00-Preface | 99.23 KB |
Preface
This installation guide describes the installation procedures for the H3C WX5860X access controller, including preparing for installing the controller, installing and accessing the controller, troubleshooting the controller, and maintaining the controller.
· Audience.
Audience
· Network planners.
· Network administrators working with the H3C WX5860X access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
For any comments or suggestions about product documentation, you can share with us by sending emails to [email protected].
Your comments or suggestions would be highly appreciated.
