11-Security Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10011-Security Command Reference
24-802.1X client commands
24-802.1X client commands 91.56 KB
display dot1x supplicant
Use display dot1x supplicant to display 802.1X client authentication information.
display dot1x supplicant [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays 802.1X client authentication information for all interfaces.
# Display 802.1X client authentication information on Ten-GigabitEthernet 3/0/1.
<Sysname> display dot1x supplicant interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1
  User name            : aaa
  EAP method           : PEAP-MSCHAPv2
  Dot1x supplicant     : Enabled
  Anonymous identifier : bbb
  SSL client policy    : policy_1
  FSM state            : Init
  EAPOL-Start packets  : 0
User name
802.1X client username.
EAP method
802.1X client EAP authentication method:
·     MD5.
·     PEAP-GTC.
·     PEAP-MSCHAPv2.
·     TTLS-GTC.
·     TTLS-MSCHAPv2.
Dot1x supplicant
Status of the 802.1X client feature:
·     Enabled.
·     Disabled.
802.1X client anonymous identifier.
SSL client policy
SSL client policy used by the 802.1X client feature.
FSM state
802.1X client authentication state:
·     Init—The authentication process starts.
·     Connecting—The 802.1X client is connecting to the authenticator.
·     Authenticating—The 802.1X client is being authenticated.
·     Authenticated—The 802.1X client has been authenticated.
·     Held—The 802.1X client is waiting for authentication.
EAPOL-Start packets
Number of sent EAPOL-Start packets.
dot1x supplicant anonymous identify
Use dot1x supplicant anonymous identify to configure an 802.1X client anonymous identifier.
Use undo dot1x supplicant anonymous identify to restore the default.
dot1x supplicant anonymous identify identifier
No 802.1X client anonymous identifier exists.
Ethernet interface view
identifier: Specifies an 802.1X client anonymous identifier, a case-sensitive string of 1 to 253 characters.
At phase 1, packets sent to the authenticator are not encrypted. The use of an 802.1X client anonymous identifier prevents the 802.1X client username from being disclosed at phase 1. The 802.1X client sends the anonymous identifier to the authenticator instead of the 802.1X client username. The 802.1X client username will be sent to the authenticator in encrypted packets at phase 2.
If no 802.1X client anonymous identifier is configured, the 802.1X client sends the 802.1X client username at phase 1.
The configured 802.1X client anonymous identifier takes effect only if one of the following EAP authentication methods is used:
·     PEAP-MSCHAPv2.
·     PEAP-GTC.
·     TTLS-MSCHAPv2.
·     TTLS-GTC.
If the MD5-Challenge EAP authentication is used, the configured 802.1X client anonymous identifier does not take effect. The 802.1X client uses the 802.1X client username at phase 1.
Do not configure the 802.1X client anonymous identifier if the vendor-specific authentication server cannot identify anonymous identifiers.
# Configure the 802.1X client anonymous identifier as bbb on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant anonymous identify bbb
dot1x supplicant enable
dot1x supplicant username
dot1x supplicant eap-method
Use dot1x supplicant eap-method to specify an 802.1X client EAP authentication method.
Use undo dot1x supplicant eap-method to restore the default.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
The MD5-Challenge authentication is used as the 802.1X client EAP authentication method.
md5: Specifies the MD5-challenge EAP authentication method.
peap-gtc: Specifies the PEAP-GTC EAP authentication method.
peap-mschapv2: Specifies the PEAP-MSCHAPv2 EAP authentication method
ttls-gtc: Specifies the TTLS-GTC EAP authentication method.
ttls-mschapv2: Specifies the TTLS-MSCHAPv2 EAP authentication method.
Make sure the specified 802.1X client EAP authentication method is supported by the authentication server.
# Specify PEAP-GTC as the 802.1X client EAP authentication method on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant eap-method peap-gtc
Use dot1x supplicant enable to enable the 802.1X client feature.
Use undo dot1x supplicant enable to disable the 802.1X client feature.
The 802.1X client feature is disabled.
Make sure you have configured 802.1X authentication on the authenticator before you use this command.
To ensure a successful authentication, do not enable the 802.1X client on an Ethernet interface in an aggregation group.
# Enable the 802.1X client feature on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant enable
dot1x supplicant mac-address
Use dot1x supplicant mac-address to configure an 802.1X client MAC address used for 802.1X client authentication.
Use undo dot1x supplicant mac-address to restore the default.
dot1x supplicant mac-address mac-address
The 802.1X client on an Ethernet interface uses the MAC address of the interface for 802.1X authentication. If the interface's MAC address is unavailable, the client uses the device's MAC address for 802.1X authentication.
mac-address: Specifies a MAC address in the format of H-H-H, excluding multicast, all-zero, and all-F MAC addresses. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
When the device has multiple Ethernet interfaces that act as 802.1X clients, each interface requires a unique MAC address to pass 802.1X client authentication.
You can use either of the following methods to configure a unique MAC address for each 802.1X client-enabled interface:
·     Execute the mac-address command in Ethernet interface view.
·     Execute the dot1x supplicant mac-address command.
# Configure the 802.1X client MAC address for 802.1X client authentication as 0001-0001-0001.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant mac-address 1-1-1
dot1x supplicant password
Use dot1x supplicant password to set an 802.1X client password.
Use undo dot1x supplicant password to restore the default.
dot1x supplicant password { cipher | simple } string
No 802.1X client password exists.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 127 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
# Set the 802.1X client password to 123456 in plaintext form on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant password simple 123456
dot1x supplicant ssl-client-policy
Use dot1x supplicant ssl-client-policy to specify an SSL client policy for an 802.1X client.
Use undo dot1x supplicant ssl-client-policy to restore the default.
dot1x supplicant ssl-client-policy policy-name
undo dot1x supplicant ssl-client-policy policy-name
The default SSL client policy is used.
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters. Make sure the specified SSL client policy already exists.
If the PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication is used, the 802.1X client authentication process is as follows:
·     Phase 1—The 802.1X client acts as an SSL client to negotiate with the SSL server.
The SSL client uses the SSL parameters specified in the specified SSL client policy to establish a connection to the SSL server for negotiation. The SSL parameters include a PKI domain, supported cipher suites, and the SSL version. For information about SSL client policies, see Security Configuration Guide.
·     Phase 2—The 802.1X client uses the negotiated result to encrypt and transmit the interchanged authentication packets.
If the MD5-Challenge authentication is used, the 802.1X client does not use an SSL client policy during the authentication process.
# Specify SSL client policy policy_1 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant ssl-client-policy policy_1
ssl client-policy
dot1x supplicant transmit-mode
Use dot1x supplicant transmit-mode to specify a mode used by 802.1X client authentication for sending EAP-Response and EAPOL-Logoff packets.
Use undo dot1x supplicant transmit-mode to restore the default.
dot1x supplicant transmit-mode { multicast | unicast }
802.1X client authentication uses unicast mode to send EAP-Response and EAPOL-Logoff packets.
multicast: Specifies multicast mode for sending EAP-Response and EAPOL-Logoff packets, of which the destination addresses are multicast MAC address 01-80-C2-00-00-03.
unicast: Specifies unicast mode for sending EAP-Response and EAPOL-Logoff packets.
When the device has 802.1X client-enabled interfaces, use the multicast mode to avoid 802.1X authentication failures if the NAS device does not support receiving unicast EAP-Response or EAPOL-Logoff packets.
# Configure 802.1X client authentication to use multicast mode for sending EAP-Response and EAPOL-Logoff packets on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant transmit-mode multicast
Use dot1x supplicant username to configure an 802.1X client username.
Use undo dot1x supplicant username to restore the default.
dot1x supplicant username username
No 802.1X client username exists.
username: Specifies the 802.1X client username, a case-sensitive string of 1 to 253 characters.
802.1X client usernames can include domain names. The supported domain name delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
If a username string includes multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For more information about the domain name delimiters, see the dot1x domain-delimiter command.
# Configure the 802.1X client username as aaa on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] dot1x supplicant username aaa
