- 11-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-Password control commands
- 08-Keychain commands
- 09-Public key management commands
- 10-PKI commands
- 11-IPsec commands
- 12-SSH commands
- 13-SSL commands
- 14-Object group commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-FIPS commands
- 23-MACsec commands
- 24-802.1X client commands
- 25-Microsegmentation commands
- 26-SAVA commands
- 27-Crypto engine commands
- 28-IP-SGT mapping commands
- 29-User profile commands
- 30-CloudSec commands
- 31-SAVI commands
23-MACsec commands | 233.68 KB |
macsec cipher-suite (interface view)
macsec cipher-suite (system view)
macsec maintenance-mode enable
macsec replay-protection enable
MACsec commands
confidentiality-offset
Use confidentiality-offset to set the MACsec confidentiality offset in an MKA policy.
Use undo confidentiality-offset to restore the default.
confidentiality-offset offset-value
The MACsec confidentiality offset is 0. The entire frame is encrypted.
MKA policy view
offset-value: Specifies the confidentiality offset in bytes. The value can be 0, 30 or 50.
Application scenarios
To meet the requirements of some applications for identifying IPv4 or IPv6 packet headers, you can set the MACsec confidentiality offset, which specifies the number of bytes starting from the frame header. MACsec encrypts only the bytes after the offset in a frame.
Operating mechanism
When an MKA policy is applied to a port, the MACsec confidentiality offset in the policy overwrites the confidentiality offset previously configured on the port. However, MACsec uses the confidentiality offset propagated by the key server.
The configured MACsec confidentiality offset does not take effect when the GCM-AES-XPN-128 or GCM-AES-XPN-256 cipher suite is used. The confidentiality offset is fixed at 0 for these two suites.
# Set the MACsec confidentiality offset to 30 bytes in MKA policy abcd.
[Sysname] mka policy abcd
[Sysname-mka-policy-abcd] confidentiality-offset 30
macsec confidentiality-offset
mka apply policy
display macsec
Use display macsec to display MACsec information on ports.
display macsec [ interface interface-type interface-number ] [ verbose ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays MACsec information on all ports.
verbose: Displays detailed MACsec information. If you do not specify this keyword, the command displays brief MACsec information.
# Display brief MACsec information on Ten-GigabitEthernet 3/0/1.
<Sysname> display macsec interface ten-gigabitethernet 3/0/1
Interface Ten-GigabitEthernet3/0/1
Protect frames : Yes
Active MKA policy : PL01
Replay protection : Enabled
Config reply window size : 0 frames
Active replay window size : 0 frames
Config confidentiality offset : 0 bytes
Active confidentinlity offset : 0 bytes
Config validation mode : Check
Active validation mode : Strict
# Display detailed MACsec information on Ten-GigabitEthernet 3/0/1.
<Sysname> display macsec interface ten-gigabitethernet 3/0/1 verbose
Config replay window size : 0 frames
Active confidentiality offset : 0 bytes
Included SCI : No
SCI conflict : No
Cipher suite : GCM-AES-128
MKA life time : 6 seconds
Transmit secure channel:
SCI : 000C29F6A4380004
Elapsed time: 00h:02m:19s
Current SA : AN 0 PN 1
Receive secure channels:
SCI : 000C29258D430124
Elapsed time: 00h:02m:17s
Current SA : AN 0 LPN 1
Previous SA : AN N/A LPN N/A
Protect frames |
Status of MACsec desire on the port: · Yes. · No. If the port does not have an MKA principal actor, this field displays N/A. |
Active MKA policy |
MKA policy applied to the port. This field displays N/A if the port is not enabled with MACsec desire. This field is not available if the port is enabled with MACsec desire but is not applied an MKA policy. |
Replay protection |
Status of replay protection on the port: · Enabled. · Disabled. If the port is not enabled with MACsec desire, this field displays N/A. |
Config replay window size |
Configured replay protection window size in number of frames. This field displays N/A in the following situations: · The port is not enabled with MACsec desire. · The port is not enabled with replay protection. |
Active replay window size |
Effective replay protection window size in number of frames. This field displays N/A in the following situations: · The port is not enabled with MACsec desire. · The port is not enabled with replay protection. |
Config confidentiality offset |
Configured confidentiality offset in bytes. If the port is not enabled with MACsec desire, this field displays N/A. |
Active confidentiality offset |
Effective confidentiality offset, in bytes. If the port is not enabled with MACsec desire, this field displays N/A. |
Config validation mode |
Configured validation mode: · Check. · Disabled. · Strict. If the port is not enabled with MACsec desire, this field displays N/A. |
Active validation mode |
Effective validation mode: · Check. · Disabled. · Strict. If the port is not enabled with MACsec desire, this field displays N/A. |
Included SCI |
Whether the frame includes SCI tag: · Yes. · No. If the port is not enabled with MACsec desire, this field displays N/A. |
SCI conflict |
Whether the SCI in the received MKA packets is the same as the local SCI: · Yes—The SCI in the received MKA packets is the same as the local SCI. · No—No MKA packet is received, or the SCI in the received MKA packets is different from the local SCI. |
Cipher suite |
Cipher suite for MACsec encryption: · GCM-AES-128. · GCM-AES-256. · GCM-AES-XPN-128. · GCM-AES-XPN-256. If the port is not enabled with MACsec desire, this field displays N/A. |
MKA life time |
MKA session keepalive timer. |
Transmit secure channel |
Information about the secure channel for outbound traffic. This field is not available if the port is not enabled with MACsec desire. |
Receive secure channel |
Information about the secure channel for inbound traffic. This field is not available if the port is not enabled with MACsec desire. |
Elapsed time |
Lifetime of the secure channel. |
SCI |
A hexadecimal string that contains the MAC address and port ID. |
Current SA |
Current SA used by the secure channel. If no current SA is available, each of the AN, PN, and LPN fields for the current SA displays N/A. |
Previous SA |
Previous SA used by the secure channel. If no previous SA is available, each of the AN and LPN fields for the previous SA displays N/A. |
PN |
Packet number for outbound traffic. |
AN |
SA number. |
LPN |
The minimum received packet number allowed by SAK. |
mka apply policy
display mka policy
Use display mka policy to display MKA policy information.
display mka { default-policy | policy [ name policy-name ] }
default-policy: Specifies the system-defined MKA policy.
policy: Specifies an MKA policy or all MKA policies.
name policy-name: Specifies an MKA policy by policy name. The policy-name argument represents the MKA policy name, a case-sensitive string of 1 to 16 characters. If you do not specify an MKA policy, this command displays information about all MKA policies.
# Display information about all MKA policies.
<Sysname> display mka policy
PolicyName ReplayProtection WindowSize ConfOffset Validation
default-policy Yes 0 0 Check
policy1 Yes 0 30 Check
policy2 Yes 0 30 Check
policy3 No 0 0 Strict
policy4 Yes 200 50 Check
policy5 Yes 0 0 Check
PolicyName |
Name of the MKA policy. |
ReplayProtection |
Whether the replay protection feature is enabled. |
WindowSize |
Replay protection window size in number of frames. |
ConfOffset |
Confidentiality offset in bytes. |
Validation |
Validation mode: · Check. · Disabled. · Strict. |
mka policy
mka apply policy
display mka session
Use display mka session to display MKA session information.
display mka session [ interface interface-type interface-number | local-sci sci-id ] [ verbose ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays MKA session information on all ports.
local-sci sci-id: Specifies a local SCI, a case-insensitive hexadecimal string of 16 characters.
verbose: Displays detailed MKA session information. If you do not specify this keyword, the command displays brief MKA session information.
# Display brief MKA session information on Ten-GigabitEthernet 3/0/1.
<Sysname> display mka session interface ten-gigabitethernet 3/0/1
Tx-SCI : 000C29F6A4380004
Priority : 0
Capability: 3
CKN for participant: ABCD
Key server : Yes
MI (MN) : D7B00EDA353242704CC6B0DB (7)
Live peers : 1
Potential peers : 0
Principal actor : Yes
MKA session status : Secured
Confidentiality offset: 30 bytes
# Display detailed MKA session information on Ten-GigabitEthernet 3/0/1.
<Sysname> display mka session interface ten-gigabitethernet 3/0/1 verbose
Priority : 0
Capability: 3
Key server : Yes
Live peers : 1
Potential peers : 1
Tx-SSCI : 2
Current SAK status : Rx & Tx
Current SAK AN : 0
Current SAK KI (KN) : 4273791304C1C26259C94C3400000001 (1)
Previous SAK status : N/A
Previous SAK AN : N/A
Previous SAK KI (KN) : N/A
Live peer list:
MI MN Prio Cap Rx-SCI Rx-SSCI
EA58DC3F8715953DBC6593F0 840 100 3 00E0020000000106 1
Potential peer list:
DA58DC3Q4573543DBC6699F0 3 200 3 00E0021200000107 N/A
Tx-SCI |
SCI for outbound traffic, in hexadecimal notation. |
Tx- SSCI |
SSCI for outbound traffic when an XPN cipher suite is used. If no XPN cipher suite is used, this field displays N/A. |
Priority/Prio |
Key server priority, in the range of 0 to 255. |
Capability/Cap |
MACsec capability: · 0—The port is MACsec incapable. · 1—The port supports integrity check only. · 2—The port supports integrity check and packet encryption. The confidentiality offset must be 0. · 3—The port supports integrity check and packet encryption. The confidentiality offset can be 0, 30, or 50. |
CKN for participant |
CAK name of the MKA instance. |
Key server |
Whether the local end is the key server. |
MI |
Member identifier in hexadecimal notation. |
MN |
Message number. |
Live peers |
Numbers of peers that have already been learned. |
Potential peers |
Numbers of peers that are being negotiated. |
Principal actor |
Whether the MKA instance is the principal actor. MKA instance refers to the operation entity of the MKA protocol on a port. A port might have multiple MKA instances. The principal actor is the MKA instance in active state. |
MKA session status |
MKA session status: · Unknown. · Pending. · Unauthenticated—The port has not been authenticated. · Authenticated—The port has passed the 802.1X authentication. · Secured—The session will be secured. If the MKA instance is not the principal actor, this field displays N/A. |
Confidentiality offset |
Confidentiality offset issued by the key server. This field displays N/A in the following situations: · The packet is transmitted in plain text. · The MKA instance is not the principal actor. |
Current SAK status |
Status of the current SAK: · Tx—The SAK is used to send packets. · Rx—The SAK is used to receive packets. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Current SAK AN |
SA number of the current SAK in use. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Current SAK KI |
Key identifier of the current SAK in use, a string of hexadecimal digits that contains the key server's 12-byte MI and KN. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
KN |
SAK number. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Previous SAK status |
Status of the previous SAK: · Tx—The SAK is used to send packets. · Rx—The SAK is used to receive packets. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Previous SAK AN |
SA number of the previous SAK. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Previous SAK KI |
Key identifier of the previous SAK, a string of hexadecimal digits that contains the key server's 12-byte MI and KN. This field displays N/A in the following situations: · The MKA instance is not the principal actor. · The SAK does not exist. |
Live peer list |
List of peers that have participated in the MKA session. This field is not available if no live peer exists. |
Potential peer list |
List of peers that are being negotiated. This field is not available if no potential peer exists. |
Rx-SCI |
SCI for inbound traffic, in hexadecimal notation. |
Rx-SSCI |
SSCI for inbound traffic when an XPN cipher suite is used. If no XPN cipher suite is used, this field displays N/A. |
reset mka session
display mka statistics
Use display mka statistics to display MKA statistics on ports.
display mka statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays MKA statistics on all ports.
# Display MKA statistics on Ten-GigabitEthernet 3/0/1.
<Sysname> display mka statistics interface ten-gigabitethernet 3/0/1
Interface Ten-GigabitEthernet3/0/1 statistics
MKPDUs with invalid CKN : 0
MKPDUs with invalid ICV : 0
MKPDUs with Rx error : 0
CKN for participant : ABCD
Tx MKPDUs : 2379
Rx MKPDUs : 2375
MKPDUs with invalid MN: 0
MKPDUs with Tx error : 0
SAKs distributed : 0
SAKs received : 5
MKPDUs with invalid CKN |
Number of received MKA packets with invalid CKNs. |
MKPDUs with invalid ICV |
Number of MKA packets that failed ICV check. |
MKPDUs with Rx error |
Number of received error MKA packets. |
Tx MKPDUs |
Number of the MKA packets sent by the MKA instance. |
Rx MKPDUs |
Number of the MKA packets received by the MKA instance. |
MKPDUs with invalid MN |
Number of MKA packets with illegal MNs received by the MKA instance. |
MKPDUs with Tx error |
Number of error MKA packets sent by the MKA instance. |
SAKs distributed |
Number of SAKs distributed by the MKA instance. |
SAKs received |
Number of SAKs received by the MKA instance. |
reset mka statistics
Use macsec cipher-suite to specify the cipher suite for MACsec encryption.
Use undo macsec cipher-suite to restore the default.
macsec cipher-suite { gcm-aes-128 | gcm-aes-256 [ standard ] | gcm-aes-xpn-128 | gcm-aes-xpn-256 [ standard ] }
MACsec uses the GCM-AES-128 cipher suite for encryption.
Ethernet interface view
gcm-aes-128: Specifies the GCM-AES-128 cipher suite.
gcm-aes-256: Specifies the GCM-AES-256 cipher suite.
gcm-aes-xpn-128: Specifies the GCM-AES-XPN-128 cipher suite.
gcm-aes-xpn-256: Specifies the GCM-AES-XPN-256 cipher suite.
standard: Specifies the standard cipher suite.
If data packets sent by a port are encrypted through MACsec, you can specify the cipher suite for MACsec encryption.
H3C's implementations of GCM-AES-256 and GCM-AES-XPN-256 cipher suites differ from their standard open source counterparts. To successfully establish MKA sessions with a peer that uses the standard open source GCM-AES-256 or GCM-AES-XPN-256 cipher suite, you must specify the standard cipher suite for MACsec encryption.
Do not use this command on an 802.1X-enabled port.
This command is supported only in device-oriented mode. Make sure the connected ports are configured with the same cipher suite. If the ports are configured with different cipher suites, they cannot successfully establish MKA sessions.
# Specify the GCM-AES-256 cipher suite for MACsec encryption on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] macsec cipher-suite gcm-aes-256
dot1x
mka psk
In standalone mode:
macsec cipher-suite { gcm-sm4-128 | gcm-sm4-xpn-128 } { slot slot-number }
undo macsec cipher-suite { gcm-sm4-128 | gcm-sm4-xpn-128 } { slot slot-number }
In IRF mode:
macsec cipher-suite { gcm-sm4-128 | gcm-sm4-xpn-128 } { chassis chassis-number slot slot-number }
undo macsec cipher-suite { gcm-sm4-128 | gcm-sm4-xpn-128 } { chassis chassis-number slot slot-number }
MACsec uses the cipher suite configured in interface view for encryption.
gcm-sm4-128: Specifies the GCM-SM4-128 cipher suite.
gcm-sm4-xpn-128: Specifies the GCM-SM4-XPN-128 cipher suite.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
SM algorithms, cryptographic algorithm standards independently developed by China, aim to construct a secure industry network environment and enhance security and controllability of national industry information systems. As a best practice to ensure national information security, use SM algorithm cipher suites in fields that involve sensitive data, such as finance, e-government, and security.
Operating mechanism
After you specify a SM algorithm cipher suite for MACsec encryption in system view, the cipher suites that take effect on interfaces are as follows:
· If the card does not support SM algorithms, the cipher suites configured on the interfaces take effect.
· If the card supports SM algorithms, the specified SM algorithm cipher suite takes effect on the interfaces.
Traditionally, the priorities of the following algorithm configurations on an interface are in descending order: non-default configuration of the interface, global non-default configuration, and default configuration of the interface. For the global SM algorithm configuration to take precedence over the non-default algorithm configuration of the interface, the algorithm configuration of the interface is restored to the default after the global SM algorithm configuration is deployed.
SM algorithm cipher suites take effect only on cards that support SM algorithms.
You can execute this command only when 802.1X authentication is disabled on interfaces.
This command is supported only in device-oriented mode. For an MKA session to be successfully established between devices at both ends, make sure they are configured with the same cipher suite for MACsec encryption.
# Specify the GCM-SM4-128 cipher suite for MACsec encryption in system view.
[Sysname] macsec cipher-suite gcm-sm4-128 slot 1
Use macsec confidentiality-offset to set the MACsec confidentiality offset on a port.
Use undo macsec confidentiality-offset to restore the default.
macsec confidentiality-offset offset-value
The MACsec confidentiality offset on the port is 0. The entire frame is encrypted.
Operating mechanism
If you execute this command on a port to which an MKA policy has been applied, the configuration overwrites the confidentiality offset in the MKA policy. The MKA policy application is removed from the port. However, other settings (settings for parameters except the confidentiality offset) of the MKA policy are effective on the port.
MACsec uses the MACsec confidentiality offset propagated by the key server.
# Set the MACsec confidentiality offset to 30 bytes on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec confidentiality-offset 30
display macsec
display mka session
mka apply policy
macsec desire
Use macsec desire to enable MACsec desire. The port expects MACsec protection for outbound frames.
Use undo macsec desire to disable MACsec desire.
macsec desire
undo macsec desire
MACsec desire is disabled. A port does not expect MACsec protection for outbound frames.
This command allows a MACsec port to expect MACsec protection for outbound frames. The key server determines whether MACsec protects the outbound frames.
MACsec protects the outbound frames of the port when the following requirements are met:
· The key server is MACsec capable.
· Both the local participant and its peer are MACsec capable.
· A minimum of one participant is enabled with the MACsec desire feature.
# Enable MACsec desire on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec desire
macsec include-sci
Use macsec include-sci to have an interface send encrypted MACsec frames with the secure channel identifier (SCI) included in the SecTAG field.
Use undo macsec include-sci to have an interface send encrypted MACsec frames without including the secure channel identifier (SCI) in the SecTAG field.
macsec include-sci
A MACsec port sends MACsec frames with the SCI included in the SecTAG field.
The secure channel identifier (SCI) identifies the source of a MACsec frame. It contains the MAC address and ID of the port that sends the frame.
To forward traffic between a pair of peer MACsec interfaces, you must make sure inclusion of the SCI in the SecTAG field is enabled or disabled on both of them.
# Configure Ten-GigabitEthernet 3/0/1 to not include the SCI in the SecTAG field of encrypted MACsec frames.
[Sysname-Ten-GigabitEthernet3/0/1] undo macsec include-sci
Use macsec maintenance-mode enable to enable MACsec maintenance mode on an interface.
Use undo macsec maintenance-mode enable to disable MACsec maintenance mode on an interface.
MACsec maintenance mode is disabled.
On a network that uses a controller to deploy configuration, two devices are serially connected to the controller. The ports connecting the devices are blocked if they have been enabled with MACsec before an MKA session is established. This causes a configuration deployment failure if the configuration deployed to a device must traverse a MACsec port.
To make sure a device can always receive its configuration from a controller over the link between a pair of MACsec ports, enable MACsec maintenance mode on the MACsec ports.
In maintenance mode, a MACsec port is always unblocked regardless of whether it has established an MKA session with its peer port.
Operating mechanism
To protect data security, a MACsec port is blocked by default until it establishes an MKA session with its peer port. In blocked state, the MACsec port can send and receive MKA protocol packets, but it cannot send or receive data packets. To place a MACsec port in unblocked state regardless of whether it has established an MKA session with its peer port, enable MACsec maintenance mode on it.
Before you enable or disable MACsec maintenance mode on a MACsec port, you must disable MKA on that port.
Transient link state flapping might occur after you enable MACsec maintenance mode. To prevent a link down event from causing MKA packet exchange failure during this period, use the link-delay down command to increase the delay to report a link down event to CPU before you enable MACsec maintenance mode.
For security purposes, a MACsec port in MACsec maintenance mode will still be blocked when it receives frames that contain its own SCI (identified by its MAC address and port ID).
A MACsec port in MACsec maintenance mode issues its SCI information only after it receives MKA protocol packets from its peer port.
# Enable MACsec maintenance mode on interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec maintenance-mode enable
mka enable
macsec mka-session log enable
Use macsec mka-session log enable to enable MKA session logging.
Use undo macsec mka-session log enable to disable MKA session logging.
MKA session logging is disabled.
This command enables the device to generate logs for MKA session changes, such as peer aging and SAK updates. The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
As a best practice, disable MKA session logging to prevent excessive log output.
# Enable MKA session logging.
[Sysname] macsec mka-session log enable
info-center source (Network Management and Monitoring Command Reference)
Use macsec replay-protection enable to enable MACsec replay protection on a port.
Use undo macsec replay-protection enable to disable MACsec replay protection on a port.
MACsec replay protection is enabled on the port.
To prevent malicious users from launching network attacks by repeatedly sending captured data packets, the receiver discards duplicate or out-of-order data packets by default. However, in certain networks (for example, in a network where data frames are forwarded through a carrier's network), data frames are reordered during the forwarding process due to different transmission priorities. To prevent legitimate out-of-order packets from being dropped by the receiver, you can enable MACsec replay protection.
Operating mechanism
MACsec replay protection allows the device to accept the out-of-order inbound packets within the replay protection window size and drop other out-of-order packets. This mechanism improves network performance and efficiency, makes sure the receiver can correctly receive out-of-order data packets, and reduces possible data error or delay caused by out-of-order packets.
If you execute this command on a port to which an MKA policy has been applied, the configuration overwrites the MACsec replay protection configuration in the MKA policy. The MKA policy application is removed from the port. However, other settings (settings for parameters except MACsec replay protection) of the MKA policy are effective on the port.
# Enable MACsec replay protection on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec replay-protection enable
display macsec
macsec replay-protection window-size
mka apply policy
Use macsec replay-protection window-size to set the MACsec replay protection window size on a port.
Use undo macsec replay-protection window-size to restore the default.
macsec replay-protection window-size size-value
The MACsec replay protection window size is 0 on a port. The device accepts only frames that arrive in the correct order. Out-of-order or duplicated frames will be dropped.
size-value: Specifies the replay protection window size, in number of frames. If the GCM-AES-128 or GCM-AES-256 cipher suite is used, the value range for the replay protection window size is 0 to 4294967295. If the GCM-AES-XPN-128 or GCM-AES-XPN-256 cipher suite is used, the value range for the replay protection window size is 0 to 1073741823.
Operating mechanism
MACsec replay protection allows the device to accept the out-of-order inbound packets within the replay protection window size and drop other out-of-order packets. This improves network performance and efficiency, makes sure the receiver can correctly receive out-of-order data packets, and reduces possible data error or delay caused by out-of-order packets.
Suppose the replay protection window size is a on a port. After the port receives a packet with packet number (PN) x, it can accept only packets whose PN is greater than or equal to x-a.
The replay protection window size takes effect only when the replay protection feature is enabled on the port.
Set a replay protection window size based on the forwarding path of frames. If the frames might be forwarded multiple times, set a large replay protection window size.
If you execute this command on a port to which an MKA policy has been applied, the configuration overwrites the replay protection window size in the MKA policy. The MKA policy application is removed from the port. However, other settings (settings for parameters except the replay protection window size) of the MKA policy are effective on the port.
# Set the MACsec replay protection window size to 100 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec replay-protection window-size 100
display macsec
mka apply policy
macsec validation mode
Use macsec validation mode to set a MACsec validation mode on a port.
Use undo macsec validation mode to restore the default.
macsec validation mode { check | disabled | strict }
The MACsec validation mode is check on a port.
check: Performs validation only and does not drop illegal frames.
disabled: Does not perform validation.
SF interface modules do not support the disabled keyword.
strict: Performs validation and drops illegal frames.
When you configure a port to perform integrity check on received MACsec-encrypted data packets, you can set a MACsec validation mode on the port as required.
To avoid data loss, use the default validation mode check on the MACsec devices in case of MKA negotiation failure. After you use the display macsec command to verify that MKA negotiation has succeeded, change the validation mode to strict.
If you execute this command on a port to which an MKA policy has been applied, the configuration overwrites the validation mode in the MKA policy. The MKA policy application is removed from the port. However, other settings (settings for parameters except the validation mode) of the MKA policy are effective on the port.
When you configure a MACsec validation mode not supported by the switch or card on an interface, the system will generate a log indicating that the mode is not supported.
If the MACsec validation mode configured on an interface is not supported by the switch or card, the system will generate a log indicating that the mode is not supported after you execute the mka enable command on that interface.
# Set the MACsec validation mode to strict on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] macsec validation mode strict
display macsec
mka apply policy
validation mode
mka apply policy
Use mka apply policy to apply an MKA policy to a port.
Use undo mka apply policy to remove the MKA policy from a port.
mka apply policy policy-name
No MKA policy is applied to the port.
policy-name: Specifies the name of an MKA policy, a case-sensitive string of 1 to 16 characters.
To configure the same MACsec parameters on multiple ports on the device, you can configure an MKA policy, configure the parameters in the view of the MKA policy, and then apply it to the ports. This simplifies configuration and eliminates the need for manual configuration on each port.
Operating mechanism
An MKA policy defines MACsec parameters, including confidentiality offset, validation mode, replay protection, and replay protection window size.
When you apply an MKA policy to a port, the MACsec parameter settings in the policy overwrite the MACsec parameters previously configured on the port. Any modifications to the MKA policy take effect immediately.
When you remove the MKA policy from a port, the MACsec parameter settings on the port restore to the default.
The MKA policy applied to a port is automatically removed from that port when you delete the policy. No MKA policy will run on that port until after you apply one to it.
When you apply a nonexistent MKA policy to a port, the port automatically uses the system-defined MKA policy default-policy. After you create the specified policy, the policy will be automatically applied to the port.
# Apply MKA policy abcd to Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mka apply policy abcd
display mka policy
validation mode
mka enable
Use mka enable to enable MKA on a port.
Use undo mka enable to disable MKA on a port.
mka enable
undo mka enable
MKA is disabled on a port.
The enabling of MKA on a port triggers MKA negotiation. After MKA negotiation succeeds, an MKA session is successfully established.
MKA establishes and manages MACsec secure channels on a port. It also negotiates encryption keys used by MACsec.
# Enable MKA on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mka enable
display mka session
mka policy
Use mka policy to create an MKA policy and enter its view, or enter the view of an existing MKA policy.
Use undo mka policy to delete an MKA policy.
mka policy policy-name
undo mka policy policy-name
A system-defined MKA policy exists. The policy name is default-policy.
MKA policy provides a centralized method for configuring MACsec confidentiality offset, validation mode, replay protection, and replay protection window size.
The system supports multiple MKA policies.
You cannot delete or modify the system-defined MKA policy default-policy.
# Create an MKA policy named abcd and enter its view.
display mka policy
mka apply policy
validation mode
mka priority
Use mka priority to set the MKA key server priority.
Use undo mka priority to restore the default.
mka priority priority-value
undo mka priority
The MKA key server priority is 0.
priority-value: Specifies the priority value, in the range of 0 to 255. The priority is inversely related to its value.
When MACsec encrypts and decrypts data packets, the ports on the local and remote devices must use the same key to establish an MKA session. The key is generated and distributed by a key server. Use this command to set the MKA key server priority on the ports. A smaller value indicates a higher priority. The port with a higher priority becomes the key server.
Operating mechanism
If you use 802.1 X-generated CAK, the access device port automatically becomes the key server.
The port that has higher priority (lower priority value) becomes the key server if you use a preshared key as the CAK. If the port and its peers have the same priority, MACsec compares the SCI values on the ports. The port with the lowest SCI value becomes the key server.
A port with priority 255 cannot become the key server. For a successful key server selection, make sure a minimum of one participant's key server priority is not 255.
# Set the MKA key server priority to 2 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mka priority 2
display mka session
mka psk
Use mka psk to set a preshared key as the CAK.
Use undo mka psk to restore the default.
mka psk ckn name cak { cipher | simple } string
undo mka psk
No preshared key exists.
ckn name: Specifies the preshared key name, a hexadecimal string with an even number of case-insensitive characters. The name length is in the range of 2 to 64 characters.
cak: Specifies the preshared key.
cipher: Specifies the preshared key in encrypted form.
simple: Specifies the preshared key in plaintext form. For security purposes, the preshared key specified in plaintext form will be stored in encrypted form.
string: Specifies the preshared key. The plaintext form of the key is a hexadecimal string with an even number of case-insensitive characters, and the key length is in the range of 2 to 64 characters. The encrypted form of the key is a case-sensitive string of 2 to 117 characters.
The key used by the CA participants is called a connectivity association key (CAK). The CAK is not directly used for data packet encryption. MACsec uses the SAK generated from the CAK and other parameters to encrypt data packets.
The CAK has the following sources:
· Generated during 802.1X.
· Manually configured at the CLI.
The manually configured CAK takes precedence over the 802.1X-generated key.
When 802.1X is not enabled on MACsec ports, you can execute this command to configure a preshared key on each MACsec port. Make sure the connected ports are configured with the same CKN and CAK. If the connected ports are configured with different CKNs and CAKs, they cannot successfully establish MKA sessions.
To successfully establish an MKA session between two connected ports, make sure only the ports are configured with the same CKN in the network.
To delete the configured keys for MKA sessions that have been established, perform the following tasks:
1. Execute the undo mka psk command on the key server.
2. Execute the undo mka psk command on the non-key server.
The deletion operation deletes the established MKA sessions at the same time.
Different cipher suites for MACsec encryption have different requirements for the CKN and CAK configuration.
· The GCM-AES-128 cipher suite requires that the CKN and CAK each must be 32 characters long. If the configured CKN or CAK is not 32 characters long, the system performs the following operations when it runs the cipher suite:
¡ Automatically increases the length of the CKN or CAK by zero padding if the CKN or CAK contains less than 32 characters.
¡ Uses only the first 32 characters if the CKN or CAK contains more than 32 characters.
· The GCM-AES-256 cipher suite requires that the CKN and CAK each must be 64 characters long. If the configured CKN or CAK contains less than 64 characters, the system automatically increases the length of the CKN or CAK by zero padding when it runs the cipher suite.
# Configure the CAK name as AB, and set the CAK to 1234 in plain text on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mka psk ckn AB cak simple 1234
dot1x
macsec cipher-suite
mka timer mka-life
Use mka timer mka-life to set the MKA life time.
Use undo mka timer mka-life to restore the default.
mka timer mka-life seconds
The MKA life time is 6 seconds.
seconds: Sets the MKA life time in seconds. The value range for this argument is 6 to 60600.
The participants at each end of a secure session exchange MKA protocol packets to keep the session alive.
The MKA life time sets the session keepalive timer for participants. The timer starts on a participant when the participant receives the first MKA protocol packet from its peer. If the participant does not receive any subsequent MKA protocol packets from that peer before the timer expires, the participant determines that the session is insecure and then removes the session in time.
This command is applicable only in device-oriented mode.
Make sure the participants at each end of a secure session have the same MKA life time.
# Set the MKA life time to 10 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mka timer mka-life 10
display macsec
Use replay-protection enable to enable MACsec replay protection in an MKA policy.
Use undo replay-protection enable to disable MACsec replay protection in an MKA policy.
MACsec replay protection is enabled in an MKA policy.
MKA policy view
Operating mechanism
When an MKA policy is applied to a port, the replay protection configuration in the policy overwrites the replay protection feature already used by the port.
# Enable MACsec replay protection in MKA policy abcd.
[Sysname-mka-policy-abcd] replay-protection enable
mka apply policy
Use replay-protection window-size to set the MACsec replay protection window size in an MKA policy.
Use undo replay-protection window-size to restore the default.
The MACsec replay protection window size in an MKA policy is 0. The device accepts only frames that arrive in the correct order. Out-of-order or duplicated frames will be dropped.
MKA policy view
Operating mechanism
Suppose the replay protection window size is a on a port. After the port receives a packet with PN x, it can accept only packets whose PN is greater than or equal to x-a.
When an MKA policy is applied to a port, the replay protection window size in the policy overwrites the window size already configured on the port.
# Set the MACsec replay protection window size to 100 in MKA policy abcd.
[Sysname-mka-policy-abcd] replay-protection window-size 100
mka apply policy
reset mka session
Use reset mka session to reset MKA sessions on ports.
reset mka session [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command resets MKA sessions on all ports.
This command first clears MKA sessions, and then immediately triggers a new session establishment negotiation.
# Reset MKA sessions on Ten-GigabitEthernet 3/0/1.
<Sysname> reset mka session interface ten-gigabitethernet 3/0/1
display mka session
Use reset mka statistics to clear MKA statistics on ports.
reset mka statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears MKA statistics on all ports.
# Clear MKA statistics on Ten-GigabitEthernet 3/0/1.
<Sysname> reset mka statistics interface ten-gigabitethernet 3/0/1
validation mode
Use validation mode to set a MACsec validation mode in an MKA policy.
Use undo validation mode to restore the default.
The MACsec validation mode is check. The device performs validation only and does not drop illegal frames.
MKA policy view
When an MKA policy is applied to a port, the MACsec validation mode in the policy overwrites the MACsec validation mode already configured on the port.
# Set the MACsec validation mode to strict in MKA policy abcd.
[Sysname-mka-policy-abcd] validation mode strict
mka apply policy
