H3C UniServer R4950 G7 Server User Guide-6W100
HomeSupportServersH3C UniServer R4950 G7Technical DocumentsInstall & UpgradeInstallation GuidesH3C UniServer R4950 G7 Server User Guide-6W100
02-Appendix A Support Information
02-Appendix A Support Information 172.28 KB
Support information
Technical support
To resolve issues during routine maintenance or troubleshooting, contact Technical Support.
Collecting information
To facilitate troubleshooting, collect the following server information before contacting Technical Support:
·     Log information and sensor information.
¡     Log information , including the following:
-     Event log, operation log, and SDS log on HDM.
-     Diagnosis information in iFIST.
¡     Sensor information on HDM.
·     Product serial number.
·     Product model and name.
·     Error information screenshots and description.
·     Hardware change records, including adding, replacing, or re-installing hardware components.
·     Third-party software.
·     Operating system type and version.
Preparing maintenance tools
To facilitate troubleshooting, prepare the following tools: For more information about these tools, see "Installation tools."
·     T-25, T-15, and T-10 Torx screwdrivers.
·     T30 Torx screwdriver.
·     Flat-head screwdriver and Phillips screwdriver.
·     Cage nut insertion/extraction tool
·     Diagonal pliers.
·     Multimeter.
·     Interface cable (such as an Ethernet cable or optical fiber).
·     Monitor (such as PC)
·     ESD wrist strap, antistatic gloves, and antistatic clothing.
Obtaining the most recent firmware or software
To obtain the most recent firmware or software, access https://www.h3c.com/en/BizPortal/DownLoadAccessory/en_DownLoadAccessoryFilt.aspx.
Product security and compatibility
For information about the product security and compatibility, see the security and compatibility manual for the server.
Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Glossary
Item
B
BIOS
The Basic Input Output System (BIOS) is a collection of programs stored on a ROM chip on the server motherboard. It includes critical components such as the Basic Input Output Program, Power-On Self-Test (POST), and system startup programs. The BIOS provides the most fundamental and direct hardware settings and controls for the computer.
C
CPLD
Complex Programmable Logic Device (CPLD) is a type of digital integrated circuit that can construct logic functions according to requirements.
G
GPU
A GPU is one of the most important components of a server. It is used to convert digital signals from the server into analog signals, which are then displayed on a monitor. Additionally, a GPU has image processing capabilities and can assist CPUs in tasks, thereby enhancing the overall operational speed of the server.
H
HDM
Hardware Device Management (HDM) is a control unit used for server management. Through HDM, you can simplify the server configuration process, view server component information, monitor server operation status, and remotely control the server, among other functions.
Hot swapping
Hot swapping capability refers to the ability to remove or install a component in a server while the server is running, without the need to power down the server. This operation does not disrupt the running system and avoids any impact on its operation.
K
KVM device
A Keyboard, Video, Mouse (KVM) device is a physical device that allows you to monitor and manage multiple servers using a single set of keyboard, display, and mouse.
N
Network adapter
A network adapter is a network component that operates at the data link layer. It not only establishes a physical connection and electrical signal matching between the LAN transmission media but also provides functions such as frame transmission and reception, frame encapsulation and decapsulation, medium access control, data encoding and decoding, and data caching.
NVMe VROC module
Used to activate and achieve the RAID capabilities of NVMe drives in conjunction with the VMD technology.
R
RAID
Redundant Array of Independent Disks (RAID) is a technology used for combining multiple independent physical drives in different ways to create a disk array, providing higher storage performance and data security than a single drive.
Redundancy
Redundancy means that when a component, such as a fan, fails, the system can automatically utilize a backup component to replace the failed one.
T
Temperature sensor
A temperature sensor is used to detect the temperature at a specific location and transmits temperature information to the server system.
U
U
The IEC 60297-1 standard specifies the units of vertical height measurement for racks and enclosures in the form of "U" or "RU" (rack unit), , where 1 U or 1 RU is equivalent to 44.45 mm (1.75 in).
UniBay drive backplane
A UniBay drive backplane is a backplane that supports SAS/SATA/NVMe drives.
UniSystem
UniSystem is a software program developed by H3C for server management. It allows for quick and flexible server configurations and intelligent guidance for users. With FIST, users can even develop their own tools. It is an intelligent and scalable server management tool.
V
VMD
The VMD technology provides hot-swapping capability, drive management, and fault tolerance features for NVMe drives, making them reliable, available, and serviceable.
Acronyms
Acronym
Full name
B
BIOS
C
CMA
Cable Management Arm
CPLD
CPU
Central Processing Unit
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual Inline Memory Module
DRAM
Dynamic Random Access Memory
DVD
Digital Versatile Disc
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
K
KVM
L
LRDIMM
Load Reduced Dual Inline Memory Module
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
POST
Power-on Self Test
R
RAID
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
sLOM
Small form factor Local Area Network on Motherboard
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
