01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10201-Fundamentals Command Reference
08-Emergency shell commands
08-Emergency shell commands 227.52 KB
File system names, directory names, or file names must be compliant with the naming conventions. For more information about the naming conventions and the methods for specifying the names, see Fundamentals Configuration Guide.
(In standalone mode.) Unless otherwise stated, a file or directory name argument in this chapter must contain the file system name and can have a maximum of 511 characters. The path information can contain multiple levels of directories, each of which can have 1 to 255 characters. The file name alone (without the path information) can include 1 to 255 characters.
(In IRF mode.) Unless otherwise stated, a file or directory name argument in this document must contain the file system name and cannot contain file system location information. The path information can contain multiple levels of directories, each of which can have 1 to 255 characters. The file name alone (without the path information) can have 1 to 255 characters. The entire argument can have 1 to 511 characters.
If the device has a flash memory and a CF card, you can access the flash memory and the CF card in emergency shell mode. Examples in this chapter use the flash memory. A different storage medium might be used on your device.
The following compatibility matrixes show the support of hardware platforms for emergency shell:
Hardware
Emergency shell compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK
Yes
MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1
Yes
MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3600-28-G-DP, MSR3600-51-G-DP
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
No
MSR 3610, MSR 3620, MSR 3640, MSR 3660
Yes
MSR 3620-DP
No
MSR3610-G, MSR3620-G
No
MSR3640-G
Yes
MSR3640-X1-HI
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
MSR3620-DP-WiNet
No
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
No
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
copy
Use copy to copy a file.
copy source-file { dest-file | dest-directory }
source-file: Specifies the file to be copied.
dest-file: Specifies the destination file.
dest-directory: Specifies the destination directory. The system uses the name of the source file as the name for the destination file.
If the destination file already exists, the system prompts whether or not to overwrite it. If you enter Y, the existing file is overwritten. If you enter N, the command is not executed.
# Copy the test.cfg file. Save the copy to testbackup.cfg.
<boot> copy flash:/test.cfg flash:/testbackup.cfg
Copy flash:/test.cfg to flash:/testbackup.cfg?[Y/N]:y
Start to copy flash:/test.cfg to flash:/testbackup.cfg...Done.
# Copy the test.cfg file and save the copy to testbackup.cfg. Overwrite the existing file that has the same name as the destination file.
flash:/testbackup.cfg already exists. Overwrite it?[Y/N]:y
delete
Use delete to permanently delete a file.
delete file
file: Specifies the file to be deleted.
# Delete the tt.cfg file.
<boot> delete flash:/tt.cfg
Delete flash:/tt.cfg? [Y/N]:y
Deleting the file permanently will take a long time. Please wait...
Start to delete flash:/tt.cfg...Done.
dir
Use dir to display files or directories.
dir [ /all ] [ file | directory ]
/all: Displays both hidden and non-hidden files and subdirectories.
file: Specifies a file or directory.
directory: Specifies a directory.
Remarks
Display all non-hidden files and subdirectories in the current directory.
dir
N/A
Display all files and subdirectories in the current directory.
dir /all
N/A
Display all non-hidden files and subdirectories in a directory.
dir directory
Specify a directory for the directory argument.
Display all files and subdirectories in a directory.
dir /all directory
Display a file.
dir file
Specify a file for the file argument.
# Display information about all files and directories in the system.
<boot> dir /all
Directory of flash:
     0      drw-           -  Jan 01 2012 00:06:09     01
     1      drw-           -  Sep 15 2012 04:03:14     pki
     2      drw-           -  Jan 01 2012 00:04:07     test
     4      drw-           -  Nov 05 2012 06:45:07     logfile
     5      -rwh          20  Oct 20 2012 09:09:52     .snmpboots
     6      drw-           -  Nov 05 2012 05:56:22     diagfile
     7      drwh           -  Aug 20 2012 09:23:48     .trash
     8      -rw-         816  Aug 20 2012 06:15:00     ifindex.dat
     9      -rw-        3231  Aug 31 2012 09:01:41     startup.cfg
    10      -rw-       60620  Aug 31 2012 09:01:43     startup.mdb
    11      drw-           -  Sep 30 2012 04:43:24     versionInfo
    12      drw-           -  Nov 05 2012 05:56:22     seclog
    13      -rwh          18  Aug 20 2012 09:09:34     .pathfile
    14      -rw-    11238400  Aug 30 2012 11:06:53     boot-t2301001.bin
    15      -rw-           0  Aug 31 2012 05:04:40     lauth.dat
    16      -rw-        4383  Oct 20 2012 06:15:00     test.cfg
61440 KB total (11108 KB free)
# Display all unhidden files and directories in the system.
<boot> dir
Directory of flash:
     5      drw-           -  Nov 05 2012 05:56:22     diagfile
     6      -rw-         816  Aug 20 2012 06:15:00     ifindex.dat
     7      -rw-        3231  Aug 31 2012 09:01:41     startup.cfg
     8      -rw-       60620  Aug 31 2012 09:01:43     startup.mdb
     9      drw-           -  Sep 30 2012 04:43:24     versionInfo
    10      drw-           -  Nov 05 2012 05:56:22     seclog
    11      -rw-    11238400  Aug 30 2012 11:06:53     boot-t2301001.bin
    12      -rw-           0  Aug 31 2012 05:04:40     lauth.dat
    13      -rw-        4383  Aug 20 2012 06:15:00     test.cfg
# Display information about the config.cfg file.
<boot> dir flash:/config.cfg
Directory of flash:
     0      -rw-        3231  Aug 31 2012 09:01:41     startup.cfg
Directory of
Current directory.
Information about a file or directory:
·     7—Index number, automatically assigned by the system.
·     -rw-—Attributes of the file or directory. The first character is the directory indicator (d for directory and - for file). The second character indicates whether the file or directory is readable (r for readable). The third character indicates whether the file or directory is writable (w for writable). The last character indicates whether the file or directory is hidden (h for hidden and - for visible).
·     3231—Size of the file, in bytes. For a directory, the value of this field is a hyphen (-).
·     Aug 31 2012 09:01:41—Time when the file was most recently modified.
·     startup.cfg—Name of the file or directory.
Total size of the storage medium and size of the free space, in kilobytes.
display copyright
Use display copyright to display copyright information.
display copyright
# Display copyright information.
<boot> display copyright
display install package
Use display install package to display information about a software package.
display install package package
package: Specifies a .bin file in the filesystemname/filename.bin format, for example, flash:/startup-system.bin. The file must be saved in the root directory of a file system on the device. The value string can have a maximum of 63 characters. (In standalone mode.)
package: Specifies a .bin system image file in the filesystemname/filename.bin format, for example, flash:/startup-system.bin. The file must be saved in the root directory of a file system on the current member device. The value string can have a maximum of 63 characters. The filesystemname cannot contain file system location information. (In IRF mode.)
# Display information about the system.bin software package.
<boot> display install package flash:/system-t6101010.bin
Verifying the file flash:/system-t6101010.bin ..................Done.
  [Package]
  Vendor: H3C
  Product: MSR26
  Service name: system
  Platform version: 7.1.070
  Product version: Test 0001010
  Supported board: MSR26-30
  [Component]
  Component: system
  Description: system package
Product
Product name.
Service name
Type of the service package:
·     boot—Boot image.
·     system—System image.
·     patch—Patch package.
If the value of this field is not boot, system, or patch, the service packet is a feature package.
Platform version
Platform version number.
Product version
Product version number. You determine whether the version of a system image matches that of a boot image by checking the value of this field.
Supported board
Supported member device models, including MSR810, MSR2600-6-X1, MSR2600-10-X1, MSR 26-30, MSR3600-28, MSR3600-51, MSR 36-10, MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR 36-20, MSR3620-DP, MSR 36-40, MSR 36-60, MSR2600-15-X1, and MSR2600-15-X1-T.
[Component]
Information about the components of the software package.
display interface m-eth0
Use display interface m-eth0 to display information about the management Ethernet interface M-Eth 0.
# Display information about management Ethernet interface M-Eth 0.
<boot> display interface m-eth0
 m-eth0 current state: UP
The Maximum transmit unit is 1500
Inet4 Address is 192.168.20.189/24
Inet6 Address is 1:1::1:1/64 Scope:Global
Inet6 Address is FE80::202:3FF:FE04:506/10 Scope:Link
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: c4ca-d94c-e201
IPV6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: c4ca-d94c-e201
Input:  8983 packets, 0 errors, 0 dropped, 0 overruns, 2 frame
Output: 431 packets, 0 errors, 0 dropped, 0 overruns, 0 carrier,
        0 collisions, 1000 txqueuelen
Input bytes:804168
Output bytes:30367
Physical layer status of the management Ethernet interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface has been enabled by using the undo shutdown command, but its physical status is down. The interface might not have a cable connected or the cable has a problem.
·     UP—The interface has been enabled by using the undo shutdown command, and its physical status is up.
Link layer status of the interface.
MTU of the interface.
Inet4 Address
IPv4 address of the interface. This field is displayed only when the device is configured with an IPv4 address.
Inet6 Address
IPv6 global unicast address of the interface. This field is displayed only when the device is configured with an IPv6 address.
IPv6 link-local address of the interface.
Link layer encapsulation type and hardware address for IPv4 packets.
Link layer encapsulation type and hardware address for IPv6 packets.
Statistics for received packets:
·     Total number.
·     Number of erroneous packets.
·     Number of dropped packets.
·     Number of packets encountering queue overflow errors.
·     Number of packets encountering frame queue errors.
Output: 431 packets, 0 errors, 0 dropped, 0 overruns, 0 carrier,  0 collisions, 1000 txqueuelen
Statistics for sent packets:
·     Total number.
·     Number of packets encountering carrier failures.
·     Number of packets with collision.
·     Number of packets permitted by the queue.
Input bytes
Total number of received bytes.
Output bytes
Total number of sent bytes.
display ip routing-table
Use display ip routing-table to display IPv4 routing information.
# Display IPv4 routing information.
<boot> display ip routing-table
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.116.0   *               255.255.255.0   U     0      0        0 m-eth0
default         192.168.116.1   0.0.0.0         UG    0      0        0 m-eth0
Destination
Destination address. For the default route, the value of this field is default.
Gateway
Gateway address. If no gateway is needed, the value of this field is an asterisk (*).
Genmask
Subnet mask. For the default route, the value of this field is 0.0.0.0.
Flags
Flags:
·     A—The route was learned from a route advertisement.
·     C—The route is a cached route used to fast forward packets.
·     D—The route is the default route learned through neighbor discovery.
·     G—The route is a gateway route.
·     H—The route is a host route.
·     U—The route can be used.
Metric
Cost of the route.
Ref
Number of times the route has been referenced by other route entries.
Use
Number of times the route has been matched.
Iface
Outbound interface.
display ipv6 routing-table
Use display ipv6 routing-table to display IPv6 routing information.
# Display IPv6 routing information.
<boot> display ipv6 routing-table
Kernel IPv6 routing table
Destination                                 Next Hop
::1/128                                     ::
    U     0      0        1 lo
FE80::201:2FF:FE03:406/128                  ::
    U     0      0        1 lo
FE80::/64                                   ::
    U     256    0        0 m-eth0
FF02::1:2/128                               FF02::1:2
    UC    0      2888     0 m-eth0
FF00::/8                                    ::
    U     256    0        0 m-eth0
Table 5 Command output
Flags
Flags:
Metric
Cost of the route.
Ref
Use
Iface
Outbound interface. If it is a loopback interface, the value of this field is lo.
display version
Use display version to display boot image version information.
display version
# Display boot image version information.
<boot> display version
format
Use format to format a file system.
format filesystem
filesystem: Specifies a file system.
Use this command with caution. This command permanently deletes all files and directories from the file system, including the startup image files and startup configuration files. The deleted files and directories cannot be restored. Without startup images, the device cannot reboot.
# Format the flash: file system.
<boot> format flash:
All data on flash: will be lost, continue?[Y/N]:y
Formatting flash:… Done.
ftp
Use ftp to access an FTP server.
ftp { server-ipv4-address | ipv6 server-ipv6-address } { get remote-file local-file | put local-file remote-file }
server-ipv4-address: Specifies the IPv4 address of the FTP server.
server-ipv6-address: Specifies the IPv6 address of the FTP server.
get remote-file local-file: Downloads a file from the FTP server. The remote-file argument indicates the file to be downloaded. The local-file argument indicates the name for the downloaded file.
put local-file remote-file: Uploads a file to the FTP server. The local-file argument indicates the file to be uploaded. The remote-file argument indicates the name for the uploaded file.
If the traffic is heavy and the file transfer speed is low, you can press Ctrl+C to abort the transfer and try again later.
# Log in to FTP server 192.168.1.100. Download the 111.txt file and save it to a local file named 222.txt.
<boot> ftp 192.168.1.100 get 111.txt flash:/222.txt
User: test
Password: ***
install load
Use install load to load a system image and start the Comware system.
install load system-package
system-package: Specifies a .bin system image file in the filesystemname/filename.bin format, for example, flash:/startup-system.bin. The file must be saved in the root directory of a file system on the device. The value string can have a maximum of 63 characters. (In standalone mode.)
system-package: Specifies a .bin system image file in the filesystemname/filename.bin format, for example, flash:/startup-system.bin. The file must be saved in the root directory of a file system on the current member device. The value string can have a maximum of 63 characters. The filesystemname cannot contain file system location information. (In IRF mode.)
This command modifies the main startup image list to include only the boot image and system image. The modification ensures that the device can reboot correctly.
After the Comware system starts up, you can load feature and patch images. For more information, see software upgrade in Fundamentals Configuration Guide.
# Load a system image and start the Comware system.
<boot> install load flash:/system.bin
Check package flash:/system.bin ...
Verifying the file flash:/system.bin ........Done.
Extracting package ...
Loading...
Cryptographic algorithms tests passed.
Line con1 is available.
Press ENTER to get started.
interface m-eth0
Use interface m-eth0 to enter management Ethernet interface view.
interface m-eth0
In management Ethernet interface view, you can assign an IP address to the interface and specify a gateway.
# Enter management Ethernet interface view.
<boot> system-view
[boot] interface m-eth0
[boot-m-eth0]
ip address
Use ip address to assign an IPv4 address to the management Ethernet interface.
Use undo ip address to restore the default.
ip address ip-address { mask-length | mask }
undo ip address
No IPv4 address is assigned to the management Ethernet interface.
Management Ethernet interface view
ip-address: Specifies an IPv4 address in dotted decimal notation.
mask-length: Specifies the length of the subnet mask, in the range of 1 to 31.
mask: Specifies the subnet mask in dotted decimal notation.
When the management Ethernet interface is manually shut down, assigning it an IPv4 address or removing its IPv4 address activates it at the same time.
The IP address assigned to the management Ethernet interface must be different from the IP addresses of the other devices on the network.
# Assign the IPv4 address 192.168.1.1/24 to the management Ethernet interface.
<boot> system-view
[boot-m-eth0] ip address 192.168.1.1 24
ip gateway
Use ip gateway to specify an IPv4 gateway for the management Ethernet interface.
Use undo ip gateway to restore the default.
ip gateway ip-address
undo ip gateway
No IPv4 gateway is specified for the management Ethernet interface.
ip-address: Specifies the IPv4 address of an IPv4 gateway in dotted decimal notation.
When the device needs to communicate with a device on a remote IPv4 network, you must specify an IPv4 gateway for the management Ethernet interface.
Changing or removing the IPv4 address of the management Ethernet interface deletes the interface's IPv4 gateway configuration.
# Configure the management Ethernet interface to use the IPv4 gateway 192.168.1.5.
<boot> system-view
[boot-m-eth0] ip gateway 192.168.1.5
ipv6 address
Use ipv6 address to assign an IPv6 address to the management Ethernet interface.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address prefix-length
undo ipv6 address
No IPv6 address is assigned to the management Ethernet interface .
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 1 to 127.
When the management Ethernet interface is manually shut down, assigning it an IPv6 address or removing its IPv6 address activates it at the same time.
# Assign the IPv6 address 2001::1/64 to the management Ethernet interface.
<boot> system-view
[boot-m-eth0] ipv6 address 2001::1 64
ipv6 gateway
Use ipv6 gateway to specify an IPv6 gateway for the management Ethernet interface.
Use undo ipv6 gateway to restore the default.
ipv6 gateway link-local
undo ipv6 gateway
No IPv6 gateway is specified for the management Ethernet interface.
link-local: Specifies the link-local address of an IPv6 gateway.
When the device needs to communicate with a device on a remote IPv6 network, you must specify an IPv6 gateway for the management Ethernet interface.
Changing or removing the IPv6 address of the management Ethernet interface deletes the interface's IPv6 gateway configuration.
# Configure the management Ethernet interface to use the IPv6 gateway FE80::BAAF:67FF:FE27:DCD0.
<boot> system-view
[boot-m-eth0] ipv6 gateway fe80::baaf:67ff:fe27:dcd0
mkdir
Use mkdir to create a directory.
mkdir directory
You can create a directory only in an existing directory. For example, to create the flash:/test/mytest directory, the directory test must already exist.
The name of the directory to be created must be unique in the parent directory.
# Create a directory named test.
<boot> mkdir flash:/test
Directory flash:/test created.
# Create a directory named subtest in the flash:/test directory.
<boot> mkdir flash:/test/subtest
Directory flash:/test/subtest created.
dir
rmdir
more
Use more to display the contents of a text file.
more file
file: Specifies a text file.
# Display the contents of the test.txt file.
<boot> more flash:/test.txt
Have a nice day.
move
Use move to move a file.
source-file: Specifies the name of the file to be moved, a case-insensitive string of 1 to 63 characters.
dest-file: Specifies the name for the destination file, a case-insensitive string of 1 to 63 characters.
dest-directory: Specifies the name of the directory, a case-insensitive string of 1 to 63 characters. The system moves the file without changing the file name.
If a file in the destination directory is using the destination file name, the system prompts whether or not to overwrite the existing file. If you enter Y, the existing file is overwritten. If you enter N, the command is not executed.
# Move the config.cfg file to the flash:/test directory.
<boot>move flash:/config.cfg flash:/test/
Move flash:/config.cfg to flash:/test/config.cfg?[Y/N]:y
<boot> dir flash:/test
Directory of flash:/test
     0      -rw-       77065  Oct 20 1939 06:15:02     config.cfg
ping
Use ping to check the connectivity to an IPv4 address.
ping [ -c count | -s size ] * ip-address
-c count: Specifies the number of ICMP echo requests to send, in the range of 1 to 2147483647. The default is 5.
-s size: Specifies the length (in bytes) of each ICMP echo request, in the range of 20 to 8100. The default is 56.
ip-address: Specifies the IPv4 address of the destination in dotted decimal notation.
When you execute the ping command, the device sends ICMP echo requests to the destination. You can press Ctrl+C to abort the ping operation.
# Check the connectivity to the destination 1.2.1.1.
<boot> ping 1.2.1.1
PING 1.2.1.1 (1.2.1.1): 56 data bytes
56 bytes from 1.2.1.1: seq=0 ttl=128 time=2.243 ms
56 bytes from 1.2.1.1: seq=1 ttl=128 time=0.717 ms
56 bytes from 1.2.1.1: seq=2 ttl=128 time=0.891 ms
56 bytes from 1.2.1.1: seq=3 ttl=128 time=0.745 ms
56 bytes from 1.2.1.1: seq=4 ttl=128 time=0.911 ms
--- 1.2.1.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.717/1.101/2.243 ms
Table 6 Command output
Checking the connectivity to the device at 1.2.1.1.
56 data bytes
Number of data bytes in each ICMP echo request.
Received an ICMP reply from the device at 1.2.1.1.
Fields of the reply:
·     bytes—Number of data bytes in the ICMP reply.
·     seq—Sequence number of the reply. You can examine the sequence numbers of replies to determine whether packets are missing, disordered, or duplicated.
·     ttl—TTL value in the ICMP reply.
·     time—Response time.
Statistics for packets sent and received during the ping operation.
Number of ICMP echo requests sent.
5 packets received
Number of ICMP echo replies received.
0% packet loss
Percentage of echo requests that failed to be echoed back.
Minimum/average/maximum response time, in milliseconds.
ping ipv6
Use ping ipv6 to check the connectivity to an IPv6 address.
ping ipv6 [ -c count | -s size ] * ipv6-address
-c count: Specifies the number of ICMPv6 echo requests to send, in the range of 1 to 2147483647. The default is 5.
-s size: Specifies the length (in bytes) of each ICMPv6 echo request, in the range of 20 to 8100. The default is 56.
Ipv6-address: Specifies the IPv6 address of the destination.
When you execute the ping ipv6 command, the device sends ICMPv6 echo requests to the destination. You can press Ctrl+C to abort the ping operation.
# Check the connectivity to the destination 2001::2.
<boot> ping ipv6 2001::2
ping ipv6 2001::2
PING 2001::2 (2001::2): 56 data bytes
56 bytes from 2001::2: seq=0 ttl=64 time=5.420 ms
56 bytes from 2001::2: seq=1 ttl=64 time=1.140 ms
56 bytes from 2001::2: seq=2 ttl=64 time=2.027 ms
56 bytes from 2001::2: seq=3 ttl=64 time=0.887 ms
56 bytes from 2001::2: seq=4 ttl=64 time=0.791 ms
--- 2001::2 ping statistics ---
round-trip min/avg/max = 0.791/2.053/5.420 ms
For information about the fields, see Table 6.
pwd
Use pwd to display the working directory.
pwd
# Display the working directory.
<boot> pwd
flash:
Use quit to return to the upper-level view.
# Return from management Ethernet interface view to user view.
[boot-m-eth0] quit
[boot] quit
<boot>
reboot
(In standalone mode.) Use reboot to reboot the device.
(In IRF mode.) Use reboot to reboot the current member device.
reboot
# (In standalone mode.) Reboot the device.
<boot> reboot
# (In IRF mode.) Reboot the current member device.
<boot> reboot
reset ssh public-key
Use reset ssh public-key to delete all SSH server public keys saved on the device.
The first time you use the ssh2 command to connect to an SSH server, the device saves the server's public key locally. The device can then use the public key to authenticate the server when you connect to the server from the device again. If the server changes its public key, the public keys will not match anymore and you cannot connect to the server. To solve this problem, use this command to delete all SSH server public keys saved on the device.
# Delete all SSH server public keys saved on the device.
<boot> ssh2 192.168.1.59
login as:client001
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
83:2d:b6:90:4a:1b:0e:c1:ea:af:09:3a:65:09:8a:b3.
Please contact your system administrator.
RSA host key for 192.168.1.59 has changed and you have requested strict checking
Host key verification failed.
<boot> reset ssh public-key
login as:client001
The authenticity of host '192.168.1.59 (192.168.1.59)' can't be established.
RSA key fingerprint is 83:2d:b6:90:4a:1b:0e:c1:ea:af:09:3a:65:09:8a:b3.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.59' (RSA) to the list of known hosts.
[email protected]'s password:
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
<Sysname.59>
rmdir
Use rmdir to delete an existing directory.
rmdir directory
directory: Specifies the directory to be deleted.
To delete a directory, first delete the files and subdirectories in the directory. To delete files, use the delete command.
# Delete the mydir directory.
<boot> rmdir flash:/mydir
Remove directory flash:/mydir?[Y/N]:y
Directory flash:/1 removed.
delete
dir
mkdir
shutdown
Use shutdown to shut down the management Ethernet interface.
Use undo shutdown to bring up the management Ethernet interface.
shutdown
The management Ethernet interface is up.
When the management Ethernet interface is not operating correctly, you can shut it down and then bring it up.
# Shut down the management Ethernet interface.
<boot> system-view
[boot-m-eth0] shutdown
# Bring up the management Ethernet interface.
[boot-m-eth0] undo shutdown
ssh2
Use ssh2 to log in to an SSH server.
ssh2 { server-ipv4-address | ipv6 server-ipv6-address }
server-ipv4-address: Specifies the IPv4 address of the SSH server in dotted decimal notation.
ipv6 server-ipv6-address: Specifies the IPv6 address of the SSH server.
If the SSH server does not respond, you can press Ctrl+C to abort the login attempt and try again later.
# Connect to the SSH server 192.168.1.59 for the first time.
login as:client001
RSA key fingerprint is 3d:ee:1f:f9:81:be:4f:aa:42:88:1c:ab:81:4e:95:6f.
<Syaname.59> quit
<boot>
# Connect to the SSH server 192.168.1.59 for the second time.
login as:client001
<Syaname.59>
Use system-view to enter system view from user view.
# Enter system view from user view.
<boot> system-view
[boot]
telnet
Use telnet to log in to a Telnet server.
telnet { server-ipv4-address | ipv6 server-ipv6-address }
server-ipv4-address: Specifies the IPv4 address of the Telnet server in dotted decimal notation.
server-ipv6-address: Specifies the IPv6 address of the Telnet server.
If the Telnet server does not respond, you can press Ctrl+K to abort the login attempt and try again later.
# Log in to the Telnet server 192.168.100.1.
<boot> telnet 192.168.100.1
tftp
Use tftp to access to a TFTP server.
tftp server-ipv4-address { get remote-file local-file | put local-file remote-file }
tftp ipv6 server-ipv6-address { get remote-file local-file | put local-file remote-file }
server-ipv4-address: Specifies the IPv4 address of the TFTP server in dotted decimal notation.
server-ipv6-address: Specifies the IPv6 address of the TFTP server.
get remote-file local-file: Downloads a file from the TFTP server. The remote-file argument indicates the file to be downloaded. The local-file argument indicates the name for the downloaded file.
put local-file remote-file: Uploads a file to the TFTP server. The local-file argument indicates the file to be uploaded. The remote-file argument indicates the name for the uploaded file.
# Download the 111.txt file from TFTP server 192.168.1.100, and save the copy to a local file named 222.txt.
<boot> tftp 192.168.1.100 get 111.txt flash:/222.txt
# Upload startup configuration file startup.cfg to TFTP server 192.168.1.100.
<boot> tftp 192.168.1.100 put flash:/startup.cfg startup.cfg
