07-HH3C-TRAP-MIB | 45.73 KB |
HH3C-TRAP-MIB
About this MIB
Use this MIB to enable the device to send a notification to a network management station when a specific event occurs, such as a MAC address table getting full.
MIB file name
hh3c-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTrap(38)
Tabular objects
hh3cTrapDesInfoTable
About this table
Use this table to configure a trap destination host address and port number.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cTrapDesInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTrapDesInfoIndex (1.3.6.1.4.1.25506.2.38.1.7.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..20) |
Index nodes of a trap destination information entry. |
As per the MIB. |
hh3cTrapDesIPAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.2) |
read-create |
IpAddress |
Standard MIB values |
Trap destination host IP address. |
As per the MIB. |
hh3cTrapDesPort (1.3.6.1.4.1.25506.2.38.1.7.1.1.3) |
read-create |
Integer32 |
Integer32 (0..65535) |
Trap destination port number. |
As per the MIB. |
hh3cTrapDesRowStatus (1.3.6.1.4.1.25506.2.38.1.7.1.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cTrapDesAddrTAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.5) |
read-create |
TAddress |
Transport address. |
As per the MIB. |
