- 06-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-Basic BGP commands
- 07-Advanced BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-DCN commands
- 15-Adaptive routing commands
| 08-Policy-based routing commands | 151.66 KB |
display ip policy-based-route global
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
ip policy-based-route-log enable
reset ip policy-based-route statistics
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops.
Use undo apply loadshare to restore the default.
apply loadshare next-hop
undo apply loadshare next-hop
Multiple next hops operate in primary/backup mode.
Policy node view
next-hop: Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
· Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over.
· Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed.
If the apply loadshare-mode command is configured, the load sharing mode depends on the setting in the apply loadshare-mode command.
# Enable load sharing among multiple next hops.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
apply next-hop
Use apply loadshare-mode to specify the load sharing mode for multiple next hops.
Use undo apply loadshare-mode to restore the default.
apply loadshare-mode next-hop { robin | spray }
undo apply loadshare-mode [ next-hop ]
Load sharing is not performed among multiple next hops.
Policy node view
next-hop: Specifies the load sharing mode for next hops.
robin: Selects load-shared links based on packets according to the next hop configuration order.
spray: Selects the member links with lighter load among the load-shared links based on packets.
To enable multiple next hops specified in the PBR policy to operate in load sharing mode, you must execute the apply loadshare next-hop command.
# Enable multiple next hops to operate in the robin load sharing mode.
[Sysname-pbr-aa-11] apply loadshare-mode next-hop robin
apply loadshare
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-16>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-16> ]
No next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-16>: Indicates that you can repeat the previous group of parameters to configure up to 16 next hops. You can configure up to 32 next hops for one policy node.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
If the next hop specified in the apply next-hop command becomes unreachable (for example, when the peer interface IP address is deleted), the device might still have the ARP entry associated with this next hop IP addresses. In this case, the associated PBR setting still takes effect, which redirects packets incorrectly. As a best practice to avoid this issue, configure Track to detect the next hop reachability. When the next hop becomes unreachable, the PBR setting will not take effect.
You cannot specify the next hops for forwarding packets as tunnel interface addresses.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface NULL 0
undo apply output-interface [ NULL 0 ]
No output interfaces are set.
Policy node view
NULL 0: Specifies interface Null 0 as the output interface.
You can specify only interface Null 0 as the output interface.
# Specify interface Null 0 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface NULL 0
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
Setting the precedence for IP packets also sets the last three bits of the DSCP value to 0.
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply statistics
Use apply statistics to enable successful matches counting on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Successful matches counting is disabled on a policy node.
Policy node view
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
This apply clause is always executed for the policy node.
# Enable match counting on policy node 11.
[Sysname-pbr-aa-11] apply statistics
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
policy-based-route
Use display ip policy-based-route global to display information about global PBR, including its configuration and statistics.
display ip policy-based-route global [ slot slot-number ]
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display information about global PBR.
<Sysname> display ip policy-based-route global
Global policy-based routing information:
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 2.2.2.2
node 5 permit:
if-match acl 3101
Total matches: 0, total bytes: 0
Global policy-based routing information |
Global PBR configuration and statistics. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy and then apply it again. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. |
if-match acl |
apply next-hop |
apply output-interface XXXX |
Specifies an output interface for permitted packets. This field displays the interface status in brackets. · down—The interface is down at the network layer. · inactive—The card that hosts the interface is not in position. |
Matches |
Number of successful matches on the node. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. |
bytes |
Number of matching bytes on the node. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on the node. |
Total matches |
Total number of successful matches on all nodes. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on all nodes. |
total bytes |
Total number of matching bytes on all nodes. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on all nodes. |
ip global policy-based-route
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for interface XXXX |
PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
apply next-hop |
apply output-interface |
Specifies an output interface and its associated track entry for permitted packets. This field displays the interface status in brackets. · up—The interface is up. · down—The interface is down at network layer. · inactive—The card that hosts the interface is not in position. |
Matches |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
Total matches |
total bytes |
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Table 5 Command output
Policy based routing information for local |
Local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node: permit or deny. |
if-match acl |
apply next-hop |
Matches |
Number of successful matches on the node. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. |
bytes |
Total matches |
total bytes |
ip local policy-based-route
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface2
aaa Local N/A
abc Global N/A
Table 6 Command output
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. This field displays N/A for local and global PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
if-match acl [ user-defined ] { acl-number | name acl-name }
undo if-match acl
No ACL match criterion is set.
Policy node view
user-defined: Specifies a user-defined ACL.
acl-number: Specifies an ACL by its number. The value ranges for this argument are as follows:
· 2000 to 2999 for a basic ACL.
· 3000 to 3999 for an advanced ACL.
· 5000 to 5999 for a user-defined ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic, user-defined, or advanced ACL.
If the specified ACL does not exist or has no rules configured, all packets will match the ACL.
If you specify the vpn-instance keyword for an ACL rule, the ACL does not take effect for the PBR policy. If you do not specify the vpn-instance keyword for the rule, the rule takes effect for both public network and private network packets.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
Use ip global policy-based-route to specify a PBR policy as the global PBR policy.
Use undo ip global policy-based-route to restore the default.
ip global policy-based-route policy-name
No policy is specified for global PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Global PBR guides the forwarding of packets on all interfaces of the device.
You can specify only one policy for global PBR on the device. Before you apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
# Specify PBR policy aaa for global PBR.
[Sysname] ip global policy-based-route aaa
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
Use ip policy-based-route-log enable to enable the PBR logging feature.
Use undo ip policy-based-route-log enable to disable the PBR logging feature.
The PBR logging feature is disabled.
The PBR logging feature helps the administrator locate and fix faults. The feature logs PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see System Management Configuration Guide.
Excessive PBR log messages degrade the performance of the device. To avoid this problem, disable the PBR logging feature.
# Enable the PBR logging feature.
[Sysname] ip policy-based-route-log enable
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 255.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
· If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
· If a match mode is specified, the command deletes all nodes configured with the match mode.
· If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
