions and the maximum number of retries for an EAPOL-Key packet.
2.     Enter service template view.
wlan service-template service-template-name
3.     Set the maximum number of retransmissions for an EAPOL-Key packet and the retransmission interval.
option 4-way-handshake resend max-count [ interval interval ]
By default, the maximum number of retransmissions for an EAPOL-Key packet is three, and the retransmission interval is 300 milliseconds.
4.     Set the maximum number of retries for an EAPOL-Key packet and the retry interval.
option 4-way-handshake retry max-count [ interval interval ]
By default, the maximum number of retries for an EAPOL-Key packet is three, and the retry interval is 5 seconds.
After this feature is enabled in an IPv4 network, the AP performs the following tasks for the requests received from the AC:
·     Answers ARP requests.
·     Discards DHCP requests.
·     Forwards other basic IPv4 broadcast packets and multicast packets through radio interfaces.
After this feature is enabled in an IPv6 network, the AP performs the following tasks for the requests received from the AC:
·     Discards RS messages and DHCPv6 requests.
·     Forwards RA messages through unicast.
·     Answers NS messages.
·     Forwards other basic IPv6 broadcast packets and multicast packets through radio interfaces.
This feature is applicable only when software forwarding is used.
2.     Enter AP view or AP group view.
¡     Enter AP view.
wlan ap ap-name
¡     Enter AP group view.
3.     Configure an AP to discard broadcast and multicast packets.
rrop anti-bmc default-action deny
By default:
¡     In AP view, an AP uses the configuration in AP group view.
¡     In AP group view, an AP forwards broadcast and multicast packets through radio interfaces.
4.     Configure an AP to discard IPv6 multicast packets.
rrop anti-bmc protocol ipv6 deny
By default:
¡     In AP group view, an AP takes the default action specified by the rrop anti-bmc default-action command on IPv6 multicast packets.
5.     Configure basic broadcast and multicast packet control.
rrop anti-bmc network { disable | { ipv4-simple | ipv6-simple | ipv4-and-ipv6-simple } enable }
By default:
¡     In AP view, if an AP group is configured, an AP uses the configuration in AP group view. If no AP group is configured, an AP uses the configuration in system view.
¡     In AP group view, an AP uses the configuration in system view.
¡     In system view, basic broadcast and multicast packet control is enabled.
6.     (Optional.) Configure the action to take on ARP packets.
rrop anti-bmc protocol arp mode { proxy-reply | unicast-forward }
By default:
¡     In system view, APs convert ARP packets to unicast packets and then forward them.
7.     (Optional.) Configure the action to take on ND packets.
rrop anti-bmc protocol nd mode { proxy-reply | unicast-forward }
By default:
¡     In system view, APs convert ND packets to unicast packets and then forward them.
Perform this task to rate limit uplink and downlink broadcast and multicast packets. Downlink packets refer to broadcast and multicast packets sent from APs to clients. Uplink packets refer to broadcast and multicast packets sent from APs to the gateway devices.
¡     Enter AP view.
wlan ap ap-name
3.     Configure downlink broadcast or multicast packet rate limiting.
rrop anti-bmc { broadcast | multicast } rate-limit { disable | enable }
By default:
¡     In AP group view, downlink broadcast or multicast packet rate limiting is disabled.
4.     Set the maximum number of broadcast or multicast packets that an AP can send per second.
rrop anti-bmc { broadcast | multicast } rate-limit pps max-pps
By default:
¡     In AP group view, the maximum number of broadcast or multicast packets that an AP can send per second is not specified.
5.     Configure uplink broadcast or multicast packet rate limiting.
¡     In AP view or AP group view:
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit { disable | enable }
¡     In system view:
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit enable
By default:
¡     In system view, rate limiting is disabled for uplink broadcast or multicast packets.
6.     Set the maximum number of uplink broadcast or multicast packets that an AP can send per second.
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit pps max-pps
By default:
¡     In system view, the maximum number of uplink broadcast or multicast packets that an AP can send per second is not specified.
Perform this task to protect APs against ARP flooding attacks. If the number of ARP packets that a client sends to an AP in one second reaches the specified threshold, the AP discards all ARP packets from the client within the specified suppression period.
This feature does not take effect on ARP requests for the gateway.
¡     Enter AP view.
wlan ap ap-name
3.     Enable upstream ARP packet suppression.
rrop ul-arp attack-suppression { disable | enable [ threshold threshold-value ] [ block-time time ] }
By default:
¡     In system view, upstream ARP packet suppression is disabled.
Perform this task to enable the AP to reply ARP requests of clients on behalf of the gateway. If the MAC address of the gateway changes during a reply period, ARP failures might occur. To resolve this issue, you can specify a limit for the number of ARP requests that the AP can reply on behalf of the gateway in a reply period. When the number of ARP requests that the AP has replied reaches the limit, the AP will forward an ARP request to the gateway and perform either of the following tasks:
·     If the gateway replies to the ARP request, the AP starts a new reply period with the new MAC address of the gateway.
·     If the gateway does not reply to the ARP request, the AP starts a new reply period with the original MAC address of the gateway.
As a best practice to reduce the gateway's service load, enable this feature when the gateway's service load is heavy or the network condition is poor.
¡     Enter AP view.
wlan ap ap-name
3.     Enable the AP to reply ARP requests of clients on behalf of the gateway.
rrop arp ap-proxy-gateway { disable | enable [ count count ] }
By default:
¡     In system view, the AP does not reply ARP requests of clients on behalf of the gateway.
The client keepalive feature enables an AP to send keepalive packets to clients at the specified interval to determine whether the clients are online. To quickly determine whether clients are online and save radio resources, configure this feature to set the maximum number of keepalive packets that an AP can send to a client. The AP logs off a client if it does not receive any replies from the client after sending the specified number of keepalive packets to the client.
This feature is mainly used in scenarios with high client mobility. If the network quality is poor, reduce the maximum number of keepalive packets that an AP can send to a client. As a best practice, use the default setting in scenarios with stable clients.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter AP group AP model view.
ap-model ap-model
radio radio-id
4.     Configure the client fast keepalive feature.
rrop client fast-keep-alive { disable | enable [ count count-value ] }
By default:
¡     In radio view, a radio uses the configuration in the AP group's radio view.
¡     In an AP group's radio view, the client fast keepalive feature is enabled.
Perform this task to configure software retransmission and set the maximum number of software retransmissions for the specified type of packets.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Enable software retransmission and set the maximum number of software retransmissions.
rrop software-retry { unicast [ eap ] | broadcast-multicast } enable count count
By default:
¡     In an AP group's radio view, the maximum number of software retransmissions varies by device model.
The client inspection feature enables you to view information about packets exchanged and time consumed in each stage of the client association process.
In the current software version, the client inspection feature supports only client association, client association failure, and IP address lease extension events.
¡     Enter AP view.
wlan ap ap-name
3.     Enable client inspection.
wlan client inspect enable
By default, client inspection is disabled.
Perform this task to configure the DSCP precedence for TCP or UDP packets with the specified port numbers. A greater DSCP precedence value represents a higher packet priority.
¡     Enter AP view.
wlan ap ap-name
3.     Specify a DSCP value for TCP packets.
rrop traffic-policy priority tcp port-num-list dscp value
By default:
¡     In AP group view, no DSCP value is specified for TCP packets.
4.     Specify a DSCP value for UDP packets.
rrop traffic-policy priority udp port-num-list dscp value
By default:
¡     In AP group view, no DSCP value is specified for UDP packets.
After you specify the AP group-based flow scheduling mode, the AC calculates the available total bandwidth based on factors such as channel usage, maximum speed, and number of clients. The AC then allocates available bandwidth to the clients in the AP group based on the mode. The following modes are available:
·     Balanced mode—The bandwidth is evenly distributed among the clients.
·     Quick-speed mode—Clients compete for bandwidth based on their own traffic.
·     Intelligent mode—The bandwidth is evenly distributed among the clients. Idle clients allocate their idle bandwidth to high-traffic clients based on an algorithm while ensuring their own bandwidth. You can manually set the threshold for enabling the intelligent mode, as well as the maximum and minimum values for client bandwidth.
As a best practice, use the balanced mode in scenarios where fairness must be ensured, such as office environments. In scenarios with a small number of clients or where the performance of high-traffic clients must be ensured, use the high-speed mode. In scenarios with a large number of clients and a significant number of idle clients, use the intelligent mode to improve the bandwidth usage.
This feature has a lower priority than radio-based client rate limit. When both features are configured, radio-based client rate limit configured by using the client-rate-limit enable command takes effect.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Specify the flow scheduling mode for the AP group.
rrop flow-schedule mode [ balanced | quick-speed | intelligent [ channel-usage-threshold threshold-value | max max-value | min min-value ] ]
By default:
¡     In radio view, an AP uses the configuration in AP group view.
¡     In an AP group's radio view, the quick-speed flow scheduling mode is used for an AP group.
In most network deployments, wireless clients are located at the network edge and do not participate in STP calculations. By default, APs discard BPDUs sent by clients to the wired network to prevent client BPDUs from affecting the network-wide STP calculations.
With this feature enabled, APs permit transmission of client BPDUs to the wired network.
This feature does not take effect on STP BPDUs in mesh networks.
2.     Enable APs to permit uplink STP BPDUs.
rrop ul-bpdu forward enable
By default, this feature is disabled and APs discard uplink STP BPDUs.
