- 11-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-Password control commands
- 08-Keychain commands
- 09-Public key management commands
- 10-PKI commands
- 11-IPsec commands
- 12-SSH commands
- 13-SSL commands
- 14-Object group commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-FIPS commands
- 23-MACsec commands
- 24-802.1X client commands
- 25-Microsegmentation commands
- 26-SAVA commands
- 27-Crypto engine commands
- 28-IP-SGT mapping commands
- 29-User profile commands
- 30-CloudSec commands
- 31-SAVI commands
08-Keychain commands | 105.00 KB |
Keychain commands
accept-lifetime utc
Use accept-lifetime utc to set the receiving lifetime for a key of a keychain in absolute time mode.
Use undo accept-lifetime to restore the default.
accept-lifetime utc start-time start-date { duration { duration-value | infinite } | to end-time end-date }
The receiving lifetime is not configured for a key of a keychain.
Key view
start-time: Specifies the start time in the HH:MM:SS format. The value range for this argument is 0:0:0 to 23:59:59.
start-date: Specifies the start date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035.
duration duration-value: Specifies the lifetime of the key, in the range of 1 to 2147483646 seconds.
duration infinite: Specifies that the key never expires after it becomes valid.
to: Specifies the end time and date.
end-time: Specifies the end time in the HH:MM:SS format. The value range for this argument is 0:0:0 to 23:59:59.
end-date: Specifies the end date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035.
A key becomes a valid accept key when the following requirements are met:
· A key string has been configured.
· An authentication algorithm has been specified.
· The system time is within the specified receiving lifetime.
If an application receives a packet that carries a key ID, and the key is valid, the application uses the key to authenticate the packet. If the key is not valid, packet authentication fails.
If the received packet does not carry a key ID, the application uses all valid keys in the keychain to authenticate the packet. If the packet does not pass any authentication, packet authentication fails.
An application can use multiple valid keys to authenticate packets received from a peer.
# Set the receiving lifetime for key 1 of keychain abc in absolute time mode.
[Sysname] keychain abc mode absolute
[Sysname-keychain-abc] key 1
[Sysname-keychain-abc-key-1] accept-lifetime utc 12:30 2015/1/21 to 18:30 2015/1/21
accept-tolerance
Use accept-tolerance to set a tolerance time for accept keys in a keychain.
Use undo accept-tolerance to restore the default.
accept-tolerance { value | infinite }
No tolerance time is configured for accept keys in a keychain.
Keychain view
value: Specifies a tolerance time in the range of 1 to 8640000 seconds.
infinite: Specifies that the accept keys never expires.
After a tolerance time is configured, the start time and the end time configured in the accept-lifetime utc command are extended for the period of the tolerance time.
If authentication information is changed, information mismatch occurs on the local and peer devices, and the service might be interrupted. Use this command to ensure continuous packet authentication.
# Set the tolerance time to 100 seconds for accept keys in keychain abc.
[Sysname-keychain-abc] accept-tolerance 100
# Configure the accept keys in keychain abc to never expire.
[Sysname-keychain-abc] accept-tolerance infinite
authentication-algorithm
Use authentication-algorithm to specify an authentication algorithm for a key.
Use undo authentication-algorithm to restore the default.
authentication-algorithm{ aes-128-cmac | aes-256-cmac | hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 | sm3 }
No authentication algorithm is specified for a key.
Key view
aes-128-cmac: Specifies the AES-128-CMAC authentication algorithm.
aes-256-cmac: Specifies the AES-128-CMAC authentication algorithm.
hmac-md5: Specifies the HMAC-MD5 authentication algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication algorithm.
hmac-sm3: Specifies the HMAC-SM3 authentication algorithm.
md5: Specifies the MD5 authentication algorithm.
sm3: Specifies the SM3 authentication algorithm.
Recommended configuration
CMAC, MD5, and SHA are international cryptographic algorithms. SM3 is a Chinese domestic cryptographic algorithm issued by the National Cryptography Administration. Table 1 shows the comparison results of various authentication algorithms of the same type. Choose the appropriate authentication algorithm as needed.
Table 1 Comparison results of various authentication algorithms of the same type
Authentication algorithm type |
Authentication algorithm comparison |
AES-128-CMAC, AES-256-CMAC |
The AES-256-CMAC authentication algorithm is more secure than the AES-128-CMAC authentication algorithm, but it has a relatively slower calculation speed. |
HMAC-MD5 |
The HMAC-MD5 authentication algorithm is more secure than the MD5 authentication algorithm, but it has a relatively slower calculation speed. |
MD5 |
SM3 |
The HMAC-SM3 authentication algorithm is more secure than the SM3 authentication algorithm, but it has a relatively slower calculation speed. |
HMAC-SM3 |
If an application does not support the authentication algorithm specified for a key, the application cannot use the key for packet authentication.
# Specify the MD5 authentication algorithm for key 1 of keychain abc in absolute time mode.
[Sysname-keychain-abc-key-1] authentication-algorithm md5
default-send-key
Use default-send-key to specify a key in a keychain as the default send key.
Use undo default-send-key to restore the default.
default-send-key
No key in a keychain is specified as the default send key.
Key view
When send keys in a keychain are inactive, the default send key can be used for packet authentication.
A keychain can have only one default send key. The default send key must be configured with an authentication algorithm and a key string.
# Specify key 1 in keychain abc as the default send key.
[Sysname-keychain-abc-key-1] default-send-key
display keychain
Use display keychain to display keychain information.
display keychain [ name keychain-name [ key key-id ] ]
name keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a keychain, this command displays information about all keychains.
key key-id: Specifies a key by its ID in the range of 0 to 281474976710655. If you do not specify a key, this command displays information about all keys in a keychain.
# Display information about all keychains.
<Sysname> display keychain
Keychain name : abc
Mode : absolute
Accept tolerance : 0
TCP kind value : 254
TCP algorithm value
HMAC-MD5 : 5
HMAC-SHA-256 : 7
MD5 : 3
HMAC-SM3 : 52
SM3 : 51
Default send key ID : 2 (Inactive)
Active send key ID : 1
Active accept key IDs: 1 2
Key ID : 1
Key string : $c$3$vuJpEX3Lah7xcSR2uqmrTK2IZQJZguJh3g==
Algorithm : md5
Send lifetime : 01:00:00 2015/01/22 to 01:00:00 2015/01/25
Send status : Active
Accept lifetime : 01:00:00 2015/01/22 to 01:00:00 2015/01/27
Accept status : Active
Key ID : 2
Algorithm : md5
Send lifetime : 01:00:01 2015/01/25 to 01:00:00 2015/01/27
Send status : Inactive
Mode |
Time mode for the keychain. |
Accept tolerance |
Tolerance time (in seconds) for accept keys of the keychain. |
TCP kind value |
Value for the TCP kind field. |
TCP algorithm value |
ID of the TCP authentication algorithm. |
Default send key ID |
ID of the default send key. The status for the key is displayed in parentheses. |
Key string |
Key string in encrypted form. |
Algorithm |
Authentication algorithm for the key: · hmac-md5 · hmac-sha-256 · hmac-sm3 · sm3 · md5 · aes-128-cmac · aes-256-cmac |
Send lifetime |
Sending lifetime for the key. |
Send status |
Status of the send key: Active or Inactive. |
Accept lifetime |
Receiving lifetime for the key. |
Accept status |
Status of the accept key: Active or Inactive. |
key
Use key to create a key for a keychain and enter its view, or enter the view of an existing key.
Use undo key to delete a key and all its configurations for a keychain.
key key-id
undo key key-id
No keys exist.
Keychain view
key-id: Specifies a key ID in the range of 0 to 281474976710655.
The keys in a keychain must have different key IDs.
# Create key 1 and enter its view.
keychain
Use keychain to create a keychain and enter its view, or enter the view of an existing keychain.
Use undo keychain to delete a keychain and all its configurations.
keychain keychain-name [ mode absolute ]
undo keychain keychain-name
No keychains exist.
keychain-name: Specifies a keychain name, a case-sensitive string of 1 to 63 characters.
mode: Specifies a time mode.
absolute: Specifies the absolute time mode. In this mode, each time point during a key's lifetime is the UTC time and is not affected by the system's time zone or daylight saving time.
You must specify the time mode when you create a keychain. You cannot change the time mode for an existing keychain.
The time mode is not required when you enter the view of an existing keychain.
# Create keychain abc, specify the absolute time mode for it, and enter keychain view.
key-string
Use key-string to configure a key string for a key.
Use undo key-string to restore the default.
key-string { cipher | plain } string
undo key-string
No key string is configured for a key.
Key view
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 255 characters. Its encrypted form is a case-sensitive string of 33 o 373 characters.
If the length of a plaintext key exceeds the length limit supported by an application, the application uses the supported length of the key to authenticate packets.
# Set the key string to 123456 in plaintext form for key 1.
[Sysname-keychain-abc-key-1] key-string plain 123456
send-lifetime utc
Use send-lifetime utc to set the sending lifetime for a key of a keychain in absolute time mode.
Use undo send-lifetime to restore the default.
send-lifetime utc start-time start-date { duration { duration-value | infinite } | to end-time end-date }
undo send-lifetime
The sending lifetime is not configured for a key of a keychain.
Key view
A key becomes a valid send key when the following requirements are met:
· The system time is within the specified sending lifetime.
To make sure only one key in a keychain is used at a time to authenticate packets to a peer, set non-overlapping sending lifetimes for the keys in the keychain.
# Set the sending lifetime for key 1 of keychain abc in absolute time mode.
[Sysname-keychain-abc-key-1] send-lifetime utc 12:30 2015/1/21 to 18:30 2015/1/21
tcp-algorithm-id
Use tcp-algorithm-id to set an algorithm ID for a TCP authentication algorithm.
Use undo tcp-algorithm-id to restore the default.
tcp-algorithm-id { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 | sm3 } algorithm-id
undo tcp-algorithm-id { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 | sm3 }
The algorithm ID is 3 for the MD5 authentication algorithm, 51 for the SM3 authentication algorithm, 52 for the HMAC-SM3 authentication algorithm, 7 for the HMAC-SHA-256 authentication algorithm, and 5 for the HMAC-MD5 authentication algorithm.
Keychain view
hmac-md5: Specifies the HMAC-MD5 authentication algorithm, which provides a key length of 16 bytes.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication algorithm, which provides a key length of 16 bytes.
hmac-sm3: Specifies the HMAC-SM3 authentication algorithm, which provides a key length of 32 bytes.
md5: Specifies the MD5 authentication algorithm, which provides a key length of 16 bytes.
sm3: Specifies the SM3 authentication algorithm, which provides a key length of 32 bytes.
algorithm-id: Specifies an algorithm ID in the range of 1 to 63.
If an application uses keychain authentication during TCP connection establishment, the incoming and outgoing TCP packets will carry the TCP Enhanced Authentication Option. The algorithm-id field in the option represents the authentication algorithm ID. The algorithm IDs are not assigned by IANA. They are vendor-specific.
To communicate with a peer device from another vendor, the local device must have the same algorithm ID as the peer device. For example, if the algorithm ID is 3 for the HMAC-MD5 algorithm on the peer device, you must execute the tcp-algorithm-id hmac-md5 3 command on the local device.
# Create keychain abc and set the algorithm ID to 1 for the HMAC-MD5 authentication algorithm.
[Sysname-keychain-abc] tcp-algorithm-id hmac-md5 1
tcp-kind
Use tcp-kind to set the kind value in the TCP Enhanced Authentication Option.
Use undo tcp-kind to restore the default.
tcp-kind kind-value
undo tcp-kind
The kind value is 254 in the TCP Enhanced Authentication Option.
Keychain view
kind-value: Specifies the kind value in the range of 28 to 255. The default is 254.
If an application uses keychain authentication during TCP connection establishment, the incoming and outgoing TCP packets will carry the TCP Enhanced Authentication Option. For a successful packet authentication, the local device and the peer device must have the same kind value setting in the TCP Enhanced Authentication Option.
# Set the kind value to 252 for keys in keychain abc in absolute time mode.
[Sysname-keychain-abc] tcp-kind 252
