06-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10006-Layer 3—IP Routing Command Reference
09-IPv6 static routing commands
09-IPv6 static routing commands 197.89 KB
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all IPv6 static routes for the public network.
CAUTION
CAUTION:
This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network.
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
      NibID: 0x21000000           Sequence: 0
       Type: 0x41                  Flushed: Yes
        Age: 00h01m50s            FlushCnt: 1
   UserKey0: 0x0                   VrfNthp: 0
   UserKey1: 0x0                   Nexthop: 2::3
   UserKey2: 0x0                   IFIndex: 0x10001
   UserKey3: 0x0                 LocalAddr: ::
   TopoNthp: Invalid               ExtType: 0x0
      Color: 0                      COFlag: 0x0
     LinkID: 0x0
   SIDIndex: 0x0                   SRPName:
 OriNexthop: ::               ExtBandwidth: 0
RemoteDevID: 0
      NibID: 0x21000001           Sequence: 1
   UserKey1: 0x0                   Nexthop: 3::4
   UserKey2: 0x0                   IFIndex: 0x10002
     LinkID: 0x0
RemoteDevID: 0
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the RIB.
Age
Elapsed time since the next hop information was last updated.
FlushCnt
Number of times to flush to the RIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
TopoNthp
Index of the topology that contains the next hop.
This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies.
ExtType
NIB extension type.
Color
Color extended community attribute.
COFlag
Flag of the color extended community attribute.
LinkID
Link ID of the SDWAN TTE connection.
SIDIndex
SID index value.
SRPName
SR-MPLS TE policy name.
OriNexthop
Original next hop address of the route.
If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message.
ExtBandwidth
Link bandwidth attribute value from BGP. If the link bandwidth attribute value from BGP is not obtained, this field displays 0.
RemoteDevID
Device ID of the remote device corresponding to the next hop, which is the device ID of the remote leaf device. If the remote device ID does not exist, this field displays 0.
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
     LinkID: 0x0
RemoteDevID: 0
     RefCnt: 1                 FlushRefCnt: 0
       Flag: 0x12                  Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 2::3
  RelyDepth: 2                 RealNexthop: ::
  Interface: NULL0               LocalAddr: ::
  TunnelCnt: 0                         Vrf: default-vrf
   TunnelID: N/A                  Topology:
     Weight: 0                       Flags: 0x0
SRPolicyNID: 4294967295        SRInterface:
ColorWeight: 0                     Locator: N/A
 OrigLinkID: 0x0                RealLinkID: 0x0
     LinkID: 0x0
RemoteDevID: 0
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 3::4
  RelyDepth: 1                 RealNexthop: ::
  Interface: Vlan11              LocalAddr: ::
NibID
ID of the NIB.
Sequence
Type of the NIB.
Flushed
Age
FlushCnt
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
TopoNthp
ExtType
NIB extension type.
Color
COFlag
LinkID
SIDIndex
SID index value.
SRPName
OriNexthop
ExtBandwidth
RemoteDevID
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
ExtFlag
Extended flag of the next hop.
Flags
Flags of the detailed next hop.
SRPolicyNID
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion.
SRInterface
Output interface of the route obtained from the SR-MPLS TE policy through route recursion.
ColorWeight
Weight value of the color attribute in the SR-MPLS TE policy.
Locator
IPv6 prefix of the locator to which the SID belongs.
If no locator is available, this field displays N/A.
OrigLinkID
Original link ID of the SDWAN TTE connection.
RealLinkID
Real link ID of the SDWAN TTE connection.
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv6 static routing table information for the public network.
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
       NibID: 0x21000000        NextHop: 2::2
   MainNibID: N/A             BkNextHop: N/A
     BkNibID: N/A             Interface: Vlan-interface11
     TableID: 0xa           BkInterface: N/A
        Flag: 0x80d0a          BfdSrcIp: N/A
     DbIndex: 0x3            BfdIfIndex: 0x0
        Type: Normal        BfdVrfIndex: 0
  TrackIndex: 0xffffffff          Label: NULL
  Preference: 60            vrfIndexDst: 0
     BfdMode: N/A            vrfIndexNH: 0
   Permanent: 0                     Tag: 0
*Destination: 1::1234/128
     BkNibID: N/A             Interface: NULL0
     DbIndex: 0x1            BfdIfIndex: 0x0
   Permanent: 0                     Tag: 0
Destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route. (If an SRv6 TE policy or SR-MPLS TE policy is obtained through route recursion for the route, this field displays the policy name.)
BkInterface
Backup output interface. (If an SRv6 TE policy or SR-MPLS TE policy is obtained through route recursion for the route, this field displays the policy name.)
TableID
ID of the table to which the route belongs.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
BfdSrcIp
Source IPv6 address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode.
·     Echo—Echo packet mode.
TrackIndex
NQA Track index.
vrfIndexDst
Index of the VPN instance to which the destination belongs. For the public network, this field displays 0.
vrfIndexNH
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd { { control-packet | echo-packet } [ bfd-source ipv6-address ] | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static ipv6-address prefix-length interface-type interface-number next-hop-address track-nd [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static ipv6-address prefix-length interface-type interface-number gateway [ bfd { { control-packet | echo-packet } [ bfd-source ipv6-address ] | static session-name } | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static ipv6-address prefix-length next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ipv6-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static ipv6-address prefix-length vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ipv6-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address | gateway ] | [ vpn-instance d-vpn-instance-name ] next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is not a point-to-point (P2P) interface (for example, an NBMA interface or broadcast interface), the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
gateway: Uses the gateway address obtained during IPv6 address autoconfiguration of the interface as the next hop address of the IPv6 static route. If the gateway address changes, the device automatically changes the next hop address of the IPv6 static route to the changed gateway address. For more information about IPv6 address autoconfiguration, see IPv6 basics configuration and DHCPv6 configuration in Layer 3—IP Services Configuration Guide.
recursive-lookup host-route: Specifies only host routes for IPv6 static route recursion.
recursive-lookup longest-match: Specifies host routes with the longest matching mask for IPv6 static route recursion.
bfd: Enables BFD to detect reachability of the static route's next hop.
control-packet: Specifies the BFD control packet mode.
echo-packet: Specifies the BFD echo packet mode.
bfd-source ipv6-address: Specifies the source IPv6 address of BFD packets.
static session-name: Associates the IPv6 static route with a static BFD session. The session-name argument represents the static BFD session name, a case-sensitive string of 1 to 64 characters. If you specify a nonexistent static BFD session, you must create the static BFD session to have the configuration take effect.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. After you specify this keyword, the static route will always be active, even if the output interface is down.
track track-entry-number: Associates the IPv6 static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
track-nd: Associates the IPv6 static route with the ND entry corresponding to the next hop of the IPv6 static route. If you specify this keyword and the ND entry corresponding to the next hop of the IPv6 static route does not exist, the system will not activate the IPv6 static route. If you do not specify this keyword, the ND entry does not affect activation status of the IPv6 static route. As a best practice when you use this keyword, use the ipv6 route-static nd-request command to configure the device to periodically send ND requests to the next hop of the IPv6 static route to prevent the ND entry from aging and causing the IPv6 static route to become inactive.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a destination VPN is specified, packets will search for the output interface based on the specified next hop (IPv6 address) for the static route.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
recursive-lookup: Enables support for next hop recursion loops for the IPv6 static route. If you do not specify this keyword, the device does not support next hop recursion loops for the IPv6 static route.
description text: Configures a description for the IPv6 static route, which consists of 1 to 150 characters, including special characters such as the space, but excluding the question mark (?).
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
·     If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
·     If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
Follow these guidelines when you configure BFD for IPv6 static routes:
·     If you specify a source IPv6 address for BFD packets on the local device, you must specify that IPv6 address as the next hop IPv6 address on the peer device.
·     If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡     The address is the same as the IPv6 address of the output interface.
¡     The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
Follow these guidelines when you configure a static route:
·     Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
·     The next hop IPv6 address of echo packets must be a global unicast address.
·     Do not specify the permanent keyword together with the bfd keyword.
To specify the recursive-lookup host-route keyword, you must use the ipv6 nd route-direct advertise command to enable ND direct route advertisement to advertise 128-bit host routes on the following interfaces:
·     The output interface corresponding to the next hop of the static route.
·     The peer interface connected to the output interface.
If you do not specify the recursive-lookup longest-match or recursive-lookup host-route keyword, the IPv6 static route preferentially recurses to a direct route. The IPv6 static route recurses to the route with the longest matching mask only when no matching direct route is found. If the destination network address of the direct route contains the next hop address of the IPv6 static route, the following conditions might exist:
·     The IPv6 static route recurses the next hop to the direct route.
·     The device determines that the next hop address of the IPv6 static route is locally connected.
However, the next hop might be incorrect, which results in failure to forward packets matching the IPv6 static route. If you specify the recursive-lookup longest-match keyword, the IPv6 static route recurses to the route with the longest matching mask to ensure correct next hop recursion. If you specify the recursive-lookup host-route keyword, the IPv6 static route recurses to only a host route with a 128-bit mask, and the IPv6 static route can be activated only when the host route is reachable.
For IPv6 static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
A recursion loop occurs when an IPv6 static route recurses to a related route whose destination address contains the destination address of the IPv6 static route. For example, a recursion loop occurs when the IPv6 static route destined for 4::2/64 recurses to a related route whose destination address is 4::2/48.
·     If the recursive-lookup keyword is not specified, the recursion loop results in route recursion failure. The device further looks up for a related route.
·     If the recursive-lookup keyword is specified, the device determines that the recursion succeeds if the output interface of the related route is an interface directly connected to the device.
If the output interface of an IPv6 static route is found through recursion loops, routing protocols on the device cannot advertise the IPv6 static route to other devices.
As a best practice, use the recursive-lookup keyword only in specific scenarios, for example, in a network with microsegment configuration. You can recurse an IPv6 static route to a larger network segment, and apply the associated traffic control policies to the traffic matching the IPv6 static route.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 route-static bfd
Use ipv6 route-static bfd to configure BFD session parameters for an IPv6 static route.
Use undo ipv6 route-static bfd to restore the default.
BFD control packet mode for single-hop detection and BFD echo packet mode:
ipv6 route-static bfd interface-type interface-number next-hop-address { detect-multiplier detect-multiplier | min-echo-receive-interval min-echo-receive-interval | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
undo ipv6 route-static bfd interface-type interface-number next-hop-address
BFD control packet mode for multihop detection:
ipv6 route-static bfd [ vpn-instance d-vpn-instance-name ] next-hop-address source-ipv6 ipv6-address { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
undo ipv6 route-static bfd [ vpn-instance d-vpn-instance-name ] next-hop-address
No BFD session parameters are specifically configured for an IPv6 static route. The IPv6 static route uses the session parameters configured for the BFD module (common BFD session parameters).
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the next hop of the IPv6 static route belongs to the public network, do not specify this option.
next-hop-address: Specifies the IPv6 address of the next hop.
source-ipv6 ipv6-address: Specifies a source IPv6 address for BFD packets.
detect-multiplier detect-multiplier: Sets the BFD detection time multiplier. The value range for the detect-multiplier argument is 3 to 50. The default value is 5.
min-echo-receive-interval min-echo-receive-interval: Sets the minimum interval for receiving BFD echo packets, in milliseconds. The value range for the min-echo-receive-interval argument is 100 to 10000.
min-receive-interval min-receive-interval: Sets the minimum interval for receiving BFD control packets, in milliseconds. The value range for the min-receive-interval argument is 100 to 10000.
min-transmit-interval min-transmit-interval: Sets the minimum interval for transmitting BFD control packets, in milliseconds. The value range for the min-transmit-interval argument is 100 to 10000.
Use this command to configure BFD session parameters for an IPv6 static route, including parameters that determine the BFD detection time. The BFD detection time = detect-multiplier × max (min-echo-receive-interval, min-receive-interval, min-transmit-interval). For more information about the calculation method of BFD detection time, see BFD in High Availability Command Reference.
If you specify the output interface when executing this command, support for the BFD session parameters varies by BFD session mode.
·     Echo-mode BFD sessions support only the min-echo-receive-interval and detect-multiplier parameters.
·     Control-mode BFD sessions for single-hop detection support only the min-receive-interval, min-transmit-interval, and detect-multiplier parameters.
To apply the configured BFD session parameters, use one of the following combinations of parameters to specify an IPv6 static route:
·     In control packet mode for single-hop detection and in echo packet mode, use the output interface and next hop IPv6 address.
·     In control packet mode for multihop detection, use the next hop IPv6 address and BFD packet source IPv6 address. If the next hop belongs to a VPN instance, use the destination VPN instance, next hop IPv6 address, and BFD packet source IPv6 address to specify the IPv6 static route.
For an unspecified BFD session parameter, the IPv6 static route uses the value of the corresponding common BFD session parameter.
# Configure BFD session parameters for the IPv6 static route with output interface HundredGigE 1/0/1 and next hop 1:2::3:4. The BFD detection time multiplier is 20 and the minimum interval for receiving BFD echo packets is 1000 milliseconds.
[Sysname] ipv6 route-static bfd hundredgige 1/0/1 1:2::3:4 detect-multiplier 20 min-echo-receive-interval 1000
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
ipv6 route-static fast-reroute auto
Use ipv6 route-static fast-reroute auto to configure IPv6 static route FRR to automatically select a backup next hop.
Use undo ipv6 route-static fast-reroute auto to disable IPv6 static route FRR from automatically selecting a backup next hop.
IPv6 static route FRR is disabled from automatically selecting a backup next hop.
# Configure IPv6 static route FRR to automatically select a backup next hop.
[Sysname] ipv6 route-static fast-reroute auto
Use ipv6 route-static nd-request to enable periodic sending of ND requests to the next hops of IPv6 static routes.
Use undo ipv6 route-static nd-request to disable periodic sending of ND requests to the next hops of IPv6 static routes.
ipv6 route-static nd-request [ interval interval ]
Periodic sending of ND requests to the next hops of IPv6 static routes is disabled.
interval: Specifies an ND request sending interval in the range of 1 to 300 seconds. The default value is 5.
As a best practice, use this command when the following types of IPv6 static routes exist on the device:
·     IPv6 static routes that recurse to host routes, which include the following static routes:
¡     IPv6 static routes with the recursive-lookup host-route keywords specified to recurse only to host routes.
¡     IPv6 static routes that recurse to host routes according to routing policies (configured by using the protocol nexthop recursive-lookup command).
The device might delete the ND entry for the next hop host address of an IPv6 static route after that entry ages out because the device cannot update that entry in time. As a result, the device does not have the host route of the directly connected device in the IPv6 routing table for that IPv6 static route. In this case, route recursion fails and that IPv6 static route cannot be activated.
·     IPv6 static routes with the track-nd keyword specified to associate their next hops with the ND entries for these next hops. The device might delete the ND entry for the next hop address of an IPv6 static route after that entry ages out because the device cannot update that entry in time. As a result, that IPv6 static route cannot be activated.
For IPv6 static routes that recurse to host routes, the ipv6 route-static nd-request command enables the device to periodically send ND requests to the next hops of the IPv6 static routes that meet the following requirements:
·     The IPv6 static routes have no output interfaces specified.
·     The IPv6 static routes fail the next-hop recursion.
When the device receives an ND response from the next hop host of an IPv6 static route, it automatically performs the following operations:
1.     Adds the host route to the routing table.
2.     Activates the IPv6 static route that recurses to the host route.
3.     Stops sending ND requests to the host.
For IPv6 static routes with the track-nd keyword specified, the ipv6 route-static nd-request command enables the device to periodically send ND requests to the next hops of the IPv6 static routes associated with next hop ND entries. When the device receives an ND response from the next hop of an IPv6 static route, it automatically activates that IPv6 static route and stops sending ND requests to the next hop of that IPv6 static route.
For more information about ND, see IPv6 neighbor discovery in Layer 3—IP Services Configuration Guide.
# Enable sending of ND requests to the next hops of IPv6 static routes and set the sending interval to 10 seconds.
[Sysname] ipv6 route-static nd-request interval 10
ipv6 route-static
ipv6 route-static primary-path-detect bfd echo
Use ipv6 route-static primary-path-detect bfd echo to enable BFD echo packet mode for IPv6 static route FRR.
Use undo ipv6 route-static primary-path-detect bfd to disable BFD echo packet mode for IPv6 static route FRR.
BFD echo packet mode is disabled for IPv6 static route FRR.
For quicker IPv6 static route FRR, use BFD echo packet mode on the primary link of redundant links to detect link failure.
# Enable BFD echo packet mode for IPv6 static route FRR.
[Sysname] ipv6 route-static primary-path-detect bfd echo
ipv6 route-static recursive-lookup tunnel
Use ipv6 route-static recursive-lookup tunnel to allow IPv6 static routes to recurse to SRv6 TE policy tunnels or LSP tunnels.
Use undo ipv6 route-static recursive-lookup tunnel to restore the default.
ipv6 route-static recursive-lookup [ srv6-policy ] tunnel [ prefix-list ipv6-prefix-list-name ] [ tunnel-policy tunnel-policy-name | tunnel-selector tunnel-selector-name ]
undo ipv6 route-static recursive-lookup [ srv6-policy ] tunnel
IPv6 static routes cannot recurse to SRv6 TE policy tunnels or LSP tunnels.
srv6-policy: Allows IPv6 static routes to recurse to SRv6 TE policy tunnels. If you do not specify this keyword, the command allows IPv6 static routes to recurse to LSP tunnels.
prefix-list ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. Only IPv6 static routes filtered by the specified IPv6 prefix list can recurse to SRv6 TE policy tunnels or LSP tunnels. If you do not specify an IPv6 prefix list, the command allows all IPv6 static routes to recurse to SRv6 TE policy tunnels or LSP tunnels.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. IPv6 static routes can recurse only to SRv6 TE policy or LSP tunnels that match the specified tunnel policy.
tunnel-selector tunnel-selector-name: Specifies a tunnel selector by its name, a case-sensitive string of 1 to 40 characters. IPv6 static routes can recurse only to SRv6 TE policy or LSP tunnels that match the specified tunnel selector.
By default, an IPv6 static route can recurse only to output interfaces and next hops based on IP forwarding. This command allows the device to preferentially recurse IPv6 static routes to SRv6 TE policy tunnels or LSP tunnels. If an IPv6 static route cannot recurse to an SRv6 TE policy tunnel or LSP tunnel, the device recurses the IPv6 static route to an output interface and next hop based on IP forwarding.
If you do not specify the tunnel-policy tunnel-policy-name or tunnel-selector tunnel-selector-name option, this command allows IPv6 static routes to recurse to any SRv6 TE policy tunnels or LSP tunnels.
# Allow IPv6 static routes to recurse to LSP tunnels.
[Sysname] ipv6 route-static recursive-lookup tunnel
ipv6 route-static vpn-instance
Use ipv6 route-static vpn-instance to configure an IPv6 static route in a VPN instance.
Use undo ipv6 route-static vpn-instance to delete an IPv6 static route from a VPN instance.
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd { { control-packet | echo-packet } [ bfd-source ipv6-address ] | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number next-hop-address track-nd [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number gateway [ bfd { { control-packet | echo-packet } [ bfd-source ipv6-address ] | static session-name } | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length next-hop-address [ recursive-lookup { host-route | longest-match } ] [ public ] [ bfd { control-packet bfd-source ipv6-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ipv6-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address | gateway ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { public | vpn-instance d-vpn-instance-name } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ public | vpn-instance d-vpn-instance-name ] [ preference preference ]
No IPv6 static route is configured in a VPN instance.
vpn-instance s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN instance has its own routing table, and the configured IPv6 static route is installed in the routing tables of the specified VPN instances.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is a non-P2P interface (for example, an NBMA interface or broadcast interface), the next hop address must be specified.
bfd: Enables BFD to detect reachability of the static route's next hop. For more information about BFD, see High Availability Configuration Guide.
public: Indicates the next hop is on the public network.
description text: Configures a description for the IPv6 static route, a string of 1 to 150 characters, including special characters such as the space, but excluding the question mark (?).
·     If you specify the source IPv6 address of BFD packets, you must specify the IPv6 address as the next hop IPv6 address on the peer device.
·     You cannot specify both the permanent and bfd keywords.
# Configure an IPv6 static route in VPN instance vpn1, whose destination address is 1:1:2::/64 and next hop address is 1:1:3::1 in VPN instance vpn2.
[Sysname] ipv6 route-static vpn-instance vpn1 1:1:2:: 64 vpn-instance vpn2 1:1:3::1
