01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10201-Fundamentals Command Reference
14-RAID management commands (routers)
14-RAID management commands (routers) 57.33 KB
RAID commands
RAID commands are supported only on MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG, MSR-iMC, MSR3610-I-XS, and 3610-IE-XS.
create raid
Use create raid to create a RAID.
create raid level level-number
RAID view
level level-number: Specifies a RAID level. The level-number argument is fixed at 1.
Only SIC slot 1 and slot 2 support inserting SIC-M2-SATA drives with SSD to create a RAID. All data on the drives will be cleared after they form a RAID.
Before creating a RAID, make sure that the SIC-M2-SATA drives in SIC slot 1 and slot 2 each have only one partition and the file system format is EXT4.
# Create a level-1 RAID.
[Sysname] raid
[Sysname-raid] create raid level 1
fdisk
format
display raid status
Use display raid status to display detailed RAID information.
display raid status
# Display detailed RAID information.
<Sysname> display raid status
 Name   Level   Status          Disks           Resync  Size(GB)
 md0    raid1   active      hdb0[0]hdc0[1]      0.3%    447
Name
RAID drive name.
Level
RAID level.
Status
RAID running status.
Disks
RAID member disks.
Resync
RAID member disk synchronization status:
·     A percentage—Synchronizing.
·     Done—The synchronization has completed.
·     None—The RAID has only one member disk.
Size(GB)
Available amount of storage space.
raid
Use raid to enter RAID view.
raid
# Enter RAID view.
[Sysname] raid
[Sysname-raid]
remove raid
Use remove raid to remove a RAID.
remove raid target
RAID view
target: Specifies a RAID by its drive name, which is fixed at md0.
# Remove a RAID.
[Sysname] raid
[Sysname-raid] remove raid md0
restore raid
Use restore raid to manually restore a RAID after replacing a damaged drive in the RAID with a new drive.
restore raid target
RAID view
target: Specifies a RAID by its drive name.
Verify that the new SIC-M2-SATA drive has only one partition and the file system format is EXT4.
·     If yes, the system automatically restores the RAID.
·     If no, configure the drive to have only one partition and set the file system format to EXT4. Then, use this command to manually restore the RAID.
RAID restoration will clear all data from the new SIC-M2-SATA drive.
# Manually restore the level-1 RAID.
[Sysname] raid
[Sysname-raid] restore raid md0
