03-Device Management
HomeSupportRouters5G IPRAN Access RoutersReference GuidesMIB CompanionH3C RA5300[RA5100-G] Routers MIB Reference-R7752-6W10003-Device Management
06-HH3C-TRANSCEIVER-INFO-MIB
06-HH3C-TRANSCEIVER-INFO-MIB 94.17 KB
About this MIB
Use this MIB to obtain information about transceiver modules, including vendor information and physical transmission characteristics.
MIB file name
hh3c-transceiver-info.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTransceiver(70)
Tabular objects
hh3cTransceiverInfoTable
About this table
Use this table to obtain or edit information about transceiver modules.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverHardwareType (1.3.6.1.4.1.25506.2.70.1.1.1.1)
read-only
OCTET STRING
Standard MIB values.
Hardware type of the transceiver module, such as single mode (SM).
As per the MIB.
hh3cTransceiverType (1.3.6.1.4.1.25506.2.70.1.1.1.2)
read-only
OCTET STRING
Type of the transceiver module, such as SFP.
As per the MIB.
hh3cTransceiverWaveLength (1.3.6.1.4.1.25506.2.70.1.1.1.3)
read-only
Integer32
Wavelength of the transceiver module, in nm.
As per the MIB.
hh3cTransceiverVendorName (1.3.6.1.4.1.25506.2.70.1.1.1.4)
read-only
OCTET STRING
Vendor name of the transceiver module.
As per the MIB.
hh3cTransceiverSerialNumber (1.3.6.1.4.1.25506.2.70.1.1.1.5)
read-only
OCTET STRING
Serial number of the transceiver module.
As per the MIB.
hh3cTransceiverFiberDiameterType (1.3.6.1.4.1.25506.2.70.1.1.1.6)
read-only
INTEGER
fiber9(1),
fiber50(2),
fiber625(3),
copper(4),
unknown(65535)
Fiber diameter for the transceiver module, in microns (μm).
As per the MIB.
hh3cTransceiverTransferDistance (1.3.6.1.4.1.25506.2.70.1.1.1.7)
read-only
Integer32
Maximum transmission distance of the transceiver module, in meters.
As per the MIB.
hh3cTransceiverDiagnostic (1.3.6.1.4.1.25506.2.70.1.1.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the transceiver module supports digital diagnosis.
As per the MIB.
hh3cTransceiverCurTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.9)
read-only
Integer32
Current transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
The object returns 2147483647 when read if the device does not support this parameter.
hh3cTransceiverMaxTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.10)
read-only
Integer32
Maximum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.11)
read-only
Integer32
Minimum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverCurRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.12)
read-only
Integer32
Current receive power in dBm of the transceiver module, accurate to 0.01 dBm.
hh3cTransceiverMaxRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.13)
read-only
Integer32
Maximum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.14)
read-only
Integer32
Minimum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverTemperature (1.3.6.1.4.1.25506.2.70.1.1.1.15)
read-only
Integer32
Current temperature of the transceiver module, in °C.
As per the MIB.
hh3cTransceiverVoltage (1.3.6.1.4.1.25506.2.70.1.1.1.16)
read-only
Integer32
Current voltage of the transceiver module, in V, accurate to 0.01 V.
As per the MIB.
hh3cTransceiverBiasCurrent (1.3.6.1.4.1.25506.2.70.1.1.1.17)
read-only
Integer32
Current bias current of the transceiver module, in mA, accurate to 0.01 mA.
As per the MIB.
hh3cTransceiverTempHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.18)
read-only
Integer32
High temperature alarm threshold in °C, accurate to 0.001 °C , for example, 49120 representing 49.120 °C
As per the MIB.
hh3cTransceiverTempLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.19)
read-only
Integer32
Low temperature alarm threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.20)
read-only
Integer32
High temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.21)
read-only
Integer32
Low temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverVccHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.22)
read-only
Integer32
High voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
This object returns 0 when read if the transceiver module does not support this parameter.
hh3cTransceiverVccLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.23)
read-only
Integer32
Low voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.24)
read-only
Integer32
High voltage warning threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.25)
read-only
Integer32
Low voltage warning threshold in mV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverBiasHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.26)
read-only
Integer32
High bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.27)
read-only
Integer32
Low bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.28)
read-only
Integer32
High bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.29)
read-only
Integer32
Low bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverPwrOutHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.30)
read-only
Integer32
High transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.31)
read-only
Integer32
Low transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.32)
read-only
Integer32
High transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.33)
read-only
Integer32
Low transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.34)
read-only
Integer32
High receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.35)
read-only
Integer32
Low receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.36)
read-only
Integer32
High receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.37)
read-only
Integer32
Low receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverErrors (1.3.6.1.4.1.25506.2.70.1.1.1.38)
read-only
BITS
BITS {
xcvrIOError(0),
xcvrChecksum(1),
xcvrTypeAndPortConfigMismatch(2),
xcvrTypeNotSupported(3),
wisLocalFault(4),
rcvOpticalPowerFault(5),
pmapmdReceiverLocalFault(6),
pcsReceiveLocalFault(7),
phyXSReceiveLocalFault(8),
laserBiasCurrentFault(9),
laserTemperatureFault(10),
laserOutputPowerFault(11),
txFault(12),
pmapmdTransmitterLocalFault(13),
pcsTransmitLocalFault(14),
phyXSTransmitLocalFault(15),
rxLossOfSignal(16),
tecError(17),
wavelengthUnlocked(18),
txIsNotReadyDueToTuning(19) ,
Unused(20-31)
Error information about the transceiver module.
As per the MIB.
hh3cTransceiverVendorOUI (1.3.6.1.4.1.25506.2.70.1.1.1.39)
read-only
SnmpAdminString
OCTET STRING (0..255)
Vendor OUI of the transceiver module.
As per the MIB.
hh3cTransceiverRevisionNumber (1.3.6.1.4.1.25506.2.70.1.1.1.40)
read-only
SnmpAdminString
Revision number of the transceiver module.
As per the MIB.
hh3cTransceiverFrequency (1.3.6.1.4.1.25506.2.70.1.1.1.41)
read-only
Integer32
Frequency of the transceiver module, in THz, accurate to 0.01 THz.
Not supported.
hh3cTransceiverActiveITUChannel (1.3.6.1.4.1.25506.2.70.1.1.1.42)
read-write
Unsigned32
Unsigned32 (1.. 4294967295)
Index of the current ITU channel.
Not supported.
hh3cTransceiverPartNumber (1.3.6.1.4.1.25506.2.70.1.1.1.49)
read-only
OCTET STRING
Part number of the transceiver module.
Not supported.
hh3cTransceiverProductCode (1.3.6.1.4.1.25506.2.70.1.1.1.50)
read-only
OCTET STRING
Product code of the transceiver module.
Not supported.
hh3cTransceiverOriginalSN (1.3.6.1.4.1.25506.2.70.1.1.1.51)
read-only
OCTET STRING
Original serial number of the transceiver module.
Not supported.
