- 12-WLAN Advanced Features Configuration Guide
- 01-WLAN optimization configuration
- 02-Hotspot 2.0 configuration
- 03-WLAN probe configuration
- 04-WSA configuration
- 05-Wireless location configuration
- 06-WLAN process maintenance configuration
- 07-WLAN mesh configuration
- 08-Bonjour gateway configuration
- 09-WLAN fast forwarding configuration
- 10-WDRC configuration
| 09-WLAN fast forwarding configuration | 55.04 KB |
Configuring WLAN fast forwarding
Restrictions: Hardware compatibility with WLAN fast forwarding
Restrictions and guidelines: WLAN fast forwarding configuration
Display and maintenance commands for WLAN fast forwarding
About WLAN fast forwarding
WLAN fast forwarding uses both software and hardware to enhance forwarding performance. Software fast forwarding enables an AC to perform concurrent forwarding by using the multi-core CPU and the 5-tuple table. The AC learns the source IP, source port, destination IP, destination port, and protocol during forwarding and uses high-speed buffer technology to save the information in the 5-tuple table.
In hardware fast forwarding, an AC performs software fast forwarding and uses the embedded FPGA chip to perform line-speed forwarding.
Hardware series |
Model |
Product code |
Feature compatibility |
WX3500X series |
· WX3510X · WX3520X · WX3540X |
· EWP-WX3510X · EWP-WX3520X · EWP-WX3540X |
No |
WX3500X-E series |
WX3508X-E |
EWP-WX3508X-E |
No |
Access controller modules |
LSEM1WBC120G0 |
LSEM1WBC120G0 |
Yes |
Hardware series |
Model |
Product code |
WX3500X-G series |
WX3520X-G |
EWP-WX3520X-G |
No |
Hardware series |
Model |
Product code |
WX3800X series |
· WX3820X · WX3840X |
· EWP-WX3820X · EWP-WX3840X |
No |
Only ACs embedded with the FPGA chip support hardware fast forwarding.
1. Enter system view.
2. Enable WLAN fast forwarding.
wlan fast-forwarding enable
By default, WLAN fast forwarding is enabled.
3. Set the WLAN fast forwarding mode.
wlan fast-forwarding mode { hardware | software }
By default, the WLAN fast forwarding mode is hardware.
Task |
Command |
Display WLAN fast forwarding status. |
display wlan fast-forwarding status |
