04-Network Connectivity Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10004-Network Connectivity Command Reference
09-PPP commands
09-PPP commands 82.16 KB
PPPoE commands
PPPoE client commands
dialer bundle enable
Use dialer bundle enable to enable bundle DDR on a dialer interface.
Use undo dialer bundle enable to disable bundle DDR on a dialer interface.
Bundle DDR is disabled on a dialer interface.
Dialer interface view
DDR includes traditional DDR and bundle DDR.
Before using bundle DDR, use this command to enable bundle DDR on a dialer interface. Then assign physical interfaces to the corresponding dialer bundle by using the dialer bundle-member command. To enable bundle DDR to receive calls, configure the dialer peer-name command on the dialer interface.
After you configure this command on a dialer interface already enabled with traditional DDR, the system clears the original traditional DDR settings.
The undo dialer bundle enable command clears all bundle DDR settings on the dialer interface.
# Enable bundle DDR on Dialer 1.
[Sysname] interface dialer 1
[Sysname-Dialer1] dialer bundle enable
dialer diagnose
Use dialer diagnose to configure DDR to operate in diagnostic mode.
Use undo dialer diagnose to restore the default.
dialer diagnose [ interval interval ]
DDR operates in non-diagnostic mode.
interval: Specifies the diagnostic interval in the range of 5 to 65535 seconds. The default is 120 seconds.
Operating mechanism
In diagnostic mode, the device performs the following operations:
·     Dials a PPPoE connection immediately after the device configurations are complete.
·     Automatically terminates the connection.
·     Starts the auto-dial timer after a configurable diagnostic interval.
·     Redials a connection when the auto-dial timer expires.
By establishing and terminating PPPoE sessions periodically, you can monitor the operating status of the PPPoE link.
This command takes effect only when a dialer interface is used for PPPoE client applications.
In diagnostic mode, the link idle-timeout timer is ignored.
# Configure Dialer 1 to operate in diagnostic mode, with a diagnostic interval of 300 seconds.
[Sysname-Dialer1] dialer diagnose interval 300
dialer timer autodial
dialer timer idle
display pppoe-client session packet
Use display pppoe-client session packet to display the protocol packet statistics for a PPPoE session.
display pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023.   If you do not specify this option, the command displays the protocol packet statistics for all PPPoE sessions.
To display the data packet statistics for a PPPoE session, use the display interface virtual-access command to display information about the specified VA interface.
# Display the protocol packet statistics for all PPPoE sessions.
<Sysname> display pppoe-client session packet
Bundle:    1                     Interface:  Vlan10
InPackets: 19                    OutPackets: 19
InBytes:   816                   OutBytes:   816
InDrops:   0                     OutDrops:   0
Bundle:    2                     Interface:  Vlan10
InPackets: 18                    OutPackets: 18
InBytes:   730                   OutBytes:   730
Bundle
Dialer bundle to which a PPPoE session belongs.
Ethernet interface where the PPPoE session is present.
InPackets
Number of packets received.
OutPackets
Number of packets transmitted.
InBytes
Number of bytes received.
OutBytes
Number of bytes transmitted.
InDrops
Number of discarded incoming packets.
OutDrops
Number of discarded outgoing packets.
reset pppoe-client session packet
display pppoe-client session summary
Use display pppoe-client session summary to display summary PPPoE session information.
display pppoe-client session summary [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023. If you do not specify this option, the command displays summary information for all PPPoE sessions.
# Display summary information for all PPPoE sessions.
<Sysname> display pppoe-client session summary
Bundle ID    Interface    VA          RemoteMAC      LocalMAC       State
1      1     GE1/0/1      VA0         00e0-1400-4300 00e0-1500-4100 SESSION
2      1     GE1/0/2      VA1         00e0-1500-4300 00e0-1600-4100 SESSION
Bundle
Dialer bundle to which the PPPoE session belongs.
VA
Virtual access interface created for the PPPoE session.
RemoteMAC
MAC address of the remote end.
LocalMAC
MAC address of the local end.
PPPoE session state:
·     IDLE—Initialization state.
·     PADI SENT—A PPPoE Active Discovery Initiation (PADI) packet has been sent, and a PPPoE Active Discovery Offer (PADO) packet is being expected.
·     PADR SENT—A PPPoE Active Discovery Request (PADR) packet has been sent, and a PPPoE Active Discovery Session-confirmation (PADS) packet is being expected.
·     SESSION—The PPPoE session has been successfully established.
mtu
Use mtu to set the maximum transmission unit (MTU) of a dialer interface.
mtu size
undo mtu
The MTU of dialer interfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range for this argument is 128 to 1500.
The MTU setting of a dialer interface affects the fragmentation and reassembly of IP packets.
# Set the MTU of Dialer 1 to 1200 bytes.
[Sysname-Dialer1] mtu 1200
pppoe-client
Use pppoe-client to establish a PPPoE session and specify the dialer bundle corresponding to the session.
Use undo pppoe-client to remove a PPPoE session.
pppoe-client dial-bundle-number number [ no-hostuniq ]
undo pppoe-client dial-bundle-number number
No PPPoE session is established.
VLAN interface view
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. A dialer bundle number uniquely identifies a PPPoE session. It can also be used as a PPPoE session ID. The value range for the number argument is 0 to 1023.
no-hostuniq: Configures the client not to carry the Host-Uniq field in discovery packets. If you do not specify this keyword, the client carries the Host-Unique field. The Host-Unique field uniquely identifies a PPPoE client when an interface is configured with multiple PPPoE sessions. When the PPPoE server receives a packet with this field, it must include this field unmodified in the response packet. The device identifies the PPPoE client where the response packet belongs based on the Host-Unique field in the response packet.
# Establish a PPPoE session on VLAN-Interface 1.
[Sysname-Vlan-interface1] pppoe-client dial-bundle-number 1
reset pppoe-client
Use reset pppoe-client to reset a PPPoE session corresponding to a dialer bundle.
reset pppoe-client { all | dial-bundle-number number }
all: Resets all the PPPoE sessions.
dial-bundle-number number: Specifies a dialer bundle by its number. The value range for the number argument is 0 to 1023.
A PPPoE session in permanent mode and terminated by this command will be established again when the auto dial timer expires.
A PPPoE session in on-demand mode and terminated by this command will be established again only when there is a need for data transmission.
# Reset all PPPoE sessions.
<Sysname> reset pppoe-client all
Use reset pppoe-client session packet to reset the protocol packet statistics for a PPPoE session.
reset pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023. If you do not specify this option, the command resets the protocol packet statistics for all PPPoE sessions.
# Reset the protocol packet statistics for all PPPoE sessions.
<Sysname> reset pppoe-client session packet
