01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5100[S5500]-D-G&S5130S-G[-V2] Command References-R8336Pxx-6W10001-Fundamentals Command Reference
11-Automatic configuration commands
11-Automatic configuration commands 70.46 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has a USB interface.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
display autodeploy status
Use display autodeploy status to display information about automatic configuration status.
Use this command to identify whether automatic configuration was performed at the last initial configuration startup and whether automatic configuration is enabled for the next startup.
# Display the status of system automatic configuration
<Sysname> display autodeploy status
Last startup autodeploy statusYes
Next startup autodeploy statusNo
Whether the system was automatically configured at the last initial configuration startup:
·     Yes.
·     No.
Whether the system will be automatically configured at the next startup:
·     Yes.
·     No.
