08-MPLS
HomeSupportRouters5G IPRAN Access RoutersDiagnose & MaintainAlarms ReferencesH3C RA5300[RA5100-G] Routers Alarm Reference-R7752-6W10008-MPLS
04-HH3C-MPLSEXT-MIB
04-HH3C-MPLSEXT-MIB 112.00 KB
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
hh3c-mplsext.mib
Notifications
hh3cMplsExtLabThreExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.142.0.1
The MPLS LSM label usage reached the upper threshold.
Error
Warning
1.3.6.1.4.1.25506.2.142.0.2
(hh3cMplsExtLabThreExceedClear)
OFF
Notification triggers
This notification is generated when the usage of a type of MPLS labels reaches the upper threshold.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private [ label-threshold | label-total | tunnel-to-vpn | slsp-up-down ]* command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private [ label-threshold | label-total | tunnel-to-vpn | slsp-up-down ]* command.
Objects
OID (object name)
Index nodes
Value range
hh3cMplsExtLabelInfo (1.3.6.1.4.1.25506.2.142.1.1.3)
MPLS label information.
N/A
OCTET STRING
As per the MIB.
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
MPLS LSM label usage dropped below the lower threshold.
Recovery
N/A
N/A
OFF
This notification is generated when the usage of a type of MPLS labels drops below the lower threshold.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsExtLabTotExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.142.0.3
MPLS LSM labels are used up.
Error
Major
1.3.6.1.4.1.25506.2.142.0.4
(hh3cMplsExtLabTotExceedClear)
OFF
This notification is generated when the usage of a type of MPLS labels reaches 100%.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
The MPLS LSM label usage dropped to the specified value.
Recovery
N/A
N/A
OFF
This notification is generated when the MPLS LSM label usage drops to the specified value, which is 95%.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsExtTnlToVpnEvent
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.142.0.5
The tunnel selected for the VPN changed.
Recovery
Major
N/A
OFF
This notification is generated when the selected tunnel for the VPN changes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cMplsExtTnlToVpnInfo (1.3.6.1.4.1.25506.2.142.1.1.4)
Tunnel policy information
N/A
OCTET STRING
As per the MIB.
Recommended action
