06-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10006-Layer 3—IP Routing Command Reference
06-Basic BGP commands
06-Basic BGP commands 1.33 MB
Basic BGP commands· 1
address-family ipv4· 1
address-family ipv6· 2
advertise lowest-priority on-peer-up duration· 3
advertise lowest-priority on-startup duration· 10
advertisement-interval 11
advertise-rib-active· 12
aggregate· 13
as-path-limit 15
balance· 16
balance as-path-neglect 18
balance as-path-relax· 19
balance igp-metric-ignore· 20
bestroute as-path-neglect 21
bestroute compare-med· 21
bestroute igp-metric-ignore· 22
bestroute med-confederation· 23
bestroute med-plus-igp· 23
bestroute router-id-ignore· 24
bgp· 25
bgp apply-policy on-startup duration· 26
bgp policy on-startup med· 27
bgp queue-limit 27
bgp update-delay on-startup· 28
bgp update-delay on-startup prefix-list 29
bgp update-delay on-startup ipv6-prefix-list 30
compare-different-as-med· 30
confederation id· 31
confederation nonstandard· 32
confederation peer-as· 33
dampening· 33
default local-preference· 35
default med· 35
default-route imported· 36
default-route update-first 37
display bgp dampening parameter 38
display bgp group· 39
display bgp instance-info· 42
display bgp network· 42
display bgp paths· 44
display bgp peer 45
display bgp routing-table dampened· 55
display bgp routing-table flap-info· 57
display bgp routing-table ipv4 unicast 60
display bgp routing-table ipv6 unicast 76
display bgp troubleshooting· 90
display bgp update-group· 92
filter-policy export 94
filter-policy import 96
group· 98
ignore-first-as· 99
import-route· 99
import-route-append· 101
import-route multipath· 103
ip vpn-instance (BGP instance view) 104
log-peer-change· 105
log-route-flap· 105
network· 106
network short-cut 107
nexthop global-address-only· 109
peer advertise bandwidth transitive· 109
peer advertise-community· 111
peer advertise ebgp bandwidth· 112
peer advertise-ext-community· 114
peer advertise-large-community· 115
peer advertisement-interval 117
peer advertise-policy exist-policy· 118
peer advertise-policy non-exist-policy· 119
peer aigp· 121
peer aigp send med· 122
peer allow-as-loop· 123
peer-as-check enable· 124
peer as-number (for a BGP peer group) 125
peer as-number (for a BGP peer) 126
peer as-path-acl 127
peer bandwidth· 128
peer cluster-id· 131
peer connect-interface· 132
peer { connect-only | listen-only } 134
peer default-route-advertise· 135
peer description· 137
peer ebgp-max-hop· 138
peer enable· 139
peer fake-as· 141
peer filter-policy· 142
peer group· 144
peer high-priority· 146
peer ignore-first-as· 147
peer ignore-originatorid· 148
peer listen-as (for a BGP peer group) 149
peer listen-as (for a dynamic BGP peer) 151
peer listen-as-segment (for a BGP peer group) 152
peer listen-as-segment (for a dynamic BGP peer) 154
peer log-change· 155
peer next-hop-invariable· 156
peer next-hop-local 158
peer preferred-value· 159
peer prefix-list 161
peer public-as-only· 162
peer reflect-client 164
peer route-limit 165
peer route-policy· 167
peer route-update-interval 169
peer send-buffer-size· 170
peer source-address· 171
peer substitute-as· 173
peer timer 174
peer timer connect-retry· 175
preference· 176
reflect between-clients· 177
reflect change-path-attribute· 178
reflector cluster-id· 179
reset bgp· 180
reset bgp advertise lowest-priority· 182
reset bgp all 183
reset bgp dampening· 184
reset bgp flap-info· 185
router id· 186
route-rate-limit 187
route-update-interval intelligent-timer 188
route-update-interval withdrawn enable· 190
router-id (BGP instance view) 191
route-update-delay· 192
send-buffer-size· 192
snmp context-name· 193
snmp-agent trap enable bgp· 194
summary automatic· 195
timer 196
timer connect-retry· 197
update-first route-policy· 198
Basic BGP commands
address-family ipv4
Use address-family ipv4 to create the BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, and enter its view, or enter the view of the existing address family.
Use undo address-family ipv4 to remove the BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, and all its configurations.
In BGP instance view:
address-family ipv4 [ rtfilter | unicast ]
undo address-family ipv4 [ rtfilter | unicast ]
In BGP-VPN instance view:
undo address-family ipv4 [ unicast ]
No BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, exists.
BGP instance view
multicast: Specifies the IPv4 multicast address family.
rtfilter: Specifies the BGP IPv4 RT filter address family.
unicast: Specifies the IPv4 unicast address family. If this command is executed with the unicast keyword in BGP instance view, it places you into BGP IPv4 unicast address family view. If this command is executed with the unicast keyword in BGP-VPN instance view, it places you into BGP-VPN IPv4 unicast address family view.
Configurations made in BGP IPv4 unicast address family view apply only to the BGP IPv4 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv4 unicast address family view apply only to the BGP IPv4 unicast routes and peers of the specified VPN instance.
Configurations made in BGP IPv4 RT filter address family view apply only to the BGP IPv4 RT filter routes and peers.
By default, the unicast keyword is used if you do not specify the multicast, rtfilter, or unicast keyword.
# In BGP instance view, create the BGP IPv4 unicast address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4]
address-family ipv6
Use address-family ipv6 to create the BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, and enter its view, or enter the view of the existing address family.
Use undo address-family ipv6 to remove the BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, and all its configurations.
undo address-family ipv6 [ unicast ]
No BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, exists.
BGP instance view
unicast: Specifies the IPv6 unicast address family. If this command is executed with the unicast keyword in BGP instance view, it places you into BGP IPv6 unicast address family view. If this command is executed with the unicast keyword in BGP-VPN instance view, it places you into BGP-VPN IPv6 unicast address family view.
Configurations made in BGP IPv6 unicast address family view apply only to the BGP IPv6 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv6 unicast address family view apply only to the BGP IPv6 unicast routes and peers of the specified VPN instance.
By default, the unicast keyword is used.
# In BGP instance view, create the BGP IPv6 unicast address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6]
Use advertise lowest-priority on-peer-up duration to minimize the priority of the routes advertised to a peer after the peer state changes from DOWN to UP.
Use undo advertise lowest-priority on-peer-up duration to restore the default.
advertise lowest-priority on-peer-up duration seconds
BGP does not change the priority of the routes advertised to its peers.
BGP instance view
BGP VPNv4 address family view
BGP-VPN VPNv4 address family view
BGP VPNv6 address family view
BGP EVPN address family view
seconds: Set the time to wait for route priority restoration. The value range for the wait time is 1 to 864000 seconds.
By default, the device sends BGP routes immediately to a peer when the peer state changes to UP. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this command to minimize the priority of the routes to be advertised after the state of a peer changes from DOWN to UP. The peer will not select the routes received from the device as optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peer.
After you use this command, the device performs the following tasks when the state of a peer changes from DOWN to UP:
1.     Set the local preference value to the minimum (zero) and the MED value to the maximum (4294967295) for the routes to be advertised.
2.     After the specified wait time elapses, restore the local preference value and the MED value for the advertised routes, and then advertise these routes immediately.
To have the device restore the priority of the advertised routes before the specified wait time elapses, you can use one of the following commands:
¡     reset bgp advertise lowest-priority on-peer-up
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
¡     undo advertise lowest-priority on-peer-up duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. The device does not change the original local preference value and MED value for the subsequent routes advertised to peers.
You can use the advertise lowest-priority on-peer-up duration command in BGP instance view or BGP address family view:
·     If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
·     If you use this command in the view of a BGP address family, this command takes effect only on the address family.
·     For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
You can use this command multiple times to change the wait time. After you change the wait time, the following rules apply:
·     If the original wait time setting is taking effect, the new wait time setting will immediately take over and the device will update the time to wait for route priority restoration.
For example, you can set the wait time to 10 seconds by using the advertise lowest-priority on-peer-up duration 10 command. Then, you use the advertise lowest-priority on-peer-up duration 6 command to set a new wait time six seconds after the state of a peer changes from DOWN to UP. The device will still minimize the priority of the routes advertised to the peer during the following six seconds.
·     If the original wait time is not taking effect, the new wait time will take effect when the state of a peer changes from DOWN to UP.
The following commands can influence each other:
·     advertise lowest-priority on-peer-up duration
·     advertise lowest-priority on-startup duration
·     bgp update-delay on-startup
·     route-update-delay
When you use two of the commands above together, the configuration result varies by command as follows:
Table 1 Configuration results
Command A
Command B
advertise lowest-priority on-startup duration in BGP instance view
Command A and command B overwrite each other. The command used at last takes effect.
advertise lowest-priority on-peer-up duration in BGP instance view
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers:
·     If TA ≥ TB, only command A takes effect.
·     If TA < TB, the device performs the following tasks:
a.     The device does not send any BGP routes to peers within TA.
b.     After TA elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA).
c.     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
route-update-delay
Both command A and command B take effect after the device restarts and the BGP process recovers.
Provided that the delay time specified in command A is TA, the device can advertise BGP routes to a peer only after TA plus TS elapses.
TS represents the larger interval among the intervals specified in the peer route-update-interval command and command B. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command B.
advertise lowest-priority on-startup duration in the view of a BGP address family
·     In the address family configured with command B, only command B takes effect.
·     In the address families not configured with command B, command A takes effect.
advertise lowest-priority on-peer-up duration in the view of a BGP address family
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the following rules apply:
·     In the address families not configured with command B, only command A takes effect.
·     In the address family configured with command B, the two commands take effect as follows after the device restarts and the BGP process recovers:
¡     If TA ≥ TB, only command A takes effect.
¡     If TA < TB, the device performs the following tasks:
i. The device does not send any BGP routes to peers within TA.
ii. After TA elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA).
iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
route-update-delay
·     In BGP EVPN address family, only command B takes effect.
·     The following description applies to BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, BGP VPNv4 address family, BGP-VPN VPNv4 address family, and BGP VPNv6 address family.
Provided that the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers:
¡     If TS ≥ TB, only command A takes effect.
¡     If TS < TB, the device performs the following tasks:
i. The device does not send any BGP routes to peers within TS.
ii. After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS).
·     TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peers, the device uses the default value of this command to compare with the interval configured in command A.
Provided that the wait time specified in command B is TB, the two commands take effect as follows when the state of a peer changes from DOWN to UP:
i. The device does not send any BGP routes to the peer within TS.
ii. After TS elapses, the device sends BGP routes to the peer and minimizes the priority of these routes during the remaining time (TB minus TS).
iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer.
·     TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command A.
advertise lowest-priority on-startup duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, BGP VPNv4 address family view, BGP-VPN VPNv4 address family view, or BGP VPNv6 address family view
Provided that the wait time specified in command B is TB, the following rules apply:
advertise lowest-priority on-peer-up duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, BGP VPNv4 address family view, BGP-VPN VPNv4 address family view, or BGP VPNv6 address family view
·     In the address family configured with command B, the two commands take effect as follows when the state of a peer changes from DOWN to UP:
advertise lowest-priority on-startup duration or advertise lowest-priority on-peer-up duration in BGP EVPN address family view
Only command B takes effect.
Command A is mutually exclusive with command B.
Command A is mutually exclusive with command B in the same address family.
# In BGP instance view, minimize the priority of the routes advertised to a peer after the peer state changes from DOWN to UP, and set the wait time to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] advertise lowest-priority on-peer-up duration 100
Use advertise lowest-priority on-startup duration to minimize the priority of the routes advertised to peers after the device restarts and the BGP process recovers.
Use undo advertise lowest-priority on-startup duration to restore the default.
advertise lowest-priority on-startup duration seconds
BGP instance view
seconds: Set the time to wait for route priority restoration. The value range for the wait time is 1 to 3600 seconds.
By default, the device sends BGP routes immediately to peers after the device restarts and the BGP process recovers. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this command to minimize the priority of the routes to be advertised after the device restarts and the BGP process recovers. Peers will not select the routes received from the device as the optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peers.
After you use this command, the device performs the following tasks after the device restarts and the BGP process recovers:
To have the device restore the priority of the advertised routes before the specified wait time elapses, use one of the following commands:
¡     reset bgp advertise lowest-priority on-startup
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not minimize the priority of the subsequent routes advertised to the peers unless the device restarts again.
¡     undo advertise lowest-priority on-startup duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not change the original local preference value and MED value for the subsequent routes advertised to the peers.
When you use the advertise lowest-priority on-startup duration command, follows these guidelines:
·     You can use this command in BGP instance view or BGP address family view:
¡     If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
¡     If you use this command in the view of a BGP address family, this command takes effect only on the address family.
¡     For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
·     The configuration of this command does not take effect immediately. It takes effect only after the device saves the configuration and restarts.
The following commands can influence the configuration of each other:
When you use two of the commands above together, the configuration result varies by command. For more information, see Table 1.
# In BGP instance view, minimize the priority of the routes advertised to a peer after the device restarts and the BGP process recovers, and set the wait time to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] advertise lowest-priority on-startup duration 100
Use advertisement-interval to set the interval for sending update messages and the maximum number of update messages that can be sent each time.
Use undo advertisement-interval to restore the default.
advertisement-interval interval count
The interval for sending update messages and the maximum number of update messages that can be sent each time are not set.
BGP instance view
interval: Specifies the interval for sending update messages, in the range of 100 to 10000 milliseconds. The value of this argument must be an integer multiple of 100.
count: Specifies the maximum number of update messages that can be sent each time, in the range of 1 to 40960.
Configure this command to prevent the device from sending a large number of update messages in a short time period.
This command takes effect only on BGP sessions established or re-established after the command is executed.
# In BGP instance view, set the interval for sending update messages and the maximum number of update messages that can be sent each time to 1000 milliseconds and 5, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] advertisement-interval 1000 5
Use advertise-rib-active to enable BGP to advertise only the optimal BGP routes in the IP routing table.
Use undo advertise-rib-active to restore the default.
In BGP instance view, BGP advertises optimal routes in the BGP routing table, regardless of whether they are optimal in the IP routing table. In other views, the setting is the same as that in BGP instance view.
BGP instance view
The advertise-rib-active command does not apply to the following routes:
·     Routes redistributed by the import-route command.
·     Routes advertised by the network command.
·     Default routes redistributed by the default-route imported command.
·     Locator routes advertised by using the advertise srv6 locator command.
This command takes effect only on the routes generated after you execute this command. To apply this command to existing routes, use the reset bgp command to reset BGP sessions.
The setting in BGP unicast address family view applies when it is different from that in BGP instance view.
This command is mutually exclusive with the routing-table bgp-rib-only command.
# In BGP instance view, enable BGP to advertise optimal routes in the IP routing table.
[Sysname] bgp 100
[Sysname-bgp-default] advertise-rib-active
routing-table bgp-rib-only (Layer 3—IP Routing Command Reference)
aggregate
Use aggregate to create a summary route in the BGP routing table.
Use undo aggregate to remove a summary route.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
undo aggregate ipv4-address { mask-length | mask }
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
undo aggregate ipv6-address prefix-length
No summary routes are configured.
ipv4-address: Specifies an IPv4 summary address.
mask-length: Specifies a mask length for the IPv4 summary address, in the range of 0 to 32.
mask: Specifies a mask for the IPv4 summary address, in dotted decimal notation.
ipv6-address: Specifies an IPv6 summary address.
prefix-length: Specifies a prefix length for the IPv6 summary address, in the range of 0 to 128.
as-set: Enables the AS_PATH attribute of the summary route to contain the AS path information for all summarized routes. The AS_PATH attribute is of the AS_SET type that requires no sequence when arranging AS numbers. If you do not specify this keyword, the AS_PATH attribute of the summary route contains only the AS number of the local router.
attribute-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set attributes for the summary route.
detail-suppressed: Advertises only the summary route. If you do not specify this keyword, BGP advertises both the summary route and the more specific routes.
origin-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to select routes to be summarized.
suppress-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter more specific routes to be advertised. Routes permitted by the specified routing policy are not advertised. Routes denied by the specified routing policy are advertised.
This command creates a summary route. If the BGP routing table has routes whose destination addresses fall within the specified network, the summary route is added to the BGP routing table. For example, if two routes 10.1.1.0/24 and 10.1.2.0/24 exist in the BGP routing table, configuring the aggregate 10.1.0.0 16 command creates a summary route 10.1.0.0/16.
In BGP-VPN IPv4/IPv6 unicast address family view, this command is also applicable to type 2 and type 5 BGP EVPN routes that have the same RD as that of the current VPN instance. For example, two type 5 routes 10.1.1.0/24 and 10.1.2.0/24 exist in the BGP EVPN routing table. If you configure the aggregate 10.1.0.0 16 command in BGP-VPN IPv4 unicast address family view, type 5 EVPN summary route 10.1.0.0/16 will be created. To prevent BGP from advertising the summaried EVPN routes of that summary route, specify the detail-suppressed keyword.
If the summarized routes have different ORIGIN attributes, the summary route selects the ORIGIN attribute in the sequence of INCOMPLETE, EGP, and IGP. For example, if the ORIGIN attributes of the summarized routes include INCOMPLETE and IGP, the ORIGIN attribute of the summary route is INCOMPLETE.
The COMMUNITY attribute of the summary route includes all the COMMUNITY (or extended community) attribute values if the routes have the following details:
·     Summarized routes have different COMMUNITY (or extended community) attribute values.
·     The summary route does not have the ATOMIC_AGGREGATE attribute.
Table 2 Functions of the keywords
Keywords
Function
as-set
Enables the summary route to carry the AS path information for all summarized routes. This feature can help avoid routing loops. However, if many routes are summarized and are changed frequently, do not specify this keyword. This configuration causes the summary route to flap with the more specific routes.
attribute-policy
Sets attributes except the AS-PATH attribute for the summary route. The peer route-policy command can achieve the same purpose.
The attribute-policy and as-set keywords are mutually exclusive when they are used to modify the AS_PATH attribute for the summary route. Modifying the AS_PATH attribute of the summary route might cause routing loops.
detail-suppressed
Disables advertisement of all more specific routes. To disable advertisement of some more specific routes, use the suppress-policy keyword or the peer filter-policy command.
origin-policy
Summarizes only routes matching a routing policy.
If the destination address of a route falls within the summary network but does not match the routing policy, the route is not summarized. It is not controlled by the detail-suppressed and suppress-policy keywords.
There is no need to configure apply clauses for the routing policy applied by the origin-policy keyword because they do not take effect.
suppress-policy
Disables advertisement of some more specific routes filtered by a routing policy. The routing policy uses if-match clauses to filter routes.
There is no need to configure apply clauses for the routing policy applied by the suppress-policy keyword because they do not take effect.
# In BGP IPv4 unicast address family view, create summary route 1.1.0.0/16 in the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] aggregate 1.1.0.0 255.255.0.0
display bgp routing-table ipv4 multicast
summary automatic
as-path-limit
Use as-path-limit to set an AS number quantity threshold.
Use undo as-path-limit to restore the default.
as-path-limit [ as-numbers ]
undo as-path-limit
No AS number quantity threshold is configured.
BGP instance view
as-numbers: Specifies an AS number quantity threshold in the range of 1 to 2000. The default threshold is 255.
This command enables BGP to filter routes based on the quantity of AS numbers contained in the AS_PATH attribute. BGP will discard incoming and outgoing routes, and withdraw routes that have been advertised if they exceed the specified quantity threshold.
This command does not take effect on routes that have been received or on local summary routes.
# Set the AS number quantity threshold to 100.
[Sysname] bgp 100
[Sysname-bgp-default] as-path-limit 100
balance
Use balance to enable load balancing and set the maximum number of BGP ECMP routes for load balancing.
Use undo balance to disable load balancing.
balance [ ebgp | eibgp | ibgp ] number [ ecmp-nexthop-local | ecmp-nexthop-unchanged ]
undo balance [ ebgp | eibgp | ibgp ]
Load balancing is disabled.
ebgp: Enables load balancing over EBGP routes.
eibgp: Enables load balancing between EBGP and IBGP routes.
ibgp: Enables load balancing over IBGP routes.
number: Specifies the maximum number of BGP ECMP routes for load balancing. When it is set to 1, load balancing is disabled.
ecmp-nexthop-local: Sets the local device IP as the next hop of each BGP ECMP route for load balancing.
ecmp-nexthop-unchanged: Retains the next hop of each BGP ECMP route for load balancing.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing by modifying route selection rules.
If multiple BGP routes destined for a network meet the following conditions, the device selects the specified number of routes for load balancing:
BGP uses the following load balancing criteria to determine load balanced routes:
·     The routes have the same ORIGIN, LOCAL_PREF, AIGP, and MED attributes.
·     The routes meet the following requirements on the AS_PATH attribute:
¡     If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡     If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡     If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
·     The next hops of the routes meet the following requirements on IGP metrics:
¡     If neither the bestroute igp-metric-ignore command nor the balance igp-metric-ignore command is configured, the next hops of the routes must have the same IGP metric value.
¡     If either the bestroute igp-metric-ignore command or the balance igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
If you use the balance command without specifying the ecmp-nexthop-local or ecmp-nexthop-unchanged keyword, BGP advertises the routes used for load balancing to IBGP peers as follows:
·     Without the Add-Path feature configured, BGP advertises only the optimal route among the routes used for load balancing and sets the local device IP as the next hop of that optimal route.
·     With the Add-Path feature configured, BGP performs the following tasks:
¡     Advertises the routes used for load balancing. The number of routes that BGP can advertise equals the maximum number of Add-Path optimal routes that can be advertised.
¡     Sets the local device IP as the next hop of the optimal route among the advertised routes.
If you do not specify the ibgp, eibgp, or ebgp keyword, this command enables load balancing over EBGP routes and IBGP routes, but not between EBGP and IBGP routes.
Configuration of the balance eibgp number command can be removed only by executing the undo balance eibgp command.
After you execute the balance eibgp number command, the balance [ ebgp | ibgp ] number command cannot be executed; and vice versa.
# In BGP IPv4 unicast address family view, enable load balancing and set the maximum number of BGP ECMP routes used for load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance 2
Use balance as-path-neglect to enable BGP to ignore the AS_PATH attribute when it implements load balancing.
Use undo balance as-path-neglect to restore the default.
BGP does not ignore the AS_PATH attribute when it implements load balancing.
BGP IPv4 multicast address family view
BGP IPv6 multicast address family view
For BGP to implement load balancing over routes with different AS_PATH attributes, you must use this command together with the balance command.
After this command is executed, BGP ignores the AS_PATH attributes in the routes for load balancing and changes the attributes of the advertised routes to those of the optimal route. The operations might cause routing loops. In addition, this command might also affect the NetStream data. Therefore, use this command with caution.
# In BGP IPv4 unicast address family view, enable BGP to ignore the AS_PATH attribute when it implements load balancing.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-neglect
balance
Use balance as-path-relax to enable load balancing for routes that have different AS_PATH attributes of the same length.
Use undo balance as-path-relax to restore the default.
balance as-path-relax [ ebgp | ibgp ]
undo balance as-path-relax [ ebgp | ibgp ]
BGP cannot perform load balancing for routes that have different AS_PATH attributes of the same length.
ebgp: Enables load balancing for EBGP routes that have different AS_PATH attributes of the same length.
ibgp: Enables load balancing for IBGP routes that have different AS_PATH attributes of the same length.
For BGP to perform load balancing for routes with different AS_PATH attributes of the same length, you must use this command together with the balance command.
If you configure both the balance as-path-relax and balance as-path-neglect commands, the balance as-path-neglect command takes effect.
If you do not specify the ibgp or ebgp keyword when you execute this command, the following rules apply:
·     BGP performs load balancing for EBGP routes that have different AS_PATH attributes of the same length.
·     BGP performs load balancing for IBGP routes that have different AS_PATH attributes of the same length.
·     BGP does not perform load balancing between EBGP and IBGP routes that have different AS_PATH attributes of the same length.
After this command is executed, BGP ignores the AS_PATH attributes in the routes for load balancing and changes the attributes of the advertised routes to those of the optimal route. This might cause routing loops and affect NetStream statistics. Therefore, use this command with caution.
# In BGP IPv4 unicast address family view, enable load balancing for EBGP routes that have different AS_PATH attributes of the same length.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-relax ebgp
Use balance igp-metric-ignore to enable BGP to use routes with different IGP metrics for load balancing.
Use undo balance igp-metric-ignore to restore the default.
BGP cannot use routes with different IGP metrics to implement load balancing.
After you use the balance and balance igp-metric-ignore commands together, BGP will ignore the IGP metrics of routes and can use routes with different IGP metrics for load balancing.
Both the balance igp-metric-ignore and bestroute igp-metric-ignore commands can enable BGP to use routes with different IGP metrics for load balancing. The two commands are different as follows:
·     The balance igp-metric-ignore command can be used only for load balancing. It does not change the rules of optimal route selection. BGP still compares the IGP metric value of each route during optimal route selection.
·     The bestroute igp-metric-ignore command takes effect on optimal route selection and on route selection for load balancing. With this command executed, BGP will ignore the IGP metric in both cases.
# In BGP IPv4 unicast address family view, enable BGP to use routes with different IGP metrics for load balancing.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance igp-metric-ignore
balance
Use bestroute as-path-neglect to configure BGP to ignore the AS_PATH attribute during optimal route selection.
Use undo bestroute as-path-neglect to restore the default.
BGP considers the AS_PATH attribute during optimal route selection.
BGP instance view
# In BGP instance view, ignore AS_PATH during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute as-path-neglect
Use bestroute compare-med to enable MED comparison for routes on a per-AS basis.
Use undo bestroute compare-med to restore the default.
MED comparison for routes on a per-AS basis is disabled.
BGP instance view
By default, BGP does not compare MEDs for routes from the same AS. When a router learns a new route, it compares the route with the optimal route in its BGP routing table. If the new route is more optimal, it becomes the optimal route in the BGP routing table. In this way, route learning sequence might affect optimal route selection.
To solve the selection issue, the router puts routes received from the same AS into a group when the bestroute compare-med command is configured. The router then selects the route with the lowest MED from the same group, and compares routes from different groups.
# In BGP instance view, enable MED comparison for routes on a per-AS basis.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute compare-med
Use bestroute igp-metric-ignore to configure BGP to ignore IGP metrics during optimal route selection.
Use undo bestroute igp-metric-ignore to restore the default.
BGP considers IGP metrics during optimal route selection, and selects the route with the smallest IGP metric as the optimal route.
BGP instance view
# In BGP instance view, ignore IGP metrics during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute igp-metric-ignore
Use bestroute med-confederation to enable MED comparison for routes received from confederation peers.
Use undo bestroute med-confederation to restore the default.
MED comparison is disabled for routes received from confederation peers.
BGP instance view
This command enables BGP to compare the MEDs of routes received from confederation peers. However, if a route from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008, which does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
# In BGP instance view, enable MED comparison for routes received from confederation peers.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute med-confederation
Use bestroute med-plus-igp to use the sum of the calculated MED and IGP metric values instead of the MED value for optimal route selection.
Use undo bestroute med-plus-igp to restore the default.
bestroute med-plus-igp [ igp-multiplier igp-multiplier | med-multiplier med-multiplier ] *
BGP selects the route with the lowest MED value as the optimal route.
BGP instance view
igp-multiplier igp-multiplier: Specifies the IGP metric value multiplier. The value range for the igp-multiplier argument is 1 to 1000 and the default value is 1.
med-multiplier med-multiplier: Specifies the MED value multiplier. The value range for the med-multiplier argument is 1 to 1000 and the default value is 1.
By default, BGP uses the MED value and the IGP metric value separately for optimal route selection. With this command executed, BGP performs the following tasks when it selects the optimal route by MED comparison:
1.     Multiply the MED value and IGP metric value for each route by the MED value multiplier and the IGP metric value multiplier, respectively.
2.     Calculate the sum of the new MED value and IGP metric value for each route.
3.     Select the route with the smallest sum as the optimal route.
BGP cannot use routes with different MED values to implement load balancing. To resolve this issue, set the multipliers as needed to ensure that the sums of the calculated MED and IGP metric values for these routes are the same.
If a route has no MED attribute, the MED value for this route is 0.
# In BGP instance view, enable BGP to use the sum of the calculated MED and IGP metric values instead of the MED value for optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute med-plus-igp
Use bestroute router-id-ignore to configure BGP to ignore router IDs during optimal route selection.
Use undo bestroute router-id-ignore to restore the default.
BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
BGP instance view
# In BGP instance view, configure BGP to ignore router IDs during optimal route selection.
[Sysname] bgp 1
[Sysname-bgp-default] bestroute router-id-ignore
bgp
Use bgp to enable a BGP instance and enter its view.
Use undo bgp to disable a BGP instance.
undo bgp [ as-number [ instance instance-name ] [ force ] ]
BGP is disabled and no BGP instances exist.
as-number: Specifies a local AS number. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command enables the BGP instance default.
force: Forcibly shuts down the BGP process. This keyword might cause errors. Use it with caution.
A router supports 4-byte AS numbers and dotted decimal AS numbers.
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance.
You can create multiple public address families for a BGP instance. However, each public address family (except for IPv4 unicast address family, IPv6 unicast address family, VPNv4 address family, VPNv6 address family, IPv4 RT filter address family, IPv4 SR policy address family, and IPv6 SR policy address family) can belong to only one BGP instance.
On the public network, a peer address can establish a BGP session to only one BGP instance. Multiple BGP instances cannot synchronously establish BGP sessions to the same peer address.
Different BGP instances can have the same AS number but cannot have the same name.
# Enable BGP instance default, set the local AS number to 100, and enter BGP instance view.
[Sysname] bgp 100
# Enable BGP instance default, set the local AS number to 1.1, and enter BGP instance view.
[Sysname] bgp 1.1
# Forcibly shut down the BGP process.
[Sysname] undo bgp 100 force
If you forcibly delete the BGP process, the process might be corrupted. Continue? [Y/N]:n
Use bgp apply-policy on-startup duration to specify the period after reboot within which the startup policy is effective.
Use undo bgp apply-policy on-startup duration to restore the default.
The startup policy does not take effect.
BGP instance view
seconds: Specifies the period after reboot within which the startup policy is effective, in the range of 0 to 3600 seconds. The number of 0 indicates that the startup policy is effective permanently.
This command allows BGP to send route updates with the attribute values specified in the startup policy within the specified period after reboot. Then, BGP can forward traffic through other devices to avoid traffic loss caused by reboot.
# In BGP instance view, set the period after reboot to 100 seconds within which the startup policy is effective.
[Sysname] bgp 100
[Sysname-bgp-default] bgp apply-policy on-startup duration 100
Use bgp policy on-startup med to set the MED attribute value in the startup policy.
Use undo bgp policy on-startup med to restore the default.
The MED attribute value in the startup policy is 4294967295.
BGP instance view
med-value: Specifies the MED attribute value in the startup policy, in the range of 0 to 4294967295.
After you configure this command, BGP uses the specified MED attribute value to send route updates within the specified period after reboot.
# In BGP instance view, set the MED attribute value in the startup policy to 100.
[Sysname] bgp 100
[Sysname-bgp-default] bgp policy on-startup med 100
bgp queue-limit
Use bgp queue-limit to set the update message send queue parameters.
Use undo bgp queue-limit to restore the default.
bgp queue-limit { packet packet-count | send send-count } *
The maximum number of BGP update message in the send queue and the number of update messages sent each time are 100 and 5, respectively.
BGP instance view
packet-count: Specifies the maximum number of BGP update message in the send queue, in the range of 1 to 1000. The default value is 100.
send-count: Specifies the number of update messages that can be sent each time, in the range of 1 to 100. The default value is 5.
# In BGP instance view, set the maximum number of BGP update message in the send queue and the number of update messages sent each time to 60 and 10, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] bgp queue-limit packet 60 send 10
Use bgp update-delay on-startup to configure BGP to delay sending route updates when it restores after a device reboot.
Use undo bgp update-delay on-startup to restore the default.
BGP sends route updates immediately to BGP peers in established state when it restores after a device reboot.
BGP instance view
seconds: Specifies the delay time in the range of 0 to 3600 seconds. The value of 0 indicates that BGP does not send route updates after the device reboots and the BGP process recovers.
With this feature enabled, BGP delays sending route updates when it restores after a device reboot. During the delay time, BGP learns all routes from other neighbors, and then selects the optimal route. After the delay time elapses, BGP will advertise the optimal route. Using this feature can reduce traffic loss caused by device reboot.
For BGP EVPN routes, this feature takes effect only on IP prefix routes and MAC/IP advertisement routes that carry IP routing information.
# In BGP instance view, configure BGP to delay sending route updates when it restores after a device reboot and set the delay time to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup 100
Use bgp update-delay on-startup prefix-list to enable BGP to immediately send route updates for IPv4 routes that match a prefix list.
Use undo bgp update-delay on-startup prefix-list to restore the default.
No prefix list is specified to filter IPv4 routes.
BGP instance view
ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
After the bgp update-delay on-startup command is configured, BGP delays sending updates for all routes when it restores after a device reboot. For BGP to immediately send updates for the specified routes, execute the bgp update-delay on-startup prefix-list command.
# In BGP instance view, enable BGP to send updates 100 seconds after it restores from a device reboot and immediately send updates for routes that match prefix list aaa.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup prefix-list aaa
Use bgp update-delay on-startup ipv6-prefix-list to enable BGP to immediately send route updates for IPv6 routes that match a prefix list.
Use undo bgp update-delay on-startup ipv6-prefix-list to restore the default.
bgp update-delay on-startup ipv6-prefix-list ipv6-prefix-list-name
No prefix list is specified to filter IPv6 routes.
BGP instance view
ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
After the bgp update-delay on-startup command is configured, BGP delays sending updates for all routes when it restores after a device reboot. For BGP to immediately send updates for the specified routes, execute the bgp update-delay on-startup ipv6-prefix-list command.
# In BGP instance view, enable BGP to send updates 100 seconds after it restores from a device reboot and immediately send updates for routes that match prefix list bbb.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup ipv6-prefix-list bbb
Use compare-different-as-med to enable MED comparison for routes from peers in different ASs.
Use undo compare-different-as-med to restore the default.
MED comparison is disabled for routes from peers in different ASs.
BGP instance view
If multiple routes to a destination exist, the route with the smallest MED is selected.
Do not use this command unless relevant ASs adopt the same IGP protocol and routing selection method.
# In BGP instance view, enable MED comparison for routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-default] compare-different-as-med
confederation id
Use confederation id to configure a confederation ID.
Use undo confederation id to restore the default.
confederation id as-number
No confederation ID is configured.
BGP instance view
as-number: Specifies an AS number that identifies the confederation. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
You can split an AS into several sub-ASs, and each sub-AS remains fully meshed. These sub-ASs form a confederation. Key path attributes of a route, such as the Next_HOP, MED, and LOCAL_PREF, are not discarded when crossing each sub-AS. The sub-ASs still look like one AS from the perspective of other ASs. The AS number is the confederation ID.
Confederation can ensure the integrity of the former AS, and solve the issue of too many IBGP connections in the AS.
Configure the same confederation ID for all routers in one confederation.
For a non-confederation BGP router that establishes a BGP connection to a router in a confederation, the confederation ID is the AS number of the router.
# Confederation 9 consists of four sub-ASs numbered 38, 39, 40 and 41. Peer 10.1.1.1 is a member of sub-AS 38. Peer 200.1.1.1 is a member outside of confederation 9, which belongs to AS 98. Confederation 9 looks like one AS (with AS number 9) from the perspective of peer 200.1.1.1. This example uses a router in sub-AS 41.
[Sysname] bgp 41
[Sysname-bgp-default] confederation id 9
[Sysname-bgp-default] confederation peer-as 38 39 40
[Sysname-bgp-default] group Confed38 external
[Sysname-bgp-default] peer Confed38 as-number 38
[Sysname-bgp-default] peer 10.1.1.1 group Confed38
[Sysname-bgp-default] group Remote98 external
[Sysname-bgp-default] peer Remote98 as-number 98
[Sysname-bgp-default] peer 200.1.1.1 group Remote98
Use confederation nonstandard to enable compatibility with routers not compliant with RFC 3065 in the confederation.
Use undo confederation nonstandard to restore the default.
The device is compatible with only routers compliant with RFC 3065 in the confederation.
BGP instance view
Configure this command on all routers compliant with RFC 3065 to interact with those routers not compliant with RFC 3065 in the confederation.
# Confederation 100 consists of two sub-ASs, 64000 and 65000, and contains routers not compliant with RFC 3065. Enable compatibility with routers not compliant with RFC 3065 in the confederation.
[Sysname] bgp 64000
[Sysname-bgp-default] confederation id 100
[Sysname-bgp-default] confederation peer-as 65000
[Sysname-bgp-default] confederation nonstandard
confederation id
Use confederation peer-as to specify confederation peer sub-ASs.
Use undo confederation peer-as to remove the specified confederation peer sub-ASs.
undo confederation peer-as [ as-number-list ]
No confederation peer sub-ASs are specified.
BGP instance view
as-number-list: Specifies a sub-AS number list. A maximum of 32 sub-ASs can be configured in one command line. The expression is as-number-list = as-number &<1-32>. The as-number argument specifies a sub-AS number. The sub-AS number can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
Before this configuration, use the confederation id command to specify the confederation ID for the sub-ASs.
If the undo confederation peer-as command is executed without the as-number-list argument, all confederation peer sub-ASs are removed.
# In BGP instance view, specify confederation peer sub-ASs 2000 and 2001.
[Sysname] bgp 100
[Sysname-bgp-default] confederation peer-as 2000 2001
confederation id
dampening
Use dampening to enable BGP route dampening.
Use undo dampening to restore the default.
undo dampening
Route dampening is disabled.
half-life-reachable: Specifies a half-life for active routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes, in the range of 1 to 20000. A suppressed route whose penalty value decreases under the value is reused. By default, the reuse value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The route with a penalty value greater than the threshold is suppressed. The default value is 2000.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The value must be greater than the suppress value. By default, the value is 16000.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This command dampens only EBGP routes.
If an EBGP peer goes down after you configure this command, routes coming from the peer are dampened but not deleted.
After an active/standby switchover, BGP route dampening processes and information will be reset. The device needs to recalculate the dampening mechanism of BGP routes.
# In BGP IPv4 unicast address family view, configure BGP route dampening. Set the half-life for both active and suppressed routes to 10 minutes, the reuse threshold to 1000, the suppression threshold to 2000, and the ceiling penalty to 10000.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] dampening 10 10 1000 2000 10000
Use default local-preference to configure a default local preference.
Use undo default local-preference to restore the default.
The default local preference is 100.
value: Specifies a default local preference in the range of 0 to 4294967295. A larger value represents a higher preference.
You can also use the apply local-preference command in a routing policy to configure the local preference for BGP routes. If no routing policy is configured, all BGP routes use the local preference set by the default local-preference command. If a routing policy is configured, BGP routes matching the routing policy use the local preference set by the apply local-preference command. Other BGP routes use the local preference set by the default local-preference command.
# In BGP IPv4 unicast address family view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default local-preference 180
route-policy
default med
Use default med to specify a default MED value.
Use undo default med to restore the default.
default med med-value
undo default med
The default MED value is 0.
med-value: Specifies the default MED value in the range of 0 to 4294967295.
BGP selects a MED value in the following order:
1.     MED set by the apply cost command.
2.     MED set by the med keyword in the import-route command.
3.     MED set by the default med command.
4.     Original MED of a BGP route, or MED changed from the metric of a redistributed IGP route.
# In BGP IPv4 unicast address family view, set the default MED to 25.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default med 25
apply cost
import-route
route-policy
Use default-route imported to enable default route redistribution into the BGP routing table.
Use undo default-route imported to restore the default.
Default route redistribution into the BGP routing table is disabled.
By default, BGP does not redistribute default IGP routes. To redistribute default IGP routes into the BGP routing table, you must use the default-route imported command together with the import-route command.
# In BGP IPv4 unicast address family view, enable default route redistribution from OSPF process 1 into the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default-route imported
[Sysname-bgp-default-ipv4] import-route ospf 1
import-route
Use default-route update-first to configure BGP to send withdrawal messages of the default route prior to other routes.
Use undo default-route update-first to restore the default.
BGP does not send withdrawal messages of the default route prior to other routes.
BGP instance view
Typically a BGP router does not send withdrawal messages of the default route prior to other routes to its peers. If the peer relationship is down, the default route cannot be withdrawn first. Traffic interruption might occur. Use this command to configure BGP to send the withdrawal messages of the default route prior to other routes. This can reduce the traffic interruption time when the peer relationship is down.
# In BGP instance view, configure BGP to send withdrawal messages of the default route prior to other routes.
[Sysname] bgp 100
[Sysname-bgp-default] default-route update-first
display bgp dampening parameter
Use display bgp dampening parameter to display BGP route dampening parameters.
display bgp [ instance instance-name ] dampening parameter { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP route dampening parameters for the default BGP instance.
ipv4: Displays BGP IPv4 route dampening parameters.
ipv6: Displays BGP IPv6 route dampening parameters.
unicast: Displays BGP unicast route dampening parameters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP route dampening parameters for the public network.
# Display BGP IPv4 unicast route dampening parameters.
<Sysname> display bgp dampening parameter ipv4
Maximum suppression time (in seconds)              : 3973
Ceiling value                                      : 16000
Reuse value                                        : 750
Half-life time for reachable routes (in seconds)   : 900
Half-life time for unreachable routes (in seconds) : 900
Suppression threshold                              : 2000
Maximum time (in seconds) for the penalty value to decrease from the ceiling value to the reuse value.
Ceiling value
Penalty ceiling value.
Reuse value
Reuse threshold.
dampening
display bgp group
Use display bgp group to display BGP peer group information.
display bgp [ instance instance-name ] group ipv4 [  multicast | rtfilter | sr-policy | unicast [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group ipv6 [ multicast | sr-policy | unicast [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group link-state [ group-name group-name ]
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
display bgp [ instance instance-name ] group inof [ group-name group-name ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP peer group information for the default BGP instance.
ipv4: Displays IPv4 BGP peer group information.
ipv6: Displays IPv6 BGP peer group information.
link-state: Displays BGP LS peer group information.
rtfilter: Displays BGP IPv4 RT filter peer group information.
sr-policy: Displays BGP SR policy peer group information.
unicast: Displays BGP unicast peer group information.
l2vpn vpn: Displays BGP EVPN peer group information.
inof: Displays BGP iNOF peer group information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP peer group information for the public network.
group-name group-name: Specifies a BGP peer group by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a group, this command displays brief information about all BGP peer groups for the specified address family.
By default, the unicast keyword is used if you do not specify the unicast keyword.
# Display brief information about all BGP IPv4 unicast peer groups.
<Sysname> display bgp group ipv4
 BGP peer group: group1
 Remote AS: 600
 Authentication type configured: None
 Type: external
 Members:
  1.1.1.10
 BGP peer group: group2
 Remote AS number: not specified
 Type: external
 Members:
  2.2.2.2
# Display detailed information about BGP IPv4 unicast peer group group1.
<Sysname> display bgp group ipv4 group-name group1
 Listen AS: 600 700 800
 Type: external
 Maximum number of prefixes allowed: 4294967295
 Threshold: 75%
 Configured hold time: 180 seconds
 Keepalive time: 60 seconds
 Minimum time between advertisements: 30 seconds
 Peer preferred value: 0
 Site-of-Origin: Not specified
 Routing policy configured:
 Members:
* - Dynamically created peer
  1.1.1.10               600        0        0    0       0 00:00:55 Established
# Display detailed information about BGP IPv6 unicast peer group group2.
<Sysname> display bgp group ipv6 group-name group2
 Listen AS segment count: 3
 Type: external
 Threshold: 75%
 Members:
  2::2                   600        0        0    0       0 00:00:45 Established
  3::3                   600        0        0    0       0 00:00:40 Established
BGP peer group
Name of the BGP peer group.
Remote AS
AS number of the peer group.
Listen AS
AS numbers specified for the peer group. These AS numbers are applicable to only dynamic peers.
Number of AS number ranges specified for the peer group. These AS number ranges are applicable to only dynamic peers.
Authentication mode of the peer group:
·     None.
·     MD5.
Type of the peer groups:
·     external—EBGP peer group.
·     internal—IBGP peer group.
Maximum number of routes allowed to learn from the peer.
Threshold
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates a log message.
Configured hold interval in seconds.
Keepalive time
Keepalive interval in seconds.
Minimum route advertisement interval in seconds.
Preferred value specified for routes from the peer.
Site-of-Origin
SoO for the peer group.
Routing policy configured for the peer group.
If you do not specify a routing policy, this field displays No routing policy is configured.
Members
Information about peers included in the peer group.
An asterisk (*) before a peer address indicates that the peer is a dynamic peer.
Peer
IPv4 or IPv6 address of the peer.
AS
AS number of the peer.
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages to be sent.
PrefRcv
For the IPv4 and IPv6 address families, this field displays the number of prefixes received from the peer.
Up/Down
Lasting time of the current BGP session state.
Current state of the BGP session between the local router and the peer.
display bgp instance-info
Use display bgp instance-info to display information about all BGP instances.
# Display information about all BGP instances.
<Sysname> display bgp instance-info
Total BGP instances: 3
  BGP instance name               AS
  BGP1                            100
  BGP2                            200
  BGP3                            300
Table 5 Command output
Total BGP instances
Number of BGP instances.
BGP instance name
BGP instance name.
AS
AS number of the BGP instance.
display bgp network
Use display bgp network to display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp [ instance instance-name ] network { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the default BGP instance.
ipv4: Displays IPv4 address family information.
ipv6: Displays IPv6 address family information.
unicast: Displays BGP unicast address family information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays routing information for the public network.
By default, the unicast keyword is used.
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv4 unicast address family.
<Sysname> display bgp network ipv4
  Local AS number: 100
  Network           Mask            Route-policy        Short-cut
  20.1.1.0          255.255.255.0                       No
  40.1.1.0          255.255.255.0   abc                 No
  30.1.1.0          255.255.255.0                       Yes
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv6 unicast address family.
<Sysname> display bgp network ipv6
  Network           PrefixLen       Route-policy        Short-cut
  1::               24                                  No
  2::               24                                  No
  3::               64              policy1             No
  2::               24                                  Yes
Table 6 Command output
Network
Destination network address of the routes advertised by the network command and the shortcut routes.
Mask
Mask of the destination network address.
PrefixLen
Prefix length of the destination network address.
Route-policy
Routing policy that is applied to the route.
Short-cut
Whether the route is a shortcut route:
·     Yes.
·     No.
display bgp paths
Use display bgp paths to display BGP path attribute information.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP path attribute information for the default BGP instance.
as-regular-expression: Displays information about BGP path attributes whose AS_PATH attribute matches the specified regular expression. The as-regular-expression argument is a string of 1 to 256 characters. If you do not specify this argument, the command displays information about all BGP path attributes.
# Display information about all BGP path attributes.
<Sysname> display bgp paths
  RefCount    MED         Path/Origin
  3           0           ?
  2           0           100i
  3           0           100i
  1           0           ?
  1           0           ?
  1           0           ?
Table 7 Command output
RefCount
Number of BGP routes with these path attributes.
MED
MULTI_EXIT_DISC attribute.
Path/Origin
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH attribute—Records the ASs the route has passed, which avoids routing loops.
·     ORIGIN attribute—Identifies the origin of the route:
¡     i—Originated in the AS. The origin of routes advertised with the network command is IGP.
¡     e—Learned through EGP.
¡     ?—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
display bgp peer
Use display bgp peer to display BGP peer or peer group information.
display bgp [ instance instance-name ] peer ipv4 [ multicast | rtfilter | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ multicast | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer link-state [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer inof [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address } log-info | [ ipv4-address | ipv6-address ] verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP peer or peer group information for the default BGP instance.
ipv4: Displays IPv4 BGP peer or peer group information.
ipv6: Displays IPv6 BGP peer or peer group information.
link-state: Displays BGP LS peer or peer group information.
l2vpn evpn: Displays BGP EVPN peer or peer group information.
rtfilter: Displays BGP IPv4 RT filter peer or peer group information.
sr-policy: Displays BGP SR policy peer or peer group information.
unicast: Displays BGP unicast peer or peer group information.
inof: Displays BGP iNOF peer or peer group information.
vpn-instance-all: Displays BGP peer or peer group information for all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP peer or peer group information for the public network.
ipv4-address mask-length: Specifies a subnet. The value range for the mask length is 0 to 32. If you specify a subnet, this command displays information about all dynamic peers in the subnet.
ipv4-address: Specifies a peer by its IPv4 address.
ipv6-address prefix-length: Specifies a subnet. The value range for the prefix length is 0 to 128. If you specify a subnet, this command displays information about all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address.
group-name group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
log-info: Displays log information.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief BGP peer or peer group information.
If you do not specify any parameters, this command displays brief information about all BGP peers for the specified address family.
# Display brief information about all BGP IPv4 unicast peers.
<Sysname> display bgp peer ipv4
 BGP local router ID: 192.168.100.1
 Total number of peers: 1                  Peers in established state: 1
  10.2.1.2               200       13       16    0       0 00:10:34 Established
Table 8 Command output
Peer
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
For the IPv4 and IPv6 address families, this field displays the number of prefixes that have been received from the peer and added into the local BGP routing table.
Up/Down
# Display brief information about all dynamic peers in network 1.1.1.0/24.
<Sysname> display bgp peer ipv4 1.1.1.0 24
 Type: EBGP link
 Dynamic address range: 1.1.1.0 24
 Configured: Active Hold Time: 3 sec     Keepalive Time: 1 sec
 Address family IPv4 Unicast: Configured
 Maximum allowed prefix number: 100
 Threshold: 75%
 Minimum time between advertisements is 100 seconds
 Optional capabilities:
 Nexthop self has been configured
 Keep-all-routes has been configured
 Send community has been configured
 Send extend community has been configured
 Default route originating has been configured
 Multi-hop ebgp has been enabled
 Peer preferred value: 100
 BFD: Enabled
 Site-of-Origin: 1:1
 Track-route-policy: test
 No import as-path-acl list
 Export as-path-acl list is: 22
 No import prefix list
 Export prefix list is: p1
 No import route policy
 Export route policy is: p1
 No import filter-policy
 No export filter-policy
 Dynamic peers:
  1.1.1.3
# Display brief information about all dynamic peers in network 1::/64.
<Sysname> display bgp peer ipv6 1:: 64
 Type: IBGP link
 Dynamic address range: 1:: 64
 Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
 Address family IPv6 Unicast: Configured
 Threshold: 75%
 Minimum time between advertisements is 15 seconds
 Dynamic peers:
  1::1
Table 9 Command output
BGP connection type between the local router and the dynamic peer:
·     IBGP link—IBGP connection.
·     EBGP link—EBGP connection.
Configured
Timers configured on the local router in seconds, including the hold time (Active Hold Time) and keepalive interval (Keepalive Time).
IPv4 unicast address family capability.
Address family link-state
LS address family capability.
IPv6 unicast address family capability.
Address family iNOF
iNOF address family capability.
Threshold
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates alarm messages.
Optional capabilities supported by the local end.
Peer Preferred Value
Preferred value specified for the routes from the peer.
BFD
Whether BFD is enabled to detect the link to the BGP peers.
Site-of-Origin
SoO attribute specified for the peer.
Track-route-policy
Routing policy used to achieve Track-based priority adjustment for BGP routes advertised to the peer. If the peer advertise lowest-priority track-route-policy command is not configured, this field will not be displayed.
Listen AS
AS numbers specified for the dynamic peer.
Number of AS number ranges specified for the dynamic peer.
Routing policy configured for the peer.
Dynamic peers
IP addresses of dynamic peers.
# Display detailed information about BGP IPv4 unicast peer 10.2.1.2.
<Sysname> display bgp peer ipv4 10.2.1.2 verbose
         Peer: 10.2.1.2          Local: 192.168.100.1
         Type: EBGP link
         BGP version 4, remote router ID 192.168.100.2
         Update group ID: 0
         BGP current state: Established, Up for 00h11m10s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 60672
         Local source address: 10.2.1.1
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer supports BGP multi-protocol extension
         Peer supports BGP route refresh capability
         Peer supports BGP enhanced route refresh capability
         Peer supports BGP route AS4 capability
         Address family IPv4 Unicast: advertised and received
         Address family LS: received
InQ updates: 0, OutQ updates: 0
 NLRI statistics:
         Rcvd:   UnReach NLRI          0,      Reach NLRI          0
         Sent:   UnReach NLRI          0,      Reach NLRI          0
 Message statistics:
 Msg type     Last rcvd time/      Current rcvd count/      History rcvd count/
              Last sent time       Current sent count       History sent count
 Open         10:38:50-2013.7.23   1                        1
 Update       10:38:51-2013.7.23   1                        1
 Notification -                    0                        0
              -                    0                        0
 Keepalive    10:38:50-2013.7.23   1                        1
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    3                        3
              -                    3                        3
 Threshold: 75%
  Withdraw route refresh capability has been enabled
 TCP-MSS configured value: 200
 Peer Preferred Value: 0
 GTSM has been enabled, and the maximum number of hops is 10
 BFD: Enabled
# Display detailed information about BGP peer 2::2 in IPv4 unicast address family.
<Sysname> display bgp peer ipv4 2::2 verbose
         Peer: 2::2      Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 3.3.3.3
         BGP current state: Established, Up for 00h24m31s
         Port:  Local - 179      Remote - 51971
         Local source address: 2::1
         Peer supports BGP extended nexthop encoding capability
 NLRI statistics:
         Rcvd:   UnReach NLRI          0,      Reach NLRI          1
         Sent:   UnReach NLRI          0,      Reach NLRI          5
 Message statistics:
 Open         15:45:52-2019.4.19   1                        2
 Update       15:45:53-2019.4.19   2                        4
              15:45:52-2019.4.19   6                        12
 Notification 15:45:50-2019.4.19   0                        1
              -                    0                        0
 Keepalive    16:09:25-2019.4.19   25                       31
              16:10:13-2019.4.19   30                       36
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    28                       38
              -                    37                       50
 Threshold: 75%
  Extended nexthop encoding has been enabled
# Display detailed information about BGP peer 1::2 in IPv6 unicast address family.
<Sysname> display bgp peer ipv6 1::2 verbose
         Peer: 1::2      Local: 192.168.1.136
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.135
         Update group ID: 0
         BGP current state: Established, Up for 00h05m48s
         Port:  Local - 13184    Remote - 179
         Local source address: 1::1
 NLRI statistics:
         Sent:   UnReach NLRI          0,       Reach NLRI          3
 Message statistics:
 Open         18:59:15-2013.4.24   1                        1
              18:59:15-2013.4.24   1                        2
 Update       -                    0                        0
              18:59:16-2013.4.24   1                        1
 Notification -                    0                        0
              18:59:15-2013.4.24   0                        1
 Keepalive    18:59:15-2013.4.24   1                        1
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    2                        2
              -                    3                        5
 Threshold: 75%
 Authentication type configured: MD5
 BFD: Enabled
 Min transmit-interval: 10ms
 Min receive-interval: 10ms
 Detect-multiplier: 10
 Flap dampening: Enabled
  Max idle time=1800 sec    Min established time=600 sec
Table 10 Command output
Peer
Local
Local router ID.
BGP connection type between the local router and the peer:
remote router ID
Router ID of the peer.
Update group ID
ID of the update group to which the BGP peer belongs. This field is displayed only when the BGP peer is in Established state.
BGP current state
Up for
Lasting time of the BGP session.
BGP current event
Current event of the BGP session between the local router and the peer.
BGP last state
Previous state of the BGP session.
Port
TCP port numbers of the local router and its peer.
IPv4 or IPv6 source address that the local device used to establish a TCP connection with the peer.
Configured
Received
Received timer (configured on the peer) in seconds, including the hold time (Active Hold Time).
Negotiated
Negotiated timers in seconds, including the hold time (Active Hold Time) and keepalive interval (Keepalive Time).
Optional capabilities supported by the peer.
The peer supports BGP multi-protocol extension.
The peer supports BGP route refresh.
The peer supports exchanging BGP enhanced ROUTE-REFRESH messages. Only withdrawal ROUTE-REFRESH messages are supported in the current software version.
The peer supports 4-byte AS number.
Peers in IPv4 unicast address family support extended next hop encoding capability.
IPv4 unicast address family capability: routes of the address family can be advertised and received.
Address family IPv4 SR Policy
IPv4 SR policy address family capability: routes of the address family can be advertised and received.
Address family LS
LS address family capability: routes of the address family can be advertised and received.
IPv6 unicast address family capability: routes of the address family can be advertised and received.
Address family iNOF
iNOF address family capability: routes of the address family can be advertised and received.
InQ updates
Number of received updates to be processed.
OutQ updates
Number of updates to be sent to the peer.
NLRI statistics
Number of the reachable and unreachable routes received from and sent to the peer after the BGP session is established.
Message statistics
BGP message statistics.
Msg type
BGP message type.
Last rcvd time/Last sent time
Time when the most recent BGP message was received from or sent to the peer.
Current rcvd count/Current sent count
Number of BGP messages received from or sent to the peer on the current BGP session.
History rcvd count/History sent count
Number of BGP messages received from or sent to the peer since the BGP peer relationship was established.
Total
Total number of received and sent messages.
Threshold
The local end supports multi-protocol extension.
The local end supports route refresh.
The local end supports exchanging withdrawal ROUTE-REFRESH messages.
Extended Nexthop Encoding has been enabled
The local end supports the extended next hop encoding capability.
TCP maximum segment size used for TCP connection to the peer.
Maximum number of hops to the specified peer.
BFD
Whether BFD is enabled to detect the link to the BGP peer.
Site-of-Origin
Track-route-policy
Flap dampening
Peer flap dampening state.
Max idle time
Maximum time (in seconds) during which a BGP peer remains in idle state.
Minimum time (in seconds) during which a BGP peer remains in Established state so as to exit the dampened state.
# Display log information for BGP IPv4 unicast peer 1.1.1.1.
<Sysname> display bgp peer ipv4 1.1.1.1 log-info
 Peer : 1.1.1.1
     Date      Time    State Notification
                             Error/SubError
  06-Feb-2013 22:54:42 Down  Send notification with error 6/4
                             Cease/Administrative Reset
                             <administrative reset>
Table 11 Command output
Peer
Date
Date on which the Notification was sent or received.
Time
Time at which the Notification was sent or received.
BGP session state:
·     Up—The BGP session is in Established state.
·     Down—The BGP session is down.
Notification Error/SubError
Error code of the Notification, indicating the cause of why the BGP session was down.
·     Error—Refers to the error code, which identifies the type of the Notification.
·     SubError—Refers to the error subcode of the Notification, which identifies the specific information about the reported error.
display bgp routing-table dampened
Use display bgp routing-table dampened to display dampened BGP routes.
display bgp [ instance instance-name ] routing-table dampened { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays dampened BGP routes for the default BGP instance.
ipv4: Displays dampened BGP IPv4 routes.
ipv6: Displays dampened BGP IPv6 routes.
unicast: Displays dampened BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays dampened BGP routes for the public network.
# Display dampened BGP IPv4 unicast routes.
<Sysname> display bgp routing-table dampened ipv4
 Total number of routes: 1
 BGP local router ID is 192.168.1.135
               a – additional-path
     Network            From            Reuse                         Path/Ogn
  de 20.1.1.0/24        10.1.1.2        00:56:27                      100i
# Display dampened BGP IPv6 unicast routes.
<Sysname> display bgp routing-table dampened ipv6
 Total number of routes: 2
               a – additional-path
  de Network : 2::                                      PrefixLen : 64
     From    : 10.1.1.1                                 Reuse     : 00:39:49
     Path/Ogn: 100i
     From    : 1::1                                     Reuse     : 00:39:49
     Path/Ogn: 100i
Table 12 Command output
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d – dampened—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
·     a – additional-path—Add-Path optimal route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS. The origin of routes advertised with the network command is IGP.
·     e – EGP—Learned through EGP.
·     ?– incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
Network
Destination network address.
From
IP address from which the route was received.
Reuse
Reuse time of the route.
Path/Ogn
·     ORIGIN attribute—Identifies the origin of the route.
dampening
dampening ibgp (MPLS Command Reference)
reset bgp dampening
display bgp routing-table flap-info
Use display bgp routing-table flap-info to display BGP route flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP route flap statistics for the default BGP instance.
ipv4: Displays BGP IPv4 route flap statistics.
ipv6: Displays BGP IPv6 route flap statistics.
vpnv4: Displays IBGP VPNv4 route flap statistics.
unicast: Displays BGP unicast route flap statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP route flap statistics for the public network.
ipv4-address: Specifies a destination network address.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a network mask in dotted decimal notation.
longest-match: Specifies longest match mode, which selects the longest matching route through the following steps:
1.     ANDs the specified network address with the mask of each route.
2.     Matches a route if the AND result is the same as the network address of the route and the mask of the route is shorter than or equal to the specified mask.
3.     Selects the route with the longest mask among the matching routes.
ipv6-address prefix-length: Displays route flap statistics for BGP IPv6 routes that match the specified network address, and match the prefix length in the range of 0 to 128.
as-path-acl as-path-acl-number: Displays route flap statistics for BGP routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays route flap statistics for BGP routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a BGP IPv4 unicast or multicast route. If the result matches the network address of the route, the command displays flap statistics of the route.
If you specify the ipv4-address mask or ipv4-address mask-length argument, and do not specify the longest-match keyword, the command displays flap statistics of the BGP IPv4 unicast or multicast route that matches both the specified destination network address and the mask (or mask length).
# Display BGP IPv4 unicast route flap statistics.
<Sysname> display bgp routing-table flap-info ipv4
               a – additional-path
     Network            From            Flaps  Duration  Reuse        Path/Ogn
  de 20.1.1.0/24        10.1.1.2        1      00:02:36  00:53:58     100i
# Display BGP IPv6 unicast route flap statistics.
<Sysname> display bgp routing-table flap-info ipv6
               a – additional-path
     From    : 10.1.1.1                                 Flaps     : 5
     Duration: 00:03:25                                 Reuse     : 00:39:28
     Path/Ogn: 100i
     From    : 1::1                                     Flaps     : 5
     Path/Ogn: 100i
Table 13 Command output
Status codes
Status codes:
·     a – additional-path.
Origin
Network
From
Source IP address of the route.
Flaps
Number of routing flaps.
Duration
Duration time of the flap route.
Reuse
Path/Ogn
dampening
reset bgp flap-info
display bgp routing-table ipv4 unicast
Use display bgp routing-table ipv4 unicast to display BGP IPv4 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask [ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | ipv4-address [ mask-length | mask ] { as-path | cluster-list | community | ext-community } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number }  [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-community-list-number | adv-large-community-list-number | large-comm-list-name } } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] vpn-instance vpn-instance-name system-ip
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv4 unicast routing information for the default BGP instance.
longest-match: Displays the longest matching BGP IPv4 unicast route. The system first ANDs the specified network address with the mask of each route, and then selects the longest matching BGP IPv4 unicast route as follows:
·     If you specify a mask, the system selects routes whose network address matches the AND result and whose mask is shorter than or equal to the specified mask. The command displays brief information about the route with the longest mask among the matching routes.
·     If you do not specify a mask, the system selects routes whose network address matches the AND result. The command displays detailed information about the route with the longest mask among the matching routes.
advertise-info: Displays advertisement information for BGP IPv4 unicast routes.
as-path: Displays AS_PATH attribute information for BGP IPv4 unicast routes.
cluster-list: Displays CLUSTER_LIST attribute information for BGP IPv4 unicast routes.
community: Displays community attribute information for BGP IPv4 unicast routes or displays BGP IPv4 unicast routes that match the community number criterion specified for route filtering.
ext-community: Displays extended community attribute information for BGP IPv4 unicast routes or displays BGP IPv4 unicast routes that match the extended community attribute criterion specified for route filtering.
peer ipv4-address: Displays BGP IPv4 unicast routing information advertised to or received from the specified IPv4 peer.
peer ipv6-address: Displays BGP IPv4 unicast routing information advertised to or received from the specified IPv6 peer.
advertised-routes: Displays BGP IPv4 unicast routing information advertised to the specified peer.
received-routes: Displays BGP IPv4 unicast routing information received from the specified peer.
statistics: Displays BGP IPv4 unicast route statistics.
as-path-acl as-path-acl-number: Displays BGP IPv4 unicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv4 unicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
community-number&<1-32>: Specifies a community number in integer format. The value range for the community-number argument is 1 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
aa:nn&<1-32>: Specifies a community number in aa:nn format. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
internet: Displays BGP IPv4 unicast routes that have the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Displays BGP IPv4 unicast routes that have the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any peers.
no-export: Displays BGP IPv4 unicast routes that have the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Displays BGP IPv4 unicast routes that have the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP IPv4 unicast routes that exactly match the specified community attributes, extended community attributes, or large community attributes. If you do not specify this keyword, the command displays BGP IPv4 unicast routes that meet one of the following requirements:
·     The community attributes of the routes include the specified community community attributes.
·     The extended community attributes of the routes include the specified extended community attributes.
·     The large community attributes of the routes include the specified large community attributes.
community-list: Displays BGP IPv4 unicast routes that match a community list.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
large-community: Displays BGP IPv4 unicast routes that match the specified large community attribute. You can specify a large community attribute by its community number.
aa:bb:cc&<1-32>: Specifies a large community number. aa, bb, and cc are all in the range of 0 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified. If you do not specify this argument, this command displays information about all BGP IPv4 unicast routes that have a large community attribute.
large-community-list: Displays BGP IPv4 unicast routes that match the specified large community list.
basic-large-comm-list-number: Specifies a basic large community list by its number. The value range for this argument is 1 to 99.
adv-large-comm-list-number: Specifies an advanced large community list by its number. The value range for this argument is 100 to 199.
large-comm-list-name: Specifies a large community list by its name. A large community list name is a case-sensitive string of 1 to 63 characters and cannot contain only digits.
bandwidth link-bandwidth-value: Specifies a link bandwidth attribute value. The value for this argument is a string of 3 to 16 characters in 16-bit AS number:32-bit user-defined number format, for example, 100:3. The value range is 0 to 65535 for an AS number and is 0 to 4294967295 for a user-defined number.
color color: Specifies a color attribute value. The value for this argument is a string of 4 to 13 characters in Color-Only flag:color value format, for example, 10:3. The CO flag is a binary number in the range of 00 to 11 and the color value range is 0 to 4294967295.
rt route-target: Specifies a Route Target (RT) attribute value. The value for this argument is a string of 3 to 24 characters.
soo site-of-origin: Specifies a Site of Origin (SoO) attribute value. The value for this argument is a string of 3 to 24 characters.
&<1-32>: Indicates that you can specify a maximum of 32 extended community attributes.
system-ip: Displays IPv4 routing information generated based on the Priority-Color extended community attribute in the specified BGP VPN instance.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 unicast routes.
If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays information about the route.
If you specify the ipv4-address mask or ipv4-address mask-length argument and do not specify the longest-match keyword, this command displays information about the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
This command displays BGP IPv4 unicast routing information regardless of whether the unicast keyword is specified.
When you specify none of the community-number, aa:nn, internet, no-advertise, no-export, and no-export-subconfed parameters, this command displays BGP IPv4 unicast routes that have community attributes. In this situation, the whole-match keyword does not take effect.
When you specify an RT or SoO attribute, use one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3. The value range is 0 to 65535 for an AS number and is 0 to 4294967295 for a user-defined number.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1. The value range is 0 to 65535 for a user-defined number.
·     32-bit AS number:16-bit user-defined number. For example, 70000:3. The value range is 65536 to 4294967295 for an AS number and is 0 to 65535 for a user-defined number.
·     32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
·     32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
When you specify none of the bandwidth, color, rt, and soo parameters, this command displays BGP IPv4 unicast routes that have extended community attributes. In this situation, the whole-match keyword does not take effect.
If you specify the adv-large-community-list-number argument together with the whole-match keyword, the whole-match keyword does not take effect.
# Display brief information about all BGP IPv4 unicast routes.
<Sysname> display bgp routing-table ipv4
 Total number of routes: 4
 BGP local router ID is 192.168.100.1
               a – additional-path
* >  10.2.1.0/24        10.2.1.1        0                     0       i
   e                    10.2.1.2        0                     0       4294967295
 4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290... i
* >  192.168.1.0/24     192.168.1.135   0                     0       i
*  e                    10.2.1.2        0                     0       200i
# Display information about BGP IPv4 unicast routes that match AS path list 1.
<Sysname> display bgp routing-table ipv4 as-path-acl 1
               a – additional-path
* >e 30.1.1.0/24        20.1.1.1                              0       200i
# Display information about all public BGP IPv4 unicast routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes
 Status codes: * - valid, > - best, d - damped, h - history,,
               s - suppressed, S - Stale, i - internal, e - external
               a – additional-path
# Display information about all public BGP IPv4 unicast routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
               a – additional-path
   e 10.2.1.0/24        10.2.1.2        0                     0       200i
*  e 192.168.1.0/24     10.2.1.2        0                     0       200i
# Display information about the public-network BGP IPv4 unicast routes that have community attributes in BGP instance default.
<Sysname> display bgp routing-table ipv4 community
               a – additional-path
     Network       NextHop         MED     LocPrf   PrefVal   Community
* >  10.2.1.0/24   10.2.1.1        0                 0        <1:1>
* >  192.168.1.0   192.168.1.135   0                 0        <1:2>
# Display information about the public-network BGP IPv4 unicast routes that have extended community attributes in BGP instance default.
<Sysname> dis bgp routing-table ipv4 ext-community
 BGP local router ID is 192.168.184.56
               a - additional-path
     Network            NextHop         MED        LocPrf     PrefVal Ext-Community
* >i 9.1.1.0/24         120.1.1.1       0          100        0       <RT: 1:1>
# Display information about all BGP IPv4 unicast routes that have a large community attribute on the public network for the default BGP instance.
<Sysname> display bgp routing-table ipv4 large-community
 Total number of routes: 3
               a – additional-path
     Network       NextHop         MED     LocPrf   PrefVal   Large-community
* >  10.2.1.0/24   10.2.1.1        0                 0        <1:1:1>
* >  192.168.1.0   192.168.1.135   0                 0        <1:1:2>
# Displays IPv4 routing information generated based on the Priority-Color extended community attribute in BGP VPN instance vpn1.
<Sysname> display bgp routing-table ipv4 vpn-instance vpn1 system-ip
 BGP local router ID is 50.50.50.30
               s - suppressed, S - stale, i - internal, e - external,
               a - additional-path
     Network            NextHop         SystemIP        Priority       Path/Ogn
* >i 100.1.1.8/32       50.50.50.50     N/A             0              i
*  i                    50.50.50.50     10.10.10.10     1              i
Command output
Status codes
Status codes:
Origin
Network
NextHop
Next hop IP address.
MED
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path/Ogn
·     AS_PATH—Records the ASs the route has passed, which avoids routing loops. A maximum of 16 AS numbers can be displayed in this field. Exceeding AS numbers are omitted and are viewable if you display detailed routing information.
·     ORIGIN—Identifies the origin of the route.
Community
Community attribute value.
Ext-Community
Extended community attribute value.
Large-community
Large community attribute value.
SystemIP
System IP iterated based on the Priority-Color extended community attribute. The field displays the next hop of the route. If the route is a primary route, this field displays N/A.
Priority
Priority value of the Priority-Color extended community attribute used to generate the route. The priority value of a primary route is zero.
# Display detailed information about BGP IPv4 unicast routes destined to network 10.2.1.0/24.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24
 Paths:   2 available, 1 best
 BGP routing table information of 10.2.1.0/24:
 Imported route.
 Original nexthop: 10.2.1.1
 Out interface   : HundredGigE1/0/2
 Route age       : 01h30m23s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  :Not found
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, pref-val 0, pre 0
 State           : valid, local, best
 Originator      : 176.1.1.2
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel policy   : NULL
 Rely tunnel IDs : N/A
 Rely nexthop   : not resolved
 Original nexthop: 10.2.1.2
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0, pref-val 0, pre 255
 State           : external
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 Dscp            : N/A
 Exp             : N/A
# Display detailed information about the BGP IPv4 unicast route destined to address 1.1.1.1/32.
<Sysname> display bgp routing-table ipv4 1.1.1.1 32
 BGP routing table information of 1.1.1.1/32:
 Rely nexthop    : 10.2.1.1
 Route age       : 01h35m24s
 OutLabel        : NULL
 Ext-Community   : <Device-id: Type 0x84ef, ID 4.4.4.4>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Dscp            : N/A
 Exp             : N/A
 Backup route.
 Rely nexthop    : 10.2.1.2
 Out interface   : HundredGigE1/0/3
 Route age       : 01h38m25s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : external
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Dscp            : N/A
 Exp             : N/A
# Display detailed information about the longest matching BGP IPv4 unicast route destined to 20.1.1.1.
<Sysname> display bgp routing-table ipv4 20.1.1.1 longest-match
 Paths:   1 available, 1 best
 BGP routing table information of 20.1.1.1/31:
 Imported route.
 Original nexthop: 0.0.0.0
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : MED 0, pref-val 32768
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# Display community attribute information for the BGP IPv4 unicast routes with destination network 10.3.1.0/24.
<Sysname> display bgp routing-table ipv4 10.3.1.0 24 community
 BGP local router ID: 1.1.1.9
 Community: no-export
# Display extended community attribute information for the BGP IPv4 unicast routes with destination network 10.3.1.0/24.
<Sysname> display bgp routing-table ipv4 10.3.1.0 24 ext-community
 Ext-Community: <RT: 1:1>
# Display AS_PATH attribute information for the BGP IPv4 unicast routes with destination network 10.3.1.0/24.
<Sysname> display bgp routing-table ipv4 10.3.1.0 24 as-path
 As-path: 200
# Display CLUSTER_LIST attribute information for the BGP IPv4 unicast routes with destination network 10.3.1.0/24.
<Sysname> display bgp routing-table ipv4 10.3.1.0 24 cluster-list
 Cluster list: 80
Table 14 Command output
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
OutLabel
Outgoing label of the route.
Out interface
Next hop output interface information.
Route age
Time elapsed since the most recent route update.
RxPathID
Add-Path ID of received routes.
TxPathID
Add-Path ID of advertised routes.
Org-validation
BGP RPKI validation state:
·     Valid.
·     Not found.
·     Invalid.
AS-path
AS_PATH attribute of the route, which records the ASs the route has passed and avoids routing loops.
Community
Community attribute.
Ext-Community
Extended community attribute:
·     RT—Route target attribute. Supported RT formats include:
¡     16-bit integer AS number:32-bit user-defined number. For example, 101:3.
¡     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
¡     32-bit integer AS number:16-bit user-defined number. For example, 70000:3.
¡     32-bit IPv4 address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
¡     16-bit dotted AS number:32-bit user-defined number. For example, 0.12345:1. The maximum dotted AS number is 0.65535.
¡     32-bit dotted AS number:16-bit user-defined number. For example, 10.1:1. The minimum dotted AS number is 1.0.
·     Bandwidth—Link bandwidth attribute in 16-bit AS number:32-bit bandwidth value format.
·     CO-Flag—Color attribute in Color-Only (CO) bit:color value format.
·     SOO—Site of Origin attribute. Supported formats include:
·     RT Import—VRF Route Import Extended Community attribute, carrying local source address and BGP route VPN instance information. This attribute is in the 32-bit/128-bit source address:VPN instance index format, for example, 192.168.122.15:1.
·     SrcAs—Source AS Extended Community attribute, carrying the local BGP AS number information. The value of this attribute is the AS number of the MVPN multicast source, in the 32-bit AS number:0 format, for example, 100:0.
·     HostRoute—Host route.
·     IP Mobility—IP migration attribute. Flag indicates whether the IP address can be migrated. 1 indicates that the IP address cannot be migrated and 0 indicates that the IP address can be migrated. SeqNum represents the host migration serial number. The larger the serial number, the later the migration.
·     Device-id—Device ID attribute. This attribute contains the type value and the router ID.
Origin
·     igp—Originated in the AS. The origin of routes advertised with the network command is IGP.
·     egp—Learned through EGP.
·     incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localprefLocal preference value.
·     pref-val—Preferred value.
·     pre—Route preference.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
·     delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output.
·     localredist—If the state of a route is localredist, the route can be one of the following routes:
¡     Route that is redistributed from another local VPN instance or the public instance to the current VPN instance.
¡     Route that is redistributed from a VPN instance to the public instance.
·     remoteredist—Route that is received from a peer and is redistributed to a local VPN instance.
·     remoteredist—The route is added from another BGP routing table.
·     evpn ad remoteredist—The route is generated based on an Ethernet auto-discovery route.
·     not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see table "Reason why the route is not selected as the optimal route.".
·     not ECMP for reason—Reason why the route does not form ECMP routes with other routes. For more information, see table "Reason why the route does not form ECMP routes with other routes.".
·     bgp-rib-only—The route will not be flushed to the routing table. This field is displayed only in the detailed command output.
Originator
Router ID of the peer that advertised the route to the reflector.
Cluster list
CLUSTER_LIST attribute of the route.
From
IP address of the BGP peer that advertised the route.
Rely Nexthop
Next hop found by route recursion. If no next hop is found, this field displays not resolved.
SystemIP
System IP iterated through the Priority-Color extended community attribute. The field displays the next hop of the route. If the route is a primary route or is not iterated based on the Priority-Color extended community attribute, this field is not available.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
Tag
Route tag set by using the apply tag command, or route tag that the BGP route inherited from a redistributed IGP route.
Connector
Connector attribute in Type 1, Value RD:IPv4 address format.
·     The RD argument represents the route distinguisher of the route.
·     The IPv4 address argument represents the IPv4 address of the source PE.
When the MVPN networking model is MDT-based MVPN inter-AS option B, this attribute transmits source PE address information used for RPF check on PEs.
When a route does not carry the Connector attribute, this field is not displayed.
VPN-Peer UserID
VPN peer ID in the range of 1 to 134217727. N/A indicates that the route does not support this field.
DSCP
DSCP value in the range of 0 to 63. N/A indicates that the route does not support this field.
EXP
EXP value. N/A indicates that the route does not support this field.
Tunnel policy
Tunnel policy that takes effect. NULL indicates that no tunnel policy takes effect.
Rely Tunnel IDs
Tunnel index IDs after route recursion. This field displays multiple tunnel index IDs if ECMP tunnels exist and displays N/A if no tunnels are found by route recursion.
Table 15 Reason why the route is not selected as the optimal route
Reason
preferred-value
Routes with larger preferred values exist.
local-preference
Routes with larger local preference values exist.
local-origin-route
There are routes whose local-origin-route attribute has a higher priority.
BGP selects the optimal route from local routes in this order: route generated by the network command, route redistributed by the import-route command, and summary route.
aigp
Routes carrying the AIGP attribute or routes with smaller AIGP attribute values exist.
as-path
Routes with smaller AS_PATH attribute values exist.
origin
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority.
med
Routes with smaller MED values exist.
remote-route
There are routes whose remote-route attribute has a higher priority.
BGP selects the optimal route from remote routes in this order:
·     Route learned from an EBGP peer.
·     Route learned from a confederation EBGP peer.
·     Route learned from a confederation IBGP peer.
·     Route learned from an IBGP peer.
igp-cost
Routes with smaller IGP metrics exist.
relydepth
Routes with smaller recursion depth values exist.
rfc5004
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers.
router-id
Routes with smaller router IDs exist.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route.
cluster-list
Routes with smaller CLUSTER_LIST attribute values exist.
peer-address
Routes advertised by peers with lower IP addresses exist.
received
Earlier learned routes exist.
Table 16 Reason why the route does not form ECMP routes with other routes
Reason
preferred-value
The preferred value of the route is different than other routes.
local-preference
The local preference of the route is different than other routes.
local-origin-route
The way for generating the route is different than other routes.
aigp
The AIGP attribute state (whether or not the attribute is carried) or the AIGP attribute value of the route is different than other routes.
as-path
The AS_PATH attribute of the route is different than other routes.
origin
The ORIGIN attribute of the route is different than other routes.
med
The MED attribute of the route is different than other routes.
remote-route
The route comes from a different EBGP, confederation EBGP, confederation IBGP, or IBGP peer than other routes.
igp-cost
The IGP metric of the route is different than other routes.
samenexthop
The route has the same next hop with another route.
# Display statistics for public BGP IPv4 unicast routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes statistics
 Advertised routes total: 2
# Display statistics for public BGP IPv4 unicast routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes statistics
 Received routes total: 2
Table 17 Command output
Total number of advertised routes.
Total number of received routes.
# Display BGP IPv4 unicast route statistics.
<Sysname> display bgp routing-table ipv4 statistics
# Display statistics about the BGP IPv4 unicast routes that have community attributes.
<Sysname> display bgp routing-table ipv4 statistics community
Table 18 Command output
Total number of routes.
# Display advertisement information for the BGP IPv4 unicast route destined to network 10.2.1.0/24.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.2.1.0/24(TxPathID:0):
    10.2.1.2
Table 19 Command output
BGP local router ID
Local BGP router ID.
Local AS number
Local AS number.
Paths
Number of optimal routes to the destination.
Advertisement information for network 10.2.1.0/24.
Peers to which the network has been advertised.
# Display information about all BGP IPv4 unicast routes that have a large community attribute and are destined for network 10.3.1.0/24.
<Sysname> display bgp routing-table ipv4 10.3.1.0 24 large-community
 Large-community: <1:1:2>, <1:1:3>
Table 20 Command output
BGP local router ID
Local AS number
Local AS number.
Paths
Number of routes to the destination.
·     available—Number of available routes.
Information about all BGP IPv4 unicast routes that have a large community attribute and are destined for network 10.3.1.0/24.
Large-community
Large community attribute.
apply extcommunity priority-color (Layer 3—IP Routing Command Reference)
ip as-path (Layer 3—IP Routing Command Reference)
ip community-list (Layer 3—IP Routing Command Reference)
display bgp routing-table ipv6 unicast
Use display bgp routing-table ipv6 unicast to display BGP IPv6 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | ipv6-address prefix-length { as-path | cluster-list | community | ext-community } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-comm-list-number | adv-large-comm-list-number | large-comm-list-name } } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] vpn-instance vpn-instance-name system-ip
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv6 unicast routing information for the default BGP instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the BGP IPv6 unicast routing information for the public network.
ipv6-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If you do not specify this argument, the command displays brief information about all BGP IPv6 unicast routing information.
advertise-info: Displays advertisement information for BGP IPv6 unicast routes. If you do not specify this keyword, the command displays the BGP IPv6 unicast routing table.
as-path: Displays AS_PATH attribute information for BGP IPv6 unicast routes.
cluster-list: Displays CLUSTER_LIST attribute information for BGP IPv6 unicast routes.
community: Displays community attribute information for BGP IPv6 unicast routes or displays BGP IPv6 unicast routes that match the community number criterion specified for route filtering.
ext-community: Displays extended community attribute information for BGP IPv6 unicast routes or displays BGP IPv6 unicast routes that match the extended community attribute criterion specified for route filtering.
peer: Displays BGP IPv6 unicast routing information advertised to or received from the specified peer.
ipv4-address: Specifies a BGP peer by its IPv4 address.
ipv6-address: Specifies a BGP peer by its IPv6 address.
advertised-routes: Displays BGP IPv6 unicast routing information advertised to the specified peer.
received-routes: Displays BGP IPv6 unicast routing information received from the specified peer.
statistics: Displays BGP IPv6 unicast route statistics.
as-path-acl as-path-acl-number: Displays BGP IPv6 unicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv6 unicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
internet: Displays BGP IPv6 unicast routes that have the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Displays BGP IPv6 unicast routes that have the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any peers.
no-export: Displays BGP IPv6 unicast routes that have the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Displays BGP IPv6 unicast routes that have the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP IPv6 unicast routes that exactly match the specified community attributes, extended community attributes, or large community attributes. If you do not specify this keyword, the command displays BGP IPv6 unicast routes that meet one of the following requirements:
·     The community attributes of the routes include the specified community attributes.
community-list: Displays BGP IPv6 unicast routes that match a community list.
large-community: Displays BGP IPv6 unicast routes that match the specified large community attribute. You can specify a large community attribute by its community number.
aa:bb:cc&<1-32>: Specifies a large community number. aa, bb, and cc are all in the range of 0 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified. If you do not specify this argument, this command displays information about all BGP IPv6 unicast routes that has a large community attribute.
large-community-list: Displays BGP IPv6 unicast routes that match the specified large community list.
system-ip: Displays IPv6 routing information generated based on the Priority-Color extended community attribute in the specified BGP VPN instance.
This command displays BGP IPv6 unicast routing information regardless of whether the unicast keyword is specified.
When you specify none of the community-number, aa:nn, internet, no-advertise, no-export, and no-export-subconfed parameters, this command displays BGP IPv6 unicast routes that have community attributes. In this situation, the whole-match keyword does not take effect.
When you specify none of the bandwidth, color, rt, and soo parameters, this command displays BGP IPv6 unicast routes that have extended community attributes. In this situation, the whole-match keyword does not take effect.
# Display brief information about all BGP IPv6 unicast routes.
<Sysname> display bgp routing-table ipv6
 BGP local router ID is 192.168.1.136
               a – additional-path
* >e Network : 3::                                      PrefixLen : 64
     NextHop : 1::2                                     LocPrf    :
     MED     :
     Path/Ogn: 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290... i
# Display information about BGP IPv6 unicast routes that match AS path list 1.
<Sysname> display bgp routing-table ipv6 as-path-acl 1
               a – additional-path
* >e Network : 2::                                      PrefixLen : 64
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
# Display information about BGP IPv6 unicast routes that match BGP community list 100.
<Sysname> display bgp routing-table ipv6 community-list 100
               a – additional-path
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
# Display information about all BGP IPv6 unicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes
               a – additional-path
* >  Network : 2::                                      PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: i
# Display information about all BGP IPv6 unicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes
               a – additional-path
     NextHop : ::FFFF:10.1.1.1                          LocPrf    :
     MED     : 0
     Path/Ogn: 100i
# Display information about the BGP IPv6 unicast routes that have community attributes.
               a – additional-path
     PrefVal : 0                                        OutLabe   : NULL
     MED     :
     Community: <1:1>
# Display information about the BGP IPv6 unicast routes that have extended community attributes.
<Sysname> display bgp routing-table ipv6 ext-community
               a – additional-path
     MED     :
     Ext-Community: <RT 1:1>
# Display information about all BGP IPv6 unicast routes that have a large community attribute on the public network for the default BGP instance.
<Sysname> display bgp routing-table ipv6 large-community
               a – additional-path
     MED     :
     Large-community: <1:1:1>
# Displays IPv6 unicast routing information generated based on the Priority-Color extended community attribute in BGP VPN instance vpn1.
<Sysname> display bgp routing-table ipv6 vpn-instance vpn1 system-ip
               a - additional-path
* >i Network : 100::8                                   PrefixLen : 128
     NextHop : ::FFFF:50.50.50.50                       LocPrf    : 100
     SystemIP: N/A                                      Priority  : 0
     Path/Ogn: i
*  i Network : 100::8                                   PrefixLen : 128
     SystemIP: ::FFFF:10.10.10.10                       Priority  : 1
     Path/Ogn: i
Table 21 Command output
Status codes
Status codes:
Origin
Network
PrefixLen
NextHop
Next hop IPv6 address.
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
·     AS_PATH attribute—Records the ASs the route has passed, which avoids routing loops. A maximum of 16 AS numbers can be displayed in this field. Exceeding AS numbers are omitted and are viewable if you display detailed routing information.
Community
Ext-Community
Large-community
SystemIP
Priority
# Display detailed information about BGP IPv6 unicast routes destined to network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64
 Local AS number: 200
 BGP routing table information of 2::/64:
 Relay nexthop   : ::FFFF:10.1.1.1
 Original nexthop: ::FFFF:10.1.1.1
 Route age       : 01h45m22s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Dscp            : N/A
 Exp             : N/A
 Backup route.
 Relay nexthop   : 1::1
 Original nexthop: 1::1
 OutLabel        : NULL
 Route age       : 01h50m35s
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Dscp            : N/A
 Exp             : N/A
# Display community attribute information for the BGP IPv6 unicast routes with destination network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 community
 Local AS number: 100
# Display extended community attribute information for the BGP IPv6 unicast routes with destination network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 ext-community
# Display AS_PATH attribute information for the BGP IPv6 unicast routes with destination network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 as-path
 As-path: 100
# Display CLUSTER_LIST attribute information for the BGP IPv6 unicast routes with destination network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 cluster-list
 Cluster list: 80
Table 22 Command output
Paths
Number of routes:
Original nexthop
Out interface
Route age
OutLabel
Org-validation
·     Valid.
·     Not found.
·     Invalid.
RxPathID
TxPathID
AS-path
Community
Ext-Community
Origin
Attribute value
·     MED—MED value.
·     valid.
·     internal.
·     external.
·     local.
·     best.
Originator
Cluster list
From
Relay Nexthop
SystemIP
System IP iterated based on the Priority-Color extended community attribute. The field displays the next hop of the route. If the route is a primary route or is not iterated based on the Priority-Color extended community attribute, this field is not available.
IP precedence
QoS local ID
Traffic index
Tag
Tunnel policy
Rely Tunnel IDs
VPN-Peer UserID
DSCP
EXP
# Display advertisement information for BGP IPv6 unicast routes destined to network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 advertise-info
 BGP local router ID: 192.168.1.136
 Paths:   1 best
 BGP routing table information of 2::/64(TxPathID:0):
 Advertised to peers (2 in total):
    10.1.1.2
    1::2
Table 23 Command output
Paths
Number of optimal routes destined to the specified network.
Advertisement information for BGP routes destined to network 2::/64.
Peers to which the route has been advertised, and the number of peers.
# Display statistics for BGP IPv6 unicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes statistics
 Advertised routes total: 1
# Display statistics for BGP IPv6 unicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes statistics
 Received routes total: 1
Table 24 Command output
# Display BGP IPv6 unicast route statistics.
<Sysname> display bgp routing-table ipv6 statistics
# Display statistics about the BGP IPv6 unicast routes that have community attributes.
<Sysname> display bgp routing-table ipv6 statistics community
Table 25 Command output
# Display information about all BGP IPv6 unicast routes that have a large community attribute and are destined for network 2:: /64.
<Sysname> display bgp routing-table ipv6 2:: 64 large-community
Table 26 Command output
BGP local router ID
Local AS number
Local AS number.
Paths
Information about all BGP IPv6 unicast routes that have a large community attribute and are destined for network 2::/64.
Large-community
display bgp troubleshooting
Use display bgp troubleshooting to display information about BGP peer relationship down events.
display bgp [ instance instance-name ] troubleshooting [ event-count ] [ reverse ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the default BGP instance.
event-count: Specifies the number of peer relationship down events to display, in the range of 1 to 1000. If you do not specify this argument, the command displays information about the earliest or most recent 20 events based on the configuration of the reverse keyword.
reverse: Displays peer relationship down events in chronological order. If you do not specify this keyword, the command displays peer relationship down events in reverse chronological order.
Configure this command to display information about BGP peer relationship down events, including the time, reason, and recommended action. You can use this information to troubleshoot issues, such as BGP peer disconnections and flappings.
# Display reasons why BGP peer relationships went down.
<Sysname> display bgp troubleshooting
Total number: 1
Date        Time            Event description
2019-10-06 09:39:18        The BGP peer 10.1.1.1 went down because the
                            peer ignore command was configured manually.
                            Please check local BGP configuration.
Table 27 Command output
Total number
Total number of peer relationships that went down.
Date
Date (in YYYY-MM-DD format) on which a specific BGP peer relationship went down.
Time
Time (in hh:mm:ss format) when a specific BGP peer relationship went down.
Event description
Description for a specific peer down event. The description format is as follows:
The BGP peer ip-address went down because peer-down-reason. Please treatment-suggestion. ip-address represents the IP address of the peer, peer-down-reason represents the down reason, and treatment-suggestion represents the recommended action to take.
maintenance-probe enable
display bgp update-group
Use display bgp update-group to display information about BGP update groups.
display bgp [ instance instance-name ] update-group ipv4 [ multicast | rtfilter | sr-policy | unicast ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group ipv6 [ multicast | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address ]
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address ]
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group link-state [ ipv4-address | ipv6-address ]
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ]
display bgp [ instance instance-name ] update-group inof [ ipv4-address | ipv6-address ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP update group information for the default BGP instance.
ipv4: Displays BGP update group information for IPv4 address family.
ipv6: Displays BGP update group information for IPv6 address family.
link-state: Displays BGP update group information for LS address family.
l2vpn evpn: Displays BGP update group information for EVPN address family.
rtfilter: Displays BGP update group information for BGP IPv4 RT filter address family.
sr-policy: Displays BGP update group information for BGP SR policy address family.
unicast: Displays BGP update group information for unicast address family.
inof: Displays BGP update group information for iNOF address family.
vpn-instance vpn-instance-name: Displays BGP update group information for the MPLS L3VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays update group information for the public network.
ipv4-address: Displays BGP update group information for the specified BGP peer.
ipv6-address: Displays BGP update group information for the specified IPv6 BGP peer.
For non-default vSystems, this command can display only BGP IPv4 and BGP IPv6 unicast update group information.
The update group feature classifies BGP peers that have the same export policy into an update group. When BGP advertises routes to the peers in the update group, it uses the export policy to filter the routes and generates route updates for all the peers only once.
With this feature, BGP performs one-time policy filtering and encapsulation for a prefix before advertising the prefix to all the peers in the update group. For example, BGP advertises 1000 prefixes to 1000 peers that have the same export policy (in data centers for example). Without the update group feature, BGP matches the export policy 1000 × 1000 times. With the update group feature, BGP matches the export policy only 1000 × 1 times, improving encapsulation efficiency 1000 times.
If you do not specify any parameters, this command displays all update groups for the specified address family on the public network.
By default, the unicast keyword is used if you do not specify the unicast keyword.
# Display information about all BGP update groups for the IPv4 unicast address family.
<Sysname> display bgp update-group ipv4
  Update-group ID: 0
  Type: EBGP link
  4-byte AS number: Supported
  Site-of-Origin: Not specified
  Minimum time between advertisements: 30 seconds
  OutQ: 0
  Members: 1
    99.1.1.1
Table 28 Command output
Update-group ID
ID of the update group.
BGP link type:
·     IBGP link.
·     EBGP link.
·     Confed IBGP linkConfederation IBGP link.
·     Confed EBGP link—Confederation EBGP link.
Label capability: Supported
The peers in the update group support labeled routes.
4-byte AS number suppression is disabled for the peers in the update group. The peers in the update group support 4-byte AS numbers.
4-byte AS number: Suppressed
4-byte AS number suppression is enabled for the peers in the update group.
Fake AS
A fake local AS number is configured for the peers in the update group.
Public-AS-Only: Yes
BGP route updates advertised to the peers in the update group only carry the public AS number without the private AS number.
·     Yes—If a peer uses a private AS number, the AS number is used as an update group classification criterion. If a peer uses a public AS number, the AS number is not used as an update group classification criterion.
·     No—The AS number is not used as an update group classification criterion.
Substitute-AS: Yes
AS number substitution is enabled.
Site-of-Origin
SoO attribute specified for peers in the update group.
Track-route-policy
Routing policy used to achieve Track-based priority adjustment for BGP routes advertised to the peer group. If the peer advertise lowest-priority track-route-policy command is not configured, this field will not be displayed.
Minimum time between advertisements: number seconds
Minimum time between advertisements.
intelligent timer calculation: Yes
Intelligent timer is enabled to control the frequency of sending the same route to peers in the update group.
Advertising community: Yes
Community advertisement to peers in the update group is enabled.
Route-reflect client: Yes
The peer is a client of the route reflector.
Advertising extended community: Yes
Extended community advertisement to peers in the update group is enabled.
Export AS-path-ACL
AS path ACL used to filter BGP routes advertised to peers in the update group.
Export prefix list
Prefix list used to filter BGP routes advertised to peers in the update group.
Export route policy
Routing policy used to filter BGP routes advertised to peers in the update group.
Export filter-policy
OutQ
Number of prefixes to be advertised to peers in the update group.
Members
Number and IP addresses of peers in the update group.
filter-policy export
Use filter-policy export to filter advertised BGP routes.
Use undo filter-policy export to remove the route filter.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
undo filter-policy export [ direct | { isis | ospf | rip } process-id | static ]
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-list-name } export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
undo filter-policy export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
Advertised BGP routes are not filtered.
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999, to match routes by destination.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999, to match routes by destination.
name ipv4-acl-name: Specifies an IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
prefix-list ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
prefix-list ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
direct: Filters direct routes.
ospf: Filters OSPF routes.
ospfv3: Filters OSPFv3 routes.
static: Filters static routes.
process-id: Specifies a routing protocol by its ID in the range of 1 to 65535.
If you specify a protocol (such as direct and isis), this command filters only routes redistributed from the specified protocol. If you do not specify a protocol, this command filters all advertised routes, including the following routes:
·     Redistributed from IGP.
·     Injected by the network command.
·     Learned from BGP peers.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination network addresses match the source-address source-wildcard argument. However, it does not match the masks of the destination addresses.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following steps:
·     To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address.
When you specify an ACL, follow these guidelines:
·     If the specified ACL does not exist or has no rules, all BGP routes can pass the ACL.
·     If a rule in the specified ACL is applied to a VPN instance, the rule will deny all BGP routes.
# In BGP IPv4 unicast address family view, use IPv4 basic ACL 2000 to filter advertised BGP IPv4 routes.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] filter-policy 2000 export
filter-policy import
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
Use filter-policy import to filter received BGP routes.
Use undo filter-policy import to restore the default.
Received BGP routes are not filtered.
# In BGP IPv4 unicast address family view, use IPv4 basic ACL 2000 to filter received BGP routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] filter-policy 2000 import
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
group
Use group to create a peer group.
Use undo group to delete a peer group.
group group-name [ external | internal ]
undo group group-name
No peer groups exist.
BGP instance view
group-name: Specifies a name for the peer group, a case-sensitive string of 1 to 47 characters.
external: Creates an EBGP peer group.
internal: Creates an IBGP peer group.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. In this way, peers can share the same policy as the peer group. When the policy of the group is modified, the modification also applies to peers in it.
If you do not specify the internal or external keyword, this command creates an IBGP peer group.
If you perform configurations on a peer group and peers of the peer group, the most recent configuration takes effect.
After you create a peer group, you must use the peer enable command to enable BGP to exchange routing information with the specified peer group.
# In BGP instance view, create EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp-default] group test external
[Sysname-bgp-default] peer test as-number 200
[Sysname-bgp-default] peer 10.1.1.1 group test
[Sysname-bgp-default] peer 10.1.2.1 group test
display bgp group
peer enable
ignore-first-as
Use ignore-first-as to configure BGP to ignore the first AS number of EBGP route updates.
Use undo ignore-first-as to restore the default.
ignore-first-as
BGP checks the first AS number of a received EBGP route update. If the first AS number is neither that of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
BGP instance view
# Configure BGP to ignore the first AS number of EBGP route updates.
[Sysname] bgp 100
[Sysname-bgp-default] ignore-first-as
peer ignore-first-as
import-route
Use import-route to enable BGP to redistribute routes from an IGP protocol.
Use undo import-route to disable route redistribution from an IGP protocol.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP IPv4 multicast address family view:
import-route { direct | static } [ med med-value | route-policy route-policy-name ] *
import-route eigrp [ { eigrp-as | all-as } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
undo import-route { direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static }
undo import-route { direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
BGP does not redistribute IGP routes.
direct: Redistributes direct routes.
ospf: Redistributes OSPF routes.
ospfv3: Redistributes OSPFv3 routes.
static: Redistributes static routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default is 1. For IPv4 routes, it is available only when the protocol is isis, ospf, or rip.
all-processes: Redistributes routes from all the processes of the specified IGP protocol.
eigrp-as: Specifies an EIGRP process by its number in the range of 1 to 65535.
all-as: Redistributes routes from all EIGRP processes.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
med med-value: Specifies a MED value for redistributed routes, in the range of 0 to 4294967295. If you do not specify an MED, the metric of a redistributed route is used as its MED.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes or set route attributes for redistributed routes.
The import-route command cannot redistribute default IGP routes. To redistribute default IGP routes, use the default-route imported command together with the import-route command.
Only active routes can be redistributed. You can use the display ip routing-table protocol or display ipv6 routing-table protocol command to view route state information.
The ORIGIN attribute of routes redistributed by the import-route command is INCOMPLETE.
After you redistribute routes from all processes of a routing protocol by using the all-processes keyword, this command does not take effect on any processes of the protocol.
# In BGP IPv4 unicast address family view, redistribute routes from RIP process 1, and set the MED value for redistributed routes to 100.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route rip 1 med 100
import-route-append
Use import-route-append to redistribute routes from an IGP without overwriting the routes redistributed by the import-route command.
Use undo import-route-append to remove the redistributed routes.
import-route-append { isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
import-route-append { direct | static } [ med med-value | route-policy route-policy-name ]*
undo import-route-append { direct | { isis | ospf | rip } [ process-id | all-processes ] | static }
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view/BGP IPv6 multicast address family view:
import-route-append { isisv6 | ospfv3 | ripng } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
undo import-route-append { direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
BGP does not redistribute routes from an IGP without overwriting the routes redistributed by the import-route command.
isis: Redistributes IS-IS routes.
isisv6: Redistributes IPv6 IS-IS routes.
rip: Redistributes RIP routes.
ripng: Redistributes RIPng routes.
process-id: Specifies a process by its number in the range of 1 to 65535.
all-processes: Redistributes routes from all processes of the specified routing protocol.
If you execute the import-route-append command without executing the import-route command, the import-route-append command has the same effect as the import-route command.
If you execute both the import-route and import-route-append commands for an IGP process, the commands take effect as follows:
·     A route is redistributed as long as it matches the criteria of either command.
·     If a route matches the criteria of both commands, the route is redistributed, and the apply clauses in the routing policies specified in the two commands take effect as follows:
¡     If the apply clauses do not conflict, all apply clauses take effect.
¡     If conflicts occur between the apply clauses, only the apply clauses in the import-route-append command take effect.
·     The MED value specified by the import-route-append command takes precedence over that specified by the import-route command.
# In BGP IPv4 unicast address family view, redistribute routes matching routing policy policy1 from IS-IS process 1 without overwriting the routes redistributed by the import-route command.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route isis 1
[Sysname-bgp-default-ipv4] import-route-append isis 1 route-policy policy1
import-route
import-route multipath
Use import-route multipath to redistribute all routes with the same destination address to BGP.
Use undo import-route multipath to restore the default.
When multiple routes with the same destination address exist, BGP redistributes only the optimal routes to its routing table.
This command takes effect only on the routes redistributed by the import-route command in the same address family.
By default, the import-route command redistributes only the optimal routes to BGP when multiple routes with the same destination address exist. To redistribute all routes with the same destination address to BGP, execute this command and BGP can advertise these routes to its peers.
# In BGP IPv4 unicast address family view, enable BGP to redistribute all routes with the same destination address.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route multipath
import-route
ip vpn-instance (BGP instance view)
Use ip vpn-instance to create a BGP-VPN instance and enter its view, or enter the view of an existing BGP-VPN instance.
Use undo ip vpn-instance to remove a BGP-VPN instance and all its configurations.
No BGP-VPN instances exist.
BGP instance view
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After you create a BGP peer in BGP-VPN instance view, the BGP routes learned from the peer are added into the routing table of the specified VPN instance.
This command and all commands in BGP-VPN instance view are typically executed on provider edge (PE) or Multi-VPN-Instance CE (MCE) devices. The commands add routes learned from different sites into different VPN instances.
Before you execute this command, you must perform the following tasks:
·     Use the ip vpn-instance command to create the VPN instance in system view.
·     Use the route-distinguisher command to configure a route distinguisher (RD) for the VPN instance.
# Create a BGP-VPN instance and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1]
ip vpn-instance (system view) (MPLS Command Reference)
route-distinguisher (MPLS Command Reference)
log-peer-change
Use log-peer-change to enable logging for BGP session state changes globally.
Use undo log-peer-change to disable logging for BGP session state changes globally.
log-peer-change
Logging for BGP session state changes is enabled globally.
BGP instance view
After you execute both the log-peer-change and peer log-change commands, BGP logs session establishment and disconnection events for the peer or peer group. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center of the device. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
If you disable logging for BGP session state changes globally or disable logging for a peer or peer group, BGP does not generate logs for session establishments and disconnections.
# Enable logging for session state changes globally.
[Sysname] bgp 100
[Sysname-bgp-default] log-peer-change
display bgp peer
peer log-change
log-route-flap
Use log-route-flap to enable logging for BGP route flapping.
Use undo log-route-flap to restore the default.
undo log-route-flap
Logging for BGP route flapping is disabled.
monitor-time: Specifies the monitoring interval for route flapping, in the range of 1 to 600 minutes.
monitor-count: Specifies the number of route flaps for triggering a log, in the range of 2 to 8.
log-count-limit: Specifies the maximum number of logs allowed to be generated in a minute. The value range for this argument is 1 to 600, and the default value is 200.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
This command is applicable only to incoming routes of the specified address family.
# In BGP IPv4 unicast address family view, enable logging for BGP route flapping. Set the monitoring interval to 10 minutes, the number of route flaps for triggering a log to 5, and the maximum number of allowed logs in a minute to 100.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] log-route-flap 10 5 100
network
Use network to inject a network to the BGP routing table and configure BGP to advertise the network.
Use undo network to remove a local network.
undo network ipv4-address [ mask-length | mask ]
In BGP IPv6 unicast address family view/BGP IPv6 multicast address family view:
undo network ipv6-address prefix-length
BGP does not advertise local networks.
ipv4-address: Specifies an IPv4 network address. If you do not specify the mask or mask-length argument, natural mask is used.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a mask in dotted decimal notation.
ipv6-address: Specifies an IPv6 network address.
prefix-length: Specifies a prefix length in the range of 0 to 128.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes or set the route attributes.
The network to be injected must be available and active in the local IP routing table.
The ORIGIN attribute of the route injected with the network command is IGP.
When you execute the undo network command, you must specify the same mask or mask length/prefix length that you specified for the network command. Otherwise, the configuration cannot be removed.
# In BGP IPv4 unicast address family view, inject local network 10.0.0.0/16 to the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0
network short-cut
Use network short-cut to increase the preference for a received EBGP route. This EBGP route is called a shortcut route.
Use undo network short-cut to remove the configuration.
undo network ipv4-address [ mask-length | mask ] short-cut
undo network ipv6-address prefix-length short-cut
A received EBGP route has a preference of 255.
mask: Specifies a mask for the network address, in dotted decimal notation.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
By default, the preference of an EBGP route is lower than a local route. If a device has an EBGP route and a local route to reach the same destination, the device does not select the EBGP route. You can use the network shortcut command to configure the EBGP route to have the same preference as the local route so the EBGP route is more likely to become the optimal route.
You can use the preference command to modify the preferences for external and local BGP routes.
# In BGP IPv4 unicast address family view, increase the preference of EBGP route 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0 short-cut
preference
nexthop global-address-only
Use nexthop global-address-only to enable the device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
Use undo nexthop global-address-only to enable the device to advertise both the link-local address and the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
The device advertises only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
A directly-connected IPv6 EBGP peer might fail to learn routes if it cannot parse a route update that contains both the link-local address and the global unicast address. To resolve this issue, execute this command to enable the local device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
This command might not apply to EBGP peers established through directly connected broadcast interfaces. If the next hop of the advertised route and the directly connected broadcast interfaces belong to the same subnet, this command does not take effect.
The device can use its global unicast address to establish direct IPv6 EBGP peer relationships. If the undo nexthop global-address-only command is configured and the local device has a link-local address, it advertises both the link-local address and the global unicast address in the NEXT_HOP attribute to those established direct IPv6 EBGP peers.
# In BGP IPv6 unicast address family view, enable the device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] nexthop global-address-only
peer advertise bandwidth transitive
Use peer advertise bandwidth transitive to transform the type of the link bandwidth attribute to optional transitive for BGP routes advertised to a peer.
Use undo peer advertise bandwidth transitive to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] } advertise bandwidth transitive
undo peer { group-name | ipv4-address [ mask-length ] } advertise bandwidth transitive
In BGP IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise bandwidth transitive
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise bandwidth transitive
In BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv6-address [ prefix-length ] } advertise bandwidth transitive
undo peer { group-name | ipv6-address [ prefix-length ] } advertise bandwidth transitive
The link bandwidth attribute of BGP routes is optional non-transitive.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command takes effect on all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command takes effect on all dynamic peers in the subnet.
By default, the link bandwidth attribute of BGP routes is optional non-transitive. If a BGP device cannot recognize the link bandwidth attribute, it ignores the link bandwidth attribute and does not advertise this attribute to its peers. With this command configured, the device transforms the type of the link bandwidth attribute to optional transitive for BGP routes before advertising those routes to the specified BGP peer. The specified peer can then receive and advertise routes with the link bandwidth attribute even if it does not support the link bandwidth attribute.
Before route advertisement, the device deletes the link bandwidth attribute of a received route if the device needs to change the next hop of that route. This is because the forwarding link instructed by this route has changed and thus the original link bandwidth no longer indicates the bandwidth of the real forwarding link.
In BGP IPv4 unicast address family view, transform the type of the link bandwidth attribute to optional transitive for BGP routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise bandwidth transitive
apply extcommunity (Layer 3—IP Routing Command Reference)
ip extcommunity-list (Layer 3—IP Routing Command Reference)
peer advertise ebgp bandwidth
peer bandwidth
peer advertise-community
Use peer advertise-community to enable BGP to advertise the COMMUNITY attribute to a peer or peer group.
Use undo peer advertise-community to disable BGP from advertising the COMMUNITY attribute to a peer or peer group.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP VPNv4 address family view/BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-community
No COMMUNITY attribute is advertised to any peers or peer groups.
BGP EVPN address family view
BGP IPv4 SR policy address family view
BGP IPv6 SR policy address family view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises the COMMUNITY attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises the COMMUNITY attribute to all dynamic peers in the subnet.
The COMMUNITY attribute is a group of specific data carried in update messages. A route can carry one or more COMMUNITY attribute values (each is represented by a 4-byte integer). The receiving router processes the route (for example, determining whether to advertise the route and the scope for advertising the route) based on the COMMUNITY attribute values.
After you execute the peer advertise-community command, routing updates advertised to the peer carry the COMMUNITY attribute.
After you execute the undo peer advertise-community command, BGP, upon receiving a route with the COMMUNITY attribute, removes the COMMUNITY attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast address family view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-community
apply community
if-match community
ip community-list
Use peer advertise ebgp bandwidth to enable advertising the link bandwidth attribute to EBGP peers.
Use undo peer advertise ebgp bandwidth to disable advertising the link bandwidth attribute to EBGP peers.
peer { group-name | ipv4-address [ mask-length ] } advertise ebgp bandwidth
undo peer { group-name | ipv4-address [ mask-length ] } advertise ebgp bandwidth
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise ebgp bandwidth
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise ebgp bandwidth
peer { group-name | ipv6-address [ prefix-length ] } advertise ebgp bandwidth
undo peer { group-name | ipv6-address [ prefix-length ] } advertise ebgp bandwidth
The device does not advertise the link bandwidth attribute to EBGP peers.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, the device advertises the link bandwidth attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, the device advertises the link bandwidth attribute to all dynamic peers in the subnet.
By default, the device advertises the link bandwidth attribute only to IBGP peers. This command enables the device to advertise the link bandwidth attribute to EBGP peers.
In BGP IPv4 unicast address family view, enable advertising the link bandwidth attribute to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise ebgp bandwidth
peer bandwidth
peer advertise-ext-community
Use peer advertise-ext-community to enable BGP to advertise extended community attributes to a peer or peer group.
Use undo peer advertise-ext-community to disable BGP from advertising extended community attributes to a peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } advertise-ext-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-ext-community
BGP does not advertise extended community attributes to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises the extended community attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises the extended community attribute to all dynamic peers in the subnet.
To meet increasing user demands, BGP defines a new attribute—extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
·     The extended community attribute has an 8-byte length.
·     The extended community attribute supports various types. You can select an extended community attribute type as needed to implement route filtering and control. This simplifies configuration and management.
After you execute the peer advertise-ext-community command, route updates sent to the peer or peer group carry the extended community attribute.
After you execute the undo peer advertise-ext-community command, BGP, upon receiving a route with the extended community attribute, removes the extended community attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast address family view, advertise the extended community attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-ext-community
apply extcommunity
if-match extcommunity
peer advertise-large-community
Use peer advertise-large-community to advertise the large community attribute to a peer or peer group.
Use undo peer advertise-large-community to disable large community attribute advertisement to a peer or peer group.
In BGP IPv4 multicast address family view/BGP IPv4 MVPN address family view/BGP IPv4 SR policy address family view:
peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
undo peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP VPNv4 address family view/BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view/BGP VPNv6 address family view/BGP EVPN address family view/BGP IPv6 SR policy address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-large-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-large-community
In BGP IPv6 multicast address family view/BGP IPv6 SR policy address family view:
peer { group-name | ipv6-address [ prefix-length ] } advertise-large-community
undo peer { group-name | ipv6-address [ prefix-length ] } advertise-large-community
The device does not advertise the large community attribute to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises the large community attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises the large community attribute to all dynamic peers in the subnet.
The large community attribute is defined to address the shortcomings of the community attribute and the extended community attribute. It is a group of specific data carried in UPDATE messages. A route can carry one or more large community attribute values. The receiving router processes the route (for example, determining whether to receive or advertise the route) based on the large community attribute values.
After you execute the peer advertise-large-community command, routing updates advertised to the peer carry the large community attribute.
After you execute the undo peer advertise-large-community command, BGP removes the large community attribute from the received routes before sending them to a peer or peer group.
# In BGP IPv4 unicast address family view, advertise the large community attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-large-community
apply large-community (Layer 3—IP Routing Command Reference)
apply large-comm-list delete (Layer 3—IP Routing Command Reference)
if-match large-community (Layer 3—IP Routing Command Reference)
ip large-community-list (Layer 3—IP Routing Command Reference)
peer advertisement-interval
Use peer advertisement-interval to set the interval for sending update messages and the maximum number of update messages that can be sent each time to a peer or peer group.
Use undo peer advertisement-interval to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertisement-interval interval count
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertisement-interval
The interval for sending update messages and the maximum number of update messages that can be sent each time to a peer or peer group are not set. The configuration of the advertisement-interval command takes effect.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
interval: Specifies the interval for sending update messages, in the range of 100 to 10000 milliseconds. The value of this argument must be an integer multiple of 100.
count: Specifies the maximum number of update messages that can be sent each time, in the range of 1 to 40960.
Configure this command to prevent the device from sending a large number of update messages to a peer or peer group in a short time period.
The configuration of this command takes precedence over that of the advertisement-interval command.
This command takes effect only on BGP sessions established or re-established after the command is executed.
# In BGP instance view, set the interval for sending update messages and the maximum number of update messages can be sent each time to peer group test to 1000 milliseconds and 5, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] peer test advertisement-interval 1000 5
peer advertise-policy exist-policy
Use peer advertise-policy exist-policy to specify an existent policy to control route advertisement.
Use undo peer advertise-policy exist-policy to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy exist-policy
No existent policy is specified to control route advertisement.
advertise-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the route advertisement policy.
exist-policy exist-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the existent policy.
After you configure this command, routes that match the route advertisement policy can be advertised only when the BGP routing table contains prefixes that match the existent policy.
The existent policy does not apply to routes that do not match the route advertisement policy.
# In BGP IPv4 unicast address family view, configure BGP to advertise routes matching routing policy adv-policy to peer 1.1.1.1 only when the BGP routing table contains prefixes matching routing policy ex-policy.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy exist-policy ex-policy
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
peer advertise-policy non-exist-policy
route-policy
Use peer advertise-policy non-exist-policy to specify a nonexistent policy to control route advertisement.
Use undo peer advertise-policy non-exist-policy to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy non-exist-policy
No nonexistent policy is specified to control route advertisement.
non-exist-policy non-exist-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the nonexistent policy.
After you configure this command, routes that match the route advertisement policy can be advertised only when the BGP routing table does not contain any prefixes that match the nonexistent policy.
The nonexistent policy does not apply to routes that do not match the route advertisement policy.
# In BGP IPv4 unicast address family view, configure BGP to advertise routes matching routing policy adv-policy to peer 1.1.1.1 only when the BGP routing table does not contain any prefixes matching routing policy n-ex-policy.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy non-exist-policy n-ex-policy
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
route-policy
peer aigp
Use peer aigp to configure BGP to advertise the AIGP attribute to a peer or peer group.
Use undo peer aigp to disable BGP from advertising the AIGP attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } aigp
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } aigp
BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attributes in routes received from the peer or peer group.
As a best practice, do not configure the peer aigp command on border routers of an AIGP administrative domain.
When a router advertises a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you configure only the peer aigp command. To enable the router to carry the AIGP attribute, you must configure both the peer aigp and apply aigp command.
# In BGP IPv4 unicast address family view, configure BGP to advertise the AIGP attribute to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 aigp
apply aigp
peer aigp send med
Use peer aigp send med to configure BGP to replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use undo peer aigp send med to disable BGP from replacing the MED value with AIGP value in routes advertised to the peer or peer group.
In :
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } aigp send med
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } aigp send med
BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
# In BGP IPv4 unicast address family view, configure BGP to replace the MED value with AIGP value in routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 aigp send med
apply aigp
peer allow-as-loop
Use peer allow-as-loop to allow a local AS number to exist in the AS_PATH attribute of routes from a peer or peer group, and to set the number of times for which the local AS number can appear.
Use undo peer allow-as-loop to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } allow-as-loop
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } allow-as-loop
The local AS number is not allowed to exist in the AS_PATH attribute of routes from a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP allows a local AS number to exist in the AS_PATH attribute of routes from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP allows a local AS number to exist in the AS_PATH attribute of routes from all dynamic peers in the subnet.
number: Specifies the number of times for which the local AS number can appear, in the range of 1 to 10. The default number is 1. If the number of times for which the local AS number appears in a route exceeds the specified number, BGP considers that a routing loop occurs and discards the route.
By default, BGP does not receive routes that contain the local AS number in the AS_PATH attribute to avoid routing loops. However, in some network environments, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
# In BGP IPv4 unicast address family view, set the number of times for which the local AS number can appear in AS_PATH attribute of routes from peer group test to 2.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test allow-as-loop 2
peer-as-check enable
Use peer-as-check enable to enable BGP to check the first AS number of EBGP routes. BGP will not advertise an EBGP route to EBGP peers whose AS number is the route's first AS number.
Use undo peer-as-check enable to restore the default.
On receipt of an EBGP route, BGP does not check the first AS number of the route and advertises it to all peers except the source peer.
The default setting for EBGP route advertisement brings about a large number of BGP routes and is not friendly to network maintenance. To resolve this issue, use this command. When the first AS number of an EBGP route to be advertised is the same as that of an EBGP peer, BGP does not advertise the route to that peer. This can reduce the number of routes received by EBGP peers.
# In BGP IPv4 unicast address family view, enable first-AS-number check for EBGP routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer-as-check enable
peer as-number (for a BGP peer group)
Use peer as-number to specify an AS number for a peer group.
Use undo peer as-number to delete the AS number of a peer group.
undo peer group-name as-number
No AS number is specified for a peer group.
BGP instance view
group-name: Specifies a name for a peer group, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
as-number: Specifies an AS number for a peer group. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
This command applies only to a peer group with no peers in it.
When you specify an AS number for a peer group and want to add peers to it, make sure the AS number of the peers is the same as the peer group.
If you do not specify an AS number for a peer group, peers added to it can use their own AS numbers.
# In BGP instance view, set the AS number for peer group test to 100.
[Sysname] bgp 100
[Sysname-bgp-default] peer test as-number 100
peer group
peer as-number (for a BGP peer)
Use peer as-number to create a BGP peer and specify its AS number.
Use undo peer to delete a BGP peer.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] }
No BGP peers exist.
BGP instance view
ipv4-address: Specifies the IPv4 address of a peer.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to establish dynamic peer relationships with all devices in the subnet.
ipv6-address: Specifies the IPv6 address of a peer.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to establish dynamic peer relationships with all devices in the subnet.
as-number: Specifies an AS number for the peer. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535. If the AS numbers of the peer and the local router are the same, the peer is an IBGP peer. If they are different, the peer is an EBGP peer.
You can also create a peer and add it to a peer group by using the peer group command.
To modify the AS number of a peer, do not execute the peer as-number command repeatedly. Instead, you must first delete the peer and configure it again.
After you create a peer, you must use the peer enable command to enable BGP to exchange routing information with the specified peer.
To specify a BGP peer by its IPv6 link-local address, you must make sure the BGP peer is directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
# In BGP instance view, create BGP peer 1.1.1.1 and set its AS number to 100.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 100
display bgp peer
peer enable
peer group
peer as-path-acl
Use peer as-path-acl to specify an AS path list to filter routes incoming from or outgoing to a peer or peer group.
Use undo peer as-path-acl to delete the AS path list specified to filter routes incoming from or outgoing to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
No AS path list is specified for filtering.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies an AS path list to filter routes incoming from or outgoing to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies an AS path list to filter routes incoming from or outgoing to all dynamic peers in the subnet.
as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256.
as-path-acl-name: Specifies an AS path list by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
export: Filters outgoing routes.
import: Filters incoming routes.
The specified AS path list must have been created with the ip as-path command in system view. If you specify a nonexistent AS path list, all routes can pass the AS path list.
If you configure this command for an EBGP peer on the local device, the local device performs the following operations before route advertisement to that EBGP peer:
1.     Use the specified AS path list to filter BGP routes and determine the routes to be advertised.
2.     Add the local AS number into the AS_PATH attribute of the routes to be advertised.
# In BGP IPv4 unicast address family view, specify AS path list 1 to filter routes outgoing to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test as-path-acl 1 export
ip as-path
peer filter-policy
peer prefix-list
peer route-policy
peer bandwidth
Use peer bandwidth to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
Use undo peer bandwidth to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] } bandwidth [ bandwidth-value ]
undo peer { group-name | ipv4-address [ mask-length ] } bandwidth
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bandwidth [ bandwidth-value ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bandwidth
peer { group-name | ipv6-address [ prefix-length ] } bandwidth [ bandwidth-value ]
undo peer { group-name | ipv6-address [ prefix-length ] } bandwidth
BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
bandwidth-value: Specifies a 32-bit link bandwidth attribute value. The value range for this argument is 1 to 4294967295 kbps. The device adds this value in conjunction with the AS number of the current BGP process to the routes received from direct EBGP peers, in AS:bandwidth format. For example, 100:100000. If you do not specify any link bandwidth attribute value, the device adds AS:bandwidth to the routes received from a direct EBGP peer as follows:
·     The AS argument equals the AS number of the current BGP process
·     The bandwidth argument equals the bandwidth value for the local interface attached to the direct EBGP peer.
Application scenarios
ECMP load balancing equally distributes traffic to the equal-cost links without considering link bandwidth differences. This might cause insufficient usage of high-speed links and traffic congestion on low-speed links. To resolve this issue, you can configure Unequal Cost Multiple Path (UCMP) load balancing based on the link bandwidth attributes of BGP routes.
Operating mechanism
The link bandwidth attribute of a route indicates the link bandwidth of the outgoing interface of the route. After UCMP load balancing is enabled for an EBGP peer on the device, the device adds the link bandwidth attribute into the routes received from the EBGP peer. This attribute carries the AS number of the current BGP process and the interface bandwidth used for direct EBGP session establishment. UCMP BGP routes are formed in the following situation:
·     BGP route load balancing is configured by the balance command.
·     All BGP routes used for load balancing carry a link bandwidth attribute.
During traffic forwarding, the proportion of the traffic carried on each BGP route is that of the route's link bandwidth to the total link bandwidth of all UCMP routes. For example, the link bandwidth attribute value is 500 kbps for Route A, 1000 kbps for Route B, and 500 kbps for Route C . The traffic load proportions carried on the three BGP routes are 25%, 50%, and 25%, respectively.
When you use this command to add a link bandwidth attribute value to BGP routes, follow these restrictions and guidelines:
·     This command applies only to direct EBGP peers and peer groups. If the specified peer or peer group becomes an indirectly connected one, BGP stops adding the link bandwidth attribute to routes received from the EBGP peer or peer group.
·     Only if all BGP routes for the same destination address carry a link bandwidth attribute, can these routes provide UCMP load balancing. Otherwise, the routes can only provide ECMP load balancing.
·     A BGP route can carry a maximum of one link bandwidth attribute. If a received route already has a link bandwidth attribute, BGP cannot add another link bandwidth attribute to the route any more.
You can use this command together with the following commands:
·     By default, the device advertises the link bandwidth attribute only to IBGP peers. To have the device advertise the link bandwidth attribute to EBGP peers, use the peer advertise ebgp bandwidth command.
·     By default, the link bandwidth attribute of BGP routes is optional non-transitive. If a BGP device cannot recognize the link bandwidth attribute, it ignores the link bandwidth attribute and does not advertise this attribute to its peers. To resolve this issue, use the peer advertise bandwidth transitive command. With this command configured, the device transforms the type of the link bandwidth attribute to optional transitive for BGP routes before advertising those routes to the specified BGP peer. The specified peer can then receive and advertise routes with the link bandwidth attribute even if it does not support the link bandwidth attribute.
In advertisement of BGP routes with link bandwidth attributes, the following restrictions apply:
·     In BGP IPv4 address family, BGP-VPN IPv4 address family, BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, BGP IPv4 multicast address family, or BGP IPv6 multicast address family: BGP can advertise the link bandwidth attribute to a BGP peer or peer group only after you use the peer advertise-ext-community command.
·     For a BGP peer or peer group, the configuration of the peer route-policy export command takes precedence over that of the peer bandwidth command after you perform the following operations:
¡     Use the peer route-policy export command to apply a routing policy to the BGP peer or peer group. The routing policy uses the apply extcommunity command to configure a link bandwidth attribute for BGP routes.
¡     Configure the peer bandwidth command for the BGP peer or peer group.
·     Before advertisement, the device deletes the link bandwidth attribute of a received route if the device needs to change the next hop of that route. This is because the forwarding link instructed by this route has changed and thus the original link bandwidth no longer indicates the bandwidth of the actual forwarding link. This restriction does not exist if the device receives a route without any link bandwidth attribute and adds a link bandwidth attribute to the route.
·     For UCMP routes, if the Add-Path feature is configured to advertise only one optimal route, the link bandwidth attribute value for the optimal route equals the total link bandwidth of all UCMP routes. If the Add-Path feature is configured to advertise more than one optimal route, the advertised routes carry their respective link bandwidth attributes.
If you execute this command for the same BGP peer or peer group multiple times, the most recent configuration takes effect.
# In BGP IPv4 unicast address family view, enable BGP to add the link bandwidth attribute to routes received from EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 bandwidth
apply extcommunity
balance
peer cluster-id
Use peer cluster-id to set the cluster ID of the route reflector for a peer or peer group.
Use undo peer cluster-id to remove the cluster ID of the route reflector for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } cluster-id cluster-id
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } cluster-id
The cluster ID of the route reflector is not set for a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the network.
cluster-id: Specifies the cluster ID. The cluster ID can be an integer in the range of 1 to 4294967295 or an IPv4 address.
When a route reflector connects to multiple clusters, you can use this command to configure different cluster IDs for different peers or peer groups.
If you do not configure the peer cluster-id command for a peer or peer group, the peer or peer group uses the cluster ID configured by the reflector cluster-id command.
For a peer or peer group, the cluster ID configured by the peer cluster-id command takes precedence over the cluster ID configured by the reflector cluster-id command.
Do not configure the router ID of a client as the cluster ID.
# In BGP IPv4 unicast address family view, set the cluster ID to 80 for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as 100
[Sysname-bgp-default] peer 1.1.1.1 cluster-id 80
peer reflect-client
Use peer connect-interface to specify a source interface (IPv4 address/IPv6 address) for establishing TCP connections to a peer or peer group.
Use undo peer connect-interface to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface interface-type interface-number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface
BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route destined for the BGP peer or peer group as the source address.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source interface for establishing TCP connections to all dynamic peers in the network.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source interface for establishing TCP connections to all dynamic peers in the subnet.
The peer connect-interface command and the peer source-address command can both change the source address for establishing TCP connections. If you execute both commands, the most recent configuration takes effect.
The peer source-address and peer connect-interface commands are applicable to the following scenarios:
·     The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡     Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡     Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
·     A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
·     On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this issue, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
·     You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this issue, use one of the following methods:
¡     If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡     If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
The source interfaces on the local router and the peer must be reachable to each other.
BGP immediately tears down the session to an IBGP peer or peer group when the following conditions exist:
·     The source interface of TCP connections to the IBGP peer or peer group is a physical interface.
·     The source interface fails and the link to the IBGP peer or peer group goes down.
To specify an indirectly connected interface on an EBGP peer as the source interface, use the peer ebgp-max-hop command. The command allows the establishment of an EBGP session to the indirectly connected peer.
If an interface has multiple IPv4 addresses, BGP uses the primary IPv4 address to establish TCP connections. If an interface has multiple IPv6 addresses, BGP selects a source IPv6 address. To use an IPv6 address as the source address, specify that IPv6 address by using the peer source-address command.
# In BGP instance view, specify loopback 0 as the source interface for TCP connections to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test connect-interface loopback 0
peer ebgp-max-hop
peer source-address
peer { connect-only | listen-only }
Use peer { connect-only | listen-only } to enable BGP to operate in connect-only or listen-only mode for a peer or peer group.
Use undo peer { connect-only | listen-only } to restore the default.
peer { group-name | ipv4-address | ipv6-address } { connect-only | listen-only }
BGP initiates and listens for connection requests.
BGP instance view
connect-only: Enables BGP to only initiate connection requests.
listen-only: Enables BGP to only listen for connection requests.
To control BGP connection establishment, you can use this command to configure the operating mode of a BGP node:
·     Listen-only—Only listens for connection requests from the specified BGP peer or peer group. In this mode, the BGP node does not initiate connection requests to the specified BGP peer or peer group.
·     Connect-only—Only initiates connection requests to the specified BGP peer or peer group. In this mode, the BGP node does not listen for connection requests from the specified BGP peer or peer group.
For example, before two nodes establish a BGP connection, you can enable one node to operate in listen-only mode, and enable another node to operate in connect-only mode.
If you execute this command multiple times for a peer or peer group, the most recent configuration takes effect.
For successful BGP connection establishment between two BGP nodes, make sure that they are operating in different modes. If they are operating in listen-only or connect-only mode simultaneously, they will fail to establish a BGP connection.
# In BGP instance view, enable BGP to operate in listen-only mode for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 listen-only
peer default-route-advertise
Use peer default-route-advertise to advertise a default route to a peer or peer group.
Use undo peer default-route-advertise to disable default route advertisement to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise [ route-policy route-policy-name ] [ conditional-policy route-policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] } default-route-advertise
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ] [ conditional-policy route-policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise
In BGP IPv4 RT filter address family view:
In BGP EVPN address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
No default route is advertised to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises a default route to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises a default route to all dynamic peers in the subnet.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to modify the attributes of the advertised default route. If you do not specify this option, no routing policy is specified for the advertised default route.
conditional-policy route-policy-name: Specifies a routing policy to determine whether to advertise the default route. BGP advertises the default route only when the current routing table contains a route that matches a permit-mode node of the specified routing policy. The route-policy-name argument represents the routing policy name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, sending of the default route is not limited.
ipv4: Sends the IPv4 default route through BGP EVPN.
ipv6: Sends the IPv6 default route through BGP EVPN.
This command enables the router to send a default route with the next hop being itself to the peer or peer group regardless of whether the default route exists in the routing table.
# In BGP IPv4 unicast address family view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer test default-route-advertise
peer description
Use peer description to configure a description for a peer or peer group.
Use undo peer description to remove the description for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } description text
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } description
No description information is configured for a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures a description for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures a description for all dynamic peers in the subnet.
text: Specifies a description for a peer or peer group, a case-sensitive string of 1 to 79 characters.
# In BGP instance view, set the description for peer group test to ISP1.
[Sysname] bgp 100
[Sysname-bgp-default] peer test description ISP1
peer ebgp-max-hop
Use peer ebgp-max-hop to enable BGP to establish an EBGP session to an indirectly connected peer or peer group and specify the maximum hop count.
Use undo peer ebgp-max-hop to disable BGP from establishing an EBGP session to an indirectly connected peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop
BGP does not establish an EBGP session to an indirectly connected peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP establishes EBGP sessions to all indirectly connected dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP establishes EBGP sessions to all indirectly connected dynamic peers in the subnet.
hop-count: Specifies the maximum number of hop counts, in the range of 1 to 255. The default is 64.
To become EBGP peers, two routers must be directly connected and use directly connected interfaces to establish an EBGP session. If they are not directly connected, use the peer ebgp-max-hop command to establish an EBGP session over multiple hops between two peers.
This command takes effect only on routes received after you execute this command. To apply this command to existing routes, use the refresh bgp command to soft-reset BGP sessions.
To ensure correct BGP route recursion, do not specify any direct EBGP peer or peer group when you configure this command.
# In BGP instance view, enable BGP to establish EBGP sessions to indirectly connected EBGP peer group test, and set the maximum hop count to 64 (default).
[Sysname] bgp 100
[Sysname-bgp-default] peer test ebgp-max-hop
peer ttl-security
peer enable
Use peer enable to enable BGP to exchange routing information for an address family with a peer or peer group.
Use undo peer enable to disable BGP from exchanging routing information for an address family with a peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } enable
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP LS address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } enable
In BGP iNOF address family view:
BGP cannot exchange routing information with a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP exchanges routing information for an address family with all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP exchanges routing information for an address family with all dynamic peers in the subnet.
Executing the peer enable command in different views enables BGP to exchange routing information for the corresponding address families with the specified peer.
·     In BGP IPv4 unicast address family view, the command enables the capability to exchange IPv4 unicast routing information. It also adds the learned routes to the BGP routing table of the public network.
·     In BGP-VPN IPv4 unicast address family view, the command enables the capability to exchange IPv4 unicast routing information. It also adds the learned routes to the BGP routing table of the specified VPN instance.
·     In BGP IPv6 unicast address family view, the command enables the capability to exchange IPv6 unicast routing information. It also adds the learned routes to the IPv6 BGP routing table of the public network.
·     In BGP-VPN IPv6 unicast address family view, the command enables the capability to exchange IPv6 unicast routing information. It also adds the learned routes to the IPv6 BGP routing table of the specified VPN instance.
·     In BGP IPv4 multicast address family view, the command enables the capability to exchange IPv4 unicast routes used for RPF check. For information about RPF check, see IP Multicast Configuration Guide.
·     In BGP IPv4 RT filter address family view, the command enables the capability to exchange IPv4 RT filter routing information. In an MPLS L3VPN network, execute the command on PE devices in BGP IPv4 RT filter address family view.
·     In BGP IPv4 SR policy address family view, the command enables the capability to exchange IPv4 SR policy routing information.
·     In BGP iNOF address family view, the command enables the capability to exchange iNOF routing information. It also adds the learned routes to the BGP iNOF routing table.
The undo peer enable command disables BGP to exchange routing information for the corresponding address family with the specified peer.
# In BGP IPv4 unicast address family view, enable BGP to exchange IPv4 unicast routing information with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 enable
display bgp peer
peer fake-as
Use peer fake-as to advertise a fake AS number to a peer or peer group.
Use undo peer fake-as to remove the fake AS number advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } fake-as as-number [ dual-as | prepend-fake-as | prepend-global-as ] *
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } fake-as
No fake local AS number is advertised to a peer or peer group.
BGP instance view
BGP-VPN instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises a fake AS number to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises a fake AS number to all dynamic peers in the subnet.
as-number: Specifies a fake AS number. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
dual-as: Supports both the real AS number and fake AS number for peer establishment.
prepend-fake-as: Adds the fake AS number to the AS_PATH attribute in packets received from a peer.
prepend-global-as: Adds the real AS number to the AS_PATH attribute in packets sent to a peer.
After you move a BGP router from an AS to another AS (Router A from AS 2 to AS 3, for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
If you execute the peer fake-as command on the local router, specify the local router's AS number on the peer as the fake local AS number specified in the command.
The prepend-fake-as and prepend-global-as keywords take effect only when BGP establishes a session to its peer using a fake AS number.
When you specify the dual-as keyword, BGP initiates session requests to a peer using the real AS number and fake AS number in turn until a session is established. The first session request contains the real AS number. When the session goes down and BGP re-initiates session requests to the peer, the first session request contains the most recent AS number before the session goes down.
The peer fake-as command is applicable only to EBGP peers and peer groups. When you set the AS number of the specified peer as the fake AS number in the peer fake-as command, follow these restrictions and guidelines:
·     If the device successfully establishes a session to the specified peer by using the fake AS number, the device considers the peer as an IBGP peer.
·     If the device successfully establishes a session to the specified peer by using the actual AS number, the device considers the peer as an EBGP peer.
·     Both the features supported only by IBGP peers and the features supported only by EBGP peers are configurable for the peer. However, only the features supported by the established peer session can take effect on the peer.
·     BGP clears the configuration that takes effect on only IBGP peers for the peer if one of the following conditions exists:
¡     The value for the as-number argument in the peer fake-as command is different from that in the peer as-number command.
¡     The undo peer fake-as command is executed.
# In BGP instance view, advertise a fake AS number of 200 to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test fake-as 200
peer filter-policy
Use peer filter-policy to filter routes advertised to or received from a peer or peer group by using an ACL.
Use undo peer filter-policy to remove the ACL specified to filter routes advertised to or received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { acl-number | name acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy [ acl-number | name acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] } filter-policy { acl-number | name acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } filter-policy [acl-number | name acl-name ] { export | import }
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { acl6-number | name acl6-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { export | import }
No ACL-based filtering is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command filters routes advertised to or received from all dynamic peers in the subnet by using an ACL.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command filters routes advertised to or received from all dynamic peers in the subnet by using an ACL.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
acl6-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
name acl6-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
export: Filters routes advertised to the specified peer/peer group.
import: Filters routes received from the specified peer/peer group.
The specified ACL used by the peer filter-policy command must have been created with the acl command in system view. Otherwise, all routes can pass the ACL.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination network addresses match the source-address source-wildcard argument without matching the masks of the destination addresses.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following steps:
·     To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address.
When you specify an ACL, follow these guidelines:
·     If the specified ACL does not exist or has no rules, all BGP routes can pass the ACL.
·     If a rule in the specified ACL is applied to a VPN instance, the rule will deny all BGP routes.
# In BGP IPv4 unicast address family view, apply ACL 2000 to filter routes advertised to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test filter-policy 2000 export
acl (ACL and QoS Command Reference)
filter-policy export
filter-policy import
peer as-path-acl
peer prefix-list
peer route-policy
peer group
Use peer group to add a peer to a peer group.
Use undo peer group to delete a peer from a peer group.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } group group-name [ as-number as-number ]
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } group group-name
No peers exist in a peer group.
BGP instance view
ipv4-address: Specifies a peer by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to a peer group.
ipv6-address: Specifies a peer by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to a peer group.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
as-number as-number: Specifies an AS for a peer by its number. The value of the as-number argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
You can add a peer to a peer group in the following ways:
·     Use the peer as-number command to create a peer and specify its AS number, and then use the peer group command to add the peer to the peer group.
¡     You can specify the as-number keyword for the peer group command. The AS number must be the same as the AS number specified in the peer as-number command.
¡     If you have specified the AS number of the peer group with the peer as-number command, the peer to be added must have the same AS number as the peer group.
¡     To add a peer to an IBGP peer group, the peer must be an IBGP peer.
·     Use the peer group command to create a peer and add it to the peer group.
¡     If you have specified the AS number of the peer group with the peer as-number command, you do not need to specify the as-number keyword when you execute the peer group command. This is because the AS number of the peer is the same as the peer group. To specify the as-number keyword for the peer group command, make sure the AS number is the same as the peer group.
¡     If no AS number is specified for an EBGP peer group, specify the as-number keyword when you execute the peer group command.
¡     If no AS number is specified for an IBGP peer group, you do not need to specify the as-number keyword when you execute the peer group command. This is because the AS number of the IBGP peer group is the local AS number. To specify the as-number keyword for the peer group command, make sure the AS number is the same as the local AS number.
If you have specified the AS number of a peer group with the peer as-number command, only the peers with the same AS number can be added to the peer group. All peers in the group share the same AS number. If you have not specified the AS number for a peer group, peers added to it can use their own AS numbers.
After you add a peer to a peer group, you must use the peer enable command to enable BGP to exchange routing information with the peer group.
# In BGP instance view, add peer 10.1.1.1 to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] group test external
[Sysname-bgp-default] peer 10.1.1.1 group test as-number 2004
group
peer as-number
peer enable
peer high-priority
Use peer high-priority to set a high priority for BGP routes learned from a peer or peer group during optimal route selection.
Use undo peer high-priority to remove the configuration.
In BGP IPv4 unicast address family view/BGP IPv6 unicast address family view/BGP LS address family view/BGP VPNv4 address family view/BGP VPNv6 address family view/BGP-VPN IPv4 unicast address family view/BGP-VPN IPv6 unicast address family view/BGP EVPN address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
In BGP IPv4 multicast address family view/BGP-VPN VPNv4 address family view/BGP IPv4 RT filter address family view/BGP IPv4 SR policy address family view:
peer { group-name | ipv4-address [ mask-length ] } high-priority
undo peer { group-name | ipv4-address [ mask-length ] } high-priority
peer { group-name | ipv6-address [ prefix-length ] } high-priority
undo peer { group-name | ipv6-address [ prefix-length ] } high-priority
BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
BGP VPNv4 address family view/BGP VPNv6 address family view/BGP-VPN VPNv4 address family view
BGP IPv4 SR policy address family view/BGP IPv6 SR policy address family view
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP prefers routes learned from all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP prefers routes learned from all dynamic peers in the subnet.
Routes learned from the specified peer or peer group take precedence over routes learned from other peers or peer groups if these routes have the same prefix. BGP uses this rule to continue route selection if it fails to select an optimal route by using the peer type selection rule. If BGP still fails route selection, it uses the IGP metric selection rule to select an optimal route. For more information about the peer type selection and IGP metric selection rules, see BGP route selection in BGP Configuration Guide.
# In BGP IPv4 unicast address family view, set a high priority for BGP routes learned from peer group test during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test high-priority
peer ignore-first-as
Use peer ignore-first-as to configure BGP to ignore the first AS number of EBGP route updates received from a peer or peer group.
Use undo peer ignore-first-as to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-first-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-first-as
BGP checks the first AS number of an EBGP-learned route update. If the first AS number is neither that of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the first AS number of EBGP route updates received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the first AS number of EBGP route updates received from all dynamic peers in the subnet.
This command takes effect only on the EBGP routes received after you execute this command. After you execute the undo peer ignore-first-as command, BGP advertises a ROUTE-REFRESH message to request the routing information from the EBGP peer or peer group.
# In BGP instance view, configure BGP to ignore the first AS number of EBGP route updates received from peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test ignore-first-as
ignore-first-as
peer ignore-originatorid
Use peer ignore-originatorid to configure BGP to ignore the ORIGINATOR_ID attribute in BGP route updates.
Use undo peer ignore-originatorid to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-originatorid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-originatorid
BGP does not ignore the ORIGINATOR_ID attribute in BGP route updates.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the ORIGINATOR_ID attribute in BGP route updates from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the ORIGINATOR_ID attribute in BGP route updates from all dynamic peers in the subnet.
Before using this command, make sure it does not cause any routing loops to the network.
Before forwarding a route received from a client, the route reflector adds an ORIGINATOR_ID attribute (the router ID of the client) to the route. By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID.
Some networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
# In BGP instance view, configure BGP to ignore the ORIGINATOR_ID attribute in BGP route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore-originatorid
peer listen-as (for a BGP peer group)
Use peer listen-as to specify AS numbers for the dynamic peers in a peer group.
Use undo peer listen-as to delete AS numbers specified for the dynamic peers in a peer group.
peer group-name listen-as as-number-list
undo peer group-name listen-as [ as-number-list ]
No AS numbers are specified for the dynamic peers in a peer group.
BGP instance view
as-number-list: Specifies a list of AS numbers for dynamic peers in the peer group. The format of the as-number-list argument is as-number&<1-6>. The as-number argument specifies an AS number in the range of 1 to 4294967295. &<1-6> indicates that you can specify a maximum of six AS numbers at a time.
When the dynamic peers in a BGP peer group are located in different ASs, network configuration and maintenance might be laborious. This command can simplify network configuration and maintenance by specifying the related AS numbers for the peer group. All dynamic peers in the peer group can then automatically establish BGP sessions to the local device.
Execute the group command to create an EBGP peer group before executing this command.
Operating mechanism
With this command configured for a peer group, a dynamic peer in that peer group can establish a peer relationship with the local device as long as its AS number is one of the specified AS numbers.
This command takes effect only on the dynamic peers within a peer group. It does not take effect on non-dynamic peers.
This command is available only for EBGP peer groups. When you execute this command, do not specify the local AS number.
After you delete all AS numbers specified for a peer group, all dynamic peers in that peer group will also be deleted.
If the peer listen-as or peer listen-as-segment command is configured for a BGP peer group, only dynamic peers can join that peer group. If no AS number is specified for a BGP peer group containing peers, neither of the peer listen-as and peer listen-as-segment commands can be used to specify AS numbers for that peer group. The peer listen-as and peer listen-as-segment commands are applicable to a peer group only if that peer group does not contain any peers.
You can specify up to six AS numbers for dynamic peers in a peer group by repeating this command.
The peer listen-as, peer as-number, and peer listen-as-segment commands are mutually exclusive with each other. Do not configure them simultaneously.
If you execute the undo peer listen-as command without specifying the as-number-list argument, this command will delete all AS numbers from the specified peer group. If you specify the as-number-list argument, this command will delete only the specified AS numbers.
# In BGP instance view, specify AS numbers 2000 and 2001 for BGP peer group ebgp.
[Sysname] bgp 100
[Sysname-bgp-default] group ebgp external
[Sysname-bgp-default] peer ebgp listen-as 2000 2001
group
peer as-number
peer listen-as (for a dynamic BGP peer)
Use peer listen-as to create a dynamic BGP peer and specify its AS numbers.
Use undo peer listen-as to delete a dynamic BGP peer.
peer { ipv4-address mask-length | ipv6-address  prefix-length } listen-as as-number-list
undo peer { ipv4-address mask-length | ipv6-address prefix-length } listen-as [ as-number-list ]
No variable AS numbers are configured for a dynamic BGP peer.
BGP instance view
as-number-list: Specifies a list of AS numbers for the dynamic peer. The format of the as-number-list argument is as-number&<1-6>. The as-number argument specifies an AS number in the range of 1 to 4294967295. &<1-6> indicates that you can specify a maximum of six AS numbers at a time.
When the dynamic peers in a network segment are located in different ASs, network configuration and maintenance might be laborious. This command can simplify network configuration and maintenance by specifying the related AS numbers for dynamic peers in that network segment. The dynamic peers can then automatically establish BGP sessions to the local device.
Operating mechanism
With this command configured for a network segment, a dynamic peer in that network segment can establish a peer relationship with the local device as long as its AS number is one of the specified AS numbers.
This command is available only for EBGP dynamic peers. When you execute this command, do not specify the local AS number.
You can specify up to six AS numbers for dynamic peers in a network segment by repeating this command.
If a dynamic peer is configured with this command, it cannot join any peer group. If a dynamic peer has joined a peer group, you cannot configure this command for that dynamic peer.
To delete all dynamic peers within a network segment, execute the undo peer listen-as command without specifying the as-number-list argument. If the as-number-list argument is specified, the undo peer listen-as command will only delete the dynamic peers in the specified ASs.
In BGP instance view, create dynamic peer 10.1.1.0/24 and specify AS numbers 2000 and 2001 for the dynamic peer.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.0 24 listen-as 2000 2001
peer as-number
peer listen-as-segment (for a BGP peer group)
Use peer listen-as-segment to specify an AS number range for the dynamic peers in a peer group.
Use undo peer listen-as-segment to delete an AS number range specified for the dynamic peers in a peer group.
peer group-name listen-as-segment begin-as as-number end-as as-number
undo peer group-name listen-as-segment begin-as as-number end-as as-number
No AS number ranges are specified for the dynamic peers in a peer group.
BGP instance view
begin-as as-number: Specifies the start AS number. The value range is 1 to 4294967295.
end-as as-number: Specifies the end AS number. The value range is 1 to 4294967295. The end AS number must be higher than the start AS number.
Operating mechanism
With this command configured for a peer group, a dynamic peer in that peer group can establish a peer relationship with the local device as long as its AS number belongs to the specified AS number ranges.
After you delete all AS number ranges specified for a peer group, all dynamic peers in that peer group will also be deleted.
You can specify up to 16 AS number ranges for dynamic peers in a peer group by repeating this command. All of the specified AS number ranges can take effect. When you execute this command multiple times, make sure the specified AS number ranges do not overlap with each other. You cannot edit the AS number ranges that are already in effect. To edit an AS number range specified for a peer group, first execute the undo peer listen-as-segment command to delete that AS number range from the peer group.
In BGP instance view, specify AS number range 2000 to 2010 for dynamic peers in BGP peer group ebgp.
[Sysname] bgp 100
[Sysname-bgp-default] peer ebgp listen-as-segment begin-as 2000 end-as 2010
group
peer as-number
peer listen-as
peer listen-as-segment (for a dynamic BGP peer)
Use peer listen-as-segment to create a BGP dynamic peer and specify an AS number range for the peer.
Use undo peer listen-as-segment to delete a BGP dynamic peer.
peer { ipv4-address mask-length  | ipv6-address  prefix-length } listen-as-segment begin-as as-number end-as as-number
undo peer { ipv4-address mask-length | ipv6-address  prefix-length } listen-as-segment begin-as as-number end-as as-number
BGP instance view
Operating mechanism
With this command configured for a network segment, a dynamic peer in that network segment can establish a peer relationship with the local device as long as its AS number belongs to the specified AS number ranges.
You can specify up to 16 AS number ranges for dynamic peers in a network segment by repeating this command. All of the specified AS number ranges can take effect. When you execute this command multiple times, make sure the specified AS number ranges do not overlap with each other. You cannot edit the AS number ranges that are already in effect. To edit an AS number range specified for a network segment, first execute the undo peer listen-as-segment command to delete that AS number range from the network segment.
In BGP instance view, create dynamic peer 10.1.1.0/24 and specify AS number range 2000 to 2010 for the dynamic peer.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.0 24 listen-as-segment begin-as 2000 end-as 2010
peer as-number
peer listen-as
peer log-change
Use peer log-change to enable logging for BGP session state changes for a peer or peer group.
Use undo peer log-change to disable logging for BGP session state changes for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } log-change
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } log-change
Logging for BGP session state changes is enabled for all peers or peer groups.
BGP instance view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must already exist.
ipv4-address: Specifies the IPv4 address of a peer. The peer must already exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables the logging of BGP session state changes for all dynamic peers in the subnet.
ipv6-address: Specifies the IPv6 address of a peer. The peer must already exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables the logging of BGP session state changes for all dynamic peers in the subnet.
After you execute both the log-peer-change and peer log-change commands, BGP logs session establishment and disconnection events for the peer or peer group. To view the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center of the device. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
If you disable logging for BGP session state changes globally or disable logging for a peer or peer group, BGP does not generate logs for session establishments and disconnections.
# In BGP instance view, enable logging for BGP session state changes for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default] peer 1.1.1.1 log-change
display bgp peer
log-peer-change
peer next-hop-invariable
Use peer next-hop-invariable to disable the device from changing the NEXT_HOP attribute of routes advertised to a peer or peer group.
Use undo peer next-hop-invariable to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-invariable
BGP sets the local device as the next hop for all routes advertised to an EBGP peer or peer group. BGP does not set the local device as the next hop for EBGP routes advertised to an IBGP peer or peer group. When BGP sends equal-cost routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command does not change the NEXT_HOP attribute of routes advertised to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command does not change the NEXT_HOP attribute of routes advertised to all dynamic peers in the subnet.
This command disables the device from changing the NEXT_HOP attribute of routes advertised to peers. It is applicable to the networks where the advertisement of default routes hampers that of other routes. On an inter-AS peer-to-peer network, you can configure this command on the edge devices to disable them from changing the NEXT_HOP attribute of routes advertised to EBGP peers.
To ensure that directly-connected EBGP peers can receive routes from the device, be cautious when you configure this command for these peers. A directly-connected EBGP peer does not receive any route whose next hop is not in the same subnet as that of the peer.
To change the NEXT_HOP attribute of routes after configuring this command, you can configure a BGP route distribution policy that includes a routing policy.
When the device advertises the redistributed routes to IBGP peers, it changes the NEXT_HOP attribute of these routes regardless of the configuration of this command.
The following commands are mutually exclusive when you execute them for the same peer or peer group:
·     peer next-hop-local
·     peer next-hop-invariable
# In BGP IPv4 unicast address family view, disable the device from changing the NEXT_HOP attribute of routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 next-hop-invariable
peer next-hop-local
peer next-hop-local
Use peer next-hop-local to set the local device IP as the next hop for routes sent to a peer or peer group.
Use undo peer next-hop-local to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-local
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-local
When BGP advertises a route to an EBGP peer, it processes the next hop of that route as follows:
·     If the EBGP peer is a directly connected peer and the next hop of the route is in the same network as the peer-facing interface of the local device, BGP does not change the next hop of the route.
·     In other scenarios, BGP sets the local device IP as the next hop of the route.
It does not set the local device IP as the next hop for EBGP routes sent to an IBGP peer or peer group for other address families. When BGP sends equal-cost routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command sets the local device as the next hop for routes sent to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command sets the local device as the next hop for routes sent to all dynamic peers in the subnet.
By default, BGP does not set the local device as the next hop for EBGP routes sent to an IBGP peer or peer group. To ensure that an IBGP peer can find the next hop, you can use this command to specify the device as the next hop for routes sent to the IBGP peer.
The peer next-hop-local command is mutually exclusive with the peer next-hop-invariable command. Follow these restrictions and guidelines when you configure the commands for a peer or peer group:
·     After you configure the peer next-hop-local command for a peer group, you cannot configure the peer next-hop-invariable command for the peer group or any peer in the peer group.
·     After you configure the peer next-hop-local command for a peer, do not configure the peer next-hop-invariable command for the peer group to which the peer belongs. Otherwise, the configuration of the peer next-hop-invariable command will overwrite that of the peer next-hop-local command on the peer.
A route reflector can change the NEXT_HOP attribute of reflected routes only if it is configured with both of the peer next-hop-local and reflect change-path-attribute commands.
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test next-hop-local
peer preferred-value
Use peer preferred-value to set a preferred value for routes received from a peer or peer group.
Use undo peer preferred-value to remove the configuration.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP EVPN address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } preferred-value
The preferred value is 0 for routes received from a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a preferred value for routes received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a preferred value for routes received from all dynamic peers in the subnet.
value: Specifies a preferred value in the range of 0 to 65535.
If multiple routes that have the same destination are learned from different peers, you can specify different preferred values for the routes as needed to control BGP path selection. The one with the greatest preferred value is selected as the optimal route to the destination.
The preferred value is used for route selection on the local router and is not advertised to the peer. It has only local significance.
You can also use the apply preferred-value command in a routing policy to configure the preferred value for BGP routes. If both the peer preferred-value and apply preferred-value commands are configured, the apply preferred-value command applies. If the preferred value is not set in the routing policy or no routing policy is configured, the peer preferred-value command applies.
# In BGP IPv4 unicast address family view, set the preferred value to 50 for routes from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 preferred-value 50
route-policy
peer prefix-list
Use peer prefix-list to specify a prefix list to filter routes received from or advertised to a peer or peer group.
Use undo peer prefix-list to remove the prefix list specified to filter routes received from or advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length } prefix-list ipv4-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length } prefix-list [ ipv4-prefix-list-name ] { export | import }
In BGP IPv4 multicast address family view/BGP IPv4 SR policy address family view:
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv4-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } prefix-list [ ipv4-prefix-list-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list [ ipv6-prefix-list-name ] { export | import }
No prefix list based filtering is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command uses a prefix list to filter routes received from or advertised to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command uses a prefix list to filter routes received from or advertised to all dynamic peers in the subnet.
ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the filter to routes advertised to the specified peer/peer group.
import: Applies the filter to routes received from the specified peer/peer group.
The specified prefix list must have been created with the ip prefix-list or ipv6 prefix-list command in system view. If you specify a nonexistent IPv4/IPv6 prefix list, all routes can pass the prefix list.
# In BGP IPv4 unicast address family view, use IPv4 prefix list list1 to filter routes advertised to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test prefix-list list1 export
ip prefix-list
ipv6 prefix-list
peer as-path-acl
peer filter-policy
peer route-policy
peer public-as-only
Use peer public-as-only to remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
Use undo peer public-as-only to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
undo peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command removes private AS numbers in BGP updates sent to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command removes private AS numbers in BGP updates sent to all dynamic peers in the subnet.
force: Removes or replaces all private AS numbers with the local AS number.
limited: Removes or replaces all private AS numbers on the left of the first non-private AS number.
replace: Replaces all private AS numbers with the local AS number. If you do not specify this keyword, this command removes all private AS numbers in BGP updates.
include-peer-as: Removes or replaces the AS number of the specified peer or peer group if it is a private AS. If you do not specify this keyword, this command does not remove or replace the AS number of the specified peer or peer group.
CAUTION
CAUTION:
Use this feature with caution, because changing the AS_PATH attribute might cause routing loops.
Private AS numbers are typically used in test networks, and need not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
After you execute the command without specifying the force keyword or the limited keyword, you can get the following results:
·     If the AS_PATH attribute of a BGP update carries only private AS numbers, the device removes the AS numbers before sending the update to the EBGP peer or peer group.
·     If the AS_PATH attribute carries both public and private AS numbers, the command does not take effect. The device sends the BGP update to the EBGP peer or peer group without removing the private AS numbers.
·     If the AS_PATH attribute carries AS numbers of the peer or peer group, the command does not take effect. The device sends the BGP update to the peer or peer group without removing the private AS numbers.
This command is applicable only to EBGP peers and peer groups.
# In BGP IPv4 unicast address family view, remove private AS numbers in BGP updates sent to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test public-as-only
peer reflect-client
Use peer reflect-client to configure the device as a route reflector and specify a peer or peer group as a client.
Use undo peer reflect-client to remove the configuration.
In /BGP EVPN address family view/BGP IPv4 multicast address family view/BGP IPv4 RT filter address family view/BGP IPv4 SR policy address family view/BGP IPv4 tunnel-encap-ext address family view:
undo peer { group-name | ipv4-address [ mask-length ] } reflect-client
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-client
In BGP LS address family view:
Neither the route reflector nor the client is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
Using route reflectors can solve the issue brought by too many IBGP connections. After you configure a device as a route reflector in an AS, it advertises routes as follows:
·     Advertises routes received from a non-client IBGP peer to all clients.
·     Advertises routes received from an IBGP peer that acts as a client to all peers.
·     Advertises routes received from an EBGP peer to all peers.
# In BGP IPv4 unicast address family view, configure the local device as a route reflector and specify IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test reflect-client
reflect between-clients
reflector cluster-id
peer route-limit
Use peer route-limit to set the maximum number of routes that can be received from a peer or peer group.
Use undo peer route-limit to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit
The number of routes that can be received from a peer or peer group is not limited.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies the maximum number of routes that can be received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies the maximum number of routes that can be received from all dynamic peers in the subnet.
prefix-number: Specifies the number of routes that can be received from the peer or peer group.The value range for this argument is 1 to 4294967295. The router will tear down the session to the peer or peer group if the following conditions exist:
·     The alert-only, discard, and reconnect keywords are not specified.
·     The number of routes received from the peer or peer group reaches the prefix-number.
The router will not attempt to re-establish the session to a dynamic BGP peer until the router receives a connection request from the peer. For other peers, you can use the reset bgp command to re-establish the sessions.
alert-only: If the number of routes received from the peer or peer group reaches the prefix-number, the router generates a log message instead of tearing down the session to the peer or peer group. The router can continue to receive routes from the peer or peer group.
discard: If the number of routes received from the peer or peer group reaches the prefix-number, the router retains the session to the peer or peer group. However, it discards excess routes and generates a log message. After the number of routes received from the peer or peer group falls below the prefix-number, the router can continue to receive routes from the peer or peer group. To restore the discarded routes, use the refresh bgp import command to request the peer or peer group to resend the routes.
reconnect reconnect-time: Specifies a reconnect time. After the specified time is reached, the router re-establishes a session to the peer or peer group when the number of routes received from the peer or peer group reaches the prefix-number. The value range for the reconnect-time argument is 1 to 65535 seconds. This option is not available for dynamic BGP peers.
percentage-value: Specifies the threshold value for the router to generate a log message (the router generates a log message when the ratio of the number of received routes to the prefix-number exceeds the percentage value). The value range of this argument is 1 to 100, and the default is 75.
When the number of routes received from the specified peer or peer group reaches prefix-number, the discard keyword takes effect on the device as follows:
·     The device retains the routes already received from the peer or peer group.
·     If the device receives subsequent routes from the peer or peer group, it will discard these routes.
# In BGP IPv4 unicast address family view, set the maximum number of routes that can be received from peer 1.1.1.1 to 10000. Configure the router to tear down the session to the peer if the number is exceeded.
[Sysname] bgp 109
[Sysname-bgp-default-ipv4] peer 1.1.1.1 route-limit 10000
peer route-policy
Use peer route-policy to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use undo peer route-policy to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } route-policy [ route-policy-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy [ route-policy-name ] { export | import }
No routing policy is applied to routes incoming from or outgoing to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command applies a routing policy to routes incoming from or outgoing to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command applies a routing policy to routes incoming from or outgoing to all dynamic peers in the subnet.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the routing policy to routes outgoing to the peer or peer group.
import: Applies the routing policy to routes incoming from the peer or peer group.
The specified routing policy must have been configured with the route-policy command in system view. When a routing policy that does not exist is specified, routes are filtered based on the following rules:
·     If you execute the route-policy non-exist-deny command, all routes can pass the routing policy.
·     If you do not execute the route-policy non-exist-deny command, all routes cannot pass the routing policy.
The apply clause used to modify the AS_PATH attributes in the specified routing policy does not take effect on routes advertised to IBGP peers or peer groups.
The if-match interface command, if configured for the applied routing policy, does not take effect on routes.
# In BGP IPv4 unicast address family view, apply routing policy test-policy to routes outgoing to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test route-policy test-policy export
peer as-path-acl
peer filter-policy
peer prefix-list
route-policy (Layer 3—IP Routing Command Reference)
route-policy non-exist-deny (Layer 3—IP Routing Command Reference)
peer route-update-interval
Use peer route-update-interval to control the frequency of sending the same route update to a peer or peer group.
Use undo peer route-update-interval to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval { interval | intelligent-timer }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval
The interval for sending the same update to an IBGP peer is 15 seconds and the interval for sending the same update to an EBGP peer is 30 seconds.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies an interval for sending the same update to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies an interval for sending the same update to all dynamic peers in the subnet.
interval: Specifies a minimum interval for sending the same update message, in the range of 0 to 600 seconds.
intelligent-timer: Uses the intelligent timer specified by the route-update-interval intelligent-timer command to suppress the frequency of sending the same update.
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. This command can reduce the impact of routing flaps by suppressing the frequency of sending the same update to a peer or peer group.
BGP compares the timer values specified for a BGP peer by using the route-update-delay command and the peer route-update-interval command. Only the larger timer value takes effect. If you did not execute the peer route-update-interval command, BGP compares the BGP route advertisement delay timer with the default value of the peer route-update-interval command.
# In BGP instance view, set the interval for sending the same update to peer group test to 10 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] peer test as-number 100
[Sysname-bgp-default] peer test route-update-interval 10
route-update-delay
peer send-buffer-size
Use peer send-buffer-size to set the send buffer size for a peer or peer group.
Use undo peer send-buffer-size to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } send-buffer-size size
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } send-buffer-size
The send buffer size for a peer or peer group is not set. The send buffer size configured by the send-buffer-size command applies.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
size: Specifies the send buffer size in the range of 2048 to 327680 bytes.
A small send buffer size might cause a long convergence time when there are a large number of update messages to send. Execute this command to set an appropriate send buffer size to improve the convergence performance.
The configuration of this command takes precedence over that of the send-buffer-size command.
This command takes effect only on BGP sessions established or re-established after the command is executed.
# In BGP instance view, set the send buffer size for peer group test to 50000 bytes.
[Sysname] bgp 100
[Sysname-bgp-default] peer test send-buffer-size 50000
send-buffer-size
peer source-address
Use peer source-address to specify a source IPv4 or IPv6 address for establishing TCP connections to a peer or peer group.
Use undo peer source-address to remove the configuration.
peer ipv4-address [ mask-length ] source-address source-ipv4-address
peer ipv6-address [ prefix-length ] source-address source-ipv6-address
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } source-address
peer group-name source-address { source-ipv4-address | source-ipv6-address } *
undo peer group-name source-address [ source-ipv4-address | source-ipv6-address ]
BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route destined for the BGP peer or peer group as the source address for TCP connection establishment.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source IP address for establishing TCP connections to all dynamic peers in the subnet.
source-ipv4-address: Specifies a source IPv4 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source IPv6 address for establishing TCP connections to all dynamic peers in the subnet.
source-ipv6-address: Specifies a source IPv6 address.
The peer connect-interface command and the peer source-address command can both change the source address for establishing TCP connections. If you execute both commands, the most recent configuration takes effect.
The peer source-address and peer connect-interface commands are applicable to the following scenarios:
·     The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡     Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡     Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
·     A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
·     On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this issue, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
·     You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this issue, use one of the following methods:
¡     If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡     If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
The source addresses on the local router and the peer must be reachable to each other.
To specify the address of an indirectly connected interface as the source address, use the peer ebgp-max-hop command. The command allows the establishment of an EBGP session to the indirectly connected peer.
You can specify both a source IPv4 address and a source IPv6 address for a peer group. BGP uses the source IPv4 address to establish TCP connections to IPv4 peers in the group. It also uses the source IPv6 address to establish TCP connections to IPv6 peers in the group.
# In BGP instance view, specify source IPv4 address 1.1.1.1 for peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test source-address 1.1.1.1
peer ebgp-max-hop
peer substitute-as
Use peer substitute-as to replace the AS number of a peer or peer group in the AS_PATH attribute with the local AS number.
Use undo peer substitute-as to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } substitute-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } substitute-as
The AS number of a peer or peer group in the AS_PATH attribute is not replaced.
BGP instance view
BGP-VPN instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command replaces the AS number of all dynamic peers in the subnet in the AS_PATH attribute with the local AS number.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command replaces the AS number of all dynamic peers in the subnet in the AS_PATH attribute with the local AS number.
If different CEs use the same AS number, you must configure the relevant PE to replace the AS number of the attached CE with its own AS number. Before advertising a route whose AS_PATH attribute contains the AS number of the CE, the PE replaces the CE's AS number with its own AS number. This ensures correct advertisement of private network routes.
# In BGP instance view, substitute the local AS number for the AS number of peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 substitute-as
peer soo
peer timer
Use peer timer to set a keepalive interval and hold time for a peer or peer group.
Use undo peer timer to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer
The keepalive interval is 60 seconds, and the hold time is 180 seconds.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures a keepalive interval and hold time for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures a keepalive interval and hold time for all dynamic peers in the subnet.
keepalive keepalive: Sets a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Sets a hold time in the range of 3 to 65535 seconds. The hold time must be at least three times the keepalive interval.
After establishing a BGP session, two routers send keepalive messages at the specified keepalive interval to each other to keep the session.
If a router receives no keepalive or update message from the peer within the hold time, it tears down the session.
The timers configured with this command are preferred to the timers configured with the timer command.
If the hold time settings on the local and peer routers are different, the smaller one is used.
If the hold time is set to 0, no keepalive message will be sent to the peer, and the peer session will never time out. If neither the hold time nor the keepalive interval is set to 0, the actual keepalive interval is the smaller one between one third of the hold time and the keepalive interval.
The timers configured with this command do not take effect until a session is re-established (for example, a session is reset).
# In BGP instance view, set the keepalive interval and hold time for peer group test to 60 seconds and 180 seconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] peer test timer keepalive 60 hold 180
display bgp peer
timer
peer timer connect-retry
Use peer timer connect-retry to set the session retry timer for a peer or peer group.
Use undo peer timer connect-retry to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer connect-retry retry-time
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer connect-retry
The session retry timer is 32 seconds for a peer or peer group.
BGP instance view
retry-time: Specifies a session retry timer in the range of 1 to 65535 seconds.
To speed up session establishment to a peer or peer group and route convergence, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
# In BGP instance view, set the session retry timer to 30 seconds for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 timer connect-retry 30
timer connect-retry
preference
Use preference to configure preferences for BGP routes.
Use undo preference to restore the default.
undo preference
The preferences of external, internal, and local BGP routes are 255, 255, and 130, respectively.
external-preference: Specifies a preference for EBGP routes, in the range of 1 to 255. A smaller value indicates a higher preference.
internal-preference: Specifies a preference for IBGP routes, in the range of 1 to 255. A smaller value indicates a higher preference.
local-preference: Specifies a preference for local routes, in the range of 1 to 255. A smaller value indicates a higher preference.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set the route preference for matching routes. Routes not matching the routing policy use the default preference.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
Configuring the preferences for BGP routes changes the possibility for the routes to become the optimal route.
To use a routing policy to set the preference, you must configure the preference with the apply preference command in the routing policy in advance. Otherwise, all matching routes use the default preference.
You can use the preference command to configure preferences for BGP routes generated by the local device. In the current software version, this command takes effect only on BGP summary routes generated by using the aggregate command.
# In BGP IPv4 unicast address family view, set preferences for EBGP, IBGP, and local routes to 20, 20, and 200, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] preference 20 20 200
aggregate
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable route reflection between clients.
Route reflection between clients is enabled.
BGP IPv4 MVPN address family view
BGP IPv4 flowspec address family view
BGP IPv6 flowspec address family view
When a route reflector is configured, and the clients of a route reflector are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use the undo reflect between-clients command to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
# In BGP IPv4 unicast address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] undo reflect between-clients
peer reflect-client
Use reflect change-path-attribute to enable the route reflector to change the attributes of routes to be reflected.
Use undo reflect change-path-attribute to restore the default.
A route reflector cannot change the attributes of routes to be reflected.
By default, the route reflector does not change the attributes of routes before route reflection to avoid routing loops. When you replan network traffic, you can use this command to allow the route reflector to change the attributes of the routes to be reflected.
After using the reflect change-path-attribute command, you can use the peer route-policy export command to apply a routing policy that can change the attributes of the routes to be reflected. The following apply commands can define how the routing policy modifies route attributes:
·     Use apply origin to change the ORIGIN attribute of routes.
·     Use apply ip-address next-hop or apply ipv6 next-hop to change the NEXT_HOP attribute of routes.
·     Use apply cost to change the MED attribute of routes.
·     Use apply local-preference to change the local preference for routes.
·     Use apply community to configure the COMMUNITY attribute of routes. For BGP to advertise the COMMUNITY attribute to a peer or peer group, use the peer advertise-community command.
·     Use apply comm-list delete to delete COMMUNITY attribute values from routes.
·     Use apply extcommunity to configure the link bandiwidth or RT extended community attribute of routes. For BGP to advertise extended community attributes to a peer or peer group, use the peer advertise-ext-community command.
·     Use apply extcommunity color to configure the color extended community attribute of routes.
·     Use apply extcommunity soo to configure the SoO extended community attribute of routes.
·     Use apply large-community to configure the large community attribute for BGP routes. For BGP to advertise the large community attribute to a peer or peer group, use the peer advertise-large-community command.
·     Use apply large-comm-list delete to delete large community attribute values from routes.
·     Use apply aigp to configure the AIGP attribute for BGP routes. For BGP to advertise the AIGP attribute to a peer or peer group, use the peer aigp command.
For more information about the apply commands, see routing policy commands in Layer 3—IP Routing Command Reference.
# In BGP IPv4 unicast address family view, enable the route reflector to change the attributes of routes to be reflected.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflect change-path-attribute
peer reflect-client
Use reflector cluster-id to configure the cluster ID for a route reflector.
Use undo reflector cluster-id to restore the default.
A route reflector uses its router ID as the cluster ID.
BGP IPv6 unicast address family view
BGP iNOF address family view
cluster-id: Specifies the cluster ID in the format of an integer, in the range of 1 to 4294967295.
ipv4-address: Specifies the cluster ID in the format of an IPv4 address in dotted decimal notation.
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the cluster ID.
You can configure more than one route reflector in a cluster to improve network reliability and prevent a single point of failure. Use this command to configure the same cluster ID for all route reflectors in the cluster to avoid routing loops.
Do not configure the router ID of a client as the cluster ID.
# In BGP IPv4 unicast address family view, set the cluster ID on the local router (a reflector in the cluster) to 80.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflector cluster-id 80
peer reflect-client
reset bgp
Use reset bgp to reset BGP sessions for the specified address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ multicast | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ]
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ multicast | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ]
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } l2vpn evpn
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | internal } inof
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets BGP sessions for the default BGP instance.
as-number: Resets BGP sessions to peers in the AS specified by its number. The value of this argument can be an integer in the range of 1 to 4294967295 or a dotted decimal string in the range of 0.1 to 65535.65535.
ipv4-address: Resets the BGP session to a peer specified by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command resets BGP sessions to all dynamic peers in the subnet.
ipv6-address: Resets the BGP session to a peer specified by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command resets BGP sessions to all dynamic peers in the subnet.
all: Resets all BGP sessions.
external: Resets all EBGP sessions.
group group-name: Resets the BGP sessions to the peers in the peer group specified by its name, a case-sensitive string of 1 to 47 characters.
internal: Resets all IBGP sessions.
ipv4: Resets BGP sessions for IPv4 address family.
ipv6: Resets BGP sessions for IPv6 address family.
link-state: Resets BGP sessions for LS address family.
rtfilter: Resets BGP sessions for IPv4 RT filter address family.
sr-policy: Resets BGP sessions for SR policy address family.
unicast: Resets BGP sessions for unicast address family.
l2vpn evpn: Resets BGP sessions for EVPN address family.
inof: Resets BGP sessions for iNOF address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command resets BGP sessions for the specified address family on the public network.
CAUTION
CAUTION:
A reset operation tears down BGP sessions for a short period of time.
A reset operation enables the router to apply a new route selection policy by re-establishing BGP sessions.
By default, the unicast keyword is used if you do not specify the unicast keyword.
# Reset all BGP sessions for the IPv4 unicast address family on the public network.
<Sysname> reset bgp all ipv4
reset bgp advertise lowest-priority
Use reset bgp advertise lowest-priority to restore the priority of the routes to be advertised during the time to wait for route priority restoration.
reset bgp [ instance instance-name ] advertise lowest-priority { on-peer-up | on-startup }
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command takes effect on the default BGP instance.
on-peer-up: Restores the route priority adjusted by the advertise lowest-priority on-peer-up duration command.
on-startup: Restores the route priority adjusted by the advertise lowest-priority on-startup duration command.
Before using this command, make sure the following conditions exist:
·     The device has completed ARP or ND table convergence and is ready to advertise routes with original priority.
·     The advertise lowest-priority on-peer-up duration or advertise lowest-priority on-startup duration command still takes effect after a peer comes up or the device restarts.
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers.
·     If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
·     If the device restarts again later, the device still minimizes the priority of the routes advertised to peers.
# Restore the route priority adjusted by the advertise lowest-priority on-peer-up duration command.
<Sysname> reset bgp advertise lowest-priority on-peer-up
reset bgp all
Use reset bgp all to reset all BGP sessions for all address families.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets all BGP sessions for all address families of the default BGP instance.
CAUTION
CAUTION:
# Reset all BGP sessions.
reset bgp dampening
Use reset bgp dampening to clear BGP route dampening information and release suppressed BGP routes.
reset bgp [ instance instance-name ] dampening ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] ]
reset bgp [ instance instance-name ] dampening ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears BGP route dampening information and releases suppressed BGP routes for the default BGP instance.
ipv4: Clears BGP IPv4 route dampening information and releases suppressed BGP IPv4 routes.
ipv6: Clears BGP IPv6 route dampening information and releases suppressed BGP IPv6 routes.
unicast: Clears BGP unicast route dampening information and releases suppressed BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears BGP route dampening information for the public network, and releases suppressed BGP routes.
ipv4-address: Specifies an IPv4 destination network address. If you do not specify a network address, this command clears all BGP route dampening information, and releases all suppressed BGP routes.
mask: Specifies a network mask in dotted decimal notation.
ipv6-address: Specifies an IPv6 destination network address. If you do not specify a network address, this command clears all BGP route dampening information, and releases all suppressed BGP routes.
When you execute the reset bgp dampening ipv4 command:
·     If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a BGP IPv4 unicast or multicast route. If the result matches the network address of the route, the command clears dampening information for the route, and releases the suppressed route.
·     If you specify the ipv4-address mask or ipv4-address mask-length argument, this command does the following:
¡     Clears dampening information for the BGP IPv4 unicast or multicast route that matches both the specified destination network address and the mask (or mask length).
¡     Releases the suppressed route.
By default, the unicast keyword is used if neither the unicast keyword nor the multicast keyword is specified.
# Clear dampening information for the BGP IPv4 unicast route to network 20.1.0.0/16 and release the suppressed route.
<Sysname> reset bgp dampening ipv4 20.1.0.0 255.255.0.0
dampening
display bgp routing-table dampened
reset bgp flap-info
Use reset bgp flap-info to clear flap statistics for BGP routes.
reset bgp [ instance instance-name ] flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
reset bgp [ instance instance-name ] flap-info ipv6  [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears flap statistics for the default BGP instance.
ipv4: Clears flap statistics for BGP IPv4 routes.
ipv6: Clears flap statistics for BGP IPv6 routes.
unicast: Clears flap statistics for BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears flap statistics for public BGP routes.
as-path-acl as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256, to filter BGP route flap statistics.
as-path-acl as-path-acl-name: Specifies an AS path list by its name, a case-sensitive string of 1 to 51 characters, to filter BGP route flap statistics. The AS path list name cannot contain only digits.
peer ipv4-address [ mask-length ]: Clears flap statistics for BGP routes learned from the specified IPv4 BGP peer. The mask-length argument specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command clears flap statistics for BGP routes learned from all dynamic peers in the subnet.
peer ipv6-address [ prefix-length ]: Clears flap statistics for BGP routes learned from the specified IPv6 BGP peer. The prefix-length argument specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command clears flap statistics for BGP routes learned from all dynamic peers in the subnet.
When you execute the reset bgp flap-info ipv4 command:
·     If you specify only the ipv4-address argument, the system ANDs the IPv4 network address with the mask of a BGP IPv4 unicast or multicast route. If the result matches the IPv4 network address of the route, this command clears the flap statistics of the route.
·     If you specify the ipv4-address mask or ipv4-address mask-length argument, this command clears the flap statistics of the BGP IPv4 unicast or multicast route that matches both the specified IPv4 destination network address and the mask (or mask length).
By default, the unicast keyword is used.
# Clear flap statistics for the BGP IPv4 unicast route to network 20.1.0.0/16.
<Sysname> reset bgp flap-info ipv4 20.1.0.0 16
dampening
dampening ibgp (MPLS Command Reference)
display bgp routing-table flap-info
router id
Use router id to configure a global router ID.
Use undo router id to restore the default.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies a router ID in IP address format.
Some routing protocols use a router ID to identify a device. You can configure a global router ID, which is used by routing protocols that have no router ID configured.
If no global router ID is configured, the highest loopback address, if any, is used as the router ID. If no loopback address is available, the highest physical interface IP address is used, regardless of the interface status. If no IP address is configured for any interface, the router ID is 0.0.0.0. BGP cannot use router ID 0.0.0.0 for peer session establishment, because the router ID is invalid.
During an active/standby switchover, the standby main processing unit (MPU) checks the validity of the previous router ID backed up before switchover. If it is not valid, it selects a new router ID.
If the interface IP address that is selected as the router ID is removed or modified, a new router ID is selected. The following events will not trigger a router ID re-selection:
·     The interface goes down.
·     After a physical interface address is selected as the router ID, an IP address is configured for a loopback interface.
·     A higher interface IP address is configured.
After you modify the global router ID and reset BGP sessions, the modification does not take effect for a BGP instance that uses the global router ID. To modify the router ID for the BGP instance, use the router-id command in BGP instance view.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
router-id (BGP instance view)
router-id (BGP-VPN instance view)
route-rate-limit
Use route-rate-limit to set the BGP route sending rate.
Use undo route-rate-limit to restore the default.
route-rate-limit rate
The BGP route sending rate is not limited.
BGP instance view
rate: Specifies the maximum number of new routes that BGP can send per second, in the range of 0 to 4294967595. A value of 0 means that BGP does not send newly added routes.
If a device sends many new routes within a short time period, it might be unable to add the routes to the FIB before the peer device adds them. This might result in traffic forwarding failure. To avoid this issue, set an appropriate route sending rate depending on the performance of the device.
If the device performance is high, set a high BGP route sending rate as needed. Otherwise, set a low rate.
To prevent route withdrawal failures when network flapping occurs, avoid setting the rate to 0 or a small value and make sure the rate is high enough for the network.
This command applies only to IPv4 unicast routes and IPv6 unicast routes.
# In BGP instance view, set the BGP route sending rate to 1000.
[Sysname] bgp 100
[Sysname-bgp-default] route-rate-limit 1000
Use route-update-interval intelligent-timer to configure the intelligent timer parameters for route-update suppression interval calculation.
Use undo route-update-interval intelligent-timer to remove the configuration.
route-update-interval intelligent-timer min-update-interval [ max-update-interval [ ignore-delay-count [ incremental-interval ] ] ]
The following intelligent timer settings take effect:
·     The maximum update suppression interval is 30 seconds.
·     The minimum update suppression interval is 5 seconds.
·     BGP can send the same route update to peers three times in a suppression interval.
·     The penalty increment interval is 1 second.
BGP instance view
min-update-interval: Specifies the minimum update suppression interval in seconds. The value range for this argument is 0 to 600.
max-update-interval: Specifies the maximum update suppression interval in seconds. The value range for this argument is 0 to 600.
ignore-delay-count: Specifies the maximum number of times that BGP can send the same route update to peers in a suppression interval. The value range for this argument is 0 to 200 and the default value is 3.
incremental-interval: Specifies the penalty increment interval in seconds. The value range for this argument is 1 to 10 and the default value is 1.
IMPORTANT
IMPORTANT:
This command takes effect only when you use it together with the peer route-update-interval intelligent-timer command.
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. To resolve this issue, you can configure and apply the intelligent timer by using this command together with the peer route-update-interval intelligent-timer command. Then, BGP can flexibly control the interval for sending the same route update to a peer or peer group according to the network condition.
If you apply the intelligent timer, the initial route-update suppression interval takes effect after BGP sends a route update. During the suppression interval, the number of times that BGP can send the same route update to a peer is limited. The length of the next suppression interval depends on the number of route flaps that occur within the current suppression interval as follows:
·     If the number of route flaps increases, the next suppression interval also shortens.
·     If the number of route flaps reduces, the next suppression interval is the same as the current suppression interval or shortens.
After the current suppression interval elapses, BGP can resend the route update, and then the next suppression interval takes effect.
The intelligent timer calculates the suppression interval on a per route basis as follows:
1.     Calculates N.
N equals the count value for the current suppression interval minus ignore-delay-count. After the intelligent timer takes effect, the count value for the first suppression interval equals ignore-delay-count. To calculate the count value for the next suppression interval, use the following algorithm:
¡     If A is greater than B, the count value for the next suppression interval equals B plus one,
¡     If A is not greater than B, the count value for the next suppression interval equals B.
A represents the number of route flaps that occur within the current suppression interval and B represents the count value for the current suppression interval.
The length of the suppression interval depends on N as follows:
¡     If N is zero, the suppression interval equals min-update-interval.
¡     If N is greater than zero, the intelligent timer proceeds to step 2 to calculate the suppression interval.
2.     Uses the following formula to calculate a suppression interval candidate:
Suppression interval = min-update-interval + incremental-interval × 2^N
3.     Compares the candidate with max-update-interval:
¡     If the candidate is less than max-update-interval, the suppression interval equals the candidate.
¡     If the candidate is not less than max-update-interval, the suppression interval equals max-update-interval.
The intelligent timer restores the suppression interval as the network restores. If no route flaps occur during a maximum update suppression interval, the next suppression interval takes effect directly. In this situation, the next suppression interval is min-update-interval and the count value is ignore-delay-count.
The process from entering the first suppression interval to restoring the suppression interval is a route update suppression cycle. The number of times that BGP can send the same route update in a suppression cycle or a suppression interval equals the initial count value. For example, a suppression cycle includes three suppression intervals and the initial count value is five. BGP can send a route update five times in the first suppression interval or once in the first suppression interval, three times in the second, and once in the third. This mechanism ensures fast route convergence upon normal path switchovers or route changes.
# In BGP instance view, configure the intelligent timer parameters for route-update suppression interval calculation.
[Sysname] bgp 100
[Sysname-bgp-default] route-update-interval intelligent-timer 10 60 3 1
route-update-interval withdrawn enable
Use route-update-interval withdrawn enable to apply route update interval setting to withdrawn routes.
Use undo route-update-interval withdrawn enable to restore the default.
Route update interval setting does not apply to withdrawn routes. BGP sends withdrawal messages for withdrawn routes immediately.
BGP instance view
By default, for a route to be withdrawn, a BGP router immediately sends a withdrawal message to its peers. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. To avoid this issue, use this command to apply the route update interval configured in the peer route-update-interval command to withdrawn routes. BGP will send withdrawn and update messages at the specified intervals.
This command does not take effect on routes that exist before the command is configured.
# In BGP instance view, apply route update interval setting to withdrawn routes.
[Sysname] bgp 100
[Sysname-bgp-default] route-update-interval withdrawn enable
Use router-id to configure a router ID for a BGP instance.
Use undo router-id to restore the default.
router-id router-id
undo router-id
No router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router id command in system view.
BGP instance view
router-id: Specifies a router ID for BGP, in IP address format.
To run BGP, a BGP instance must have a router ID, which is an unsigned 32-bit integer that uniquely identifies the router in the AS.
To modify a non-zero router ID for BGP, execute the router-id command in BGP instance view.
To improve availability, specify the IP address of a loopback interface as the router ID for BGP.
If you execute this command in the same BGP instance view multiple times, the most recent configuration takes effect.
You can configure the same router ID for different BGP instances.
# In BGP instance view, set the router ID for BGP to 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] router-id 1.1.1.1
router id
route-update-delay
Use route-update-delay to enable BGP route advertisement delay and set a delay timer.
Use undo route-update-delay to restore the default.
route-update-delay delay-value
BGP route advertisement delay is disabled.
BGP instance view
delay-value: Specifies the BGP route advertisement delay timer in the range of 1 to 600 seconds.
BGP sends update messages to peers when route changes occur or peer relationship establishment is complete. If a large number of routes need to be updated within a short time period, BGP might send update messages to peers before issuing the updated routes to the FIB. As a result, some packets might be discarded because BGP cannot find the forwarding path for the packets.
To resolve this issue, execute this command to enable BGP route advertisement delay and set a delay timer. When route changes occur or peer relationship establishment is complete, BGP cannot send any update messages unless the delay timer expires.
In the current software version, this command is applicable only to BGP IPv4 unicast routes, BGP VPNv4 routes, BGP VPNv6 routes, and BGP IPv6 unicast routes.
# Set the BGP route advertisement delay timer to 60 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] route-update-delay 60
send-buffer-size
Use send-buffer-size to set the send buffer size.
Use undo send-buffer-size to restore the default.
The send buffer size is 32768 bytes.
BGP instance view
size: Specifies the send buffer size in the range of 2048 to 327680 bytes. The default value is 32768.
# In BGP instance view, set the send buffer size to 50000 bytes.
[Sysname] bgp 100
[Sysname-bgp-default] send-buffer-size 50000
snmp context-name
Use snmp context-name to configure an SNMP context for a BGP instance.
Use undo snmp context-name to restore the default.
No SNMP context is configured for a BGP instance.
BGP instance view
context-name: Specifies an SNMP context by its name, a case-sensitive string of 1 to 32 characters.
BGP does not know the BGP instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different BGP instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
·     For an SNMPv3 packet:
¡     The device selects the MIB of the BGP instance default if the packet does not carry a context and no SNMP context was configured for the BGP instance default.
¡     The device selects the MIB of a BGP instance if the packet meets the following conditions:
-     Carries a context that was configured with the snmp-agent context command in system view.
-     Matches the context of the BGP instance.
¡     The device does not process any MIBs in other situations.
·     For an SNMPv1/v2c packet:
¡     The device selects the MIB of the BGP instance default if the following conditions are met:
-     No SNMP community to SNMP context mapping was configured with the snmp-agent community-map command in system view.
-     No SNMP context was configured for the BGP instance default.
¡     The device selects the MIB of a BGP instance if the SNMP community is mapped to an SNMP context and the context matches the context of the BGP instance.
For more information about SNMP contexts and community names, see Network Management and Monitoring Configuration Guide.
Do not configure the same SNMP context for different BGP instances.
# Configure SNMP context bgp-abc for BGP instance abc.
[Sysname-bgp-abc] snmp context-name bgp-abc
snmp-agent community-map (Network Management and Monitoring Command Reference)
snmp-agent context (Network Management and Monitoring Command Reference)
snmp-agent trap enable bgp
Use snmp-agent trap enable bgp to enable SNMP notifications for BGP.
Use undo snmp-agent trap enable bgp to disable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ] [ peer-backward-transition | peer-established ] *
undo snmp-agent trap enable bgp [ instance instance-name ] [ peer-backward-transition | peer-established ] *
SNMP notifications for BGP are enabled.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command enables SNMP notifications for the default BGP instance.
peer-backward-transition: Specifies SNMP notifications when the BGP session with the peer changes from the Established state to another state.
peer-established: Specifies SNMP notifications when the BGP session with the peer enters the Established state.
After you enable SNMP notifications for BGP, the device generates a notification when a BGP session state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state.
If you do not specify an SNMP notification type in the command, BGP enables or disables all types of SNMP notifications. If you specify an SNMP notification type in the command, BGP enables or disables the specified type of SNMP notifications.
For BGP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for BGP.
[Sysname] snmp-agent trap enable bgp
summary automatic
Use summary automatic to configure automatic route summarization for redistributed IGP subnet routes.
Use undo summary automatic to restore the default.
summary automatic
Automatic route summarization is not performed for redistributed IGP subnet routes.
BGP-VPN IPv4 unicast address family view
After the summary automatic command is configured, BGP summarizes IGP subnets redistributed by the import-route command.
Automatic summary routes can be manually summarized, but cannot be added to the IP routing table.
# In BGP IPv4 unicast address family view, configure automatic route summarization for redistributed IGP subnet routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] summary automatic
aggregate
import-route
timer
Use timer to configure a BGP keepalive interval and hold time.
Use undo timer to restore the default.
undo timer
The BGP keepalive interval and the hold time are 60 seconds and 180 seconds, respectively.
BGP instance view
keepalive keepalive: Configures a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Configures a hold time in seconds, whose value is 0 or in the range of 3 to 65535. The hold time must be at least three times the keepalive interval.
Use the timer command to configure the keepalive interval and hold time for all BGP peers. Use the peer timer command to configure the keepalive interval and hold time for a peer or peer group. If both commands are configured, the intervals configured by the peer timer command have higher priority.
The timer command affects only new BGP sessions.
After the timer command is executed, no peer session is closed at once. The configured hold time is used for negotiation in session re-establishment (for example, when you reset the BGP session).
# In BGP instance view, set the keepalive interval and hold time to 60 seconds and 180 seconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] timer keepalive 60 hold 180
display bgp peer
peer timer
timer connect-retry
Use timer connect-retry to set the session retry timer for all peers and peer groups.
Use undo timer connect-retry to restore the default.
The session retry timer is 32 seconds for all peers and peer groups.
BGP instance view
# In BGP instance view, set the session retry timer to 30 seconds for all peers.
[Sysname] bgp 100
[Sysname-bgp-default] timer connect-retry 30
update-first route-policy
Use update-first route-policy to configure BGP to send withdrawal messages of routes matching the specified routing policy prior to other routes.
Use undo update-first route-policy to restore the default.
BGP does not send withdrawal messages of any routes prior to other routes.
BGP VPNv4 address family view
BGP-VPN IPv6 unicast address family view
BGP VPNv6 address family view
BGP IPv4 multicast address family view
BGP IPv6 multicast address family view
This command enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast route switchover and reduce the traffic interruption time.
# In BGP IPv4 unicast address family view, configure BGP to send withdrawal messages of routes matching routing policy test-policy prior to other routes.
[Sysname] bgp 1
[Sysname-bgp-default-ipv4] update-first route-policy test-policy
default-route update-first
route-policy
