03-HH3C-MPLS-LDP-MIB | 55.27 KB |
HH3C-MPLS-LDP-MIB
About this MIB
This MIB contains MPLS LDP notifications.
MIB file name
hh3c-mpls-ldp.mib
Notifications
hh3cMplsLdpMulLinkCfgInc
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.12.2.2.0.17 |
LDP multi-link configuration inconsistency |
Error |
Major |
1.3.6.1.4.1.25506.8.12.2.2.0.18 (hh3cMplsLdpMulLinkCfgIncClear) |
OFF |
Notification triggers
If multiple links exist between LDP peers, the system compares the LDP parameters configured on the interfaces of the links and the targeted peer with the LDP parameters negotiated. If the LDP parameter settings are inconsistent, the system generates a notification.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable ldp-private command.
OFF
CLI: undo snmp-agent trap enable ldp-private command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
hh3cMplsLdpCfgInfo (1.3.6.1.4.1.25506.8.12.2.3.1) |
LDP configuration information |
N/A |
OCTET STRING |
As per the MIB. |
hh3cMplsLdpSessInfo (1.3.6.1.4.1.25506.8.12.2.3.2) |
LDP session information |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
1. Check whether the keepalive-hold value configured in interface view or LDP peer view (targeted-peer) is consistent with that selected after the LDP session negotiation. If they are inconsistent, change the keepalive-hold setting on the interfaces or targeted-peer to the negotiated value.
2. Check whether the transport-address value configured in interface view or LDP peer view (targeted-peer) is consistent with that selected after the LDP session negotiation. If they are inconsistent, change the transport-address setting on the interfaces or targeted-peer to the negotiated value.
3. If the issue persists, contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.12.2.2.0.18 |
LDP multi-link configuration inconsistency cleared |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the LDP multi-link configuration inconsistency is removed.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
