02-HH3C-COMMON-SYSTEM-MIB | 70.53 KB |
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
hh3cReboot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cReboot (1.3.6.1.4.1.25506.6.7) |
read-write |
INTEGER |
normal(0), reboot(1) |
Reboots the device. |
As per the MIB. |
hh3cSysBootType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBootType (1.3.6.1.4.1.25506.6.10) |
read-only |
INTEGER |
coldStart(1), warmStart(2) |
Boot mode of the system. |
Not supported. |
hh3cSysFirstTrapTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysFirstTrapTime (1.3.6.1.4.1.25506.6.11.10) |
accessible-for-notify |
Timeticks |
Standard MIB values. |
Time when a trap is sent for the first time. |
Not supported. |
hh3cSysBannerMOTD
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11) |
read-write |
OCTETSTRING |
OCTET STRING (0..2000) |
Banner message. |
As per the MIB. |
Tabular objects
hh3cSystemDiagInfoTable
About this table
This table creates diagnosis files for the system.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemDiagInfoIndex (1.3.6.1.4.1.25506.6.13.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Entry index. |
As per the MIB. |
hh3cSystemDiagInfoFilename (1.3.6.1.4.1.25506.6.13.1.2) |
read-create |
DisplayString |
OCTET STRING (0..255) |
Diagnosis file name. |
As per the MIB. The system uses the default file name if you do not specify a file name during row creation. |
hh3cSystemDiagInfoRowStatus (1.3.6.1.4.1.25506.6.13.1.3) |
read-create |
RowStatus |
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6) |
Row status. |
As per the MIB. |
hh3cSystemDiagInfoOperEndTime(1.3.6.1.4.1.25506.6.13.1.4) |
read-only |
TimeStamp |
Time when the operation was completed. |
As per the MIB. |
hh3cSystemDiagInfoOperState (1.3.6.1.4.1.25506.6.13.1.5) |
read-only |
INTEGER |
opInProgress(1),opSuccess(2),opFailure(3) |
Operation status. |
As per the MIB. |
hh3cSystemDiagInfoOperFailReason (1.3.6.1.4.1.25506.6.13.1.6) |
read-only |
DisplayString |
Failure reason. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-COMMON-SYSTEM-MIB module.
hh3cRebootSendTrap
Basic information
OID (object name) |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.6.8.3 |
The device is to reboot |
Informational |
Major |
N/A |
ON |
Notification triggers
This notification is generated two seconds before the reboot command is used to reboot the device.
System impact
The system will stop providing services and restart.
Status control
This notification cannot be disabled.
Objects
N/A
Recommended action
No action is required.
hh3cSysDyingGaspTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.7 |
Poweroff alarm |
Informational |
Critical |
N/A |
ON |
This notification is generated when the device is powered off.
System impact
The system will be powered off and stop providing services.
Status control
Objects
N/A
Recommended action
Verify that the power cord is connected correctly.
