- 16-Security Configuration Guide
- 01-Keychain configuration
- 02-Public key management
- 03-PKI configuration
- 04-Crypto engine configuration
- 05-SSH configuration
- 06-SSL configuration
- 07-Packet filter configuration
- 08-DHCP snooping configuration
- 09-DHCPv6 snooping configuration
- 10-ARP attack protection configuration
- 11-ND attack defense configuration
- 12-Attack detection and prevention configuration
- 13-IP-based attack prevention configuration
- 14-IP source guard configuration
- 15-uRPF configuration
- 16-FIPS configuration
- 17-APR configuration
06-SSL configuration | 110.41 KB |
Restrictions and guidelines: SSL configuration
Configuring an SSL server policy
Configuring an SSL client policy
Disabling SSL protocol versions for the SSL server
Disabling SSL session renegotiation
Enabling the server-preferred order during cipher suite negotiation
Configuring SSL
About SSL
Secure Sockets Layer (SSL) is a cryptographic protocol that provides communication security for TCP-based application layer protocols such as HTTP. SSL has been widely used in applications such as e-business and online banking to provide secure data transmission over the Internet.
SSL security services
SSL provides the following security services:
· Privacy—SSL uses a symmetric encryption algorithm to encrypt data. It uses the asymmetric key algorithm of RSA to encrypt the key used by the symmetric encryption algorithm. For more information about RSA, see "Managing public keys."
· Authentication—SSL uses certificate-based digital signatures to authenticate the SSL server and client. The SSL server and client obtain digital certificates through PKI. For more information about PKI and digital certificates, see "Configuring PKI."
· Integrity—SSL uses the message authentication code (MAC) to verify message integrity. It uses a MAC algorithm and a key to transform a message of any length to a fixed-length message. Any change to the original message will result in a change to the calculated fixed-length message. As shown in Figure 1, the message integrity verification process is as follows:
a. The sender uses a MAC algorithm and a key to calculate a MAC value for a message. Then, it appends the MAC value to the message and sends the message to the receiver.
b. The receiver uses the same key and MAC algorithm to calculate a MAC value for the received message, and compares it with the MAC value appended to the message.
c. If the two MAC values match, the receiver considers the message intact. Otherwise, the receiver considers that the message was tampered with and it discards the message.
Figure 1 MAC algorithm diagram
SSL protocol stack
The SSL protocol stack includes the following protocols:
· SSL record protocol at the lower layer.
· SSL handshake protocol, SSL change cipher spec protocol, and SSL alert protocol at the upper layer.
The following describes the major functions of SSL protocols:
· SSL record protocol—Fragments data received from the upper layer, computes and adds MAC to the data, and encrypts the data.
· SSL handshake protocol—Negotiates the cipher suite used for secure communication, authenticates the server and client, and securely exchanges the keys between the server and client. The cipher suite that needs to be negotiated includes the symmetric encryption algorithm, key exchange algorithm, and MAC algorithm.
· SSL change cipher spec protocol—Notifies the receiver that subsequent packets are to be protected based on the negotiated cipher suite and key.
· SSL alert protocol—Sends alert messages to the receiving party. An alert message contains the alert severity level and a description.
SSL protocol versions include SSL 2.0, SSL 3.0, TLS 1.0 (or SSL 3.1), TLS 1.1, TLS 1.2, and TLS 1.3. Because SSL 3.0 is known to be insecure, you can disable SSL 3.0 for the SSL server to ensure security.
By default, the SSL server can communicate with clients running all SSL protocol versions. When the server receives an SSL 2.0 Client Hello message from a client, it notifies the client to use a later version for communication.
SSL tasks at a glance
To configure SSL, perform the following tasks:
1. Configure an SSL server:
¡ Configuring an SSL server policy
¡ (Optional.) Disabling SSL protocol versions for the SSL server
¡ (Optional.) Disabling SSL session renegotiation
2. Configure an SSL client:
3. Enabling the server-preferred order during cipher suite negotiation
An SSL server policy is a set of SSL parameters used by the device when the device acts as the SSL server. An SSL server policy takes effect only after it is associated with an application such as HTTPS.
Some services (such as SSL VPN, load balancing, and proxy policy) might require using two digital certificates on the server. To meet the requirement, you can use this command to specify two PKI domains in the SSL server policy at a time, so that the SSL server policy can associate with two digital certificates.
1. Enter system view.
2. Create an SSL server policy and enter its view.
ssl server-policy policy-name
3. Specify a PKI domain for the SSL server policy.
pki-domain domain-name&<1-2>
By default, no PKI domain is specified for an SSL server policy.
If SSL server authentication is required, you must specify a PKI domain and request a local certificate for the SSL server in the domain.
For information about configuring a PKI domain, see "Configuring PKI."
4. Specify the cipher suites that the SSL server policy supports.
ciphersuite { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecc_sm2_sm1_sm3 | ecc_sm2_sm4_sm3 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_sm2_sm1_sm3 | ecdhe_sm2_sm4_sm3 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_sm1_sha | rsa_sm1_sm3 | rsa_sm4_sha | rsa_sm4_sm3 | rsa_aes_256_cbc_sha256 rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha | tls_aes_128_ccm_sha256 | tls_aes_128_ccm_8_sha256 | tls_aes_128_gcm_sha256 | tls_aes_256_gcm_sha384 | tls_chacha20_poly1305_sha256 } *<1-11>
By default, an SSL server policy supports all cipher suties.
5. (Optional.) Set the maximum number of sessions that the SSL server can cache and the session cache timeout time.
By default, the SSL server can cache a maximum of 500 sessions, and the session cache timeout time is 3600 seconds.
6. Enable mandatory or optional SSL client authentication.
By default, SSL client authentication is disabled. The SSL server does not perform digital certificate-based authentication on SSL clients.
When authenticating a client by using the digital certificate, the SSL server verifies the certificate chain presented by the client. It also verifies that the certificates in the certificate chain (except the root CA certificate) are not revoked.
7. (Optional.) Enable the SSL server to send the complete certificate chain to the client during SSL negotiation.
certificate-chain-sending enable
By default, the SSL server sends the server certificate rather than the complete certificate chain to the client during negotiation.
8. (Optional.) Associate the SSL server policy with a server name.
server-name server-name
By default, no server name is associated with an SSL server policy.
An SSL client policy is a set of SSL parameters used by the device when the device acts as the SSL client. The SSL client uses the settings in the client policy to establish a connection to the server. An SSL client policy takes effect only after it is associated with an application such as DDNS. For information about DDNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
As a best practice to enhance system security, do not specify SSL 3.0 for the SSL client policy.
2. Create an SSL client policy and enter its view.
ssl client-policy policy-name
3. Specify a PKI domain for the SSL client policy.
By default, no PKI domain is specified for an SSL client policy.
If SSL client authentication is required, you must specify a PKI domain and request a local certificate for the SSL client in the PKI domain.
4. Specify the preferred cipher suite for the SSL client policy.
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecc_sm2_sm1_sm3 | ecc_sm2_sm4_sm3 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_sm2_sm1_sm3 | ecdhe_sm2_sm4_sm3 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_sm1_sha | rsa_sm1_sm3 | rsa_sm4_sha | rsa_sm4_sm3 |rsa_rc4_128_md5 | rsa_rc4_128_sha | tls_aes_128_ccm_sha256 | tls_aes_128_ccm_8_sha256 | tls_aes_128_gcm_sha256 | tls_aes_256_gcm_sha384 | tls_chacha20_poly1305_sha256 } *<1-11>
By default, the preferred cipher suites of an SSL client policy are the following:
¡ rsa_aes_128_cbc_sha256
¡ rsa_aes_256_cbc_sha256
¡ dhe_rsa_aes_256_cbc_sha
¡ dhe_rsa_aes_128_cbc_sha
¡ ecdhe_ecdsa_aes_128_gcm_sha256
¡ ecdhe_rsa_aes_128_gcm_sha256
¡ ecdhe_ecdsa_aes_256_gcm_sha384
¡ ecdhe_rsa_aes_256_gcm_sha384
¡ ecdhe_ecdsa_aes_128_cbc_sha256
¡ ecdhe_rsa_aes_128_cbc_sha256
¡ rsa_3des_cbc_sha
5. Specify the SSL protocol version for the SSL client policy.
version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2 | tls1.3 }
By default, an SSL client policy uses TLS 1.0.
6. Enable the SSL client to authenticate servers through digital certificates.
server-verify enable
By default, SSL server authentication is enabled.
To enhance security, you can disable the SSL server from using specific SSL protocol versions for session negotiation.
Disabling an SSL protocol version does not affect the availability of earlier SSL protocol versions. For example, if you execute the ssl version tls1.1 disable command, TLS 1.1 is disabled but TLS 1.0 is still available for the SSL server.
2. Disable SSL protocol versions for the SSL server.
ssl version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2 | tls1.3 } * disable
By default, an SSL server can use SSL 3.0, TLS 1.0, TLS 1.1, TLS 1.2, and TLS 1.3 for session negotiation.
3. Enter SSL server policy view.
4. Disable SSL protocol versions in the SSL server policy.
By default, an SSL protocol version is enabled in an SSL sever policy unless it is explicitly disabled in system view by using the ssl version disable command.
The SSL session renegotiation feature enables the SSL client and server to reuse a previously negotiated SSL session for an abbreviated handshake.
Disabling session renegotiation causes more computational overhead to the system but it can avoid potential risks.
Disable SSL session renegotiation only when explicitly required.
2. Disable SSL session renegotiation.
ssl renegotiation disable
By default, SSL session renegotiation is enabled.
During SSL connection negotiation, the key exchange algorithm, symmetric encryption algorithm, and MAC algorithm used for message exchange between the SSL server and the SSL client will be determined. By default, the SSL server uses the order of cipher suites presented by the client to negotiate the cipher suite. That is, the SSL server chooses the first cipher suite in the client's list that matches any one of the server's cipher suites. If no match is found, the negotiation fails.
This feature allows you to select the server-preferred order for cipher suite negotiation. That is, the SSL server chooses the first cipher suite in its list that matches any one of the client's cipher suites. If no match is found, the negotiation fails.
The earlier a cipher suite is configured, the higher priority it has during the cipher suite negotiation.
2. Enter SSL server policy view.
3. Enable the server-preferred order for choosing a cipher suite during the cipher suite negotiation between the SSL server and SSL client.
ciphersuite server-preferred enable
By default, the client-preferred order for choosing a cipher suite during the cipher suite negotiation between the SSL server and SSL client.
Verifying and maintaining SSL
Perform all display tasks in in any view.
· Display SSL client policy information.
display ssl client-policy [ policy-name ]
· Display SSL server policy information.
display ssl server-policy [ policy-name ]
