04-Network Connectivity Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10004-Network Connectivity Command Reference
19-IPv6 static routing commands
19-IPv6 static routing commands 83.29 KB
display ipv6 routing-table
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ verbose ]
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3        Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Destination: FF00::/8                                    Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Next hop address of the route.
Preference
Preference of the route.
Output interface for packets to be forwarded along the route.
Protocol
Protocol that installed the route.
Cost
Cost of the route.
# Display detailed information about all routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table verbose
Destinations : 2 Routes : 2
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 19h23m02s
        Cost: 0                  Preference: 0
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active NoAdv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0xa                    OrigAs: 0
       NibID: 0x20000000             LastAs: 0
      AttrID: 0xffffffff           Neighbor: ::
       Flags: 0x10004           OrigNextHop: ::1
       Label: NULL              RealNextHop: ::1
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: InLoopBack0
   BkSRLabel: NULL              BkInterface: N/A
    SIDIndex: NULL                  InLabel: NULL
   Tunnel ID: Invalid           IPInterface: InLoopBack0
 BkTunnel ID: Invalid         BkIPInterface: N/A
    FtnIndex: 0x0            ColorInterface: N/A
TrafficIndex: N/A          BkColorInterface: N/A
   Connector: N/A                 VpnPeerId: N/A
        Dscp: N/A                       Exp: N/A
  SRTunnelID: Invalid             StatFlags: 0x0
    SID Type: N/A                       SID: N/A
       BkSID: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid                PathID: 0x0
CommBlockLen: 0
  OrigLinkID: 0x0                RealLinkID: 0x0
Destination: 12::/96
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h01m47s
         Tag: 0                       State: Active Adv
       NibID: 0x20000003             LastAs: 0
       Flags: 0x10080           OrigNextHop: ::
     SRLabel: NULL                Interface: Vlan-interface11
   Tunnel ID: Invalid           IPInterface: Vlan-interface11
        Dscp: N/A                       Exp: N/A
CommBlockLen: 0
Destination
Protocol
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route status:
·     Active—Active unicast route.
·     Adv—Route that can be advertised.
·     Inactive—Inactive route.
·     NoAdv—Route that the router must not advertise.
·     Vrrp—Routes generated by VRRP.  This state is not supported in the current software version.
·     Nat—Routes generated by NAT. This state is not supported in the current software version.
·     TunE—Tunnel. This state is not supported in the current software version.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN instance that the route belongs to. This field displays default-vrf if the route is on the public network.
TableID
ID of the routing table.
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
Label
Label of the route.
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
SRLabel
SR label.
BkSRLabel
Backup SR label.
BkInterface
Backup output interface.
SIDIndex
SID index value.
InLabel
Incoming label of the route.
Tunnel ID
Tunnel ID.
IPInterface
IP output interface.
BkTunnel ID
Backup tunnel ID.
BkIPInterface
Backup IP output interface.
FtnIndex
Index of the FTN entry.
ColorInterface
Output interface recursed by an SR-MPLS TE policy or SRv6 TE policy.
BkColorInterface
Backup output interface recursed by an SR-MPLS TE policy or SRv6 TE policy.
TrafficIndex
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid.
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported.
VpnPeerId
ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid.
Dscp
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid.
Exp
MPLS EXP value of the route, which is supported only by BGP. This field displays N/A when the value is invalid.
Summary count
Number of routes.
SRTunnelID
SR tunnel ID.
StatFlags
Flags for SRv6 traffic statistics.
SID Type
SID type. If the route does not have an SID, this field displays N/A.
SID
Primary Segment Identifier (SID).
If no primary SID is available, this field displays N/A.
BkSID
Backup SID.
If no backup SID is available, this field displays N/A.
NID
Index of the Next Hop Label Forwarding Entry (NHLFE) flushed by the routing protocol.
FlushNID
Index of the NHLFE flushed to the FIB.
BkNID
Index of the backup NHLFE flushed by the routing protocol.
BkFlushNID
Index of the backup NHLFE flushed to the FIB.
PathID
Path ID.
CommBlockLen
Common prefix length in the locator.
OrigLinkID
Original link ID of the SDWAN TTE connection.
RealLinkID
Real link ID of the SDWAN TTE connection.
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number | next-hop-address } [ preference preference ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number | next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. Only Null 0 is supported.
next-hop-address: Specifies the next hop IPv6 address.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
