08-MPLS
HomeSupportRouters5G IPRAN Access RoutersDiagnose & MaintainAlarms ReferencesH3C RA5300[RA5100-G] Routers Alarm Reference-R7752-6W10008-MPLS
11-MPLS-TE-STD-MIB
11-MPLS-TE-STD-MIB 81.37 KB
MPLS-TE-STD-MIB
About this MIB
MPLS-TE-STD-MIB is a standard MIB based on RFC 3812.
Network congestion can degrade the network backbone performance. It might occur when network resources are inadequate or when load distribution is unbalanced. Traffic engineering (TE) is intended to avoid the latter situation where partial congestion might occur because of improper resource allocation.
TE can make the best use of network resources and avoid uneven load distribution by using the following functionalities:
·     Real-time monitoring of traffic and traffic load on network elements.
·     Dynamic tuning of traffic management attributes, routing parameters, and resources constraints.
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
With MPLS TE, a service provider can deploy traffic engineering on the existing MPLS backbone to provide various services and optimize network resources management.
MIB file name
rfc3812-mpls-te-std.mib
Notifications
mplsTunnelUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.3.0.1
A tunnel comes up.
Recovery
Warning
N/A
ON
Notification triggers
This notification is generated when the operational state (indicated by the mplsTunnelOperStatus object) of a tunnel changes from down to another value (except for notPresent).
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.10.166.3.2.2.1.34
 (mplsTunnelAdminStatus)
Administrative state of the tunnel.
mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, mplsTunnelEgressLSRId
INTEGER
up(1)
down(2)
testing(3)
1.3.6.1.2.1.10.166.3.2.2.1.35
(mplsTunnelOperStatus)
Actual state of the tunnel.
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
No action is required.
mplsTunnelDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.3.0.2
The operation state of a tunnel becomes down.
Error
Major
N/A
ON
For all types of tunnels, possible reasons for this notification include the following:
·     The interface went Down.
·     The configuration of the tunnel was deleted.
·     The link was faulty.
·     The tunnel was manually shut down.
·     Others
For RSVP-TE tunnels, possible reasons for this notification also include the following:
·     RSVP-TE LSP resources were preempted.
·     Transmission of an RSVP message timed out.
·     RSVP Hello mechanism detected a downstream node failure.
·     CSPF failed to calculate a path.
For Segment Routing TE tunnels, possible reasons for this notification also include the following:
·     IGP calculation or verification failed.
For static TE tunnels, possible reasons for this notification also include:
·     A static CR-LSP went Down.
·     A static SR-LSP went Down.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
INTEGER
up(1)
down(2)
testing(3)
Operational state of the tunnel.
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
To resolve this issue:
1.     Check the current tunnel interface configuration, IGP configuration, and the whole tunnel path.
¡     If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
-     If yes, clear link faults.
-     If no, execute step 2 or 3 according to the tunnel type.
¡     If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2 or 3 according to the tunnel type.
2.     For an RSVP-TE tunnel, check whether the RSVP protocol, link bandwidth, and link affinity settings are correct.
¡     If the settings are correct but the issue persists, go to step 4.
¡     If the settings are not correct, edit the related configuration.
3.     For a static MPLS TE tunnel, check whether static CRLSP or SRLSP settings are correct.
4.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
mplsTunnelRerouted
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.3.0.3
A tunnel is rerouted.
Informational
Warning
N/A
ON
This notification is generated when a tunnel is rerouted because of the current path used by the tunnel is unreachable. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
INTEGER
up(1)
down(2)
testing(3)
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
