01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5100[S5500]-D-G&S5130S-G[-V2] Command References-R8336Pxx-6W10001-Fundamentals Command Reference
13-Device management commands
13-Device management commands 742.93 KB
Device management commands· 1
clock datetime· 1
clock protocol 2
clock summer-time· 2
clock timezone· 4
command· 5
copyright-info enable· 6
display alarm active· 6
display alarm history· 9
display clock· 11
display copyright 12
display cpu-usage· 12
display cpu-usage configuration· 13
display cpu-usage history· 14
display device· 16
display device manuinfo· 17
display device manuinfo fan· 17
display device manuinfo power 18
display device uptime· 18
display diagnostic-information· 19
display dying-gasp host 21
display environment 22
display fan· 23
display kernel memory alloc-failure· 24
display kernel memory fragment free· 24
display memory· 25
display memory dma· 27
display memory-threshold· 27
display memory-threshold dma· 29
display power 30
display resource-monitor 32
display scheduler job· 33
display scheduler logfile· 33
display scheduler reboot 34
display scheduler schedule· 35
display system health· 36
display system health history· 37
display system stable state· 38
display transceiver alarm·· 40
display transceiver diagnosis· 43
display transceiver eyediagram-diagnosis· 44
display transceiver health· 47
display transceiver interface· 48
display transceiver manuinfo· 48
display transceiver power 49
display version· 50
display version-update-record· 50
dying-gasp host 51
dying-gasp source· 52
fan ignore-absent 53
hardware-alarm disable· 54
header 55
job· 55
memory-threshold· 56
memory-threshold dma· 58
memory-threshold usage· 59
monitor cpu-usage enable· 60
monitor cpu-usage interval 60
monitor cpu-usage logging interval 61
monitor cpu-usage threshold· 62
monitor memory-usage logging interval 63
monitor resend cpu-usage· 63
monitor resend memory-threshold· 64
monitor resend memory-threshold dma· 66
parity-error consistency-check log enable· 67
parity-error consistency-check period· 67
parity-error consistency-check threshold· 68
parity-error monitor log enable· 69
parity-error monitor period· 70
parity-error monitor threshold· 70
parity-error unrecoverable log enable· 71
parity-error unrecoverable period· 72
parity-error unrecoverable reboot 73
parity-error unrecoverable threshold· 73
password-recovery enable· 74
push-button mode enable· 75
reboot 76
reset scheduler logfile· 77
reset version-update-record· 77
resource-monitor minor resend enable· 78
resource-monitor output 79
resource-monitor resource· 80
restore factory-default 82
scheduler job· 82
scheduler logfile size· 83
scheduler reboot at 83
scheduler reboot delay· 84
scheduler schedule· 85
shutdown-interval 86
sysid· 87
sysname· 87
temperature-limit 88
time at 89
time once· 90
time repeating· 91
transceiver health check enable· 92
transceiver health weight 93
transceiver monitor enable· 94
transceiver monitor interval 95
transceiver rx-power high-threshold· 95
transceiver rx-power low-threshold· 96
transceiver rx-power change-threshold· 97
transceiver tx-power high-threshold· 98
transceiver tx-power low-threshold· 99
transceiver tx-power change-threshold· 100
usb disable· 101
user-role· 102
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is UTC time 00:00:00 01/01/2011.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Change of the system time affects execution of system time-related features (such as scheduled tasks) and cooperative operation with other devices (such as log reporting and statistics collection). Before executing this command, make sure you understand its impact on the live network.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
A device power cycling operation restores the local system time to the default. After the device is power cycled, you must execute this command again to set the local system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you execute the clock protocol ntp command, the device obtains the UTC time through NTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
Use display alarm active to display information about active alarms.
display alarm active [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If a power module, CPU, or fan is operating abnormally on the device, you can use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display information about active alarms.
<Sysname> display alarm active
Seq    Level    Time                  Info
24     Warning  2020-01-11  12:40:00  CPU usage is in minor alarm state on slot 1.
23     Warning  2020-01-11  12:30:00  Memory minor threshold has been exceeded on slot 1.
22     Minor    2020-01-11  12:18:00  Board state changed to Fault on slot 1.
Seq
Alarm sequence number, assigned when an alarm occurs.
Level
Alarm severity. Values include Critical, Major, Minor, and Warning, in descending order of severity.
Time
Time when the alarm occurred.
Info
Detailed alarm information. Values include:
·     Board state changed to Fault on slot n—The state of the specified slot changed to Fault. The slot might be starting up or might be faulty.
·     Slot n fan n is absent—The specified fan is absent.
·     Slot n fan n is failed—The specified fan is abnormal.
·     Slot n power n is absent—The specified power module is absent.
·     Slot n power n failed—The specified power module is abnormal.
·     Temperature is higher than the high-temperature alarming threshold on slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold.
·     Memory minor threshold has been exceeded on slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold.
·     CPU usage is in minor alarm state on slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold.
·     Interface-name: RX power is high!—The optical power on the specified interface is too high.
·     Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit.
·     SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully.
·     Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason.
·     The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes:
¡     $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational.  For more information about LDP sessions states, see LDP commands in MPLS Command Reference.
¡     $2: Duration when the LDP session is in the operational state.
¡     $3: Times that the LDP session received unknown messages.
¡     $4: Times that the LDP session received unknown TLVs.
·     The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6)
¡     $1: BGP instance name.
¡     $2: Address Family Identifier (AFI).
¡     $3: Subsequent Address Family Identifier (SAFI).
¡     $4: IP type of the BGP peer.
¡     $5: IP address of the BGP peer.
¡     $6: The maximum number of routes that the device can receive from a BGP peer.
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.
¡     $2: VPN instance name. For a log message on public network, this field is null.
¡     $3: IP address of the BGP peer.
¡     $4: Address Family Identifier (AFI).
¡     $5: Subsequent Address Family Identifier (SAFI).
¡     $6: The maximum number of route prefixes that can be received from the peer.
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7).
¡     $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold.
·     The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
# Display detailed information about active alarms.
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
  Info: Board state changed to Fault on slot 2.
Seq
Alarm source
Location where the alarm occurred.
Level
Start time
Info
display alarm
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ verbose ]
If a power module, CPU, or fan is operating abnormally on the device, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
The maximum number of historical alarms that can be displayed by this command varies by device model.
# Display brief information about historical alarms.
<Sysname> display alarm history
Seq        Time                  Info
23         2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
For information about the fields in the command output, see the display alarm active command.
# Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
Seq
Alarm sequence number, assigned automatically by the system when an alarm occurs.
AlarmPosition
Start time
Level
Recovery time
Time when the alarm was cleared.
Info
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7).
¡     $6: The maximum number of routes that can be received from the peer.
·     The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
·     The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6).
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.
display alarm
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
control-plane: Displays CPU usage statistics for the control plane. If you do not specify this keyword or the data-plane keyword, the command displays the total CPU usage statistics.
data-plane: Displays CPU usage statistics for the data plane. If you do not specify this keyword or the control-plane keyword, the command displays the total CPU usage statistics.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage statistics for all member devices.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
x% in last 5 seconds
Last 5 sec
Average CPU or CPU core usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU or CPU core usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU or CPU core usage during the most recent 5-minute interval.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the CPU usage monitoring settings for the master device.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current severe alarm threshold is 85% for the following cores: 0.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
Table 5 Command output
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current severe alarm threshold is xxx.
Severe CPU usage alarm threshold.
Current minor alarm threshold is xxx.
Minor CPU usage alarm threshold.
Current recovery threshold is xxx.
CPU usage recovery threshold.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes on all member devices.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device information.
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
If you do not specify the flash and usb keywords, this command displays information about member devices.
# Display device information.
<Sysname> display device
Slot 1
Slot Type                 State    Subslot  Soft Ver             Patch Ver
1    S5130S-54S-PWR-EI-G   Master   0        S5130SEIG-6009P13     None
Table 6 Command output
Device type.
Role of the device in an IRF fabric:
·     Master—The device is the master.
·     Standby—The device is a subordinate member.
Soft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see "Upgrading software."
Use display device manuinfo to display electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo slot 1 fan 1
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo slot 1 power 1
Use display device uptime to display information about member device uptime since the latest startup.
# Display information about member device uptime since the latest startup.
<Sysname> display device uptime
Slot Type                 State    Subslot  UP time(DD:HH:MM)
1    S7800XP-48Y8C-G      Master   0        0000:04:28
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware: Specifies hardware-related operating information.
ifmgr: Specifies IFMGR-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
Use display dying-gasp host to display poweroff alarm destination host settings.
# Display poweroff alarm destination host settings.
<Sysname> display dying-gasp host
IPv4 address: 1.1.1.0
Message type: SNMP Trap
Securityname: p1
Version: V1
IPv4 address: 1.1.1.1
Message type: Syslog
Table 7 Command output
IPv4 address
IPv4 address of the poweroff alarm destination host.
IPv6 address
IPv6 address of the poweroff alarm destination host.
VPN instance
VPN instance to which the poweroff alarm destination host belongs.
Message type
Message types that the poweroff alarm destination host supports:
·     SNMP Trap—SNMP notification.
·     Syslog—Log message.
Securityname
SNMPv1 or SNMPv2c community name.
This field is displayed when the message type is SNMP Trap.
Version
SNMP version:
·     v1—SNMPv1.
·     v2c—SNMPv2c.
dying-gasp host
display environment
Use display environment to display temperature information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices.
# Display information about all temperature sensors on the device.
<Sysname> display environment
 System temperature information (degree centigrade):
Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 41           0      60       65     NA
 1     hotspot 2 68           0      100      117    NA
 1     hotspot 3 56           0      100      117    NA
Table 8 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     inflow—Air inlet sensor.
·     outflow—Air outlet sensor.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices.
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Slot 1:
 Fan 1 State: Normal
 Airflow Direction: Power-to-port
 Fan 2 State: Normal
 Fan 3 State: Normal
 Fan 4 State: Normal
 Fan 5 State: Normal
Table 9 Command output
Slot 1
Member device number.
Fan 1
Fan tray number.
Fan tray status:
·     Absent—The slot is not installed with a fan tray.
·     Fault—The fan tray is faulty.
·     Normal—The fan tray is operating correctly.
Airflow Direction
Actual airflow direction:
·     Port-to-power—From the port side to the power supply side.
·     Power-to-port—From the power supply side to the port side.
Use display kernel memory alloc-failure to display kernel memory allocation failure information.
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel memory allocation failure information for the master device.
# Display kernel memory allocation failure information.
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
Table 10 Command output
Number of memory allocation failures on the use of kmalloc_tag.
Number of memory allocation failures on the use of kcalloc_tag.
Number of memory allocation failures on the use of kzalloc_tag.
Number of memory allocation failures on the use of krealloc_tag.
Number of memory allocation failures on the use of kmem_cache_alloc_tag.
Use display kernel memory fragment free to display the kernel memory fragment statistics.
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel memory fragment statistics for the master device.
# Display the kernel memory fragment statistics.
<Sysname> display kernel memory fragment free
Kernel memory free ratio:  0.13%
cfq_io_context                   memory free (in kbytes): 0
LFIB_NhlfeEntryCache26           memory free (in kbytes): 0
LFIB_NhlfeEntryCache74           memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache           memory free (in kbytes): 0
NAT_SESSION_EXT_INFO             memory free (in kbytes): 0
ARP_VSISUP_Entry_cache           memory free (in kbytes): 0
LFIB_NhlfeEntryCache1            memory free (in kbytes): 0
FVN_FwdCache19                   memory free (in kbytes): 0
Table 11 Command output
Memory fragment ratio in the kernel space.
Memory fragment size in the slab named cfq_io_context, in KB.
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage for all member devices.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       3956640    891056   3065584         0      4364    188384       77.7%
-/+ Buffers/Cache:    698308   3258332
Swap:            0         0         0
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0       984560    456128    528432        4     45616     53.7%
Table 12 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches. If a memory threshold is reached, part of memory used for caches can be automatically released for other services.
FreeRatio
Free memory ratio. The free memory includes the free physical memory and the part of memory used for caches that can be automatically released for other services when a memory threshold is reached.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DMA memory usage information for the master device.
# Display DMA memory usage information for slot 1.
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
Table 13 Command output
Total
Total size of the DMA memory space, including the free and used DMA memory.
Used
Used DMA memory.
Free
Free DMA memory.
FreeRatio
Free DMA memory ratio.
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the memory usage thresholds and statistics for the master device.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory thresholds:
    Minor: 386M
    Severe: 270M
    Critical: 154M
    Normal: 502M
    Early-warning: 618M
    Secure: 695M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
Table 14 Command output
Free-memory thresholds
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
Free-memory thresholds:
·     Minor—Minor alarm threshold in MB.
·     Severe—Severe alarm threshold in MB.
·     Critical—Critical alarm threshold in MB.
·     Normal—Normal state threshold in MB.
·     Early-warning—Early-warning threshold in MB. This threshold is supported only on the S5130S-HI-G and S5130S-EI-G-V2 switch series.
·     Secure—Sufficient-memory threshold in MB. This threshold is supported only on the S5130S-HI-G and S5130S-EI-G-V2 switch series.
Current state of the free memory in the system:
·     Normal—Normal state.
·     Minor—Minor alarm threshold.
·     Severe—Severe alarm threshold.
·     Critical—Critical alarm threshold.
·     Normal (early-warning)—Early-warning threshold.‌ This state is supported only on the S5130S-HI-G and S5130S-EI-G-V2 switch series.
·     Normal (secure)—Sufficient-memory state.‌ This state is supported only on the S5130S-HI-G and S5130S-EI-G-V2 switch series.
Time when the alarm notification was sent for the first time, in the format of yyyy-mm-dd hh:mm:ss.msec.
Time when the alarm notification was sent most recently in the format of yyyy-mm-dd hh:mm:ss.msec.
Total number of notification send
Total number of the alarm notifications that were sent.
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DMA memory alarm information for the master device.
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critcal state]
    First notificatio: 0.0
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id | verbose ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power module information for all member devices.
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief power supply information.
<Sysname> display power
Slot 1:
 Input Power: -- W
 PowerID  State  Mode   Current(A)  Voltage(V)  Power(W) FanDirection
 1        Normal AC     10.3        12.0        121.0    --
 2        Absent --     --          --          --       --
Table 15 Command output
Input Power
Rated power of the device.
PowerID
Power supply ID.
Power supply status.
·     Absent—The slot is not installed with a power supply.
·     Fault—The power supply is faulty.
·     Normal—The power supply is operating correctly.
Mode
Mode of the power supply:
·     AC—AC power supply.
·     DC—DC power supply.
Current(A)
Output current of the power supply, in amperes.
Voltage(V)
Output voltage of the power supply, in volts.
Power(W)
Output power of the power supply, in watts.
FanDirection
Airflow direction of the power supply:
·     PowerToPort—From the power supply side to the port side.
·     PortToPower—From the port side to the power supply side.
# Display detailed power module information.
<Sysname> display power slot 1 verbose
System power information on slot 1:
 Power modules installed: 1
 Power modules usable: 1
 Rated power: 450 W
 Usable power: 450 W
 Used power: 0.0 W
 Redundant power: -- W
 Total DC output: 10.1 A
 PowerID State   InVoltage(V) InPower(W) OutVoltage(V) OutCurrent(A) OutPower(W)
 1       Normal  --           --         11.9          10.1          120.0
Table 16 Command output
Number of power supplies installed on the device.
Number of available power supplies.
Rated power
Total rated power of power supplies that are in Normal state, in watts.
Usable power
Total available power of power supplies that are in Normal state, in watts.
Used power
Total used power, in watts.
Redundant power
Redundant power, in watts.
Total DC output
Total output current of all power supplies, in amperes.
PowerID
Power supply ID.
Use display resource-monitor to display resource monitoring information.
Only the S5130S-HI-G and S5130S-EI-G-V2 switch series supports this command.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays resource monitoring information for all member devices.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 17 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values. ‌
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 18 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
Table 19 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display system health to display system health status information.
This command is supported only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
display system health [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays health status information about the master device.
The device periodically performs a series of checks to identify the health status of the device. The check items are already defined in the factory-default configuration. The check results can be used by the internal service modules such as IRF in the device.  You can execute this command to view these check results.
# Display system health status information.
<Sysname> display system health
Slot 1 health: Normal(0)
    Memory: Normal(0)
    Communication: Normal(0)
    DBM monitor: Normal(0)
    Chip jam: Normal(0)
    CPU deadloop: Normal(0)
    Forwarding channel: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    LSW port: Normal(0)
    Board status: Normal(0)
    Fan status: Normal(0)
    Temperature: Normal(0)
Table 20 Command output
Health: Normal(0)
System health status:
·     Normal(0)—The system is healthy.
·     Faulty(n)—The system is faulty. A greater value of n indicates a worse condition.
Memory
Memory health status.
Communication
Communication health status.
DBM monitor
DBM health status.
Chip jam
Chip jam status.
CPU deadloop
CPU deadloop status.
Forwarding channel
Health status of cross-card services on the device.
HG
HG health status.
LSW CPU
LSW CPU health status.
LSW port
LSW port health status.
Board status
Card health status.
Fan status
Fan tray health status.
Temperature status
Temperature sensor health status.
Use display system health history to display historical system health status change information.
display system health history [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays historical health status change information about the master device.
# Display historical system health status change information.
<Sysname> display system health history
Health: Faulty(1)
  Chip jam:
    Faulty(1)  2019-10-10 18:00:00 on slot 1
    Normal(0)  2019-10-08 17:00:00 on slot 1
    Faulty(1)  2019-10-07 18:00:00 on slot 1
Table 21 Command output
Health: Normal(0)
Chip jam:
Historical status change information of items. For more information about the supported check items on the device, see the display system health command.
A maximum of 30 historical status change entries are supported for each item.
Use display system stable state to display system stability and status information.
display system stable state [ summary ]
summary: Displays brief information about system status and NSR status. If you do not specify this keyword, the command displays detailed information about system status and CPU role and status.
Before performing an ISSU or a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
·     Use the display device command to identify the device operating status.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
·     Use the display system internal process state command in probe view to display service operating status.
# Display brief system stability and status information.
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR     state     : No standby
# Display system stability and status information.
Redundancy state: No redundancy
  Slot   CPU   Role      State
  1      0     Active    Stable
Table 22 Command output
System state
Operating status of all member devices:
·     Stable—All member devices are operating stably.
·     Not ready—The system is not operating stably. You cannot perform an ISSU when the system is in this state.
Redundancy state
System redundancy status:
·     Stable—Member devices are operating stably. You can perform a switchover.
·     No redundancy—The system has only one member device. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
NSR state
NSR status of all member devices:
·     Ready—NSR is operating correctly on all member devices where it is enabled.
·     Not ready—NSR is not operating correctly on all member devices where it is enabled. You cannot perform a process or member switchover or an ISSU.
·     No standby—The IRF fabric has only one member device.
·     Not configured—NSR is not enabled.
Role
Role of the member device in the system:
·     Active—The member device is the master.
·     Standby—The member device is a subordinate member.
Member device status:
·     Stable—The member device is operating stably.
·     Board inserted—The member device has just been installed.
·     Kernel initiating—Member device kernel is being initialized.
·     Service starting—Services are starting on the member device.
·     Service stopping—Services are stopping on the member device.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
The object is not operating stably.
display device
display ha service-group (High Availability Command Reference)
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarm information on transceiver modules.
If no error occurs, None is displayed. The following tables describe the alarm information that might be present on transceiver module.
Table 23 Command output for SFP+/SFP28 transceiver modules
RX signal loss
Receive signal loss.
RX power high alarm
Alarm on a high receive optical power.
RX power high warning
Early warning on a high receive optical power.
RX power low alarm
Alarm on a low receive optical power.
RX power low warning
Early warning on a low receive optical power.
TX fault
Transmit fault.
TX bias high alarm
Alarm on a high transmit bias current.
TX bias high warning
Early warning on a high transmit bias current.
TX bias low alarm
Alarm on a low transmit bias current.
TX bias low warning
Early warning on a low transmit bias current.
TX power high alarm
Alarm on a high transmit optical power.
TX power high warning
Early warning on a high transmit optical power.
TX power low alarm
Alarm on a low transmit optical power.
TX power low warning
Early warning on a low transmit optical power.
Temp high alarm
Alarm on a high temperature.
Temp high warning
Early warning on a high temperature.
Temp low alarm
Alarm on a low temperature.
Temp low warning
Early warning on a low temperature.
Voltage high alarm
Alarm on a high voltage.
Voltage high warning
Early warning on a high voltage.
Voltage low alarm
Alarm on a low voltage.
Voltage low warning
Early warning on a low voltage.
Transceiver info I/O error
N/A
Transceiver info checksum error
N/A
Transceiver type and port configuration mismatch
The transceiver type does not match port configuration.
Transceiver type not supported by port hardware
The transceiver type is not supported on the port.
TEC error
Thermoelectric Cooler (TEC) error.
This field is available only for the SFP-XG-LH80-Tunable transceiver module.
Wavelength unlocked
Optical signal wavelength is out of lock.
Tx is not ready due to tunning
The transmitter is not ready when the signal wavelength changes.
Tx dither not supported
Transmit dithering is not supported.
Excessive RX power change
Alarm on the excessive receive optical power change in channel x.
Excessive TX power change
Alarm on the excessive transmit optical power change in channel x.
Excessive TX bias change
Alarm on the excessive bias current change in channel x.
Excessive temp change
Alarm on the excessive temperature change.
User-set TX power high
User-set high transmit optical power alarm in channel x.
User-set TX power low
User-set low transmit optical power alarm in channel x.
User-set RX power high
User-set high receive optical power alarm in channel x.
User-set RX power low
User-set low receive optical power alarm in channel x.
RX CDR loss of lock
Receive CDR loss of lock, indicating poor signal.
TX CDR loss of lock
Transmit CDR loss of lock, indicating poor signal.
Table 24 Command output for QSFP+/QSFP28 transceiver modules
Temp high alarm
Temp high warning
Temp low alarm
Temp low warning
Voltage high alarm
Voltage low alarm
Voltage low warning
RX loss of signal(channel x)
Loss of receive signal in channel x.
TX fault(channel x)
Packet transmission fault in channel x.
TX loss of signal(channel x)
Loss of transmit signal in channel x.
RX power high(channel x)
Alarm on a high receive optical power in channel x.
RX power low(channel x)
Alarm on a low receive optical power in channel x.
TX power high alarm(channel x)
Alarm on a high transmit optical power in channel x.
TX power high warning(channel x)
Early warning on a high transmit optical power in channel x.
TX power low alarm(channel x)
Alarm on a low transmit optical power in channel x.
TX power low warning(channel x)
Early warning on a low transmit optical power in channel x.
TX bias high(channel x)
Alarm on a high bias current in channel x.
TX bias low(channel x)
Alarm on a low bias current in channel x.
N/A
N/A
Transceiver type and port configuration mismatched
Excessive RX power change(channel x)
Excessive TX power change(channel x)
Excessive TX bias change(channel x)
User-set TX power high(channel x)
User-set TX power low(channel x)
User-set RX power high(channel x)
User-set RX power low(channel x)
# Display the alarms present on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
  RX signal loss
  RX power low alarm
Table 25 Command output
Alarms present on the transceiver module.
RX signal loss
RX power low alarm
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
  Warning thresholds:
           Temp(C)    Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   45         3.25        1.25      -15.00         4.00
    Low    25         2.85        0.85      -25.00         1.00
  User-set power thresholds:
    High  -11.40         N/A
    Low   -26.00         0.10
Table 26 Command output
Digital diagnosis information for the transceiver module in the interface.
Wave.er(nm)
Wavelength offset in nm, accurate to 0.001 nm. This field is supported only on the SFP-XG-LH80-Tunable transceiver module.
Freq.er(GHz)
Frequency offset in GHz, accurate to 0.1 GHz. This field is supported only on the SFP-XG-LH80-Tunable transceiver module.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
Total RX power(dBm)
Total receive power in dBm, accurate to 0.01 dBm.
Total TX power(dBm)
Total transmit power in dBm, accurate to 0.01 dBm.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
High
High alarm threshold or high early warning threshold.
Low
Low alarm threshold or low early warning threshold.
Warning threshold
Early warning threshold.
User-set power threshold.
RX power(dBm)
User-set receive optical power threshold in dBm, accurate to 0.01 dBm.
TX power(dBm)
User-set transmit optical power threshold in dBm, accurate to 0.01 dBm.
display transceiver eyediagram-diagnosis
Use display transceiver eyediagram-diagnosis to diagnose transceiver modules and display diagnosis information in an eye diagram.
display transceiver eyediagram-diagnosis interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the diagnostic results on every transceiver module.
This command is used to simulate the quality of data transmission from professional testing instruments. It obtains the sampling values of received data on chips and outputs the diagnostic results of transceiver modules in an eye diagram. This facilitates users in analyzing and evaluating the data transmission quality of transceiver modules.
You can analyze the data transmission quality of transceiver modules through eye diagrams as follows:
·     A larger eye opening area with a clearer shape indicates more stable signal transmission and better quality. The eye opening area is the blank area above and below the central line (0mV line).
·     No digits in the eye opening area indicate good data transmission quality. If the eye opening area has digits, the data transmission quality is poor.
# Diagnose the transceiver module in interface GigabitEthernet 1/0/1, and display the diagnostic results in an eye diagram.
<Sysname> display transceiver eyediagram-diagnosis interface gigabitethernet 1/0/1
This operation might consume a large amount of system resources. It might cause unknown risks and might take several minutes. Continue?[Y/N]:y
    | EYESCAN Phy: 0x0e1 lane_mask: 0x01                                 |
Each character N represents approximate error rate 1e-N at that location
  UI/64  : -30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
   128mV : 111111111111111111111111112222322222222211111111111111111111111
   124mV : 111111111111111111111111122233332222222221111111111111111111111
   120mV : 111111111111111111111111222333333332222222211111111111111111111
   115mV : 111111111111111111111112223334443333222222221111111111111111111
   111mV : 111111111111111111111122233344444333322222222111111111111111111
   107mV : 111111111111111111111122233445544433332222222211111111111111111
   103mV : 111111111111111111111222334456655544333332222222111111111111111
    99mV : 111111111111111111112223344566665544433333222222211111111111111
    95mV : 11111111111111111111222344556776655443333322222221111111111111
    91mV : 11111111111111111112223345567  :766554443333222222111111111111
    86mV : 11111111111111111122233455677  :  76655444333322222211111111111
    82mV : 111111111111111111223344567----+---7665544433322222221111111111
    78mV : 111111111111111112223345667    :    :76655444333222222111111111
    74mV : 11111111111111112223345677:    :    :77665544333322222111111111
    70mV : 1111111111111111223344567 7    :    :   76655443332222211111111
    66mV : 1111111111111112223345677 :    :    :    7665444333222221111111
    62mV : 111111111111112223345667--+----+----+----+776554433322222111111
    57mV : 111111111111112223445677  :    :    :    :76655443332222111111
    53mV : 1111111111111222334566    :    :    :    :  7765544333222211111
    49mV : 1111111111112223345567    :    :    :    :    76554333222221111
    45mV : 111111111111222334567:    :    :    :    :    :7655443322222111
    41mV : 111111111112223345677+----+----+----+----+----+7765544332222211
    37mV : 11111111112223344567 :    :    :    :    :    :776544333222211
    33mV : 11111111112223345667 :    :    :    :    :    :   7654433322221
    28mV : 1111111112223344567  :    :    :    :    :    :   7765443322222
    24mV : 111111111222334567   :    :    :    :    :    :    765543332222
    20mV : 111111112223345567---+----+----+----+----+----+----+76544333222
    16mV : 11111112222344567    :    :    :    :    :    :    :7654433222
    12mV : 1111111222334567:    :    :    :    :    :    :    :77655433322
     8mV : 1111112223344567:    :    :    :    :    :    :    :  765543322
     4mV : 111111222334566 :    :    :    :    :    :    :    :  776544332
     0mV : 111111222344567-+----+----+----+----+----+----+----+----6554332
    -4mV : 111111222344567 :    :    :    :    :    :    :    :   76544332
    -8mV : 111111222334567 :    :    :    :    :    :    :    :  765443332
   -12mV : 1111112223344567:    :    :    :    :    :    :    :7655433322
   -16mV : 1111111222334567:    :    :    :    :    :    :    :7654433222
   -20mV : 11111112222344567----+----+----+----+----+----+----776544333222
   -24mV : 111111112223345677   :    :    :    :    :    :    765543332222
   -28mV : 111111111222334567   :    :    :    :    :    :   7665443332222
   -33mV : 1111111111222344567  :    :    :    :    :    :  77654433322221
   -37mV : 1111111111222334567  :    :    :    :    :    :766544333222211
   -41mV : 11111111111223344567-+----+----+----+----+----+7765544332222211
   -45mV : 11111111111222334566 :    :    :    :    :    77655443332222111
   -49mV : 1111111111112223345677    :    :    :    :    76554433322221111
   -53mV : 1111111111111222344567    :    :    :    :  7765544333222221111
   -57mV :1111111111111222334567    :    :    :    :77655443332222211111
   -62mV : 111111111111112223445677--+----+----+----+776654433332222211111
   -66mV : 111111111111111223345567  :    :    :    7765544333222222111111
   -70mV : 1111111111111112223345667 :    :    :    7655443333222221111111
   -74mV :11111111111111112223345667 :    :    :  766554433322222211111111
   -78mV :111111111111111112233445677    :    :  776554433322222211111111
   -82mV : 111111111111111112223345567----+----766554443332222221111111111
   -86mV : 1111111111111111112223345567   :    765544433322222221111111111
   -91mV : 11111111111111111112233445667  :   7665444333322222211111111111
   -95mV : 111111111111111111122233445667 :7766554433332222222111111111111
   -99mV : 111111111111111111112223344566777665544333322222221111111111111
  -103mV : 111111111111111111111223334556676655443333222222211111111111111
  -107mV : 111111111111111111111222333445565544333322222222111111111111111
  -111mV : 111111111111111111111122233444554443333222222221111111111111111
  -115mV : 111111111111111111111112223334444433332222222211111111111111111
  -120mV : 111111111111111111111111222333444333322222222111111111111111111
  -124mV : 111111111111111111111111222233333332222222211111111111111111111
  -128mV : 111111111111111111111111122223333322222222111111111111111111111
  UI/64  :-30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
display transceiver health
Use display transceiver health to display health information of transceiver modules.
Only the S5130S-HI-G or S5130S-EI-G-V2 switch series supports this command.
display transceiver health interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays health information of all transceiver modules.
#  Display health information of the transceiver module in interface GigabitEthernet 1/0/1.
[Sysname] display transceiver health interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver health information:
LinkStatus health: 10
Transceiver health:
  Temp.    Voltage    Bias    RX power    TX power   Total
  10       10         10      10          10         10
Table 27 Command output
Transceiver health
Health information of the transceiver module in the interface.
LinkStatus health
Link health, whose calculation is related to the health of the error packet rate.
·     If the health of the error packet rate is 1, the link health is 1.
·     If the health of the error packet rate is 2 to 9, the link health = (Receive power health + the health of the error packet rate)/2.
·     If the health of the error packet rate is 10, the link health = Round-off number for [(receive power health + 10)/2 + 0.5].
Tem
Temperature health.
Voltage
Voltage health.
Bias
Bias current health.
RX power
Receive power health.
TX power
Transmit power health.
Total
Overall transceiver module health, sum of the health of each element multiplied by its corresponding weight.
transceiver health check enable
transceiver health weight
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver interface gigabitethernet 1/0/1
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 1/0/1
display transceiver power
Use display transceiver power to display power information for transceiver modules.
display transceiver power interface [ interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If no interface is specified, this command displays power information for all transceiver modules.
# Display power information for all transceiver modules.
<Sysname> display transceiver power interface
Interface       Transceiver type         Current power(w)    Max power(w)
GE1/0/1         100G_BASE_SR4_QSFP28     2.30                3.50
GE1/0/2         100G_BASE_LR4_QSFP28     2.50                4.00
GE1/0/3         100G_BASE_ER4_QSFP28     3.51                5.00
GE1/0/4         Absent                   --                  --
GE1/0/5         100G_BASE_SR4_QSFP28     --                  --
GE1/0/6         10G_BASE_LR_SFP          --                  1.50
         10G_BASE_LR_SFP          1.00                --
Current total power  : 9.31w
Maximum total Power  : 15.5w
# Display power information for the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver power interface gigabitethernet 1/0/1
GE1/0/1           10G_BASE_LR_SFP              1.00                1.50
Table 28 Command output
Current power(w)
Current power of a transceiver module, in watts, accurate to 0.01 w.
Max power(w)
Maximum power of a transceiver module, in watts, accurate to 0.01 w.
Current total power
Current total power of all transceiver modules, in watts, accurate to 0.01 w.
Max total power
Maximum total power of all transceiver modules, in watts, accurate to 0.01 w
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
Table 29 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
dying-gasp host
Use dying-gasp host to configure poweroff alarm destination host settings.
Use undo dying-gasp host to remove poweroff alarm destination host settings.
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] snmp-trap version { v1 | v2c | v3 [ authentication | privacy ] } securityname security-string
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] syslog
undo dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] { snmp-trap | syslog }
No poweroff alarm destination host settings are configured.
ip-address: Specifies the IPv4 address of the destination host to which the device sends the poweroff alarm.
ipv6 ipv6-address: Specifies the IPv6 address of the destination host to which the device sends the poweroff alarm.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the destination host belongs to the public network, do not specify this option.
snmp-trap: Uses an SNMP notification to send the poweroff alarm.
version: Specifies the SNMP version.
·     v1: Uses SNMPv1.
·     v2c: Uses SNMPv2c.
·     v3: Uses SNMPv3. If you do not specify the authentication or privacy keyword, no authentication or encryption is performed.
¡     authentication: Performs only authentication on packets.
¡     privacy: Performs both authenticaiton and encrypton on packets.
securityname security-string: Specifies an SNMPv1 or SNMPv2c community name, or SNMPv3 username, a case-sensitive string of 1 to 32 characters.
syslog: Uses a log message to send the poweroff alarm.
The device can send the poweroff alarm by using either or both of an SNMP notification and a log message.
The device can send the poweroff alarm to multiple destination hosts at the same time.
When you configure the device to send poweroff alarms in SNMP v3 traps to the NMS, execute the snmp-agent usm-user command to create an SNMP v3 user. Make sure the authentication mode for the group to which the SNMP v3 user belongs is the same as the authentication mode configured by the dying-gasp host command. In addition, the authentication and encryption parameters must match those configured on the NMS. If you fail to do so, the device cannot send poweroff alarms in SNMP v3 traps to the NMS.
# Configure the device to send the poweroff alarm to the host at 1.1.1.1 by using an SNMPv1 notification. The community name is public.
[Sysname] dying-gasp host 1.1.1.1 snmp-trap version v1 securityname public
dying-gasp source
dying-gasp source
Use dying-gasp source to specify the source interface for sending the poweroff alarm.
Use undo dying-gasp source to restore the default.
dying-gasp source interface-type interface-number
No source interface is specified. On an IPv4 network, the device uses the primary IPv4 address of the output interface for the route to the destination host as the source address. On an IPv6 network, the device selects a source IPv6 address as defined in RFC 3484.
The device uses the IPv6 address or primary IPv4 address of the specified source interface as the source address for outgoing poweroff alarm packets. The destination hosts use this address to identify SNMP notifications or log messages received from the device.
If no address is configured for the specified source interface, this command does not take effect. For this command to take effect, assign an address to the source interface.
# Use the M-GigabitEthernet 0/0/0 interface as the source interface for sending the poweroff alarm.
[Sysname] dying-gasp source M-GigabitEthernet 0/0/0
dying-gasp host
fan ignore-absent
Use fan ignore-absent to configure the device to ignore absent fans.
Use undo fan ignore-absent to restore the default.
fan ignore-absent
The devices does not ignore absent fans.
CAUTION
CAUTION:
Ignoring absent fans might cause device reboot and even device damage if the device is not well ventilated.
The device periodically polls the status of fans. Upon detecting an absent fan, the device sets the status of the fan to Absent and sends a log message and a trap. If the device has external fans and is well ventilated, you can use this command to configure the device to ignore absent fans. Then, the device does not send log messages or traps upon detecting absent fans.
# Ignore absent fans.
[Sysname] fan ignore-absent
After you configure this command, the device does not provide traps or log messages when it detects that one or more fans are absent. You must make sure that the device is well-ventilated. Continue?[Y/N] y
hardware-alarm disable
Use hardware-alarm disable to disable the notification of hardware resource alarms.
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-portdevice | disk | fan | interface | power | subcard | transceiver | voltage } disable
The notification of all hardware resource alarms is enabled.
all: Specifies all types of resource alarms.
bus: Specifies bus-related resource alarms.
chip-channel: Specifies chip channel-related resource alarms.
chip-port: Specifies chip port-related resource alarms.
device: Specifies device-related resource alarms.
disk: Specifies disk-related resource alarms.
fan: Specifies fan-related resource alarms.
interface: Specifies interface-related resource alarms.
syslog: Sends hardware resources alarms in syslog messages.
subcard: Specifies subcard-related resource alarms.
transceiver: Specifies transceiver-related resource alarms.
trap: Sends hardware resources alarms in traps.
power: Specifies power supply-related resource alarms.
voltage: Specifies voltage-related resource alarms.
# Disable trap notification for all hardware resource alarms.
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# Disable syslog notification for device-related resource alarms.
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
For the S5130S-HI-G or S5130S-EI-G-V2 switch series:
·     Minor alarm threshold: 190 MB.
·     Severe alarm threshold: 133 MB.
·     Critical alarm threshold: 76 MB.
·     Normal state threshold: 247 MB.
·     Early-warning threshold: 304 MB.
·     Sufficient-memory threshold: 342 MB.
·     Minor alarm threshold: 56 MB.
·     Severe alarm threshold: 52 MB.
·     Critical alarm threshold: 48 MB.
·     Normal state threshold: 64 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
The early-warning early-warning-value option is supported only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
The secure secure-value option is supported only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets free-memory thresholds for the master device.
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
You can use the display memory command to display memory usage information.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
The system restarts the device if one of the following conditions is met:
·     After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
·     The interval between two consecutive critical alarms is shorter than 30 seconds.
·     The critical alarm has occurred three times within three minutes.
·     After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the device.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB and the normal state threshold is 4096 KB.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets DMA memory thresholds for the master device.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, .
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the device adjusts the value for the normal-value argument depending on the value for the critical-value argument.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification indicating that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification indicating that the DMA memory space is sufficient.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot 1.
<System> system-view
[System] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the memory usage threshold for the master device.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables CPU usage monitoring for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the interval for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging interval
Use monitor cpu-usage logging interval to enable periodic CPU usage logging.
Use undo monitor cpu-usage logging interval to disable periodic CPU usage logging.
monitor cpu-usage logging interval interval-time
Periodic CPU usage logging is disabled.
interval interval-time: Specifies the logging interval in seconds, a multiple of five in the range of 5 to 300.
# Enable periodic CPU usage logging and set the logging interval to 60 seconds.
[Sysname] monitor cpu-usage logging interval 60
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number }
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 80%.
CPU usage recovery threshold: 60%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU usage threshold for the master device.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the severe CPU usage alarm threshold to 90%, minor CPU usage alarm threshold to 80%, and CPU usage recovery threshold to 70%.
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor memory-usage logging interval
Use monitor memory-usage logging interval to enable periodic memory usage logging.
Use undo monitor memory-usage logging interval to disable periodic memory usage logging.
monitor memory-usage logging interval interval-time
Periodic memory usage logging is disabled.
# Enable periodic memory usage logging and set the logging interval to 60 seconds.
[Sysname] monitor memory-usage logging interval 60
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor alarm resending interval is 300 seconds. The severe alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets alarm resending intervals for the master device.
The device samples CPU usage periodically and compares the sample with the CPU usage threshold. If the sample increases above an alarm threshold, the CPU usage enters an alarm state and the device sends an alarm.
While the CPU usage is in minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
While the CPU usage is in severe alarm state, the device sends severe alarms periodically until the severe alarm is removed.
You can use this command to change CPU usage alarm resending intervals.
If you do not specify the minor-interval or severe-interval keyword, the undo monitor resend cpu-usage command restores default settings for both the minor and severe alarm resending intervals.
# Set the CPU usage minor alarm resending interval to 60 seconds for CPU 0 in slot 1.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold
Use monitor resend memory-threshold to set memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
For the S5130S-HI-G or S5130S-EI-G-V2 switch series, the default settings are as follows:
·     Early warning resending interval: 1 hour.
·     Minor alarm resending interval: 12 hours.
·     Severe alarm resending interval: 3 hours.
·     Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
early-warning-interval early-warning-interval: Specifies the early warning resending interval in hours, in the range of 1 to 48.
The early-warning-interval early-warning-interval option is supported only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
The device samples the amount of free memory space periodically and compares the sample with free-memory thresholds. If the sample decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
If you do not specify any memory depletion alarm resending intervals, the undo monitor resend memory-threshold command restores default settings for all memory depletion alarm resending intervals.
# Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
This command is available only on the S5130S-EI-G, S5100-D-G, or S5500-D-G switch series.
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
The default settings vary by device model.
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100<Sysname> system-view
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is enabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries on forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
After you execute this command, the device collects consistency errors periodically. If the number of consistency errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
parity-error consistency-check period
Use parity-error consistency-check period to set the statistics period for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check period to restore the default.
parity-error consistency-check period value
The statistics period is 3600 seconds.
value: Specifies the statistics period (in seconds) for consistency errors between software and hardware forwarding entries, in the range of 600 to 31536000.
To forward packets, the device generates hardware forwarding entries in forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
This command determines the period for the device to collect consistency error statistics.
As a best practice, set the consistency error statistics period to a value greater than 3600 seconds.
# Set the statistics period to 600 seconds for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check period 600
Use parity-error consistency-check threshold to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check threshold to restore the default.
parity-error consistency-check threshold value
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 2147483647.
After you enable consistency error logging for software and hardware forwarding entries, the device collects statistics for consistency errors periodically. If the number of consistency errors reaches or exceeds the logging threshold, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error and ECC error logging for entries on forwarding chips.
Parity error and ECC error logging is enabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips.
After you execute this command, the device collects parity errors and ECC errors periodically. If the number of parity errors and ECC errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a parity error and ECC error log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable parity error and ECC error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error and ECC error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error and ECC error statistics period is 60 seconds for entries on forwarding chips.
period: Specifies the parity error and ECC error statistics period in seconds, in the range of 1 to 86400.
The device automatically detects parity errors and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold.
This command determines the period for the device to collect parity error and ECC error statistics.
# Set the parity error and ECC error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error and ECC error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
The parity error and ECC error logging threshold is 5000 for entries on forwarding chips.
value: Specifies the parity error and ECC error logging threshold for entries on forwarding chips, in the range of 1 to 1000000.
The device detects parity error and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold. This command sets the logging threshold.
# Set the parity error and ECC error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period is 60 seconds for uncorrectable parity errors and ECC errors for entries on forwarding chips.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips, in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can execute this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold is 1 for uncorrectable parity errors and ECC errors in entries on forwarding chips.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips, in the range of 1 to 1000000.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the master device and access the BootWare menu while it is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
push-button mode enable
Use push-button mode enable to enable special operations with the MODE button.
Use undo push-button mode enable to restore the default.
This command is available only on the devices that can be deployed in Cloudnet.
Special operations with the MODE button are disabled.
By default, you can use the MODE button on the front panel of the device in conjunction with the port LEDs to view the operating state of the ports from different perspectives.
The operations that the device performs depending on the duration of the press on the MODE button, as follows:
·     0 to 5 seconds—Changes the type of port information that the port LEDs are showing.
·     More than 5 seconds—Invalid instruction. The device does not perform any operations.
After you execute the push-button mode enable command, you can press the MODE button for different durations to perform the following operations:
·     Less than 5 seconds—Change the type of port information that the port LEDs are showing, which is the same as the default setting.
·     5 to 10 seconds—Add the device to Cloudnet for management. In this case, the device attempts to establish a connection with Cloudnet. If the Cloudnet management status LED flashes at 1 Hz in blue, the connection is being set up. After the connection is established, you can add the device to Cloudnet. If the device is added to Cloudnet successfully, the Cloudnet management status LED changes to steady blue. To disconnect the device from Cloudnet, press the MODE button for 5 to 10 seconds. Then, the Cloudnet management status LED turns off.
·     More than 10 seconds—No operation will be performed. To indicate that you have pressed MODE button for 10 seconds, the Cloudnet management status LED flashes once at 3 Hz in blue.
# Enable special operations with the MODE button.
[Sysname] push-button mode enable
reboot
Use reboot to reboot the device.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the IRF fabric has only one member device, rebooting the member device reboots the entire IRF fabric. If the IRF fabric has a subordinate member and the member is operating correctly, rebooting the master triggers a master/subordinate switchover.
To ensure correct operation of the IRF fabric and member devices, do not trigger a switchover by rebooting the master if no subordinate member devices are in Stable state. To view the status of subordinate member devices, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
display scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
This command is supported only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in Network Management and Monitoring Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 30 shows the resource types that can be monitored.
Table 30 Resource types that can be monitored
Resource type
agg_group
Aggregation group resources.
agg_member
Member ports in an aggregation group.
arp
ARP resources.
ecmpgroup
ECMP group resources.
egs_acl
Outbound ACL resources.
egs_counter
Outbound counter resources.
egs_meter
Outbound meter resources.
igs_acl
Intbound ACL resources.
igs_counter
Inbound counter resources.
igs_meter_0
Intbound meter resources.
input_flowrate
Inbound traffic flow rate resources
ipmc
Layer 3 multicast replication table resources.
ipv6
IPv6 routing table resources.
l2mc
Multicast replication table resources for a VLAN.
mac
MAC address table resources.
mqcin
Inbound MQC resources.
mqcout
Outbound MQC resources.
nd
ND resources.
nexthoppool1
Next-hop pool resources for the underlay network.
openflow
OpenFlow resources.
output_flowrate
Outbound traffic flow rate resources.
pbr
PBR resources.
pfilterin
Inbound packet filter resources.
pfilterout
Outbound packet filter resources.
route
Routing resources.
rport
Layer 3 Ethernet interface resources.
stg
STP instance resources.
vlaninterface
VLAN interface resources.
vrf
VPN instance resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command restores the device to the factory default settings. Before executing this command, make sure you understand its impact on the live network.
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
On a network enabled with loopback detection or STP, the device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysid
Use sysid to set the system ID.
Use undo sysid to restore the default.
sysid system-id
undo sysid
The device does not have a system ID.
system-id: Specifies the system ID for the device. You can use this argument to indicate the position or functionality of the device or any other information.
# Set the system ID of the device to position-hall.
[Sysname] sysid positon-hall
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently executed command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is executed most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver health check enable
Use transceiver health check enable to enable transceiver health check.
Use undo transceiver health check enable to restore the default.
Only the S5130S-HI-G or S5130S-EI-G-V2 switch series supports this command.
Transceiver health check is disabled.
# Enable transceiver health check.
[Sysname] transceiver health check enable
display transceiver health
transceiver health weight
Use transceiver health weight to set the weights for transceiver health calculation.
Use undo transceiver health weight to restore the default.
transceiver health weight temp temp-weight voltage voltage-weight bias bias-weight rxpower rxpower-weight txpower txpower-weight
The weights for calculating transceiver health are as follows:
·     Temperature weight: 15.
·     Voltage weight: 5.
·     Bias current weight: 30.
·     Receive power weight: 10.
·     Transmit power weight: 40.
temp temp-weight: Specifies the temperature weight in transceiver health calculation. The value range is 1 to 96.
voltage voltage-weight: Specifies the voltage weight in transceiver health calculation. The value range is 1 to 96.
bias bias-weight: Specifies the bias current weight in transceiver health calculation. The value range is 1 to 96.
rxpower rxpower-weight: Specifies the receive power weight in transceiver health calculation. The value range is 1 to 96.
txpower txpower-weight: Specifies the transmit power weight in transceiver health calculation. The value range is 1 to 96.
Use this command to set the weights of five diagnosis parameters for transceiver health calculation, including temperature, voltage, bias current, receive power, and transmit power.
The sum of the weight of each diagnosis parameter for transceiver health calculation must be 100.
# Set the weights of the temperature, voltage, bias current, receive power, and transmit power to 20.
[Sysname] transceiver health weight temp 20 voltage 20 bias 20 rxpower 20 txpower 20
transceiver monitor enable
Use transceiver monitor enable to enable transceiver monitoring.
Use undo transceiver monitor enable to restore the default.
Transceiver monitoring is disabled.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
# Enable transceiver monitoring.
[Sysname] transceiver monitor enable
transceiver monitor interval
Use transceiver monitor interval to set a transceiver monitoring interval.
Use undo transceiver monitor interval to restore the default.
transceiver monitor interval interval
The transceiver monitoring interval is 600 seconds.
interval: Specifies the transceiver monitoring interval in seconds. The value range is 300 to 3600.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log entry to notify users.
This command takes effect only when the transceiver monitor enable command is used.
# Set the transceiver monitoring interval to 500 seconds.
[Sysname] transceiver monitor interval 500
transceiver rx-power high-threshold
Use transceiver rx-power high-threshold to configure the high RX power threshold for a transceiver module.
Use undo transceiver rx-power high-threshold to restore the default.
transceiver rx-power high-threshold power-value
No high RX power threshold is set for a transceiver module.
Ethernet interface view
power-value: Specifies the high RX power threshold in dBm, accurate to 0.01 dBm. The value range for the power-value argument varies by transceiver module model.
Operating mechanism
You can execute the transceiver rx-power high-threshold command to configure the high RX power threshold for a transceiver module between the default high early-warning threshold and high alarm threshold. If the RX power of a transceiver module exceeds the user-defined threshold, the system generates an alarm message. For example, if the default high threshold range for a transceiver module is 3.00 to 5.00 dBm, you can set the high TX power threshold to 4.40 dBm.
To verify the alarm thresholds for a transceiver module, execute the display transceiver diagnosis command.
This command is available only for the SFP and SFP+ transceiver modules that support digital diagnosis and is not available for the 400G ZR, 400G ZR+, or fiber-to-copper transceiver modules.
If a transceiver module has multiple lanes, the configuration takes effect for all lanes.
# Set the high RX power threshold for the transceiver module in GigabitEthernet1/0/1 to 4.40 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver rx-power high-threshold 4.40
transceiver rx-power change-threshold
transceiver rx-power low-threshold
Use transceiver rx-power low-threshold to configure the low RX power threshold for a transceiver module.
Use undo transceiver rx-power low-threshold to restore the default.
transceiver rx-power low-threshold power-value
No low RX power threshold is set for a transceiver module.
Operating mechanism
You can execute the transceiver rx-power low-threshold command to configure the low RX power threshold for a transceiver module between the default low early-warning threshold and low alarm threshold. If the RX power of a transceiver module drops below the user-defined threshold, the system generates an alarm message. For example, if the default low threshold range for a transceiver module is –14.00 to –11.00 dBm, you can set the low RX power threshold to –13.00 dBm.
# Set the low RX power threshold for the transceiver module in GigabitEthernet1/0/1 to –13.00 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver rx-power low-threshold -13.00
Use transceiver rx-power change-threshold to configure the RX power change threshold for a transceiver module.
Use undo transceiver rx-power change-threshold to restore the default.
transceiver rx-power change-threshold power-value
The RX power change threshold for a transceiver module is 5.00 dBm.
power-value: Specifies the RX power change threshold in dBm, accurate to 0.01 dBm. The value range is 0 to 48.
Application scenarios
This command enables the device to monitor significant RX power changes on transceiver modules and generate alarm messages in time.
Operating mechanism
The device configures the initial RX optical power as the baseline for a transceiver module after the transceiver module starts up and operates correctly for the first time. After you execute the transceiver rx-power change-threshold command, the system checks the RX optical power of a transceiver module periodically. If an RX optical power change exceeds the user-defined threshold compared to the baseline, the system identifies it as a significant change and generates an alarm. Assume that the RX power change threshold is set to 20.00 dBm and the initial RX optical power after the link starts up and operates correctly is –15.00 dBm. If the RX optical power decreases to –36.00 dBm or increases to 6.00 dBm, an alarm will be triggered.
# Set the RX power change threshold for a transceiver module in GigabitEthernet1/0/1 to 4.00 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver rx-power change-threashold 4.00
transceiver tx-power high-threshold
Use transceiver rx-power high-threshold to configure the high TX power threshold for a transceiver module.
transceiver tx-power high-threshold power-value
undo transceiver tx-power high-threshold
No high TX power threshold is set for a transceiver module.
power-value: Specifies the high TX power threshold in dBm, accurate to 0.01 dBm.
Operating mechanism
You can execute the transceiver tx-power high-threshold command to configure the high TX power threshold for a transceiver module between the default high early-warning threshold and high alarm threshold. If the TX power of a transceiver module exceeds the user-defined threshold, the system generates an alarm message. For example, if the default high threshold range for a transceiver module is 3.00 to 5.00 dBm, you can set the high TX power threshold to 4.40 dBm.
# Set the high TX power threshold for the transceiver module in GigabitEthernet1/0/1to 4.40 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver tx-power high-threshold 4.40
transceiver tx-power change-threshold
transceiver tx-power low-threshold
Use transceiver tx-power low-threshold to configure the low TX power threshold for a transceiver module.
Use undo transceiver tx-power low-threshold to restore the default.
transceiver tx-power low-threshold power-value
No low TX power threshold is set for a transceiver module.
power-value: Specifies the low TX power threshold in dBm, accurate to 0.01 dBm.
Operating mechanism
You can execute the transceiver tx-power low-threshold command to configure the low TX power threshold for a transceiver module between the default low early-warning threshold and low alarm threshold. If the TX power of a transceiver module drops below the user-defined threshold, the system generates an alarm message. For example, if the default low threshold range for a transceiver module is –14.00 to –11.00 dBm, you can set the low RX power threshold to –13.00 dBm.
# Set the low TX power threshold for the transceiver module in GigabitEthernet1/0/1 to –13.00 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver tx-power low-threshold -13.00
Use transceiver tx-power change-threshold to configure the TX power change threshold for a transceiver module.
Use undo transceiver tx-power change-threshold to restore the default.
transceiver tx-power change-threshold power-value
The TX power change threshold for a transceiver module is 4.00 dBm.
power-value: Specifies the TX power change threshold in dBm, accurate to 0.01 dBm. The value range is 0 to 48.
This command enables the device to monitor significant TX power changes on transceiver modules and generate alarm messages in time.
Operating mechanism
The device configures the initial TX optical power as the baseline for a transceiver module after the transceiver module starts up and operates correctly for the first time. After you execute the transceiver tx-power change-threshold command, the system checks the TX optical power of a transceiver module periodically. If a TX optical power change exceeds the user-defined threshold compared to the baseline, the system identifies it as a significant change and generates an alarm. Assume that the TX power change threshold is set to 20.00 dBm and the initial TX optical power after the link starts up and operates correctly for the first time is –15.00 dBm. If the TX optical power decreases to –36.00 dBm or increases to 6.00 dBm, an alarm will be triggered.
# Set the TX power change threshold for a transceiver module in GigabitEthernet1/0/1 to 5.00 dBm.
[Sysname-GigabitEthernet1/0/1] transceiver tx-power change-threashold 5.00
usb disable
Use usb disable to disable USB interfaces.
Use undo usb disable to enable USB interfaces.
usb disable
undo usb disable
All USB interfaces are enabled.
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB file systems.
For more information about the umount command, see Fundamentals Command Reference.
# Enable USB interfaces.
[Sysname] undo usb disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
