H3C UniServer R4950 G7 Server User Guide-6W100
HomeSupportServersH3C UniServer R4950 G7Technical DocumentsInstall & UpgradeInstallation GuidesH3C UniServer R4950 G7 Server User Guide-6W100
00-Preface
00-Preface 139.93 KB
Preface
The H3C UniServer R4950 G7 server user guide contains the following chapters:
·     Chapter 1 Safety infomration
Introduces safety information, precautions, ESD protection, and safety identifiers on the device.
·     Chapter 2 Identifying the server
Introduces the appearance, specifications, parts, panels, LEDs, and various interfaces of the server.
·     Chapter 3 Installing or removing the server
Introduces how to install and remove the server, including the installation process, installation planning, optimal environment, tool preparation, and external cable connections.
·     Chapter 4 Powering on and powering off the server
Introduces methods to power on and power off the server.
·     Chapter 5 Configuring the server
Introduces the process of software configuration for the server after installation and initial power-on.
·     Chapter 6 Replacing hardware options
Introduces the replaceable parts of the server, as well as detailed steps for part replacement.
·     Chapter 7 Connecting internal cables
Introduces the internal cable connection methods for server parts.
·     Chapter 8 Maintenance
Introduces the daily maintenance methods for the server.
·     Appendixes
Introduces the part specifications of the server, the operating ambient temperature specifications, help information, product recycling information, terms and acronyms, and managed hot swapping of OCP network adapters.
·     Drive Slot Number Mapping Matrixes
Provides users with procedures to identify the mapping relationship between physical slot numbers on the server and the slot numbers displayed in software (HDM and BIOS).
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners.
·     Administrators working with the server.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
