04-Network Connectivity Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10004-Network Connectivity Command Reference
14-DNS commands
14-DNS commands 164.90 KB
DNS commands
display dns domain
Use display dns domain to display the domain name suffixes.
display dns domain [ dynamic ]
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained domain name suffixes.
# Display the statically configured and dynamically obtained domain name suffixes for the public network.
<Sysname> display dns domain
Type:
  D: Dynamic    S: Static
No.    Type   Domain suffix
1      S      com
2      D      net
No.
Sequence number.
Domain name suffix type:
·     S—A statically configured domain name suffix.
·     D—A domain name suffix dynamically obtained through DHCP or other protocols. ‌
Domain suffix
Domain name suffixes.
dns domain
display dns host
Use display dns host to display information about domain name-to-IP address mappings.
display dns host [ ip | ipv6 ]
ip: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address.
If you do not specify the ip or ipv6 keyword, this command displays domain name-to-IP address mappings of both query types.
# Display domain name-to-IP address mappings of both query types.
<Sysname> display dns host
Type:
Total number: 3
No.  Host name       Interface    Type  TTL      QType IP Count IP addresses
1    sample.com                   D     3132     A     3         192.168.10.1
        192.168.10.2
        192.168.10.3
2    zig.sample.com               S     -        A     1        192.168.1.1
3    sample.net                   S     -        AAAA  1        FE80::4904:4448
No.
Sequence number.
Host name
Domain name.
Name of the output interface.
Domain name-to-IP address mapping type:
·     S—A static mapping configured by the ip host or ipv6 host command.
·     D—A mapping dynamically obtained through dynamic domain name resolution. ‌
TTL
Time in seconds that a mapping can be stored in the cache.
For a static mapping, a hyphen (-) is displayed.
Query type
Query type: A and AAAA.
IP Count
Number of IP addresses corresponding to the domain name.
IP addresses
Replied IP addresses:
·     For a type A query, the replied IP addresses are IPv4 addresses.
·     For a type AAAA query, the replied IP addresses are IPv6 addresses.
ip host
ipv6 host
reset dns host
display dns server
Use display dns server to display IPv4 DNS server information.
display dns server [ dynamic ]
dynamic: Displays IPv4 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays statically configured and dynamically obtained IPv4 DNS server information.
# Display IPv4 DNS server information for the public network.
<Sysname> display dns server
Type:
No. Type  IP address
1   S     202.114.0.124
2   S     169.254.65.125
No.
Sequence number.
DNS server type:
·     S—A manually configured DNS server.
·     D—DNS server information dynamically obtained through DHCP or other protocols. ‌
IP address
IPv4 address of the DNS server.
dns server
display dns server health status
Use display dns server health status to display health status of DNS servers.
# Display health status of DNS servers.
<Sysname> display dns server health status
No. DNS server           OutInterface     VPN name                        Status
1   1.1.1.1              -                vpn1                            Up
2   2::1                 -                                                Up
3   FE80::1              -                vpn1                            Up
No.
Sequence number.
DNS server
Address of the DNS server.
OutInterface
Output interface of the DNS server.
This field is displayed only when the DNS server address is a local IPv6 link address.
VPN name
VPN instance name. If this field is empty, the domain name rule is on the public network.
Status
Result of the health check:
·     Up—The DNS server is available.
·     Down—The DNS server is unavailable.
health-check enable
display ipv6 dns server
Use display ipv6 dns server to display IPv6 DNS server information.
display ipv6 dns server [ dynamic ]
dynamic: Displays IPv6 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained IPv6 DNS server information.
# Display IPv6 DNS server information for the public network.
<Sysname> display ipv6 dns server
Type:
No. Type  IPv6 address                             Outgoing Interface
1   S     2::2
Table 5 Command output
No.
Sequence number.
DNS server type:
IPv6 address
IPv6 address of the DNS server.
Outgoing Interface
Output interface.
ipv6 dns server
dns cache ttl
Use dns cache ttl to set the TTL value for DNS entries.
Use undo dns cache ttl to cancel the TTL configuration for DNS entries.
dns cache ttl { maximum max-value | minimum min-value } *
undo dns cache ttl [ maximum | minimum ]
The TTL value for DNS entries is the TTL value in the DNS reply.
maximum max-value: Specifies the maximum TTL value for DNS entries, in the range of 60 to 3600 seconds.
minimum min-value: Specifies the minimum TTL value for DNS entries, in the range of 60 to 3600 seconds. The value for the min-value argument must be smaller than that for the max-value argument.
The device periodically sends a DNS request to the DNS server according to the TTL for DNS entries, which consumes CPU resources. If the TTL value is too small, the device sends DNS requests frequently to the DNS server, which consumes more CPU resources. If the TTL value is too large, DNS mappings cannot be updated in time. To avoid such issues, you can use this command to set the TTL value for DNS entries.
By default, the DNS client obtains the TTL for the following DNS entries from the DNS reply:
·     DNS entries generated from DNS transparent proxy.
·     DNS entries generated from DNS snooping.
·     Dynamic domain name resolution cache generated from the DNS server/DNS server group.
After you set the TTL value for DNS entries, the device specifies the TTL for DNS entries as follows:
·     If the TTL value in the DNS reply is smaller than the minimum TTL value, the device uses the minimum TTL value as the TTL for DNS entries. If the TTL value is greater than or equal to the minimum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
·     If the TTL value in the DNS reply is greater than the maximum TTL value, the device uses the maximum TTL value as the TTL for DNS entries. If the TTL value is smaller than or equal to the maximum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
After you execute this command, the configuration only takes effect on the subsequent DNS entries generated from DNS transparent proxy, DNS snooping, and DNS server/DNS server group.
After you execute the undo dns cache ttl command, the current TTL for the existing DNS entries still works.
If you do not specify any keywords when you execute the undo dns cache ttl command, this command cancels all TTL configuration for DNS entries.
If you execute the dns cache ttl minimum, dns cache ttl maximum, or dns cache ttl minimum maximum command multiple times, the most recent configuration takes effect.
# Set the maximum TTL value for DNS entries to 3600 seconds and the minimum TTL value for DNS entries to 180 seconds.
[Sysname] dns cache ttl maximum 3600 minimum 180
dns server
dns server-group
dns snooping enable
dns transparent-proxy enable
dns domain
Use dns domain to configure a domain name suffix.
Use undo dns domain to delete the specified domain name suffix.
dns domain domain-name
undo dns domain domain-name
No domain name suffix is configured. Only the provided domain name is resolved.
domain-name: Specifies a domain name suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, example.com. The domain name suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
For domain name resolution, the resolver automatically uses the suffix list to supply the missing part of an incomplete name entered by a user.
A domain name suffix applies to both IPv4 DNS and IPv6 DNS.
The system allows a maximum of 16 domain name suffixes for the public network.
# Configure domain name suffix com for the public network.
[Sysname] dns domain com
display dns domain
dns dscp
Use dns dscp to set the DSCP value for DNS packets sent by a DNS client or DNS proxy.
Use undo dns dscp to restore the default.
dns dscp dscp-value
undo dns dscp
The DSCP value is 0 in DNS packets sent by a DNS client or DNS proxy.
dscp-value: Specifies the DSCP value in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for outgoing DNS packets.
[Sysname] dns dscp 30
dns fast-reply enable
Use dns fast-reply enable to enable DNS fast-reply.
Use undo dns fast-reply enable to disable DNS fast-reply.
DNS fast-reply is disabled.
As DNS fast-reply can process a large number of DNS requests per second, use this feature in scenarios that require high DNS packet processing performance.
With this feature enabled, the device monitors the received DNS requests (only UDP packets are supported in the current software version). Then, it resolves the domain names in the requests, and searches for a match in the local static domain name resolution table.
·     If a match is found, the device sends a DNS reply to the DNS client.
·     If no match is found, the device forwards the query to the DNS server.
This command enables both IPv4 DNS fast-reply and IPv6 DNS fast-reply.
The dns fast-reply enable and dns transparent-proxy enable commands are mutually exclusive. After one command is executed, the other command cannot be executed.
# Enable DNS fast-reply.
[Sysname] dns fast-reply enable
dns proxy enable
Use dns proxy enable to enable DNS proxy.
Use undo dns proxy enable to disable DNS proxy.
dns proxy enable
DNS proxy is disabled.
This configuration applies to both IPv4 DNS and IPv6 DNS.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns redirect enable
Use dns redirect enable to enable DNS redirection.
Use undo dns redirect enable to disable DNS redirection.
dns redirect enable
DNS redirection is disabled.
With DNS redirection enabled, the device monitors the received DNS requests (only UDP packets are supported in the current software version) and resolves the source IP addresses, source port numbers, and domain names. Then, the device searches for a matching domain name rule and redirects the request to the DNS server in the rule.
The device enabled with DNS redirection works as follows:
1.     The device searches for a matching domain name rule.
¡     If a match is found, it replaces the destination IP address in the request with the IP address of the first reachable DNS server in the server group bound to the rule. Then, the device forwards the request to the DNS server.
¡     If no match is found, the device does not redirect the DNS request.
2.     The device records the replacement, including the source IP address, source port number, and requested server address in the DNS request, and the replaced server address
3.     Upon receiving the DNS reply, the device replaces the source IP address in the reply with the original server address in the request.
This configuration applies to both IPv4 DNS redirection and IPv6 DNS redirection.
The dns redirect enable and dns transparent-proxy enable commands are mutually exclusive. After one command is executed, the other command cannot be executed.
# Enable DNS redirection.
[Sysname] dns redirect enable
dns server
Use dns server to specify the IPv4 address of a DNS server.
Use undo dns server to remove the IPv4 address of a DNS server.
dns server ip-address[ priority priority ]
undo dns server [ ip-address ]
No DNS server IPv4 address is specified.
Interface view
ip-address: Specifies the IPv4 address of a DNS server. When you execute the undo form of the command in interface view, you must specify this argument.
priority priority-value: Specifies the DNS server priority. The value range for the priority-value argument is 1 to 255 and the default is 100. A smaller value indicates a higher priority.
Operating mechanism
The device sends a DNS query to the DNS servers in descending order of their priorities. If they have the same priority, the device sends the DNS query to the DNS servers in ascending order of their IPv4 addresses. You can edit the priority of DNS servers to change the DNS query sending order.
The system allows a maximum of six DNS server IPv4 addresses for the public network.
If you do not specify an IPv4 address, the undo dns server command removes all DNS server IPv4 addresses for the public network.
# Specify DNS server IPv4 address 172.16.1.1.
[Sysname] dns server 172.16.1.1
# Specify DNS server IPv4 address 172.16.1.1 on VLAN-interface 2.
[Sysname-Vlan-interface2] dns server 172.16.1.1
display dns server
dns source-interface
Use dns source-interface to specify the source interface for DNS packets.
Use undo dns source-interface to restore the default.
dns source-interface interface-type interface-number
undo dns source-interface interface-type interface-number
No source interface is specified for DNS packets. The device uses the primary IP address of the output interface of the matching route as the source IP address for a DNS request.
This configuration applies to both IPv4 and IPv6.
In IPv4 DNS, the device uses the primary IPv4 address of the specified source interface as the source IP address of a DNS query. In IPv6 DNS, the device selects an IPv6 address of the specified source interface as the source IP address of a DNS query. The method of selecting the IPv6 address is defined in RFC 3484.
The system allows only one source interface for the public network. If you execute this command multiple times, the most recent configuration takes effect.
# Specify VLAN-interface 2 as the source interface for DNS packets on the public network.
[Sysname] dns source-interface vlan-interface 2
dns spoofing
Use dns spoofing to enable DNS spoofing and specify the IPv4 address for spoofing DNS requests.
Use undo dns spoofing to disable DNS spoofing.
dns spoofing ip-address
undo dns spoofing ip-address
DNS spoofing is disabled.
ip-address: Specifies the IPv4 address used to spoof DNS requests.
Use the dns spoofing command together with the dns proxy enable command.
DNS spoofing functions when the DNS proxy does not know the DNS server address or cannot reach the DNS server. It enables the DNS proxy to spoof DNS queries of type A by responding with the specified IPv4 address.
The system allows only one replied IPv4 address for the public network. If you execute this command multiple times, the most recent configuration takes effect.
# Enable DNS spoofing for the public network and specify IPv4 address 1.1.1.1 for spoofing DNS requests.
[Sysname] dns spoofing 1.1.1.1
dns proxy enable
dns trust-interface
Use dns trust-interface to specify a DNS trusted interface.
Use undo dns trust-interface to remove a DNS trusted interface.
dns trust-interface interface-type interface-number
undo dns trust-interface [ interface-type interface-number ]
No DNS trusted interface is specified.
By default, an interface obtains DNS suffix and DNS server information from DHCP. A network attacker might act as the DHCP server to assign a wrong DNS suffix and DNS server address to the device. As a result, the device fails to obtain the resolved IP address or might get the wrong IP address. With the DNS trusted interface specified, the device only uses the DNS suffix and DNS server information obtained through the trusted interface to avoid attacks.
You can configure a maximum of 128 DNS trusted interfaces on the device.
If you do not specify an interface, the undo dns trust-interface command removes all DNS trusted interfaces and restores the default.
# Specify VLAN-interface 2 as a DNS trusted interface.
[Sysname] dns trust-interface vlan-interface 2
health-check enable
Use health-check enable to enable DNS server health check.
Use undo health-check enable to disable DNS server health check.
health-check enable
DNS server health check is disabled.
DNS server group view
When the device enabled with DNS redirection receives a DNS request that matches a domain name rule, the device forwards the request to a DNS server. The DNS server is selected according to the server order displayed in the display this command.
If the device does not receive a DNS reply from the DNS server within two seconds, it reselects a DNS server. To prevent the device from selecting an unavailable DNS server, execute the health-check enable command to detect the availability of DNS servers. After you execute the command on the device, it works as follows:
1.     The device periodically sends a DNS request to each DNS server in the DNS server group.
2.     If the device receives a DNS reply from a DNS server, it regards the DNS server available.
3.     If the device does not receive any DNS reply from a DNS server after it sends a DNS request to the DNS server for three consecutive times, it regards the DNS server unavailable.
4.     Upon receiving a DNS request that matches a domain name rule, the device ignores the unavailable DNS servers automatically and selects a DNS server according to the lexicographical order.
# Enable health check for DNS servers in DNS server group 1.
[Sysname] dns server-group 1
[Sysname-server-group-1] health-check enable
ip host
Use ip host to create a host name-to-IPv4 address mapping.
Use undo ip host to remove a host name-to-IPv4 address mapping.
ip host host-name ip-address
undo ip host host-name ip-address
No host name-to-IPv4 address mappings exist.
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.). A host name must meet the following requirements:
·     The host name string is separated by dots (.). Each separated part includes up to 63 characters.
·     The host name cannot start or end with a dot (.).
·     The host name cannot contain two consecutive dots (..).
ip-address: Specifies the IPv4 address of the host.
The system allows a maximum of 1024 host name-to-IPv4 address mappings for the public network.
For the public network, each host name maps to only one IPv4 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping command parameter ip, -a, -c, -f, -h, -i, -m, -n, -p, -q, -r, -s, -t, -tos, or -v as the host name. For more information about the ping command parameters, see Network Management and Monitoring Command Reference.
# Map IPv4 address 10.110.0.1 to host name aaa for the public network.
[Sysname] ip host aaa 10.110.0.1
display dns host
ipv6 dns dscp
Use ipv6 dns dscp to set the DSCP value for IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
Use undo ipv6 dns dscp to restore the default.
ipv6 dns dscp dscp-value
undo ipv6 dns dscp
The DSCP value is 0 in IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
# Set the DSCP value to 30 for outgoing IPv6 DNS packets.
[Sysname] ipv6 dns dscp 30
ipv6 dns server
Use ipv6 dns server to specify the IPv6 address of a DNS server.
Use undo ipv6 dns server to remove the IPv6 address of a DNS server.
ipv6 dns server ipv6-address [ interface-type interface-number ] [ priority priority ]
undo ipv6 dns server [ ipv6-address [ interface-type interface-number ] ]
No DNS server IPv6 address is specified.
ipv6-address: Specifies the IPv6 address of a DNS server.
interface-type interface-number: Specifies the output interface by its type and number. If you do not specify an interface, the device forwards DNS packets out of the output interface of the matching route. Specify this argument if the IPv6 address of the DNS server is a link-local address. Do not specify this argument if the IPv6 address of the DNS server is a global unicast address.
Operating mechanism
The device sends a DNS query to the DNS servers in descending order of their priorities. If they have the same priority, the device sends the DNS query to the DNS servers in ascending order of their IPv6 addresses. You can edit the priority of DNS servers to change the DNS query sending order.
The system allows a maximum of six DNS server IPv6 addresses for the public network.
If you do not specify an IPv6 address, the undo ipv6 dns server command removes all DNS server IPv6 addresses for the public network.
# Specify DNS server IPv6 address 2002::1 for the public network.
[Sysname] ipv6 dns server 2002::1
ipv6 dns spoofing
Use ipv6 dns spoofing to enable DNS spoofing and specify the IPv6 address to spoof DNS requests.
Use undo ipv6 dns spoofing to disable DNS spoofing.
ipv6 dns spoofing ipv6-address
undo ipv6 dns spoofing ipv6-address
ipv6-address: Specifies the IPv6 address used to spoof DNS requests.
Use the ipv6 dns spoofing command together with the dns proxy enable command.
DNS spoofing functions when the DNS proxy does not know the DNS server address or cannot reach the DNS server. It enables the DNS proxy to spoof DNS queries of type AAAA by responding with the specified IPv6 address.
The system allows only one replied IPv6 address for the public network. If you execute this command multiple times, the most recent configuration takes effect.
# Enable DNS spoofing for the public network and specify IPv6 address 2001::1 for spoofing DNS requests.
[Sysname] ipv6 dns spoofing 2001::1
dns proxy enable
ipv6 host
Use ipv6 host to create a host name-to-IPv6 address mapping.
Use undo ipv6 host to remove a host name-to-IPv6 address mapping.
ipv6 host host-name ipv6-address
undo ipv6 host host-name ipv6-address
No host name-to-IPv6 address mappings exist.
ipv6-address: Specifies the IPv6 address of the host.
The system allows a maximum of 1024 host name-to-IPv6 address mappings for the public network.
For the public network, each host name maps to only one IPv6 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping ipv6 command parameter -a, -c, -i, -m, -q, -s, -t, -tc, or -v as the host name. For more information about the ping ipv6 command parameters, see Network Management and Monitoring Command Reference.
# Map IPv6 address 2001::1 to host name aaa for the public network.
[Sysname] ipv6 host aaa 2001::1
ip host
reset dns host
Use reset dns host to clear dynamic DNS entries.
reset dns host [ ip | ipv6 ]
If you do not specify the ip or ipv6 keyword, the reset dns host command clears dynamic DNS entries of both query types.
Use this command to clear the following dynamic DNS entries:
·     Dynamic DNS entries on the DNS client.
·     Dynamic DNS entries on the device enabled with DNS transparent proxy or DNS snooping.
# Clear dynamic DNS entries of all query types for the public network.
<Sysname> reset dns host
display dns host
dns snooping enable
