01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5100[S5500]-D-G&S5130S-G[-V2] Command References-R8336Pxx-6W10001-Fundamentals Command Reference
15-Python commands
15-Python commands 48.17 KB
Python commands
Python2 commands
exit()
Use exit() to exit the Python2 shell.
exit()
Python2 shell
To return to user view from the Python2 shell, you cannot use the quit command. You must use the exit() command.
# Exit the Python2 shell.
>>> exit()
<Sysname>
python
Use python to enter the Python2 shell.
python
In the Python2 shell, you can use the following items:
·     Python 2.7 commands.
·     Python 2.7 standard API.
·     Comware 7 extended API.
# Enter the Python2 shell.
<Sysname> python
Python 2.7.18 (default)
[GCC 4.4.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
python filename
Use python filename to execute a Python2 script.
python filename [ param ]
filename: Specifies the name of a Python2 script on a storage medium of the device. The script name is case sensitive and must use the extension .py. The extension .py is case insensitive.
param: Specifies the parameters to be passed to the script. To enter multiple parameters, use spaces as the delimiter.
You cannot perform any operations while you are executing a Python2 script.
Make sure the statements in the script meet the syntax requirements. The system stops executing a Python2 script if it finds a statement with syntax errors.
When executing a script, the system uses the defaults for interactive statements. The system does not stop for human input.
# Execute Python2 script test.py.
<Sysname> python test.py 1 2
['/flash:/test.py', '1', '2']
